path: root/arch
2014-01-23sched/x86/tsc: Initialize multiplier to 0Peter Zijlstra
Since we keep the clock value linearly continuous on frequency change, make sure the initial multiplier is 0, such that our initial value is 0. Without this we compute the initial value at whatever the TSC has managed to reach since power-on. Reported-and-Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de> Fixes: 20d1c86a57762 ("sched/clock, x86: Rewrite cyc2ns() to avoid the need to disable IRQs") Cc: lenb@kernel.org Cc: rjw@rjwysocki.net Cc: Eliezer Tamir <eliezer.tamir@linux.intel.com> Cc: rui.zhang@intel.com Cc: jacob.jun.pan@linux.intel.com Cc: Mike Galbraith <bitbucket@online.de> Cc: hpa@zytor.com Cc: paulmck@linux.vnet.ibm.com Cc: John Stultz <john.stultz@linaro.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: dyoung@redhat.com Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140123094804.GP30183@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-20Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 uapi changes from Peter Anvin: "This is the first few of a set of patches by H.J. Lu to make the kernel uapi headers usable for x32, as required by some non-glibc libcs. These particular patches make the stat and statfs structures usable" * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, x32: Use __kernel_long_t for __statfs_word x86, x32: Use __kernel_long_t/__kernel_ulong_t in x86-64 stat.h
2014-01-20Merge branch 'x86/mpx' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tipLinus Torvalds
Pull x86 cpufeature and mpx updates from Peter Anvin: "This includes the basic infrastructure for MPX (Memory Protection Extensions) support, but does not include MPX support itself. It is, however, a prerequisite for KVM support for MPX, which I believe will be pushed later this merge window by the KVM team. This includes moving the functionality in futex_atomic_cmpxchg_inatomic() into a new function in uaccess.h so it can be reused - this will be used by the final MPX patches. The actual MPX functionality (map management and so on) will be pushed in a future merge window, when ready" * 'x86/mpx' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/intel/mpx: Remove unused LWP structure x86, mpx: Add MPX related opcodes to the x86 opcode map x86: replace futex_atomic_cmpxchg_inatomic() with user_atomic_cmpxchg_inatomic x86: add user_atomic_cmpxchg_inatomic at uaccess.h x86, xsave: Support eager-only xsave features, add MPX support x86, cpufeature: Define the Intel MPX feature flag
2014-01-20Merge branch 'x86-kaslr-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 kernel address space randomization support from Peter Anvin: "This enables kernel address space randomization for x86" * 'x86-kaslr-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, kaslr: Clarify RANDOMIZE_BASE_MAX_OFFSET x86, kaslr: Remove unused including <linux/version.h> x86, kaslr: Use char array to gain sizeof sanity x86, kaslr: Add a circular multiply for better bit diffusion x86, kaslr: Mix entropy sources together as needed x86/relocs: Add percpu fixup for GNU ld 2.23 x86, boot: Rename get_flags() and check_flags() to *_cpuflags() x86, kaslr: Raise the maximum virtual address to -1 GiB on x86_64 x86, kaslr: Report kernel offset on panic x86, kaslr: Select random position from e820 maps x86, kaslr: Provide randomness functions x86, kaslr: Return location from decompress_kernel x86, boot: Move CPU flags out of cpucheck x86, relocs: Add more per-cpu gold special cases
2014-01-20Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull leftover x86 fixes from Ingo Molnar: "Two leftover fixes that did not make it into v3.13" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Add check for number of available vectors before CPU down x86, cpu, amd: Add workaround for family 16h, erratum 793
2014-01-20Merge branch 'x86-ras-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 RAS changes from Ingo Molnar: - SCI reporting for other error types not only correctable ones - GHES cleanups - Add the functionality to override error reporting agents as some machines are sporting a new extended error logging capability which, if done properly in the BIOS, makes a corresponding EDAC module redundant - PCIe AER tracepoint severity levels fix - Error path correction for the mce device init - MCE timer fix - Add more flexibility to the error injection (EINJ) debugfs interface * 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, mce: Fix mce_start_timer semantics ACPI, APEI, GHES: Cleanup ghes memory error handling ACPI, APEI: Cleanup alignment-aware accesses ACPI, APEI, GHES: Do not report only correctable errors with SCI ACPI, APEI, EINJ: Changes to the ACPI/APEI/EINJ debugfs interface ACPI, eMCA: Combine eMCA/EDAC event reporting priority EDAC, sb_edac: Modify H/W event reporting policy EDAC: Add an edac_report parameter to EDAC PCI, AER: Fix severity usage in aer trace event x86, mce: Call put_device on device_register failure
2014-01-20Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull Intel SoC changes from Ingo Molnar: "Improved Intel SoC platform support" * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, tsc, apic: Unbreak static (MSR) calibration when CONFIG_X86_LOCAL_APIC=n x86, tsc: Add static (MSR) TSC calibration on Intel Atom SoCs arch: x86: New MailBox support driver for Intel SOC's
2014-01-20Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm changes from Ingo Molnar: "A cleanup, a fix and ASLR support for hugetlb mappings" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mm/numa: Fix 32-bit kernel NUMA boot x86/mm: Implement ASLR for hugetlb mappings x86/mm: Unify pte_to_pgoff() and pgoff_to_pte() helpers
2014-01-20Merge branch 'x86-microcode-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 microcode loader updates from Ingo Molnar: "There are two main changes in this tree: - AMD microcode early loading fixes - some microcode loader source files reorganization" * 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, microcode: Move to a proper location x86, microcode, AMD: Fix early ucode loading x86, microcode: Share native MSR accessing variants x86, ramdisk: Export relocated ramdisk VA
