path: root/arch
2013-09-06Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "Device tree and bindings updates for 3.12. General additions of various on-chip and on-board peripherals on various platforms as support gets added. Some of the bigger changes are: - Addition of (new) PCI-e support on Tegra. - More Tegra4 support, including PMC configuration for Dalmore. - Addition of a new board for Exynos4 (trats2) and more bindings for 4x12 IP. - Addition of Allwinner A20 and A31 SoC and board files. - Move of the ST Ericsson device tree files to now use ste-* prefix. - More move of hardware description of shmobile platforms to DT. - Two new board dts files for Freescale MXs" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (177 commits) dts: Rename DW APB timer compatible strings dts: Deprecate ALTR as a vendor prefix of: add vendor prefix for Altera Corp. ARM: at91/dt: sam9x5ek: add sound configuration ARM: at91/dt: sam9x5ek: enable SSC ARM: at91/dt: sam9x5ek: add WM8731 codec ARM: at91/dt: sam9x5: add SSC DMA parameters ARM: at91/dt: add at91rm9200 PQFP package version ARM: at91: at91rm9200: set default mmc0 pinctrl-names ARM: at91: at91sam9n12: correct pin number of gpio-key ARM: at91: at91sam9n12: add qt1070 support ARM: at91: at91sam9n12: add pinctrl of TWI ARM: at91: Add PMU support for sama5d3 ARM: at91: at91sam9260: add missing pinctrl-names on mmc ARM: tegra: configure power off for Dalmore ARM: DT: binding fixup to align with vendor-prefixes.txt (DT) ARM: dts: add sdio blocks to bcm28155-ap board ARM: dts: align sdio numbers to HW definition ARM: sun7i: Add Olimex A20-Olinuxino-Micro support ARM: sun7i: Add Allwinner A20 DTSI ...
2013-09-06Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This branch contains code cleanups, moves and removals for 3.12. There's a large number of various cleanups, and a nice net removal of 13500 lines of code. Highlights worth mentioning are: - A series of patches from Stephen Boyd removing the ARM local timer API. - Move of Qualcomm MSM IOMMU code to drivers/iommu. - Samsung PWM driver cleanups from Tomasz Figa, removing legacy PWM driver and switching over to the drivers/pwm one. - Removal of some unusued auto-generated headers for OMAP2+ (PRM/CM). There's also a move of a header file out of include/linux/i2c/ to platform_data, where it really belongs. It touches mostly ARM platform code for include changes so we took it through our tree" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits) ARM: OMAP2+: Add back the define for AM33XX_RST_GLOBAL_WARM_SW_MASK gpio: (gpio-pca953x) move header to linux/platform_data/ arm: zynq: hotplug: Remove unreachable code ARM: SAMSUNG: Remove unnecessary exynos4_default_sdhci*() tegra: simplify use of devm_ioremap_resource ARM: SAMSUNG: Remove plat/regs-timer.h header ARM: SAMSUNG: Remove remaining uses of plat/regs-timer.h header ARM: SAMSUNG: Remove pwm-clock infrastructure ARM: SAMSUNG: Remove old PWM timer platform devices pwm: Remove superseded pwm-samsung-legacy driver ARM: SAMSUNG: Modify board files to use new PWM platform device ARM: SAMSUNG: Rework private data handling in dev-backlight pwm: Add new pwm-samsung driver ARM: mach-mvebu: remove redundant DT parsing and validation ARM: msm: Only compile io.c on platforms that use it iommu/msm: Move mach includes to iommu directory ARM: msm: Remove devices-iommu.c ARM: msm: Move mach/board.h contents to common.h ARM: msm: Migrate msm_timer to CLOCKSOURCE_OF_DECLARE ARM: msm: Remove TMR and TMR0 static mappings ...
2013-09-06Merge tag 'fixes-nc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC low-priority fixes from Olof Johansson: "This branch contains a handful of fixes for various platforms that weren't serious enough to be included in late 3.11-rc releases. Most of them are for minor cleanups and cosmetic fixes. There's also a bit of code removal here, one board file removal for clps711x, and removal of some legacy device creation on OMAP2+" * tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (25 commits) ARM: OMAP2: use 'int' instead of 'unsigned' for variable 'gpmc_irq_start' ARM: OMAP2: remove useless variable 'ret' ARM: OMAP: dma: fix error return code in omap_system_dma_probe() ARM: OMAP2+: fix wrong address when loading PRM_FRAC_INCREMENTOR_DENUMERATOR_RELOAD ARM: OMAP2+: am33xx-restart: trigger warm reset on omap2+ boards ARM: OMAP2: Use a consistent AM33XX SoC option description ARM: OMAP2+: Remove legacy device creation for McPDM and DMIC ARM: clps711x: edb7211: Remove extra iotable_init() call ARM: clps711x: autcpu12: Remove incorrect config checking ARM: clps711x: Drop fortunet board support ARM: clps711x: Remove the special name for the syscon driver ARM: dts: Fix memory node in skeleton64.dtsi ARM: Keystone: Convert device tree file to use IRQ defines ARM: keystone: use #include to include skeleton.dtsi ARM: keystone: Drop the un-necessary dsb from keystone_cpu_smc() ARM: Keystone: No need to preserve r12 across smc call ARM: keystone: remove redundant smp_init_cpus definition ARM: keystone: drop useless HAVE_SCHED_CLOCK ARM: dove: fix missing __init section of dove_mpp_gpio_mode ARM: shmobile: armadillo800eva-reference: fix compiler warning ...
2013-09-06Merge tag 'please-pull-misc-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull ia64 fixes from Tony Luck: "Couple of small cleanups for ia64" * tag 'please-pull-misc-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: [IA64] Use asm-generic/bitops/builtin-ffs.h [IA64] dmi.h: Make dmi_alloc use kzalloc
2013-09-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull Tile arch updates from Chris Metcalf: "These changes bring in a bunch of new functionality that has been maintained internally at Tilera over the last year, plus other stray bits of work that I've taken into the tile tree from other folks. The changes include some PCI root complex work, interrupt-driven console support, support for performing fast-path unaligned data fixups by kernel-based JIT code generation, CONFIG_PREEMPT support, vDSO support for gettimeofday(), a serial driver for the tilegx on-chip UART, KGDB support, more optimized string routines, support for ftrace and kprobes, improved ASLR, and many bug fixes. We also remove support for the old TILE64 chip, which is no longer buildable" * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (85 commits) tile: refresh tile defconfig files tile: rework <asm/cmpxchg.h> tile PCI RC: make default consistent DMA mask 32-bit tile: add null check for kzalloc in tile/kernel/setup.c tile: make __write_once a synonym for __read_mostly tile: remove support for TILE64 tile: use asm-generic/bitops/builtin-*.h tile: eliminate no-op "noatomichash" boot argument tile: use standard tile_bundle_bits type in traps.c tile: simplify code referencing hypervisor API addresses tile: change <asm/system.h> to <asm/switch_to.h> in comments tile: mark pcibios_init() as __init tile: check for correct compiler earlier in asm-offsets.c tile: use standard 'generic-y' model for <asm/hw_irq.h> tile: use asm-generic version of <asm/local64.h> tile PCI RC: add comment about "PCI hole" problem tile: remove DEBUG_EXTRA_FLAGS kernel config option tile: add virt_to_kpte() API and clean up and document behavior tile: support FRAME_POINTER tile: support reporting Tilera hypervisor statistics ...
