path: root/arch
2010-12-21OMAP2+: clockdomain: move header file from plat-omap to mach-omap2Paul Walmsley
The OMAP clockdomain code and data is all OMAP2+-specific. This seems unlikely to change any time soon. Move plat-omap/include/plat/clockdomain.h to mach-omap2/clockdomain.h. The primary point of doing this is to remove the temptation for unrelated upper-layer code to access clockdomain code and data directly. DSPBridge also uses the clockdomain headers for some reason, so, modify it also. The DSPBridge code should not be including the clockdomain headers; these should be removed. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Felipe Contreras <felipe.contreras@gmail.com> Cc: Greg Kroah-Hartman <greg@kroah.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21OMAP2/3: clockdomain: remove unneeded .clkstctrl_reg, remove some direct CM ↵Paul Walmsley
register accesses Reverse some of the effects of commit 84c0c39aec31a09571fc08a752a2f4da0fe9fcf2 ("ARM: OMAP4: PM: Make OMAP3 Clock-domain framework compatible for OMAP4"). On OMAP2/3, the CM_CLKSTCTRL register is at a constant offset from the powerdomain's CM instance. Also, remove some of the direct CM register access from the clockdomain code, moving it to the OMAP2/3 CM code instead. The intention here is to simplify the clockdomain code. (The long-term goal is to move all direct CM register access across the OMAP core code to the appropriate cm*.c file.) Signed-off-by: Paul Walmsley <paul@pwsan.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21OMAP4: clockdomains: add OMAP4 PRCM data and OMAP4 supportPaul Walmsley
Add PRCM partition, CM instance register address offset, and clockdomain register address offset to each OMAP4 struct clockdomain record. Add OMAP4 clockdomain code to use this new data to access registers properly. While here, clean up some nearby clockdomain code to allocate auto variables in my recollection of Linus's preferred style. The autogeneration scripts have been updated. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Benoît Cousson <b-cousson@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21OMAP4: CM instances: add clockdomain register offsetsPaul Walmsley
In OMAP4 CM instances, some registers (CM_CLKSTCTRL, CM_STATICDEP, CM_DYNAMICDEP, and the module-specific registers underneath) are organized by clockdomain. Add the clockdomain offset macros to the appropriate PRCM module header files. This data was almost completely autogenerated from the TI hardware database; the autogeneration scripts have been updated. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21OMAP2+: clockdomains: split the clkdm hwsup enable/disable functionPaul Walmsley
Split _omap2_clkdm_set_hwsup() into _disable_hwsup() and _enable_hwsup(). While here, also document that the autodeps are deprecated and that they should be removed at the earliest opportunity. The documentation has been fixed for _{enable,disable}_hwsup(), thanks to Kevin Hilman <khilman@deeprootsystems.com> for pointing out that those functions still had placeholder documentation in an earlier patch revision. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP4: powerdomains: add PRCM partition data; use OMAP4 PRM functionsPaul Walmsley
OMAP4 powerdomain control registers are split between the PRM hardware module and the PRCM_MPU local PRCM. Add this PRCM partition information to each OMAP4 powerdomain record, and convert the OMAP4 powerdomain function implementations to use the OMAP4 PRM instance functions. Also fixes a potential null pointer dereference of pwrdm->name. The autogeneration scripts have been updated. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Benoît Cousson <b-cousson@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP2/3: PRM/CM: prefix OMAP2 PRM/CM functions with "omap2_"Paul Walmsley
Now that OMAP4-specific PRCM functions have been added, distinguish the existing OMAP2/3-specific PRCM functions by prefixing them with "omap2_". This patch should not result in any functional change. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Jarkko Nikula <jhnikula@gmail.com> Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP4: PRCM: move global reset function for OMAP4 to an OMAP4-specific filePaul Walmsley
Move the OMAP4 global software reset function to the OMAP4-specific prm44xx.c file, where it belongs. Part of the long-term process of moving all of the direct PRCM register writes into lower-layer code. Also add OCP barriers on OMAP2/3/4 to reduce the chance that the MPU will continue executing while the system is supposed to be resetting itself. Signed-off-by: Paul Walmsley <paul@pwsan.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP4: PRCM: add OMAP4-specific accessor/mutator functionsPaul Walmsley
