A zero value for prot_sect in the memory types table implies that
section mappings should never be created for the memory type in question.
This is checked for in alloc_init_section().
With LPAE, we set a bit to mask access flag faults for kernel mappings.
This breaks the aforementioned (!prot_sect) check in alloc_init_section().
This patch fixes this bug by first checking for a non-zero
prot_sect before setting the PMD_SECT_AF flag.
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: <stable@vger.kernel.org>
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
The vfp_enable function enables access to the VFP co-processor register
space (cp10 and cp11) on the current CPU and must be called with
preemption disabled. Unfortunately, the vfp_init late initcall does not
disable preemption and can lead to an oops during boot if thread
migration occurs at the wrong time and we end up attempting to access
the FPSID on a CPU with VFP access disabled.
This patch fixes the initcall to call vfp_enable from a non-preemptible
context on each CPU and adds a BUG_ON(preemptible) to ensure that any
similar problems are easily spotted in the future.
Cc: stable@vger.kernel.org
Reported-by: Hyungwoo Yang <hwoo.yang@gmail.com>
Signed-off-by: Hyungwoo Yang <hyungwooy@nvidia.com>
Commit 4e8ee7de227e3ab9a72040b448ad728c5428a042 (ARM: SMP: use
idmap_pgd for mapping MMU enable during secondary booting)
switched secondary boot to use idmap_pgd, which is initialized
during early_initcall, instead of a page table initialized during
__cpu_up. This causes idmap_pgd to contain the static mappings
but be missing all dynamic mappings.
If a console is registered that creates a dynamic mapping, the
printk in secondary_start_kernel will trigger a data abort on
the missing mapping before the exception handlers have been
initialized, leading to a hang. Initial boot is not affected
because no consoles have been registered, and resume is usually
not affected because the offending console is suspended.
Onlining a cpu with hotplug triggers the problem.
A workaround is to the printk in secondary_start_kernel until
after the page tables have been switched back to init_mm.
Signed-off-by: Colin Cross <ccross@android.com>
The machine endianness has no direct correspondence to the syscall ABI,
so use only AUDIT_ARCH_ARM when identifying the ABI to the audit tools
in userspace.
The ARM audit code incorrectly uses the saved application ip register
value to infer syscall entry or exit. Additionally, the saved value will
be clobbered if the current task is not being traced, which can lead to
libc corruption if ip is live (apparently glibc uses it for the TLS
pointer).
This patch fixes the syscall tracing code so that the why parameter is
used to infer the syscall direction and the saved ip is only updated if
we know that we will be signalling a ptrace trap.
Reported-and-Tested-by: Jon Masters <jcm@jonmasters.org>
Cc: Eric Paris <eparis@redhat.com>
The inline assembly in kernel_execve() uses r8 and r9. Since this
code sequence does not return, it usually doesn't matter if the
register clobber list is accurate. However, I saw a case where a
particular version of gcc used r8 as an intermediate for the value
eventually passed to r9. Because r8 is used in the inline
assembly, and not mentioned in the clobber list, r9 was set
to an incorrect value.
This resulted in a kernel panic on execution of the first user-space
program in the system. r9 is used in ret_to_user as the thread_info
pointer, and if it's wrong, bad things happen.
Signed-off-by: Tim Bird <tim.bird@am.sony.com>
Pull ARM fixes from Russell King.
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7406/1: hotplug: copy the affinity mask when forcefully migrating IRQs
ARM: 7405/1: kexec: call platform_cpu_kill on the killer rather than the victim
ARM: 7403/1: tls: remove covert channel via TPIDRURW
ARM: 7401/1: mm: Fix section mismatches
ARM: OMAP: fix DMA vs memory ordering
ARM: 7390/1: dts: versatile-pb/ab fix MMC IRQs
ARM: 7400/1: vfp: clear fpscr length and stride bits on entry to sig handler
ARM: 7399/1: vfp: move user vfp state save/restore code out of signal.c
ARM: 7398/1: l2x0: only write to debug registers on PL310
ARM: 7397/1: l2x0: only apply workaround for erratum #753970 on PL310
ARM: 7396/1: errata: only handle ARM erratum #326103 on affected cores
Recently, Ryan Wang tried to compile PPC pSeries platform without
CONFIG_EEH and eventually run into errors. Nishanth Aravamudan
helped to narrow down the root cause. Actually, the pSeries platform
depends on CONFIG_EEH heavily and that won't work properly without
EEH support.
