path: root/arch
2012-11-16Merge branch '3.8/vram-conversion' of git://gitorious.org/linux-omap-dss2/linuxTomi Valkeinen
Conflicts: drivers/video/omap2/dss/Kconfig drivers/video/omap2/omapfb/omapfb-ioctl.c drivers/video/omap2/omapfb/omapfb-main.c Merge changes to make omapfb use common dma_alloc, and remove omap's custom vram allocator.
2012-11-16Merge tag 'v3.7-rc4'Tomi Valkeinen
Merge Linux 3.7-rc4 to get fixes for CMA.
2012-11-13OMAP: remove vram allocatorTomi Valkeinen
OMAP specific vram allocator is no longer in use, and we can remove all the vram code. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-11-13OMAP: common.c: remove init call to vramTomi Valkeinen
OMAP specific vram allocator is no longer used, and we can remove init call to the vram allocator. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-11-13OMAP: RX51: remove use of vramTomi Valkeinen
As omapfb no longer uses omap specific vram allocator we can remove the vram pre-allocation from rx51 board file. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-11-13OMAP: FB: use DMA_BIT_MASK() for fb's coherent_dma_maskTomi Valkeinen
Use DMA_BIT_MASK() for fb's coherent_dma_mask for clarity. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-11-02Merge tag 'frv-fixes-20121102' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-frv Pull FRV fixes from David Howells: "A collection of small fixes for the FRV architecture." * tag 'frv-fixes-20121102' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-frv: frv: fix the broken preempt frv: switch to saner kernel_execve() semantics FRV: Fix the new-style kernel_thread() stuff FRV: Fix the preemption handling FRV: gcc-4.1.2 also inlines weak functions FRV: Don't objcopy the GNU build_id note FRV: Add missing linux/export.h #inclusions
2012-11-02Merge tag 'stable/for-linus-3.7-rc4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen bugfixes from Konrad Rzeszutek Wilk: - Use appropriate macros instead of hand-rolling our own (ARM). - Fixes if FB/KBD closed unexpectedly. - Fix memory leak in /dev/gntdev ioctl calls. - Fix overflow check in xenbus_file_write. - Document cleanup. - Performance optimization when migrating guests. * tag 'stable/for-linus-3.7-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/mmu: Use Xen specific TLB flush instead of the generic one. xen/arm: use the __HVC macro xen/xenbus: fix overflow check in xenbus_file_write() xen-kbdfront: handle backend CLOSED without CLOSING xen-fbfront: handle backend CLOSED without CLOSING xen/gntdev: don't leak memory from IOCTL_GNTDEV_MAP_GRANT_REF x86: remove obsolete comment from asm/xen/hypervisor.h
2012-11-02frv: fix the broken preemptAl Viro
Just get %icc2 into the state we would have after local_irq_disable() and physical IRQ having happened since then. Then we can simply use preempt_schedule_irq() and be done with the whole mess. Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-02frv: switch to saner kernel_execve() semanticsAl Viro
2012-11-02FRV: Fix the new-style kernel_thread() stuffDavid Howells
The kernel_thread() changes for FRV don't work, and FRV fails to boot, starting with: commit 02ce496f152df87be081a64796498942c433a2fd Author: Al Viro <viro@zeniv.linux.org.uk> Date: Tue Sep 18 22:18:51 2012 -0400 Subject: frv: split ret_from_fork, simplify kernel_thread() a lot The problem is that the userspace registers are completely cleared when a kernel thread is created and all subsequent user threads are then copied from that. Unfortunately, however, the TBR and PSR registers are restored from the pt_regs and the values they should be set to are clobbered by the memset. Instead, copy across the old user registers as normal, and then merely alter GR8 and GR9 in it if we're going to execute a kernel thread. Signed-off-by: David Howells <dhowells@redhat.com>
2012-11-02FRV: Fix the preemption handlingDavid Howells
