path: root/crypto/tcrypt.c
2007-10-10[CRYPTO] xts: XTS blockcipher mode implementation without partial blocksRik Snel
XTS currently considered to be the successor of the LRW mode by the IEEE1619 workgroup. LRW was discarded, because it was not secure if the encyption key itself is encrypted with LRW. XTS does not have this problem. The implementation is pretty straightforward, a new function was added to gf128mul to handle GF(128) elements in ble format. Four testvectors from the specification http://grouper.ieee.org/groups/1619/email/pdf00086.pdf were added, and they verify on my system. Signed-off-by: Rik Snel <rsnel@cube.dyndns.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] seed: New cipher algorithmHye-Shik Chang
This patch adds support for the SEED cipher (RFC4269). This patch have been used in few VPN appliance vendors in Korea for several years. And it was verified by KISA, who developed the algorithm itself. As its importance in Korean banking industry, it would be great if linux incorporates the support. Signed-off-by: Hye-Shik Chang <perky@FreeBSD.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-18[CRYPTO] tcrypt: Add missing error checkHerbert Xu
The return value of crypto_hash_final isn't checked in test_hash_cycles. This patch corrects this. Thanks to Eric Sesterhenn for reporting this. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-02[CRYPTO] tcrypt: Use async blkcipher interfaceHerbert Xu
This patch converts the tcrypt module to use the asynchronous block cipher interface. As all synchronous block ciphers can be used through the async interface, tcrypt is still able to test them. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-03-21[CRYPTO] tcrypt: Fix error checking for comp allocationSebastian Siewior
This patch fixes loading the tcrypt module while deflate isn't available at all (isn't build). Signed-off-by: Sebastian Siewior <linux-crypto@ml.breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-07[CRYPTO] camellia: added the testing code of Camellia cipherNoriaki TAKAMIYA
This patch adds the code of Camellia code for testing module. Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-07[CRYPTO] tcrypt: Removed vestigial crypto_alloc_tfm callHerbert Xu
The crypto_comp conversion missed the last remaining crypto_alloc_tfm call. This patch replaces it with crypto_alloc_comp. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-07[CRYPTO] fcrypt: Add FCrypt from RxRPCDavid Howells
Add a crypto module to provide FCrypt encryption as used by RxRPC. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-07[CRYPTO] tcrypt: Added test vectors for sha384/sha512Andrew Donofrio
This patch adds tests for SHA384 HMAC and SHA512 HMAC to the tcrypt module. Test data was taken from RFC4231. This patch is a follow-up to the discovery (bug 7646) that the kernel SHA384 HMAC implementation was not generating proper SHA384 HMACs. Signed-off-by: Andrew Donofrio <linuxbugzilla@kriptik.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-12-06[CRYPTO] tcrypt: LRW test vectorsRik Snel
Do modprobe tcrypt mode=10 to check the included test vectors, they are from: http://grouper.ieee.org/groups/1619/email/pdf00017.pdf and from http://www.mail-archive.com/stds-p1619@listserv.ieee.org/msg00173.html. To make the last test vector fit, I had to increase the buffer size of input and result to 512 bytes. Signed-off-by: Rik Snel <rsnel@cube.dyndns.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-12-06[CRYPTO] tcrypt: Add test vectors of AES_XCBCKazunori MIYAZAWA
est vectors of XCBC with AES-128. Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] users: Use crypto_comp and crypto_has_*Herbert Xu
This patch converts all users to use the new crypto_comp type and the crypto_has_* functions. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] tcrypt: Use HMAC template and hash interfaceHerbert Xu
This patch converts tcrypt to use the new HMAC template rather than the hard-coded version of HMAC. It also converts all digest users to use the new cipher interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-21[CRYPTO] tcrypt: Use block ciphers where applicableHerbert Xu
This patch converts tcrypt to use the new block cipher type where applicable. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] tcrypt: Use test_hash for crc32cHerbert Xu
Now that crc32c has been fixed to conform with standard digest semantics, we can use test_hash for it. I've turned the last test into a chunky test. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] api: Get rid of flags argument to setkeyHerbert Xu