2013-09-06Merge tag 'arm64-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull ARM64 update from Catalin Marinas: - User tagged pointers support (top 8-bit of user pointers automatically ignored by the CPU). - Kernel mode NEON (no users for arm64 yet but work in progress). - arm64 kernel Image header extended to accommodate future EFI stub. - Remove BogoMIPS reporting (not relevant, it's just the timer frequency). - Clean-up (EM_AARCH64/EM_ARM to elf-em.h, ELF notes in read-only segment, unused variable). - Bug-fixes (RAM boundaries not 2MB aligned, perf, includes). * tag 'arm64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: Documentation/arm64: clarify requirements for DTB placement arm64: mm: permit use of tagged pointers at EL0 Move the EM_ARM and EM_AARCH64 definitions to uapi/linux/elf-em.h arm64: Remove unused cpu_name ascii in arch/arm64/mm/proc.S arm64: delay: don't bother reporting bogomips in /proc/cpuinfo arm64: Fix mapping of memory banks not ending on a PMD_SIZE boundary arm64: move elf notes into readonly segment arm64: Enable interrupts in the EL0 undef handler arm64: Expand arm64 image header ARM64: include: asm: include "asm/types.h" in "pgtable-2level-types.h" and "pgtable-3level-types.h" arm64: add support for kernel mode NEON arm64: perf: fix ARMv8 EVTYPE_MASK to include NSH bit arm64: perf: fix group validation when using enable_on_exec
2013-09-06Merge tag 'microblaze-3.12-rc1' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
Pull Microblaze patches from Michal Simek: - PCI fixes - Selfmod code removing - Intc and timer fixes - Adding new MB versions - Minor fixes * tag 'microblaze-3.12-rc1' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Show message when reset gpio is not present microblaze: Add linux.bin.ub target microblaze: Add PVR version string for MB v9.0 and v9.1 microblaze: timer: Replace microblaze_ prefix by xilinx_ microblaze: timer: Update header microblaze: timer: Remove unused header microblaze: timer: Clear driver init function microblaze: timer: Use CLKSRC_OF initialization microblaze: intc: Remove unused header microblaze: intc: Clean driver init function microblaze: intc: Using irqchip microblaze: intc: Update header microblaze: intc: Remove unused headers microblaze: Remove selfmodified feature of/pci: Use of_pci_range_parser
2013-09-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "Here's the powerpc batch for this merge window. Some of the highlights are: - A bunch of endian fixes ! We don't have full LE support yet in that release but this contains a lot of fixes all over arch/powerpc to use the proper accessors, call the firmware with the right endian mode, etc... - A few updates to our "powernv" platform (non-virtualized, the one to run KVM on), among other, support for bridging the P8 LPC bus for UARTs, support and some EEH fixes. - Some mpc51xx clock API cleanups in preparation for a clock API overhaul - A pile of cleanups of our old math emulation code, including better support for using it to emulate optional FP instructions on embedded chips that otherwise have a HW FPU. - Some infrastructure in selftest, for powerpc now, but could be generalized, initially used by some tests for our perf instruction counting code. - A pile of fixes for hotplug on pseries (that was seriously bitrotting) - The usual slew of freescale embedded updates, new boards, 64-bit hiberation support, e6500 core PMU support, etc..." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (146 commits) powerpc: Correct FSCR bit definitions powerpc/xmon: Fix printing of set of CPUs in xmon powerpc/pseries: Move lparcfg.c to platforms/pseries powerpc/powernv: Return secondary CPUs to firmware on kexec powerpc/btext: Fix CONFIG_PPC_EARLY_DEBUG_BOOTX on ppc32 powerpc: Cleanup handling of the DSCR bit in the FSCR register powerpc/pseries: Child nodes are not detached by dlpar_detach_node powerpc/pseries: Add mising of_node_put in delete_dt_node powerpc/pseries: Make dlpar_configure_connector parent node aware powerpc/pseries: Do all node initialization in dlpar_parse_cc_node powerpc/pseries: Fix parsing of initial node path in update_dt_node powerpc/pseries: Pack update_props_workarea to map correctly to rtas buffer header powerpc/pseries: Fix over writing of rtas return code in update_dt_node powerpc/pseries: Fix creation of loop in device node property list powerpc: Skip emulating & leave interrupts off for kernel program checks powerpc: Add more exception trampolines for hypervisor exceptions powerpc: Fix location and rename exception trampolines powerpc: Add more trap names to xmon powerpc/pseries: Add a warning in the case of cross-cpu VPA registration powerpc: Update the 00-Index in Documentation/powerpc ...
2013-09-06tile: refresh tile defconfig filesChris Metcalf
These are based on the current shipping versions of the config files from Tilera, as synced up to the tip, so are a better starting point for folks who want a default configuration. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-09-06tile: rework <asm/cmpxchg.h>Chris Metcalf
The macrology in cmpxchg.h was designed to allow arbitrary pointer and integer values to be passed through the routines. To support cmpxchg() on 64-bit values on the 32-bit tilepro architecture, we used the idiom "(typeof(val))(typeof(val-val))". This way, in the "size 8" branch of the switch, when the underlying cmpxchg routine returns a 64-bit quantity, we cast it first to a typeof(val-val) quantity (i.e. size_t if "val" is a pointer) with no warnings about casting between pointers and integers of different sizes, then cast onwards to typeof(val), again with no warnings. If val is not a pointer type, the additional cast is a no-op. We can't replace the typeof(val-val) cast with (for example) unsigned long, since then if "val" is really a 64-bit type, we cast away the high bits. HOWEVER, this fails with current gcc (through 4.7 at least) if "val" is a pointer to an incomplete type. Unfortunately gcc isn't smart enough to realize that "val - val" will always be a size_t type even if it's an incomplete type pointer. Accordingly, I've reworked the way we handle the casting. We have given up the ability to use cmpxchg() on 64-bit values on tilepro, which is OK in the kernel since we should use cmpxchg64() explicitly on such values anyway. As a result, I can just use simple "unsigned long" casts internally. As I reworked it, I realized it would be cleaner to move the architecture-specific conditionals for cmpxchg and xchg out of the atomic.h headers and into cmpxchg, and then use the cmpxchg() and xchg() primitives directly in atomic.h and elsewhere. This allowed the cmpxchg.h header to stand on its own without relying on the implicit include of it that is performed by <asm/atomic.h>. It also allowed collapsing the atomic_xchg/atomic_cmpxchg routines from atomic_{32,64}.h into atomic.h. I improved the tests that guard the allowed size of the arguments to the routines to use a __compiletime_error() test. (By avoiding the use of BUILD_BUG, I could include cmpxchg.h into bitops.h as well and use the macros there, which is otherwise impossible due to include order dependency issues.) The tilepro _atomic_xxx internal methods were previously set up to take atomic_t and atomic64_t arguments, which isn't as convenient with the new model, so I modified them to take int or u64 arguments, which is consistent with how they used the arguments internally anyway, so provided some nice simplification there too. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-09-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "The usual trivial updates all over the tree -- mostly typo fixes and documentation updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits) doc: Documentation/cputopology.txt fix typo treewide: Convert retrun typos to return Fix comment typo for init_cma_reserved_pageblock Documentation/trace: Correcting and extending tracepoint documentation mm/hotplug: fix a typo in Documentation/memory-hotplug.txt power: Documentation: Update s2ram link doc: fix a typo in Documentation/00-INDEX Documentation/printk-formats.txt: No casts needed for u64/s64 doc: Fix typo "is is" in Documentations treewide: Fix printks with 0x%# zram: doc fixes Documentation/kmemcheck: update kmemcheck documentation doc: documentation/hwspinlock.txt fix typo PM / Hibernate: add section for resume options doc: filesystems : Fix typo in Documentations/filesystems scsi/megaraid fixed several typos in comments ppc: init_32: Fix error typo "CONFIG_START_KERNEL" treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks page_isolation: Fix a comment typo in test_pages_isolated() doc: fix a typo about irq affinity ...
