path: root/arch
2009-12-07[S390] fault handler performance optimization.Martin Schwidefsky
Slim down the do_exception function to handle only the fast path of a fault and move the exceptional cases into a new function. That slightly increases the performance of the fault handling. Build fix for !CONFIG_COMPAT by Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] Improve notify_page_fault implementation.Martin Schwidefsky
notify_page_fault does a preempt_disable/preempt_enable for each fault generated by a kernel access to user space. If kprobes is not active that is unnecessary since the interrupts are not reenabled yet. To play safe repeat the kprobe_running check after preempt_disable(). Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] Improve address space mode selection.Martin Schwidefsky
Introduce user_mode to replace the two variables switch_amode and s390_noexec. There are three valid combinations of the old values: 1) switch_amode == 0 && s390_noexec == 0 2) switch_amode == 1 && s390_noexec == 0 3) switch_amode == 1 && s390_noexec == 1 They get replaced by 1) user_mode == HOME_SPACE_MODE 2) user_mode == PRIMARY_SPACE_MODE 3) user_mode == SECONDARY_SPACE_MODE The new kernel parameter user_mode=[primary,secondary,home] lets you choose the address space mode the user space processes should use. In addition the CONFIG_S390_SWITCH_AMODE config option is removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] Improve address space check.Martin Schwidefsky
A data access in access-register mode always is a user mode access, the code to inspect the access-registers can be removed. The second change is to use a different test to check for no-execute fault. The third change is to pass the translation exception identification as parameter, in theory the trans_exc_code in the lowcore could have been overwritten by the time the call to check_space from do_no_context is done. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] cio: split PGID settings and statusPeter Oberparleiter
Split setting (driver wants feature enabled) and status (feature setup was successful) for PGID related ccw device features so that setup errors can be detected. Previously, incorrectly handled setup errors could in rare cases lead to erratic I/O behavior and permanently unusuable devices. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] s390: clear high-order bits of registers after sam64Hendrik Brueckner
When the kernel is IPLed without the CLEAR option and switches to 64-bit, the high-order half of the registers might contain random values. This can cause addressing exceptions and the kernel enters an interrupt loop. Initialize the high-order half of the general purpose registers with zeros after switching to 64-bit mode. Cc: <stable@kernel.org> Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-05Merge branch 'x86-debug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Limit number of per cpu TSC sync messages x86: dumpstack, 64-bit: Disable preemption when walking the IRQ/exception stacks x86: dumpstack: Clean up the x86_stack_ids[][] initalization and other details x86, cpu: mv display_cacheinfo -> cpu_detect_cache_sizes x86: Suppress stack overrun message for init_task x86: Fix cpu_devs[] initialization in early_cpu_init() x86: Remove CPU cache size output for non-Intel too x86: Minimise printk spew from per-vendor init code x86: Remove the CPU cache size printk's cpumask: Avoid cpumask_t in arch/x86/kernel/apic/nmi.c x86: Make sure we also print a Code: line for show_regs()
2009-12-05Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, msr, cpumask: Use struct cpumask rather than the deprecated cpumask_t x86, cpuid: Simplify the code in cpuid_open x86, cpuid: Remove the bkl from cpuid_open() x86, msr: Remove the bkl from msr_open() x86: AMD Geode LX optimizations x86, msr: Unify rdmsr_on_cpus/wrmsr_on_cpus
2009-12-05Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Fix a section mismatch in arch/x86/kernel/setup.c x86: Fixup last users of irq_chip->typename x86: Remove BKL from apm_32 x86: Remove BKL from microcode x86: use kernel_stack_pointer() in kprobes.c x86: use kernel_stack_pointer() in kgdb.c x86: use kernel_stack_pointer() in dumpstack.c x86: use kernel_stack_pointer() in process_32.c