According to Ben's suggestion, the patch make CONFIG_EEH invisible
and keep it as always selected on pSeries platform.
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
The switch from using irq_map to irq_alloc_desc*() for managing irq
number allocations introduced new bugs in some of the powerpc
interrupt code. Several functions rely on the value of NR_IRQS to
determine the maximum irq number that could get allocated. However,
with sparse_irq and using irq_alloc_desc*() the maximum possible irq
number is now specified with 'nr_irqs' which may be a number larger
than NR_IRQS. This has caused breakage on powermac when
CONFIG_NR_IRQS is set to 32.
This patch removes most of the direct references to NR_IRQS in the
powerpc code and replaces them with either a nr_irqs reference or by
using the common for_each_irq_desc() macro. The powerpc-specific
for_each_irq() macro is removed at the same time.
Also, the Cell axon_msi driver is refactored to remove the global
build assumption on the size of NR_IRQS and instead add a limit to the
maximum irq number when calling irq_domain_add_nomap().
The mpc8xx driver uses a reference to NR_IRQS that is buggy. It uses
NR_IRQs for the array size of the ppc_cached_irq_mask bitmap, but
NR_IRQs could be smaller than the number of hardware irqs that
ppc_cached_irq_mask tracks.
Also, while fixing that problem, it became apparent that the interrupt
controller only supports 32 interrupt numbers, but it is written as if
it supports multiple register banks which is more complicated.
This patch pulls out the buggy reference to NR_IRQs and fixes the size
of the ppc_cached_irq_mask to match the number of HW irqs. It also
drops the now-unnecessary code since ppc_cached_irq_mask is no longer
an array.
Pull ARM SoC fixes from Olof Johansson:
"Nothing controversial, just another batch of fixes:
- Samsung/exynos fixes for more merge window fallout: build errors
and warnings mostly, but also some clock/device setup issues on
exynos4/5
- PXA bug and warning fixes related to gpio and pinmux
- IRQ domain conversion bugfixes for U300 and MSM
- A regulator setup fix for U300"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: PXA2xx: MFP: fix potential direction bug
ARM: PXA2xx: MFP: fix bug with MFP_LPM_KEEP_OUTPUT
arm/sa1100: fix sa1100-rtc memory resource
ARM: pxa: fix gpio wakeup setting
ARM: SAMSUNG: add missing MMC_CAP2_BROKEN_VOLTAGE capability
ARM: EXYNOS: Fix compilation error when CONFIG_OF is not defined
ARM: EXYNOS: Fix resource on dev-dwmci.c
ARM: S3C24XX: Fix build warning for S3C2410_PM
ARM: mini2440_defconfig: Fix build error
ARM: msm: Fix gic irqdomain support
ARM: EXYNOS: Fix incorrect initialization of GIC
ARM: EXYNOS: use 'exynos4-sdhci' as device name for sdhci controllers
ARM: u300: bump all IRQ numbers by one
ARM: ux300: Fix unimplementable regulation constraints
When a CPU is hotplugged off, we migrate any IRQs currently affine to it
away and onto another online CPU by calling the irq_set_affinity
function of the relevant interrupt controller chip. This function
returns either IRQ_SET_MASK_OK or IRQ_SET_MASK_OK_NOCOPY, to indicate
whether irq_data.affinity was updated.