2013-09-05Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "This set includes adding support for Neon acceleration of RAID6 XOR code from Ard Biesheuvel, cache flushing and barrier updates from Will Deacon, and a cleanup to the ARM debug code which reduces the amount of code by about 500 lines. A few other cleanups, such as constifying the machine descriptors which already shouldn't be written to, cleaning up the printing of the L2 cache size" * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (55 commits) ARM: 7826/1: debug: support debug ll on hisilicon soc ARM: 7830/1: delay: don't bother reporting bogomips in /proc/cpuinfo ARM: 7829/1: Add ".text.unlikely" and ".text.hot" to arm unwind tables ARM: 7828/1: ARMv7-M: implement restart routine common to all v7-M machines ARM: 7827/1: highbank: fix debug uart virtual address for LPAE ARM: 7823/1: errata: workaround Cortex-A15 erratum 773022 ARM: 7806/1: allow DEBUG_UNCOMPRESS for Tegra ARM: 7793/1: debug: use generic option for ep93xx PL10x debug port ARM: debug: move SPEAr debug to generic PL01x code ARM: debug: move davinci debug to generic 8250 code ARM: debug: move keystone debug to generic 8250 code ARM: debug: remove DEBUG_ROCKCHIP_UART ARM: debug: provide generic option choices for 8250 and PL01x ports ARM: debug: move PL01X debug include into arch/arm/include/debug/ ARM: debug: provide PL01x debug uart phys/virt address configuration options ARM: debug: add support for word accesses to debug/8250.S ARM: debug: move 8250 debug include into arch/arm/include/debug/ ARM: debug: provide 8250 debug uart phys/virt address configuration options ARM: debug: provide 8250 debug uart register shift configuration option ARM: debug: provide 8250 debug uart flow control configuration option ...
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc changes from David Miller: "Several bug fixes (from Kirill Tkhai, Geery Uytterhoeven, and Alexey Dobriyan) and some support for Fujitsu sparc64x chips (from Allen Pais)" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Export flush_ptrace_access() (needed by lustre) sparc: fix PCI device proc file mmap(2) sparc64: Remove RWSEM export leftovers sparc64: Fix off by one in trampoline TLB mapping installation loop. sparc64: Fix ITLB handler of null page esp_scsi: Fix tag state corruption when autosensing. sparc64: Fix not SRA'ed %o5 in 32-bit traced syscall sparc64: cleanup: Rename ret_from_syscall to ret_from_fork sparc32: Fix exit flag passed from traced sys_sigreturn sparc64: Fix wrong syscall return value passed to trace_sys_exit() support sparc64x chip type in cpumap.c cpu hw caps support for sparc64x
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: "Noteworthy changes this time around: 1) Multicast rejoin support for team driver, from Jiri Pirko. 2) Centralize and simplify TCP RTT measurement handling in order to reduce the impact of bad RTO seeding from SYN/ACKs. Also, when both timestamps and local RTT measurements are available prefer the later because there are broken middleware devices which scramble the timestamp. From Yuchung Cheng. 3) Add TCP_NOTSENT_LOWAT socket option to limit the amount of kernel memory consumed to queue up unsend user data. From Eric Dumazet. 4) Add a "physical port ID" abstraction for network devices, from Jiri Pirko. 5) Add a "suppress" operation to influence fib_rules lookups, from Stefan Tomanek. 6) Add a networking development FAQ, from Paul Gortmaker. 7) Extend the information provided by tcp_probe and add ipv6 support, from Daniel Borkmann. 8) Use RCU locking more extensively in openvswitch data paths, from Pravin B Shelar. 9) Add SCTP support to openvswitch, from Joe Stringer. 10) Add EF10 chip support to SFC driver, from Ben Hutchings. 11) Add new SYNPROXY netfilter target, from Patrick McHardy. 12) Compute a rate approximation for sending in TCP sockets, and use this to more intelligently coalesce TSO frames. Furthermore, add a new packet scheduler which takes advantage of this estimate when available. From Eric Dumazet. 13) Allow AF_PACKET fanouts with random selection, from Daniel Borkmann. 14) Add ipv6 support to vxlan driver, from Cong Wang" Resolved conflicts as per discussion. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1218 commits) openvswitch: Fix alignment of struct sw_flow_key. netfilter: Fix build errors with xt_socket.c tcp: Add missing braces to do_tcp_setsockopt caif: Add missing braces to multiline if in cfctrl_linkup_request bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize vxlan: Fix kernel panic on device delete. net: mvneta: implement ->ndo_do_ioctl() to support PHY ioctls net: mvneta: properly disable HW PHY polling and ensure adjust_link() works icplus: Use netif_running to determine device state ethernet/arc/arc_emac: Fix huge delays in large file copies tuntap: orphan frags before trying to set tx timestamp tuntap: purge socket error queue on detach qlcnic: use standard NAPI weights ipv6:introduce function to find route for redirect bnx2x: VF RSS support - VF side bnx2x: VF RSS support - PF side vxlan: Notify drivers for listening UDP port changes net: usbnet: update addr_assign_type if appropriate driver/net: enic: update enic maintainers and driver driver/net: enic: Exposing symbols for Cisco's low latency driver ...
2013-09-05Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Fix for the annoying paravirt.o build warning under allmodconfig, and a MAINTAINERS file update" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, doc: Add an entry in MAINTAINERS for arch/x86/kernel/cpu/vmware.c x86, paravirt: Remove duplicate definition for DEF_NATIVE
2013-09-05sparc64: Export flush_ptrace_access() (needed by lustre)Geert Uytterhoeven
ERROR: "flush_ptrace_access" [drivers/staging/lustre/lustre/libcfs/libcfs.ko] undefined! Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05sparc64: Remove RWSEM export leftoversKirill Tkhai
The functions __down_read __down_read_trylock __down_write __down_write_trylock __up_read __up_write __downgrade_write are implemented inline, so remove corresponding EXPORT_SYMBOLs (They lead to compile errors on RT kernel). Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c net/bridge/br_multicast.c net/ipv6/sit.c The conflicts were minor: 1) sit.c changes overlap with change to ip_tunnel_xmit() signature. 2) br_multicast.c had an overlap between computing max_delay using msecs_to_jiffies and turning MLDV2_MRC() into an inline function with a name using lowercase instead of uppercase letters. 3) stmmac had two overlapping changes, one which conditionally allocated and hooked up a dma_cfg based upon the presence of the pbl OF property, and another one handling store-and-forward DMA made. The latter of which should not go into the new of_find_property() basic block. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-05Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "This series contains: - Exynos s5p-mfc driver got support for VP8 encoder - Some SoC drivers gained support for asynchronous registration (needed for DT) - The RC subsystem gained support for RC activity LED; - New drivers added: a video decoder(adv7842), a video encoder (adv7511), a new GSPCA driver (stk1135) and support for Renesas R-Car (vsp1) - the first SDR kernel driver: mirics msi3101. Due to some troubles with the driver, and because the API is still under discussion, it will be merged at staging for 3.12. Need to rework on it - usual new boards additions, fixes, cleanups and driver improvements" * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (242 commits) [media] cx88: Fix regression: CX88_AUDIO_WM8775 can't be 0 [media] exynos4-is: Fix entity unregistration on error path [media] exynos-gsc: Register v4l2 device [media] exynos4-is: Fix fimc-lite bayer formats [media] em28xx: fix assignment of the eeprom data [media] hdpvr: fix iteration over uninitialized lists in hdpvr_probe() [media] usbtv: Throw corrupted frames away [media] usbtv: Fix deinterlacing [media] v4l2: added missing mutex.h include to v4l2-ctrls.h [media] DocBook: upgrade media_api DocBook version to 4.2 [media] ml86v7667: fix compile warning: 'ret' set but not used [media] s5p-g2d: Fix registration failure [media] media: coda: Fix DT driver data pointer for i.MX27 [media] s5p-mfc: Fix input/output format reporting [media] v4l: vsp1: Fix mutex double lock at streamon time [media] v4l: vsp1: Add support for RT clock [media] v4l: vsp1: Initialize media device bus_info field [media] davinci: vpif_capture: fix error return code in vpif_probe() [media] davinci: vpif_display: fix error return code in vpif_probe() [media] MAINTAINERS: add entries for adv7511 and adv7842 ...
