path: root/arch
2011-03-18Merge branch 'next' into for-linusDmitry Torokhov
2011-02-21Input: atmel_mxt_ts - allow board code to specify IRQ flagsIiro Valkonen
Different board have different requirements/setups so let's be more flexible. Signed-off-by: Iiro Valkonen <iiro.valkonen@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-02-21Input: atmel_mxt_ts - get rid of qt602240 prefixes in namesIiro Valkonen
Change prefixes from qt602240 to mxt to reflect that the driver supports whole line of mXT touchscreens. Signed-off-by: Iiro Valkonen <iiro.valkonen@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-02-21Input: qt602240_ts - rename to atmel_mxt_tsDmitry Torokhov
Since the driver will be supporting whole range of Atmels mXT touchscreen controllers we better rename it to atmel_mxt_ts. Acked-by: Iiro Valkonen <iiro.valkonen@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-02-18Input: tegra-kbc - add function keymapRakesh Iyer
Add Fn keymap support to allow for internal processing of Fn keys. Signed-off-by: Rakesh Iyer <riyer@nvidia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-02-01Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: smp_on_up: allow non-ARM SMP processors ARM: io: ensure inb/outb() et.al. are properly ordered on ARMv6+ ARM: initrd: disable initrd if passed address overlaps reserved region ARM: footbridge: fix debug macros ARM: mmci: round down the bytes transferred on error ARM: mmci: complete the transaction on error ARM: 6642/1: mmci: calculate remaining bytes at error correctly
2011-02-01Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: arch/arm/mach-omap2/dma.c: Convert IS_ERR result to PTR_ERR arm: omap2: mux: fix compile warning omap1: Simplify use of omap_irq_flags omap2+: Fix unused variable warning for omap_irq_base
2011-01-31ARM: smp_on_up: allow non-ARM SMP processorsRussell King
Allow non-ARM SMP processors to use the SMP_ON_UP feature. CPUs supporting SMP must have the new CPU ID format, so check for this first. Then check for ARM11MPCore, which fails the MPIDR check. Lastly check the MPIDR reports multiprocessing extensions and that the CPU is part of a multiprocessing system. Cc: <stable@kernel.org> Reported-and-Tested-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-31ARM: io: ensure inb/outb() et.al. are properly ordered on ARMv6+Russell King
Ensure that the ISA/PCI IO space accessors are properly ordered on ARMv6+ architectures. These should always be ordered with respect to all other accesses. This also fixes __iormb() and __iowmb() not being visible to ioread/ iowrite if a platform defines its own MMIO accessors. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-31ARM: initrd: disable initrd if passed address overlaps reserved regionRussell King
Disable the initrd if the passed address already overlaps the reserved region. This avoids oopses on Netwinders when NeTTrom tells the kernel that an initrd is located at mem+4MB, but this overlaps the BSS, resulting in the kernels in-use BSS being freed. This should be applied to v2.6.37-stable. Cc: <stable@kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-31ARM: footbridge: fix debug macrosRussell King
0ea1293 (arm: return both physical and virtual addresses from addruart) changed the way the 'addruart' worked, making it return both the virt and phys addresses. Unfortunately, for footbridge, these were reversed. Fix that. Tested on Netwinder. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-31Merge branch 'for-linus' of git://android.git.kernel.org/kernel/tegraLinus Torvalds
* 'for-linus' of git://android.git.kernel.org/kernel/tegra: ARM: tegra: clock: Add forward reference to struct clk ARM: tegra: irq: Rename gic pointers to avoid conflicts arm/tegra: Fix tegra irq_data conversion
2011-01-28Merge branch 'stable/bug-fixes-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/bug-fixes-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/setup: Route halt operations to safe_halt pvop. xen/e820: Guard against E820_RAM not having page-aligned size or start. xen/p2m: Mark INVALID_P2M_ENTRY the mfn_list past max_pfn.
