path: root/arch
2008-04-29powerpc: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Add correct ->owner to proc_fops to fix reading/module unloading race. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29parisc: use non-racy method for /proc/pcxl_dma creationDenis V. Lunev
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ia64: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29cris: use non-racy method for /proc/system_profile creationDenis V. Lunev
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29avr32: proc: use non-racy method for /proc/tlb creationDenis V. Lunev
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29arm: use non-racy method for /proc/davinci_clocks creationDenis V. Lunev
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: switch /proc/excite/unit_id to seq_file interfaceAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Thomas Koeller <thomas.koeller@baslerweb.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: switch /proc/bus/ecard/devices to seq_file interfaceAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Yani Ioannou <yani.ioannou@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove /proc/mac_iopAlexey Dobriyan
Entry creation was commented for a long time and right now it stands on the way of ->get_info removal, so unless nobody objects... Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Simon Arlott <simon@fire.lp0.eu> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Joern Engel <joern@wohnheim.fh-wedel.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root from driversAlexey Dobriyan
Remove proc_root export. Creation and removal works well if parent PDE is supplied as NULL -- it worked always that way. So, one useless export removed and consistency added, some drivers created PDEs with &proc_root as parent but removed them as NULL and so on. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_busAlexey Dobriyan
Remove proc_bus export and variable itself. Using pathnames works fine and is slightly more understandable and greppable. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29dma/ia64: update ia64 machvecs, swiotlb.cArthur Kepner
Change all ia64 machvecs to use the new dma_*map*_attrs() interfaces. Implement the old dma_*map_*() interfaces in terms of the corresponding new interfaces. For ia64/sn, make use of one dma attribute, DMA_ATTR_WRITE_BARRIER. Introduce swiotlb_*map*_attrs() functions. Signed-off-by: Arthur Kepner <akepner@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Jes Sorensen <jes@sgi.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29dma: add dma_*map*_attrs() interfacesArthur Kepner
Introduce new interfaces, dma_*map*_attrs(), for passing architecture-specific attributes when memory is mapped and unmapped for DMA. Give the interfaces default implementations which ignore attributes. Also introduce the dma_{set|get}_attr() interfaces for setting and retrieving individual attributes. Define one attribute, DMA_ATTR_WRITE_BARRIER, in anticipation of its use by ia64/sn. Select whether architectures implement arch-specific versions of the dma_*map*_attrs() interfaces via HAVE_DMA_ATTRS in Kconfig. [markn@au1.ibm.com: dma_{set,get}_attr() have to be static inline] Signed-off-by: Arthur Kepner <akepner@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Jes Sorensen <jes@sgi.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Mark Nelson <markn@au1.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29x86: olpc: add One Laptop Per Child architecture supportAndres Salomon
This adds support for OLPC XO hardware. Open Firmware on XOs don't contain the VSA, so it is necessary to emulate the PCI BARs in the kernel. This also adds functionality for running EC commands, and a CONFIG_OLPC. A number of OLPC drivers depend upon CONFIG_OLPC. olpc_ec_timeout is a hack to work around Embedded Controller bugs. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: geode_has_vsa build fix] [akpm@linux-foundation.org: olpc_register_battery_callback doesn't exist] Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@suse.de> Cc: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29swiotlb: use iommu_is_span_boundary helper functionFUJITA Tomonori
iommu_is_span_boundary in lib/iommu-helper.c was exported for PARISC IOMMUs (commit 3715863aa142c4f4c5208f5f3e5e9bac06006d2f). SWIOTLB can use it instead of the homegrown function. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proper extern for late_time_initAdrian Bunk
Add a proper extern for late_time_init in include/linux/init.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Remove the macro get_personalityWANG Cong
Remove the macro get_personality, use ->personality instead. Cc: Christoph Hellwig <hch@infradead.org Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proper __do_softirq() prototypeAdrian Bunk
Add a proper prototype for __do_softirq() in include/linux/interrupt.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29iomap: fix 64 bits resources on 32 bitsBenjamin Herrenschmidt
Almost all implementations of pci_iomap() in the kernel, including the generic lib/iomap.c one, copies the content of a struct resource into unsigned long's which will break on 32 bits platforms with 64 bits resources. This fixes all definitions of pci_iomap() to use resource_size_t. I also "fixed" the 64bits arch for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (35 commits) siimage: coding style cleanup (take 2) ide-cd: clean up cdrom_analyze_sense_data() ide-cd: fix test unsigned var < 0 ide: add TSSTcorp CDDVDW SH-S202H to ivb_list[] piix: add Asus Eee 701 controller to short cable list ARM: always select HAVE_IDE remove the broken ETRAX_IDE driver ide: remove ->dma_prdtable field from ide_hwif_t ide: remove ->dma_vendor{1,3} fields from ide_hwif_t scc_pata: add ->dma_host_set and ->dma_start methods ide: skip "VLB sync" if host uses MMIO ide: add ide_pad_transfer() helper ide: remove ->INW and ->OUTW methods ide: use IDE I/O helpers directly in ide_tf_{load,read}() ns87415: add ->tf_read method scc_pata: add ->tf_{load,read} methods ide-h8300: add ->tf_{load,read} methods ide-cris: add ->tf_{load,read} methods ide: add ->tf_load and ->tf_read methods ide: move ide_tf_{load,read} to ide-iops.c ...