2013-09-05Merge tag 'fbdev-3.12-omap-legacy-removal' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull OMAP specific fbdev changes from Tomi Valkeinen: "I've got this pull request separate from the main fbdev pull request, as this contains a bunch of OMAP board file changes and thus could possibly be rejected in case of bad conflicts. The removal of the old display drivers depend on the board file changes, so Tony Lindgren suggested taking them together via fbdev tree. These are in linux-next, and also Tony didn't see any conflicts with any of the branches he had, so they should go in clean. - Change the OMAP board files to use the new OMAP display drivers - Remove all the old drivers, and the related auxiliary code" * tag 'fbdev-3.12-omap-legacy-removal' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (35 commits) OMAPDSS: rename omap_dss_device's 'device' field to 'dst' OMAPDSS: rename omap_dss_device's 'output' to 'src' OMAPDSS: DSS: remove legacy dss bus support OMAPDSS: RFBI: remove code related to old panel model OMAPDSS: VENC: remove code related to old panel model OMAPDSS: SDI: remove code related to old panel model OMAPDSS: DSI: remove code related to old panel model OMAPDSS: HDMI: remove code related to old panel model OMAPDSS: DPI: remove code related to old panel model OMAPDSS: remove all old panel drivers OMAPDSS: DPI: change regulator handling OMAPDSS: SDI: change regulator handling OMAPDSS: fix DPI and SDI device ids OMAPDSS: remove omap_dss_device->channel field OMAPDSS: RFBI: Mark RFBI as broken ARM: OMAP2+: Remove old display drivers from omap2plus_defconfig ARM: OMAP: AM3517EVM: use new display drivers ARM: OMAP: Zoom: use new display drivers ARM: OMAP: Pandora: use new display drivers ARM: OMAP: OMAP3EVM: use new display drivers ...
2013-09-05Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: "Highlights: - OF and ACPI helpers are now included in the core, and not in external files anymore. This removes dependency problems for modules and is cleaner, in general. - mv64xxx-driver gains fifo usage to support mv78230 - imx-driver overhaul to support VF610 - various cleanups, most notably related to devm_* and CONFIG_PM usage - driver bugfixes and smaller feature additions" * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (51 commits) i2c: rcar: add rcar-H2 support i2c: sirf: retry 3 times as sometimes we get random noack and timeout i2c: sirf: support reverse direction of address i2c: sirf: fix the typo for setting bitrate to less than 100k i2c: sirf: we need to wait I2C_RESET status in resume i2c: sirf: reset i2c controller early after we get a noack i2c: designware: get SDA hold time, HCNT and LCNT configuration from ACPI i2c: designware: make HCNT/LCNT values configurable i2c: mpc: cleanup clock API use i2c: pnx: fix error return code in i2c_pnx_probe() i2c: ismt: add error return code in probe() i2c: mv64xxx: fix typo in binding documentation i2c: imx: use exact SoC revision to document binding i2c: move ACPI helpers into the core i2c: move OF helpers into the core i2c: mv64xxx: Fix timing issue on Armada XP (errata FE-8471889) i2c: mv64xxx: Add I2C Transaction Generator support i2c: powermac: fix return path on error Documentation: i2c: Fix example in instantiating-devices i2c: tiny-usb: do not use stack as URB transfer_buffer ...
2013-09-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "Unfortunately, this merge window it'll have a be a lot of small piles - my fault, actually, for not keeping #for-next in anything that would resemble a sane shape ;-/ This pile: assorted fixes (the first 3 are -stable fodder, IMO) and cleanups + %pd/%pD formats (dentry/file pathname, up to 4 last components) + several long-standing patches from various folks. There definitely will be a lot more (starting with Miklos' check_submount_and_drop() series)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits) direct-io: Handle O_(D)SYNC AIO direct-io: Implement generic deferred AIO completions add formats for dentry/file pathnames kvm eventfd: switch to fdget powerpc kvm: use fdget switch fchmod() to fdget switch epoll_ctl() to fdget switch copy_module_from_fd() to fdget git simplify nilfs check for busy subtree ibmasmfs: don't bother passing superblock when not needed don't pass superblock to hypfs_{mkdir,create*} don't pass superblock to hypfs_diag_create_files don't pass superblock to hypfs_vm_create_files() oprofile: get rid of pointless forward declarations of struct super_block oprofilefs_create_...() do not need superblock argument oprofilefs_mkdir() doesn't need superblock argument don't bother with passing superblock to oprofile_create_stats_files() oprofile: don't bother with passing superblock to ->create_files() don't bother passing sb to oprofile_create_files() coh901318: don't open-code simple_read_from_buffer() ...
2013-09-05Merge branches 'debug-choice', 'devel-stable' and 'misc' into for-linusRussell King
2013-09-05powerpc: Correct FSCR bit definitionsPaul Mackerras
Commit 74e400cee6 ("powerpc: Rework setting up H/FSCR bit definitions") ended up with incorrect bit numbers for FSCR_PM_LG and FSCR_BHRB_LG. This fixes them. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-09-05powerpc/xmon: Fix printing of set of CPUs in xmonPaul Mackerras
Commit 24ec2125f3 ("powerpc/xmon: Use cpumask iterator to avoid warning") replaced a loop from 0 to NR_CPUS-1 with a for_each_possible_cpu() loop, which means that if the last possible cpu is in xmon, we print the wrong value for the end of the range. For example, if 4 cpus are possible, NR_CPUS is 128, and all cpus are in xmon, we print "0-7f" rather than "0-3". The code also assumes that the set of possible cpus is contiguous, which may not necessarily be true. This fixes the code to check explicitly for contiguity, and to print the ending value correctly. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-09-05Merge remote-tracking branch 'agust/next' into nextBenjamin Herrenschmidt
From Anatolij: << There are cleanups for some mpc5121 specific drivers and DTS files in preparation to switch mpc5121 clock support to a clock driver based on common clock framework. Additionally Sebastian fixed the mpc52xx PIC driver so that it builds when using older gcc versions. >>
2013-09-04Merge branch 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Gleb Natapov: "The highlights of the release are nested EPT and pv-ticketlocks support (hypervisor part, guest part, which is most of the code, goes through tip tree). Apart of that there are many fixes for all arches" Fix up semantic conflicts as discussed in the pull request thread.. * 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (88 commits) ARM: KVM: Add newlines to panic strings ARM: KVM: Work around older compiler bug ARM: KVM: Simplify tracepoint text ARM: KVM: Fix kvm_set_pte assignment ARM: KVM: vgic: Bump VGIC_NR_IRQS to 256 ARM: KVM: Bugfix: vgic_bytemap_get_reg per cpu regs ARM: KVM: vgic: fix GICD_ICFGRn access ARM: KVM: vgic: simplify vgic_get_target_reg KVM: MMU: remove unused parameter KVM: PPC: Book3S PR: Rework kvmppc_mmu_book3s_64_xlate() KVM: PPC: Book3S PR: Make instruction fetch fallback work for system calls KVM: PPC: Book3S PR: Don't corrupt guest state when kernel uses VMX KVM: x86: update masterclock when kvmclock_offset is calculated (v2) KVM: PPC: Book3S: Fix compile error in XICS emulation KVM: PPC: Book3S PR: return appropriate error when allocation fails arch: powerpc: kvm: add signed type cast for comparation KVM: x86: add comments where MMIO does not return to the emulator KVM: vmx: count exits to userspace during invalid guest emulation KVM: rename __kvm_io_bus_sort_cmp to kvm_io_bus_cmp kvm: optimize away THP checks in kvm_is_mmio_pfn() ...