If we are forcefully migrating an interrupt (because the affinity mask
no longer identifies any online CPUs) then we should update the IRQ
affinity mask to reflect the new CPU set. Failure to do so can
potentially leave /proc/irq/n/smp_affinity identifying only offline
CPUs, which may confuse userspace IRQ balancing daemons.
This patch updates migrate_one_irq to copy the affinity mask when
the interrupt chip returns IRQ_SET_MASK_OK after forcefully changing the
affinity of an interrupt.
Reported-by: Leif Lindholm <leif.lindholm@arm.com>
When performing a kexec on an SMP system, the secondary cores are stopped
by calling machine_shutdown(), which in turn issues IPIs to offline the
other CPUs. Unfortunately, this isn't enough to reboot the cores into
a new kernel (since they are just executing a cpu_relax loop somewhere
in memory) so we make use of platform_cpu_kill, part of the CPU hotplug
implementation, to place the cores somewhere safe. This function expects
to be called on the killing CPU for each core that it takes out.
This patch moves the platform_cpu_kill callback out of the IPI handler
and into smp_send_stop, therefore ensuring that it executes on the
killing CPU rather than on the victim, matching what the hotplug code
requires.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
TPIDRURW is a user read/write register forming part of the group of
thread registers in more recent versions of the ARM architecture (~v6+).
Currently, the kernel does not touch this register, which allows tasks
to communicate covertly by reading and writing to the register without
context-switching affecting its contents.
This patch clears TPIDRURW when TPIDRURO is updated via the set_tls
macro, which is called directly from __switch_to. Since the current
behaviour makes the register useless to userspace as far as thread
pointers are concerned, simply clearing the register (rather than saving
and restoring it) will not cause any problems to userspace.
WARNING: vmlinux.o(.text+0x111b8): Section mismatch in reference
from the function arm_memory_present() to the function
.init.text:memory_present()
The function arm_memory_present() references
the function __init memory_present().
This is often because arm_memory_present lacks a __init
annotation or the annotation of memory_present is wrong.
WARNING: arch/arm/mm/built-in.o(.text+0x1edc): Section mismatch
in reference from the function alloc_init_pud() to the function
.init.text:alloc_init_section()
The function alloc_init_pud() references
the function __init alloc_init_section().
This is often because alloc_init_pud lacks a __init
annotation or the annotation of alloc_init_section is wrong.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
Pull Xen fixes from Konrad Rzeszutek Wilk:
"Some of these had been in existence since the 2.6.27 days, some since
3.0 - and some due to new features added in v3.4.
The one that is most interesting is David's one - in the low-level
assembler code we had be checking events needlessly. With his patch
now we do it when the appropriate flag is set - with the added benefit
that we can process events faster. Stefano's is fixing a mistake
where the Linux IRQ numbers were ACK-ed instead of the Xen IRQ,
resulting in missing interrupts. The other ones are bootup related
that can show up on various hardware."
- In the low-level assembler code we would jump to check events even if
none were present. This incorrect behavior had been there since
2.6.27 days!
- When using the fast-path for ACK-ing interrupts we were using the
Linux IRQ numbers instead of the Xen ones (and they can differ) and
missing interrupts in process.
- Fix bootup crashes when ACPI hotplug CPUs were present and they would
expand past the set number of CPUs we were allocated.
- Deal with broken BIOSes when uploading C-states to the hypervisor.
- Disable the cpuid check for MWAIT_LEAF if the ACPI PAD driver is
loaded. If the ACPI PAD driver is used it will crash, so lets not
export the functionality so the ACPI PAD driver won't load.
* tag 'stable/for-linus-3.4-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: correctly check for pending events when restoring irq flags
xen/acpi: Workaround broken BIOSes exporting non-existing C-states.
xen/smp: Fix crash when booting with ACPI hotplug CPUs.
xen: use the pirq number to check the pirq_eoi_map
xen/enlighten: Disable MWAIT_LEAF so that acpi-pad won't be loaded.
Pull x86 fixes from Ingo Molnar.