In some ways, the OMAP4 PRCM register layout is quite different than the OMAP2/3 PRCM register layout. For example, on OMAP2/3, from a register layout point of view, all CM instances were located in the CM subsystem, and all PRM instances were located in the PRM subsystem. OMAP4 changes this. Now, for example, some CM instances, such as WKUP_CM and EMU_CM, are located in the system PRM subsystem. And a "local PRCM" exists for the MPU - this PRCM combines registers that would normally appear in both CM and PRM instances, but uses its own register layout which matches neither the OMAP2/3 PRCM layout nor the OMAP4 PRCM layout. To try to deal with this, introduce some new functions, omap4_cminst* and omap4_prminst*. The former is to be used when writing to a CM instance register (no matter what subsystem or hardware module it exists in), and the latter, similarly, with PRM instance registers. To determine which "PRCM partition" to write to, the functions take a PRCM instance ID argument. Subsequent patches add these partition IDs to the OMAP4 powerdomain and clockdomain definitions. As far as I can see, there's really no good way to handle these types of register access inconsistencies. This patch seemed like the least bad approach. Moving forward, the long-term goal is to remove all direct PRCM register access from the PM code. PRCM register access should go through layers such as the powerdomain and clockdomain code that can hide the details of how to interact with the specific hardware variant. While here, rename cm4xxx.c to cm44xx.c to match the naming convention of the other OMAP4 PRCM files. Thanks to Santosh Shilimkar <santosh.shilimkar@ti.com>, Rajendra Nayak <rnayak@ti.com>, and Benoît Cousson <b-cousson@ti.com> for some comments. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21OMAP3: PRM/CM: separate CM context save/restore; remove PRM context save/restorePaul Walmsley
The OMAP3 PRM module is in the WKUP powerdomain, which is always powered when the chip is powered, so it shouldn't be necessary to save and restore those PRM registers. Remove the PRM register save/restore code, which should save several microseconds during off-mode entry/exit, since PRM register accesses are relatively slow. While doing so, move the CM register save/restore code into CM-specific code. The CM module has been distinct from the PRM module since 2430. This patch includes some minor changes to pm34xx.c. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Tero Kristo <tero.kristo@nokia.com> Cc: Kalle Jokiniemi <kalle.jokiniemi@digia.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP2/3: PRCM: split OMAP2/3-specific PRCM code into OMAP2/3-specific filesPaul Walmsley
In preparation for adding OMAP4-specific PRCM accessor/mutator functions, split the existing OMAP2/3 PRCM code into OMAP2/3-specific files. Most of what was in mach-omap2/{cm,prm}.{c,h} has now been moved into mach-omap2/{cm,prm}2xxx_3xxx.{c,h}, since it was OMAP2xxx/3xxx-specific. This process also requires the #includes in each of these files to be changed to reference the new file name. As part of doing so, add some comments into plat-omap/sram.c and plat-omap/mcbsp.c, which use "sideways includes", to indicate that these users of the PRM/CM includes should not be doing so. Thanks to Felipe Contreras <felipe.contreras@gmail.com> for comments on this patch. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Jarkko Nikula <jhnikula@gmail.com> Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Acked-by: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Felipe Contreras <felipe.contreras@gmail.com> Acked-by: Felipe Contreras <felipe.contreras@gmail.com> Cc: Greg Kroah-Hartman <greg@kroah.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21OMAP4: PRCM: rename _MOD macros to _INSTPaul Walmsley
Back in the OMAP2/3 PRCM interface days, the macros that referred to the offsets of individual PRM/CM instances from the top of the PRM/CM hardware modules were incorrectly suffixed with "_MOD". (They should have been suffixed with something like "_INST" or "_INSTANCE".) These days, now that we have better contact with the OMAP hardware people, we know that this naming is wrong. And in fact in OMAP4, there are actual hardware module offsets inside the instances, so the incorrect naming gets confusing very quickly for anyone who knows the hardware. Fix this naming for OMAP4, before things get too far along, by changing "_MOD" to "_INST" on the end of these macros. So, for example, OMAP4430_CM2_INSTR_MOD becomes OMAP4430_CM2_INSTR_INST. This unfortunately creates quite a large diff, but it is a straightforward rename. This patch should not result in any functional changes. The autogeneration scripts have been updated accordingly. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP4: PRCM: Add SCRM header fileBenoit Cousson