2009-12-05Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: include/linux/compiler-gcc4.h: Fix build bug - gcc-4.0.2 doesn't understand __builtin_object_size x86/alternatives: No need for alternatives-asm.h to re-invent stuff already in asm.h x86/alternatives: Check replacementlen <= instrlen at build time x86, 64-bit: Set data segments to null after switching to 64-bit mode x86: Clean up the loadsegment() macro x86: Optimize loadsegment() x86: Add missing might_fault() checks to copy_{to,from}_user() x86-64: __copy_from_user_inatomic() adjustments x86: Remove unused thread_return label from switch_to() x86, 64-bit: Fix bstep_iret jump x86: Don't use the strict copy checks when branch profiling is in use x86, 64-bit: Move K8 B step iret fixup to fault entry asm x86: Generate cmpxchg build failures x86: Add a Kconfig option to turn the copy_from_user warnings into errors x86: Turn the copy_from_user check into an (optional) compile time warning x86: Use __builtin_memset and __builtin_memcpy for memset/memcpy x86: Use __builtin_object_size() to validate the buffer size for copy_from_user()
2009-12-05Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits) x86, apic: Enable lapic nmi watchdog on AMD Family 11h x86: Remove unnecessary mdelay() from cpu_disable_common() x86, ioapic: Document another case when level irq is seen as an edge x86, ioapic: Fix the EOI register detection mechanism x86, io-apic: Move the effort of clearing remoteIRR explicitly before migrating the irq x86: SGI UV: Map low MMR ranges x86: apic: Print out SRAT table APIC id in hex x86: Re-get cfg_new in case reuse/move irq_desc x86: apic: Remove not needed #ifdef x86: io-apic: IO-APIC MMIO should not fail on resource insertion x86: Remove asm/apicnum.h x86: apic: Do not use stacked physid_mask_t x86, apic: Get rid of apicid_to_cpu_present assign on 64-bit x86, ioapic: Use snrpintf while set names for IO-APIC resourses x86, apic: Use PAGE_SIZE instead of numbers x86: Remove local_irq_enable()/local_irq_disable() in fixup_irqs() x86: Use EOI register in io-apic on intel platforms x86: Force irq complete move during cpu offline x86: Remove move_cleanup_count from irq_cfg x86, intr-remap: Avoid irq_chip mask/unmask in fixup_irqs() for intr-remapping ...
2009-12-05Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (470 commits) x86: Fix comments of register/stack access functions perf tools: Replace %m with %a in sscanf hw-breakpoints: Keep track of user disabled breakpoints tracing/syscalls: Make syscall events print callbacks static tracing: Add DEFINE_EVENT(), DEFINE_SINGLE_EVENT() support to docbook perf: Don't free perf_mmap_data until work has been done perf_event: Fix compile error perf tools: Fix _GNU_SOURCE macro related strndup() build error trace_syscalls: Remove unused syscall_name_to_nr() trace_syscalls: Simplify syscall profile trace_syscalls: Remove duplicate init_enter_##sname() trace_syscalls: Add syscall_nr field to struct syscall_metadata trace_syscalls: Remove enter_id exit_id trace_syscalls: Set event_enter_##sname->data to its metadata trace_syscalls: Remove unused event_syscall_enter and event_syscall_exit perf_event: Initialize data.period in perf_swevent_hrtimer() perf probe: Simplify event naming perf probe: Add --list option for listing current probe events perf probe: Add argv_split() from lib/argv_split.c perf probe: Move probe event utility functions to probe-event.c ...
2009-12-05Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (40 commits) tracing: Separate raw syscall from syscall tracer ring-buffer-benchmark: Add parameters to set produce/consumer priorities tracing, function tracer: Clean up strstrip() usage ring-buffer benchmark: Run producer/consumer threads at nice +19 tracing: Remove the stale include/trace/power.h tracing: Only print objcopy version warning once from recordmcount tracing: Prevent build warning: 'ftrace_graph_buf' defined but not used ring-buffer: Move access to commit_page up into function used tracing: do not disable interrupts for trace_clock_local ring-buffer: Add multiple iterations between benchmark timestamps kprobes: Sanitize struct kretprobe_instance allocations tracing: Fix to use __always_unused attribute compiler: Introduce __always_unused tracing: Exit with error if a weak function is used in recordmcount.pl tracing: Move conditional into update_funcs() in recordmcount.pl tracing: Add regex for weak functions in recordmcount.pl tracing: Move mcount section search to front of loop in recordmcount.pl tracing: Fix objcopy revision check in recordmcount.pl tracing: Check absolute path of input file in recordmcount.pl tracing: Correct the check for number of arguments in recordmcount.pl ...
