path: root/arch
2015-09-18Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fix from Thomas Gleixner: "A single regression fix for the x86 dma allocator which got wreckaged in the merge window" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/pci/dma: Fix gfp flags for coherent DMA memory allocation
2015-09-18Merge tag 'powerpc-4.3-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc fixes from Michael Ellerman: - Fix 32-bit TCE table init in kdump kernel from Nish - Fix kdump with non-power-of-2 crashkernel= from Nish - Abort cxl_pci_enable_device_hook() if PCI channel is offline from Andrew - Fix to release DRC when configure_connector() fails from Bharata - Wire up sys_userfaultfd() - Fix race condition in tearing down MSI interrupts from Paul - Fix unbalanced pci_dev_get() in cxl_probe() from Daniel - Fix cxl build failure due to -Wunused-variable gcc behaviour change from Ian - Tell the toolchain to use ABI v2 when building an LE boot wrapper from Benh - Fix THP to recompute hash value after a failed update from Aneesh - 32-bit memcpy/memset: only use dcbz once cache is enabled from Christophe * tag 'powerpc-4.3-2' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: powerpc32: memset: only use dcbz once cache is enabled powerpc32: memcpy: only use dcbz once cache is enabled powerpc/mm: Recompute hash value after a failed update powerpc/boot: Specify ABI v2 when building an LE boot wrapper cxl: Fix build failure due to -Wunused-variable behaviour change cxl: Fix unbalanced pci_dev_get in cxl_probe powerpc/MSI: Fix race condition in tearing down MSI interrupts powerpc: Wire up sys_userfaultfd() powerpc/pseries: Release DRC when configure_connector fails cxl: abort cxl_pci_enable_device_hook() if PCI channel is offline powerpc/powernv/pci-ioda: fix kdump with non-power-of-2 crashkernel= powerpc/powernv/pci-ioda: fix 32-bit TCE table init in kdump kernel
2015-09-17Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc fixes from ANdrew Morton: "8 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: revert "mm: make sure all file VMAs have ->vm_ops set" MAINTAINERS: update LTP mailing list userfaultfd: add missing mmput() in error path lib/string_helpers.c: fix infinite loop in string_get_size() alpha: lib: export __delay alpha: io: define ioremap_uc kasan: fix last shadow judgement in memory_is_poisoned_16() zram: fix possible use after free in zcomp_create()
2015-09-17alpha: lib: export __delaySudip Mukherjee
__delay was not exported as a result while building with allmodconfig we were getting build error of undefined symbol. __delay is being used by: drivers/net/phy/mdio-octeon.c Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-17alpha: io: define ioremap_ucSudip Mukherjee
ioremap_uc was not defined and as a result while building with allmodconfig were getting build error of: implicit declaration of function 'ioremap_uc'. Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-17Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Will Deacon: "This addresses some problems with filesystem writeback due to the recently merged hardware DBM patches, which caused us to treat some read-only pages as dirty. There are also some other, less significant fixes that are described in the summary below: A mixture of fixes for regressions introduced during the merge window, some longer standing problems that we spotted and a couple of hardware errata. The main changes are: - Fix fallout from the h/w DBM patches, causing filesystem writeback issues on both v8 and v8.1 CPUs - Workaround for Cortex-A53 erratum #843419 in the module loader - Fix for long-standing issue with compat big-endian signal handlers using the saved floating point state" * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: errata: add module build workaround for erratum #843419 arm64: compat: fix vfp save/restore across signal handlers in big-endian arm64: cpu hotplug: ensure we mask out CPU_TASKS_FROZEN in notifiers arm64: head.S: initialise mdcr_el2 in el2_setup arm64: enable generic idle loop arm64: pgtable: use a single bit for PTE_WRITE regardless of DBM arm64: Fix pte_modify() to preserve the hardware dirty information arm64: Fix the pte_hw_dirty() check when AF/DBM is enabled arm64: dma-mapping: check whether cma area is initialized or not
2015-09-17Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: - misc fixes all around the map - block non-root vm86(old) if mmap_min_addr != 0 - two small debuggability improvements - removal of obsolete paravirt op * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/platform: Fix Geode LX timekeeping in the generic x86 build x86/apic: Serialize LVTT and TSC_DEADLINE writes x86/ioapic: Force affinity setting in setup_ioapic_dest() x86/paravirt: Remove the unused pv_time_ops::get_tsc_khz method x86/ldt: Fix small LDT allocation for Xen x86/vm86: Fix the misleading CONFIG_VM86 Kconfig help text x86/cpu: Print family/model/stepping in hex x86/vm86: Block non-root vm86(old) if mmap_min_addr != 0 x86/alternatives: Make optimize_nops() interrupt safe and synced x86/mm/srat: Print non-volatile flag in SRAT x86/cpufeatures: Enable cpuid for Intel SHA extensions
2015-09-17Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo MOlnar: "Mostly tooling fixes, but also two x86 PMU driver fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tests: Fix software clock events test setting maps perf tests: Fix task exit test setting maps perf evlist: Fix create_syswide_maps() not propagating maps perf evlist: Fix add() not propagating maps perf evlist: Factor out a function to propagate maps for a single evsel perf evlist: Make create_maps() use set_maps() perf evlist: Make set_maps() more resilient perf evsel: Add own_cpus member perf evlist: Fix missing thread_map__put in propagate_maps() perf evlist: Fix splice_list_tail() not setting evlist perf evlist: Add has_user_cpus member perf evlist: Remove redundant validation from propagate_maps() perf evlist: Simplify set_maps() logic perf evlist: Simplify propagate_maps() logic perf top: Fix segfault pressing -> with no hist entries perf header: Fixup reading of HEADER_NRCPUS feature perf/x86/intel: Fix constraint access perf/x86/intel/bts: Set event->hw.itrace_started in pmu::start to match the new logic perf tools: Fix use of wrong event when processing exit events perf tools: Fix parse_events_add_pmu caller