2008-04-28ARM: always select HAVE_IDEAdrian Bunk
It's plain wrong for PCMCIA to select HAVE_IDE that implies e.g. the availability of an asm/ide.h It turns out this was done for ARM, and we can simply always select HAVE_IDE on ARM instead of manually tracking which platforms might possible have an IDE controller directly or indirectly. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Russell King <rmk+lkml@arm.linux.org.uk> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28x86_64 vDSO: use initdataRoland McGrath
The 64-bit vDSO image is in a special ".vdso" section for no reason I can determine. Furthermore, the location of the vdso_end symbol includes some wrongly-calculated padding space in the image, which is then (correctly) rounded to page size, resulting in an extra page of zeros in the image mapped in to user processes. This changes it to put the vdso.so image into normal initdata as we have always done for the 32-bit vDSO images. The extra padding is gone, so the user VMA is one page instead of two. The image that was already copied around at boot time is now in initdata, so we recover that wasted space after boot. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28[CPUFREQ] Make acpi-cpufreq more robust against BIOS freq changes behind our ↵Venkatesh Pallipadi
back. We checked the hardware freq with OS cached freq value in get_cur_freqon_cpu(). Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Dave Jones <davej@redhat.com>
2008-04-28Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (45 commits) [MIPS] Pb1200/DBAu1200: move platform code to its proper place [MIPS] Fix handling of trap and breakpoint instructions [MIPS] Pb1200: do register SMC 91C111 [MIPS] DBAu1200: fix bad SMC 91C111 resource size [NET] Kconfig: Rename MIKROTIK_RB500 -> MIKROTIK_RB532 [MIPS] IP27: Fix build bug due to missing include [MIPS] Fix some sparse warnings on traps.c and irq-msc01.c [MIPS] cevt-gt641xx: Kill unnecessary include [MIPS] DS1287: Add clockevent driver [MIPS] add DECstation I/O ASIC clocksource [MIPS] rbtx4938: minor cleanup [MIPS] Alchemy: kill unused PCI_IRQ_TABLE_LOOKUP macro [MIPS] rbtx4938: misc cleanups [MIPS] jmr3927: use generic txx9 gpio [MIPS] rbhma4500: use generic txx9 gpio [MIPS] generic txx9 gpio support [MIPS] make fallback gpio.h gpiolib-friendly [MIPS] unexport null_perf_irq() and make it static [MIPS] unexport rtc_mips_set_time() [MIPS] unexport copy_from_user_page() ...
2008-04-28x86: Fix 32-bit MSI-X allocation leakagePJ Waskiewicz
This bug was introduced in the 2.6.24 i386/x86_64 tree merge, where MSI-X vector allocation will eventually fail. The cause is the new bit array tracking used vectors is not getting cleared properly on IRQ destruction on the 32-bit APIC code. This can be seen easily using the ixgbe 10 GbE driver on multi-core systems by simply loading and unloading the driver a few times. Depending on the number of available vectors on the host system, the MSI-X allocation will eventually fail, and the driver will only be able to use legacy interrupts. I am generating the same patch for both stable trees for 2.6.24 and 2.6.25. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28celleb_scc_pciex __iomem annotationsAl Viro
2008-04-28ia64 kvm fixes for O=... buildsAl Viro
* EXTRA_CFLAGS do not apply for *.S * don't bother with symlinks to ../lib/mem*.S, just add ../lib/mem*.o to object list Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28frv si_addr annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: video drivers: add facility level sparc: tcx.c make tcx_init and tcx_exit static sparc: ffb.c make ffb_init and ffb_exit static sparc: cg14.c make cg14_init and cg15_exit static sparc: bw2.c fix bw2_exit sparc64: Fix accidental syscall restart on child return from clone/fork/vfork. sparc64: Clean up handling of pt_regs trap type encoding. sparc: Remove old style signal frame support. sparc64: Kill bogus RT_ALIGNEDSZ macro from signal.c sparc: sunzilog.c remove unused argument sparc: fix drivers/video/tcx.c warning sparc64: Kill unused local ISA bus layer. input: Rewrite sparcspkr device probing. sparc64: Do not ignore 'pmu' device ranges. sparc64: Kill ISA_FLOPPY_WORKS code. sparc64: Kill CONFIG_SPARC32_COMPAT sparc64: Cleanups and corrections for arch/sparc64/Kconfig sparc64: Fix wedged irq regression.
