path: root/arch
2017-06-14ARM: 8637/1: Adjust memory boundaries after reservationsLaura Abbott
commit 985626564eedc470ce2866e53938303368ad41b7 upstream. adjust_lowmem_bounds is responsible for setting up the boundary for lowmem/highmem. This needs to be setup before memblock reservations can occur. At the time memblock reservations can occur, memory can also be removed from the system. The lowmem/highmem boundary and end of memory may be affected by this but it is currently not recalculated. On some systems this may be harmless, on others this may result in incorrect ranges being passed to the main memory allocator. Correct this by recalculating the lowmem/highmem boundary after all reservations have been made. Tested-by: Magnus Lilja <lilja.magnus@gmail.com> Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Julien Grall <julien.grall@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14ARM: 8636/1: Cleanup sanity_check_meminfoLaura Abbott
commit 374d446d25d6271ee615952a3b7f123ba4983c35 upstream. The logic for sanity_check_meminfo has become difficult to follow. Clean up the code so it's more obvious what the code is actually trying to do. Additionally, meminfo is now removed so rename the function to better describe its purpose. Tested-by: Magnus Lilja <lilja.magnus@gmail.com> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Julien Grall <julien.grall@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14arm64: entry: improve data abort handling of tagged pointersKristina Martsenko
commit 276e93279a630657fff4b086ba14c95955912dfa upstream. This backport has a minor difference from the upstream commit: it adds the asm-uaccess.h file, which is not present in 4.9, because 4.9 does not have commit b4b8664d291a ("arm64: don't pull uaccess.h into *.S"). Original patch description: When handling a data abort from EL0, we currently zero the top byte of the faulting address, as we assume the address is a TTBR0 address, which may contain a non-zero address tag. However, the address may be a TTBR1 address, in which case we should not zero the top byte. This patch fixes that. The effect is that the full TTBR1 address is passed to the task's signal handler (or printed out in the kernel log). When handling a data abort from EL1, we leave the faulting address intact, as we assume it's either a TTBR1 address or a TTBR0 address with tag 0x00. This is true as far as I'm aware, we don't seem to access a tagged TTBR0 address anywhere in the kernel. Regardless, it's easy to forget about address tags, and code added in the future may not always remember to remove tags from addresses before accessing them. So add tag handling to the EL1 data abort handler as well. This also makes it consistent with the EL0 data abort handler. Fixes: d50240a5f6ce ("arm64: mm: permit use of tagged pointers at EL0") Reviewed-by: Dave Martin <Dave.Martin@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Kristina Martsenko <kristina.martsenko@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14arm64: hw_breakpoint: fix watchpoint matching for tagged pointersKristina Martsenko
commit 7dcd9dd8cebe9fa626af7e2358d03a37041a70fb upstream. This backport has a small difference from the upstream commit: - The address tag is removed in watchpoint_handler() instead of get_distance_from_watchpoint(), because 4.9 does not have commit fdfeff0f9e3d ("arm64: hw_breakpoint: Handle inexact watchpoint addresses"). Original patch description: When we take a watchpoint exception, the address that triggered the watchpoint is found in FAR_EL1. We compare it to the address of each configured watchpoint to see which one was hit. The configured watchpoint addresses are untagged, while the address in FAR_EL1 will have an address tag if the data access was done using a tagged address. The tag needs to be removed to compare the address to the watchpoints. Currently we don't remove it, and as a result can report the wrong watchpoint as being hit (specifically, always either the highest TTBR0 watchpoint or lowest TTBR1 watchpoint). This patch removes the tag. Fixes: d50240a5f6ce ("arm64: mm: permit use of tagged pointers at EL0") Acked-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Kristina Martsenko <kristina.martsenko@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14arm64: traps: fix userspace cache maintenance emulation on a tagged pointerKristina Martsenko
commit 81cddd65b5c82758ea5571a25e31ff6f1f89ff02 upstream. This backport has a minor difference from the upstream commit, as v4.9 did not yet have the refactoring done by commit 8b6e70fccff2 ("arm64: traps: correctly handle MRS/MSR with XZR"). Original patch description: When we emulate userspace cache maintenance in the kernel, we can currently send the task a SIGSEGV even though the maintenance was done on a valid address. This happens if the address has a non-zero address tag, and happens to not be mapped in. When we get the address from a user register, we don't currently remove the address tag before performing cache maintenance on it. If the maintenance faults, we end up in either __do_page_fault, where find_vma can't find the VMA if the address has a tag, or in do_translation_fault, where the tagged address will appear to be above TASK_SIZE. In both cases, the address is not mapped in, and the task is sent a SIGSEGV. This patch removes the tag from the address before using it. With this patch, the fault is handled correctly, the address gets mapped in, and the cache maintenance succeeds. As a second bug, if cache maintenance (correctly) fails on an invalid tagged address, the address gets passed into arm64_notify_segfault, where find_vma fails to find the VMA due to the tag, and the wrong si_code may be sent as part of the siginfo_t of the segfault. With this patch, the correct si_code is sent. Fixes: 7dd01aef0557 ("arm64: trap userspace "dc cvau" cache operation on errata-affected core") Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Kristina Martsenko <kristina.martsenko@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14powerpc/kernel: Initialize load_tm on task creationBreno Leitao
