Occasionally the system gets into a state where the CMOS clock has gotten
slightly ahead of current time and the periodic update of RTC fails. The
message is a nuisance and repeats spamming the log.
See: http://www.ntp.org/ntpfaq/NTP-s-trbl-spec.htm#Q-LINUX-SET-RTC-MMSS
Rather than just removing the message, make it show only once and reduce
severity since it indicates a normal and non urgent condition.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Simplify write file operation for mmapper by using
simple_write_to_buffer().
Cc: Jeff Dike <jdike@addtoit.com>
Add missing MODULE_LICENSE():
WARNING: modpost: missing MODULE_LICENSE() in arch/um/drivers/mmapper_kern.o
Cc: Greg Lonnon <glonnon@ridgerun.com>
unregister_winch() should use list_for_each_safe(), as it can delete from
the list.
Signed-off-by: Will Newton <will.newton@gmail.com>
Cc: richard -rw- weinberger <richard.weinberger@gmail.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Currently CONFIG_HIGHMEM is broken on User Mode Linux. I'm not sure if it
worked ever.
It doesn't compile and this breaks randomconfig testing.
Signed-off-by: Richard Weinberger <richard@nod.at>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sparc64: Fix bootup regression due to perf init ordering.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (72 commits)
powerpc/pseries: Fix build of topology stuff without CONFIG_NUMA
powerpc/pseries: Fix VPHN build errors on non-SMP systems
powerpc/83xx: add mpc8308_p1m DMA controller device-tree node
powerpc/83xx: add DMA controller to mpc8308 device-tree node
powerpc/512x: try to free dma descriptors in case of allocation failure
powerpc/512x: add MPC8308 dma support
powerpc/512x: fix the hanged dma transfer issue
powerpc/512x: scatter/gather dma fix
powerpc/powermac: Make auto-loading of therm_pm72 possible
of/address: Use propper endianess in get_flags
powerpc/pci: Use printf extension %pR for struct resource
powerpc: Remove unnecessary casts of void ptr
powerpc: Disable VPHN polling during a suspend operation
powerpc/pseries: Poll VPA for topology changes and update NUMA maps
powerpc: iommu: Add device name to iommu error printks
powerpc: Record vma->phys_addr in ioremap()
powerpc: Update compat_arch_ptrace
powerpc: Fix PPC_PTRACE_SETHWDEBUG on PPC_BOOK3S
powerpc/time: printk time stamp init not correct
powerpc: Minor cleanups for machdep.h
* 'next' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: remove obsolete DEBUG_BOOTMEM
microblaze: trivial: Fix removed the part of line
microblaze: Fix __muldi3 function for little-endian.
microblaze: Clear i/dcache for sw breakpoints
microblaze: Remove useless early_init_dt_check_for_initrd
microblaze: Fix unaligned exception for little endian platform
microblaze: Add PVR for Microblaze v8.00.b
microblaze: Correct PVR access macros
Revert "microblaze: Simplify syscall rutine"
microblaze: Fix initramfs
arch/microblaze: Remove unnecessary semicolons
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix Moorestown VRTC fixmap placement
x86/gpio: Implement x86 gpio_to_irq convert function
x86, UV: Fix APICID shift for Westmere processors
x86: Use PCI method for enabling AMD extended config space before MSR method
x86: tsc: Prevent delayed init if initial tsc calibration failed
x86, lapic-timer: Increase the max_delta to 31 bits
x86: Fix sparse non-ANSI function warnings in smpboot.c
x86, numa: Fix CONFIG_DEBUG_PER_CPU_MAPS without NUMA emulation
x86, AMD, PCI: Add AMD northbridge PCI device id for CPU families 12h and 14h
x86, numa: Fix cpu to node mapping for sparse node ids
x86, numa: Fake node-to-cpumask for NUMA emulation
x86, numa: Fake apicid and pxm mappings for NUMA emulation
x86, numa: Avoid compiling NUMA emulation functions without CONFIG_NUMA_EMU
x86, numa: Reduce minimum fake node size to 32M
Fix up trivial conflict in arch/x86/kernel/apic/x2apic_uv_x.c
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits)
perf session: Fix infinite loop in __perf_session__process_events
perf evsel: Support perf_evsel__open(cpus > 1 && threads > 1)
perf sched: Use PTHREAD_STACK_MIN to avoid pthread_attr_setstacksize() fail
perf tools: Emit clearer message for sys_perf_event_open ENOENT return