Now that the tfm is passed directly to setkey instead of the ctx, we no longer need to pass the &tfm->crt_flags pointer. This patch also gets rid of a few unnecessary checks on the key length for ciphers as the cipher layer guarantees that the key length is within the bounds specified by the algorithm. Rather than testing dia_setkey every time, this patch does it only once during crypto_alloc_tfm. The redundant check from crypto_digest_setkey is also removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] crc32c: Fix unconventional setkey usageHerbert Xu
The convention for setkey is that once it is set it should not change, in particular, init must not wipe out the key set by it. In fact, init should always be used after setkey before any digestion is performed. The only user of crc32c that sets the key is tcrypt. This patch adds the necessary init calls there. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] tcrypt: Speed benchmark support for digest algorithmsMichal Ludvig
This patch adds speed tests (benchmarks) for digest algorithms. Tests are run with different buffer sizes (16 bytes, ... 8 kBytes) and with each buffer multiple tests are run with different update() sizes (e.g. hash 64 bytes buffer in four 16 byte updates). There is no correctness checking of the result and all tests and algorithms use the same input buffer. Signed-off-by: Michal Ludvig <michal@logix.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] tcrypt: Return -EAGAIN from module_init()Michal Ludvig
Intentionaly return -EAGAIN from module_init() to ensure it doesn't stay loaded in the kernel. The module does all its work from init() and doesn't offer any runtime functionality => we don't need it in the memory, do we? Signed-off-by: Michal Ludvig <michal@logix.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-06[PATCH] s390: in-kernel crypto test vectorsJan Glauber
Add new test vectors to the AES test suite for AES CBC and AES with plaintext larger than AES blocksize. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[CRYPTO] Simplify one-member scatterlist expressionsHerbert Xu
This patch rewrites various occurences of &sg[0] where sg is an array of length one to simply sg. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-10-30[PATCH] Use sg_set_buf/sg_init_one where applicableDavid Hardeman
This patch uses sg_set_buf/sg_init_one in some places where it was duplicated. Signed-off-by: David Hardeman <david@2gen.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-09-01[CRYPTO]: Fix XTEA implementationAaron Grothe
The XTEA implementation was incorrect due to a misinterpretation of operator precedence. Because of the wide-spread nature of this error, the erroneous implementation will be kept, albeit under the new name of XETA. Signed-off-by: Aaron Grothe <ajgrothe@yahoo.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: Use CPU cycle counters in tcryptHerbert Xu
After using this facility for a while to test my changes to the cipher crypt() layer, I realised that I should've listend to Dave and made this thing use CPU cycle counters :) As it is it's too jittery for me to feel safe about relying on the results. So here is a patch to make it use CPU cycles by default but fall back to jiffies if the user specifies a non-zero sec value. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: Use template keys for speed tests if possibleHerbert Xu
The existing keys used in the speed tests do not pass the 3DES quality check. This patch makes it use the template keys instead. Other algorithms can supply template keys through the same interface if needed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: Add cipher speed testsHarald Welte
From: Reyk Floeter <reyk@vantronix.net> I recently had the requirement to do some benchmarking on cryptoapi, and I found reyk's very useful performance test patch [1]. However, I could not find any discussion on why that extension (or something providing a similar feature but different implementation) was not merged into mainline. If there was such a discussion, can someone please point me to the archive[s]? I've now merged the old patch into 2.6.12-rc1, the result can be found attached to this email. [1] http://lists.logix.cz/pipermail/padlock/2004/000010.html Signed-off-by: Harald Welte <laforge@gnumonks.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: Kill unnecessary strncpy from tcryptHerbert Xu
It seems that bad code tends to get copied (see test_cipher_speed). So let's kill this idiom before it spreads any further. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: White space and coding style clean up in tcryptHerbert Xu