commit 7f22ced4377628074e2ac25f41a88f98eb3b03f1 upstream. Currently tsk->thread.load_tm is not initialized in the task creation and can contain garbage on a new task. This is an undesired behaviour, since it affects the timing to enable and disable the transactional memory laziness (disabling and enabling the MSR TM bit, which affects TM reclaim and recheckpoint in the scheduling process). Fixes: 5d176f751ee3 ("powerpc: tm: Enable transactional memory (TM) lazily for userspace") Signed-off-by: Breno Leitao <leitao@debian.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14powerpc/kernel: Fix FP and vector register restorationBreno Leitao
commit 1195892c091a15cc862f4e202482a36adc924e12 upstream. Currently tsk->thread->load_vec and load_fp are not initialized during task creation, which can lead to garbage values in these variables (non-zero values). These variables will be checked later in restore_math() to validate if the FP and vector registers are being utilized. Since these values might be non-zero, the restore_math() will continue to save the FP and vectors even if they were never utilized by the userspace application. load_fp and load_vec counters will then overflow (they wrap at 255) and the FP and Altivec will be finally disabled, but before that condition is reached (counter overflow) several context switches will have restored FP and vector registers without need, causing a performance degradation. Fixes: 70fe3d980f5f ("powerpc: Restore FPU/VEC/VSX if previously used") Signed-off-by: Breno Leitao <leitao@debian.org> Signed-off-by: Gustavo Romero <gusbromero@gmail.com> Acked-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14powerpc/hotplug-mem: Fix missing endian conversion of aa_indexMichael Bringmann
commit dc421b200f91930c9c6a9586810ff8c232cf10fc upstream. When adding or removing memory, the aa_index (affinity value) for the memblock must also be converted to match the endianness of the rest of the 'ibm,dynamic-memory' property. Otherwise, subsequent retrieval of the attribute will likely lead to non-existent nodes, followed by using the default node in the code inappropriately. Fixes: 5f97b2a0d176 ("powerpc/pseries: Implement memory hotplug add in the kernel") Signed-off-by: Michael Bringmann <mwb@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14powerpc/numa: Fix percpu allocations to be NUMA awareMichael Ellerman
commit ba4a648f12f4cd0a8003dd229b6ca8a53348ee4b upstream. In commit 8c272261194d ("powerpc/numa: Enable USE_PERCPU_NUMA_NODE_ID"), we switched to the generic implementation of cpu_to_node(), which uses a percpu variable to hold the NUMA node for each CPU. Unfortunately we neglected to notice that we use cpu_to_node() in the allocation of our percpu areas, leading to a chicken and egg problem. In practice what happens is when we are setting up the percpu areas, cpu_to_node() reports that all CPUs are on node 0, so we allocate all percpu areas on node 0. This is visible in the dmesg output, as all pcpu allocs being in group 0: pcpu-alloc: [0] 00 01 02 03 [0] 04 05 06 07 pcpu-alloc: [0] 08 09 10 11 [0] 12 13 14 15 pcpu-alloc: [0] 16 17 18 19 [0] 20 21 22 23 pcpu-alloc: [0] 24 25 26 27 [0] 28 29 30 31 pcpu-alloc: [0] 32 33 34 35 [0] 36 37 38 39 pcpu-alloc: [0] 40 41 42 43 [0] 44 45 46 47 To fix it we need an early_cpu_to_node() which can run prior to percpu being setup. We already have the numa_cpu_lookup_table we can use, so just plumb it in. With the patch dmesg output shows two groups, 0 and 1: pcpu-alloc: [0] 00 01 02 03 [0] 04 05 06 07 pcpu-alloc: [0] 08 09 10 11 [0] 12 13 14 15 pcpu-alloc: [0] 16 17 18 19 [0] 20 21 22 23 pcpu-alloc: [1] 24 25 26 27 [1] 28 29 30 31 pcpu-alloc: [1] 32 33 34 35 [1] 36 37 38 39 pcpu-alloc: [1] 40 41 42 43 [1] 44 45 46 47 We can also check the data_offset in the paca of various CPUs, with the fix we see: CPU 0: data_offset = 0x0ffe8b0000 CPU 24: data_offset = 0x1ffe5b0000 And we can see from dmesg that CPU 24 has an allocation on node 1: node 0: [mem 0x0000000000000000-0x0000000fffffffff] node 1: [mem 0x0000001000000000-0x0000001fffffffff] Fixes: 8c272261194d ("powerpc/numa: Enable USE_PERCPU_NUMA_NODE_ID") Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Reviewed-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14powerpc/sysdev/simple_gpio: Fix oops in gpio save_regs functionChristophe Leroy
commit 6f553912eedafae13ff20b322a65e471fe7f5236 upstream. of_mm_gpiochip_add_data() generates an oops for NULL pointer dereference. of_mm_gpiochip_add_data() calls mm_gc->save_regs() before setting the data, therefore ->save_regs() cannot use gpiochip_get_data() Fixes: 937daafca774 ("powerpc: simple-gpio: use gpiochip data pointer") Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14KVM: arm/arm64: Handle possible NULL stage2 pud when ageing pagesMarc Zyngier
commit d6dbdd3c8558cad3b6d74cc357b408622d122331 upstream. Under memory pressure, we start ageing pages, which amounts to parsing the page tables. Since we don't want to allocate any extra level, we pass NULL for our private allocation cache. Which means that stage2_get_pud() is allowed to fail. This results in the following splat: [ 1520.409577] Unable to handle kernel NULL pointer dereference at virtual address 00000008 [ 1520.417741] pgd = ffff810f52fef000 [ 1520.421201] [00000008] *pgd=0000010f636c5003, *pud=0000010f56f48003, *pmd=0000000000000000 [ 1520.429546] Internal error: Oops: 96000006 [#1] PREEMPT SMP [ 1520.435156] Modules linked in: [ 1520.438246] CPU: 15 PID: 53550 Comm: qemu-system-aar Tainted: G W 4.12.0-rc4-00027-g1885c397eaec #7205 [ 1520.448705] Hardware name: FOXCONN R2-1221R-A4/C2U4N_MB, BIOS G31FB12A 10/26/2016 [ 1520.463726] task: ffff800ac5fb4e00 task.stack: ffff800ce04e0000 [ 1520.469666] PC is at stage2_get_pmd+0x34/0x110 [ 1520.474119] LR is at kvm_age_hva_handler+0x44/0xf0 [ 1520.478917] pc : [<ffff0000080b137c>] lr : [<ffff0000080b149c>] pstate: 40000145 [ 1520.486325] sp : ffff800ce04e33d0 [ 1520.489644] x29: ffff800ce04e33d0 x28: 0000000ffff40064 [ 1520.494967] x27: 0000ffff27e00000 x26: 0000000000000000 [ 1520.500289] x25: ffff81051ba65008 x24: 0000ffff40065000 [ 1520.505618] x23: 0000ffff40064000 x22: 0000000000000000 [ 1520.510947] x21: ffff810f52b20000 x20: 0000000000000000 [ 1520.516274] x19: 0000000058264000 x18: 0000000000000000 [ 1520.521603] x17: 0000ffffa6fe7438 x16: ffff000008278b70 [ 1520.526940] x15: 000028ccd8000000 x14: 0000000000000008 [ 1520.532264] x13: ffff7e0018298000 x12: 0000000000000002 [ 1520.537582] x11: ffff000009241b93 x10: 0000000000000940 [ 1520.542908] x9 : ffff0000092ef800 x8 : 0000000000000200 [ 1520.548229] x7 : ffff800ce04e36a8 x6 : 0000000000000000 [ 1520.553552] x5 : 0000000000000001 x4 : 0000000000000000 [ 1520.558873] x3 : 0000000000000000 x2 : 0000000000000008 [ 1520.571696] x1 : ffff000008fd5000 x0 : ffff0000080b149c [ 1520.577039] Process qemu-system-aar (pid: 53550, stack limit = 0xffff800ce04e0000) [...] [ 1521.510735] [<ffff0000080b137c>] stage2_get_pmd+0x34/0x110 [ 1521.516221] [<ffff0000080b149c>] kvm_age_hva_handler+0x44/0xf0 [ 1521.522054] [<ffff0000080b0610>] handle_hva_to_gpa+0xb8/0xe8 [ 1521.527716] [<ffff0000080b3434>] kvm_age_hva+0x44/0xf0 [ 1521.532854] [<ffff0000080a58b0>] kvm_mmu_notifier_clear_flush_young+0x70/0xc0 [ 1521.539992] [<ffff000008238378>] __mmu_notifier_clear_flush_young+0x88/0xd0 [ 1521.546958] [<ffff00000821eca0>] page_referenced_one+0xf0/0x188 [ 1521.552881] [<ffff00000821f36c>] rmap_walk_anon+0xec/0x250 [ 1521.558370] [<ffff000008220f78>] rmap_walk+0x78/0xa0 [ 1521.563337] [<ffff000008221104>] page_referenced+0x164/0x180 [ 1521.569002] [<ffff0000081f1af0>] shrink_active_list+0x178/0x3b8 [ 1521.574922] [<ffff0000081f2058>] shrink_node_memcg+0x328/0x600 [ 1521.580758] [<ffff0000081f23f4>] shrink_node+0xc4/0x328 [ 1521.585986] [<ffff0000081f2718>] do_try_to_free_pages+0xc0/0x340 [ 1521.592000] [<ffff0000081f2a64>] try_to_free_pages+0xcc/0x240 [...] The trivial fix is to handle this NULL pud value early, rather than dereferencing it blindly. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Reviewed-by: Christoffer Dall <cdall@linaro.org> Signed-off-by: Christoffer Dall <cdall@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14KVM: async_pf: avoid async pf injection when in guest modeWanpeng Li
commit 9bc1f09f6fa76fdf31eb7d6a4a4df43574725f93 upstream. INFO: task gnome-terminal-:1734 blocked for more than 120 seconds. Not tainted 4.12.0-rc4+ #8 "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. gnome-terminal- D 0 1734 1015 0x00000000 Call Trace: __schedule+0x3cd/0xb30 schedule+0x40/0x90 kvm_async_pf_task_wait+0x1cc/0x270 ? __vfs_read+0x37/0x150 ? prepare_to_swait+0x22/0x70 do_async_page_fault+0x77/0xb0 ? do_async_page_fault+0x77/0xb0 async_page_fault+0x28/0x30 This is triggered by running both win7 and win2016 on L1 KVM simultaneously, and then gives stress to memory on L1, I can observed this hang on L1 when at least ~70% swap area is occupied on L0. This is due to async pf was injected to L2 which should be injected to L1, L2 guest starts receiving pagefault w/ bogus %cr2(apf token from the host actually), and L1 guest starts accumulating tasks stuck in D state in kvm_async_pf_task_wait() since missing PAGE_READY async_pfs. This patch fixes the hang by doing async pf when executing L1 guest. Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14arm: KVM: Allow unaligned accesses at HYPMarc Zyngier
commit 33b5c38852b29736f3b472dd095c9a18ec22746f upstream. We currently have the HSCTLR.A bit set, trapping unaligned accesses at HYP, but we're not really prepared to deal with it. Since the rest of the kernel is pretty happy about that, let's follow its example and set HSCTLR.A to zero. Modern CPUs don't really care. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <cdall@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14arm64: KVM: Allow unaligned accesses at EL2Marc Zyngier
commit 78fd6dcf11468a5a131b8365580d0c613bcc02cb upstream. We currently have the SCTLR_EL2.A bit set, trapping unaligned accesses at EL2, but we're not really prepared to deal with it. So far, this has been unnoticed, until GCC 7 started emitting those (in particular 64bit writes on a 32bit boundary). Since the rest of the kernel is pretty happy about that, let's follow its example and set SCTLR_EL2.A to zero. Modern CPUs don't really care. Reported-by: Alexander Graf <agraf@suse.de> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <cdall@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14arm64: KVM: Preserve RES1 bits in SCTLR_EL2Marc Zyngier
commit d68c1f7fd1b7148dab5fe658321d511998969f2d upstream. __do_hyp_init has the rather bad habit of ignoring RES1 bits and writing them back as zero. On a v8.0-8.2 CPU, this doesn't do anything bad, but may end-up being pretty nasty on future revisions of the architecture. Let's preserve those bits so that we don't have to fix this later on. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <cdall@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14KVM: cpuid: Fix read/write out-of-bounds vulnerability in cpuid emulationWanpeng Li
commit a3641631d14571242eec0d30c9faa786cbf52d44 upstream. If "i" is the last element in the vcpu->arch.cpuid_entries[] array, it potentially can be exploited the vulnerability. this will out-of-bounds read and write. Luckily, the effect is small: /* when no next entry is found, the current entry[i] is reselected */ for (j = i + 1; ; j = (j + 1) % nent) { struct kvm_cpuid_entry2 *ej = &vcpu->arch.cpuid_entries[j]; if (ej->function == e->function) { It reads ej->maxphyaddr, which is user controlled. However... ej->flags |= KVM_CPUID_FLAG_STATE_READ_NEXT; After cpuid_entries there is int maxphyaddr; struct x86_emulate_ctxt emulate_ctxt; /* 16-byte aligned */ So we have: - cpuid_entries at offset 1B50 (6992) - maxphyaddr at offset 27D0 (6992 + 3200 = 10192) - padding at 27D4...27DF - emulate_ctxt at 27E0 And it writes in the padding. Pfew, writing the ops field of emulate_ctxt would have been much worse. This patch fixes it by modding the index to avoid the out-of-bounds access. Worst case, i == j and ej->function == e->function, the loop can bail out. Reported-by: Moguofang <moguofang@huawei.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Guofang Mo <moguofang@huawei.com> Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14kvm: async_pf: fix rcu_irq_enter() with irqs enabledPaolo Bonzini