2009-12-05Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mutex: Fix missing conditions to build mutex_spin_on_owner() mutex: Better control mutex adaptive spinning config locking, task_struct: Reduce size on TRACE_IRQFLAGS and 64bit locking: Use __[SPIN|RW]_LOCK_UNLOCKED in [spin|rw]_lock_init() locking: Remove unused prototype locking: Reduce ifdefs in kernel/spinlock.c locking: Make inlining decision Kconfig based
2009-12-05Merge branch 'core-iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits) x86, Calgary IOMMU quirk: Find nearest matching Calgary while walking up the PCI tree x86/amd-iommu: Remove amd_iommu_pd_table x86/amd-iommu: Move reset_iommu_command_buffer out of locked code x86/amd-iommu: Cleanup DTE flushing code x86/amd-iommu: Introduce iommu_flush_device() function x86/amd-iommu: Cleanup attach/detach_device code x86/amd-iommu: Keep devices per domain in a list x86/amd-iommu: Add device bind reference counting x86/amd-iommu: Use dev->arch->iommu to store iommu related information x86/amd-iommu: Remove support for domain sharing x86/amd-iommu: Rearrange dma_ops related functions x86/amd-iommu: Move some pte allocation functions in the right section x86/amd-iommu: Remove iommu parameter from dma_ops_domain_alloc x86/amd-iommu: Use get_device_id and check_device where appropriate x86/amd-iommu: Move find_protection_domain to helper functions x86/amd-iommu: Simplify get_device_resources() x86/amd-iommu: Let domain_for_device handle aliases x86/amd-iommu: Remove iommu specific handling from dma_ops path x86/amd-iommu: Remove iommu parameter from __(un)map_single x86/amd-iommu: Make alloc_new_range aware of multiple IOMMUs ...
2009-12-05avr32: Convert BUG() to use unreachable()David Daney
Use the new unreachable() macro instead of for(;;); Signed-off-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-05s390: Convert BUG() to use unreachable()David Daney
Use the new unreachable() macro instead of for(;;); Signed-off-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> CC: Heiko Carstens <heiko.carstens@de.ibm.com> CC: linux390@de.ibm.com CC: linux-s390@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-05MIPS: Convert BUG() to use unreachable()David Daney
Use the new unreachable() macro instead of while(1); Signed-off-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> CC: linux-mips@linux-mips.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-05x86: Convert BUG() to use unreachable()David Daney
Use the new unreachable() macro instead of for(;;);. When allyesconfig is built with a GCC-4.5 snapshot on i686 the size of the text segment is reduced by 3987 bytes (from 6827019 to 6823032). Signed-off-by: David Daney <ddaney@caviumnetworks.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> CC: Thomas Gleixner <tglx@linutronix.de> CC: Ingo Molnar <mingo@redhat.com> CC: x86@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-03Merge branch 'perf/probes' into perf/coreIngo Molnar
Merge reason: add these fixes to 'perf probe'. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-03Merge branch 'perf/mce' into perf/coreIngo Molnar
Merge reason: It's ready for v2.6.33. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-03x86, apic: Enable lapic nmi watchdog on AMD Family 11hMikael Pettersson
The x86 lapic nmi watchdog does not recognize AMD Family 11h, resulting in: NMI watchdog: CPU not supported As far as I can see from available documentation (the BKDM), family 11h looks identical to family 10h as far as the PMU is concerned. Extending the check to accept family 11h results in: Testing NMI watchdog ... OK. I've been running with this change on a Turion X2 Ultra ZM-82 laptop for a couple of weeks now without problems. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: <stable@kernel.org> LKML-Reference: <19223.53436.931768.278021@pilspetsen.it.uu.se> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-03x86, Calgary IOMMU quirk: Find nearest matching Calgary while walking up the ↵Darrick J. Wong
PCI tree On a multi-node x3950M2 system, there's a slight oddity in the PCI device tree for all secondary nodes: 30:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) \-33:00.0 PCI bridge: IBM CalIOC2 PCI-E Root Port (rev 01) \-34:00.0 RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS 1078 (rev 04) ...as compared to the primary node: 00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) \-01:00.0 VGA compatible controller: ATI Technologies Inc ES1000 (rev 02) 03:00.0 PCI bridge: IBM CalIOC2 PCI-E Root Port (rev 01) \-04:00.0 RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS 1078 (rev 04) In both nodes, the LSI RAID controller hangs off a CalIOC2 device, but on the secondary nodes, the BIOS hides the VGA device and substitutes the device tree ending with the disk controller. It would seem that Calgary devices don't necessarily appear at the top of the PCI tree, which means that the current code to find the Calgary IOMMU that goes with a particular device is buggy. Rather than walk all the way to the top of the PCI device tree and try to match bus number with Calgary descriptor, the code needs to examine each parent of the particular device; if it encounters a Calgary with a matching bus number, simply use that. Otherwise, we BUG() when the bus number of the Calgary doesn't match the bus number of whatever's at the top of the device tree. Extra note: This patch appears to work correctly for the x3950 that came before the x3950 M2. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Jon D. Mason <jdmason@kudzu.us> Cc: Corinna Schultz <coschult@us.ibm.com> Cc: <stable@kernel.org> LKML-Reference: <20091202230556.GG10295@tux1.beaverton.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-02MIPS: RB532: Fix devices.c compilation.Florian Fainelli