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/apic: Use x2apic physical mode based on FADT setting
x86/mrst: Quiet sparse noise about plain integer as NULL pointer
x86, intel_cacheinfo: Fix error return code in amd_set_l3_disable_slot()
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull build fixes for less mainstream architectures from Paul Gortmaker:
"These are fixes for frv(1), blackfin(2), powerpc(1) and xtensa(4).
Fortunately the touches are nearly all specific to files just used by
the arch in question. The two touches to shared/common files
[kernel/irq/debug.h and drivers/pci/Makefile] are trivial to assess as
no risk to anyone.
Half of them relate to xtensa directly. It was only when I fixed the
last xtensa issue that I realized that the arch has been broken for a
significant time, and isn't a specific v3.4 regression. So if you
wanted, we could leave xtensa lying bleeding in the street for a
couple more weeks and queue those for 3.5. But given they are no risk
to anyone outside of xtensa, I figured to just leave them in.
If you are OK with taking the xtensa fixes, then please pull to get:
- one last implicit include uncovered by system.h that is in a file
specific to just one powerpc defconfig. (I'd sync'd with BenH).
- fix an oversight in the PCI makefile where shared code wasn't being
compiled for ARCH=frv
- fix a missing include for GPIO in blackfin framebuffer.
- audit and tag endif in blackfin ezkit board file, in order to find
and fix the misplaced endif masking a block of code.
- fix irq/debug.h choice of temporary macro names to be more internal
so they don't conflict with names used by xtensa.
- fix a reference to an undeclared local var in xtensa's signal.c
- fix an implicit bug.h usage in xtensa's asm/io.h uncovered by my
removing bug.h from kernel.h
- fix xtensa to properly indicate it is using asm-generic/hardirq.h
in order to resolve the link error - undefined ack_bad_irq
The xtensa still fails final link as my latest binutils does something
evil when ld forward-relocates unlikely() blocks, but in theory people
who have older/valid toolchains could now use the thing."
* 'for-v3.4-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
xtensa: fix build fail on undefined ack_bad_irq
blackfin: fix ifdef fustercluck in mach-bf538/boards/ezkit.c
blackfin: fix compile error in bfin-lq035q1-fb.c
pci: frv architecture needs generic setup-bus infrastructure
irq: hide debug macros so they don't collide with others.
xtensa: fix build error in xtensa/include/asm/io.h
xtensa: fix build failure in xtensa/kernel/signal.c
powerpc: fix system.h fallout in sysdev/scom.c [chroma_defconfig]
In xen_restore_fl_direct(), xen_force_evtchn_callback() was being
called even if no events were pending. This resulted in (depending on
workload) about a 100 times as many xen_version hypercalls as
necessary.
Fix this by correcting the sense of the conditional jump.
This seems to give a significant performance benefit for some
workloads.
There is some subtle tricksy "..since the check here is trying to
check both pending and masked in a single cmpw, but I think this is
correct. It will call check_events now only when the combined
mask+pending word is 0x0001 (aka unmasked, pending)." (Ian)
CC: stable@kernel.org
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes
* 'v3.4-samsung-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
* 'fixes' of git://github.com/hzhuang1/linux:
Pins configured as input and have MFP_LPM_DRIVE_* flag set, can have a
wrong output value for some period of time (spike) during the suspend
sequence.
This can happen because the direction of the pins (GPDR) is set by
software and the output level is set by hardware (PGSR) at a later
stage.
Fix the above potential bug by setting the output levels first.
Also save the actual levels of the pins before the suspend and restore
them after the resume, but before the direction settings take place, so
the same bug as described above will not happen in the resume sequence.
Reported-by: Paul Parsons <lost.distance@yahoo.com>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Tested-by: Paul Parsons <lost.distance@yahoo.com>
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Pins that have MFP_LPM_KEEP_OUTPUT set and are configured for output
must retain the output state in low power mode.