2011-01-27arch/arm/mach-omap2/dma.c: Convert IS_ERR result to PTR_ERRJulia Lawall
This code elsewhere returns a negative constant to an indicate an error, while IS_ERR returns the result of a >= operation. The semantic patch that fixes this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x; @@ if (...) { ... - return IS_ERR(x); + return PTR_ERR(x); } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-01-27arm: omap2: mux: fix compile warningFelipe Balbi
Commit 8419fdbaf2118a0a169441be82f09f7be93a5ca1 (omap2+: Add omap_mux_get_by_name) introduced the following compile warning: arch/arm/mach-omap2/mux.c: In function '_omap_mux_get_by_name': arch/arm/mach-omap2/mux.c:163:17: warning: 'found_mode' may be used uninitialized in this function Signed-off-by: Felipe Balbi <balbi@ti.com> [tony@atomide.com: updated comments] Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-01-27omap1: Simplify use of omap_irq_flagsTony Lindgren
Commit 03a9e5126147c9f92aeba4b34f62b15b625087fb (omap1: Use asm_irq_flags for entry-macro.S) added support for multi-omap builds with addition of the omap_irq_flags. Commit 9f9605c2eda9679e6f63c605cbd9cbf6a9a7f3fa (omap2+: Fix unused variable warning for omap_irq_base) simplified omap2+ entry-macro.S by moving omap_irq_flags out of entry-macro.S. Simplify omap1 entry-macro.S in a similar way to keep the code consistent. Based on a similar earlier patch for omap2+ by Russell King <rmk+kernel@arm.linux.org.uk>. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-01-27omap2+: Fix unused variable warning for omap_irq_baseRussell King
Commit 5d190c40100793a6dfc37bf325677c10f3c80edf (omap2+: Initialize omap_irq_base for entry-macro.S from platform code) simplified the handling of omap_irq_base for multi-omap builds. However, this patch also introduced a build warning for !MULTI_OMAP2 builds: arch/arm/mach-omap2/io.c: In function 'omap_irq_base_init': arch/arm/mach-omap2/io.c:322: warning: unused variable 'omap_irq_base' Fix this by removing the ifdef. Also simplify things further by moving omap_irq_base out of entry-macro.S. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> [tony@atomide.com: updated comments] Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-01-28Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: percpu, x86: Fix percpu_xchg_op() x86: Remove left over system_64.h x86-64: Don't use pointer to out-of-scope variable in dump_trace()
2011-01-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6: avr32: add missing include causing undefined pgtable_page_* references
2011-01-27xen/setup: Route halt operations to safe_halt pvop.Stefano Stabellini
With this patch, the cpuidle driver does not load and does not issue the mwait operations. Instead the hypervisor is doing them (b/c we call the safe_halt pvops call). This fixes quite a lot of bootup issues wherein the user had to force interrupts for the continuation of the bootup. Details are discussed in: http://lists.xensource.com/archives/html/xen-devel/2011-01/msg00535.html [v2: Wrote the commit description] Reported-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> Tested-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-27xen/e820: Guard against E820_RAM not having page-aligned size or start.Stefano Stabellini
Under Dell Inspiron 1525, and Intel SandyBridge SDP's the BIOS e820 RAM is not page-aligned: [ 0.000000] Xen: 0000000000100000 - 00000000df66d800 (usable) We were not handling that and ended up setting up a pagetable that included up to df66e000 with the disastrous effect that when memset(NODE_DATA(nodeid), 0, sizeof(pg_data_t)); tried to clear the page it would crash at the 2K mark. Initially reported by Michael Young @ http://lists.xensource.com/archives/html/xen-devel/2011-01/msg00108.html The fix is to page-align the size and also take into consideration the start of the E820 (in case that is not page-aligned either). This fixes the bootup failure on those affected machines. This patch is a rework of the Micheal A Young initial patch and considers the case if the start is not page-aligned. Reported-by: Michael A Young <m.a.young@durham.ac.uk> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Michael A Young <m.a.young@durham.ac.uk>
2011-01-27xen/p2m: Mark INVALID_P2M_ENTRY the mfn_list past max_pfn.Stefan Bader