We should now use dev_set_drvdata to set the driver driver_data field. Signed-off-by: Florian Fainelli <florian@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/747/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-02MIPS: Fix MIPS I build.Ralf Baechle
Broken by d63c63e889bbeeaa461a8addf1245f89f3ce4ece (lmo) rsp. f1e39a4a616cd9981a9decfd5332fd07a01abb8b (kernel.org). Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/746/
2009-12-02x86/alternatives: No need for alternatives-asm.h to re-invent stuff already ↵Jan Beulich
in asm.h This at once also gets the alignment specification right for x86-64. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <4B0FF8F80200007800022708@vpn.id2.novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-02x86/alternatives: Check replacementlen <= instrlen at build timeJan Beulich
Having run into the run-(boot-)time check a couple of times lately, I finally took time to find a build-time check so that one doesn't need to analyze the register/stack dump and resolve this (through manual lookup in vmlinux) to the offending construct. The assembler will emit a message like "Error: value of <num> too large for field of 1 bytes at <offset>", which while not pointing out the source location still makes analysis quite a bit easier. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <4B0FF8AA0200007800022703@vpn.id2.novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-02x86: Fix comments of register/stack access functionsMasami Hiramatsu
Fix typos and some redundant comments of register/stack access functions in asm/ptrace.h. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Wenji Huang <wenji.huang@oracle.com> Cc: Mahesh J Salgaonkar <mahesh@linux.vnet.ibm.com> LKML-Reference: <20091201000222.7669.7477.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu> Suggested-by: Wenji Huang <wenji.huang@oracle.com>
2009-12-02x86: Remove unnecessary mdelay() from cpu_disable_common()Suresh Siddha
fixup_irqs() already has a mdelay(). Remove the extra and unnecessary mdelay() from cpu_disable_common(). Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: ebiederm@xmission.com Cc: garyhade@us.ibm.com LKML-Reference: <20091201233335.232177348@sbs-t61.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-02x86, ioapic: Document another case when level irq is seen as an edgeSuresh Siddha
In the case when cpu goes offline, fixup_irqs() will forward any unhandled interrupt on the offlined cpu to the new cpu destination that is handling the corresponding interrupt. This interrupt forwarding is done via IPI's. Hence, in this case also level-triggered io-apic interrupt will be seen as an edge interrupt in the cpu's APIC IRR. Document this scenario in the code which handles this case by doing an explicit EOI to the io-apic to clear remote IRR of the io-apic RTE. Requested-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: ebiederm@xmission.com Cc: garyhade@us.ibm.com LKML-Reference: <20091201233335.143970505@sbs-t61.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-02x86, ioapic: Fix the EOI register detection mechanismSuresh Siddha
Maciej W. Rozycki reported: > 82093AA I/O APIC has its version set to 0x11 and it > does not support the EOI register. Similarly I/O APICs > integrated into the 82379AB south bridge and the 82374EB/SB > EISA component. IO-APIC versions below 0x20 don't support EOI register. Some of the Intel ICH Specs (ICH2 to ICH5) documents the io-apic version as 0x2. This is an error with documentation and these ICH chips use io-apic's of version 0x20 and indeed has a working EOI register for the io-apic. Fix the EOI register detection mechanism to check for version 0x20 and beyond. And also, a platform can potentially have io-apic's with different versions. Make the EOI register check per io-apic. Reported-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: ebiederm@xmission.com Cc: garyhade@us.ibm.com LKML-Reference: <20091201233335.065361533@sbs-t61.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-02x86, io-apic: Move the effort of clearing remoteIRR explicitly before ↵Maciej W. Rozycki
migrating the irq When the level-triggered interrupt is seen as an edge interrupt, we try to clear the remoteIRR explicitly (using either an io-apic eoi register when present or through the idea of changing trigger mode of the io-apic RTE to edge and then back to level). But this explicit try also needs to happen before we try to migrate the irq. Otherwise irq migration attempt will fail anyhow, as it postpones the irq migration to a later attempt when it sees the remoteIRR in the io-apic RTE still set. Signed-off-by: "Maciej W. Rozycki" <macro@linux-mips.org> Reviewed-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: ebiederm@xmission.com Cc: garyhade@us.ibm.com LKML-Reference: <20091201233334.975416130@sbs-t61.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-02hw-breakpoints: Keep track of user disabled breakpointsFrederic Weisbecker
When we disable a breakpoint through dr7, we unregister it right away, making us lose track of its corresponding address register value. It means that the following sequence would be unsupported: - set address in dr0 - enable it through dr7 - disable it through dr7 - enable it through dr7 because we lost the address register value when we disabled the breakpoint. Don't unregister the disabled breakpoints but rather disable them. Reported-by: "K.Prasad" <prasad@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1259735536-9236-1-git-send-regression-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-01Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: MIPS: Loongson: Switch from flatmem to sparsemem MIPS: Loongson: Disallow 4kB pages MIPS: Add missing definition for MADV_HWPOISON. MIPS: Fix build error if __xchg() is not getting inlined. MIPS: IP22/IP28 Disable early printk to fix boot problems on some systems.