Fix the preemption handling in FRV code where the PREEMPT_ACTIVE value is incorrectly loaded into the threadinfo flags rather than the threadinfo preemption count. Unfortunately, the code cannot be simply converted to use preempt_schedule_irq() as is because FRV uses virtual interrupt disablement to cut down on the cost of actually disabling interrupts and thus local_irq_enable() doesn't actually enable interrupts. Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> cc: Al Viro <viro@ZenIV.linux.org.uk>
2012-11-02FRV: Don't objcopy the GNU build_id noteDavid Howells
Don't let objcopy transfer the GNU build_id note into the loadable image as it is located at address 0 and the image ends up >3G in size. Signed-off-by: David Howells <dhowells@redhat.com>
2012-11-02FRV: Add missing linux/export.h #inclusionsDavid Howells
Add missing linux/export.h #inclusions to the FRV arch. Signed-off-by: David Howells <dhowells@redhat.com>
2012-11-01Merge tag 'xtensa-next-20121101' of git://github.com/czankel/xtensa-linuxLinus Torvalds
Pull Xtensa fixes from Chris Zankel: "Some important bug fixes. With the change to uapi, there was a bug introduced that results in an empty syscall table (mult-inclusion bug). Switching to the generic thread/execve allowed us to fix a bug we had in vfork()." * tag 'xtensa-next-20121101' of git://github.com/czankel/xtensa-linux: xtensa: switch to generic sys_execve() xtensa: switch to generic kernel_execve() xtensa: switch to generic kernel_thread() xtensa: reset windowbase/windowstart when cloning the VM xtensa: use physical addresses for bus addresses xtensa: allow multi-inclusion for uapi/unistd.h
2012-10-31KVM: x86: fix vcpu->mmio_fragments overflowXiao Guangrong
After commit b3356bf0dbb349 (KVM: emulator: optimize "rep ins" handling), the pieces of io data can be collected and write them to the guest memory or MMIO together Unfortunately, kvm splits the mmio access into 8 bytes and store them to vcpu->mmio_fragments. If the guest uses "rep ins" to move large data, it will cause vcpu->mmio_fragments overflow The bug can be exposed by isapc (-M isapc): [23154.818733] general protection fault: 0000 [#1] SMP DEBUG_PAGEALLOC [ ......] [23154.858083] Call Trace: [23154.859874] [<ffffffffa04f0e17>] kvm_get_cr8+0x1d/0x28 [kvm] [23154.861677] [<ffffffffa04fa6d4>] kvm_arch_vcpu_ioctl_run+0xcda/0xe45 [kvm] [23154.863604] [<ffffffffa04f5a1a>] ? kvm_arch_vcpu_load+0x17b/0x180 [kvm] Actually, we can use one mmio_fragment to store a large mmio access then split it when we pass the mmio-exit-info to userspace. After that, we only need two entries to store mmio info for the cross-mmio pages access Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-10-31xen/mmu: Use Xen specific TLB flush instead of the generic one.Konrad Rzeszutek Wilk
As Mukesh explained it, the MMUEXT_TLB_FLUSH_ALL allows the hypervisor to do a TLB flush on all active vCPUs. If instead we were using the generic one (which ends up being xen_flush_tlb) we end up making the MMUEXT_TLB_FLUSH_LOCAL hypercall. But before we make that hypercall the kernel will IPI all of the vCPUs (even those that were asleep from the hypervisor perspective). The end result is that we needlessly wake them up and do a TLB flush when we can just let the hypervisor do it correctly. This patch gives around 50% speed improvement when migrating idle guest's from one host to another. Oracle-bug: 14630170 CC: stable@vger.kernel.org Tested-by: Jingjie Jiang <jingjie.jiang@oracle.com> Suggested-by: Mukesh Rathor <mukesh.rathor@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-10-30xen/arm: use the __HVC macroStefano Stabellini
Use the new __HVC macro in hypercall.S. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-10-30x86: remove obsolete comment from asm/xen/hypervisor.hOlaf Hering
Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-10-29OMAPDSS: split hdmi muxing functionTomi Valkeinen
