PV on HVM guests map GSIs into event channels. At restore time the
event channels are resumed by restore_pirqs.
Device drivers might try to register the same GSI again through ACPI at
restore time, but the GSI has already been mapped and bound by
restore_pirqs. This patch detects these situations and avoids
mapping the same GSI multiple times.
Without this patch we get:
(XEN) irq.c:2235: dom4: pirq 23 or emuirq 28 already mapped
and waste a pirq.
CC: stable@kernel.org
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
The git commit 1ff2b0c303698e486f1e0886b4d9876200ef8ca5
"xen: implement IRQ_WORK_VECTOR handler" added the functionality
to have a per-cpu "irqworkX" for the IPI APIC functionality.
However it missed the unbind when a vCPU is unplugged resulting
in an orphaned per-cpu interrupt line for unplugged vCPU:
30: 216 0 xen-dyn-event hvc_console
31: 810 4 xen-dyn-event eth0
32: 29 0 xen-dyn-event blkif
- 36: 0 0 xen-percpu-ipi irqwork2
- 37: 287 0 xen-dyn-event xenbus
+ 36: 287 0 xen-dyn-event xenbus
NMI: 0 0 Non-maskable interrupts
LOC: 0 0 Local timer interrupts
SPU: 0 0 Spurious interrupts
* stable/autoballoon.v5.2:
xen/setup: update VA mapping when releasing memory during setup
xen/setup: Combine the two hypercall functions - since they are quite similar.
xen/setup: Populate freed MFNs from non-RAM E820 entries and gaps to E820 RAM
xen/setup: Only print "Freeing XXX-YYY pfn range: Z pages freed" if Z > 0
xen/p2m: An early bootup variant of set_phys_to_machine
xen/p2m: Collapse early_alloc_p2m_middle redundant checks.
xen/p2m: Allow alloc_p2m_middle to call reserve_brk depending on argument
xen/p2m: Move code around to allow for better re-usage.
Provide the registration callback to call in the Xen's
ACPI sleep functionality. This means that during S3/S5
we make a hypercall XENPF_enter_acpi_sleep with the
proper PM1A/PM1B registers.
Based of Ke Yu's <ke.yu@intel.com> initial idea.
[ From http://xenbits.xensource.com/linux-2.6.18-xen.hg
change c68699484a65 ]
[v1: Added Copyright and license]
[v2: Added check if PM1A/B the 16-bits MSB contain something. The spec
only uses 16-bits but might have more in future]
Signed-off-by: Liang Tang <liang.tang@oracle.com>
Signed-off-by: Lin Ming <mlin@ss.pku.edu.cn>
Map native ipi vector to xen vector.
Implement apic ipi interface with xen_send_IPI_one.
Tested-by: Steven Noonan <steven@uplinklabs.net>
Signed-off-by: Ben Guthro <ben@guthro.net>
In xen_memory_setup(), if a page that is being released has a VA
mapping this must also be updated. Otherwise, the page will be not
released completely -- it will still be referenced in Xen and won't be
freed util the mapping is removed and this prevents it from being
reallocated at a different PFN.
This was already being done for the ISA memory region in
xen_ident_map_ISA() but on many systems this was omitting a few pages
as many systems marked a few pages below the ISA memory region as
reserved in the e820 map.
This fixes errors such as:
(XEN) page_alloc.c:1148:d0 Over-allocation for domain 0: 2097153 > 2097152
(XEN) memory.c:133:d0 Could not allocate order=0 extent: id=0 memflags=0 (0 of 17)
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
They use the same set of arguments, so it is just the matter
of using the proper hypercall.
Acked-by: David Vrabel <david.vrabel@citrix.com>
When the Xen hypervisor boots a PV kernel it hands it two pieces
of information: nr_pages and a made up E820 entry.