2009-12-01MIPS: Loongson: Switch from flatmem to sparsememWu Zhangjin
With flatmem hibernation for Loongson will fail, and there are also some other problems such as broken files when using NFS or CIFS / Samba. The config help of sparsemem says: "This option provides some potential performance benefits, along with decreased code complexity." So to avoid the potential problems of FLATMEM, we disable FLATMEM directly and use SPARSEMEM instead. Related email thread: http://groups.google.com/group/loongson-dev/browse_thread/thread/b6b65890ec2b0f24/feb43e5aa7f55d9b?show_docid=feb43e5aa7f55d9b Reported-by: Tatu Kilappa <tatu.kilappa@gmail.com> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Patchwork: http://patchwork.linux-mips.org/patch/737/ Cc: linux-mips@linux-mips.org Cc: zhangfx@lemote.com Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-01MIPS: Loongson: Disallow 4kB pagesWu Zhangjin
Currently, with PAGE_SIZE_4KB, the kernel for loongson will hang on: Kernel panic - not syncing: Attempted to kill init! The possible reason is the cache aliases problem: Loongson 2F has 64kb, 4 way L1 Cache, the way size is 16kb, which is bigger then 4kb. so, If using 4kb page size, there is cache aliases problem. To avoid this kind of problem, extra cache flushing. The 2nd possible solution is 16kb page size which avoids cache aliases without the need for extra cache flushes. So we disable 4kB pages until the aliasing issue is solved. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Patchwork: http://patchwork.linux-mips.org/patch/736/ Cc: linux-mips@linux-mips.org Cc: zhangfx@lemote.com Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-01MIPS: Add missing definition for MADV_HWPOISON.Ralf Baechle
Thanks to Joseph S. Myers for reporting this. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: "Joseph S. Myers" <joseph@codesourcery.com> Patchwork: http://patchwork.linux-mips.org/patch/723/
2009-12-01MIPS: Fix build error if __xchg() is not getting inlined.Ralf Baechle
If __xchg() is not getting inlined the outline version of the function will have a reference to __xchg_called_with_bad_pointer() which does not exist remaining. Fixed by using BUILD_BUG_ON() to check for allowable operand sizes. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/705/
2009-12-01MIPS: IP22/IP28 Disable early printk to fix boot problems on some systems.Martin Michlmayr
Some Debian users have reported that the kernel hangs early during boot on some IP22 systems. Thomas Bogendoerfer found that this is due to a "bad interaction between CONFIG_EARLY_PRINTK and overwritten prom memory during early boot". Since there's no fix yet, disable CONFIG_EARLY_PRINTK for now. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Cc: linux-mips@linux-mips.org Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Patchwork: http://patchwork.linux-mips.org/patch/702/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mattst88/alpha-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mattst88/alpha-2.6: alpha: Fixup last users of irq_chip->typename Alpha: Rearrange thread info flags fixing two regressions arch/alpha/kernel: Add kmalloc NULL tests arch/alpha/kernel/sys_ruffian.c: Use DIV_ROUND_CLOSEST
2009-11-30alpha: Fixup last users of irq_chip->typenameThomas Gleixner
The typename member of struct irq_chip was kept for migration purposes and is obsolete since more than 2 years. Fix up the leftovers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Henderson <rth@twiddle.net> Cc: linux-alpha@vger.kernel.org Signed-off-by: Matt Turner <mattst88@gmail.com>
2009-11-30Alpha: Rearrange thread info flags fixing two regressionsMichael Cree