2014-01-20Merge branch 'x86-intel-mid-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull Intel MID updates from Ingo Molnar: "This tree improves Intel MID (Mobile Internet Device) platform support: - Merrifield platform support (David Cohen) - Clovertrail platform support (Kuppuswamy Sathyanarayanan) - Various cleanups and fixes (David Cohen)" * 'x86-intel-mid-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, intel_mid: Replace memcpy with struct assignment x86, intel-mid: Return proper error code from get_gpio_by_name() x86, intel-mid: Check get_gpio_by_name() error code on platform code x86, intel-mid: sfi_handle_*_dev() should check for pdata error code x86, intel-mid: Remove deprecated X86_MDFLD and X86_WANT_INTEL_MID configs x86, intel-mid: Add Merrifield platform support x86, intel-mid: Add Clovertrail platform support x86, intel-mid: Move Medfield code out of intel-mid.c core file
2014-01-20Merge branch 'x86-efi-kexec-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 EFI changes from Ingo Molnar: "This consists of two main parts: - New static EFI runtime services virtual mapping layout which is groundwork for kexec support on EFI (Borislav Petkov) - EFI kexec support itself (Dave Young)" * 'x86-efi-kexec-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) x86/efi: parse_efi_setup() build fix x86: ksysfs.c build fix x86/efi: Delete superfluous global variables x86: Reserve setup_data ranges late after parsing memmap cmdline x86: Export x86 boot_params to sysfs x86: Add xloadflags bit for EFI runtime support on kexec x86/efi: Pass necessary EFI data for kexec via setup_data efi: Export EFI runtime memory mapping to sysfs efi: Export more EFI table variables to sysfs x86/efi: Cleanup efi_enter_virtual_mode() function x86/efi: Fix off-by-one bug in EFI Boot Services reservation x86/efi: Add a wrapper function efi_map_region_fixed() x86/efi: Remove unused variables in __map_region() x86/efi: Check krealloc return value x86/efi: Runtime services virtual mapping x86/mm/cpa: Map in an arbitrary pgd x86/mm/pageattr: Add last levels of error path x86/mm/pageattr: Add a PUD error unwinding path x86/mm/pageattr: Add a PTE pagetable populating function x86/mm/pageattr: Add a PMD pagetable populating function ...
2014-01-20Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 TLB detection update from Ingo Molnar: "A single change that extends our TLB cache size detection+reporting code" * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, cpu: Detect more TLB configuration
2014-01-20Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cleanups from Ingo Molnar: "Misc cleanups" * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, cpu, amd: Fix a shadowed variable situation um, x86: Fix vDSO build x86: Delete non-required instances of include <linux/init.h> x86, realmode: Pointer walk cleanups, pull out invariant use of __pa() x86/traps: Clean up error exception handler definitions
2014-01-20Merge branch 'x86-build-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/build changes from Ingo Molnar: "Misc smaller improvements" * 'x86-build-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, boot: Move intcall() to the .inittext section x86, boot: Use .code16 instead of .code16gcc x86, sparse: Do not force removal of __user when calling copy_to/from_user_nocheck()
2014-01-20Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/asm changes from Ingo Molnar: "Misc optimizations" * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Slightly tweak the access_ok() C variant for better code x86: Replace assembly access_ok() with a C variant x86-64, copy_user: Use leal to produce 32-bit results x86-64, copy_user: Remove zero byte check before copy user buffer.
2014-01-20Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/apic changes from Ingo Molnar: "Two main changes: - improve local APIC Error Status Register reporting robustness - add the 'disable_cpu_apicid=x' boot parameter for kexec booting" * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, apic: Make disabled_cpu_apicid static read_mostly, fix typos x86, apic, kexec: Add disable_cpu_apicid kernel parameter x86/apic: Read Error Status Register correctly
2014-01-20Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer changes from Ingo Molnar: - ARM clocksource/clockevent improvements and fixes - generic timekeeping updates: TAI fixes/improvements, cleanups - Posix cpu timer cleanups and improvements - dynticks updates: full dynticks bugfixes, optimizations and cleanups * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) clocksource: Timer-sun5i: Switch to sched_clock_register() timekeeping: Remove comment that's mostly out of date rtc-cmos: Add an alarm disable quirk timekeeper: fix comment typo for tk_setup_internals() timekeeping: Fix missing timekeeping_update in suspend path timekeeping: Fix CLOCK_TAI timer/nanosleep delays tick/timekeeping: Call update_wall_time outside the jiffies lock timekeeping: Avoid possible deadlock from clock_was_set_delayed timekeeping: Fix potential lost pv notification of time change timekeeping: Fix lost updates to tai adjustment clocksource: sh_cmt: Add clk_prepare/unprepare support clocksource: bcm_kona_timer: Remove unused bcm_timer_ids clocksource: vt8500: Remove deprecated IRQF_DISABLED clocksource: tegra: Remove deprecated IRQF_DISABLED clocksource: misc drivers: Remove deprecated IRQF_DISABLED clocksource: sh_mtu2: Remove unnecessary platform_set_drvdata() clocksource: sh_tmu: Remove unnecessary platform_set_drvdata() clocksource: armada-370-xp: Enable timer divider only when needed clocksource: clksrc-of: Warn if no clock sources are found clocksource: orion: Switch to sched_clock_register() ...