2013-09-04Merge tag 'stable/for-linus-3.12-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen updates from Konrad Rzeszutek Wilk: "A couple of features and a ton of bug-fixes. There is also some maintership changes. Jeremy is enjoying the full-time work at the startup and as much as he would love to help - he can't find the time. I have a bunch of other things that I promised to work on - paravirt diet, get SWIOTLB working everywhere, etc, but haven't been able to find the time. As such both David Vrabel and Boris Ostrovsky have graciously volunteered to help with the maintership role. They will keep the lid on regressions, bug-fixes, etc. I will be in the background to help - but eventually there will be less of me doing the Xen GIT pulls and more of them. Stefano is still doing the ARM/ARM64 and will continue on doing so. Features: - Xen Trusted Platform Module (TPM) frontend driver - with the backend in MiniOS. - Scalability improvements in event channel. - Two extra Xen co-maintainers (David, Boris) and one going away (Jeremy) Bug-fixes: - Make the 1:1 mapping work during early bootup on selective regions. - Add scratch page to balloon driver to deal with unexpected code still holding on stale pages. - Allow NMIs on PV guests (64-bit only) - Remove unnecessary TLB flush in M2P code. - Fixes duplicate callbacks in Xen granttable code. - Fixes in PRIVCMD_MMAPBATCH ioctls to allow retries - Fix for events being lost due to rescheduling on different VCPUs. - More documentation" * tag 'stable/for-linus-3.12-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (23 commits) hvc_xen: Remove unnecessary __GFP_ZERO from kzalloc drivers/xen-tpmfront: Fix compile issue with missing option. xen/balloon: don't set P2M entry for auto translated guest xen/evtchn: double free on error Xen: Fix retry calls into PRIVCMD_MMAPBATCH*. xen/pvhvm: Initialize xen panic handler for PVHVM guests xen/m2p: use GNTTABOP_unmap_and_replace to reinstate the original mapping xen: fix ARM build after 6efa20e4 MAINTAINERS: Remove Jeremy from the Xen subsystem. xen/events: document behaviour when scanning the start word for events x86/xen: during early setup, only 1:1 map the ISA region x86/xen: disable premption when enabling local irqs swiotlb-xen: replace dma_length with sg_dma_len() macro swiotlb: replace dma_length with sg_dma_len() macro xen/balloon: set a mapping for ballooned out pages xen/evtchn: improve scalability by using per-user locks xen/p2m: avoid unneccesary TLB flush in m2p_remove_override() MAINTAINERS: Add in two extra co-maintainers of the Xen tree. MAINTAINERS: Update the Xen subsystem's with proper mailing list. xen: replace strict_strtoul() with kstrtoul() ...
2013-09-04Merge tag 'PTR_RET-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull PTR_RET() removal patches from Rusty Russell: "PTR_RET() is a weird name, and led to some confusing usage. We ended up with PTR_ERR_OR_ZERO(), and replacing or fixing all the usages. This has been sitting in linux-next for a whole cycle" [ There are still some PTR_RET users scattered about, with some of them possibly being new, but most of them existing in Rusty's tree too. We have that #define PTR_RET(p) PTR_ERR_OR_ZERO(p) thing in <linux/err.h>, so they continue to work for now - Linus ] * tag 'PTR_RET-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: GFS2: Replace PTR_RET with PTR_ERR_OR_ZERO Btrfs: volume: Replace PTR_RET with PTR_ERR_OR_ZERO drm/cma: Replace PTR_RET with PTR_ERR_OR_ZERO sh_veu: Replace PTR_RET with PTR_ERR_OR_ZERO dma-buf: Replace PTR_RET with PTR_ERR_OR_ZERO drivers/rtc: Replace PTR_RET with PTR_ERR_OR_ZERO mm/oom_kill: remove weird use of ERR_PTR()/PTR_ERR(). staging/zcache: don't use PTR_RET(). remoteproc: don't use PTR_RET(). pinctrl: don't use PTR_RET(). acpi: Replace weird use of PTR_RET. s390: Replace weird use of PTR_RET. PTR_RET is now PTR_ERR_OR_ZERO(): Replace most. PTR_RET is now PTR_ERR_OR_ZERO
2013-09-04lockref: Implement lockref for ItaniumLuck, Tony
All the cool kids are doing this, join in the fun. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-04Merge tag 'sound-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "Changes are seen in a wide range of codes, mainly due to ASoC DAPM requirements; HD-audio shows a high peak in diffstat, it's just a removal of bunch of old static quirks. Some highlights: - HDPM: Updates for AIO/RayDAT support, TCO/sync support - RME96: Add PCM sync support - HD-audio: * A few HDMI/DP audio updates (CA assignment fix, stream switching fix, Intel DP device list support) * Device specific fixes (ASUS/CXT HP mic support, Thinkpad mic improvements, Chromebook fixes, STAC9228 Dell fixes) * Replace the all static quirks for AD codecs with the generic parser * WAKEEN support for handling irqs in the power saving mode - USB-audio: Clean up implicit fb handling and related codes - DAPM is now mandatory for ASoC CODEC drivers; all existing drivers have had some level of DAPM support added. In addition, a lot of cleanups and improvements in DAPM. - Support for ASoC cross-platform compile test - New drivers and support for Analog Devices ADAU1702 and ADAU1401(a), Asahi Kasei Microdevices AK4554, Atmel AT91ASM9x5 and WM8904 based machines, Freescale S/PDIF and SSI AC'97, Renesas R-Car SoCs, Samsung Exynos5420 SoCs, Texas Instruments PCM1681 and PCM1792A and Wolfson Microelectronics WM8997 - DT bindings for kirkwood and i.MX S/PDIF - Clean up and bug fixes: ssm2602, rt5640 and sgtl5000. - Core helpers for bitbanged AC'97 reset" * tag 'sound-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (375 commits) ALSA: hda - Re-setup HDMI pin and audio infoframe on stream switches ALSA: hda - hdmi: Fallback to ALSA allocation when selecting CA ASoC: mxs-sgtl5000: Configure the dai_links as unidirectional ASoC: soc-pcm: Allow to specify unidirectional dai_link ASoC: fsl_spdif: Staticse non-exported symbols ASoC: ssm2602: Fix cache sync ASoC: Remove unused sysfs_registered field from snd_soc_codec struct ASoC: Remove unused debugfs_dapm field from snd_soc_{platform,codec} struct ASoC: Remove unused control_type field from snd_soc_codec struct ASoC: fsl: Add one blank space after ':=' in Makefile ASoC: fsl: Add wrapping for dev_dbg() in fsl_spdif.c ASoC: rt5640: change widget sequence for depop ASoC: dapm: Fix auto-disable for inverted controls ASoC: fsl: Drop SND_SOC_FSL_UTILS from SND_SOC_IMX_SPDIF ASoC: Samsung: Do not queue cyclic buffers multiple times ASoC: ep93xx-i2s: Remove unnecessary dev_set_drvdata() ASoC: designware_i2s: Remove unnecessary dev_set_drvdata() ASoC: fsl_spdif: remove redundant dev_err call in fsl_spdif_probe() ASoC: fsl: Add S/PDIF machine driver ASoc: kirkwood: Use the Kirkwood audio driver in Dove boards ...
