In the code path of acpi_ev_initialize_region(), there is namespace
modification code unlocked. This patch tunes the code to make sure
such modification are always locked.
Fixes: 74f51b80a0c4 (ACPICA: Namespace: Fix dynamic table loading issues)
Tested-by: Imre Deak <imre.deak@intel.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
ACPICA commit 767ee53354e0c4b7e8e7c57c6dd7bf569f0d52bb
There are issues related to the namespace/interpreter locks, which causes
several ACPI functionalities not specification compliant. The lock issues
were detectec when we were trying to fix the functionalities (please see
Link # [1] for the details).
What's the lock issues? Let's first look into the namespace/interpreter
lock usages inside of the object evaluation and the table loading which are
the key AML interpretion code paths:
Table loading:
acpi_ns_load_table
L(Namespace)
acpi_ns_parse_table
acpi_ns_one_complete_parse(LOAD_PASS1/LOAD_PASS2)
acpi_ds_load1_begion_op
acpi_ds_load1_end_op
acpi_ds_load2_begion_op
acpi_ds_load2_end_op
U(Namespace)
Object evaluation:
acpi_ns_evaluate
L(Interpreter)
acpi_ps_execute_method
acpi_ds_exec_begin_op
acpi_ds_exec_end_op
U(Interpreter)
acpi_ns_load_table
L(Namespace)
U(Namespace)
L(Namespace)
U(Namespace)
address_space.Setup
address_space.Handler
acpi_os_wait_semaphore
acpi_os_acquire_mutex
acpi_os_sleep
L(Interpreter)
U(Interpreter)
L(Interpreter)
acpi_ex_resolve_node_to_value
U(Interpreter)
acpi_ns_check_return_value
Where:
1. L(Interpreter) means acquire(MTX_INTERPRETER);
2. U(Interpreter) means release(MTX_INTERPRETER);
3. L(Namespace) means acquire(MTX_NAMESPACE);
4. U(Namespace) means release(MTX_NAMESPACE);
We can see that acpi_ns_exec_module_code() (which invokes acpi_ns_evaluate) is
implemented in a deferred way just in order to avoid to reacquire the
namespace lock. This is in fact the root cause of many other ACPICA issues:
1. We now know for sure that the module code should be executed right in
place by the Windows AML interpreter. So in the current design, if
the region initializations/accesses or the table loadings (where the
namespace surely should be locked again) happening during the table
loading period, dead lock could happen because ACPICA never unlocks the
namespace during the AML interpretion.
2. ACPICA interpreter just ensures that all static namespace nodes (named
objects created during the acpi_load_tables()) are created
(acpi_ns_lookup()) with the correct lock held, but doesn't ensure that
the named objects created by the control method are created with the
same correct lock held. It requires the control methods to be executed
in a serial way after "loading a table", that's why ACPICA requires
method auto serialization.
This patch fixes these software design issues by extending interpreter
enter/exit APIs to hold both interpreter/namespace locks to ensure the lock
order correctness, so that we can get these code paths:
Table loading:
acpi_ns_load_table
E(Interpreter)
acpi_ns_parse_table
acpi_ns_execute_table
X(Interpreter)
acpi_ns_load_table
address_space.Setup
acpi_os_sleep
E(Interpreter)
X(Interpreter)
Object evaluation:
acpi_ns_evaluate
E(Interpreter)
X(Interpreter)
acpi_ns_load_table
address_space.Setup
acpi_os_sleep
E(Interpreter)
X(Interpreter)
Where:
1. E(Interpreter) means acquire(MTX_INTERPRETER, MTX_NAMESPACE);
2. X(Interpreter) means release(MTX_NAMESPACE, MTX_INTERPRETER);
After this change, we can see:
1. All namespace nodes creations are locked by the namespace lock.
2. All namespace nodes referencing are locked with the same lock.
3. But we also can notice a defact that, all namespace nodes deletions
could be affected by this change. As a consequence,
acpi_ns_delete_namespace_subtree() may delete a static namespace node that
is still referenced by the interpreter (for example, the parser scopes).
Currently, we needn't worry about the last defact because in ACPICA, table
unloading is not fully functioning, its design strictly relies on the fact
that when the namespace deletion happens, either the AML table or the OSPMs
should have been notified and thus either the AML table or the OSPMs
shouldn't reference deletion-related namespace nodes during the namespace
deletion. And this change still works with the above restrictions applied.
While making this a-step-forward helps us to correct the wrong grammar to
pull many things back to the correct rail. And pulling things back to the
correct rail in return makes it possible for us to support fully
functioning table unloading after doing many cleanups.