Currently, the pin direction configuration is overrided with values
in gpdr_lpm[] array and do not obey the MFP_LPM_KEEP_OUTPUT setting.
Fix the above bug and add some documentation to clarify the
MFP_LPM_KEEP_OUTPUT setting purpose.
DEFINE_RES_MEM() takes the size of resource as a second argument,
not the end address. Passing end address leads to following error
in runtime during device registration:
sa1100-rtc: failed to claim resource 0
Fix it.
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
In 3.3, gpio wakeup setting was broken. The call
enable_irq_wake() didn't set up the PXA gpio registers
(PWER, ...) anymore.
Fix it at least for pxa27x. The driver doesn't seem to be
used in pxa25x (weird ...), and the fix doesn't extend to
pxa3xx and pxa95x (which don't have a gpio_set_wake()
available).
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
When we boot on a machine that can hotplug CPUs and we
are using 'dom0_max_vcpus=X' on the Xen hypervisor line
to clip the amount of CPUs available to the initial domain,
we get this:
(XEN) Command line: com1=115200,8n1 dom0_mem=8G noreboot dom0_max_vcpus=8 sync_console mce_verbosity=verbose console=com1,vga loglvl=all guest_loglvl=all
.. snip..
DMI: Intel Corporation S2600CP/S2600CP, BIOS SE5C600.86B.99.99.x032.072520111118 07/25/2011
.. snip.
SMP: Allowing 64 CPUs, 32 hotplug CPUs
installing Xen timer for CPU 7
cpu 7 spinlock event irq 361
NMI watchdog: disabled (cpu7): hardware events not enabled
Brought up 8 CPUs
.. snip..
[acpi processor finds the CPUs are not initialized and starts calling
arch_register_cpu, which creates /sys/devices/system/cpu/cpu8/online]
CPU 8 got hotplugged
CPU 9 got hotplugged
CPU 10 got hotplugged
.. snip..
initcall 1_acpi_battery_init_async+0x0/0x1b returned 0 after 406 usecs
calling erst_init+0x0/0x2bb @ 1
[and the scheduler sticks newly started tasks on the new CPUs, but
said CPUs cannot be initialized b/c the hypervisor has limited the
amount of vCPUS to 8 - as per the dom0_max_vcpus=8 flag.
The spinlock tries to kick the other CPU, but the structure for that
is not initialized and we crash.]
BUG: unable to handle kernel paging request at fffffffffffffed8
IP: [<ffffffff81035289>] xen_spin_lock+0x29/0x60
PGD 180d067 PUD 180e067 PMD 0
Oops: 0002 [#1] SMP
CPU 7
Modules linked in:
Pid: 1, comm: swapper/0 Not tainted 3.4.0-rc2upstream-00001-gf5154e8 #1 Intel Corporation S2600CP/S2600CP
RIP: e030:[<ffffffff81035289>] [<ffffffff81035289>] xen_spin_lock+0x29/0x60
RSP: e02b:ffff8801fb9b3a70 EFLAGS: 00010282
With this patch, we cap the amount of vCPUS that the initial domain
can run, to exactly what dom0_max_vcpus=X has specified.
In the future, if there is a hypercall that will allow a running
domain to expand past its initial set of vCPUS, this patch should
be re-evaluated.
With the introduction of static keys, anything using tracepoints blows up
in the following manner:
include/trace/events/oom.h:8:13: error: initializer element is not constant
include/trace/events/oom.h:8:13: error: (near initialization for '__tracepoint_oom_score_adj_update')
include/trace/events/oom.h:8:13: error: (near initialization for '__tracepoint_oom_score_adj_update.key')
This is a result of the STATIC_KEY_INIT_xxx defs wrapping ATOMIC_INIT()
which on sh includes an atomic_t typecast. Given that we don't really
need the typecast for anything anymore, the simplest solution is simply
to kill off the cast.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull arch/tile fixes from Chris Metcalf:
"One change fixes a platform-independent bug about environment var
handling in the boot command line. The other is a trivial
tile-specific bug fix to avoid a link-time warning."