perf stat: better error message for unsupported events
perf sched: Fix allocation result check
perf, x86: P4 PMU - Fix unflagged overflows handling
dynamic debug: Fix build issue with older gcc
tracing: Fix TRACE_EVENT power tracepoint creation
tracing: Fix preempt count leak
tracepoint: Add __rcu annotation
tracing: remove duplicate null-pointer check in skb tracepoint
tracing/trivial: Add missing comma in TRACE_EVENT comment
tracing: Include module.h in define_trace.h
x86: Save rbp in pt_regs on irq entry
x86, dumpstack: Fix unused variable warning
x86, NMI: Clean-up default_do_nmi()
x86, NMI: Allow NMI reason io port (0x61) to be processed on any CPU
x86, NMI: Remove DIE_NMI_IPI
x86, NMI: Add priorities to handlers
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (39 commits)
mmc: davinci: add support for SDIO irq handling
mmc: fix division by zero in MMC core
mmc: tmio_mmc: fix CMD irq handling
mmc: tmio_mmc: handle missing HW interrupts
mfd: sh_mobile_sdhi: activate SDIO IRQ for tmio_mmc
mmc: tmio_mmc: implement SDIO IRQ support
mfd: sdhi: require the tmio-mmc driver to bounce unaligned buffers
mmc: tmio_mmc: silence compiler warnings
mmc: tmio_mmc: implement a bounce buffer for unaligned DMA
mmc: tmio_mmc: merge the private header into the driver
mmc: tmio_mmc: fix PIO fallback on DMA descriptor allocation failure
mmc: tmio_mmc: allow multi-element scatter-gather lists
mmc: Register debugfs dir before calling card probe function.
mmc: MMC_BLOCK_MINORS should depend on MMC_BLOCK.
mmc: Explain why we make adjacent mmc_bus_{put,get} calls during rescan.
mmc: Fix sd/sdio/mmc initialization frequency retries
mmc: fix mmc_set_bus_width_ddr() call without bus-width-test cap
mmc: dw_mmc: Add Synopsys DesignWare mmc host driver.
mmc: add sdhci-tegra driver for Tegra SoCs
mmc: sdhci: add quirk for max len ADMA descriptors
The x86 fixmaps need to be all together... unfortunately the
VRTC one was misplaced.
This patch makes sure the MRST VRTC fixmap is put prior to the
__end_of_permanent_fixed_addresses marker.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
LKML-Reference: <20110111105544.24448.27607.stgit@bob.linux.org.uk>
We need this for x86 MID platforms where GPIO interrupts are
used. No special magic is needed so the default 1:1 behaviour
will do nicely.
Signed-off-by: Alek Du <alek.du@intel.com>
Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com>
LKML-Reference: <20110111105439.24448.69863.stgit@bob.linux.org.uk>
Westmere processors use a different algorithm for
assigning APICIDs on SGI UV systems. The location of the
node number within the apicid is now a function of the
processor type.
Signed-off-by: Jack Steiner <steiner@sgi.com>
LKML-Reference: <20110110195210.GA18737@sgi.com>
While both methods should work equivalently well for the native
case, the Xen Dom0 case can't reliably work with the MSR one,
since there's no guarantee that the virtual CPUs it has
available fully cover all necessary physical ones.
As per the suggestion of Robert Richter the patch only adds the
PCI method, but leaves the MSR one as a fallback to cover new
systems the PCI IDs of which may not have got added to the code
base yet.
The only change in v2 is the breaking out of the new CPI
initialization method into a separate function, as requested by
Ingo.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Robert Richter <robert.richter@amd.com>
Cc: Andreas Herrmann3 <Andreas.Herrmann3@amd.com>
Cc: Joerg Roedel <joerg.roedel@amd.com>
LKML-Reference: <4D2B3FD7020000780002B67D@vpn.id2.novell.com>
commit a8760ec (x86: Check tsc available/disabled in the delayed init
function) missed to prevent the setup of the delayed init function in
case the initial tsc calibration failed. This results in the same
divide by zero bug as we have seen without the tsc disabled check.
Skip the delayed work setup when tsc_khz (the initial calibration
value) is 0.
Bisected-and-tested-by: Kirill A. Shutemov <kas@openvz.org>
Cc: John Stultz <john.stultz@linaro.org>
The header asm/hvcall.h was previously included indirectly via
smp.h. On non-SMP systems, however, these declarations are excluded
and the build breaks. This is easily fixed by including asm/hvcall.h
directly.
