path: root/arch
2008-10-14Merge branch 's3c-move' into develRussell King
Conflicts: arch/arm/mach-versatile/core.c
2008-10-14Merge branch 'omap-all' into develRussell King
Conflicts: arch/arm/mach-omap2/gpmc.c arch/arm/mach-omap2/irq.c
2008-10-14[ARM] 5302/1: ARM: OMAP: Revert omap3 WDT changes to avoid merge conflictTony Lindgren
With the upcoming WDT patches OMAP_WDT_BASE is no longer needed in devices.c. Revert some earlier omap3 changes to avoid merge conflicts with the WDT patches. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-14[ARM] 5305/1: ARM: OMAP: Fix compile of McBSP by removing unnecessary checkTony Lindgren
Recent McBSP patches changed to allocating devices dynamically and the check for OMAP_MAX_MCBSP_COUNT became unnecessary. The check for OMAP_MAX_MCBSP_COUNT should have been removed with the earlier McBSP patches in devices.c but was accidentally left out. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-14[ARM] 5301/1: ARM: OMAP: Add missing irq definesTony Lindgren
Some McBSP irq defines were missing that should have been added with the earlier McBSP patches. Add the missing McBSP irqs, and a few other missing irqs as defined in linux-omap tree. Also add a blank line to separate irq defines from the irq line calculations. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-10Merge branch 'omap3-upstream' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into omap-all
2008-10-10ARM: OMAP3: Add default kernel config for OMAP LDPNishant Kamat
This patch adds a default config for the OMAP LDP platform. Signed-off-by: Nishant Kamat <nskamat@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-10ARM: OMAP3: Add basic board support for OMAP LDPNishant Kamat
This adds minimal board support for the OMAP3430 LDP development platform. Signed-off-by: Nishant Kamat <nskamat@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-10ARM: OMAP3: Defconfig for the Gumstix Overo board (rev 3)Steve Sakoman
Add defconfig for the Gumstix Overo board Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09Merge branch 'for-rmk' of git://git.marvell.com/orionRussell King
Merge branch 'orion-devel' into devel
2008-10-09Merge branch 'for-rmk' of git://source.mvista.com/git/linux-davinci-2.6.gitRussell King
Merge branch 'davinci' into devel
2008-10-09Merge branch 'for-rmk' of ↵Russell King
git://pasiphae.extern.pengutronix.de/git/imx/linux-2.6.git Merge branch 'imx-devel' into devel
2008-10-09Merge branch 'pxa-all' into develRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/corgi.c arch/arm/mach-pxa/include/mach/hardware.h arch/arm/mach-pxa/spitz.c
2008-10-09Merge branch 'at91' into develRussell King
2008-10-09Merge branch 'ptebits' into develRussell King
Conflicts: arch/arm/Kconfig
2008-10-09Merge branches 'machtypes', 'core', 'ep93xx', 'ks8695', 'netdev' and ↵Russell King
'sa1100' into devel
2008-10-09[ARM] 5295/1: make ZONE_DMA optionalNicolas Pitre
Most ARM machines don't need a special "DMA" memory zone, and when configured out, the kernel becomes a bit smaller: | text data bss dec hex filename |3826182 102384 111700 4040266 3da64a vmlinux |3823593 101616 111700 4036909 3d992d vmlinux.nodmazone This is because the system now has only one zone total which effect is to optimize away many conditionals in page allocation paths. So let's configure this zone only on machines that need split zones. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09Merge branch 'omap2-upstream' of ↵Russell King
2008-10-09ARM: OMAP3: Add support for the Gumstix Overo board (rev 3)Steve Sakoman
This patch adds minimal overo support. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09ARM: OMAP3: Add Beagle defconfigSyed Mohammed, Khasim
Add Beagle defconfig Signed-off-by: Syed Mohammed, Khasim <khasim@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09ARM: OMAP3: Add minimal Beagle board supportSyed Mohammed, Khasim
Add minimal Beagle board support. Based on earlier patches by Syed Mohammed Khasim with some fixes from linux-omap tree. Signed-off-by: Syed Mohammed Khasim <khasim@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09ARM: OMAP3: Add minimal omap3430 supportSyed Mohammed, Khasim
Add minimal omap3430 support based on earlier patches from Syed Mohammed Khasim. Also merge in omap34xx SRAM support from Karthik Dasu and use consistent naming for sram init functions. Also do following changes that make 34xx support usable: - Remove unused sram.c functions for 34xx - Rename IRQ_SIR_IRQ to INTCPS_SIR_IRQ and define it locally in entry-macro.S - Update mach-omap2/io.c to support 2420, 2430, and 34xx - Also merge in 34xx GPMC changes to add fields wr_access and wr_data_mux_bus from Adrian Hunter - Remove memory initialization call omap2_init_memory() until until more generic memory initialization patches are posted. It's OK to rely on bootloader initialization until then. Signed-off-by: Syed Mohammed, Khasim <khasim@ti.com> Signed-off-by: Karthik Dasu<karthik-dp@ti.com> Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09ARM: OMAP2: Fix sparse, checkpatch warnings in OMAP2/3 IRQ codePaul Walmsley
Fix sparse warnings in mach-omap2/irq.c. Fix by defining intc_bank_write_reg() and intc_bank_read_reg(), and convert INTC module register access to use them rather than __raw_{read,write}l. Also clear up some checkpatch warnings involving includes from asm/ rather than linux/. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-09[ARM] 5239/1: Palm Zire 72 power management supportSergey Lapin
This patch contains Palm Zire 72 power management support. Depends on #5238/1 Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09[ARM] 5298/1: Drop desc_handle_irq()Dmitry Baryshkov