* 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch/tile: fix a couple of functions that should be __init
init: fix bug where environment vars can't be passed via boot args
Commit e520c410854bab763be24e0fce7ba89dc252efee
"xtensa: convert to asm-generic/hardirq.h"
converted over to using the asm-generic parts, but it also
added the sentinel
#define ack_bad_irq ack_bad_irq
which tells asm-generic to _not_ use the common ack_bad_irq.
Since e520c41 deleted the duplicated code from the arch specific
file, we _do_ want the asm-generic one in scope. So delete
the trigger define above which hides it. In doing so we'll
realize that we've got to delete the almost-duplicate prototype
as well to avoid "static declaration ... follows non-static".
Cc: Chris Zankel <chris@zankel.net>
Merge fixes from Andrew Morton:
"13 fixes. The acerhdf patches aren't (really) fixes. But they've
been stuck in my tree for up to two years, sent to Matthew multiple
times and the developers are unhappy."
* emailed from Andrew Morton <akpm@linux-foundation.org>: (13 patches)
mm: fix NULL ptr dereference in move_pages
mm: fix NULL ptr dereference in migrate_pages
revert "proc: clear_refs: do not clear reserved pages"
drivers/rtc/rtc-ds1307.c: fix BUG shown with lock debugging enabled
arch/arm/mach-ux500/mbox-db5500.c: world-writable sysfs fifo file
hugetlbfs: lockdep annotate root inode properly
acerhdf: lowered default temp fanon/fanoff values
acerhdf: add support for new hardware
acerhdf: add support for Aspire 1410 BIOS v1.3314
fs/buffer.c: remove BUG() in possible but rare condition
mm: fix up the vmscan stat in vmstat
epoll: clear the tfile_check_list on -ELOOP
mm/hugetlb: fix warning in alloc_huge_page/dequeue_huge_page_vma
There are exactly four users of __monitor and __mwait:
- cstate.c (which allows acpi_processor_ffh_cstate_enter to be called
when the cpuidle API drivers are used. However patch
"cpuidle: replace xen access to x86 pm_idle and default_idle"
provides a mechanism to disable the cpuidle and use safe_halt.
- smpboot (which allows mwait_play_dead to be called). However
safe_halt is always used so we skip that.
- intel_idle (same deal as above).
- acpi_pad.c. This the one that we do not want to run as we
will hit the below crash.
Why do we want to expose MWAIT_LEAF in the first place?
We want it for the xen-acpi-processor driver - which uploads
C-states to the hypervisor. If MWAIT_LEAF is set, the cstate.c
sets the proper address in the C-states so that the hypervisor
can benefit from using the MWAIT functionality. And that is
the sole reason for using it.
Without this patch, if a module performs mwait or monitor we
get this:
invalid opcode: 0000 [#1] SMP
CPU 2
.. snip..