commit bbaf0e2b1c1b4f88abd6ef49576f0efb1734eae5 upstream. native_safe_halt enables interrupts, and you just shouldn't call rcu_irq_enter() with interrupts enabled. Reorder the call with the following local_irq_disable() to respect the invariant. Reported-by: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14efi: Don't issue error message when booted under XenJuergen Gross
commit 1ea34adb87c969b89dfd83f1905a79161e9ada26 upstream. When booted as Xen dom0 there won't be an EFI memmap allocated. Avoid issuing an error message in this case: [ 0.144079] efi: Failed to allocate new EFI memmap Signed-off-by: Juergen Gross <jgross@suse.com> Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-efi@vger.kernel.org Link: http://lkml.kernel.org/r/20170526113652.21339-2-matt@codeblueprint.co.uk Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14arch/sparc: support NR_CPUS = 4096Jane Chu
[ Upstream commit c79a13734d104b5b147d7cb0870276ccdd660dae ] Linux SPARC64 limits NR_CPUS to 4064 because init_cpu_send_mondo_info() only allocates a single page for NR_CPUS mondo entries. Thus we cannot use all 4096 CPUs on some SPARC platforms. To fix, allocate (2^order) pages where order is set according to the size of cpu_list for possible cpus. Since cpu_list_pa and cpu_mondo_block_pa are not used in asm code, there are no imm13 offsets from the base PA that will break because they can only reach one page. Orabug: 25505750 Signed-off-by: Jane Chu <jane.chu@oracle.com> Reviewed-by: Bob Picco <bob.picco@oracle.com> Reviewed-by: Atish Patra <atish.patra@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14sparc64: delete old wrap codePavel Tatashin
[ Upstream commit 0197e41ce70511dc3b71f7fefa1a676e2b5cd60b ] The old method that is using xcall and softint to get new context id is deleted, as it is replaced by a method of using per_cpu_secondary_mm without xcall to perform the context wrap. Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Reviewed-by: Bob Picco <bob.picco@oracle.com> Reviewed-by: Steven Sistare <steven.sistare@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14sparc64: new context wrapPavel Tatashin
[ Upstream commit a0582f26ec9dfd5360ea2f35dd9a1b026f8adda0 ] The current wrap implementation has a race issue: it is called outside of the ctx_alloc_lock, and also does not wait for all CPUs to complete the wrap. This means that a thread can get a new context with a new version and another thread might still be running with the same context. The problem is especially severe on CPUs with shared TLBs, like sun4v. I used the following test to very quickly reproduce the problem: - start over 8K processes (must be more than context IDs) - write and read values at a memory location in every process. Very quickly memory corruptions start happening, and what we read back does not equal what we wrote. Several approaches were explored before settling on this one: Approach 1: Move smp_new_mmu_context_version() inside ctx_alloc_lock, and wait for every process to complete the wrap. (Note: every CPU must WAIT before leaving smp_new_mmu_context_version_client() until every one arrives). This approach ends up with deadlocks, as some threads own locks which other threads are waiting for, and they never receive softint until these threads exit smp_new_mmu_context_version_client(). Since we do not allow the exit, deadlock happens. Approach 2: Handle wrap right during mondo interrupt. Use etrap/rtrap to enter into into C code, and issue new versions to every CPU. This approach adds some overhead to runtime: in switch_mm() we must add some checks to make sure that versions have not changed due to wrap while we were loading the new secondary context. (could be protected by PSTATE_IE but that degrades performance as on M7 and older CPUs as it takes 50 cycles for each access). Also, we still need a global per-cpu array of MMs to know where we need to load new contexts, otherwise we can change context to a thread that is going way (if we received mondo between switch_mm() and switch_to() time). Finally, there are some issues with window registers in rtrap() when context IDs are changed during CPU mondo time. The approach in this patch is the simplest and has almost no impact on runtime. We use the array with mm's where last secondary contexts were loaded onto CPUs and bump their versions to the new generation without changing context IDs. If a new process comes in to get a context ID, it will go through get_new_mmu_context() because of version mismatch. But the running processes do not need to be interrupted. And wrap is quicker as we do not need to xcall and wait for everyone to receive and complete wrap. Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Reviewed-by: Bob Picco <bob.picco@oracle.com> Reviewed-by: Steven Sistare <steven.sistare@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14sparc64: add per-cpu mm of secondary contextsPavel Tatashin
[ Upstream commit 7a5b4bbf49fe86ce77488a70c5dccfe2d50d7a2d ] The new wrap is going to use information from this array to figure out mm's that currently have valid secondary contexts setup. Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Reviewed-by: Bob Picco <bob.picco@oracle.com> Reviewed-by: Steven Sistare <steven.sistare@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14sparc64: redefine first versionPavel Tatashin
