path: root/arch
2013-04-26KVM: IA64: Carry non-ia64 changes into ia64Alexander Graf
We changed a few things in non-ia64 code paths. This patch blindly applies the changes to the ia64 code as well, hoping it proves useful in case anyone revives the ia64 kvm code. Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: MPIC: Restrict to e500 platformsAlexander Graf
The code as is doesn't make any sense on non-e500 platforms. Restrict it there, so that people don't get wrong ideas on what would actually work. This patch should get reverted as soon as it's possible to either run e500 guests on non-e500 hosts or the MPIC emulation gains support for non-e500 modes. Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: MPIC: Add support for KVM_IRQ_LINEAlexander Graf
Now that all pieces are in place for reusing generic irq infrastructure, we can copy x86's implementation of KVM_IRQ_LINE irq injection and simply reuse it for PPC, as it will work there just as well. Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: Support irq routing and irqfd for in-kernel MPICAlexander Graf
Now that all the irq routing and irqfd pieces are generic, we can expose real irqchip support to all of KVM's internal helpers. This allows us to use irqfd with the in-kernel MPIC. Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26kvm/ppc/mpic: add KVM_CAP_IRQ_MPICScott Wood
Enabling this capability connects the vcpu to the designated in-kernel MPIC. Using explicit connections between vcpus and irqchips allows for flexibility, but the main benefit at the moment is that it simplifies the code -- KVM doesn't need vm-global state to remember which MPIC object is associated with this vm, and it doesn't need to care about ordering between irqchip creation and vcpu creation. Signed-off-by: Scott Wood <scottwood@freescale.com> [agraf: add stub functions for kvmppc_mpic_{dis,}connect_vcpu] Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26kvm/ppc/mpic: in-kernel MPIC emulationScott Wood
Hook the MPIC code up to the KVM interfaces, add locking, etc. Signed-off-by: Scott Wood <scottwood@freescale.com> [agraf: add stub function for kvmppc_mpic_set_epr, non-booke, 64bit] Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26kvm/ppc/mpic: adapt to kernel style and environmentScott Wood
Remove braces that Linux style doesn't permit, remove space after '*' that Lindent added, keep error/debug strings contiguous, etc. Substitute type names, debug prints, etc. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26kvm/ppc/mpic: remove some obviously unneeded codeScott Wood
Remove some parts of the code that are obviously QEMU or Raven specific before fixing style issues, to reduce the style issues that need to be fixed. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26kvm/ppc/mpic: import hw/openpic.c from QEMUScott Wood
This is QEMU's hw/openpic.c from commit abd8d4a4d6dfea7ddea72f095f993e1de941614e ("Update version for 1.4.0-rc0"), run through Lindent with no other changes to ease merging future changes between Linux and QEMU. Remaining style issues (including those introduced by Lindent) will be fixed in a later patch. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: Move irqfd resample cap handling to generic codeAlexander Graf
Now that we have most irqfd code completely platform agnostic, let's move irqfd's resample capability return to generic code as well. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Michael S. Tsirkin <mst@redhat.com>
2013-04-26KVM: Extract generic irqchip logic into irqchip.cAlexander Graf
The current irq_comm.c file contains pieces of code that are generic across different irqchip implementations, as well as code that is fully IOAPIC specific. Split the generic bits out into irqchip.c. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Michael S. Tsirkin <mst@redhat.com>
2013-04-26KVM: Introduce CONFIG_HAVE_KVM_IRQ_ROUTINGAlexander Graf
Quite a bit of code in KVM has been conditionalized on availability of IOAPIC emulation. However, most of it is generically applicable to platforms that don't have an IOPIC, but a different type of irq chip. Make code that only relies on IRQ routing, not an APIC itself, on CONFIG_HAVE_KVM_IRQ_ROUTING, so that we can reuse it later. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Michael S. Tsirkin <mst@redhat.com>
2013-04-26KVM: Add KVM_IRQCHIP_NUM_PINS in addition to KVM_IOAPIC_NUM_PINSAlexander Graf
The concept of routing interrupt lines to an irqchip is nothing that is IOAPIC specific. Every irqchip has a maximum number of pins that can be linked to irq lines. So let's add a new define that allows us to reuse generic code for non-IOAPIC platforms. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Michael S. Tsirkin <mst@redhat.com>