Pid: 5036, comm: insmod Tainted: G O 3.4.0-rc2upstream-dirty #2 Intel Corporation S2600CP/S2600CP
RIP: e030:[<ffffffffa000a017>] [<ffffffffa000a017>] mwait_check_init+0x17/0x1000 [mwait_check]
RSP: e02b:ffff8801c298bf18 EFLAGS: 00010282
RAX: ffff8801c298a010 RBX: ffffffffa03b2000 RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffff8801c29800d8 RDI: ffff8801ff097200
RBP: ffff8801c298bf18 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000000
R13: ffffffffa000a000 R14: 0000005148db7294 R15: 0000000000000003
FS: 00007fbb364f2700(0000) GS:ffff8801ff08c000(0000) knlGS:0000000000000000
CS: e033 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000179f038 CR3: 00000001c9469000 CR4: 0000000000002660
Process insmod (pid: 5036, threadinfo ffff8801c298a000, task ffff8801c29cd7e0)
Stack:
ffff8801c298bf48 ffffffff81002124 ffffffffa03b2000 00000000000081fd
000000000178f010 000000000178f030 ffff8801c298bf78 ffffffff810c41e6
00007fff3fb30db9 00007fff3fb30db9 00000000000081fd 0000000000010000
Call Trace:
[<ffffffff81002124>] do_one_initcall+0x124/0x170
[<ffffffff810c41e6>] sys_init_module+0xc6/0x220
[<ffffffff815b15b9>] system_call_fastpath+0x16/0x1b
Code: <0f> 01 c8 31 c0 0f 01 c9 c9 c3 00 00 00 00 00 00 00 00 00 00 00 00
RIP [<ffffffffa000a017>] mwait_check_init+0x17/0x1000 [mwait_check]
RSP <ffff8801c298bf18>
---[ end trace 16582fc8a3d1e29a ]---
Kernel panic - not syncing: Fatal exception
With this module (which is what acpi_pad.c would hit):
MODULE_AUTHOR("Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>");
MODULE_DESCRIPTION("mwait_check_and_back");
MODULE_LICENSE("GPL");
MODULE_VERSION();
static int __init mwait_check_init(void)
__monitor((void *)¤t_thread_info()->flags, 0, 0);
__mwait(0, 0);
return 0;
static void __exit mwait_check_exit(void)
module_init(mwait_check_init);
module_exit(mwait_check_exit);
Reported-by: Liu, Jinsong <jinsong.liu@intel.com>
This file has lots and lots of ifdef, around structure decls
and structure usages. The failure issue was that we would
build the BF538-EZKIT_defconfig and get:
arch/blackfin/mach-bf538/boards/ezkit.c:924:3: error: 'bfin_lq035q1_device'
undeclared here (not in a function)
even though the same ifdef _appeared_ to enable both the struct
declaration and the code that used it. Yet cpp was telling us we
didn't have the struct, but we still had the usage of it.
However, _appeared_ is the operative word. After marking all the
anonymous #endif with their parent #ifdef config options, it was
_then_ clear that there was a misplaced #endif that was hiding
the struct declaration.
The real guts of the patch boils down to this:
-#endif
+#endif /* CONFIG_MTD_M25P80 */
+#endif /* CONFIG_SPI_BFIN5XX */
-#endif /* spi master and devices */
but since I had to tag the #endif with their respective #ifdef
options to find this misplaced SPI endif, it would be silly to
then go and delete them all. So they stay.
Cc: Sonic Zhang <sonic.zhang@analog.com>
Cc: Bob Liu <lliubbo@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson into fixes
* 'u300-fixes-for-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson:
Pull x86 fixes from H. Peter Anvin.
x32, siginfo: Provide proper overrides for x32 siginfo_t
asm-generic: Allow overriding clock_t and add attributes to siginfo_t
x32: Check __ILP32__ instead of __LP64__ for x32
x86, acpi: Call acpi_enter_sleep_state via an asmlinkage C function from assembler
ACPI: Convert wake_sleep_flags to a value instead of function
x86, apic: APIC code touches invalid MSR on P5 class machines
i387: ptrace breaks the lazy-fpu-restore logic
x86/platform: Remove incorrect error message in x86_default_fixup_cpu_id()
x86, efi: Add dedicated EFI stub entry point
x86/amd: Remove broken links from comment and kernel message
x86, microcode: Ensure that module is only loaded on supported AMD CPUs
x86, microcode: Fix sysfs warning during module unload on unsupported CPUs
Don't allow everybody to use a modem.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm into fixes
* 'msm-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm:
They were marked __devinit by mistake, causing some warnings at link time.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
Provide systems that do not support x2apic cluster mode
a mechanism to select x2apic physical mode using the
FADT FORCE_APIC_PHYSICAL_DESTINATION_MODE bit.