Add the header file with scrm registers absolute address, offset and bitfields. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> [paul@pwsan.com: renamed OMAP4_SCRM to OMAP4_SCRM_BASE] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-12-21OMAP4: PRCM: reorganize existing OMAP4 PRCM header filesPaul Walmsley
Split the existing cm44xx.h file into cm1_44xx.h and cm2_44xx.h files so they match their underlying OMAP hardware modules. Add clockdomain offset information. Add header files for the MPU local PRCM, prcm_mpu44xx.h, and for the SCRM, scrm44xx.h. SCRM register offsets still need to be added; TI should do this. Move the "_MOD" macros out of the prcm-common.h header file, into the header file of the hardware module that they belong to. For example, OMAP4430_PRM_*_MOD macros have been moved into the prm44xx.h header. Adjust #includes of all files that used the old PRCM header file names to point to the new filenames. The autogeneration scripts have been updated accordingly. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com> Cc: Rajendra Nayak <rnayak@ti.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Rajendra Nayak <rnayak@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21OMAP3: control/PRCM: move CONTROL_PADCONF_SYS_NIRQ save/restore to SCM codePaul Walmsley
For some reason, the PRCM context save/restore code also saves and restores a single System Control Module register, CONTROL_PADCONF_SYS_NIRQ. This is probably just an error -- the register should be handled by SCM code -- so this patch moves it there. If this register really does need to be saved and restored before the rest of the PRCM registers, the code to do so should live in the SCM code, and the PM code should call this separate function. This register pertains to devices with a stacked modem, so this patch is unlikely to affect most OMAP devices out there. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP3: control/PRCM: add omap3_ctrl_write_boot_mode()Paul Walmsley
Get rid of the open-coded scratchpad write in mach-omap2/prcm.c and replace it with an actual API, omap3_ctrl_write_boot_mode(). While there, get rid of the gratuitous omap_writel(). There's not much documentation available for what should wind up in the scratchpad here, so more documentation would be appreciated. Also, at some point, we should formalize our treatment of the scratchpad; right now, accesses to the scratchpad are not well-documented. Signed-off-by: Paul Walmsley <paul@pwsan.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21OMAP2+: clockdomains: move clockdomain static data to .c filesPaul Walmsley
Static data should be declared in .c files, not .h files. It should be possible to #include .h files at any point without creating multiple copies of the same data. We converted the clock data to .c files some time ago. This patch does the same for the clockdomain data. Signed-off-by: Paul Walmsley <paul@pwsan.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP2+: powerdomains: move powerdomain static data to .c filesPaul Walmsley
Static data should be declared in .c files, not .h files. It should be possible to #include .h files at any point without creating multiple copies of the same data. We converted the clock data to .c files some time ago. This patch does the same for the powerdomain data. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP4: powerdomain: Add pwrdm_clear_all_prev_pwrstSantosh Shilimkar
Like OMAP3, OMAP4430 ES2 has additional bitfields in PWRSTST register which help identify the previous power state entered by the powerdomain. Add pwrdm_clear_all_prev_pwrst to the OMAP4 powerdomains implementation to support this. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> [paul@pwsan.com: clarified commit message] Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP: powerdomain: Arch specific funcs for mem controlRajendra Nayak
Define the following architecture specific funtions for omap2/3/4 .pwrdm_set_mem_onst .pwrdm_set_mem_retst .pwrdm_read_mem_pwrst .pwrdm_read_prev_mem_pwrst .pwrdm_read_mem_retst .pwrdm_clear_all_prev_pwrst .pwrdm_enable_hdwr_sar .pwrdm_disable_hdwr_sar .pwrdm_wait_transition .pwrdm_set_lowpwrstchange Convert the platform-independent framework to call these functions. Signed-off-by: Rajendra Nayak <rnayak@ti.com> [paul@pwsan.com: rearranged Makefile changes] Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21OMAP: powerdomain: Arch specific funcs for logic controlRajendra Nayak