2013-04-26KVM: PPC: Book3S HV: Report VPA and DTL modifications in dirty mapPaul Mackerras
At present, the KVM_GET_DIRTY_LOG ioctl doesn't report modifications done by the host to the virtual processor areas (VPAs) and dispatch trace logs (DTLs) registered by the guest. This is because those modifications are done either in real mode or in the host kernel context, and in neither case does the access go through the guest's HPT, and thus no change (C) bit gets set in the guest's HPT. However, the changes done by the host do need to be tracked so that the modified pages get transferred when doing live migration. In order to track these modifications, this adds a dirty flag to the struct representing the VPA/DTL areas, and arranges to set the flag when the VPA/DTL gets modified by the host. Then, when we are collecting the dirty log, we also check the dirty flags for the VPA and DTL for each vcpu and set the relevant bit in the dirty log if necessary. Doing this also means we now need to keep track of the guest physical address of the VPA/DTL areas. So as not to lose track of modifications to a VPA/DTL area when it gets unregistered, or when a new area gets registered in its place, we need to transfer the dirty state to the rmap chain. This adds code to kvmppc_unpin_guest_page() to do that if the area was dirty. To simplify that code, we now require that all VPA, DTL and SLB shadow buffer areas fit within a single host page. Guests already comply with this requirement because pHyp requires that these areas not cross a 4k boundary. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: Book3S HV: Make HPT reading code notice R/C bit changesPaul Mackerras
At present, the code that determines whether a HPT entry has changed, and thus needs to be sent to userspace when it is copying the HPT, doesn't consider a hardware update to the reference and change bits (R and C) in the HPT entries to constitute a change that needs to be sent to userspace. This adds code to check for changes in R and C when we are scanning the HPT to find changed entries, and adds code to set the changed flag for the HPTE when we update the R and C bits in the guest view of the HPTE. Since we now need to set the HPTE changed flag in book3s_64_mmu_hv.c as well as book3s_hv_rm_mmu.c, we move the note_hpte_modification() function into kvm_book3s_64.h. Current Linux guest kernels don't use the hardware updates of R and C in the HPT, so this change won't affect them. Linux (or other) kernels might in future want to use the R and C bits and have them correctly transferred across when a guest is migrated, so it is better to correct this deficiency. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: e500: Add e6500 core to Kconfig descriptionMihai Caraman
Add e6500 core to Kconfig description. Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: e500mc: Enable e6500 coresMihai Caraman
Extend processor compatibility names to e6500 cores. Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com> Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: e500: Remove E.PT and E.HV.LRAT categories from VCPUsMihai Caraman
Embedded.Page Table (E.PT) category is not supported yet in e6500 kernel. Configure TLBnCFG to remove E.PT and E.HV.LRAT categories from VCPUs. Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: e500: Add support for EPTCFG registerMihai Caraman
EPTCFG register defined by E.PT is accessed unconditionally by Linux guests in the presence of MAV 2.0. Emulate it now. Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: e500: Add support for TLBnPS registersMihai Caraman
Add support for TLBnPS registers available in MMU Architecture Version (MAV) 2.0. Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: e500: Move vcpu's MMU configuration to dedicated functionsMihai Caraman
Vcpu's MMU default configuration and geometry update logic was buried in a chunk of code. Move them to dedicated functions to add more clarity. Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: e500: Expose MMU registers via ONE_REGMihai Caraman
MMU registers were exposed to user-space using sregs interface. Add them to ONE_REG interface using kvmppc_get_one_reg/kvmppc_set_one_reg delegation mechanism. Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: Book3E: Refactor ONE_REG ioctl implementationMihai Caraman