Split the omap4_hdmi_mux_pads() function into two parts, one handles the tpd12s015 gpio muxing, the other handles the hdmi pins. This is clearer, as hdmi and tpd12s015 are separate devices, and it also allows us to mux those separately with DT. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Ricardo Neri <ricardo.neri@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-10-28Merge tag 'fixes-for-3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull arm-soc fixes from Arnd Bergmann: "Bug fixes for a number of ARM platforms, mostly OMAP, imx and at91. These come a little later than I had hoped but unfortunately we had a few of these patches cause regressions themselves and had to work out how to deal with those in the meantime." * tag 'fixes-for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (38 commits) Revert "ARM i.MX25: Fix PWM per clock lookups" ARM: versatile: fix versatile_defconfig ARM: mvebu: update defconfig with 3.7 changes ARM: at91: fix at91x40 build ARM: socfpga: Fix socfpga compilation with early_printk() enabled ARM: SPEAr: Remove unused empty files MAINTAINERS: Add arm-soc tree entry ARM: dts: mxs: add the "clock-names" for gpmi-nand ARM: ux500: Correct SDI5 address and add some format changes ARM: ux500: Specify AMBA Primecell IDs for Nomadik I2C in DT ARM: ux500: Fix build error relating to IRQCHIP_SKIP_SET_WAKE ARM: at91: drop duplicated config SOC_AT91SAM9 entry ARM: at91/i2c: change id to let i2c-at91 work ARM: at91/i2c: change id to let i2c-gpio work ARM: at91/dts: at91sam9g20ek_common: Fix typos in buttons labels. ARM: at91: fix external interrupt specification in board code ARM: at91: fix external interrupts in non-DT case ARM: at91: at91sam9g10: fix SOC type detection ARM: at91/tc: fix typo in the DT document ARM: AM33XX: Fix configuration of dmtimer parent clock by dmtimer driverDate:Wed, 17 Oct 2012 13:55:55 -0500 ...
2012-10-27Revert "ARM i.MX25: Fix PWM per clock lookups"Arnd Bergmann
This reverts commit 92063cee118655d25b50d04eb77b012f3287357a, it was applied prematurely, causing this build error for imx_v4_v5_defconfig: arch/arm/mach-imx/clk-imx25.c: In function 'mx25_clocks_init': arch/arm/mach-imx/clk-imx25.c:206:26: error: 'pwm_ipg_per' undeclared (first use in this function) arch/arm/mach-imx/clk-imx25.c:206:26: note: each undeclared identifier is reported only once for each function it appears in Sascha Hauer explains: > There are several gates missing in clk-imx25.c. I have a patch which > adds support for them and I seem to have missed that the above depends > on it. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-27ARM: versatile: fix versatile_defconfigArnd Bergmann
With the introduction of CONFIG_ARCH_MULTIPLATFORM, versatile is no longer the default platform, so we need to enable CONFIG_ARCH_VERSATILE explicitly in order for that to be selected rather than the multiplatform configuration. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-27ARM: mvebu: update defconfig with 3.7 changesThomas Petazzoni
The split of 370 and XP into two Kconfig options and the multiplatform kernel support has changed a few Kconfig symbols, so let's update the mvebu_defconfig file with the latest changes. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-27ARM: at91: fix at91x40 buildArnd Bergmann
patch 738a0fd7 "ARM: at91: fix external interrupts in non-DT case" fixed a run-time error on some at91 platforms but did not apply the same change to at91x40, which now doesn't build. This changes at91x40 in the same way that the other platforms were changed. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2012-10-26Merge tag 'tty-3.7-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull serial fix from Greg Kroah-Hartman: "Here is one patch, a revert of a omap serial driver patch that was causing problems, for your 3.7-rc tree. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'tty-3.7-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: Revert "serial: omap: fix software flow control"
2012-10-26Merge branch 'fixes_for_linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull DMA-mapping revert from Marek Szyprowski: "Due to my mistake, my previous pull request (merged as commit cff7b8ba60e3: "Merge branch 'fixes_for_linus' ..") contained a patch which is aimed for v3.8 and lacks its dependences. This pull request reverts it and fixes build break of ARM architecture." * 'fixes_for_linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: Revert "ARM: dma-mapping: support debug_dma_mapping_error"
