0/NULL, missing __user, missing __iomem, non-ANSI prototype.
Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
The `simple' way of walking and checking PageReserved is broken on
discontigmem, instead we need to check each range explicitly.
(Also rename a few things so they make more sense.)
Signed-off-by: Helge Deller <deller@gmx.de>
I deleted this file from 2.4 5 years ago. Unfortunately, that change
never got merged to Linus and so when we switched to 2.5 it came back
and nobody noticed. It's never been built in 2.5/2.6 as it was never
in the Makefile.
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (76 commits)
[ARM] 4002/1: S3C24XX: leave parent IRQs unmasked
[ARM] 4001/1: S3C24XX: shorten reboot time
[ARM] 3983/2: remove unused argument to __bug()
[ARM] 4000/1: Osiris: add third serial port in
[ARM] 3999/1: RX3715: suspend to RAM support
[ARM] 3998/1: VR1000: LED platform devices
[ARM] 3995/1: iop13xx: add iop13xx support
[ARM] 3968/1: iop13xx: add iop13xx_defconfig
[ARM] Update mach-types
[ARM] Allow gcc to optimise arm_add_memory a little more
[ARM] 3991/1: i.MX/MX1 high resolution time source
[ARM] 3990/1: i.MX/MX1 more precise PLL decode
[ARM] 3986/1: H1940: suspend to RAM support
[ARM] 3985/1: ixp4xx clocksource cleanup
[ARM] 3984/1: ixp4xx/nslu2: Fix disk LED numbering (take 2)
[ARM] 3994/1: ixp23xx: fix handling of pci master aborts
[ARM] 3981/1: sched_clock for PXA2xx
[ARM] 3980/1: extend the ARM Versatile sched_clock implementation from 32 to 63 bit
[ARM] 3979/1: extend the SA11x0 sched_clock implementation from 32 to 63 bit period
[ARM] 3978/1: macro to provide a 63-bit value from a 32-bit hardware counter
master.kernel.org:/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of master.kernel.org:/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] replace kmalloc+memset with kzalloc
[IA64] resolve name clash by renaming is_available_memory()
[IA64] Need export for csum_ipv6_magic
[IA64] Fix DISCONTIGMEM without VIRTUAL_MEM_MAP
[PATCH] Add support for type argument in PAL_GET_PSTATE
[IA64] tidy up return value of ip_fast_csum
[IA64] implement csum_ipv6_magic for ia64.
[IA64] More Itanium PAL spec updates
[IA64] Update processor_info features
[IA64] Add se bit to Processor State Parameter structure
[IA64] Add dp bit to cache and bus check structs
[IA64] SN: Correctly update smp_affinty mask
[IA64] sparse cleanups
[IA64] IA64 Kexec/kdump
Merge:
Atmel AT91RM9200 and AT91SAM9260 changes
General ARM developments
Disconfiguous memory cleanups
64-bit/32-bit division and sched_clock extension patches
EP93xx support changes
IOP support changes
Do not bother masking/unmasking the parent IRQ
for the mulitplexed EINT irqs, as masking the
leaf seems to be fine.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
It appears that include/asm-arm/bug.h requires include/linux/stddef.h
for the definition of NULL. It seems that stddef.h was always included
indirectly in most cases, and that issue was properly fixed a while ago.
Then commit 5047f09b56d0bc3c21aec9cb16de60283da645c6 incorrectly reverted
change from commit ff10952a547dad934d9ed9afc5cf579ed1ccb53a (bad dwmw2)
and the problem recently resurfaced.
Because the third argument to __bug() is never used anyway, RMK suggested
getting rid of it entirely instead of readding #include <linux/stddef.h>
which this patch does.
Signed-off-by: Nicolas Pitre <nico@cam.org>
Add the mapping for the third S3C2440 serial
port into the default serial devices for the
Osiris.
The RX3715 is similar to the H1940 in the way
that suspend to RAM works, so we can use most
of the extant support for the H1940 with only
a few modifictions
Support for the GPIO attached LEDs on the VR1000
Replace kmalloc+memset with kzalloc
Signed-off-by: Yan Burman <burman.yan@gmail.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
There is a name clash with ia64 arch code in Andrew's tree. Rename
is_avialable_memory() to is_memory_available() to avoid the clash.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Now we have our own highly optimized assembly code version of
this routine (Thanks Ken!) we should export it so that it can
be used.