2014-01-20x86/intel/mpx: Remove unused LWP structureIngo Molnar
We don't support LWP yet, don't give the impression that we do: represent the LWP state as opaque 128 bytes, the way Linux sees it currently. Cc: Qiaowei Ren <qiaowei.ren@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-ecarmjtfKpanpAapfck6dj6g@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-20Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: - Add the initial implementation of SCHED_DEADLINE support: a real-time scheduling policy where tasks that meet their deadlines and periodically execute their instances in less than their runtime quota see real-time scheduling and won't miss any of their deadlines. Tasks that go over their quota get delayed (Available to privileged users for now) - Clean up and fix preempt_enable_no_resched() abuse all around the tree - Do sched_clock() performance optimizations on x86 and elsewhere - Fix and improve auto-NUMA balancing - Fix and clean up the idle loop - Apply various cleanups and fixes * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (60 commits) sched: Fix __sched_setscheduler() nice test sched: Move SCHED_RESET_ON_FORK into attr::sched_flags sched: Fix up attr::sched_priority warning sched: Fix up scheduler syscall LTP fails sched: Preserve the nice level over sched_setscheduler() and sched_setparam() calls sched/core: Fix htmldocs warnings sched/deadline: No need to check p if dl_se is valid sched/deadline: Remove unused variables sched/deadline: Fix sparse static warnings m68k: Fix build warning in mac_via.h sched, thermal: Clean up preempt_enable_no_resched() abuse sched, net: Fixup busy_loop_us_clock() sched, net: Clean up preempt_enable_no_resched() abuse sched/preempt: Fix up missed PREEMPT_NEED_RESCHED folding sched/preempt, locking: Rework local_bh_{dis,en}able() sched/clock, x86: Avoid a runtime condition in native_sched_clock() sched/clock: Fix up clear_sched_clock_stable() sched/clock, x86: Use a static_key for sched_clock_stable sched/clock: Remove local_irq_disable() from the clocks sched/clock, x86: Rewrite cyc2ns() to avoid the need to disable IRQs ...
2014-01-20Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Kernel side changes: - Add Intel RAPL energy counter support (Stephane Eranian) - Clean up uprobes (Oleg Nesterov) - Optimize ring-buffer writes (Peter Zijlstra) Tooling side changes, user visible: - 'perf diff': - Add column colouring improvements (Ramkumar Ramachandra) - 'perf kvm': - Add guest related improvements, including allowing to specify a directory with guest specific /proc information (Dongsheng Yang) - Add shell completion support (Ramkumar Ramachandra) - Add '-v' option (Dongsheng Yang) - Support --guestmount (Dongsheng Yang) - 'perf probe': - Support showing source code, asking for variables to be collected at probe time and other 'perf probe' operations that use DWARF information. This supports only binaries with debugging information at this time, detached debuginfo (aka debuginfo packages) support should come in later patches (Masami Hiramatsu) - 'perf record': - Rename --no-delay option to --no-buffering, better reflecting its purpose and freeing up '--delay' to take the place of '--initial-delay', so that 'record' and 'stat' are consistent (Arnaldo Carvalho de Melo) - Default the -t/--thread option to no inheritance (Adrian Hunter) - Make per-cpu mmaps the default (Adrian Hunter) - 'perf report': - Improve callchain processing performance (Frederic Weisbecker) - Retain bfd reference to lookup source line numbers, greatly optimizing, among other use cases, 'perf report -s srcline' (Adrian Hunter) - Improve callchain processing performance even more (Namhyung Kim) - Add a perf.data file header window in the 'perf report' TUI, associated with the 'i' hotkey, providing a counterpart to the --header option in the stdio UI (Namhyung Kim) - 'perf script': - Add an option in 'perf script' to print the source line number (Adrian Hunter) - Add --header/--header-only options to 'script' and 'report', the default is not tho show the header info, but as this has been the default for some time, leave a single line explaining how to obtain that information (Jiri Olsa) - Add options to show comm, fork, exit and mmap PERF_RECORD_ events (Namhyung Kim) - Print callchains and symbols if they exist (David Ahern) - 'perf timechart' - Add backtrace support to CPU info - Print pid along the name - Add support for CPU topology - Add new option --highlight'ing threads, be it by name or, if a numeric value is provided, that run more than given duration (Stanislav Fomichev) - 'perf top': - Make 'perf top -g' refer to callchains, for consistency with other tools (David Ahern) - 'perf trace': - Handle old kernels where the "raw_syscalls" tracepoints were called plain "syscalls" (David Ahern) - Remove thread summary coloring, by Pekka Enberg. - Honour -m option in 'trace', the tool was offering the option to set the mmap size, but wasn't using it when doing the actual mmap on the events file descriptors (Jiri Olsa) - generic: - Backport libtraceevent plugin support (trace-cmd repository, with plugins for jbd2, hrtimer, kmem, kvm, mac80211, sched_switch, function, xen, scsi, cfg80211 (Jiri Olsa) - Print session information only if --stdio is given (Namhyung Kim) Tooling side changes, developer visible (plumbing): - Improve 'perf probe' exit path, release resources (Masami Hiramatsu) - Improve libtraceevent plugins exit path, allowing the registering of an unregister handler to be called at exit time (Namhyung Kim) - Add an alias to the build test makefile (make -C tools/perf build-test) (Namhyung Kim) - Get rid of die() and friends (good riddance!) in libtraceevent (Namhyung Kim) - Fix cross build problems related to pkgconfig and CROSS_COMPILE not being propagated to the feature tests, leading to features being tested in the host and then being enabled on the target (Mark Rutland) - Improve forked workload error reporting by sending the errno in the signal data queueing integer field, using sigqueue and by doing the signal setup in the evlist methods, removing open coded equivalents in various tools (Arnaldo Carvalho de Melo) - Do more auto exit cleanup chores in the 'evlist' destructor, so that the tools don't have to all do that sequence (Arnaldo Carvalho de Melo) - Pack 'struct perf_session_env' and 'struct trace' (Arnaldo Carvalho de Melo) - Add test for building detached source tarballs (Arnaldo Carvalho de Melo) - Move some header files (tools/perf/ to tools/include/ to make them available to other tools/ dwelling codebases (Namhyung Kim) - Move logic to warn about kptr_restrict'ed kernels to separate function in 'report' (Arnaldo Carvalho de Melo) - Move hist browser selection code to separate function (Arnaldo Carvalho de Melo) - Move histogram entries collapsing to separate function (Arnaldo Carvalho de Melo) - Introduce evlist__for_each() & friends (Arnaldo Carvalho de Melo) - Automate setup of FEATURE_CHECK_(C|LD)FLAGS-all variables (Jiri Olsa) - Move arch setup into seprate Makefile (Jiri Olsa) - Make libtraceevent install target quieter (Jiri Olsa) - Make tests/make output more compact (Jiri Olsa) - Ignore generated files in feature-checks (Chunwei Chen) - Introduce pevent_filter_strerror() in libtraceevent, similar in purpose to libc's strerror() function (Namhyung Kim) - Use perf_data_file