2015-09-17Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fixes from Ingo Molnar: "Spinlock performance regression fix, plus documentation fixes" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/static_keys: Fix up the static keys documentation locking/qspinlock/x86: Only emit the test-and-set fallback when building guest support locking/qspinlock/x86: Fix performance regression under unaccelerated VMs locking/static_keys: Fix a silly typo
2015-09-17x86/pci/dma: Fix gfp flags for coherent DMA memory allocationJunichi Nomura
Commit 6894258eda2f reversed the order of gfp_flags adjustment in dma_alloc_attrs() for x86 [arch/x86/kernel/pci-dma.c] As a result, relevant flags set by dma_alloc_coherent_gfp_flags() are just discarded and cause coherent DMA memory allocation failure on some devices. Fixes: 6894258eda2f ("dma-mapping: consolidate dma_{alloc,free}_{attrs,coherent}") Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Tested-by: Tony Luck <tony.luck@intel.com> Acked-by: Christoph Hellwig <hch@lst.de> Link: http://lkml.kernel.org/r/20150914073834.GA13077@xzibit.linux.bs1.fc.nec.co.jp Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-09-17arm64: errata: add module build workaround for erratum #843419Will Deacon
Cortex-A53 processors <= r0p4 are affected by erratum #843419 which can lead to a memory access using an incorrect address in certain sequences headed by an ADRP instruction. There is a linker fix to generate veneers for ADRP instructions, but this doesn't work for kernel modules which are built as unlinked ELF objects. This patch adds a new config option for the erratum which, when enabled, builds kernel modules with the mcmodel=large flag. This uses absolute addressing for all kernel symbols, thereby removing the use of ADRP as a PC-relative form of addressing. The ADRP relocs are removed from the module loader so that we fail to load any potentially affected modules. Cc: <stable@vger.kernel.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-09-17arm64: compat: fix vfp save/restore across signal handlers in big-endianWill Deacon
When saving/restoring the VFP registers from a compat (AArch32) signal frame, we rely on the compat registers forming a prefix of the native register file and therefore make use of copy_{to,from}_user to transfer between the native fpsimd_state and the compat_vfp_sigframe. Unfortunately, this doesn't work so well in a big-endian environment. Our fpsimd save/restore code operates directly on 128-bit quantities (Q registers) whereas the compat_vfp_sigframe represents the registers as an array of 64-bit (D) registers. The architecture packs the compat D registers into the Q registers, with the least significant bytes holding the lower register. Consequently, we need to swap the 64-bit halves when converting between these two representations on a big-endian machine. This patch replaces the __copy_{to,from}_user invocations in our compat VFP signal handling code with explicit __put_user loops that operate on 64-bit values and swap them accordingly. Cc: <stable@vger.kernel.org> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-09-17arm64: cpu hotplug: ensure we mask out CPU_TASKS_FROZEN in notifiersWill Deacon
We have a couple of CPU hotplug notifiers for resetting the CPU debug state to a sane value when a CPU comes online. This patch ensures that we mask out CPU_TASKS_FROZEN so that we don't miss any online events occuring due to suspend/resume. Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-09-17powerpc32: memset: only use dcbz once cache is enabledLEROY Christophe
memset() uses instruction dcbz to speed up clearing by not wasting time loading cache line with data that will be overwritten. Some platform like mpc52xx do no have cache active at startup and can therefore not use memset(). Allthough no part of the code explicitly uses memset(), GCC may make calls to it. This patch modifies memset() such that at startup, memset() unconditionally skip the optimised bloc that uses dcbz instruction. Once the initial MMU is set up, in machine_init() we patch memset() by replacing this inconditional jump by a NOP Tested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-09-17powerpc32: memcpy: only use dcbz once cache is enabledLEROY Christophe
memcpy() uses instruction dcbz to speed up copy by not wasting time loading cache line with data that will be overwritten. Some platform like mpc52xx do no have cache active at startup and can therefore not use memcpy(). Allthough no part of the code explicitly uses memcpy(), GCC makes calls to it. This patch modifies memcpy() such that at startup, memcpy() unconditionally jumps to generic_memcpy() which doesn't use the dcbz instruction. Once the initial MMU is set up, in machine_init() we patch memcpy() by replacing this inconditional jump by a NOP Reported-by: Michal Sojka <sojkam1@fel.cvut.cz> Tested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-09-16x86/platform: Fix Geode LX timekeeping in the generic x86 buildDavid Woodhouse