PAL_GET_PSTATE accepts a type argument to return different kinds of
frequency information.
Refer: Intel Itanium®Architecture Software Developer's Manual -
Volume 2: System Architecture, Revision 2.2
(http://developer.intel.com/design/itanium/manuals/245318.htm)
Add the support for type argument and use Instantaneous frequency
in the acpi driver.
Also fix a bug, where in return value of PAL_GET_PSTATE was getting compared
with 'control' bits instead of 'status' bits.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
While working on implementing csum_ipv6_magic, I noticed that current
version of ip_fast_csum will potentially return bits above "unsigned
short" as 1. While no harm is done right now because all call sites
will chop off the upper bits when it uses the return value. However,
this is still dangerous and buggy. Here is a patch to enforce that the
function really returns unsigned short in the native register format.
The fix is free as there are plenty open slot to add one more asm instruction.
Signed-off-by: Ken Chen <kenneth.w.chen@intel.com>
The asm version is 4.4 times faster than the generic C version and
10X smaller in code size.
Additional updates to conform with Rev 2.2 of Volume 2 of "Intel
Itanium Architecture Software Developer's Manual" (January 2006).
Add pal_bus_features_s bits 52 & 53 (page 2:347)
Add pal_vm_info_2_s field max_purges (page 2:2:451)
Add PAL_GET_HW_POLICY call (page 2:381)
Add PAL_SET_HW_POLICY call (page 2:439)
Sample output before:
cobra:~ # cat /proc/pal/cpu0/vm_info
Physical Address Space : 50 bits
Virtual Address Space : 61 bits
Protection Key Registers(PKR) : 16
Implemented bits in PKR.key : 24
Hash Tag ID : 0x2
Size of RR.rid : 24
Supported memory attributes : WB, UC, UCE, WC, NaTPage
Sample output after:
Hash Tag ID : 0x2
Max Purges : 1
Size of RR.rid : 24
Signed-off-by: Russ Anderson (rja@sgi.com)
Add the printing of additional processor features to proc_features.
Based on Rev 2.2 of Volume 2 of "Intel Itanium Architecture Software
Developer's Manual" (January 2006) fields (pages 2:430-2:432).
This patch gets the features back in sync with the spec.
cobra:~ # cat /proc/pal/cpu0/processor_info
XIP,XPSR,XFS implemented : On NoCtrl
XR1-XR3 implemented : On NoCtrl
Disable dynamic predicate prediction : NotImpl
Disable processor physical number : NotImpl
Disable dynamic data cache prefetch : NotImpl
Disable dynamic inst cache prefetch : NotImpl
Disable dynamic branch prediction : NotImpl
Disable BINIT on processor time-out : On Ctrl
Disable dynamic power management (DPM) : NotImpl
Disable coherency : NotImpl
Disable cache : NotImpl
Enable CMCI promotion : Off Ctrl
Enable MCA to BINIT promotion : Off Ctrl
Enable MCA promotion : NotImpl
Enable BERR promotion : NotImpl
cobra:~ #
Unimplemented instruction address fault : NotImpl
INIT, PMI, and LINT pins : NotImpl
Simple unimplimented instr addresses : On NoCtrl
Variable P-state performance : NotImpl
Virtual machine features implemeted : On NoCtrl
Disable P-states : Off Ctrl
Enable MCA on Data Poisoning : Off Ctrl
Enable vmsw instruction : On Ctrl
Enable extern environmental notification : NotImpl
cobra:~ #
On Altix systems, the /proc/irq/nn/smp_affinity mask is not being setup
at device iniitalization, or updated after an interrupt redirection.
This patch resolves those issues.
Signed-off-by: John Keller <jpk@sgi.com>
0/NULL confusion and some missing UL on constants.
Changes and updates.
1. Remove fake rendz path and related code according to discuss with Khalid Aziz.
2. fc.i offset fix in relocate_kernel.S.