methods to write output file in 'record' and 'inject' (Jiri Olsa) - Use pr_*() functions where applicable in 'report' (Namhyumg Kim) - Add 'machine' 'addr_location' struct to have full picture (machine, thread, map, symbol, addr) for a (partially) resolved address, reducing function signatures (Arnaldo Carvalho de Melo) - Reduce code duplication in the histogram entry creation/insertion (Arnaldo Carvalho de Melo) - Auto allocate annotation histogram data structures (Arnaldo Carvalho de Melo) - No need to test against NULL before calling free, also set freed memory in struct pointers to NULL, to help fixing use after free bugs (Arnaldo Carvalho de Melo) - Rename some struct DSO binary_type related members and methods, to clarify its purpose and need for differentiation (symtab_type, ie one is about the files .text, CFI, etc, i.e. its binary contents, and the other is about where the symbol table came from (Arnaldo Carvalho de Melo) - Convert to new topic libraries, starting with an API one (sysfs, debugfs, etc), renaming liblk in the process (Borislav Petkov) - Get rid of some more panic() like error handling in libtraceevent. (Namhyung Kim) - Get rid of panic() like calls in libtraceevent (Namyung Kim) - Start carving out symbol parsing routines (perf, just moving routines to topic files in tools/lib/symbol/, tools that want to use it need to integrate it directly, ie no tools/lib/symbol/Makefile is provided (Arnaldo Carvalho de Melo) - Assorted refactoring patches, moving code around and adding utility evlist methods that will be used in the IPT patchset (Adrian Hunter) - Assorted mmap_pages handling fixes (Adrian Hunter) - Several man pages typo fixes (Dongsheng Yang) - Get rid of several die() calls in libtraceevent (Namhyung Kim) - Use basename() in a more robust way, to avoid problems related to different system library implementations for that function (Stephane Eranian) - Remove open coded management of short_name_allocated member (Adrian Hunter) - Several cleanups in the "dso" methods, constifying some parameters and renaming some fields to clarify its purpose (Arnaldo Carvalho de Melo) - Add per-feature check flags, fixing libunwind related build problems on some architectures (Jean Pihet) - Do not disable source line lookup just because of one failure. (Adrian Hunter) - Several 'perf kvm' man page corrections (Dongsheng Yang) - Correct the message in feature-libnuma checking, swowing the right devel package names for various distros (Dongsheng Yang) - Polish 'readn()' function and introduce its counterpart, 'writen()' (Jiri Olsa) - Start moving timechart state from global variables to a 'perf_tool' derived 'timechart' struct (Arnaldo Carvalho de Melo) ... and lots of fixes and improvements I forgot to list" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (282 commits) perf tools: Remove unnecessary callchain cursor state restore on unmatch perf callchain: Spare double comparison of callchain first entry perf tools: Do proper comm override error handling perf symbols: Export elf_section_by_name and reuse perf probe: Release all dynamically allocated parameters perf probe: Release allocated probe_trace_event if failed perf tools: Add 'build-test' make target tools lib traceevent: Unregister handler when xen plugin is unloaded tools lib traceevent: Unregister handler when scsi plugin is unloaded tools lib traceevent: Unregister handler when jbd2 plugin is is unloaded tools lib traceevent: Unregister handler when cfg80211 plugin is unloaded tools lib traceevent: Unregister handler when mac80211 plugin is unloaded tools lib traceevent: Unregister handler when sched_switch plugin is unloaded tools lib traceevent: Unregister handler when kvm plugin is unloaded tools lib traceevent: Unregister handler when kmem plugin is unloaded tools lib traceevent: Unregister handler when hrtimer plugin is unloaded tools lib traceevent: Unregister handler when function plugin is unloaded tools lib traceevent: Add pevent_unregister_print_function() tools lib traceevent: Add pevent_unregister_event_handler() tools lib traceevent: fix pointer-integer size mismatch ...
2014-01-20Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull IRQ changes from Ingo Molnar: "The only change in this cycle is a CPU hotplug related spurious warning fix" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/irq: Fix kbuild warning in smp_irq_move_cleanup_interrupt() x86/irq: Fix do_IRQ() interrupt warning for cpu hotplug retriggered irqs
2014-01-20Merge branch 'core-stackprotector-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull strong stackprotector support from Ingo Molnar: "This tree adds a CONFIG_CC_STACKPROTECTOR_STRONG=y, a new, stronger stack canary checking method supported by the newest GCC versions (4.9 and later). Here's the 'intensity comparison' between the various protection modes: - defconfig 11430641 kernel text size 36110 function bodies - defconfig + CONFIG_CC_STACKPROTECTOR_REGULAR 11468490 kernel text size (+0.33%) 1015 of 36110 functions are stack-protected (2.81%) - defconfig + CONFIG_CC_STACKPROTECTOR_STRONG via this patch 11692790 kernel text size (+2.24%) 7401 of 36110 functions are stack-protected (20.5%) the strong model comes with non-trivial costs, which is why we preserved the 'regular' and 'none' models as well" * 'core-stackprotector-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: stackprotector: Introduce CONFIG_CC_STACKPROTECTOR_STRONG stackprotector: Unify the HAVE_CC_STACKPROTECTOR logic between architectures
2014-01-20Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking changes from Ingo Molnar: - futex performance increases: larger hashes, smarter wakeups - mutex debugging improvements - lots of SMP ordering documentation updates - introduce the smp_load_acquire(), smp_store_release() primitives. (There are WIP patches that make use of them - not yet merged) - lockdep micro-optimizations - lockdep improvement: better cover IRQ contexts - liblockdep at last. We'll continue to monitor how useful this is * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (34 commits) futexes: Fix futex_hashsize initialization arch: Re-sort some Kbuild files to hopefully help avoid some conflicts futexes: Avoid taking the hb->lock if there's nothing to wake up futexes: Document multiprocessor ordering guarantees futexes: Increase hash table size for better performance futexes: Clean up various details arch: Introduce smp_load_acquire(), smp_store_release() arch: Clean up asm/barrier.h implementations using asm-generic/barrier.h arch: Move smp_mb__{before,after}_atomic_{inc,dec}.h into asm/atomic.h locking/doc: Rename LOCK/UNLOCK to ACQUIRE/RELEASE mutexes: Give more informative mutex warning in the !lock->owner case powerpc: Full barrier for smp_mb__after_unlock_lock() rcu: Apply smp_mb__after_unlock_lock() to preserve grace periods Documentation/memory-barriers.txt: Downgrade UNLOCK+BLOCK locking: Add an smp_mb__after_unlock_lock() for UNLOCK+BLOCK barrier Documentation/memory-barriers.txt: Document ACCESS_ONCE() Documentation/memory-barriers.txt: Prohibit speculative writes Documentation/memory-barriers.txt: Add long atomic examples to memory-barriers.txt Documentation/memory-barriers.txt: Add needed ACCESS_ONCE() calls to memory-barriers.txt Revert "smp/cpumask: Make CONFIG_CPUMASK_OFFSTACK=y usable without debug dependency" ...