In 2007, commit 07190a08eef36 ("Mark TSC on GeodeLX reliable") bypassed verification of the TSC on Geode LX. However, this code (now in the check_system_tsc_reliable() function in arch/x86/kernel/tsc.c) was only present if CONFIG_MGEODE_LX was set. OpenWRT has recently started building its generic Geode target for Geode GX, not LX, to include support for additional platforms. This broke the timekeeping on LX-based devices, because the TSC wasn't marked as reliable: https://dev.openwrt.org/ticket/20531 By adding a runtime check on is_geode_lx(), we can also include the fix if CONFIG_MGEODEGX1 or CONFIG_X86_GENERIC are set, thus fixing the problem. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: Andres Salomon <dilinger@queued.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Marcelo Tosatti <marcelo@kvack.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1442409003.131189.87.camel@infradead.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-16powerpc/mm: Recompute hash value after a failed updateAneesh Kumar K.V
If we had secondary hash flag set, we ended up modifying hash value in the updatepp code path. Hence with a failed updatepp we will be using a wrong hash value for the following hash insert. Fix this by recomputing hash before insert. Without this patch we can end up with using wrong slot number in linux pte. That can result in us missing an hash pte update or invalidate which can cause memory corruption or even machine check. Fixes: 6d492ecc6489 ("powerpc/THP: Add code to handle HPTE faults for hugepages") Cc: stable@vger.kernel.org # v3.11+ Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-09-16powerpc/boot: Specify ABI v2 when building an LE boot wrapperBenjamin Herrenschmidt
The kernel does it, not the boot wrapper, which breaks with some cross compilers that still default to ABI v1. Fixes: 147c05168fc8 ("powerpc/boot: Add support for 64bit little endian wrapper") Cc: stable@vger.kernel.org # v3.16+ Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-09-15ia64: Enable userfaultfd and membarrier system callsLuck, Tony
Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-15arm64: head.S: initialise mdcr_el2 in el2_setupWill Deacon
When entering the kernel at EL2, we fail to initialise the MDCR_EL2 register which controls debug access and PMU capabilities at EL1. This patch ensures that the register is initialised so that all traps are disabled and all the PMU counters are available to the host. When a guest is scheduled, KVM takes care to configure trapping appropriately. Cc: <stable@vger.kernel.org> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-09-15arm64: enable generic idle loopLeo Yan
Enable generic idle loop for ARM64, so can support for hlt/nohlt command line options to override default idle loop behavior. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Leo Yan <leo.yan@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-09-14Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "A number of fixes for the merge window, fixing a number of cases missed when testing the uaccess code, particularly cases which only show up with certain compiler versions" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8431/1: fix alignement of __bug_table section entries arm/xen: Enable user access to the kernel before issuing a privcmd call ARM: domains: add memory dependencies to get_domain/set_domain ARM: domains: thread_info.h no longer needs asm/domains.h ARM: uaccess: fix undefined instruction on ARMv7M/noMMU ARM: uaccess: remove unneeded uaccess_save_and_disable macro ARM: swpan: fix nwfpe for uaccess changes ARM: 8429/1: disable GCC SRA optimization
2015-09-14x86/apic: Serialize LVTT and TSC_DEADLINE writesShaohua Li
The APIC LVTT register is MMIO mapped but the TSC_DEADLINE register is an MSR. The write to the TSC_DEADLINE MSR is not serializing, so it's not guaranteed that the write to LVTT has reached the APIC before the TSC_DEADLINE MSR is written. In such a case the write to the MSR is ignored and as a consequence the local timer interrupt never fires. The SDM decribes this issue for xAPIC and x2APIC modes. The serialization methods recommended by the SDM differ. xAPIC: "1. Memory-mapped write to LVT Timer Register, setting bits 18:17 to 10b. 2. WRMSR to the IA32_TSC_DEADLINE MSR a value much larger than current time-stamp counter. 3. If RDMSR of the IA32_TSC_DEADLINE MSR returns zero, go to step 2. 4. WRMSR to the IA32_TSC_DEADLINE MSR the desired deadline." x2APIC: "To allow for efficient access to the APIC registers in x2APIC mode, the serializing semantics of WRMSR are relaxed when writing to the APIC registers. Thus, system software should not use 'WRMSR to APIC registers in x2APIC mode' as a serializing instruction. Read and write accesses to the APIC registers will occur in program order. A WRMSR to an APIC register may complete before all preceding stores are globally visible; software can prevent this by inserting a serializing instruction, an SFENCE, or an MFENCE before the WRMSR." The xAPIC method is to just wait for the memory mapped write to hit the LVTT by checking whether the MSR write has reached the hardware. There is no reason why a proper MFENCE after the memory mapped write would not do the same. Andi Kleen confirmed that MFENCE is sufficient for the xAPIC case as well. Issue MFENCE before writing to the TSC_DEADLINE MSR. This can be done unconditionally as all CPUs which have TSC_DEADLINE also have MFENCE support. [ tglx: Massaged the changelog ] Signed-off-by: Shaohua Li <shli@fb.com> Reviewed-by: Ingo Molnar <mingo@kernel.org> Cc: <Kernel-team@fb.com> Cc: <lenb@kernel.org> Cc: <fenghua.yu@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: stable@vger.kernel.org #v3.7+ Link: http://lkml.kernel.org/r/20150909041352.GA2059853@devbig257.prn2.facebook.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-09-14x86/ioapic: Force affinity setting in setup_ioapic_dest()Thomas Gleixner
