path: root/arch
2008-07-09[ARM] pxa: use IORESOURCE_IRQ_* instead of IRQF_* for IRQ resourceEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] pxa: add codename zylonite for PXA3xx Development PlatformEric Miao
2008-07-09[ARM] 5143/1: pxa: further cleanup PXA Kconfig by removing oneDmitry Baryshkov
unnecessary menu level Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] 5142/1: pxa: move move zaurus declarations to proper placeDmitry Baryshkov
2008-07-09[ARM] 5088/3: pxa2xx: add pxa2xx_set_spi_info to register pxa2xx-spi ↵Guennadi Liakhovetski
platform devices Add a function to dynamically allocate and register pxa2xx-spi platform devices, to be used by PXA2xx and PXA3xx based systems. Switch pcm027 and lubbock to use it. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] 5084/1: zylonite: Register AC97 deviceMark Brown
The Zylonite has an AC97 subsystem on it so register the AC97 controller device. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] 5085/2: PXA: Move AC97 over to the new central device declaration modelMark Brown
As well as moving all the device declarations to a single one in devices.c this causes all platforms to register the I/O and interrupt resources for the AC97 controller. Cc: eric miao <eric.miao@marvell.com> Cc: Mike Rapoport <mike@compulab.co.il> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Jürgen Schindele <linux@schindele.name> Cc: Juergen Beisert <jbe@pengutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] 5120/1: pxa: correct platform driver names for PXA25x and PXA27x UDC ↵Philipp Zabel
drivers The pxa2xx_udc.c driver is renamed to pxa25x_udc.c (the platform driver name changes from pxa2xx-udc to pxa25x-udc) and the platform driver name of pxa27x_udc.c is fixed to pxa27x-udc. pxa_device_udc in devices.c is split into pxa25x and pxa27x flavors and the pxa27x_device_udc is enabled in pxa27x.c. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Including from Ian Molton: Fixes for mistakes left over from the PXA2{5,7}X UDC split. Signed-off-by: Ian Molton <spyro@f2s.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] 5145/1: PXA2xx: provide api to control IrDA pins stateDmitry Baryshkov
Provide a set of functions to control state of pins dedicated to IrDA. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] pxa: remove pxa_set_cken()Russell King
pxa_set_cken() is now unused, remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09Merge branches 'pxa-misc', 'pxa-pwm' and 'pxa-multi' into pxaRussell King
2008-07-09[ARM] pxa: allow clk aliasesRussell King
We need to support more than one name+device for a struct clk for a small number of peripherals. We do this by re-using struct clk alias to another struct clk - IOW, if we find that the entry we're using is an alias, we return the aliased entry not the one we found. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-07[ARM] 5135/1: pxa: drop superfluous asm/arch/pxa2xx-gpio.h includesPhilipp Zabel
Both i2c-pxa.c and irq.c still include pxa2xx-gpio.h although is is not needed anymore. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] 5094/1: pcm990: Add framebuffer and backlight supportGuennadi Liakhovetski
PCM990 boards can be assembled with either a Sharp STN or a NEC TFT LCD. This patch adds support for these displays and for the backlight, using the pwm_bl driver. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] 5045/1: magician: use the pwm_bl driver for the LCD backlightPhilipp Zabel
magician has a GPIO that modifies the brightness level additionally to the PWM duty value. This patch makes use of the pwm_bl notify callback to present userspace with a single brightness scale. This gets rid of the pxa_set_cken calls and direct PWM register access. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] 5141/1: PWM: pwm_request() should return an PTR_ERR() instead of NULL.Ben Dooks
Make the return of pwm_request() be more informative than just being NULL on error by using PTR_ERR() to respond with an approriate error. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] pxa: make LogicPD 270 use the generic PWM backlight driverRussell King
Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] pxa: make mainstone use the generic PWM backlight driverRussell King
2008-07-03[ARM] pxa: make zylonite use the generic PWM backlight drivereric miao
Patch mostly by Eric Miao, minor edits by rmk. Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] 5087/1: Get the PWM layer to handle clock enable/disable properly.Robert Jarzmik