2012-10-26Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "This fixes a couple of nasty page table initialization bugs which were causing kdump regressions. A clean rearchitecturing of the code is in the works - meanwhile these are reverts that restore the best-known-working state of the kernel. There's also EFI fixes and other small fixes." * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, mm: Undo incorrect revert in arch/x86/mm/init.c x86: efi: Turn off efi_enabled after setup on mixed fw/kernel x86, mm: Find_early_table_space based on ranges that are actually being mapped x86, mm: Use memblock memory loop instead of e820_RAM x86, mm: Trim memory in memblock to be page aligned x86/irq/ioapic: Check for valid irq_cfg pointer in smp_irq_move_cleanup_interrupt x86/efi: Fix oops caused by incorrect set_memory_uc() usage x86-64: Fix page table accounting Revert "x86/mm: Fix the size calculation of mapping tables" MAINTAINERS: Add EFI git repository location
2012-10-26Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Most of the kernel diffstat relates to a group of Intel P6 and KNC (Xeon-Phi Knights Corner) PMU driver fixes, neither of which is in heavy use, so we took the fixes. The rest is diverse smallish fixes to the tooling and kernel side." * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86: Remove unused variable in nhmex_rbox_alter_er() perf/x86: Enable overflow on Intel KNC with a custom knc_pmu_handle_irq() perf/x86: Remove cpuc->enable check on Intl KNC event enable/disable perf/x86: Make Intel KNC use full 40-bit width of counters perf/x86/uncore: Handle pci_read_config_dword() errors perf/x86: Remove P6 cpuc->enabled check perf/x86: Update/fix generic events on P6 PMU perf/x86: Fix P6 FP_ASSIST event constraint perf, cpu hotplug: Use cached value of smp_processor_id() perf, cpu hotplug: Run CPU_STARTING notifiers with irqs disabled x86/perf: Fix virtualization sanity check perf test: Fix exclude_guest parse events tests perf tools: do not flush maps on COMM for perf report perf help: Fix --help for builtins perf trace: Check if sample raw_data field is set perf trace: Validate syscall id before growing syscall table
2012-10-26Merge branch 'fixes' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: ARM: shmobile: r8a7779: I/O address abuse cleanup
2012-10-26Merge branch 'v3.7-samsung-fixes-2' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes From Kukjin Kim <kgene.kim@samsung.com>: One is spi stuff for fix the device names for the different subtypes of the spi controller. And the other is adding missing .smp field for exynos4-dt and fixing memory sections for exynos4210-trats board. * 'v3.7-samsung-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: EXYNOS: Set .smp field of machine descriptor for exynos4-dt ARM: dts: Split memory into 4 sections for exynos4210-trats ARM: SAMSUNG: Add naming of s3c64xx-spi devices Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-26Merge tag 'efi-for-3.7' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into x86/urgent Pull EFI fixes from Matt Fleming: "Fix oops with EFI variables on mixed 32/64-bit firmware/kernels and document EFI git repository location on kernel.org." Conflicts: arch/x86/include/asm/efi.h Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-10-26Revert "ARM: dma-mapping: support debug_dma_mapping_error"Marek Szyprowski