The recent ioapic cleanups changed the affinity setting in setup_ioapic_dest() from a direct write to the hardware to the delayed affinity setup via irq_set_affinity(). That results in a warning from chained_irq_exit(): WARNING: CPU: 0 PID: 5 at kernel/irq/migration.c:32 irq_move_masked_irq [<ffffffff810a0a88>] irq_move_masked_irq+0xb8/0xc0 [<ffffffff8103c161>] ioapic_ack_level+0x111/0x130 [<ffffffff812bbfe8>] intel_gpio_irq_handler+0x148/0x1c0 The reason is that irq_set_affinity() does not write directly to the hardware. It marks the affinity setting as pending and executes it from the next interrupt. The chained handler infrastructure does not take the irq descriptor lock for performance reasons because such a chained interrupt is not visible to any interfaces. So the delayed affinity setting triggers the warning in irq_move_masked_irq(). Restore the old behaviour by calling the set_affinity function of the ioapic chip in setup_ioapic_dest(). This is safe as none of the interrupts can be on the fly at this point. Fixes: aa5cb97f14a2 'x86/irq: Remove x86_io_apic_ops.set_affinity and related interfaces' Reported-and-tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: jarkko.nikula@linux.intel.com
2015-09-14x86/paravirt: Remove the unused pv_time_ops::get_tsc_khz methodJuergen Gross
It's not used anywhere. Signed-off-by: Juergen Gross <jgross@suse.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: akataria@vmware.com Cc: chrisw@sous-sol.org Cc: jeremy@goop.org Cc: virtualization@lists.linux-foundation.org Link: http://lkml.kernel.org/r/1442227343-403-1-git-send-email-jgross@suse.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-14arm64: pgtable: use a single bit for PTE_WRITE regardless of DBMWill Deacon
Depending on CONFIG_ARM64_HW_AFDBM, we use either bit 57 or 51 of the pte to represent PTE_WRITE. Given that bit 51 is reserved prior to ARMv8.1, we can just use that bit regardless of the config option. That also matches what happens if a kernel configured with ARM64_HW_AFDBM=y is run on a CPU without the DBM functionality. Cc: Julien Grall <julien.grall@citrix.com> Tested-by: Julien Grall <julien.grall@citrix.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-09-14arm64: Fix pte_modify() to preserve the hardware dirty informationCatalin Marinas
The pte_modify() function with hardware AF/DBM enabled must transfer the hardware dirty information to the software PTE_DIRTY bit. However, it was setting this bit in newprot and the mask does not cover such bit. This patch sets PTE_DIRTY on the original pte which will be preserved in the returned value. Fixes: 2f4b829c625e ("arm64: Add support for hardware updates of the access and dirty pte bits") Cc: Julien Grall <julien.grall@citrix.com> Tested-by: Julien Grall <julien.grall@citrix.com> Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-09-14arm64: Fix the pte_hw_dirty() check when AF/DBM is enabledCatalin Marinas
Commit 2f4b829c625e ("arm64: Add support for hardware updates of the access and dirty pte bits") introduced support for handling hardware updates of the access flag and dirty status. The PTE is automatically dirtied in hardware (if supported) by clearing the PTE_RDONLY bit when the PTE_DBM/PTE_WRITE bit is set. The pte_hw_dirty() macro was added to detect a hardware dirtied pte. The pte_dirty() macro checks for both software PTE_DIRTY and pte_hw_dirty(). Functions like pte_modify() clear the PTE_RDONLY bit since it is meant to be set in set_pte_at() when written to memory. In such cases, pte_hw_dirty() would return true even though such pte is clean. This patch changes pte_hw_dirty() to test the PTE_DBM/PTE_WRITE bit together with PTE_RDONLY. Fixes: 2f4b829c625e ("arm64: Add support for hardware updates of the access and dirty pte bits") Reported-by: Julien Grall <julien.grall@citrix.com> Tested-by: Julien Grall <julien.grall@citrix.com> Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-09-14arm64: dma-mapping: check whether cma area is initialized or notJisheng Zhang
If CMA is turned on and CMA size is set to zero, kernel should behave as if CMA was not enabled at compile time. Every dma allocation should check existence of cma area before requesting memory. Arm has done this by commit e464ef16c4f0 ("arm: dma-mapping: add checking cma area initialized"), also do this for arm64. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-09-14x86/ldt: Fix small LDT allocation for XenJan Beulich
While the following commit: 37868fe113 ("x86/ldt: Make modify_ldt synchronous") added a nice comment explaining that Xen needs page-aligned whole page chunks for guest descriptor tables, it then nevertheless used kzalloc() on the small size path. As I'm unaware of guarantees for kmalloc(PAGE_SIZE, ) to return page-aligned memory blocks, I believe this needs to be switched back to __get_free_page() (or better get_zeroed_page()). Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/55E735D6020000780009F1E6@prv-mh.provo.novell.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-14x86/vm86: Fix the misleading CONFIG_VM86 Kconfig help textIngo Molnar
The CONFIG_VM86 Kconfig help text is actively misleading, so fix it: - Don't mark it 'obsolete' in the text as we'll support the ABI as long as CPUs support it. - Qualify the part about software emulation and mention that for some apps you want a real vm86 mode. - Don't scare users away from the option, instead explain what it does. Reported-by: Stas Sergeev <stsp@list.ru> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Austin S Hemmelgarn <ahferroin7@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Josh Boyer <jwboyer@fedoraproject.org> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-13perf/x86/intel: Fix constraint accessPeter Zijlstra
Sasha reported that we can get here with .idx==-1, and cpuc->event_constraints unallocated. Suggested-by: Stephane Eranian <eranian@google.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: <stable@vger.kernel.org> Fixes: b371b5943178 ("perf/x86: Fix event/group validation") Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-13x86/cpu: Print family/model/stepping in hexBorislav Petkov