2008-04-28[MIPS] Pb1200/DBAu1200: move platform code to its proper placeSergei Shtylyov
Since both the IDE interface and SMC 91C111 Ethernet chip are on-board devices, not SOC devices, move the platform device registration form the common to the board specific code. While at it, remove semicolon (which didn't break compilation only by chance) from the AU1XXX_ATA_DDMA_REQ macro and do some renaming: - change 'au1200_ide0_' variable name prefix to the mere 'ide_'; - change 'smc91x_' variable name prefix to 'smc91c111_' since that's the name of the chip used on the boards; - drop 'AU1XXX_' prefix from the names of macros describing IDE and Ethernet on-board devices; - change 'SMC91111_' to 'SMC91C111_', change 'IRQ' to 'INT' in the names of the macros describing the Ethernet chip for consistency with the IDE macros; - change 'ATA_' to 'IDE_' and 'OFFSET' to 'SHIFT' (since this value is indeed a shift count) in the names of the macros describing the IDE interface. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Fix handling of trap and breakpoint instructionsRalf Baechle
With fixes and cleanups from Atsushi Nemoto (anemo@mba.ocn.ne.jp). Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Pb1200: do register SMC 91C111Sergei Shtylyov
Pb1200 does have SMC 91C111 Ethernet chip on board but the platform code did not register it, so one couldn't mount NFS... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] DBAu1200: fix bad SMC 91C111 resource sizeSergei Shtylyov
The on-board SMC 91C111 chip only decodes 16 bytes of memory (obviously, it can not decode a whole megabyte starting from address 0x19000300). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Fix some sparse warnings on traps.c and irq-msc01.cAtsushi Nemoto
* Declare board_bind_eic_interrupt, board_watchpoint_handler in traps.h * Make msc_bind_eic_interrupt static and fix its argument types. * Make msc_levelirq_type, msc_edgeirq_type static. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] cevt-gt641xx: Kill unnecessary includeAtsushi Nemoto
2008-04-28[MIPS] DS1287: Add clockevent driverYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] add DECstation I/O ASIC clocksourceYoichi Yuasa
Add DECstation I/O ASIC clocksource Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] rbtx4938: minor cleanupAtsushi Nemoto
Do not initialize res->parent for platform device. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] rbtx4938: misc cleanupsAtsushi Nemoto
* Do not use non-standard I/O accessors, such as reg_rd08, etc. * Kill unnecessary wbflush() * Kill tx4938_mips.h * Kill unnecessary includes Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] jmr3927: use generic txx9 gpioAtsushi Nemoto
Use generic txx9 gpio (and gpiolib) for JMR3927 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] rbhma4500: use generic txx9 gpioAtsushi Nemoto
Use generic txx9 gpio (and gpiolib) for RBHMA4500 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] generic txx9 gpio supportAtsushi Nemoto
This is a board-independent TXx9 gpio API implementation using gpiolib. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] unexport null_perf_irq() and make it staticDmitri Vorobiev
This patch unexports the null_perf_irq() symbol, and simultaneously makes this function static. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] unexport rtc_mips_set_time()Dmitri Vorobiev
No users for the rtc_mips_set_time() routine exist outside of the core kernel code. Therefore, EXPORT_SYMBOL(rtc_mips_set_time) is useless, and this patch removes it. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] unexport copy_from_user_page()Dmitri Vorobiev
No users for the copy_from_user_page() routine exist outside of the core kernel code. Therefore, EXPORT_SYMBOL(copy_from_user_page) is useless, and this patch removes it. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] unexport copy_to_user_page()Dmitri Vorobiev
The copy_to_user_page() function is called only in the core kernel code. Therefore, there is no need to export it. This patch removes EXPORT_SYMBOL(copy_to_user_page). Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] unexport copy_user_highpage()Dmitri Vorobiev
The copy_user_highpage() routine has no users outside of the core kernel code, so exporting this symbol is pointless. This patch removes EXPORT_SYMBOL(copy_user_highpage). Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: move UART platform code to its proper placeSergei Shtylyov
Move the code registering the Alchemy UART platform devices from drivers/serial/ to its proper place, into the Alchemy platform code. Fix the related Kconfig entry, while at it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless #include's, #define's and extern'sSergei Shtylyov
Go thru the Alchemy code and hunt down every unneeded #include, #define, and extern (some of which refer to already long dead functions). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] malta_int.c: make 4 variables staticDmitri Vorobiev
The following variables defined in arch/mips/mips-boards/malta/malta_int.c can become static: msc_irqmap[], msc_nr_irqs, msc_eicirqmap[], and msc_nr_eicirqs. This patch makes them static. Successfully build-tested using default configs for Malta, Atlas and SEAD boards. Runtime test successfully performed by booting the Malta 4Kc board up to the shell prompt. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