[ Upstream commit c4415235b2be0cc791572e8e7f7466ab8f73a2bf ] CTX_FIRST_VERSION defines the first context version, but also it defines first context. This patch redefines it to only include the first context version. Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Reviewed-by: Bob Picco <bob.picco@oracle.com> Reviewed-by: Steven Sistare <steven.sistare@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14sparc64: combine activate_mm and switch_mmPavel Tatashin
[ Upstream commit 14d0334c6748ff2aedb3f2f7fdc51ee90a9b54e7 ] The only difference between these two functions is that in activate_mm we unconditionally flush context. However, there is no need to keep this difference after fixing a bug where cpumask was not reset on a wrap. So, in this patch we combine these. Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Reviewed-by: Bob Picco <bob.picco@oracle.com> Reviewed-by: Steven Sistare <steven.sistare@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14sparc64: reset mm cpumask after wrapPavel Tatashin
[ Upstream commit 588974857359861891f478a070b1dc7ae04a3880 ] After a wrap (getting a new context version) a process must get a new context id, which means that we would need to flush the context id from the TLB before running for the first time with this ID on every CPU. But, we use mm_cpumask to determine if this process has been running on this CPU before, and this mask is not reset after a wrap. So, there are two possible fixes for this issue: 1. Clear mm cpumask whenever mm gets a new context id 2. Unconditionally flush context every time process is running on a CPU This patch implements the first solution Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Reviewed-by: Bob Picco <bob.picco@oracle.com> Reviewed-by: Steven Sistare <steven.sistare@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14sparc: Machine description indices can varyJames Clarke
[ Upstream commit c982aa9c304bf0b9a7522fd118fed4afa5a0263c ] VIO devices were being looked up by their index in the machine description node block, but this often varies over time as devices are added and removed. Instead, store the ID and look up using the type, config handle and ID. Signed-off-by: James Clarke <jrtc27@jrtc27.com> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=112541 Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14sparc64: mm: fix copy_tsb to correctly copy huge page TSBsMike Kravetz
[ Upstream commit 654f4807624a657f364417c2a7454f0df9961734 ] When a TSB grows beyond its current capacity, a new TSB is allocated and copy_tsb is called to copy entries from the old TSB to the new. A hash shift based on page size is used to calculate the index of an entry in the TSB. copy_tsb has hard coded PAGE_SHIFT in these calculations. However, for huge page TSBs the value REAL_HPAGE_SHIFT should be used. As a result, when copy_tsb is called for a huge page TSB the entries are placed at the incorrect index in the newly allocated TSB. When doing hardware table walk, the MMU does not match these entries and we end up in the TSB miss handling code. This code will then create and write an entry to the correct index in the TSB. We take a performance hit for the table walk miss and recreation of these entries. Pass a new parameter to copy_tsb that is the page size shift to be used when copying the TSB. Suggested-by: Anthony Yznaga <anthony.yznaga@oracle.com> Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14sparc64: Add __multi3 for gcc 7.x and later.David S. Miller
[ Upstream commit 1b4af13ff2cc6897557bb0b8d9e2fad4fa4d67aa ] Reported-by: Waldemar Brodkorb <wbx@openadk.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07x86/boot: Use CROSS_COMPILE prefix for readelfRob Landley
commit 3780578761921f094179c6289072a74b2228c602 upstream. The boot code Makefile contains a straight 'readelf' invocation. This causes build warnings in cross compile environments, when there is no unprefixed readelf accessible via $PATH. Add the missing $(CROSS_COMPILE) prefix. [ tglx: Rewrote changelog ] Fixes: 98f78525371b ("x86/boot: Refuse to build with data relocations") Signed-off-by: Rob Landley <rob@landley.net> Acked-by: Kees Cook <keescook@chromium.org> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Paul Bolle <pebolle@tiscali.nl> Cc: "H.J. Lu" <hjl.tools@gmail.com> Link: http://lkml.kernel.org/r/ced18878-693a-9576-a024-113ef39a22c0@landley.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07x86/MCE: Export memory_error()Borislav Petkov
commit 2d1f406139ec20320bf38bcd2461aa8e358084b5 upstream. Export the function which checks whether an MCE is a memory error to other users so that we can reuse the logic. Drop the boot_cpu_data use, while at it, as mce.cpuvendor already has the CPU vendor in there. Integrate a piece from a patch from Vishal Verma <vishal.l.verma@intel.com> to export it for modules (nfit). The main reason we're exporting it is that the nfit handler nfit_handle_mce() needs to detect a memory error properly before doing its recovery actions. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vishal Verma <vishal.l.verma@intel.com> Link: http://lkml.kernel.org/r/20170519093915.15413-2-bp@alien8.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07powerpc/spufs: Fix hash faults for kernel regionsJeremy Kerr
commit d75e4919cc0b6fbcbc8d6654ef66d87a9dbf1526 upstream. Commit ac29c64089b7 ("powerpc/mm: Replace _PAGE_USER with _PAGE_PRIVILEGED") swapped _PAGE_USER for _PAGE_PRIVILEGED, and introduced check_pte_access() which denied kernel access to non-_PAGE_PRIVILEGED pages. However, it didn't add _PAGE_PRIVILEGED to the hash fault handler for spufs' kernel accesses, so the DMAs required to establish SPE memory no longer work. This change adds _PAGE_PRIVILEGED to the hash fault handler for kernel accesses. Fixes: ac29c64089b7 ("powerpc/mm: Replace _PAGE_USER with _PAGE_PRIVILEGED") Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Reported-by: Sombat Tragolgosol <sombat3960@gmail.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07sparc/ftrace: Fix ftrace graph time measurementLiam R. Howlett