Define the following architecture specific funtions for omap2/3/4 .pwrdm_set_logic_retst .pwrdm_read_logic_pwrst .pwrdm_read_prev_logic_pwrst .pwrdm_read_logic_retst Convert the platform-independent framework to call these functions. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP: powerdomain: Arch specific funcs for state controlRajendra Nayak
Define the following architecture specific funtions for omap2/3/4 .pwrdm_set_next_pwrst .pwrdm_read_next_pwrst .pwrdm_read_pwrst .pwrdm_read_prev_pwrst Convert the platform-independent framework to call these functions. Signed-off-by: Rajendra Nayak <rnayak@ti.com> [paul@pwsan.com: remove remaining static allocations in powerdomains.h file; remove path in file header comments, rearranged Makefile changes] Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP: powerdomain: Infrastructure to put arch specific codeRajendra Nayak
Put infrastructure in place, so arch specific func pointers can be hooked up to the platform-independent part of the framework. This is in preparation of splitting the powerdomain framework into platform-independent part (for all omaps) and platform-specific parts. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP: powerdomain: Move static allocations from powerdomains.h to a .c fileRajendra Nayak
powerdomains.h header today has only static definitions. Adding any function declarations into it and including it in multiple source file is expected to cause issues. Hence move all the static definitions from powerdomains.h file into powerdomains_data.c file. Also, create a new powerdomain section of the mach-omap2/Makefile, and rearrange the prcm-common part of the Makefile, now that the powerdomain code is in its own Makefile section. Signed-off-by: Rajendra Nayak <rnayak@ti.com> [paul@pwsan.com: rearrange Makefile changes, tweaked commit message] Signed-off-by: Paul Walmsley <paul@pwsan.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Rajendra Nayak <rnayak@ti.com>
2010-12-21OMAP2+: wd_timer: disable on boot via hwmod postsetup mechanismPaul Walmsley
The OMAP watchdog timer IP blocks require a specific set of register writes to occur before they will be disabled[1], even if the device clocks appear to be disabled in the CM_*CLKEN registers. In the MPU watchdog case, failure to execute this reset sequence will eventually cause the watchdog to reset the OMAP unexpectedly. Previously, the code to disable this watchdog was manually called from mach-omap2/devices.c during device initialization. This causes the watchdog to be unconditionally disabled for a portion of kernel initialization. This should be controllable by the board-*.c files, since some system integrators will want full watchdog coverage of kernel initialization. Also, the watchdog disable code was not connected to the hwmod shutdown code. This means that calling omap_hwmod_shutdown() will not, in fact, disable the watchdog, and the goal of omap_hwmod_shutdown() is to be able to shutdown any on-chip OMAP device. To resolve the latter problem, populate the pre_shutdown pointer in the watchdog timer hwmod classes with a function that executes the watchdog shutdown sequence. This allows the hwmod code to fully disable the watchdog. Then, to allow some board files to support watchdog coverage throughout kernel initialization, add common code to mach-omap2/io.c to cause the MPU watchdog to be disabled on boot unless a board file specifically requests it to remain enabled. Board files can do this by changing the watchdog timer hwmod's postsetup state between the omap2_init_common_infrastructure() and omap2_init_common_devices() function calls. 1. OMAP34xx Multimedia Device Silicon Revision 3.1.x Rev. ZH [SWPU222H], Section 16.4.3.6, "Start/Stop Sequence for WDTs (Using WDTi.WSPR Register)" Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Charulatha Varadarajan <charu@ti.com>
2010-12-21OMAP2+: wd_timer: separate watchdog disable code from the rest of ↵Paul Walmsley
mach-omap2/devices.c Split the wd_timer disable code out into its own file, mach-omap2/wd_timer.c; it belongs in its own file rather than cluttering up devices.c. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Charulatha Varadarajan <charu@ti.com>
2010-12-21OMAP2+: hwmod: Update the sysc_cache in case module context is lostRajendra Nayak