This reverts commit 871ae57adc5ed092c1341f411514d0e8482e2611, which is scheduled for v3.8 and accidently got into v3.7-rc series. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-10-25Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "A random collection of various fixes, mainly from Arnd and a few other people. Not thing really stands out here." * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: drop experimental status for hotplug and Thumb2 ARM: 7560/1: SMP_TWD: use DIV_ROUND_CLOSEST() for periodic mode ARM: 7559/1: smp: switch away from the idmap before updating init_mm.mm_count ARM: 7556/1: perf: fix updated event period in response to PERF_EVENT_IOC_PERIOD ARM: 7555/1: kexec: fix segment memory addresses check ARM: warnings in arch/arm/include/asm/uaccess.h ARM: binfmt_flat: unused variable 'persistent' ARM: be really quiet when building with 'make -s' ARM: pass -marm to gcc by default for both C and assembler ARM: Xen: fix initial build problems ARM: export default read_current_timer ARM: Fix another build warning in arch/arm/mm/alignment.c ARM: export set_irq_flags ARM: kprobes: make more tests conditional
2012-10-25Merge branch 'fixes_for_linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull CMA and DMA-mapping fixes from Marek Szyprowski: "This consists mainly of a set of one-liner fixes and cleanups for a few minor issues identified in both Contiguous Memory Allocator code and ARM DMA-mapping subsystem." * 'fixes_for_linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: ARM: mm: Remove unused arm_vmregion priv field ARM: dma-mapping: fix build warning in __dma_alloc() ARM: dma-mapping: support debug_dma_mapping_error mm: cma: alloc_contig_range: return early for err path drivers: cma: Fix wrong CMA selected region size default value drivers: dma-coherent: Fix typo in dma_mmap_from_coherent documentation drivers: dma-contiguous: Don't redefine SZ_1M
2012-10-25x86, mm: Undo incorrect revert in arch/x86/mm/init.cYinghai Lu
Commit 844ab6f9 x86, mm: Find_early_table_space based on ranges that are actually being mapped added back some lines back wrongly that has been removed in commit 7b16bbf97 Revert "x86/mm: Fix the size calculation of mapping tables" remove them again. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/CAE9FiQW_vuaYQbmagVnxT2DGsYc=9tNeAbdBq53sYkitPOwxSQ@mail.gmail.com Acked-by: Jacob Shin <jacob.shin@amd.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-10-25xtensa: switch to generic sys_execve()Max Filippov
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2012-10-25xtensa: switch to generic kernel_execve()Max Filippov
2012-10-25xtensa: switch to generic kernel_thread()Max Filippov
2012-10-25xtensa: reset windowbase/windowstart when cloning the VMChris Zankel
When we copy a user thread with CLONE_VM, we also have to reset windowbase and windowstart to start a pristine stack frame. Otherwise, overflows can happen using the address 0 as the stack pointer. Also add a special case for vfork, which continues on the parent stack until it calls execve. Because this could be a call8, we need to spill the stack pointer of the previus frame (if still 'live' in the register file). Signed-off-by: Chris Zankel <chris@zankel.net>
2012-10-25xtensa: use physical addresses for bus addressesChris Zankel
Define virt_to_bus and bus_to_virt as virt_to_phys, and phys_to_virt, respectively. Signed-off-by: Chris Zankel <chris@zankel.net>
2012-10-25xtensa: allow multi-inclusion for uapi/unistd.hChris Zankel
Xtensa implements a method that allows to generate a arbitrary output for each system call by defining the __SYSCALL(number, function, num_args). This usually requires to include uapi/unistd.h twice. Instead of removing the guard agains multiple inclusion entirely, allow to include unistd.h again only if __SYSCALL is defined. Note that __SYSCALL gets always undefined at the end of the file. Signed-off-by: Chris Zankel <chris@zankel.net>
2012-10-25x86: efi: Turn off efi_enabled after setup on mixed fw/kernelOlof Johansson
When 32-bit EFI is used with 64-bit kernel (or vice versa), turn off efi_enabled once setup is done. Beyond setup, it is normally used to determine if runtime services are available and we will have none. This will resolve issues stemming from efivars modprobe panicking on a 32/64-bit setup, as well as some reboot issues on similar setups. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=45991 Reported-by: Marko Kohtala <marko.kohtala@gmail.com> Reported-by: Maxim Kammerer <mk@dee.su> Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Cc: stable@kernel.org # 3.4 - 3.6 Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2012-10-25ARM: socfpga: Fix socfpga compilation with early_printk() enabledPavel Machek