The nr_pages value defines the range from zero to nr_pages of PFNs
which have a valid Machine Frame Number (MFN) underneath it. The
E820 mirrors that (with the VGA hole):
BIOS-provided physical RAM map:
Xen: 0000000000000000 - 00000000000a0000 (usable)
Xen: 00000000000a0000 - 0000000000100000 (reserved)
Xen: 0000000000100000 - 0000000080800000 (usable)
The fun comes when a PV guest that is run with a machine E820 - that
can either be the initial domain or a PCI PV guest, where the E820
looks like the normal thing:
Xen: 0000000000000000 - 000000000009e000 (usable)
Xen: 000000000009ec00 - 0000000000100000 (reserved)
Xen: 0000000000100000 - 0000000020000000 (usable)
Xen: 0000000020000000 - 0000000020200000 (reserved)
Xen: 0000000020200000 - 0000000040000000 (usable)
Xen: 0000000040000000 - 0000000040200000 (reserved)
Xen: 0000000040200000 - 00000000bad80000 (usable)
Xen: 00000000bad80000 - 00000000badc9000 (ACPI NVS)
With that overlaying the nr_pages directly on the E820 does not
work as there are gaps and non-RAM regions that won't be used
by the memory allocator. The 'xen_release_chunk' helps with that
by punching holes in the P2M (PFN to MFN lookup tree) for those
regions and tells us that:
Freeing 20000-20200 pfn range: 512 pages freed
Freeing 40000-40200 pfn range: 512 pages freed
Freeing bad80-badf4 pfn range: 116 pages freed
Freeing badf6-bae7f pfn range: 137 pages freed
Freeing bb000-100000 pfn range: 282624 pages freed
Released 283999 pages of unused memory
Those 283999 pages are subtracted from the nr_pages and are returned
to the hypervisor. The end result is that the initial domain
boots with 1GB less memory as the nr_pages has been subtracted by
the amount of pages residing within the PCI hole. It can balloon up
to that if desired using 'xl mem-set 0 8092', but the balloon driver
is not always compiled in for the initial domain.
This patch, implements the populate hypercall (XENMEM_populate_physmap)
which increases the the domain with the same amount of pages that
were released.
The other solution (that did not work) was to transplant the MFN in
the P2M tree - the ones that were going to be freed were put in
the E820_RAM regions past the nr_pages. But the modifications to the
M2P array (the other side of creating PTEs) were not carried away.
As the hypervisor is the only one capable of modifying that and the
only two hypercalls that would do this are: the update_va_mapping
(which won't work, as during initial bootup only PFNs up to nr_pages
are mapped in the guest) or via the populate hypercall.
The end result is that the kernel can now boot with the
nr_pages without having to subtract the 283999 pages.
On a 8GB machine, with various dom0_mem= parameters this is what we get:
no dom0_mem
-Memory: 6485264k/9435136k available (5817k kernel code, 1136060k absent, 1813812k reserved, 2899k data, 696k init)
+Memory: 7619036k/9435136k available (5817k kernel code, 1136060k absent, 680040k reserved, 2899k data, 696k init)
dom0_mem=3G
-Memory: 2616536k/9435136k available (5817k kernel code, 1136060k absent, 5682540k reserved, 2899k data, 696k init)
+Memory: 2703776k/9435136k available (5817k kernel code, 1136060k absent, 5595300k reserved, 2899k data, 696k init)
dom0_mem=max:3G
-Memory: 2696732k/4281724k available (5817k kernel code, 1136060k absent, 448932k reserved, 2899k data, 696k init)
+Memory: 2702204k/4281724k available (5817k kernel code, 1136060k absent, 443460k reserved, 2899k data, 696k init)
And the 'xm list' or 'xl list' now reflect what the dom0_mem=
argument is.
[v2: Use populate hypercall]
[v3: Remove debug printks]
[v4: Simplify code]
Otherwise we can get these meaningless:
Freeing bad80-badf4 pfn range: 0 pages freed
We also can do this for the summary ones - no point of printing
"Set 0 page(s) to 1-1 mapping"
[v1: Extended to the summary printks]
Move the code from Xen to debugfs to make the code common
for other users as well.
Accked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Signed-off-by: Suzuki Poulose <suzuki@in.ibm.com>
[v1: Fixed rebase issues]
[v2: Fixed PPC compile issues]
Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
Pull ARM fixes from Russell King:
"Nothing too disasterous, the biggest thing being the removal of the
regulator support for vcore in the AMBA driver; only one SoC was using
this and it got broken during the last merge window, which then
started causing problems for other people. Mutual agreement was
reached for it to be removed."