2013-09-04Merge tag 'pinctrl-v3.12-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control changes from Linus Walleij: "Here is the bulk of pin control changes for the v3.12 series. Most of the relevant information is in the tag. I merged in v3.11-rc7 last week to get rid of a largeish conflict within the sunxi (AllWinner) driver in linux-next and fix up the non-trivial merge the right way. That driver had a rather large fix adding locking late in the release cycle. Overall the bulk changes this time is cleanups and refactorings and not much new features, which is nice. - Refactorings for generic pin config handling in the core. - Factor out a set of device tree utilities for use in all drivers, to parse and allocate maps from the device tree. - Some fixes to the core such as more nitpicky locking. - Pushed down config array iteration into the drivers. This patch is necessary for drivers that want to iterate over configs and pile up a stack of alterations to the same register(s), or if the driver wants to take a local spinlock when committing the configuration. - A new driver for the Texas Instruments Palmas PMIC by Laxman Dewangan. This is used on the Tegra systems. - A major cleanup and modernization of the PFC (Super Hitachi and ARM SHmobile) pin controller and subdrivers. - Support for the A20 and A31 sunxi (AllWinner) SoCs. - A huge pile of fixes and cleanups: Axel Lin, Jingoo Han Dan Carpenter, Julia Lawall and Sachin Kamat did an excellent job here" * tag 'pinctrl-v3.12-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (124 commits) pinctrl: sunxi: Fix off-by-one for valid offset range checking pinctrl: sunxi: drop lock on error path pinctrl: pinconf-generic: Remove ti prefix in dev_err messages pinctrl: rockchip: Implement .request() and .free() callbacks pinctrl: at91: fix get_pullup/down function return pinctrl: sh-pfc: remove unnecessary platform_set_drvdata() pinctrl: Add s5pv210 support to pinctrl-exynos pinctrl: utils: include export.h to avoid warnings pinctrl: s3c24xx: off by one in s3c24xx_eint_init() pinctrl: mvebu: testing the wrong variable pinctrl: abx500: fix bitwise AND test pinctrl: mvebu: Convert to use devm_ioremap_resource pinctrl: Pass all configs to driver on pin_config_set() pinctrl: tz1090-pdc: Convert to devm_ioremap_resource pinctrl: tz1090: Convert to devm_ioremap_resource pinctrl: tegra: Convert to devm_ioremap_resource pinctrl: rockchip: Simplify pin_to_bank equation pinctrl: spear: Convert to devm_ioremap_resource pinctrl: rockchip: Remove of_match_ptr macro for DT only driver pinctrl: palmas: PINCTRL_PALMAS needs to select PINMUX ...
2013-09-04Merge branch 'x86-spinlocks-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 spinlock changes from Ingo Molnar: "The biggest change here are paravirtualized ticket spinlocks (PV spinlocks), which bring a nice speedup on various benchmarks. The KVM host side will come to you via the KVM tree" * 'x86-spinlocks-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/kvm/guest: Fix sparse warning: "symbol 'klock_waiting' was not declared as static" kvm: Paravirtual ticketlocks support for linux guests running on KVM hypervisor kvm guest: Add configuration support to enable debug information for KVM Guests kvm uapi: Add KICK_CPU and PV_UNHALT definition to uapi xen, pvticketlock: Allow interrupts to be enabled while blocking x86, ticketlock: Add slowpath logic jump_label: Split jumplabel ratelimit x86, pvticketlock: When paravirtualizing ticket locks, increment by 2 x86, pvticketlock: Use callee-save for lock_spinning xen, pvticketlocks: Add xen_nopvspin parameter to disable xen pv ticketlocks xen, pvticketlock: Xen implementation for PV ticket locks xen: Defer spinlock setup until boot CPU setup x86, ticketlock: Collapse a layer of functions x86, ticketlock: Don't inline _spin_unlock when using paravirt spinlocks x86, spinlock: Replace pv spinlocks with pv ticketlocks
2013-09-04Merge branch 'x86-smap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 SMAP fixes from Ingo Molnar: "Fixes for Intel SMAP support, to fix SIGSEGVs during bootup" * 'x86-smap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: Introduce [compat_]save_altstack_ex() to unbreak x86 SMAP x86, smap: Handle csum_partial_copy_*_user()
2013-09-04Merge branch 'x86-ras-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 RAS changes from Ingo Molnar: "[ The reason for drivers/ updates is that Boris asked for the drivers/edac/ changes to go via x86/ras in this cycle ] Main changes: - AMD CPUs: . Add ECC event decoding support for new F15h models . Various erratum fixes . Fix single-channel on dual-channel-controllers bug. - Intel CPUs: . UC uncorrectable memory error parsing fix . Add support for CMC (Corrected Machine Check) 'FF' (Firmware First) flag in the APEI HEST - Various cleanups and fixes" * 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: amd64_edac: Fix incorrect wraparounds amd64_edac: Correct erratum 505 range cpc925_edac: Use proper array termination x86/mce, acpi/apei: Only disable banks listed in HEST if mce is configured amd64_edac: Get rid of boot_cpu_data accesses amd64_edac: Add ECC decoding support for newer F15h models x86, amd_nb: Clarify F15h, model 30h GART and L3 support pci_ids: Add PCI device ID functions 3 and 4 for newer F15h models. x38_edac: Make a local function static i3200_edac: Make a local function static x86/mce: Pay no attention to 'F' bit in MCACOD when parsing 'UC' errors APEI/ERST: Fix error message formatting amd64_edac: Fix single-channel setups EDAC: Replace strict_strtol() with kstrtol() mce: acpi/apei: Soft-offline a page on firmware GHES notification mce: acpi/apei: Add a boot option to disable ff mode for corrected errors mce: acpi/apei: Honour Firmware First for MCA banks listed in APEI HEST CMC
2013-09-04Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 platform documentation fix from Ingo Molnar. * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/acpi: Correct out-of-date comment of __acpi_map_table()
2013-09-04Merge branch 'x86-paravirt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 paravirt changes from Ingo Molnar: "Hypervisor signature detection cleanup and fixes - the goal is to make KVM guests run better on MS/Hyperv and to generalize and factor out the code a bit" * 'x86-paravirt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Correctly detect hypervisor x86, kvm: Switch to use hypervisor_cpuid_base() xen: Switch to use hypervisor_cpuid_base() x86: Introduce hypervisor_cpuid_base()
2013-09-04x86, paravirt: Remove duplicate definition for DEF_NATIVEH. Peter Anvin
DEF_NATIVE() is defined in paravirt_types.h, remove duplicate definition in paravirt.c Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Andi Kleen <ak@linux.kernel.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/CA%2B55aFxVv==DC0JdS87V%2BcPr-twN%2BTujYg5XmgHOjJOAkZ4xwQ@mail.gmail.com
2013-09-04Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm changes from Ingo Molnar: "Misc smaller fixes: - a parse_setup_data() boot crash fix - a memblock and an __early_ioremap cleanup - turn the always-on CONFIG_ARCH_MEMORY_PROBE=y into a configurable option and turn it off - it's an unrobust debug facility, it shouldn't be enabled by default" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: avoid remapping data in parse_setup_data() x86: Use memblock_set_current_limit() to set limit for memblock. mm: Remove unused variable idx0 in __early_ioremap() mm/hotplug, x86: Disable ARCH_MEMORY_PROBE by default
2013-09-04Merge branch 'x86-kaslr-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 relocation changes from Ingo Molnar: "This tree contains a single change, ELF relocation handling in C - one of the kernel randomization patches that makes sense even without randomization present upstream" * 'x86-kaslr-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, relocs: Move ELF relocation handling to C
2013-09-04Merge branch 'timers-nohz-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timers/nohz changes from Ingo Molnar: "It mostly contains fixes and full dynticks off-case optimizations, by Frederic Weisbecker" * 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) nohz: Include local CPU in full dynticks global kick nohz: Optimize full dynticks's sched hooks with static keys nohz: Optimize full dynticks state checks with static keys nohz: Rename a few state variables vtime: Always debug check snapshot source _before_ updating it vtime: Always scale generic vtime accounting results vtime: Optimize full dynticks accounting off case with static keys vtime: Describe overriden functions in dedicated arch headers m68k: hardirq_count() only need preempt_mask.h hardirq: Split preempt count mask definitions context_tracking: Split low level state headers vtime: Fix racy cputime delta update vtime: Remove a few unneeded generic vtime state checks context_tracking: User/kernel broundary cross trace events context_tracking: Optimize context switch off case with static keys context_tracking: Optimize guest APIs off case with static key context_tracking: Optimize main APIs off case with static key context_tracking: Ground setup for static key use context_tracking: Remove full dynticks' hacky dependency on wide context tracking nohz: Only enable context tracking on full dynticks CPUs ...