2014-01-20Merge branch 'core-debug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core debug changes from Ingo Molnar: "Currently there are two methods to set the panic_timeout: via 'panic=X' boot commandline option, or via /proc/sys/kernel/panic. This tree adds a third panic_timeout configuration method: configuration via Kconfig, via CONFIG_PANIC_TIMEOUT=X - useful to distros that generally want their kernel defaults to come with the .config. CONFIG_PANIC_TIMEOUT defaults to 0, which was the previous default value of panic_timeout. Doing that unearthed a few arch trickeries regarding arch-special panic_timeout values and related complications - hopefully all resolved to the satisfaction of everyone" * 'core-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: powerpc: Clean up panic_timeout usage MIPS: Remove panic_timeout settings panic: Make panic_timeout configurable
2014-01-20Merge tag 'please-pull-rm_xen' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull ia64 Xen removal from Tony Luck: "Nobody has been maintaining xen in ia64 for a long time. Rip it all out so people do not waste time making updates to broken/dead code" * tag 'please-pull-rm_xen' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: ia64/xen: Remove Xen support for ia64
2014-01-20Merge tag 'metag-for-v3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull Metag architecture changes from James Hogan: - A few cleanups and minor bug fixes. - Kill SMP single function call IPI. * tag 'metag-for-v3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: metag/smp: Make boot_secondary() static metag: topology: export 'cpu_core_map' smp, metag: kill SMP single function call interrupt metag: smp: don't set irq regs in do_IPI() metag: dma: remove dead code in dma_alloc_init()
2014-01-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven: - Zorro bus cleanups and UAPI revival - Bootinfo cleanups and UAPI revival - Kexec support - Memory size reductions and bug fixes for multi-platform kernels - Polled interrupt support for Atari EtherNAT, EtherNEC and NetUSBee - Machine-specific random_get_entropy() - Defconfig updates and cleanups * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (46 commits) m68k/mac: Make SCC reset work more reliably m68k/irq - Use polled IRQ flag for MFP timer cascaded interrupts m68k: Update defconfigs for v3.13-rc1 m68k/defconfig: Enable EARLY_PRINTK m68k/mm: kmap spelling/grammar fixes m68k: Convert arch/m68k/kernel/traps.c to pr_*() m68k: Convert arch/m68k/mm/fault.c to pr_*() m68k/mm: Check for mm != NULL in do_page_fault() debug code m68k/defconfig: Disable /sbin/hotplug fork-bomb by default m68k/atari: Hide RTC_PORT() macro from rtc-cmos m68k/amiga,atari: Fix specifying multiple debug= parameters m68k/defconfig: Use ext4 for ext2/ext3 file systems m68k: Add support to export bootinfo in procfs m68k: Add kexec support m68k/mac: Mark Mac IIsi ADB driver BROKEN m68k/amiga: Provide mach_random_get_entropy() m68k: Add infrastructure for machine-specific random_get_entropy() m68k/atari: Call paging_init() before nf_init() m68k: Remove superfluous inclusions of <asm/bootinfo.h> m68k/UAPI: Use proper types (endianness/size) in <asm/bootinfo*.h> ...
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "The bulk of the s390 updates for v3.14. New features are the perf support for the CPU-Measurement Sample Facility and the EP11 support for the crypto cards. And the normal cleanups and bug-fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (44 commits) s390/cpum_sf: fix printk format warnings s390: Fix misspellings using 'codespell' tool s390/qdio: bridgeport support - CHSC part s390: delete new instances of __cpuinit usage s390/compat: fix PSW32_USER_BITS definition s390/zcrypt: add support for EP11 coprocessor cards s390/mm: optimize randomize_et_dyn for !PF_RANDOMIZE s390: use IS_ENABLED to check if a CONFIG is set to y or m s390/cio: use device_lock to synchronize calls to the ccwgroup driver s390/cio: use device_lock to synchronize calls to the ccw driver s390/cio: fix unlocked access of online member s390/cpum_sf: Add flag to process full SDBs only s390/cpum_sf: Add raw data sampling to support the diagnostic-sampling function s390/cpum_sf: Filter perf events based event->attr.exclude_* settings s390/cpum_sf: Detect KVM guest samples s390/cpum_sf: Add helper to read TOD from trailer entries s390/cpum_sf: Atomically reset trailer entry fields of sample-data-blocks s390/cpum_sf: Dynamically extend the sampling buffer if overflows occur s390/pci: reenable per default s390/pci/dma: fix accounting of allocated_pages ...