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7386/1: jump_label: fixup for rename to static_key
ARM: 7384/1: ThumbEE: Disable userspace TEEHBR access for !CONFIG_ARM_THUMBEE
ARM: 7382/1: mm: truncate memory banks to fit in 4GB space for classic MMU
ARM: 7359/2: smp_twd: Only wait for reprogramming on active cpus
ARM: 7383/1: nommu: populate vectors page from paging_init
ARM: 7381/1: nommu: fix typo in mm/Kconfig
ARM: 7380/1: DT: do not add a zero-sized memory property
ARM: 7379/1: DT: fix atags_to_fdt() second call site
ARM: 7366/3: amba: Remove AMBA level regulator support
ARM: 7377/1: vic: re-read status register before dispatching each IRQ handler
ARM: 7368/1: fault.c: correct how the tsk->[maj|min]_flt gets incremented
The 'max' range needs to be unsigned, since the size of the user address
space is bigger than 2GB.
We know that 'count' is positive in 'long' (that is checked in the
caller), so we will truncate 'max' down to something that fits in a
signed long, but before we actually do that, that comparison needs to be
done in unsigned.
Bug introduced in commit 92ae03f2ef99 ("x86: merge 32/64-bit versions of
'strncpy_from_user()' and speed it up"). On x86-64 you can't trigger
this, since the user address space is much smaller than 63 bits, and on
x86-32 it works in practice, since you would seldom hit the strncpy
limits anyway.
I had actually tested the corner-cases, I had only tested them on
x86-64. Besides, I had only worried about the case of a pointer *close*
to the end of the address space, rather than really far away from it ;)
This also changes the "we hit the user-specified maximum" to return
'res', for the trivial reason that gcc seems to generate better code
that way. 'res' and 'count' are the same in that case, so it really
doesn't matter which one we return.
c5905afb0 ("static keys: Introduce 'struct static_key'...") renamed
struct jump_label_key to struct static_key. Fixup ARM for this to
eliminate these build warnings:
include/linux/jump_label.h:113:2:
warning: passing argument 1 of 'arch_static_branch' from incompatible pointer type
include/asm/jump_label.h:17:82:
note: expected 'struct jump_label_key *' but argument is of type 'struct static_key *'
Signed-off-by: Rabin Vincent <rabin@rab.in>
Currently when ThumbEE is not enabled (!CONFIG_ARM_THUMBEE) the ThumbEE
register states are not saved/restored at context switch. The default state
of the ThumbEE Ctrl register (TEECR) allows userspace accesses to the
ThumbEE Base Handler register (TEEHBR). This can cause unexpected behaviour
when people use ThumbEE on !CONFIG_ARM_THUMBEE kernels, as well as allowing
covert communication - eg between userspace tasks running inside chroot
jails.
This patch sets up TEECR in order to prevent user-space access to TEEHBR
when !CONFIG_ARM_THUMBEE. In this case, tasks are sent SIGILL if they try to
access TEEHBR.
Cc: stable@vger.kernel.org
Reviewed-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Jonathan Austin <jonathan.austin@arm.com>
If a bank of memory spanning the 4GB boundary is added on a !CONFIG_LPAE
kernel then we will hang early during boot since the memory bank will
have wrapped around to zero.
This patch truncates memory banks for !LPAE configurations when the end
address is not representable in 32 bits.
Acked-by: Nicolas Pitre <nico@linaro.org>
During booting of cpu1, there is a short window where cpu1
is online, but not active where cpu1 is occupied by waiting
to become active. If cpu0 then decides to schedule something
on cpu1 and wait for it to complete, before cpu0 has set
cpu1 active, we have a deadlock.
Typically it's this CPU frequency transition that happens at
this time, so let's just not wait for it to happen, it will
happen whenever the CPU eventually comes online instead.