2013-09-04Merge branch 'x86-fb-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fb changes from Ingo Molnar: "This tree includes preparatory patches for SimpleDRM driver support, by David Herrmann. They clean up x86 framebuffer support by creating simplefb devices wherever possible. More background can be found at http://lwn.net/Articles/558104/" * 'x86-fb-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: fbdev: fbcon: select VT_HW_CONSOLE_BINDING fbdev: efifb: bind to efi-framebuffer fbdev: vesafb: bind to platform-framebuffer device fbdev: simplefb: add common x86 RGB formats x86: sysfb: move EFI quirks from efifb to sysfb x86: provide platform-devices for boot-framebuffers fbdev: simplefb: mark as fw and allocate apertures fbdev: simplefb: add init through platform_data
2013-09-04Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cpu feature fixes from Ingo Molnar: "Two small cpufeature support updates" * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Fix override new_cpu_data.x86 with 486 x86, cpufeature: Use new CC_HAVE_ASM_GOTO
2013-09-04Merge branches 'x86-boot-for-linus' and 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull tiny x86 boot cleanups from Ingo Molnar. * 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/boot: Fix a sanity check in printf.c * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, boot: Fix warning due to undeclared strlen()
2013-09-04Merge branch 'x86-asmlinkage-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/asmlinkage changes from Ingo Molnar: "As a preparation for Andi Kleen's LTO patchset (link time optimizations using GCC's -flto which build time optimization has steadily increased in quality over the past few years and might eventually be usable for the kernel too) this tree includes a handful of preparatory patches that make function calling convention annotations consistent again: - Mark every function without arguments (or 64bit only) that is used by assembly code with asmlinkage() - Mark every function with parameters or variables that is used by assembly code as __visible. For the vanilla kernel this has documentation, consistency and debuggability advantages, for the time being" * 'x86-asmlinkage-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/asmlinkage: Fix warning in xen asmlinkage change x86, asmlinkage, vdso: Mark vdso variables __visible x86, asmlinkage, power: Make various symbols used by the suspend asm code visible x86, asmlinkage: Make dump_stack visible x86, asmlinkage: Make 64bit checksum functions visible x86, asmlinkage, paravirt: Add __visible/asmlinkage to xen paravirt ops x86, asmlinkage, apm: Make APM data structure used from assembler visible x86, asmlinkage: Make syscall tables visible x86, asmlinkage: Make several variables used from assembler/linker script visible x86, asmlinkage: Make kprobes code visible and fix assembler code x86, asmlinkage: Make various syscalls asmlinkage x86, asmlinkage: Make 32bit/64bit __switch_to visible x86, asmlinkage: Make _*_start_kernel visible x86, asmlinkage: Make all interrupt handlers asmlinkage / __visible x86, asmlinkage: Change dotraplinkage into __visible on 32bit x86: Fix sys_call_table type in asm/syscall.h
2013-09-04Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/asm changes from Ingo Molnar: "Main changes: - Apply low level mutex optimization on x86-64, by Wedson Almeida Filho. - Change bitops to be naturally 'long', by H Peter Anvin. - Add TSX-NI opcodes support to the x86 (instrumentation) decoder, by Masami Hiramatsu. - Add clang compatibility adjustments/workarounds, by Jan-Simon Möller" * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, doc: Update uaccess.h comment to reflect clang changes x86, asm: Fix a compilation issue with clang x86, asm: Extend definitions of _ASM_* with a raw format x86, insn: Add new opcodes as of June, 2013 x86/ia32/asm: Remove unused argument in macro x86, bitops: Change bitops to be native operand size x86: Use asm-goto to implement mutex fast path on x86-64
2013-09-04Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/apic changes from Ingo Molnar: "Smaller fixes" * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/ioapic: Check attr against the previous setting when programmed more than once x86/ioapic/kcrash: Prevent crash_kexec() from deadlocking on ioapic_lock x86/acpi: Fix incorrect sanity check in acpi_register_lapic()
2013-09-04Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer changes from Ingo Molnar: "Various clocksource driver updates: extend the core with memory mapped hardware (mmio) support and add new (ARM) Moxart SoC and sun4i hardware support" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) clocksource: arch_timer: Add support for memory mapped timers clocksource: arch_timer: Push the read/write wrappers deeper Documentation: Add memory mapped ARM architected timer binding clocksource: arch_timer: Pass clock event to set_mode callback clocksource: arch_timer: Make register accessors less error-prone ARM: clocksource: moxart: documentation: Update device tree bindings document ARM: clocksource: moxart: Add bitops.h include ARM: clocksource: moxart: documentation: Fix device tree bindings document ARM: clocksource: Add support for MOXA ART SoCs clocksource: cadence_ttc: Reuse clocksource as sched_clock clocksource: cadence_ttc: Remove unused header clocksource: sun4i: Fix bug when switching from periodic to oneshot modes clocksource: sun4i: Cleanup parent clock setup clocksource: sun4i: Remove TIMER_SCAL variable clocksource: sun4i: Factor out some timer code clocksource: sun4i: Fix the next event code clocksource: sun4i: Don't forget to enable the clock we use clocksource: sun4i: Add clocksource and sched clock drivers clocksource: sun4i: rename AUTORELOAD define to RELOAD clocksource: sun4i: Wrap macros arguments in parenthesis ...