Allow pwm_enable()/pwm_disable() to be called as many times as the driver wants (and not even count them). The PWM model is different from things like the clock API where we need enable counting, because PWMs have one exclusive user per PWM whereas the clock API can have multiple users of the same clock. Acked-by: eric miao <eric.miao@marvell.com> Signed-off-by: Robert Jarzmik <rjarzmik@free.fr> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] 5078/1: pxa-pwm: Add missing MODULE_LICENSE to be able to build the driverGuennadi Liakhovetski
as a module Without a GPL-compatible license this driver cannot be built as a module, because the platform_driver_* API is only exported to GPL modules. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03[ARM] 5136/1: pxa: fix PWM device order for pxa27xPhilipp Zabel
Currently PWM0/2 (pxa27x_device_pwm0 at 0x40b00000 and 0x40b00010 are registered as as pwm_id 0 and 1, PWM1/3 (pxa27x_device_pwm1 at 0x40c00000 and 0x40c00010) are registered as pwm_id 2 and 3. This patch corrects the pwm_ids to match the documented register names. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] 5071/2: Drop PXA_SHARPSL_25x/27x case from PXA Kconfig.Dmitry Baryshkov
As nothing in the code references to the PXA_SHARPSL_25x/27x, we can drop that Kconfig case and permit all-zaurus builds. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] 5073/1: spitz_pm: don't register devices on non-spitz machinesDmitry Baryshkov
2008-06-02[ARM] 5072/1: corgi_pm: don't register devices on non-corgi machinesDmitry Baryshkov
2008-06-02[ARM] 5036/2: Combine cm_x270_defconfig and em_x270_defconfig into ↵Mike Rapoport
xm_x270_defconfig Combine cm_x270_defconfig and em_x270_defconfig to allow running the same kernel on both machines Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] pxa: allow PXA to be built for multiple platformsRussell King
Convert the 'choice' into a 'menu' to allow multiple platforms to be selected. This means to do a build check across PXA, you don't end up spending a lifetime building _twenty_ sodding kernels. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] 5035/1: Ensure that zone adjustment is done only on CM-X270Mike Rapoport
Adjust zones for PCI DMA only if machine_is_armcore() to allow running the same kernel on different PXA machines. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] pxa: separate out power manager and clock registersRussell King
The power manager and core clock registers aren't present in PXA3 CPUs. Move them out of pxa-regs.h into pxa2xx-regs.h, and include pxa2xx-regs.h where necessary. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] 5075/1: i2c-pxa: move i2c pin setup and PCFR_PI2CEN handling into ↵Philipp Zabel
arch/arm/mach-pxa This fixes a build error introduced when the power manager register definitions were moved into pxa2xx-regs.h. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] pxa: Add PXA3_ prefix to PXA3 specific constantsRussell King
standby.S contains both PXA2 and PXA3 specific code. The PXA3 specific constants clash with the PXA2 ones, so give them a prefix. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] pxa: don't register lpd270 cpld_irq sysdev if !lpd270Russell King
Don't register the LPD270 cpld_irq system device when we're not running on a LPD270 machine - "cpld_irq" is also registered (separately) by Lubbock and Mainstone. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-19[ARM] pxa: separate PXA25x and PXA27x UDC register definitionsRussell King
The PXA25x and PXA27x USB device controller register definitions are different. Currently, they live side by side in pxa-regs.h, but only one set is available depending on the setting of PXA25x or PXA27x. This means that if we build to support both PXA25x and PXA27x, the PXA27x definitions are unavailable, even to PXA27x specific code. Remove these definitions from pxa-regs.h, and place them in separate files. Include these files where appropriate. Note: according to the dependencies in drivers/usb/gadget/Kconfig, we do not support the UDC on PXA27x nor PXA3xx CPUs, so remove the platform devices from pxa27x.c and pxa3xx.c. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-19[ARM] pxa: corgibl_limit_intensity build errorsRussell King
If CONFIG_BACKLIGHT_CORGI is not selected, then corgibl_limit_intensity() is not present. However, both corgi_pm.c and sharp_pm.c reference this symbol, resulting in a link error. Wrap the references with the relevant ifdefs, and avoid the resulting NULL pointer dereference by making the code in sharpsl_pm.c also conditional on the config symbol. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-19[ARM] pxa: Add PXA support for PWM APIeric miao