The VPHN feature is only meaningful on NUMA systems that implement
the SPLPAR option, so exclude the VPHN code on systems without
SPLPAR enabled.
Also, expose unmap_cpu_from_node() on systems with SPLPAR enabled,
even if CONFIG_HOTPLUG_CPU is disabled.
Lastly, map_cpu_to_node() is now needed by VPHN to manipulate the
node masks after boot time, so remove the __cpuinit annotation to
fix a section mismatch.
Signed-off-by: Jesse Larrew <jlarrew@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (52 commits)
Blackfin: encode cpu-rev into uImage name
Blackfin: bf54x: don't ack GPIO ints when unmasking them
Blackfin: sram_free_with_lsl: do not ignore return value of sram_free
Blackfin: boards: add missing "static" to peripheral lists
Blackfin: DNP5370: new board port
Blackfin: bf518f-ezbrd: fix dsa resources
Blackfin: move "-m elf32bfin" to general LDFLAGS
Blackfin: kgdb_test: make sure to initialize num2
Blackfin: kgdb: disable preempt schedule when running single step in kgdb
Blackfin: kgdb: disable interrupt when single stepping in ADEOS
Blackfin: SMP: kgdb: apply anomaly 257 work around
Blackfin: fix building IPIPE code when XIP is enabled
Blackfin: SMP: kgdb: flush core internal write buffer before flushinv
Blackfin: sport_uart resources: remove unused secondary RX/TX pins
Blackfin: tll6527m: fix spelling in unused code (struct name)
Blackfin: bf527-ezkit: add adau1373 chip address
Blackfin: no-mpu: fix masking of small uncached dma region
Blackfin: pm: drop irq save/restore in standby and suspend to mem callback
MAINTAINERS: update Analog Devices support info
Blackfin: dpmc.h: pull in new pll.h
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68knommu: Need to check __get_user()/__put_user() result
m68knommu: signal.c __user annotations
m68knommu: Equivalent of "m68k: handle new gcc's"
m68knommu: f_pcr has been gone since headers' merge
m68knommu: Don't lose state if sigframe setup fails
m68knommu: Handle multiple pending signals
m68knommu: Switch to saner sigsuspend
m68knommu: Don't bother with SA_ONESHOT
m68k: Check __get_user()/__put_user() return value
m68k: Missing syscall_trace() on sigreturn
m68k: Fix stack mangling logics in sigreturn
m68k: If we fail to set sigframe up, just leave regs alone...
m68k: Don't lose state if sigframe setup fails
m68k: Simplify the singlestepping handling in signals
m68k: Switch to saner sigsuspend()
m68k: Resetting sa_handler in local copy of k_sigaction is pointless
m68k/sun3: Kill pte_unmap() warnings
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Avoid array overflow if there are too many cpus in SRAT table
[IA64] Remove unlikely from cpu_is_offline
[IA64] irq_ia64, use set_irq_chip
[IA64] perfmon: Change vmalloc to vzalloc and drop memset.
[IA64] eliminate race condition in smp_flush_tlb_mm
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson
* 'for-torvalds' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson:
ux500: allow 5500 and 8500 to be built together
ux500: modem_irq is only for 5500
ux500: dynamic SOC detection
ux500: rename MOP board Kconfig
ux500: remove build-time changing macros
* 'msm-smp' of git://codeaurora.org/quic/kernel/davidb/linux-msm:
msm: add SMP support for msm
msm: hotplug: support cpu hotplug on msm
msm: timer: SMP timer support for msm
msm: scm-boot: Support for setting cold/warm boot addresses
msm: Secure Channel Manager (SCM) support
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
[Modified to hit the right file]
Dynamically detect the DBx500 SOC an revision based on the ASIC ID.
Rename the MOP board Kconfig entries to the same name as the machine
type, so that the machine_is_*() macros work correctly.
[Updated to match changes in the tree]
To allow the possiblity of building U8500 and U5500 support in the same
image.