Cc: stable@kernel.org
Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com>
Reviewed-by: Rickard Andersson <rickard.andersson@stericsson.com>
Pull "ARM: a few more SoC fixes for 3.4-rc" from Olof Johansson:
- A handful of warning and build fixes for Qualcomm MSM
- Build/warning and bug fixes for Samsung Exynos
- A fix from Rob Herring that removes misplaced interrupt-parent
properties from a few device trees
- A fix to OMAP dealing with cpufreq build errors, removing some of the
offending code since it was redundant anyway
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: OMAP: clock: cleanup CPUfreq leftovers, fix build errors
ARM: dts: remove blank interrupt-parent properties
ARM: EXYNOS: Fix Kconfig dependencies for device tree enabled machine files
ARM: EXYNOS: Remove broken config values for touchscren for NURI board
ARM: EXYNOS: set fix xusbxti clock for NURI and Universal210 boards
ARM: EXYNOS: fix regulator name for NURI board
ARM: SAMSUNG: make SAMSUNG_PM_DEBUG select DEBUG_LL
ARM: msm: Fix section mismatches in proc_comm.c
video: msm: Fix section mismatches in mddi.c
arm: msm: trout: fix compile failure
arm: msm: halibut: remove unneeded fixup
ARM: EXYNOS: Add PDMA and MDMA physical base address defines
ARM: S5PV210: Fix compiler warning in dma.c file
ARM: EXYNOS: Fix compile error in exynos5250-cpufreq.c
ARM: EXYNOS: Add missing definition for IRQ_I2S0
ARM: S5PV210: fix unused LDO supply field from wm8994_pdata
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes
* 'v3.4-samsung-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
Now that we have OPP layer, and OMAP CPUfreq driver is using it, we no
longer need/use the clock framework code for filling up CPUfreq
tables. Remove it.
Removing this code also eliminates build errors when CPU_FREQ_TABLE
support is not enabled.
Thanks to Russell King for pointing out the parts I missed under
plat-omap in the original version and also pointing out the build
errors when CPUFREQ_TABLE support was not enabled.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Kevin Hilman <khilman@ti.com>
Acked-by: Paul Walmsley <paul@pwsan.com>
These were incorrectly introduced and can cause problems for of_irq_init.
The correct way to define a root controller is no interrupt-parent set at
all or the interrupt-parent is set to the root controller itself when
inherited from a parent node.
Tested-by: Lee Jones <lee.jones@linaro.org>
Add config dependency for Exynos4 and Exynos5 device tree enabled machine
files on config options ARCH_EXYNOS4 and ARCH_EXYNOS5 respectively.
Enabling machine support without proper ARCH support enabled is incorrect.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
The atmel_mxt_ts driver has been extended to support more 'configuration
objects' in commit 81c88a711 ("Input: atmel_mxt_ts - update object list"),
what broke the configuration values for NURI board. These values are
optional anyway, so remove them to get the driver working correctly.
On some versions of NURI and UniversalC210 boards, camera clocks are
routed directly to xusbxti clock source. This patch sets the correct
value for this clock to let usb and camera sensors to work correctly and
avoid division by zero on driver's probe.
Regulator names should not contain slash to avoid issues with debugfs.
When selecting SAMSUNG_PM_DEBUG, it complains about a missing printascii()
function if you do not select DEBUG_LL, so make the former select the latter.
Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull system.h fixups for less common arch's from Paul Gortmaker:
"Here is what is hopefully the last of the system.h related fixups.
The fixes for Alpha and ia64 are code relocations consistent with what
was done for the more mainstream architectures. Note that the
diffstat lines removed vs lines added are not the same since I've
fixed some of the whitespace issues in the relocated code blocks.
However they are functionally the same. Compile tested locally, plus
these two have been in linux-next for a while.
There is also a trivial one line system.h related fix for the Tilera
arch from Chris Metcalf to fix an implict include.."
* 'systemh-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
irq_work: fix compile failure on tile from missing include
ia64: populate the cmpxchg header with appropriate code
alpha: fix build failures from system.h dismemberment
The invocation of softirq is now handled by irq_exit(), so there is no
need for sparc64 to invoke it on the trap-return path. In fact, doing so
is a bug because if the trap occurred in the idle loop, this invocation
can result in lockdep-RCU failures. The problem is that RCU ignores idle
CPUs, and the sparc64 trap-return path to the softirq handlers fails to
tell RCU that the CPU must be considered non-idle while those handlers
are executing. This means that RCU is ignoring any RCU read-side critical
sections in those handlers, which in turn means that RCU-protected data
can be yanked out from under those read-side critical sections.
The shiny new lockdep-RCU ability to detect RCU read-side critical sections
that RCU is ignoring located this problem.
The fix is straightforward: Make sparc64 stop manually invoking the
softirq handlers.