Refactor Book3E ONE_REG ioctl implementation to use kvmppc_get_one_reg/ kvmppc_set_one_reg delegation interface introduced by Book3S. This is necessary for MMU SPRs which are platform specifics. Get rid of useless case braces in the process. Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26booke: exit to user space if emulator requestBharat Bhushan
This allows the exit to user space if emulator request by returning EMULATE_EXIT_USER. This will be used in subsequent patches in list Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: extend EMULATE_EXIT_USER to support different exit reasonsBharat Bhushan
Currently the instruction emulator code returns EMULATE_EXIT_USER and common code initializes the "run->exit_reason = .." and "vcpu->arch.hcall_needed = .." with one fixed reason. But there can be different reasons when emulator need to exit to user space. To support that the "run->exit_reason = .." and "vcpu->arch.hcall_needed = .." initialization is moved a level up to emulator. Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26Rename EMULATE_DO_PAPR to EMULATE_EXIT_USERBharat Bhushan
Instruction emulation return EMULATE_DO_PAPR when it requires exit to userspace on book3s. Similar return is required for booke. EMULATE_DO_PAPR reads out to be confusing so it is renamed to EMULATE_EXIT_USER. Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: debug stub interface parameter definedBharat Bhushan
This patch defines the interface parameter for KVM_SET_GUEST_DEBUG ioctl support. Follow up patches will use this for setting up hardware breakpoints, watchpoints and software breakpoints. Also kvm_arch_vcpu_ioctl_set_guest_debug() is brought one level below. This is because I am not sure what is required for book3s. So this ioctl behaviour will not change for book3s. Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: cache flush for kernel managed pagesBharat Bhushan
Kernel can only access pages which maps as memory. So flush only the valid kernel pages. Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-25KVM: X86 emulator: fix source operand decoding for 8bit mov[zs]x instructionsGleb Natapov
Source operand for one byte mov[zs]x is decoded incorrectly if it is in high byte register. Fix that. Cc: stable@vger.kernel.org Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: VM_ENTRY/EXIT_LOAD_IA32_EFER overrides EFER.LMA settingsJan Kiszka
If we load the complete EFER MSR on entry or exit, EFER.LMA (and LME) loading is skipped. Their consistency is already checked now before starting the transition. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Validate EFER values for VM_ENTRY/EXIT_LOAD_IA32_EFERJan Kiszka
As we may emulate the loading of EFER on VM-entry and VM-exit, implement the checks that VMX performs on the guest and host values on vmlaunch/ vmresume. Factor out kvm_valid_efer for this purpose which checks for set reserved bits. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Fix conditions for NMI injectionJan Kiszka
The logic for checking if interrupts can be injected has to be applied also on NMIs. The difference is that if NMI interception is on these events are consumed and blocked by the VM exit. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: VMX: Move vmx_nmi_allowed after vmx_set_nmi_maskJan Kiszka
vmx_set_nmi_mask will soon be used by vmx_nmi_allowed. No functional changes. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: x86: Fix memory leak in vmx.cAndrew Honig
If userspace creates and destroys multiple VMs within the same process we leak 20k of memory in the userspace process context per VM. This patch frees the memory in kvm_arch_destroy_vm. If the process exits without closing the VM file descriptor or the file descriptor has been shared with another process then we don't free the memory. It's still possible for a user space process to leak memory if the last process to close the fd for the VM is not the process that created it. However, this is an unexpected case that's only caused by a user space process that's misbehaving. Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: x86: fix error return code in kvm_arch_vcpu_init()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as returned elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Enable and disable shadow vmcs functionalityAbel Gordon
Once L1 loads VMCS12 we enable shadow-vmcs capability and copy all the VMCS12 shadowed fields to the shadow vmcs. When we release the VMCS12, we also disable shadow-vmcs capability. Signed-off-by: Abel Gordon <abelg@il.ibm.com> Reviewed-by: Orit Wasserman <owasserm@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Synchronize VMCS12 content with the shadow vmcsAbel Gordon