924e101a7ab6 ("x86/debug: Dump family, model, stepping of the boot CPU") had its good intentions to dump the exact F/M/S as an aid during debugging sessions but its output can be ambiguous. Fix that: -smpboot: CPU0: Intel Core Processor (Broadwell) (fam: 06, model: 47, stepping: 02) +smpboot: CPU0: Intel Core Processor (Broadwell) (family: 0x6, model: 0x47, stepping: 0x2) Also, spell out "family". Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1441914927-32037-1-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-12Merge tag 'cris-for-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jesper/cris Pull CRIS updates from Jesper Nilsson: "Mostly removal of old cruft of which we can use a generic version, or fixes for code not commonly run in the cris port, but also additions to enable some good debug" * tag 'cris-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/jesper/cris: (25 commits) CRISv10: delete unused lib/dmacopy.c CRISv10: delete unused lib/old_checksum.c CRIS: fix switch_mm() lockdep splat CRISv32: enable LOCKDEP_SUPPORT CRIS: add STACKTRACE_SUPPORT CRISv32: annotate irq enable in idle loop CRISv32: add support for irqflags tracing CRIS: UAPI: use generic types.h CRIS: UAPI: use generic shmbuf.h CRIS: UAPI: use generic msgbuf.h CRIS: UAPI: use generic socket.h CRIS: UAPI: use generic sembuf.h CRIS: UAPI: use generic sockios.h CRIS: UAPI: use generic auxvec.h CRIS: UAPI: use generic headers via Kbuild CRIS: UAPI: fix elf.h export CRIS: don't make asm/elf.h depend on asm/user.h CRIS: UAPI: fix ptrace.h CRISv32: Squash compile warnings for axisflashmap CRISv32: Add GPIO driver to the default configs ...
2015-09-11Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge fourth patch-bomb from Andrew Morton: - sys_membarier syscall - seq_file interface changes - a few misc fixups * emailed patches from Andrew Morton <akpm@linux-foundation.org>: revert "ocfs2/dlm: use list_for_each_entry instead of list_for_each" mm/early_ioremap: add explicit #include of asm/early_ioremap.h fs/seq_file: convert int seq_vprint/seq_printf/etc... returns to void selftests: enhance membarrier syscall test selftests: add membarrier syscall test sys_membarrier(): system-wide memory barrier (generic, x86) MODSIGN: fix a compilation warning in extract-cert
2015-09-11ARCv2: [axs103_smp] Reduce clk for SMP FPGA configsVineet Gupta
Newer bitfiles needs the reduced clk even for SMP builds Cc: <stable@vger.kernel.org> #4.2 Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-11sys_membarrier(): system-wide memory barrier (generic, x86)Mathieu Desnoyers
Here is an implementation of a new system call, sys_membarrier(), which executes a memory barrier on all threads running on the system. It is implemented by calling synchronize_sched(). It can be used to distribute the cost of user-space memory barriers asymmetrically by transforming pairs of memory barriers into pairs consisting of sys_membarrier() and a compiler barrier. For synchronization primitives that distinguish between read-side and write-side (e.g. userspace RCU [1], rwlocks), the read-side can be accelerated significantly by moving the bulk of the memory barrier overhead to the write-side. The existing applications of which I am aware that would be improved by this system call are as follows: * Through Userspace RCU library (http://urcu.so) - DNS server (Knot DNS) https://www.knot-dns.cz/ - Network sniffer (http://netsniff-ng.org/) - Distributed object storage (https://sheepdog.github.io/sheepdog/) - User-space tracing (http://lttng.org) - Network storage system (https://www.gluster.org/) - Virtual routers (https://events.linuxfoundation.org/sites/events/files/slides/DPDK_RCU_0MQ.pdf) - Financial software (https://lkml.org/lkml/2015/3/23/189) Those projects use RCU in userspace to increase read-side speed and scalability compared to locking. Especially in the case of RCU used by libraries, sys_membarrier can speed up the read-side by moving the bulk of the memory barrier cost to synchronize_rcu(). * Direct users of sys_membarrier - core dotnet garbage collector (https://github.com/dotnet/coreclr/issues/198) Microsoft core dotnet GC developers are planning to use the mprotect() side-effect of issuing memory barriers through IPIs as a way to implement Windows FlushProcessWriteBuffers() on Linux. They are referring to sys_membarrier in their github thread, specifically stating that sys_membarrier() is what they are looking for. To explain the benefit of this scheme, let's introduce two example threads: Thread A (non-frequent, e.g. executing liburcu synchronize_rcu()) Thread B (frequent, e.g. executing liburcu rcu_read_lock()/rcu_read_unlock()) In a scheme where all smp_mb() in thread A are ordering memory accesses with respect to smp_mb() present in Thread B, we can change each smp_mb() within Thread A into calls to sys_membarrier() and each smp_mb() within Thread B into compiler barriers "barrier()". Before the change, we had, for each smp_mb() pairs: Thread A Thread B previous mem accesses previous mem accesses smp_mb() smp_mb() following mem accesses following mem accesses After the change, these pairs become: Thread A Thread B prev mem accesses prev mem accesses sys_membarrier() barrier() follow mem accesses follow mem accesses As we can see, there are two possible scenarios: either Thread B memory accesses do not happen concurrently with Thread A accesses (1), or they do (2). 1) Non-concurrent Thread A vs Thread B accesses: Thread A Thread B prev mem accesses sys_membarrier() follow mem accesses prev mem accesses barrier() follow mem accesses In this case, thread B accesses will be weakly ordered. This is OK, because at that point, thread A is not particularly interested in ordering them with respect to its own accesses. 