[ Upstream commit 48078d2dac0a26f84f5f3ec704f24f7c832cce14 ] The ftrace function_graph time measurements of a given function is not accurate according to those recorded by ftrace using the function filters. This change pulls the x86_64 fix from 'commit 722b3c746953 ("ftrace/graph: Trace function entry before updating index")' into the sparc specific prepare_ftrace_return which stops ftrace from counting interrupted tasks in the time measurement. Example measurements for select_task_rq_fair running "hackbench 100 process 1000": | tracing/trace_stat/function0 | function_graph Before patch | 2.802 us | 4.255 us After patch | 2.749 us | 3.094 us Signed-off-by: Liam R. Howlett <Liam.Howlett@Oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07sparc: Fix -Wstringop-overflow warningOrlando Arias
[ Upstream commit deba804c90642c8ed0f15ac1083663976d578f54 ] Greetings, GCC 7 introduced the -Wstringop-overflow flag to detect buffer overflows in calls to string handling functions [1][2]. Due to the way ``empty_zero_page'' is declared in arch/sparc/include/setup.h, this causes a warning to trigger at compile time in the function mem_init(), which is subsequently converted to an error. The ensuing patch fixes this issue and aligns the declaration of empty_zero_page to that of other architectures. Thank you. Cheers, Orlando. [1] https://gcc.gnu.org/ml/gcc-patches/2016-10/msg02308.html [2] https://gcc.gnu.org/gcc-7/changes.html Signed-off-by: Orlando Arias <oarias@knights.ucf.edu> -------------------------------------------------------------------------------- Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07bpf, arm64: fix faulty emission of map access in tail callsDaniel Borkmann
[ Upstream commit d8b54110ee944de522ccd3531191f39986ec20f9 ] Shubham was recently asking on netdev why in arm64 JIT we don't multiply the index for accessing the tail call map by 8. That led me into testing out arm64 JIT wrt tail calls and it turned out I got a NULL pointer dereference on the tail call. The buggy access is at: prog = array->ptrs[index]; if (prog == NULL) goto out; [...] 00000060: d2800e0a mov x10, #0x70 // #112 00000064: f86a682a ldr x10, [x1,x10] 00000068: f862694b ldr x11, [x10,x2] 0000006c: b40000ab cbz x11, 0x00000080 [...] The code triggering the crash is f862694b. x1 at the time contains the address of the bpf array, x10 offsetof(struct bpf_array, ptrs). Meaning, above we load the pointer to the program at map slot 0 into x10. x10 can then be NULL if the slot is not occupied, which we later on try to access with a user given offset in x2 that is the map index. Fix this by emitting the following instead: [...] 00000060: d2800e0a mov x10, #0x70 // #112 00000064: 8b0a002a add x10, x1, x10 00000068: d37df04b lsl x11, x2, #3 0000006c: f86b694b ldr x11, [x10,x11] 00000070: b40000ab cbz x11, 0x00000084 [...] This basically adds the offset to ptrs to the base address of the bpf array we got and we later on access the map with an index * 8 offset relative to that. The tail call map itself is basically one large area with meta data at the head followed by the array of prog pointers. This makes tail calls working again, tested on Cavium ThunderX ARMv8. Fixes: ddb55992b04d ("arm64: bpf: implement bpf_tail_call() helper") Reported-by: Shubham Bansal <illusionist.neo@gmail.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25um: Fix to call read_initrd after init_bootmemMasami Hiramatsu
commit 5b4236e17cc1bd9fa14b2b0c7a4ae632d41f2e20 upstream. Since read_initrd() invokes alloc_bootmem() for allocating memory to load initrd image, it must be called after init_bootmem. This makes read_initrd() called directly from setup_arch() after init_bootmem() and mem_total_pages(). Fixes: b63236972e1 ("um: Setup physical memory in setup_arch()") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25osf_wait4(): fix infoleakAl Viro
commit a8c39544a6eb2093c04afd5005b6192bd0e880c6 upstream. failing sys_wait4() won't fill struct rusage... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25MIPS: Loongson-3: Select MIPS_L1_CACHE_SHIFT_6Huacai Chen
commit 17c99d9421695a0e0de18bf1e7091d859e20ec1d upstream. Some newer Loongson-3 have 64 bytes cache lines, so select MIPS_L1_CACHE_SHIFT_6. Signed-off-by: Huacai Chen <chenhc@lemote.com> Cc: John Crispin <john@phrozen.org> Cc: Steven J . Hill <Steven.Hill@caviumnetworks.com> Cc: Fuxin Zhang <zhangfx@lemote.com> Cc: Zhangjin Wu <wuzhangjin@gmail.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/15755/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25metag/uaccess: Check access_ok in strncpy_from_userJames Hogan
commit 3a158a62da0673db918b53ac1440845a5b64fd90 upstream. The metag implementation of strncpy_from_user() doesn't validate the src pointer, which could allow reading of arbitrary kernel memory. Add a short access_ok() check to prevent that. Its still possible for it to read across the user/kernel boundary, but it will invariably reach a NUL character after only 9 bytes, leaking only a static kernel address being loaded into D0Re0 at the beginning of __start, which is acceptable for the immediate fix. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25metag/uaccess: Fix access_ok()James Hogan
commit 8a8b56638bcac4e64cccc88bf95a0f9f4b19a2fb upstream. The __user_bad() macro used by access_ok() has a few corner cases noticed by Al Viro where it doesn't behave correctly: - The kernel range check has off by 1 errors which permit access to the first and last byte of the kernel mapped range. - The kernel range check ends at LINCORE_BASE rather than META_MEMORY_LIMIT, which is ineffective when the kernel is in global space (an extremely uncommon configuration). There are a couple of other shortcomings here too: - Access to the whole of the other address space is permitted (i.e. the global half of the address space when the kernel is in local space). This isn't ideal as it could theoretically still contain privileged mappings set up by the bootloader. - The size argument is unused, permitting user copies which start on valid pages at the end of the user address range and cross the boundary into the kernel address space (e.g. addr = 0x3ffffff0, size > 0x10). It isn't very convenient to add size checks when disallowing certain regions, and it seems far safer to be sure and explicit about what userland is able to access, so invert the logic to allow certain regions instead, and fix the off by 1 errors and missing size checks. This also allows the get_fs() == KERNEL_DS check to be more easily optimised into the user address range case. We now have 3 such allowed regions: - The user address range (incorporating the get_fs() == KERNEL_DS check). - NULL (some kernel code expects this to work, and we'll always catch the fault anyway). - The core code memory region. Fixes: 373cd784d0fc ("metag: Memory handling") Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-metag@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25arm64: uaccess: ensure extension of access_ok() addrMark Rutland