Synchronize between the VMCS12 software controlled structure and the processor-specific shadow vmcs Signed-off-by: Abel Gordon <abelg@il.ibm.com> Reviewed-by: Orit Wasserman <owasserm@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Copy VMCS12 to processor-specific shadow vmcsAbel Gordon
Introduce a function used to copy fields from the software controlled VMCS12 to the processor-specific shadow vmcs Signed-off-by: Abel Gordon <abelg@il.ibm.com> Reviewed-by: Orit Wasserman <owasserm@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Copy processor-specific shadow-vmcs to VMCS12Abel Gordon
Introduce a function used to copy fields from the processor-specific shadow vmcs to the software controlled VMCS12 Signed-off-by: Abel Gordon <abelg@il.ibm.com> Reviewed-by: Orit Wasserman <owasserm@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Release shadow vmcsAbel Gordon
Unmap vmcs12 and release the corresponding shadow vmcs Signed-off-by: Abel Gordon <abelg@il.ibm.com> Reviewed-by: Orit Wasserman <owasserm@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Allocate shadow vmcsAbel Gordon
Allocate a shadow vmcs used by the processor to shadow part of the fields stored in the software defined VMCS12 (let L1 access fields without causing exits). Note we keep a shadow vmcs only for the current vmcs12. Once a vmcs12 becomes non-current, its shadow vmcs is released. Signed-off-by: Abel Gordon <abelg@il.ibm.com> Reviewed-by: Orit Wasserman <owasserm@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Fix VMXON emulationAbel Gordon
handle_vmon doesn't check if L1 is already in root mode (VMXON was previously called). This patch adds this missing check and calls nested_vmx_failValid if VMX is already ON. We need this check because L0 will allocate the shadow vmcs when L1 executes VMXON and we want to avoid host leaks (due to shadow vmcs allocation) if L1 executes VMXON repeatedly. Signed-off-by: Abel Gordon <abelg@il.ibm.com> Reviewed-by: Orit Wasserman <owasserm@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Refactor handle_vmwriteAbel Gordon
Refactor existent code so we re-use vmcs12_write_any to copy fields from the shadow vmcs specified by the link pointer (used by the processor, implementation-specific) to the VMCS12 software format used by L0 to hold the fields in L1 memory address space. Signed-off-by: Abel Gordon <abelg@il.ibm.com> Reviewed-by: Orit Wasserman <owasserm@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Introduce vmread and vmwrite bitmapsAbel Gordon
Prepare vmread and vmwrite bitmaps according to a pre-specified list of fields. These lists are intended to specifiy most frequent accessed fields so we can minimize the number of fields that are copied from/to the software controlled VMCS12 format to/from to processor-specific shadow vmcs. The lists were built measuring the VMCS fields access rate after L2 Ubuntu 12.04 booted when it was running on top of L1 KVM, also Ubuntu 12.04. Note that during boot there were additional fields which were frequently modified but they were not added to these lists because after boot these fields were not longer accessed by L1. Signed-off-by: Abel Gordon <abelg@il.ibm.com> Reviewed-by: Orit Wasserman <owasserm@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Detect shadow-vmcs capabilityAbel Gordon
Add logic required to detect if shadow-vmcs is supported by the processor. Introduce a new kernel module parameter to specify if L0 should use shadow vmcs (or not) to run L1. Signed-off-by: Abel Gordon <abelg@il.ibm.com> Reviewed-by: Orit Wasserman <owasserm@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22KVM: nVMX: Shadow-vmcs control fields/bitsAbel Gordon
Add definitions for all the vmcs control fields/bits required to enable vmcs-shadowing Signed-off-by: Abel Gordon <abelg@il.ibm.com> Reviewed-by: Orit Wasserman <owasserm@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-22Merge git://github.com/agraf/linux-2.6.git kvm-ppc-next into queueGleb Natapov
2013-04-17KVM: ia64: Fix kvm_vm_ioctl_irq_lineYang Zhang
Fix the compile error with kvm_vm_ioctl_irq_line. Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-04-17KVM: x86: Fix posted interrupt with CONFIG_SMP=nZhang, Yang Z
->send_IPI_mask is not defined on UP. Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-04-17kvm/ppc: don't call complete_mmio_load when it's a storeScott Wood
complete_mmio_load writes back the mmio result into the destination register. Doing this on a store results in register corruption. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de>