Reported-by: Meelis Roos <mroos@linux.ee>
Suggested-by: David Miller <davem@davemloft.net>
Tested-by: Meelis Roos <mroos@linux.ee>
The DS driver registers as a subsys_initcall() but this can be too
early, in particular this risks registering before we've had a chance
to allocate and setup module_kset in kernel/params.c which is
performed also as a subsyts_initcall().
Register DS using device_initcall() insteal.
The change
commit 4416e9eb0b4859b3d28016c5fd0a609bdcbc8a2a
Author: Gregory Bean <gbean@codeaurora.org>
Date: Wed Jul 28 10:22:12 2010 -0700
arm: msm: Fix section mismatch in smd.c.
fixes a section mismatch between the board file and the smd driver's
probe function, however, it misses the additional mismatches between
the probe function and some routines it calls. Fix these up as well.
Signed-off-by: David Brown <davidb@codeaurora.org>
Fixes the following warnings,
arch/arm/mach-msm/board-trout.c: In function 'trout_init':
arch/arm/mach-msm/board-trout.c:71: error: 'system_rev' undeclared (first use in this function)
arch/arm/mach-msm/board-trout.c:71: error: (Each undeclared identifier is reported only once
arch/arm/mach-msm/board-trout.c:71: error: for each function it appears in.)
and
arch/arm/mach-msm/board-trout-panel.c: In function 'trout_init_panel':
arch/arm/mach-msm/board-trout-panel.c:267: error: 'system_rev' undeclared (first use in this function)
arch/arm/mach-msm/board-trout-panel.c:267: error: (Each undeclared identifier is reported only once
arch/arm/mach-msm/board-trout-panel.c:267: error: for each function it appears in.)
This came in with the following commit 9f97da78bf018206fb623cd351d454af2f105fe0
which removes asm/system.h
Signed-off-by: Daniel Walker <dwalker@fifo99.com>
cc: David Howells <dhowells@redhat.com>
cc: Bryan Huntsman <bryanh@codeaurora.org>
cc: linux-arm-msm@vger.kernel.org
cc: linux-arm-kernel@lists.infradead.org
This old fixup causes a build failure, so I remove it just like in
trout.
commit 93f378883cecb9dcb2cf5b51d9d24175906659da
"Fix ia64 build errors (fallout from system.h disintegration)"
introduced arch/ia64/include/asm/cmpxchg.h as a temporary
build fix and stated:
"... leave the migration of xchg() and cmpxchg() to this new
header file for a future patch."
Migrate the appropriate chunks from asm/intrinsics.h and fix
the whitespace issues in the migrated chunk.
Acked-by: Tony Luck <tony.luck@intel.com>
commit ec2212088c42ff7d1362629ec26dda4f3e8bdad3
"Disintegrate asm/system.h for Alpha"
combined with commit b4816afa3986704d1404fc48e931da5135820472
"Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h"
introduced the concept of asm/cmpxchg.h but the alpha arch
never got one. Fork the cmpxchg content out of the asm/atomic.h
file to create one.
Some minor whitespace fixups were done on the block of code that
created the new file.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Acked-by: Matt Turner <mattst88@gmail.com>
Commit 94e5a85b ("ARM: earlier initialization of vectors page") made it
the responsibility of paging_init to initialise the vectors page.
This patch adds a call to early_trap_init for the !CONFIG_MMU case,
placing the vectors at CONFIG_VECTORS_BASE.
Cc: Jonathan Austin <jonathan.austin@arm.com>
The description for the CPU_HIGH_VECTOR Kconfig option for nommu builds
doesn't make any sense.
This patch fixes up the trivial grammatical error.
Some bootloaders are broken enough to expose an ATAG_MEM with
a null size. Converting such tag to a memory node leads to
an unbootable system.
Skip over zero sized ATAG_MEM to avoid this situation.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
atags_to_fdt() returns 1 when it fails to find a valid FDT signature.
The CONFIG_ARM_ATAG_DTB_COMPAT code is supposed to retry with another
location, but only does so when the initial call doesn't fail.
Fix this by using the correct condition in the assembly code.
Pull x86 fixes from Thomas Gleixner.
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Use correct byte-sized register constraint in __add()
x86: Use correct byte-sized register constraint in __xchg_op()
x86: vsyscall: Use NULL instead 0 for a pointer argument
Pull irqdomain bug fixes from Grant Likely:
"This branch fixes a bug in irq_create_mapping() where an error return
from irq_alloc_desc_from() gets ignored.
