commit 180ce7e81030e1ef763d58f97f9ab840ff57d848 upstream.
When Steffen originally wrote the authenc async hash patch, he
correctly had EINPROGRESS checks in place so that we did not invoke
the original completion handler with it.
Unfortuantely I told him to remove it before the patch was applied.
As only MAY_BACKLOG request completion handlers are required to
handle EINPROGRESS completions, those checks are really needed.
This patch restores them.
Reported-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
This patch converts authenc to the new ahash interface.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Now that there are no more legacy hash implementations we can
remove the reference to crypto_hash.
As it is if an algorithm with a zero-length IV is used (e.g.,
NULL encryption) with authenc, authenc may generate an SG entry
of length zero, which will trigger a BUG check in the hash layer.
This patch fixes it by skipping the IV SG generation if the IV
size is zero.
This patch allows shash algorithms to be used through the old hash
interface. This is a transitional measure so we can convert the
underlying algorithms to shash before converting the users across.
Authenc works in two stages for encryption, it first encrypts and
then computes an ICV. The context memory of the request is used
by both operations. The problem is that when an asynchronous
encryption completes, we will compute the ICV and then reread the
context memory of the encryption to get the original request.
It just happens that we have a buffer of 16 bytes in front of the
request pointer, so ICVs of 16 bytes (such as SHA1) do not trigger
the bug. However, any attempt to uses a larger ICV instantly kills
the machine when the first asynchronous encryption is completed.
This patch fixes this by saving the request pointer before we start
the ICV computation.
crypto_authenc_givencrypt_done uses req->data as struct aead_givcrypt_request,
while it really points to a struct aead_request, causing this crash:
BUG: unable to handle kernel paging request at 6b6b6b6b
IP: [<dc87517b>] :authenc:crypto_authenc_genicv+0x23/0x109
*pde = 00000000
Oops: 0000 [#1] PREEMPT DEBUG_PAGEALLOC
Modules linked in: hifn_795x authenc esp4 aead xfrm4_mode_tunnel sha1_generic hmac crypto_hash]
Pid: 3074, comm: ping Not tainted (2.6.25 #4)
EIP: 0060:[<dc87517b>] EFLAGS: 00010296 CPU: 0
EIP is at crypto_authenc_genicv+0x23/0x109 [authenc]
EAX: daa04690 EBX: daa046e0 ECX: dab0a100 EDX: daa046b0
ESI: 6b6b6b6b EDI: dc872054 EBP: c033ff60 ESP: c033ff0c
DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068
Process ping (pid: 3074, ti=c033f000 task=db883a80 task.ti=dab6c000)
Stack: 00000000 daa046b0 c0215a3e daa04690 dab0a100 00000000 ffffffff db9fd7f0
dba208c0 dbbb1720 00000001 daa04720 00000001 c033ff54 c0119ca9 dc852a75
c033ff60 c033ff60 daa046e0 00000000 00000001 c033ff6c dc87527b 00000001
Call Trace:
[<c0215a3e>] ? dev_alloc_skb+0x14/0x29
[<c0119ca9>] ? printk+0x15/0x17
[<dc87527b>] ? crypto_authenc_givencrypt_done+0x1a/0x27 [authenc]
[<dc850cca>] ? hifn_process_ready+0x34a/0x352 [hifn_795x]
[<dc8353c7>] ? rhine_napipoll+0x3f2/0x3fd [via_rhine]
[<dc851a56>] ? hifn_check_for_completion+0x4d/0xa6 [hifn_795x]
[<dc851ab9>] ? hifn_tasklet_callback+0xa/0xc [hifn_795x]
[<c011d046>] ? tasklet_action+0x3f/0x66
[<c011d230>] ? __do_softirq+0x38/0x7a
[<c0105a5f>] ? do_softirq+0x3e/0x71
[<c011d17c>] ? irq_exit+0x2c/0x65
[<c010e0c0>] ? smp_apic_timer_interrupt+0x5f/0x6a
[<c01042e4>] ? apic_timer_interrupt+0x28/0x30
[<dc851640>] ? hifn_handle_req+0x44a/0x50d [hifn_795x]
This patch implements the givencrypt function for authenc. It simply
calls the givencrypt operation on the underlying cipher instead of encrypt.