This fixes early_printk() compilation for socfpga. (senduart/busyuart/waituart were missing). It does that by making Picochip code generic. Signed-off-by: Pavel Machek <pavel@denx.de> Acked-by: Dinh Nguyen <dinguyen@altera.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-25ARM: SPEAr: Remove unused empty filesViresh Kumar
Few empty files (spear1310_misc_regs.h and spear1340_misc_regs.h) are created by commit b31e23726 "SPEAr13xx: Add header files". Don't know how they got added, obviously my fault :) But nobody could even catch them in reviews. Remove them. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-25Merge tag 'omap-for-v3.7-rc2/fixes-signed' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes From Tony Lindgren <tony@atomide.com>: Timer fix for am33xx, runtime PM fix for UART, audio McBSP fixes, mux and pinctrl fixes, and Beagle OPP fix. * tag 'omap-for-v3.7-rc2/fixes-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: AM33XX: Fix configuration of dmtimer parent clock by dmtimer driverDate:Wed, 17 Oct 2012 13:55:55 -0500 ARM: OMAP3: Beagle: fix OPP customization and initcall ordering ARM: OMAP3: Fix 3430 legacy mux names for ssi1 signals. ARM: OMAP2+: Fix location of select PINCTRL ARM/dts: omap3: Fix mcbsp2/3 hwmods to be able to probe the drivers for audio ARM: OMAP2: UART: fix console UART mismatched runtime PM status ARM: OMAP3: PM: apply part of the erratum i582 workaround Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-25Merge tag 'imx-fixes' of git://git.pengutronix.de/git/imx/linux-2.6 into fixesArnd Bergmann
Patches from Sascha Hauer <s.hauer@pengutronix.de>: ARM i.MX fixes for 3.7-rc * tag 'imx-fixes' of git://git.pengutronix.de/git/imx/linux-2.6: ARM i.MX25: Fix PWM per clock lookups ARM i.MX25 clk: Fix nfc_ipg_per parent ARM i.MX25: Fix lcdc_ipg_per parent clock ARM: mxc: platform-mxc-mmc: Fix register region size ARM: imx: clk-imx27: Fix divider width field ARM: imx: fix the return value check in imx_clk_busy_divider() ARM: imx_v6_v7_defconfig: Enable CONFIG_GPIO_MC9S08DZ60 ARM: imx: fix return value check in imx3_init_l2x0() Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-25Merge branch 'for-rcs-3.7' of ↵Arnd Bergmann
git://git.linaro.org/people/ljones/linux-3.0-ux500 into fixes * 'for-rcs-3.7' of git://git.linaro.org/people/ljones/linux-3.0-ux500: ARM: ux500: Correct SDI5 address and add some format changes ARM: ux500: Specify AMBA Primecell IDs for Nomadik I2C in DT ARM: ux500: Fix build error relating to IRQCHIP_SKIP_SET_WAKE Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-25Merge tag 'at91-fixes' of git://github.com/at91linux/linux-at91 into fixesArnd Bergmann
From Nicolas Ferre <nicolas.ferre@atmel.com>: A mix of typos and critical fixes. The most important ones are a duplicated definition of a Kconfig variable and the handling of external interrupts for non-DT case. The new at91sam9g10 was suffering a recognition issue due to an ID mis-interpreted: this was leading to a kernel panic. * tag 'at91-fixes' of git://github.com/at91linux/linux-at91: (257 commits) ARM: at91: drop duplicated config SOC_AT91SAM9 entry ARM: at91/i2c: change id to let i2c-at91 work ARM: at91/i2c: change id to let i2c-gpio work ARM: at91/dts: at91sam9g20ek_common: Fix typos in buttons labels. ARM: at91: fix external interrupt specification in board code ARM: at91: fix external interrupts in non-DT case ARM: at91: at91sam9g10: fix SOC type detection ARM: at91/tc: fix typo in the DT document Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-10-25ARM: dts: mxs: add the "clock-names" for gpmi-nandHuang Shijie
The current DT nodes for mx23/mx28 miss the `clocks-names` item for gpmi-nand. So the gpmi-nand driver could not find the proper clock. This patch fixes this issue. Signed-off-by: Huang Shijie <b32955@freescale.com> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