2) Concurrent Thread A vs Thread B accesses Thread A Thread B prev mem accesses prev mem accesses sys_membarrier() barrier() follow mem accesses follow mem accesses In this case, thread B accesses, which are ensured to be in program order thanks to the compiler barrier, will be "upgraded" to full smp_mb() by synchronize_sched(). * Benchmarks On Intel Xeon E5405 (8 cores) (one thread is calling sys_membarrier, the other 7 threads are busy looping) 1000 non-expedited sys_membarrier calls in 33s =3D 33 milliseconds/call. * User-space user of this system call: Userspace RCU library Both the signal-based and the sys_membarrier userspace RCU schemes permit us to remove the memory barrier from the userspace RCU rcu_read_lock() and rcu_read_unlock() primitives, thus significantly accelerating them. These memory barriers are replaced by compiler barriers on the read-side, and all matching memory barriers on the write-side are turned into an invocation of a memory barrier on all active threads in the process. By letting the kernel perform this synchronization rather than dumbly sending a signal to every process threads (as we currently do), we diminish the number of unnecessary wake ups and only issue the memory barriers on active threads. Non-running threads do not need to execute such barrier anyway, because these are implied by the scheduler context switches. Results in liburcu: Operations in 10s, 6 readers, 2 writers: memory barriers in reader: 1701557485 reads, 2202847 writes signal-based scheme: 9830061167 reads, 6700 writes sys_membarrier: 9952759104 reads, 425 writes sys_membarrier (dyn. check): 7970328887 reads, 425 writes The dynamic sys_membarrier availability check adds some overhead to the read-side compared to the signal-based scheme, but besides that, sys_membarrier slightly outperforms the signal-based scheme. However, this non-expedited sys_membarrier implementation has a much slower grace period than signal and memory barrier schemes. Besides diminishing the number of wake-ups, one major advantage of the membarrier system call over the signal-based scheme is that it does not need to reserve a signal. This plays much more nicely with libraries, and with processes injected into for tracing purposes, for which we cannot expect that signals will be unused by the application. An expedited version of this system call can be added later on to speed up the grace period. Its implementation will likely depend on reading the cpu_curr()->mm without holding each CPU's rq lock. This patch adds the system call to x86 and to asm-generic. [1] http://urcu.so membarrier(2) man page: MEMBARRIER(2) Linux Programmer's Manual MEMBARRIER(2) NAME membarrier - issue memory barriers on a set of threads SYNOPSIS #include <linux/membarrier.h> int membarrier(int cmd, int flags); DESCRIPTION The cmd argument is one of the following: MEMBARRIER_CMD_QUERY Query the set of supported commands. It returns a bitmask of supported commands. MEMBARRIER_CMD_SHARED Execute a memory barrier on all threads running on the system. Upon return from system call, the caller thread is ensured that all running threads have passed through a state where all memory accesses to user-space addresses match program order between entry to and return from the system call (non-running threads are de facto in such a state). This covers threads from all pro=E2=80=90 cesses running on the system. This command returns 0. The flags argument needs to be 0. For future extensions. All memory accesses performed in program order from each targeted thread is guaranteed to be ordered with respect to sys_membarrier(). If we use the semantic "barrier()" to represent a compiler barrier forcing memory accesses to be performed in program order across the barrier, and smp_mb() to represent explicit memory barriers forcing full memory ordering across the barrier, we have the following ordering table for each pair of barrier(), sys_membarrier() and smp_mb(): The pair ordering is detailed as (O: ordered, X: not ordered): barrier() smp_mb() sys_membarrier() barrier() X X O smp_mb() X O O sys_membarrier() O O O RETURN VALUE On success, these system calls return zero. On error, -1 is returned, and errno is set appropriately. For a given command, with flags argument set to 0, this system call is guaranteed to always return the same value until reboot. ERRORS ENOSYS System call is not implemented. EINVAL Invalid arguments. Linux 2015-04-15 MEMBARRIER(2) Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Nicholas Miell <nmiell@comcast.net> Cc: Ingo Molnar <mingo@redhat.com> Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Pranith Kumar <bobby.prani@gmail.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-11Merge branch 'uaccess' into fixesRussell King
2015-09-11ARM: 8431/1: fix alignement of __bug_table section entriesRobert Jarzmik
On old ARM chips, unaligned accesses to memory are not trapped and fixed. On module load, symbols are relocated, and the relocation of __bug_table symbols is done on a u32 basis. Yet the section is not aligned to a multiple of 4 address, but to a multiple of 2. This triggers an Oops on pxa architecture, where address 0xbf0021ea is the first relocation in the __bug_table section : apply_relocate(): pxa3xx_nand: section 13 reloc 0 sym '' Unable to handle kernel paging request at virtual address bf0021ea pgd = e1cd0000 [bf0021ea] *pgd=c1cce851, *pte=c1cde04f, *ppte=c1cde01f Internal error: Oops: 23 [#1] ARM Modules linked in: CPU: 0 PID: 606 Comm: insmod Not tainted 4.2.0-rc8-next-20150828-cm-x300+ #887 Hardware name: CM-X300 module task: e1c68700 ti: e1c3e000 task.ti: e1c3e000 PC is at apply_relocate+0x2f4/0x3d4 LR is at 0xbf0021ea pc : [<c000e7c8>] lr : [<bf0021ea>] psr: 80000013 sp : e1c3fe30 ip : 60000013 fp : e49e8c60 r10: e49e8fa8 r9 : 00000000 r8 : e49e7c58 r7 : e49e8c38 r6 : e49e8a58 r5 : e49e8920 r4 : e49e8918 r3 : bf0021ea r2 : bf007034 r1 : 00000000 r0 : bf000000 Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none Control: 0000397f Table: c1cd0018 DAC: 00000051 Process insmod (pid: 606, stack limit = 0xe1c3e198) [<c000e7c8>] (apply_relocate) from [<c005ce5c>] (load_module+0x1248/0x1f5c) [<c005ce5c>] (load_module) from [<c005dc54>] (SyS_init_module+0xe4/0x170) [<c005dc54>] (SyS_init_module) from [<c000a420>] (ret_fast_syscall+0x0/0x38) Fix this by ensuring entries in __bug_table are all aligned to at least of multiple of 4. This transforms a module section __bug_table as : - [12] __bug_table PROGBITS 00000000 002232 000018 00 A 0 0 1 + [12] __bug_table PROGBITS 00000000 002232 000018 00 A 0 0 4 Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Reviewed-by: Dave Martin <Dave.Martin@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-09-11arm/xen: Enable user access to the kernel before issuing a privcmd callJulien Grall
When Xen is copying data to/from the guest it will check if the kernel has the right to do the access. If not, the hypercall will return an error. After the commit a5e090acbf545c0a3b04080f8a488b17ec41fe02 "ARM: software-based privileged-no-access support", the kernel can't access any longer the user space by default. This will result to fail on every hypercall made by the userspace (i.e via privcmd). We have to enable the userspace access and then restore the correct permission every time the privcmd is used to made an hypercall. I didn't find generic helpers to do a these operations, so the change is only arm32 specific. Reported-by: Riku Voipio <riku.voipio@linaro.org> Signed-off-by: Julien Grall <julien.grall@citrix.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-09-11ARM: domains: add memory dependencies to get_domain/set_domainRussell King
We need to have memory dependencies on get_domain/set_domain to avoid the compiler over-optimising these inline assembly instructions. Loads/stores must not be reordered across a set_domain(), so introduce a compiler barrier for that assembly. The value of get_domain() must not be cached across a set_domain(), but we still want to allow the compiler to optimise it away. Introduce a dependency on current_thread_info()->cpu_domain to avoid this; the new memory clobber in set_domain() should therefore cause the compiler to re-load this. The other advantage of using this is we should have its address in the register set already, or very soon after at most call sites. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-09-11ARM: domains: thread_info.h no longer needs asm/domains.hRussell King
As of 1eef5d2f1b46 ("ARM: domains: switch to keeping domain value in register") we no longer need to include asm/domains.h into asm/thread_info.h. Remove it. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-09-11perf/x86/intel/bts: Set event->hw.itrace_started in pmu::start to match the ↵Alexander Shishkin
new logic Since event->hw.itrace_started is now set in pmu::start() to signal the beginning of the trace, do so also in the intel_bts driver. Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: acme@infradead.org Cc: adrian.hunter@intel.com Cc: hpa@zytor.com Link: http://lkml.kernel.org/r/1437140050-23363-4-git-send-email-alexander.shishkin@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-11locking/qspinlock/x86: Only emit the test-and-set fallback when building ↵Peter Zijlstra
guest support Only emit the test-and-set fallback for Hypervisors lacking PARAVIRT_SPINLOCKS support when building for guests. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Cc: stable@vger.kernel.org # 4.2 Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-11locking/qspinlock/x86: Fix performance regression under unaccelerated VMsPeter Zijlstra
Dave ran into horrible performance on a VM without PARAVIRT_SPINLOCKS set and Linus noted that the test-and-set implementation was retarded. One should spin on the variable with a load, not a RMW. While there, remove 'queued' from the name, as the lock isn't queued at all, but a simple test-and-set. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Reported-by: Dave Chinner <david@fromorbit.com> Tested-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Waiman Long <Waiman.Long@hp.com> Cc: stable@vger.kernel.org # v4.2+ Link: http://lkml.kernel.org/r/20150904152523.GR18673@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-10Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patch-bomb from Andrew Morton: - even more of the rest of MM - lib/ updates - checkpatch updates - small changes to a few scruffy filesystems - kmod fixes/cleanups - kexec updates - a dma-mapping cleanup series from hch * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (81 commits) dma-mapping: consolidate dma_set_mask dma-mapping: consolidate dma_supported dma-mapping: cosolidate dma_mapping_error dma-mapping: consolidate dma_{alloc,free}_noncoherent dma-mapping: consolidate dma_{alloc,free}_{attrs,coherent} mm: use vma_is_anonymous() in create_huge_pmd() and wp_huge_pmd() mm: make sure all file VMAs have ->vm_ops set mm, mpx: add "vm_flags_t vm_flags" arg to do_mmap_pgoff() mm: mark most vm_operations_struct const namei: fix warning while make xmldocs caused by namei.c ipc: convert invalid scenarios to use WARN_ON zlib_deflate/deftree: remove bi_reverse() lib/decompress_unlzma: Do a NULL check for pointer lib/decompressors: use real out buf size for gunzip with kernel fs/affs: make root lookup from blkdev logical size sysctl: fix int -> unsigned long assignments in INT_MIN case kexec: export KERNEL_IMAGE_SIZE to vmcoreinfo kexec: align crash_notes allocation to make it be inside one physical page kexec: remove unnecessary test in kimage_alloc_crash_control_pages() kexec: split kexec_load syscall from kexec core code ...