While this patch is generated, all namespace locks are examined to ensure
that they can meet either of the following pattens:
1. L(Namespace)
U(Namespace)
2. E(Interpreter)
X(Interpreter)
3. E(Interpreter)
X(Interpreter)
L(Namespace)
U(Namespace)
E(Interpreter)
X(Interpreter)
We ensure this by adding X(Interpreter)/E(Interpreter) or removing
U(Namespace)/L(Namespace) for those currently are executed in the following
order:
E(Interpreter)
L(Namespace)
U(Namespace)
X(Interpreter)
And adding E(Interpreter)/X(Interpreter) for those currently are executed
in the following order:
X(Interpreter)
E(Interpreter)
Originally, the interpreter lock is held for the execution AML opcodes, the
namespace lock is held for the named object creation AML opcodes. Since
they are actually same in MS interpreter (can all be executed during the
table loading), we can combine the 2 locks and tune the locking code better
in this way. Lv Zheng.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=153541 # [1]
Link: https://bugzilla.kernel.org/show_bug.cgi?id=121701 # [1]
Link: https://bugs.acpica.org/show_bug.cgi?id=1323
Link: https://github.com/acpica/acpica/commit/767ee533
Reported-and-tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reported-and-tested-by: Greg White <gwhite@kupulau.com>
Reported-and-tested-by: Dutch Guy <lucht_piloot@gmx.net>
Signed-off-by: Bob Moore <robert.moore@intel.com>
ACPICA commit b2294cae776f5a66a7697414b21949d307e6856f
This patch removes unwanted spaces for typedef. This solution doesn't cover
function types.
Note that the linuxize result of this commit is very giant and should have
many conflicts against the current Linux upstream. Thus it is required to
modify the linuxize result of this commit and the commits around it
manually in order to have them merged to the Linux upstream. Since this is
very costy, we should do this only once, and if we can't ensure to do this
only once, we need to revert the Linux code to the wrong indentation result
before merging the linuxize result of this commit. Lv Zheng.
Link: https://github.com/acpica/acpica/commit/b2294cae
All tool/utility signons.
Dual-license module header.
ACPICA commit dfa394471f6c01b2ee9433dbc143ec70cb9bca72
Mostly indentation inconsistencies across the code. Split
some long lines, etc.
Link: https://github.com/acpica/acpica/commit/dfa39447
ACPICA commit afb52611dbe7403551f93504d3798534f5c343f4
This patch cleans up the code of assigning the AML address to the
union acpi_operand_object.
The idea behind this cleanup is:
The AML address of the union acpi_operand_object should always be determined at
the point where the object is encountered. It should be started from the
first byte of the object. For example, the opcode of the object, the name
string of the user_term object, or the first byte of the packaged object
(where a pkg_length is prefixed). So it's not cleaner to have it assigned
here and there in the entire ACPICA source tree.
There are some special cases for the internal opcodes, before cleaning up
the internal opcodes, we should also determine the rules for the AML
addresses of the internal opcodes:
1. INT_NAMEPATH_OP: the address of the first byte for the name_string.
2. INT_METHODCALL_OP: the address of the first byte for the name_string.
3. INT_BYTELIST_OP: the address of the first byte for the byte_data list.
4. INT_EVAL_SUBTREE_OP: the address of the first byte for the
Region/Package/Buffer/bank_field/Field arguments.
5. INT_NAMEDFIELD_OP: the address to the name_seg.
6. INT_RESERVEDFIELD_OP: the address to the 0x00 prefix.
7. INT_ACCESSFIELD_OP: the address to the 0x01 prefix.
8. INT_CONNECTION_OP: the address to the 0x02 prefix.
9: INT_EXTACCESSFIELD_OP: the address to the 0x03 prefix.
10.INT_RETURN_VALUE_OP: the address of the replaced operand.
11.computational_data: the address to the
Byte/Word/Dword/Qword/string_prefix.
Before cleaning up the internal root scope of the aml_walk, turning it into
the term_list, we need to remember the aml_start address as the "Aml"
attribute for the union acpi_operand_object created by acpi_ps_create_scope_op().
Finally, we can delete some redundant AML address assignment in psloop.c.
Link: https://github.com/acpica/acpica/commit/afb52611
ACPICA commit 8990e73ab2aa15d6a0068b860ab54feff25bee36
Link: https://github.com/acpica/acpica/commit/8990e73a
Signed-off-by: David E. Box <david.e.box@linux.intel.com>
Update ACPICA copyrights to 2014. Includes all source headers and
signons for the various tools.
It is reported by kernel build test systems that all ACPICA source
files in the kernel tree have incorrect label indentation. This
patch changes default indent option used in the release process to
fix this bug. Lv Zheng.
After many years, different formatting for switch() has crept in.
This change makes every switch block identical. Chao Guan.
ACPICA bugzilla 997.
References: https://bugs.acpica.org/show_bug.cgi?id=997
Signed-off-by: Chao Guan <chao.guan@intel.com>
These macros/functions automatically insert a newline, so the
format string should not contain a newline at the end. (This allows
these functions to add information to the end of the output line.)
Includes all source headers and signons for the various tools.
1) Ensure that all functions that use the various TRACE macros
also use the appropriate ACPICA return macros.
2) Ensure that all normal return statements surround the return
expression (value) with parens.
Allows constructs like this:
If (XXXX)
Scope (\)
Signed-off-by: Feng Tang <feng.tang@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Update all copyrights to 2012.
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Moved this internal space id in preparation for ACPI 5.0 changes
that will include some new space IDs.
Split dsopcode.c into dsargs.c and dscontrol.c.
Split dsload.c into dsload2.c.