[Rebased to latest changes in Russells tree]
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (29 commits)
of/flattree: forward declare struct device_node in of_fdt.h
ipmi: explicitly include of_address.h and of_irq.h
sparc: explicitly cast negative phandle checks to s32
powerpc/405: Fix missing #{address,size}-cells in i2c node
powerpc/5200: dts: refactor dts files
powerpc/5200: dts: Change combatible strings on localbus
powerpc/5200: dts: remove unused properties
powerpc/5200: dts: rename nodes to prepare for refactoring dts files
of/flattree: Update dtc to current mainline.
of/device: Don't register disabled devices
powerpc/dts: fix syntax bugs in bluestone.dts
of: Fixes for OF probing on little endian systems
of: make drivers depend on CONFIG_OF instead of CONFIG_PPC_OF
of/flattree: Add of_flat_dt_match() helper function
of_serial: explicitly include of_irq.h
of/flattree: Refactor unflatten_device_tree and add fdt_unflatten_tree
of/flattree: Reorder unflatten_dt_node
of/flattree: Refactor unflatten_dt_node
of/flattree: Add non-boottime device tree functions
of/flattree: Add Kconfig for EARLY_FLATTREE
Fix up trivial conflict in arch/sparc/prom/tree_32.c as per Grant.
Remove kobject.h from files which don't need it, notably,
sched.h and fs.h.
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/bug-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/event: validate irq before get evtchn by irq
xen/fb: fix potential memory leak
xen/fb: fix xenfb suspend/resume race.
xen: disable ACPI NUMA for PV guests
xen/irq: Cleanup the find_unbound_irq
* 'stable/generic' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: HVM X2APIC support
apic: Move hypervisor detection of x2apic to hypervisor.h
Xen does not currently expose PV-NUMA information to PV
guests. Therefore disable NUMA for the time being to prevent the
kernel picking up on an host-level NUMA information which it might
come across in the firmware.
[ Added comment - Jeremy ]
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Encoding the cpu family name apparently confuses people when they try to
boot an image on a sub-variant, so encode the specific cpu name and the
silicon rev instead.
When unmasking a GPIO interrupt on a BF54x part, the code will implicitly
ack any pending interrupts. This is not what unmasking should do and can
cause people to miss interrupts from their devices, so punt the code.
Reported-by: Rutger Hofman <rutger@cs.vu.nl>
If there was an error in the lower free functions, we need to pass that
back up so the calling process is able to check things.
Signed-off-by: Andreas Schallenberg <Andreas.Schallenberg@3alitydigital.de>
On bf518-ezbrd with DSA Ethernet switch enabled, on chip MAC is
connecting to phy at address 3. If allowing the netdevice framework to
probe both 3 phys of the switch when registering MAC phy, phy at address
1 is checked for link active status other than phy at address 3. If
connecting a cable to port 2 and leave port 1 open, link status in phy
2 and 3 are online, while that in phy 1 is offline. So, the phy layer
sets wrong offline status to net device on port 3. In this case, no data
can be transferred via ethernet port 2.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Common code now invokes the linker directly which causes build failures
when using an FDPIC toolchain. So move the emulation setting out of the
module-specific LDFLAGS and into the common LDFLAGS.
We check its value at runtime, so we want to avoid garbage across runs.
Signed-off-by: Vivi Li <vivi.li@analog.com>
Otherwise, gdb continue operation after a breakpoint is hit may trap
into endless breakpoint.
When ADEOS and kgdb are both enabled, single step in linux kernel may be
scheduled to Xenomai core after return from interrupt handlers. This
blocks gdb continue operation after a break point is hit. So, disable
interrupt when running gdb single step.
When run kgdb testing, it looks like coreb hangs in single step or trap
exception without handling anomaly 05000257 properly on bf561 v0.5. But,
the anomaly list says it apply to bf561 v0.4 and bellow. Apply its work
around to 0.5 temporarily until the behavior and the root cause can be
confirmed by the hardware team.
The low level assembly needs to use the pseudo_long_call helper so that
we use the right call insn when doing kernel XIP.
KGDB single step in SMP kernel may hang forever in flushinv without a
CSYNC ahead. This is because the core internal write buffers need to
be flushed before invalidating the data cache to make sure the insn
fetch is not out of sync.
The SPORT/UART driver doesn't use the secondary channel pins, so don't
try and request them thus keeping other drivers from using them.
platfrom -> platform
This changes a struct name. The related code is conditionally
compiled and won't work because the include file linux/gpio-decoder.h
is missing, so removing this code would be an even better solution.
If the missing include file is added, it must fix the spelling, too.
Signed-off-by: Stefan Weil <weil@mail.berlios.de>