3. iospic shutdown code eoi and mask race fix from Fujitsu.
4. Warm boot hook in machine_kexec to SN SAL code from Jack Steiner.
5. Send slave to SAL slave loop patch from Jay Lan.
6. Kdump on non-recoverable MCA event patch from Jay Lan
7. Use CTL_UNNUMBERED in kdump_on_init sysctl.
Signed-off-by: Zou Nan hai <nanhai.zou@intel.com>
The iop348 processor integrates an Xscale (XSC3 512KB L2 Cache) core with a
Serial Attached SCSI (SAS) controller, multi-ported DDR2 memory
controller, 3 Application Direct Memory Access (DMA) controllers, a 133Mhz
PCI-X interface, a x8 PCI-Express interface, and other peripherals to form
a system-on-a-chip RAID subsystem engine.
The iop342 processor replaces the SAS controller with a second Xscale core
for dual core embedded applications.
The iop341 processor is the single core version of iop342.
This patch supports the two Intel customer reference platforms iq81340mc
for external storage and iq81340sc for direct attach (HBA) development.
The developer's manual is available here:
ftp://download.intel.com/design/iio/docs/31503701.pdf
Changelog:
* removed virtual addresses from resource definitions
* cleaned up some unnecessary #include's
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits)
[PATCH] x86-64: Export smp_call_function_single
[PATCH] i386: Clean up smp_tune_scheduling()
[PATCH] unwinder: move .eh_frame to RODATA
[PATCH] unwinder: fully support linker generated .eh_frame_hdr section
[PATCH] x86-64: don't use set_irq_regs()
[PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq
[PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM
[PATCH] i386: replace kmalloc+memset with kzalloc
[PATCH] x86-64: remove remaining pc98 code
[PATCH] x86-64: remove unused variable
[PATCH] x86-64: Fix constraints in atomic_add_return()
[PATCH] x86-64: fix asm constraints in i386 atomic_add_return
[PATCH] x86-64: Correct documentation for bzImage protocol v2.05
[PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code
[PATCH] x86-64: Fix numaq build error
[PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header
[PATCH] unwinder: Add debugging output to the Dwarf2 unwinder
[PATCH] x86-64: Clarify error message in GART code
[PATCH] x86-64: Fix interrupt race in idle callback (3rd try)
[PATCH] x86-64: Remove unwind stack pointer alignment forcing again
Fixed conflict in include/linux/uaccess.h manually
The elf note saving code is currently duplicated over several
architectures. This cleanup patch simply adds code to a common file and
then replaces the arch-specific code with calls to the newly added code.
The only drawback with this approach is that s390 doesn't fully support
kexec-on-panic which for that arch leads to introduction of unused code.
Signed-off-by: Magnus Damm <magnus@valinux.co.jp>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Cc: Andi Kleen <ak@suse.de>
CC: Ian Molton <spyro@f2s.com>
Every file should #include the headers containing the prototypes for
its global functions.
Pass struct dev pointer to dma_cache_sync()
dma_cache_sync() is ill-designed in that it does not have a struct device
pointer argument which makes proper support for systems that consist of a
mix of coherent and non-coherent DMA devices hard. Change dma_cache_sync
to take a struct device pointer as first argument and fix all its callers
to pass it.
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Greg KH <greg@kroah.com>
dma_is_consistent() is ill-designed in that it does not have a struct
device pointer argument which makes proper support for systems that consist
of a mix of coherent and non-coherent DMA devices hard. Change
dma_is_consistent to take a struct device pointer as first argument and fix
the sole caller to pass it.
This creates a new RTC-framework driver for the RTC/calendar module found
in various OMAP1 chips. (OMAP2 and OMAP3 use external RTCs, like those in
TI's multifunction PM companion chips.) It's been in the Linux-OMAP tree
for several months now, and other trees before that, so it's quite stable.