2015-09-10Merge tag 'armsoc-late' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull late ARM SoC updates from Kevin Hilman: "This is a collection of a few late fixes and other misc stuff that had dependencies on things being merged from other trees. The bulk of the changes are for samsung/exynos SoCs for some changes that needed a few minor reworks so ended up a bit late. The others are mainly for qcom SoCs: a couple fixes and some DTS updates" * tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (37 commits) ARM: multi_v7_defconfig: Enable PBIAS regulator soc: qcom: smd: Correct fBLOCKREADINTR handling soc: qcom: smd: Use correct remote processor ID soc: qcom: smem: Fix errant private access ARM: dts: qcom: msm8974-sony-xperia-honami: Use stdout-path ARM: dts: qcom: msm8960-cdp: Use stdout-path ARM: dts: qcom: msm8660-surf: Use stdout-path ARM: dts: qcom: ipq8064-ap148: Use stdout-path ARM: dts: qcom: apq8084-mtp: Use stdout-path ARM: dts: qcom: apq8084-ifc6540: Use stdout-path ARM: dts: qcom: apq8074-dragonboard: Use stdout-path ARM: dts: qcom: apq8064-ifc6410: Use stdout-path ARM: dts: qcom: apq8064-cm-qs600: Use stdout-path ARM: dts: qcom: Label serial nodes for aliasing and stdout-path reset: ath79: Fix missing spin_lock_init reset: Add (devm_)reset_control_get stub functions ARM: EXYNOS: switch to using generic cpufreq driver for exynos4x12 cpufreq: exynos: Remove unselectable rule for arm-exynos-cpufreq.o ARM: dts: add iommu property to JPEG device for exynos4 ARM: dts: enable SPI1 for exynos4412-odroidu3 ...
2015-09-10Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull more kvm updates from Paolo Bonzini: "ARM: - Full debug support for arm64 - Active state switching for timer interrupts - Lazy FP/SIMD save/restore for arm64 - Generic ARMv8 target PPC: - Book3S: A few bug fixes - Book3S: Allow micro-threading on POWER8 x86: - Compiler warnings Generic: - Adaptive polling for guest halt" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (49 commits) kvm: irqchip: fix memory leak kvm: move new trace event outside #ifdef CONFIG_KVM_ASYNC_PF KVM: trace kvm_halt_poll_ns grow/shrink KVM: dynamic halt-polling KVM: make halt_poll_ns per-vCPU Silence compiler warning in arch/x86/kvm/emulate.c kvm: compile process_smi_save_seg_64() only for x86_64 KVM: x86: avoid uninitialized variable warning KVM: PPC: Book3S: Fix typo in top comment about locking KVM: PPC: Book3S: Fix size of the PSPB register KVM: PPC: Book3S HV: Exit on H_DOORBELL if HOST_IPI is set KVM: PPC: Book3S HV: Fix race in starting secondary threads KVM: PPC: Book3S: correct width in XER handling KVM: PPC: Book3S HV: Fix preempted vcore stolen time calculation KVM: PPC: Book3S HV: Fix preempted vcore list locking KVM: PPC: Book3S HV: Implement H_CLEAR_REF and H_CLEAR_MOD KVM: PPC: Book3S HV: Fix bug in dirty page tracking KVM: PPC: Book3S HV: Fix race in reading change bit when removing HPTE KVM: PPC: Book3S HV: Implement dynamic micro-threading on POWER8 KVM: PPC: Book3S HV: Make use of unused threads when running guests ...
2015-09-10Merge tag 'for-linus-4.3-rc0b-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen terminology fixes from David Vrabel: "Use the correct GFN/BFN terms more consistently" * tag 'for-linus-4.3-rc0b-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/xenbus: Rename the variable xen_store_mfn to xen_store_gfn xen/privcmd: Further s/MFN/GFN/ clean-up hvc/xen: Further s/MFN/GFN clean-up video/xen-fbfront: Further s/MFN/GFN clean-up xen/tmem: Use xen_page_to_gfn rather than pfn_to_gfn xen: Use correctly the Xen memory terminologies arm/xen: implement correctly pfn_to_mfn xen: Make clear that swiotlb and biomerge are dealing with DMA address
2015-09-10Merge branch 'next' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
Pull microblaze update from Michal Simek. * 'next' of git://git.monstr.eu/linux-2.6-microblaze: elf-em.h: move EM_MICROBLAZE to the common header