2014-01-19Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: - an s2ram related fix on AMD systems - a perf fault handling bug that is relatively old but which has become much easier to trigger in v3.13 after commit e00b12e64be9 ("perf/x86: Further optimize copy_from_user_nmi()") * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/amd/ibs: Fix waking up from S3 for AMD family 10h x86, mm, perf: Allow recursive faults from interrupts
2014-01-19m68k/mac: Make SCC reset work more reliablyFinn Thain
For SCC initialization we cannot assume that the control register is in the correct state to accept a register pointer. So first read from the control register in order to "sync" up. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2014-01-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) The value choosen for the new SO_MAX_PACING_RATE socket option on parisc was very poorly choosen, let's fix it while we still can. From Eric Dumazet. 2) Our generic reciprocal divide was found to handle some edge cases incorrectly, part of this is encoded into the BPF as deep as the JIT engines themselves. Just use a real divide throughout for now. From Eric Dumazet. 3) Because the initial lookup is lockless, the TCP metrics engine can end up creating two entries for the same lookup key. Fix this by doing a second lookup under the lock before we actually create the new entry. From Christoph Paasch. 4) Fix scatter-gather list init in usbnet driver, from Bjørn Mork. 5) Fix unintended 32-bit truncation in cxgb4 driver's bit shifting. From Dan Carpenter. 6) Netlink socket dumping uses the wrong socket state for timewait sockets. Fix from Neal Cardwell. 7) Fix netlink memory leak in ieee802154_add_iface(), from Christian Engelmayer. 8) Multicast forwarding in ipv4 can overflow the per-rule reference counts, causing all multicast traffic to cease. Fix from Hannes Frederic Sowa. 9) via-rhine needs to stop all TX queues when it resets the device, from Richard Weinberger. 10) Fix RDS per-cpu accesses broken by the this_cpu_* conversions. From Gerald Schaefer. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: s390/bpf,jit: fix 32 bit divisions, use unsigned divide instructions parisc: fix SO_MAX_PACING_RATE typo ipv6: simplify detection of first operational link-local address on interface tcp: metrics: Avoid duplicate entries with the same destination-IP net: rds: fix per-cpu helper usage e1000e: Fix compilation warning when !CONFIG_PM_SLEEP bpf: do not use reciprocal divide be2net: add dma_mapping_error() check for dma_map_page() bnx2x: Don't release PCI bars on shutdown net,via-rhine: Fix tx_timeout handling batman-adv: fix batman-adv header overhead calculation qlge: Fix vlan netdev features. net: avoid reference counter overflows on fib_rules in multicast forwarding dm9601: add USB IDs for new dm96xx variants MAINTAINERS: add virtio-dev ML for virtio ieee802154: Fix memory leak in ieee802154_add_iface() net: usbnet: fix SG initialisation inet_diag: fix inet_diag_dump_icsk() to use correct state for timewait sockets cxgb4: silence shift wrapping static checker warning
2014-01-17s390/bpf,jit: fix 32 bit divisions, use unsigned divide instructionsHeiko Carstens
The s390 bpf jit compiler emits the signed divide instructions "dr" and "d" for unsigned divisions. This can cause problems: the dividend will be zero extended to a 64 bit value and the divisor is the 32 bit signed value as specified A or X accumulator, even though A and X are supposed to be treated as unsigned values. The divide instrunctions will generate an exception if the result cannot be expressed with a 32 bit signed value. This is the case if e.g. the dividend is 0xffffffff and the divisor either 1 or also 0xffffffff (signed: -1). To avoid all these issues simply use unsigned divide instructions. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-17parisc: fix SO_MAX_PACING_RATE typoEric Dumazet
SO_MAX_PACING_RATE definition on parisc got a typo. Its not too late to fix it, before 3.13 is official. Fixes: 62748f32d501 ("net: introduce SO_MAX_PACING_RATE") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-17Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fix from Paolo Bonzini: "Fix for a brown paper bag bug. Thanks to Drew Jones for noticing" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: kvm: x86: fix apic_base enable check
2014-01-17x86, mpx: Add MPX related opcodes to the x86 opcode mapQiaowei Ren
This patch adds all the MPX instructions to x86 opcode map, so the x86 instruction decoder can decode MPX instructions. Signed-off-by: Qiaowei Ren <qiaowei.ren@intel.com> Link: http://lkml.kernel.org/r/1389518403-7715-4-git-send-email-qiaowei.ren@intel.com Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-17Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fix from Catalin Marinas: "Revert "arm64: Fix memory shareability attribute for ioremap_wc/cache" We noticed that it breaks ioremap (and earlyprintk) with 64K page configuration" * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: Revert "arm64: Fix memory shareability attribute for ioremap_wc/cache"
2014-01-16x86, intel_mid: Replace memcpy with struct assignmentFengguang Wu
This is a cleanup proposed by coccinelle. It replaces memcpy with struct assignment on intel-mid's sfi layer. Generated by: coccinelle/misc/memcpy-assign.cocci Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Link: http://lkml.kernel.org/r/1389917588-9785-1-git-send-email-david.a.cohen@linux.intel.com Signed-off-by: David Cohen <david.a.cohen@linux.intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-16x86, intel-mid: Return proper error code from get_gpio_by_name()David Cohen