Patch mainly from Eric Miao, with minor edits by rmk. Note: PWM0 and PWM2 share the same register I/O space and clock gating on pxa{27x, 3xx}, thus PWM2 is treated in the driver as a child PWM of PWM0. And this is also true for PWM1/3. Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-19[ARM] pxa: Add bare bones PWM APIRussell King
2008-05-18Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c/max6875: Really prevent 24RF08 corruption i2c-amd756: Fix functionality flags i2c: Kill the old driver matching scheme i2c: Convert remaining new-style drivers to use module aliasing i2c: Switch pasemi to the new device/driver matching scheme i2c: Clean up Blackfin BF527 I2C device declarations i2c-nforce2: Disable the second SMBus channel on the DFI Lanparty NF4 Expert i2c: New co-maintainer
2008-05-18m68k: Add multi_defconfigGeert Uytterhoeven
Add multi_defconfig, to build a kernel for all supported m68k platforms, excluding Sun 3 (Sun 3 kernels are incompatible with all other m68k platforms) Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Update defconfigsGeert Uytterhoeven
Update the m68k defconfigs Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Correctly handle multi-ISA at runtimeGeert Uytterhoeven
m68k: Correctly handle multi-ISA at runtime in multi-platform kernels Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Prefix ISA type with ISA_TYPE_Geert Uytterhoeven
The *_ISA type defines are quite generic and cause namespace conflicts (e.g. with `AMIGAHW_DECLARE(GG2_ISA)' in <asm/amigahw.h>) for some kernel configurations. Use ISA_TYPE_* to avoid such conflicts. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: export m68k_mmutypeGeert Uytterhoeven
UIO needs m68k_mmutype: ERROR: "m68k_mmutype" [drivers/uio/uio.ko] undefined! (noticed by Christian T. Steigies) Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Q40/Q60 floppy support is brokenGeert Uytterhoeven
Mark Q40/Q60 floppy support broken: arch/m68k/q40/q40ints.c: In function 'q40_irq_handler': arch/m68k/q40/q40ints.c:214: error: implicit declaration of function 'floppy_hardint' Including <asm/floppy.h> doesn't help, as it causes a lot of additional error messages (cfr. Sun 3x). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Correct jump if not running on HP300Geert Uytterhoeven
When running a HP300-enabled kernel on non-HP300 hardware, a test in the early startup code jumps to the wrong label, causing a double bus fault. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Kill CONFIG_WHIPPET_SERIALGeert Uytterhoeven
The Hisoft Whippet PCMCIA serial driver has been removed a long time ago, but it's Kconfig symbol still existed. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18i2c: Switch pasemi to the new device/driver matching schemeJean Delvare
The old device/driver matching scheme is going away so stop using it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Olof Johansson <olof@lixom.net>
2008-05-18i2c: Clean up Blackfin BF527 I2C device declarationsJean Delvare
I2C_BOARD_INFO() now sets the type field so no need to set it separatetly. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Bryan Wu <cooloney@kernel.org>
2008-05-17Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] pxa: spitz wants PXA27x UDC definitions [ARM] pxa: fix pxafb build when cpufreq is enabled [ARM] fix parenthesis in include/asm-arm/arch-omap/control.h [ARM] colibri: fix support for DM9000 ethernet device [ARM] arm/kernel/arthur.c: add MODULE_LICENSE [ARM] 5037/1: Orion: fix DNS323/Kurobox Pro PCI initialisation [ARM] 5034/1: fix arm{925,926,940,946} dma_flush_range() in WT mode [ARM] export copy_page [ARM] 5026/1: locomo: add .settype for gpio and several small fixes ARM: OMAP: Fixed comments on global PRM register usage ARM: OMAP: Add PARENT_CONTROLS_CLOCK flag to dpll5_m2_ck ARM: OMAP: PRCM fixes to ssi clock handling ARM: OMAP: Add fuctional clock enabler for iva2 ARM: OMAP: Fix 34xx to use correct shift values for gpio2-6 fclks ARM: OMAP: Keymap fix for palmte and palmz71 ARM: OMAP: Fix Unbalanced enable for IRQ in omap mailbox ARM: OMAP: DMA: Fix incorrect channel linking ARM: OMAP: Warn on disabling clocks with no users ARM: OMAP: Add calls to omap2_set_globals_*() ARM: OMAP: Update MMC header to fix compile
2008-05-17Merge branch 'omap-fixes' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
2008-05-17Merge branch 'sa1100'Russell King