Do not skip the sysc programming in the hmwod framework based on the cached value alone, since at times the module might have lost context (due to the Powerdomain in which the module belongs transitions to either Open Switch RET or OFF). Identifying if a module has lost context requires atleast one register read, and since a register read has more latency than a write, it makes sense to do a blind write always. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-12-21OMAP2+: hwmod: fix a warning, add some docs, remove unused fieldsPaul Walmsley
Trivial cleanup and documentation changes on the hwmod code and data: - add some hwmod documentation to indicate flags that should be moved outside the static hwmod data in a future patch - remove some unused fields in the struct omap_hwmod_ocp_if and struct omap_hwmod structures Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com>
2010-12-21OMAP2+: hwmod: upgrade per-hwmod mutex to a spinlockPaul Walmsley
Change the per-hwmod mutex to a spinlock. (The per-hwmod lock serializes most post-initialization hwmod operations such as enable, idle, and shutdown.) Spinlocks are needed, because in some cases, hwmods must be enabled from timer interrupt disabled-context, such as an ISR. The current use-case that is driving this is the OMAP GPIO block ISR: it can trigger interrupts even with its clocks disabled, but these clocks are needed for register accesses in the ISR to succeed. This patch also effectively reverts commit 848240223c35fcc71c424ad51a8e8aef42d3879c - this patch makes _omap_hwmod_enable() and _omap_hwmod_init() static, renames them back to _enable() and _idle(), and changes their callers to call the spinlocking versions. Previously, since omap_hwmod_{enable,init}() attempted to take mutexes, these functions could not be called while the timer interrupt was disabled; but now that the functions use spinlocks and save and restore the IRQ state, it is appropriate to call them directly. Kevin Hilman <khilman@deeprootsystems.com> originally proposed this patch - thanks Kevin. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Benoît Cousson <b-cousson@ti.com>
2010-12-21OMAP2+: hwmod: add support for per-class custom device reset functionsPaul Walmsley
The standard omap_hwmod.c _reset() code relies on an IP block's OCP_SYSCONFIG.SOFTRESET register bit to reset the IP block. This works for most IP blocks on the chip, but unfortunately not all. For example, initiator-only IP blocks often don't have any MPU-accessible OCP-header registers, and therefore the MPU can't write to any OCP_SYSCONFIG registers in that block. Other IP blocks, such as the IVA and I2C, require a specialized reset sequence. Since we need to be able to reset these IP blocks as well, allow custom IP block reset functions to be passed into the hwmod code via a per-hwmod-class reset function pointer, struct omap_hwmod_class.reset. If .reset is non-null, then the hwmod _reset() code will call the custom function instead of the standard OCP SOFTRESET-based code. As part of this change, rename most of the existing _reset() function code to _ocp_softreset(), to indicate more clearly that it does not work for all cases. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com> Cc: Paul Hunt <hunt@ti.com> Cc: Stanley Liu <stanley_liu@ti.com>
2010-12-21OMAP2+: hwmod: add postsetup statePaul Walmsley
Allow board files and OMAP core code to control the state that some or all of the hwmods end up in at the end of _setup() (called by omap_hwmod_late_init() ). Reimplement the old skip_setup_idle code in terms of this new postsetup state code. There are two use-cases for this patch: the !CONFIG_PM_RUNTIME case, in which all IP blocks should stay enabled after _setup() finishes; and the MPU watchdog case, in which the watchdog IP block should enter idle if watchdog coverage of kernel initialization is desired, and should be disabled otherwise. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Charulatha Varadarajan <charu@ti.com>
2010-12-21OMAP2+: hwmod: allow custom pre-shutdown functionsPaul Walmsley
Some OMAP IP blocks, such as the watchdog timers, cannot be completely shut down via the standard hwmod shutdown mechanism. This patch enables the hwmod data files to supply a pointer to a custom pre-shutdown function via the struct omap_hwmod_class.pre_shutdown function pointer. If the struct omap_hwmod_class.pre_shutdown function pointer is non-null, the function will be executed before the existing hwmod shutdown code runs. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com>
2010-12-21OMAP2+: io: split omap2_init_common_hw()Paul Walmsley