The most notable issue is that the OMAP IRQ code doesn't yet support the
RTC IRQ as a wakeup event. Once that's fixed, a patch will be needed.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn,
prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus
generating compiler warnings of unused symbols, hence forcing people to add
#ifdefs.
the compiler can skip truly unused functions just fine:
1624412 728710 3674856 6027978 5bfaca vmlinux.before
1624412 728710 3674856 6027978 5bfaca vmlinux.after
[akpm@osdl.org: topology.c fix]
smp_call_function_single() can deadlock if the caller disabled local
interrupts (the target CPU could be spinning on call_lock). Check for that.
Why on earth do these functions use spin_lock_bh()??
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
When we are unregistering a kprobe-booster, we can't release its
instruction buffer immediately on the preemptive kernel, because some
processes might be preempted on the buffer. The freeze_processes() and
thaw_processes() functions can clean most of processes up from the buffer.
There are still some non-frozen threads who have the PF_NOFREEZE flag. If
those threads are sleeping (not preempted) at the known place outside the
buffer, we can ensure safety of freeing.
However, the processing of this check routine takes a long time. So, this
patch introduces the garbage collection mechanism of insn_slot. It also
introduces the "dirty" flag to free_insn_slot because of efficiency.
The "clean" instruction slots (dirty flag is cleared) are released
immediately. But the "dirty" slots which are used by boosted kprobes, are
marked as garbages. collect_garbage_slots() will be invoked to release
"dirty" slots if there are more than INSNS_PER_PAGE garbage slots or if
there are no unused slots.
Cc: "Keshavamurthy, Anil S" <anil.s.keshavamurthy@intel.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: "bibo,mao" <bibo.mao@intel.com>
Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com>
Cc: Yumiko Sugita <yumiko.sugita.yf@hitachi.com>
Cc: Satoshi Oshima <soshima@redhat.com>
Cc: Hideo Aoki <haoki@redhat.com>
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
The ELF32 spec says we should plus we include the zero on other platforms.
Cc: Daniel Jacobowitz <drow@false.org>
Cc: Roland McGrath <roland@redhat.com>
Cc: Jakub Jelinek <jakub@redhat.com>
Define elf_addr_t in linux/elf.h. The size of the type is determined using
ELF_CLASS. This allows us to remove the defines that today are spread all
over .c and .h files.
After LOADER_TYPE && INITRD_START are true, the short if-condition
for INITRD_START can never be false.
Remove unused code from the else condition.
Signed-off-by: Henry Nestler <henry.ne@arcor.de>
The last thing we agreed on was to remove the macros entirely for 2.6.19,
on all architectures. Unfortunately, I think nobody actually _did_ that,
so they are still there.
[akpm@osdl.org: x86_64 fix]
Cc: Greg Schafer <gschafer@zip.com.au>
Name some of the remaning 'old_style_spin_init' locks
The new shared APM emulation just like its ARM and MIPS predecessors uses
pm_suspend() which was only exported on SH. Move export to close to it's
definition where it really should be anyway.
When the UML network driver generates random MACs for its devices, it was
possible for a number of UMLs to get the same MACs because the ethernet
initialization was done before the random pool was properly seeded.
This patch moves the initialization later so that it gets better randomness.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
We were using the wrong symbol to size register files.
Include the proper header to get a definition of PAGE_SHIFT.
We were not including stddef.h in files that used offsetof.
One file was also including linux/stddef.h for no perciptible reason.
Cc: Roman Zippel <zippel@linux-m68k.org>
Make swsusp support i386 systems with PAE or without PSE.
This is done by creating temporary page tables located in resume-safe page
frames before the suspend image is restored in the same way as x86_64 does
it.
Cc: Dave Jones <davej@redhat.com>
Cc: Nigel Cunningham <ncunningham@linuxmail.org>
Cc: Pavel Machek <pavel@ucw.cz>
Move process freezing functions from include/linux/sched.h to freezer.h, so
that modifications to the freezer or the kernel configuration don't require
recompiling just about everything.
[akpm@osdl.org: fix ueagle driver]
Signed-off-by: Nigel Cunningham <nigel@suspend2.net>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Now that we have pci_get_bus_and_slot we can do the job correctly. Note that
some of these calls intentionally leak a device - this is because the device
in question is always needed from boot to reboot.
Signed-off-by: Alan Cox <alan@redhat.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