Changes from v1: (based on Suresh's comments)
- removed #ifdef CONFIG_ACPI
- removed #include <linux/acpi.h>
Signed-off-by: Greg Pearson <greg.pearson@hp.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Link: http://lkml.kernel.org/r/1335313436-32020-1-git-send-email-greg.pearson@hp.com
The second parameter to intel_scu_notifier_post is a void *, not
an integer.
This quiets the sparse noise:
arch/x86/platform/mrst/mrst.c:808:48: warning: Using plain integer as NULL pointer
arch/x86/platform/mrst/mrst.c:817:43: warning: Using plain integer as NULL pointer
Acked-by: Alan Cox <alan@linux.intel.com>
Link: http://lkml.kernel.org/r/201204241500.53685.hartleys@visionengravers.com
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp into x86/urgent
A small L3 cache index disable fix from Srivatsa Bhat which unifies the
way the code checks for already disabled indices.
( Pulling it into v3.4 despite the v3.5 tag - the fix is small and we better
keep the same code across kernel versions for such user facing interfaces. )
Commit 6e8201f57c935 "mmc: core: add the capability for broken voltage"
introduced a new quirk to indicate that MMC core should ignore voltage
change errors reported by the regulators core. This is required to get
SDHCI working on UniversalC210, NURI and GONI boards again after commit
ceb6143b2df81c ("mmc: sdhci: fix vmmc handling").
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Fixed following compile time error.
arch/arm/mach-exynos/common.c: In function 'exynos5_init_irq':
arch/arm/mach-exynos/common.c:539:2: error: implicit declaration of function 'of_irq_init'
arch/arm/mach-exynos/common.c:539:14: error: 'exynos4_dt_irq_match' undeclared (first use in this function)
arch/arm/mach-exynos/common.c:539:14: note: each undeclared identifier is reported only once for each function it appears in
Cc: Thomas Abraham <thomas.abraham@linaro.org>
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
Should be EXYNOS4_IRQ_DWMCI instead of IRQ_DWMCI,
and use DEFINE_RES_{MEM,IRQ}.
Reported-by: Jaehoon Chung <jh80.chung@samsung.com>
warning: (CPU_S3C2440 && CPU_S3C2442) selects S3C2410_PM which has unmet direct dependencies (ARCH_S3C24XX && CPU_S3C2410)
This is needed to fix mini2440_defconfig after the platform
files have been moved around.
arm-none-linux-gnueabi-ld: no machine record defined
make: *** [.tmp_vmlinux1] Error 1
git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel
Pull Hexagon fixes from Richard Kuo:
"It's mostly compile fixes and the Hexagon portion of a CPU hotplug
patch set."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel:
hexagon: add missing cpu.h include
hexagon/CPU hotplug: Add missing call to notify_cpu_starting()
hexagon: use renamed tick_nohz_idle_* functions
Hexagon: misc compile warning/error cleanup due to missing headers
Provide the proper override macros for x32 siginfo_t. The combination
of a special type here and an overall alignment constraint actually
ends up with all the types being properly aligned, but the hack is
needed to keep the substructures inside siginfo_t from adding padding.
Note: use __attribute__((aligned())) since __aligned() is not exported
to user space.
[ v2: fix stray semicolon ]
Reported-by: H.J. Lu <hjl.rools@gmail.com>
Cc: Bruce J. Beare <bruce.j.beare@intel.com>
Link: http://lkml.kernel.org/r/CAMe9rOqF6Kh6-NK7oP0Fpzkd4SBAWU%2BG53hwBbSD4iA2UzyxuA@mail.gmail.com
As of
commit 75294957be1dee7d22dd7d90bd31334ba410e836
Author: Grant Likely <grant.likely@secretlab.ca>
Date: Tue Feb 14 14:06:57 2012 -0700
irq_domain: Remove 'new' irq_domain in favour of the ppc one
the ARM gic controller uses proper irq domains. Fix the MSM gic
initialization and DT so that it works again.
Signed-off-by: David Brown <davidb@codeaurora.org>