Split omap2_init_common_hw() into two functions. The first, omap2_init_common_infrastructure(), initializes the hwmod code and data, the OMAP PM code, and the clock code and data. The second, omap2_init_common_devices(), handles any other early device initialization that, for whatever reason, has not been or cannot be moved to initcalls or early platform devices. This patch is required for the hwmod postsetup patch, which allows board files to change the state that hwmods should be placed into at the conclusion of the hwmod _setup() function. For example, for a board whose creators wish to ensure watchdog coverage across the entire kernel boot process, code to change the watchdog's postsetup state will be added in the board-*.c file between the omap2_init_common_infrastructure() and omap2_init_common_devices() function calls. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com>
2010-12-21Merge branch 'pm-opp' of ↵Tony Lindgren
ssh://master.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-for-linus
2010-12-21Merge branch 'pm-next' of ↵Tony Lindgren
2010-12-21Merge branch 'devel-dma' into omap-for-linusTony Lindgren
2010-12-21OMAP3: ASM sleep code format reworkJean Pihet
Cosmetic fixes to the code: - white spaces and tabs, - alignement, - comments rephrase and typos, - multi-line comments Tested on N900 and Beagleboard with full RET and OFF modes, using cpuidle and suspend. Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP3: add comments for low power code errataJean Pihet
Errata covered: - 1.157 & 1.185 - i443 - i581 Tested on N900 and Beagleboard with full RET and OFF modes, using cpuidle and suspend. Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP3: rework of the ASM sleep code execution pathsJean Pihet
- Reworked and simplified the execution paths for better readability and to avoid duplication of code, - Added comments on the entry and exit points and the interaction with the ROM code for OFF mode restore, - Reworked the existing comments for better readability. Tested on N900 and Beagleboard with full RET and OFF modes, using cpuidle and suspend. Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP3: re-organize the ASM sleep codeJean Pihet
Organize the code in the following sections: - register access macros, - API functions, - internal functions. Tested on N900 and Beagleboard with full RET and OFF modes, using cpuidle and suspend. Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP3: remove hardcoded values from the ASM sleep codeJean Pihet
Using macros from existing include files for registers addresses. Tested on N900 and Beagleboard with full RET and OFF modes, using cpuidle and suspend. Based on original patch from Vishwa. Signed-off-by: Jean Pihet <j-pihet@ti.com> Cc: Vishwanath BS <vishwanath.bs@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP2+: use global values for the SRAM PA addressesJean Pihet
The SRAM PA addresses are locally defined and used at different places, i.e. SRAM management code and idle sleep code. The macros are now defined at a centralized place, for easier maintenance. Tested on N900 and Beagleboard with full RET and OFF modes, using cpuidle and suspend. Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Nishanth Menon<nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP3: remove unused code from the ASM sleep codeJean Pihet
Remove unused code: - macros, - variables, - unused semaphore locking API. This API shall be added back when needed, - infinite loops for debug. Tested on N900 and Beagleboard with full RET and OFF modes, using cpuidle and suspend. Signed-off-by: Jean Pihet <j-pihet@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Nishanth Menon <nm@ti.com> Tested-by: Nishanth Menon<nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP3630: PM: Erratum i583: disable coreoff if < ES1.2Eduardo Valentin
Limitation i583: Self_Refresh Exit issue after OFF mode Issue: When device is waking up from OFF mode, then SDRC state machine sends inappropriate sequence violating JEDEC standards. Impact: OMAP3630 < ES1.2 is impacted as follows depending on the platform: CS0: for 38.4MHz as internal sysclk, DDR content seen to be stable, while for all other sysclk frequencies, varied levels of instability seen based on varied parameters. CS1: impacted This patch takes option #3 as recommended by the Silicon erratum: Avoid core power domain transitioning to OFF mode. Power consumption impact is expected in this case. To do this, we route core OFF requests to RET request on the impacted revisions of silicon. Acked-by: Jean Pihet <j-pihet@ti.com> [nm@ti.com: rebased the code to 2.6.37-rc2- short circuit code changed a bit] Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Eduardo Valentin <eduardo.valentin@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP3: PM: make omap3_cpuidle_update_states independent of enable_off_modeNishanth Menon