commit a06040d7a791a9177581dcf7293941bd92400856 upstream. Our access_ok() simply hands its arguments over to __range_ok(), which implicitly assummes that the addr parameter is 64 bits wide. This isn't necessarily true for compat code, which might pass down a 32-bit address parameter. In these cases, we don't have a guarantee that the address has been zero extended to 64 bits, and the upper bits of the register may contain unknown values, potentially resulting in a suprious failure. Avoid this by explicitly casting the addr parameter to an unsigned long (as is done on other architectures), ensuring that the parameter is widened appropriately. Fixes: 0aea86a2176c ("arm64: User access library functions") Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25arm64: armv8_deprecated: ensure extension of addrMark Rutland
commit 55de49f9aa17b0b2b144dd2af587177b9aadf429 upstream. Our compat swp emulation holds the compat user address in an unsigned int, which it passes to __user_swpX_asm(). When a 32-bit value is passed in a register, the upper 32 bits of the register are unknown, and we must extend the value to 64 bits before we can use it as a base address. This patch casts the address to unsigned long to ensure it has been suitably extended, avoiding the potential issue, and silencing a related warning from clang. Fixes: bd35a4adc413 ("arm64: Port SWP/SWPB emulation support from arm") Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25arm64: ensure extension of smp_store_release valueMark Rutland
commit 994870bead4ab19087a79492400a5478e2906196 upstream. When an inline assembly operand's type is narrower than the register it is allocated to, the least significant bits of the register (up to the operand type's width) are valid, and any other bits are permitted to contain any arbitrary value. This aligns with the AAPCS64 parameter passing rules. Our __smp_store_release() implementation does not account for this, and implicitly assumes that operands have been zero-extended to the width of the type being stored to. Thus, we may store unknown values to memory when the value type is narrower than the pointer type (e.g. when storing a char to a long). This patch fixes the issue by casting the value operand to the same width as the pointer operand in all cases, which ensures that the value is zero-extended as we expect. We use the same union trickery as __smp_load_acquire and {READ,WRITE}_ONCE() to avoid GCC complaining that pointers are potentially cast to narrower width integers in unreachable paths. A whitespace issue at the top of __smp_store_release() is also corrected. No changes are necessary for __smp_load_acquire(). Load instructions implicitly clear any upper bits of the register, and the compiler will only consider the least significant bits of the register as valid regardless. Fixes: 47933ad41a86 ("arch: Introduce smp_load_acquire(), smp_store_release()") Fixes: 878a84d5a8a1 ("arm64: add missing data types in smp_load_acquire/smp_store_release") Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Cc: Matthias Kaehlcke <mka@chromium.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25arm64: xchg: hazard against entire exchange variableMark Rutland
commit fee960bed5e857eb126c4e56dd9ff85938356579 upstream. The inline assembly in __XCHG_CASE() uses a +Q constraint to hazard against other accesses to the memory location being exchanged. However, the pointer passed to the constraint is a u8 pointer, and thus the hazard only applies to the first byte of the location. GCC can take advantage of this, assuming that other portions of the location are unchanged, as demonstrated with the following test case: union u { unsigned long l; unsigned int i[2]; }; unsigned long update_char_hazard(union u *u) { unsigned int a, b; a = u->i[1]; asm ("str %1, %0" : "+Q" (*(char *)&u->l) : "r" (0UL)); b = u->i[1]; return a ^ b; } unsigned long update_long_hazard(union u *u) { unsigned int a, b; a = u->i[1]; asm ("str %1, %0" : "+Q" (*(long *)&u->l) : "r" (0UL)); b = u->i[1]; return a ^ b; } The linaro 15.08 GCC 5.1.1 toolchain compiles the above as follows when using -O2 or above: 0000000000000000 <update_char_hazard>: 0: d2800001 mov x1, #0x0 // #0 4: f9000001 str x1, [x0] 8: d2800000 mov x0, #0x0 // #0 c: d65f03c0 ret 0000000000000010 <update_long_hazard>: 10: b9400401 ldr w1, [x0,#4] 14: d2800002 mov x2, #0x0 // #0 18: f9000002 str x2, [x0] 1c: b9400400 ldr w0, [x0,#4] 20: 4a000020 eor w0, w1, w0 24: d65f03c0 ret This patch fixes the issue by passing an unsigned long pointer into the +Q constraint, as we do for our cmpxchg code. This may hazard against more than is necessary, but this is better than missing a necessary hazard. Fixes: 305d454aaa29 ("arm64: atomics: implement native {relaxed, acquire, release} atomics") Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25arm64: dts: hi6220: Reset the mmc hostsDaniel Lezcano