2013-09-04Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "Various optimizations, cleanups and smaller fixes - no major changes in scheduler behavior" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/fair: Fix the sd_parent_degenerate() code sched/fair: Rework and comment the group_imb code sched/fair: Optimize find_busiest_queue() sched/fair: Make group power more consistent sched/fair: Remove duplicate load_per_task computations sched/fair: Shrink sg_lb_stats and play memset games sched: Clean-up struct sd_lb_stat sched: Factor out code to should_we_balance() sched: Remove one division operation in find_busiest_queue() sched/cputime: Use this_cpu_add() in task_group_account_field() cpumask: Fix cpumask leak in partition_sched_domains() sched/x86: Optimize switch_mm() for multi-threaded workloads generic-ipi: Kill unnecessary variable - csd_flags numa: Mark __node_set() as __always_inline sched/fair: Cleanup: remove duplicate variable declaration sched/__wake_up_sync_key(): Fix nr_exclusive tasks which lead to WF_SYNC clearing
2013-09-04Merge branches 'perf-urgent-for-linus' and 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "As a first remark I'd like to point out that the obsolete '-f' (--force) option, which has not done anything for several releases, has been removed from 'perf record' and related utilities. Everyone please update muscle memory accordingly! :-) Main changes on the perf kernel side: - Performance optimizations: . for trace events, by Steve Rostedt. . for time values, by Peter Zijlstra - New hardware support: . for Intel Silvermont (22nm Atom) CPUs, by Zheng Yan . for Intel SNB-EP uncore PMUs, by Zheng Yan - Enhanced hardware support: . for Intel uncore PMUs: add filter support for QPI boxes, by Zheng Yan - Core perf events code enhancements and fixes: . for full-nohz feature handling, by Frederic Weisbecker . for group events, by Jiri Olsa . for call chains, by Frederic Weisbecker . for event stream parsing, by Adrian Hunter - New ABI details: . Add attr->mmap2 attribute, by Stephane Eranian . Add PERF_EVENT_IOC_ID ioctl to return event ID, by Jiri Olsa . Export u64 time_zero on the mmap header page to allow TSC calculation, by Adrian Hunter . Add dummy software event, by Adrian Hunter. . Add a new PERF_SAMPLE_IDENTIFIER to make samples always parseable, by Adrian Hunter. . Make Power7 events available via sysfs, by Runzhen Wang. - Code cleanups and refactorings: . for nohz-full, by Frederic Weisbecker . for group events, by Jiri Olsa - Documentation updates: . for perf_event_type, by Peter Zijlstra Main changes on the perf tooling side (some of these tooling changes utilize the above kernel side changes): - Lots of 'perf trace' enhancements: . Make 'perf trace' command line arguments consistent with 'perf record', by David Ahern. . Allow specifying syscalls a la strace, by Arnaldo Carvalho de Melo. . Add --verbose and -o/--output options, by Arnaldo Carvalho de Melo. . Support ! in -e expressions, to filter a list of syscalls, by Arnaldo Carvalho de Melo. . Arg formatting improvements to allow masking arguments in syscalls such as futex and open, where the some arguments are ignored and thus should not be printed depending on other args, by Arnaldo Carvalho de Melo. . Beautify futex open, openat, open_by_handle_at, lseek and futex syscalls, by Arnaldo Carvalho de Melo. . Add option to analyze events in a file versus live, so that one can do: [root@zoo ~]# perf record -a -e raw_syscalls:* sleep 1 [ perf record: Woken up 0 times to write data ] [ perf record: Captured and wrote 25.150 MB perf.data (~1098836 samples) ] [root@zoo ~]# perf trace -i perf.data -e futex --duration 1 17.799 ( 1.020 ms): 7127 futex(uaddr: 0x7fff3f6c6674, op: 393, val: 1, utime: 0x7fff3f6c6470, ua 113.344 (95.429 ms): 7127 futex(uaddr: 0x7fff3f6c6674, op: 393, val: 1, utime: 0x7fff3f6c6470, uaddr2: 0x7fff3f6c6648, val3: 4294967 133.778 ( 1.042 ms): 18004 futex(uaddr: 0x7fff3f6c6674, op: 393, val: 1, utime: 0x7fff3f6c6470, uaddr2: 0x7fff3f6c6648, val3: 429496 [root@zoo ~]# By David Ahern. . Honor target pid / tid options when analyzing a file, by David Ahern. . Introduce better formatting of syscall arguments, including so far beautifiers for mmap, madvise, syscall return values, by Arnaldo Carvalho de Melo. . Handle HUGEPAGE defines in the mmap beautifier, by David Ahern. - 'perf report/top' enhancements: . Do annotation using /proc/kcore and /proc/kallsyms when available, removing the forced need for a vmlinux file kernel assembly annotation. This also improves this use case because vmlinux has just the initial kernel image, not what is actually in use after various code patchings by things like alternatives. By Adrian Hunter. . Add --ignore-callees=<regex> option to collapse undesired parts of call graphs, by Greg Price. . Simplify symbol filtering by doing it at machine class level, by Adrian Hunter. . Add support for callchains in the gtk UI, by Namhyung Kim. . Add --objdump option to 'perf top', by Sukadev Bhattiprolu. - 'perf kvm' enhancements: . Add option to print only events that exceed a specified time duration, by David Ahern. . Improve stack trace printing, by David Ahern. . Update documentation of the live command, by David Ahern . Add perf kvm stat live mode that combines aspects of 'perf kvm stat' record and report, by David Ahern. . Add option to analyze specific VM in perf kvm stat report, by David Ahern. . Do not require /lib/modules/* on a guest, by Jason Wessel. - 'perf script' enhancements: . Fix symbol offset computation for some dsos, by David Ahern. . Fix named threads support, by David Ahern. . Don't install scripting files files when perl/python support is disabled, by Arnaldo Carvalho de Melo. - 'perf test' enhancements: . Add various improvements and fixes to the "vmlinux matches kallsyms" 'perf test' entry, related to the /proc/kcore annotation feature. By Adrian Hunter. . Add sample parsing test, by Adrian Hunter. . Add test for reading object code, by Adrian Hunter. . Add attr record group sampling test, by Jiri Olsa. . Misc testing infrastructure improvements and other details, by Jiri Olsa. - 'perf list' enhancements: . Skip unsupported hardware events, by Namhyung Kim. . List pmu events, by Andi Kleen. - 'perf diff' enhancements: . Add support for more than two files comparison, by Jiri Olsa. - 'perf sched' enhancements: . Various improvements, including removing reliance on some scheduler tracepoints that provide the same information as the PERF_RECORD_{FORK,EXIT} events. By David Ahern. . Remove odd build stall by moving a large struct initialization from a local variable to a global one, by Namhyung Kim. - 'perf stat' enhancements: . Add --initial-delay option to skip measuring for a defined startup phase, by Andi Kleen. - Generic perf tooling infrastructure/plumbing changes: . Tidy up sample parsing validation, by Adrian Hunter. . Fix up jobserver setup in libtraceevent Makefile. by Arnaldo Carvalho de Melo. . Debug improvements, by Adrian Hunter. . Fix correlation of samples coming after PERF_RECORD_EXIT event, by David Ahern. . Improve robustness of the topology parsing code, by Stephane Eranian. . Add group leader sampling, that allows just one event in a group to sample while the other events have just its values read, by Jiri Olsa. . Add support for a new modifier "D", which requests that the event, or group of events, be pinned to the PMU. By Michael Ellerman. . Support callchain sorting based on addresses, by Andi Kleen . Prep work for multi perf data file storage, by Jiri Olsa. . libtraceevent cleanups, by Namhyung Kim. And lots and lots of other fixes and code reorganizations that did not make it into the list, see the shortlog, diffstat and the Git log for details!" [ Also merge a leftover from the 3.11 cycle ] * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Prevent race in unthrottling code * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (237 commits) perf trace: Tell arg formatters the arg index perf trace: Add beautifier for open's flags arg perf trace: Add beautifier for lseek's whence arg perf tools: Fix symbol offset computation for some dsos perf list: Skip unsupported events perf tests: Add 'keep tracking' test perf tools: Add support for PERF_COUNT_SW_DUMMY perf: Add a dummy software event to keep tracking perf trace: Add beautifier for futex 'operation' parm perf trace: Allow syscall arg formatters to mask args perf: Convert kmalloc_node(...GFP_ZERO...) to kzalloc_node() perf: Export struct perf_branch_entry to userspace perf: Add attr->mmap2 attribute to an event perf/x86: Add Silvermont (22nm Atom) support perf/x86: use INTEL_UEVENT_EXTRA_REG to define MSR_OFFCORE_RSP_X perf trace: Handle missing HUGEPAGE defines perf trace: Honor target pid / tid options when analyzing a file perf trace: Add option to analyze events in a file versus live perf evlist: Add tracepoint lookup by name perf tests: Add a sample parsing test ...