Currently omap3_cpuidle_update_states makes whole sale decision on which C states to update based on enable_off_mode variable Instead, achieve the same functionality by independently providing mpu and core deepest states the system is allowed to achieve and update the idle states accordingly. Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Jean Pihet <j-pihet@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> [khilman: fixed additional user of this API in OMAP CPUidle driver] Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP3630: PM: Disable L2 cache while invalidating L2 cachePeter 'p2' De Schrijver
While coming out of MPU OSWR/OFF states, L2 controller is reseted. The reset behavior is implementation specific as per ARMv7 TRM and hence $L2 needs to be invalidated before it's use. Since the AUXCTRL register is also reconfigured, disable L2 cache before invalidating it and re-enables it afterwards. This is as per Cortex-A8 ARM documentation. Currently this is identified as being needed on OMAP3630 as the disable/enable is done from "public side" while, on OMAP3430, this is done in the "secure side". Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Jean Pihet <j-pihet@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> [nm@ti.com: ported to 2.6.37-rc2, added hooks to enable the logic only on 3630] Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Eduardo Valentin <eduardo.valentin@nokia.com> Signed-off-by: Peter 'p2' De Schrijver <peter.de-schrijver@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP3630: PM: Erratum i608: disable RTANishanth Menon
Erratum id: i608 RTA (Retention Till Access) feature is not supported and leads to device stability issues when enabled. This impacts modules with embedded memories on OMAP3630 Workaround is to disable RTA on boot and coming out of core off. For disabling RTA coming out of off mode, we do this by overriding the restore pointer for 3630 as the first point of entry before caches are touched and is common for GP and HS devices. To disable earlier than this could be possible by modifying the PPA for HS devices, but not for GP devices. Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Jean Pihet <j-pihet@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> [ambresh@ti.com: co-developer] Signed-off-by: Ambresh K <ambresh@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP3: pm: introduce errata handlingNishanth Menon
Introduce errata handling for OMAP3. This patch introduces errata variable and stub for initialization which will be filled up by follow-on patches. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP3: PM: Erratum i581 support: dll kick strategyPeter 'p2' De Schrijver
Erratum i581 impacts OMAP3 platforms. PRCM DPLL control FSM removes SDRC_IDLEREQ before DPLL3 locks causing the DPLL not to be locked at times. IMPORTANT: *) This is not a complete workaround implementation as recommended by the silicon erratum. This is a support logic for detecting lockups and attempting to recover where possible and is known to provide stability in multiple platforms. *) This code is mostly important for inactive and retention. The ROM code waits for the maximum DLL lock time when resuming from off mode. So for off mode this code isn't really needed. *) counters are introduced here for eventual export to userspace once the cleanups are completed. This should eventually get refactored as part of cleanups to sleep34xx.S Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Peter 'p2' De Schrijver <peter.de-schrijver@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-21OMAP3: PM: Update clean_l2 to use v7_flush_dcache_allRichard Woodruff
Analysis in TI kernel with ETM showed that using cache mapped flush in kernel instead of SO mapped flush cost drops by 65% (3.39mS down to 1.17mS) for clean_l2 which is used during sleep sequences. Overall: - speed up - unfortunately there isn't a good alternative flush method today - code reduction and less maintenance and potential bug in unmaintained code This also fixes the bug with the clean_l2 function usage. Reported-by: Tony Lindgren <tony@atomide.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Jean Pihet <j-pihet@ti.com> [nm@ti.com: ported rkw's proposal to 2.6.37-rc2] Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Richard Woodruff <r-woodruff2@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