The removal of the TIF_NOTIFY_RESUME flag, commit a583f1b54249b "remove unused TIF_NOTIFY_RESUME flag," resulted in incorrect setting of the unaligned access control flags by the prctl syscall. The re-addition of the TIF_NOTIFY_RESUME flag, commit d0420c83f39f "KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures [try #6]" further caused problems, namely incorrect operands to assembler code as evidenced by: AS arch/alpha/kernel/entry.o arch/alpha/kernel/entry.S: Assembler messages: arch/alpha/kernel/entry.S:326: Warning: operand out of range (0x0000000000000406 is not between 0x0000000000000000 and 0x00000000000000ff) Both regressions fixed by (1) rearranging TIF_NOTIFY_RESUME flag to be in lower 8 bits of the thread info flags, and (2) making sure that ALPHA_UAC_SHIFT matches the rearrangement of the thread info flags. Signed-off-by: Michael Cree <mcree@orcon.net.nz> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: David Howells <dhowells@redhat.com>, Signed-off-by: Matt Turner <mattst88@gmail.com>
2009-11-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: Blackfin: fix SMP build error in start_thread() Blackfin: fix memset in smp_send_reschedule() and -stop() Blackfin: fix typo in ptrace poking Blackfin: check for anomaly 05000475 Blackfin: work around testset anomaly 05000477 Blackfin: update anomaly lists Blackfin: fix cache Kconfig typo Blackfin: fix suspend/resume failure with some on-chip ROMs
2009-11-30Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] Update mach-types ARM: 5793/1: ARM: Check put_user fail in do_signal when enable OABI_COMPAT MAINTAINERS: add maintainer information for AMBA primecell drivers [ARM] pxa/spitz: fix compile regression on spitz ARM: PNX4008: i2c-pnx: use the same dev_id for request_irq and free_irq [ARM] pxa/cpufreq: fix index assignments for end marker ARM: PNX4008: fix watchdog device driver name [ARM] kmap: fix build errors with DEBUG_HIGHMEM enabled
2009-11-30Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Fix DEBUG_HIGHMEM build break from d4515646699
2009-12-01powerpc: Fix DEBUG_HIGHMEM build break from d4515646699Becky Bruce
Code was added to mm/higmem.c that depends on several kmap types that powerpc does not support. We add dummy invalid definitions for KM_NMI, KM_NM_PTE, and KM_IRQ_PTE. According to list discussion, this fix should not be needed anymore starting with 2.6.33. The code is commented to this effect so hopefully we will remember to remove this. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-11-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sunsu: Use sunserial_console_termios() in sunsu_console_setup(). sunsu: Pass true 'ignore_line' to console match when RSC or LOM console. serial: suncore: Fix RSC/LOM handling in sunserial_console_termios(). serial: suncore: Add 'ignore_line' argument to sunserial_console_match(). sunsu: Fix detection of SU ports which are RSC console or control. sunsab: Do not set sunsab_reg.cons right before registering minors. sparc64: Fix definition of VMEMMAP_SIZE.
2009-11-30Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Enable ACPI PDC handshake for VIA/Centaur CPUs
2009-11-30arch/alpha/kernel: Add kmalloc NULL testsJulia Lawall
Check that the result of kmalloc is not NULL before passing it to other functions. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression *x; identifier f; constant char *C; @@ x = \(kmalloc\|kcalloc\|kzalloc\)(...); ... when != x == NULL when != x != NULL when != (x || ...) ( kfree(x) f(...,C,...,x,...) | *f(...,x,...) | *x->f ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Matt Turner <mattst88@gmail.com>
2009-11-30arch/alpha/kernel/sys_ruffian.c: Use DIV_ROUND_CLOSESTJulia Lawall
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d but is perhaps more readable. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @haskernel@ @@ @depends on haskernel@ expression x,__divisor; @@ - (((x) + ((__divisor) / 2)) / (__divisor)) + DIV_ROUND_CLOSEST(x,__divisor) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Matt Turner <mattst88@gmail.com>