This patch converts the authenc algorithm over to crypto_grab_skcipher
which is a prerequisite for IV generation.
This patch also changes authenc to set its ASYNC status depending on
the ASYNC status of the underlying skcipher.
This patch merges the common hashing code between encryption and decryption.
This patch changes setkey to use RTA_OK to check the validity of the
setkey request.
The ivsize should be fetched from ablkcipher, not blkcipher.
The scatterwalk infrastructure is used by algorithms so it needs to
move out of crypto for future users that may live in drivers/crypto
or asm/*/crypto.
This patch changes gcm/authenc to return EBADMSG instead of EINVAL for
ICV mismatches. This convention has already been adopted by IPsec.
The previous code incorrectly included the hash in the verification which
also meant that we'd crash and burn when it comes to actually verifying
the hash since we'd go past the end of the SG list.
This patch fixes that by subtracting authsize from cryptlen at the start.
Having enckeylen as a template parameter makes it a pain for hardware
devices that implement ciphers with many key sizes since each one would
have to be registered separately.
Since the authenc algorithm is mainly used for legacy purposes where its
key is going to be constructed out of two separate keys, we can in fact
embed this value into the key itself.
This patch does this by prepending an rtnetlink header to the key that
contains the encryption key length.
As it is authsize is an algorithm paramter which cannot be changed at
run-time. This is inconvenient because hardware that implements such
algorithms would have to register each authsize that they support
separately.
Since authsize is a property common to all AEAD algorithms, we can add
a function setauthsize that sets it at run-time, just like setkey.
This patch does exactly that and also changes authenc so that authsize
is no longer a parameter of its template.
Since alignment masks are always one less than a power of two, we can
use binary or to find their maximum.
Up until now we have ablkcipher algorithms have been identified as
type BLKCIPHER with the ASYNC bit set. This is suboptimal because
ablkcipher refers to two things. On the one hand it refers to the
top-level ablkcipher interface with requests. On the other hand it
refers to and algorithm type underneath.
As it is you cannot request a synchronous block cipher algorithm
with the ablkcipher interface on top. This is a problem because
we want to be able to eventually phase out the blkcipher top-level
interface.
This patch fixes this by making ABLKCIPHER its own type, just as
we have distinct types for HASH and DIGEST. The type it associated
with the algorithm implementation only.
Which top-level interface is used for synchronous block ciphers is
then determined by the mask that's used. If it's a specific mask
then the old blkcipher interface is given, otherwise we go with the
new ablkcipher interface.
It seems that newer versions of gcc have regressed in their abilities to
analyse initialisations. This patch moves the initialisations up to avoid
the warnings.
We do not allow spaces in algorithm names or parameters. Thanks to Joy Latten
for pointing this out.
This patch adds the authenc algorithm which constructs an AEAD algorithm
from an asynchronous block cipher and a hash. The construction is done
by concatenating the encrypted result from the cipher with the output
from the hash, as is used by the IPsec ESP protocol.
The authenc algorithm exists as a template with four parameters:
authenc(auth, authsize, enc, enckeylen).
The authentication algorithm, the authentication size (i.e., truncating
the output of the authentication algorithm), the encryption algorithm,
and the encryption key length. Both the size field and the key length
field are in bytes. For example, AES-128 with SHA1-HMAC would be
represented by
authenc(hmac(sha1), 12, cbc(aes), 16)
The key for the authenc algorithm is the concatenation of the keys for
the authentication algorithm with the encryption algorithm. For the
above example, if a key of length 36 bytes is given, then hmac(sha1)
would receive the first 20 bytes while the last 16 would be given to
cbc(aes).