This patch cleans up get_gpio_by_name() to return an error code instead of hardcoded -1. Signed-off-by: David Cohen <david.a.cohen@linux.intel.com> Link: http://lkml.kernel.org/r/1389913624-9149-4-git-send-email-david.a.cohen@linux.intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-16x86, intel-mid: Check get_gpio_by_name() error code on platform codeDavid Cohen
This patch does cleanup on all intel mid platform code that uses gpio_get_by_name() function. From now on they should check for any error code instead of only hardcoded -1. There are no functional changes from this change. Signed-off-by: David Cohen <david.a.cohen@linux.intel.com> Link: http://lkml.kernel.org/r/1389913624-9149-3-git-send-email-david.a.cohen@linux.intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-16x86, intel-mid: sfi_handle_*_dev() should check for pdata error codeDavid Cohen
When Intel MID finds a match between SFI table from FW and registered SFI devices, it will always register a device regardless the platform code was successful or not. This patch adds an extra option for platform code to return error code and abort device registration on SFI table parsing. This patch does not contain any functional changes for current intel mid platform code. Signed-off-by: David Cohen <david.a.cohen@linux.intel.com> Link: http://lkml.kernel.org/r/1389913624-9149-2-git-send-email-david.a.cohen@linux.intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-16x86, tsc, apic: Unbreak static (MSR) calibration when CONFIG_X86_LOCAL_APIC=nH. Peter Anvin
If we aren't going to use the local APIC anyway, we obviously don't care about its timer frequency. Link: http://lkml.kernel.org/r/tip-rgm7xmg7k6qnjlw3ynkcjsmh@git.kernel.org Reported-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Bin Gao <bin.gao@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-16Revert "arm64: Fix memory shareability attribute for ioremap_wc/cache"Catalin Marinas
This reverts commit 2f7dc6027522499582a520807cb9ffda589de47e. The above commit breaks the mapping type for Device memory because pgprot_default already contains a Normal memory type. pgprot_default is also not initialised early enough for earlyprintk resulting in an inconsistent memory mapping with 64K PAGE_SIZE configuration. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Will Deacon <will.deacon@arm.com> Acked-by: Will Deacon <will.deacon@arm.com>
2014-01-16s390/cpum_sf: fix printk format warningsHendrik Brueckner
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-01-16s390: Fix misspellings using 'codespell' toolHendrik Brueckner
2014-01-16Merge branch 'perf/urgent' into perf/coreIngo Molnar
Pick up the latest fixes, refresh the development tree. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-16m68k: Fix build warning in mac_via.hPeter Zijlstra
Fengguang Wu's kbuild test robot reported the following new m68k warnings: In file included from drivers/nubus/nubus.c:22:0: >> arch/m68k/include/asm/mac_via.h:262:47: warning: 'struct irq_desc' declared inside parameter list [enabled by default] >> arch/m68k/include/asm/mac_via.h:262:47: warning: its scope is only this definition or declaration, which is probably not what you want [enabled by default] Caused by the reworking of the generic local_bh{dis,en}able() code. To fix it, forward declare 'struct irq_desc'. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Fixes: c795eb55e740 ("sched/preempt, locking: Rework local_bh_{dis,en}able()") Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: geert@linux-m68k.org Link: http://lkml.kernel.org/r/20140112212456.GQ7572@laptop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-16perf/x86/amd/ibs: Fix waking up from S3 for AMD family 10hRobert Richter
On AMD family 10h we see following error messages while waking up from S3 for all non-boot CPUs leading to a failed IBS initialization: Enabling non-boot CPUs ... smpboot: Booting Node 0 Processor 1 APIC 0x1 [Firmware Bug]: cpu 1, try to use APIC500 (LVT offset 0) for vector 0x400, but the register is already in use for vector 0xf9 on another cpu perf: IBS APIC setup failed on cpu #1 process: Switch to broadcast mode on CPU1 CPU1 is up ... ACPI: Waking up from system sleep state S3 Reason for this is that during suspend the LVT offset for the IBS vector gets lost and needs to be reinialized while resuming. The offset is read from the IBSCTL msr. On family 10h the offset needs to be 1 as offset 0 is used for the MCE threshold interrupt, but firmware assings it for IBS to 0 too. The kernel needs to reprogram the vector. The msr is a readonly node msr, but a new value can be written via pci config space access. The reinitialization is implemented for family 10h in setup_ibs_ctl() which is forced during IBS setup. This patch fixes IBS setup after waking up from S3 by adding resume/supend hooks for the boot cpu which does the offset reinitialization. Marking it as stable to let distros pick up this fix. Signed-off-by: Robert Richter <rric@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: <stable@vger.kernel.org> v3.2.. Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1389797849-5565-1-git-send-email-rric.net@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-16x86, mm, perf: Allow recursive faults from interruptsPeter Zijlstra
Waiman managed to trigger a PMI while in a emulate_vsyscall() fault, the PMI in turn managed to trigger a fault while obtaining a stack trace. This triggered the sig_on_uaccess_error recursive fault logic and killed the process dead. Fix this by explicitly excluding interrupts from the recursive fault logic. Reported-and-Tested-by: Waiman Long <waiman.long@hp.com> Fixes: e00b12e64be9 ("perf/x86: Further optimize copy_from_user_nmi()") Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Scott J Norton <scott.norton@hp.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140110200603.GJ7572@laptop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-15x86, tsc: Add static (MSR) TSC calibration on Intel Atom SoCsBin Gao