desc_handle_irq() was declared as obsolete since long ago. Replace it with generic_handle_irq() Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09[ARM] 5297/1: [KS8695] Fix two compile-time warningsAndrew Victor
Fix two warnings when compiling for the KS8695 processor. arch/arm/include/asm/dma-mapping.h: In function 'dma_to_virt': arch/arm/include/asm/dma-mapping.h:40: warning: return makes pointer from integer without a cast Section mismatch in reference from the function pcibios_fixup_bus() to the (unknown reference) .devinit.text:(unknown) The function pcibios_fixup_bus() references the (unknown reference) __devinit (unknown). This is often because pcibios_fixup_bus lacks a __devinit annotation or the annotation of (unknown) is wrong. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09[ARM] 5296/1: [KS8695] Replace macro's with trailing underscores.Andrew Victor
Replace Macro names that have trailing underscores. Also use the IOPD() macro instead of a hard-coded bit-shift (for better readability). Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-08ARM: OMAP: Fixes to omap_mcbsp_request functionJarkko Nikula
Bootloader may let McBSP logic running so make sure that block is idle before requesting IRQs. Also make sure that TX and RX waitqueues are initialized before request_irq. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-08ARM: OMAP: Add support for OMAP2430 in McBSPJarkko Nikula
2008-10-08ARM: OMAP: Add support for McBSP devices 3 - 5 on 34xxChandra Shekhar
Based on Chandra's earlier patches in linux-omap tree. Signed-off-by: Chandra Shekhar <x0044955@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-08ARM: OMAP: Allocate McBSP devices dynamicallyChandra Shekhar
Based on Chandra's earlier patches in linux-omap tree. Note that omap1_mcbsp_check and omap2_mcbsp_check are no longer needed as there's now omap_mcbsp_check_valid_id() defined. Also some functions can now be marked __init. Signed-off-by: Chandra Shekhar <x0044955@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-08Fix sections for omap-mcbsp platform driverUwe Kleine-König
Don't use __init but __devinit to define probe function. A pointer to omap_mcbsp_probe is passed to the core via platform_driver_register and so the function must not disappear when the init code is freed. Using __init and having HOTPLUG=y the following probably oopses: echo -n omap-mcbsp.1 > /sys/bus/platform/driver/omap-mcbsp/unbind echo -n omap-mcbsp.1 > /sys/bus/platform/driver/omap-mcbsp/bind While at it move the remove function to the .devexit.text section. Signed-off-by: Uwe Kleine-König <ukleinek@strlen.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-10-07[ARM] S3C24XX: Additional include movesBen Dooks
Continue moving the include files into arch/arm Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-10-07[ARM] S3C24XX: Move files out of include/asm-arm/plat-s3c*Ben Dooks
First move of items out of include/asm-arm/plat-s3c* to their new homes under arch/arm/plat-s3c/include/plat and arch/arm/plat-s3c24xx/include/plat directories. Note, we have to create a dummy arch/arm/plat-s3c/Makefile to allow us to add arch/arm/plat-s3c/include/plat to the path. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-10-07[ARM] pxa: add preliminary CPUFREQ support for PXA3xxEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.hEric Miao
2008-10-07[ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.cEric Miao
2008-10-07[ARM] pxa/zylonite: add support for USB OHCIEric Miao
2008-10-07[ARM] ohci-pxa27x: use ioremap() and offset for register accessEric Miao
This avoid the pre-mapping of OHCI controller register space, and the mapping is made only when necessary (OHCI is probed). Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] ohci-pxa27x: introduce pxa27x_clear_otgph()Eric Miao
Direct access to pxa27x specific register PSSR in a generic ohci driver is no good, introduce pxa27x_clear_otgph() and move the implementation into processor specific code. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] ohci-pxa27x: move OHCI controller specific registers into the driverEric Miao
2008-10-07[ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registersEric Miao
Direct access to USB host controller registers is considered to be not portable, and is usually a bad sign for poorly abstracted interface. Introduce .flags and .power_on_delay to "struct pxaohci_platform_data" so that most platforms don't bother to write their own .init/.exit() sequences. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.cEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: simplify DMA register definitionsEric Miao
1. DRCMRxx is no longer recommended, use DRCMR(xx) instead, and pass DRCMR index by "struct resource" if possible 2. DCSRxx, DDADRxx, DSADRxx, DTADRxx, DCMDxx is never used, use DCSR(), DDADR(), DSADR(), DTADR(), DCMD() instead Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: make additional DCSR bits valid for PXA3xxEric Miao
2008-10-07[ARM] pxa: move i2c register and bit definitions into i2c-pxa.cEric Miao
2008-10-07[ARM] pxa: fix incorrect initialization of mfp sysdev when not pxa2xxEric Miao
The initialization of mfp sysdev in pxa2xx_mfp_init() shall really be avoided when !cpu_is_pxa2xx(). Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07Merge branches 'pxa-core' and 'pxa-machines' into pxa-allRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/pxa25x.c arch/arm/mach-pxa/pxa27x.c
2008-10-07Merge branch 'for_rmk' of git://git.mnementh.co.uk/linux-2.6-imRussell King
Merge branch 'pxa-eseries' into pxa-machines Conflicts: arch/arm/mach-pxa/Makefile
2008-10-07Merge branch 'viper-for-rmk' of git://www.misterjones.org/linux-2.6-armRussell King
Merge branch 'pxa-viper' into pxa-machines Conflicts: arch/arm/mach-pxa/Makefile drivers/pcmcia/Kconfig drivers/pcmcia/Makefile