commit 0fbdf9953b41c28845fe8d05007ff09634ee3000 upstream. The MMC hosts could be left in an unconsistent or uninitialized state from the firmware. Instead of assuming, the firmware did the right things, let's reset the host controllers. This change fixes a bug when the mmc2/sdio is initialized leading to a hung task: [ 242.704294] INFO: task kworker/7:1:675 blocked for more than 120 seconds. [ 242.711129] Not tainted 4.9.0-rc8-00017-gcf0251f #3 [ 242.716571] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 242.724435] kworker/7:1 D 0 675 2 0x00000000 [ 242.729973] Workqueue: events_freezable mmc_rescan [ 242.734796] Call trace: [ 242.737269] [<ffff00000808611c>] __switch_to+0xa8/0xb4 [ 242.742437] [<ffff000008d07c04>] __schedule+0x1c0/0x67c [ 242.747689] [<ffff000008d08254>] schedule+0x40/0xa0 [ 242.752594] [<ffff000008d0b284>] schedule_timeout+0x1c4/0x35c [ 242.758366] [<ffff000008d08e38>] wait_for_common+0xd0/0x15c [ 242.763964] [<ffff000008d09008>] wait_for_completion+0x28/0x34 [ 242.769825] [<ffff000008a1a9f4>] mmc_wait_for_req_done+0x40/0x124 [ 242.775949] [<ffff000008a1ab98>] mmc_wait_for_req+0xc0/0xf8 [ 242.781549] [<ffff000008a1ac3c>] mmc_wait_for_cmd+0x6c/0x84 [ 242.787149] [<ffff000008a26610>] mmc_io_rw_direct_host+0x9c/0x114 [ 242.793270] [<ffff000008a26aa0>] sdio_reset+0x34/0x7c [ 242.798347] [<ffff000008a1d46c>] mmc_rescan+0x2fc/0x360 [ ... ] Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Wei Xu <xuwei5@hisilicon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25ARM: dts: imx6sx-sdb: Remove OPP overrideLeonard Crestez
commit d8581c7c8be172dac156a19d261f988a72ce596f upstream. The board file for imx6sx-sdb overrides cpufreq operating points to use higher voltages. This is done because the board has a shared rail for VDD_ARM_IN and VDD_SOC_IN and when using LDO bypass the shared voltage needs to be a value suitable for both ARM and SOC. This only applies to LDO bypass mode, a feature not present in upstream. When LDOs are enabled the effect is to use higher voltages than necessary for no good reason. Setting these higher voltages can make some boards fail to boot with ugly semi-random crashes reminiscent of memory corruption. These failures only happen on board rev. C, rev. B is reported to still work. Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com> Fixes: 54183bd7f766 ("ARM: imx6sx-sdb: add revb board and make it default") Signed-off-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25ARM: dts: at91: sama5d3_xplained: not all ADC channels are availableLudovic Desroches
commit d3df1ec06353e51fc44563d2e7e18d42811af290 upstream. Remove ADC channels that are not available by default on the sama5d3_xplained board (resistor not populated) in order to not create confusion. Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com> Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25ARM: dts: at91: sama5d3_xplained: fix ADC vrefLudovic Desroches
commit 9cdd31e5913c1f86dce7e201b086155b3f24896b upstream. The voltage reference for the ADC is not 3V but 3.3V since it is connected to VDDANA. Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com> Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25ARM: 8670/1: V7M: Do not corrupt vector table around v7m_invalidate_l1 callVladimir Murzin
commit 6d80594936914e798b1b54b3bfe4bd68d8418966 upstream. We save/restore registers around v7m_invalidate_l1 to address pointed by r12, which is vector table, so the first eight entries are overwritten with a garbage. We already have stack setup at that stage, so use it to save/restore register. Fixes: 6a8146f420be ("ARM: 8609/1: V7M: Add support for the Cortex-M7 processor") Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25ARM: 8662/1: module: split core and init PLT sectionsArd Biesheuvel
commit b7ede5a1f5905ac394cc8e61712a13e3c5cb7b8f upstream. Since commit 35fa91eed817 ("ARM: kernel: merge core and init PLTs"), the ARM module PLT code allocates all PLT entries in a single core section, since the overhead of having a separate init PLT section is not justified by the small number of PLT entries usually required for init code. However, the core and init module regions are allocated independently, and there is a corner case where the core region may be allocated from the VMALLOC region if the dedicated module region is exhausted, but the init region, being much smaller, can still be allocated from the module region. This puts the PLT entries out of reach of the relocated branch instructions, defeating the whole purpose of PLTs. So split the core and init PLT regions, and name the latter ".init.plt" so it gets allocated along with (and sufficiently close to) the .init sections that it serves. Also, given that init PLT entries may need to be emitted for branches that target the core module, modify the logic that disregards defined symbols to only disregard symbols that are defined in the same section. Fixes: 35fa91eed817 ("ARM: kernel: merge core and init PLTs") Reported-by: Angus Clark <angus@angusclark.org> Tested-by: Angus Clark <angus@angusclark.org> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25KVM: arm: plug potential guest hardware debug leakageZhichao Huang
commit 661e6b02b5aa82db31897f36e96324b77450fd7a upstream. Hardware debugging in guests is not intercepted currently, it means that a malicious guest can bring down the entire machine by writing to the debug registers. This patch enable trapping of all debug registers, preventing the guests to access the debug registers. This includes access to the debug mode(DBGDSCR) in the guest world all the time which could otherwise mess with the host state. Reads return 0 and writes are ignored (RAZ_WI). The result is the guest cannot detect any working hardware based debug support. As debug exceptions are still routed to the guest normal debug using software based breakpoints still works. To support debugging using hardware registers we need to implement a debug register aware world switch as well as special trapping for registers that may affect the host state. Signed-off-by: Zhichao Huang <zhichao.huang@linaro.org> Signed-off-by: Alex Bennée <alex.bennee@linaro.org> Reviewed-by: Christoffer Dall <cdall@linaro.org> Signed-off-by: Christoffer Dall <cdall@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