On SoCs that have the calibration MSRs available, either there is no PIT, HPET or PMTIMER to calibrate against, or the PIT/HPET/PMTIMER is driven from the same clock as the TSC, so calibration is redundant and just slows down the boot. TSC rate is caculated by this formula: <maximum core-clock to bus-clock ratio> * <maximum resolved frequency> The ratio and the resolved frequency ID can be obtained from MSR. See Intel 64 and IA-32 System Programming Guid section 16.12 and 30.11.5 for details. Signed-off-by: Bin Gao <bin.gao@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/n/tip-rgm7xmg7k6qnjlw3ynkcjsmh@git.kernel.org
2014-01-15x86: Add check for number of available vectors before CPU downPrarit Bhargava
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=64791 When a cpu is downed on a system, the irqs on the cpu are assigned to other cpus. It is possible, however, that when a cpu is downed there aren't enough free vectors on the remaining cpus to account for the vectors from the cpu that is being downed. This results in an interesting "overflow" condition where irqs are "assigned" to a CPU but are not handled. For example, when downing cpus on a 1-64 logical processor system: <snip> [ 232.021745] smpboot: CPU 61 is now offline [ 238.480275] smpboot: CPU 62 is now offline [ 245.991080] ------------[ cut here ]------------ [ 245.996270] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:264 dev_watchdog+0x246/0x250() [ 246.005688] NETDEV WATCHDOG: p786p1 (ixgbe): transmit queue 0 timed out [ 246.013070] Modules linked in: lockd sunrpc iTCO_wdt iTCO_vendor_support sb_edac ixgbe microcode e1000e pcspkr joydev edac_core lpc_ich ioatdma ptp mdio mfd_core i2c_i801 dca pps_core i2c_core wmi acpi_cpufreq isci libsas scsi_transport_sas [ 246.037633] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.12.0+ #14 [ 246.044451] Hardware name: Intel Corporation S4600LH ........../SVRBD-ROW_T, BIOS SE5C600.86B.01.08.0003.022620131521 02/26/2013 [ 246.057371] 0000000000000009 ffff88081fa03d40 ffffffff8164fbf6 ffff88081fa0ee48 [ 246.065728] ffff88081fa03d90 ffff88081fa03d80 ffffffff81054ecc ffff88081fa13040 [ 246.074073] 0000000000000000 ffff88200cce0000 0000000000000040 0000000000000000 [ 246.082430] Call Trace: [ 246.085174] <IRQ> [<ffffffff8164fbf6>] dump_stack+0x46/0x58 [ 246.091633] [<ffffffff81054ecc>] warn_slowpath_common+0x8c/0xc0 [ 246.098352] [<ffffffff81054fb6>] warn_slowpath_fmt+0x46/0x50 [ 246.104786] [<ffffffff815710d6>] dev_watchdog+0x246/0x250 [ 246.110923] [<ffffffff81570e90>] ? dev_deactivate_queue.constprop.31+0x80/0x80 [ 246.119097] [<ffffffff8106092a>] call_timer_fn+0x3a/0x110 [ 246.125224] [<ffffffff8106280f>] ? update_process_times+0x6f/0x80 [ 246.132137] [<ffffffff81570e90>] ? dev_deactivate_queue.constprop.31+0x80/0x80 [ 246.140308] [<ffffffff81061db0>] run_timer_softirq+0x1f0/0x2a0 [ 246.146933] [<ffffffff81059a80>] __do_softirq+0xe0/0x220 [ 246.152976] [<ffffffff8165fedc>] call_softirq+0x1c/0x30 [ 246.158920] [<ffffffff810045f5>] do_softirq+0x55/0x90 [ 246.164670] [<ffffffff81059d35>] irq_exit+0xa5/0xb0 [ 246.170227] [<ffffffff8166062a>] smp_apic_timer_interrupt+0x4a/0x60 [ 246.177324] [<ffffffff8165f40a>] apic_timer_interrupt+0x6a/0x70 [ 246.184041] <EOI> [<ffffffff81505a1b>] ? cpuidle_enter_state+0x5b/0xe0 [ 246.191559] [<ffffffff81505a17>] ? cpuidle_enter_state+0x57/0xe0 [ 246.198374] [<ffffffff81505b5d>] cpuidle_idle_call+0xbd/0x200 [ 246.204900] [<ffffffff8100b7ae>] arch_cpu_idle+0xe/0x30 [ 246.210846] [<ffffffff810a47b0>] cpu_startup_entry+0xd0/0x250 [ 246.217371] [<ffffffff81646b47>] rest_init+0x77/0x80 [ 246.223028] [<ffffffff81d09e8e>] start_kernel+0x3ee/0x3fb [ 246.229165] [<ffffffff81d0989f>] ? repair_env_string+0x5e/0x5e [ 246.235787] [<ffffffff81d095a5>] x86_64_start_reservations+0x2a/0x2c [ 246.242990] [<ffffffff81d0969f>] x86_64_start_kernel+0xf8/0xfc [ 246.249610] ---[ end trace fb74fdef54d79039 ]--- [ 246.254807] ixgbe 0000:c2:00.0 p786p1: initiating reset due to tx timeout [ 246.262489] ixgbe 0000:c2:00.0 p786p1: Reset adapter Last login: Mon Nov 11 08:35:14 from 10.18.17.119 [root@(none) ~]# [ 246.792676] ixgbe 0000:c2:00.0 p786p1: detected SFP+: 5 [ 249.231598] ixgbe 0000:c2:00.0 p786p1: NIC Link is Up 10 Gbps, Flow Control: RX/TX [ 246.792676] ixgbe 0000:c2:00.0 p786p1: detected SFP+: 5 [ 249.231598] ixgbe 0000:c2:00.0 p786p1: NIC Link is Up 10 Gbps, Flow Control: RX/TX (last lines keep repeating. ixgbe driver is dead until module reload.) If the downed cpu has more vectors than are free on the remaining cpus on the system, it is possible that some vectors are "orphaned" even though they are assigned to a cpu. In this case, since the ixgbe driver had a watchdog, the watchdog fired and notified that something was wrong. This patch adds a function, check_vectors(), to compare the number of vectors on the CPU going down and compares it to the number of vectors available on the system. If there aren't enough vectors for the CPU to go down, an error is returned and propogated back to userspace. v2: Do not need to look at percpu irqs v3: Need to check affinity to prevent counting of MSIs in IOAPIC Lowest Priority Mode v4: Additional changes suggested by Gong Chen. v5/v6/v7/v8: Updated comment text Signed-off-by: Prarit Bhargava <prarit@redhat.com> Link: http://lkml.kernel.org/r/1389613861-3853-1-git-send-email-prarit@redhat.com Reviewed-by: Gong Chen <gong.chen@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Michel Lespinasse <walken@google.com> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Cc: Yang Zhang <yang.z.zhang@Intel.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Janet Morgan <janet.morgan@intel.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Ruiv Wang <ruiv.wang@gmail.com> Cc: Gong Chen <gong.chen@linux.intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: <stable@vger.kernel.org>