It also removes irq_virq_count to fix a bug on powerpc where the
irqdomain code does not find irqs allocated above the CONFIG_NR_IRQS
boundary.
The remaining patches get rid of an completely pointless export and
fix some minor bugs in the irqdomain debug output."
* tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6:
irq_domain: Move irq_virq_count into NOMAP revmap
irqdomain: Fix debugfs formatting
irq_domain: correct the debugfs file name
irq: Kill pointless irqd_to_hw export
irq/irq_domain: Quit ignoring error returns from irq_alloc_desc_from().
This patch replaces the old global setting of irq_virq_count that is only
used by the NOMAP mapping and instead uses a revmap_data property so that
the maximum NOMAP allocation can be set per NOMAP irq_domain.
There is exactly one user of irq_virq_count in-tree right now: PS3.
Also, irq_virq_count is only useful for the NOMAP mapping. So,
instead of having a single global irq_virq_count values, this change
drops it entirely and added a max_irq argument to irq_domain_add_nomap().
That makes it a property of an individual nomap irq domain instead of
a global system settting.
Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Milton Miller <miltonm@bga.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc fixes from Benjamin Herrenschmidt:
"Fixes for two nasty regression affecting powerpc in 3.4."
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc: Fix typo in runlatch code
powerpc: Fix page fault with lockdep regression
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull arch/tile fixes from Chris Metcalf:
"This is one important change from Srivatsa Bhat that got dropped when
I put together my pull request for -rc2, plus a trivial change to
remove a compiler warning."
* 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch/tile: avoid unused variable warning in proc.c for tilegx
tile/CPU hotplug: Add missing call to notify_cpu_starting()
Until we push the unaligned access support for tilegx, it's silly
to have arch/tile/kernel/proc.c generate a warning about an unused
variable. Extend the #ifdef to cover all the code and data for now.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
This merges the 32- and 64-bit versions of the x86 strncpy_from_user()
by just rewriting it in C rather than the ancient inline asm versions
that used lodsb/stosb and had been duplicated for (trivial) differences
between the 32-bit and 64-bit versions.
While doing that, it also speeds them up by doing the accesses a word at
a time. Finally, the new routines also properly handle the case of
hitting the end of the address space, which we have never done correctly
before (fs/namei.c has a hack around it for that reason).
Despite all these improvements, it actually removes more lines than it
adds, due to the de-duplication. Also, we no longer export (or define)
the legacy __strncpy_from_user() function (that was defined to not do
the user permission checks), since it's not actually used anywhere, and
the user address space checks are built in to the new code.
Other architecture maintainers have been notified that the old hack in
fs/namei.c will be going away in the 3.5 merge window, in case they
copied the x86 approach of being a bit cavalier about the end of the
address space.
Cc: Peter Anvin" <hpa@zytor.com>
It makes no sense to export this trivial function. Make it a static inline
instead.
This patch also drops virq_to_hw from arch/c6x since it is unused by that
architecture.
v2: Move irq_hw_number_t into types.h to fix ARM build failure
Commit fe1952fc0afb9a2e4c79f103c08aef5d13db1873
"powerpc: Rework runlatch code" has a nasty typo
where it uses "TLF_RUNLATCH" instead of "_TLF_RUNLATCH"
(bit number instead of bit mask), causing some flags to
be potentially lost such as _TLF_RESTORE_SIGMASK
(Brown paper bag for me ! We should be able to make
that break at compile time with a bit of magic, any
volunteer ?)
Pull sparc fixes from David Miller:
1) Build fix for LEON, from Sam Ravnborg.
2) Make the sparc side changes that go along with the infrastructure to
retry faults when blocking on a disk transfer. From Kautuk Consul.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc32,leon: fix leon build
sparc/mm/fault_32.c: Port OOM changes to do_sparc_fault
sparc/mm/fault_64.c: Port OOM changes to do_sparc64_fault
Add PDMA and MDMA physical base address macros which is
require for EXYNOS5 of_dev_auxdata setup.
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
[kgene.kim@samsung.com: changed dma channel fo mdma1]
Fixes the following warning:
warning: 'dma_dmamask' defined but not used [-Wunused-variable]