In case the mfn_list does not have enough entries to fill a p2m page we do not want the entries from max_pfn up to the boundary to be filled with unknown values. Hence set them to INVALID_P2M_ENTRY. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-26ARM: tegra: clock: Add forward reference to struct clkColin Cross
Signed-off-by: Colin Cross <ccross@android.com>
2011-01-26ARM: tegra: irq: Rename gic pointers to avoid conflictsColin Cross
A future patch will export gic_mask_irq and gic_unmask_irq. Rename the pointers in arch/arm/mach-tegra/irq.c to avoid a compile error. Signed-off-by: Colin Cross <ccross@android.com>
2011-01-26arm/tegra: Fix tegra irq_data conversionGrant Likely
Commit 37337a8d5e68d6e19075dbdb3acf4f1011dae972, "ARM: tegra: irq_data conversion." missed changing one reference to 'irq' in the function tegra_gpio_irq_set_type(). This patch fixes the build error. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Lennert Buytenhek <buytenh@secretlab.ca> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Colin Cross <ccross@android.com>
2011-01-26avr32: add missing include causing undefined pgtable_page_* referencesHans-Christian Egtvedt
This patch adds the linux/mm.h header file to the AVR32 arch pgalloc.c implementation to fix the undefined reference to pgtable_page_ctor() and pgtable_page_dtor(). Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-01-26percpu, x86: Fix percpu_xchg_op()Eric Dumazet
These recent percpu commits: 2485b6464cf8: x86,percpu: Move out of place 64 bit ops into X86_64 section 8270137a0d50: cpuops: Use cmpxchg for xchg to avoid lock semantics Caused this 'perf top' crash: Kernel panic - not syncing: Fatal exception in interrupt Pid: 0, comm: swapper Tainted: G D 2.6.38-rc2-00181-gef71723 #413 Call Trace: <IRQ> [<ffffffff810465b5>] ? panic ? kmsg_dump ? kmsg_dump ? oops_end ? no_context ? __bad_area_nosemaphore ? perf_output_begin ? bad_area_nosemaphore ? do_page_fault ? __task_pid_nr_ns ? perf_event_tid ? __perf_event_header__init_id ? validate_chain ? perf_output_sample ? trace_hardirqs_off ? page_fault ? irq_work_run ? update_process_times ? tick_sched_timer ? tick_sched_timer ? __run_hrtimer ? hrtimer_interrupt ? account_system_vtime ? smp_apic_timer_interrupt ? apic_timer_interrupt ... Looking at assembly code, I found: list = this_cpu_xchg(irq_work_list, NULL); gives this wrong code : (gcc-4.1.2 cross compiler) ffffffff810bc45e: mov %gs:0xead0,%rax cmpxchg %rax,%gs:0xead0 jne ffffffff810bc45e <irq_work_run+0x3e> test %rax,%rax je ffffffff810bc4aa <irq_work_run+0x8a> Tell gcc we dirty eax/rax register in percpu_xchg_op() Compiler must use another register to store pxo_new__ We also dont need to reload percpu value after a jump, since a 'failed' cmpxchg already updated eax/rax Wrong generated code was : xor %rax,%rax /* load 0 into %rax */ 1: mov %gs:0xead0,%rax cmpxchg %rax,%gs:0xead0 jne 1b test %rax,%rax After patch : xor %rdx,%rdx /* load 0 into %rdx */ mov %gs:0xead0,%rax 1: cmpxchg %rdx,%gs:0xead0 jne 1b: test %rax,%rax Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Tejun Heo <tj@kernel.org> LKML-Reference: <1295973114.3588.312.camel@edumazet-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-26x86: Remove left over system_64.hYinghai Lu
Left-over from the x86 merge ... Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <4D3E23D1.7010405@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: wacom - pass touch resolution to clients through input_absinfo Input: wacom - add 2 Bamboo Pen and touch models Input: sysrq - ensure sysrq_enabled and __sysrq_enabled are consistent Input: sparse-keymap - fix KEY_VSW handling in sparse_keymap_setup Input: tegra-kbc - add tegra keyboard driver Input: gpio_keys - switch to using request_any_context_irq Input: serio - allow registered drivers to get status flag Input: ct82710c - return proper error code for ct82c710_open Input: bu21013_ts - added regulator support Input: bu21013_ts - remove duplicate resolution parameters Input: tnetv107x-ts - don't treat NULL clk as an error Input: tnetv107x-keypad - don't treat NULL clk as an error Fix up trivial conflicts in drivers/input/keyboard/Makefile due to additions of tc3589x/Tegra drivers
2011-01-26console: rename acquire/release_console_sem() to console_lock/unlock()Torben Hohn
The -rt patches change the console_semaphore to console_mutex. As a result, a quite large chunk of the patches changes all acquire/release_console_sem() to acquire/release_console_mutex() This commit makes things use more neutral function names which dont make implications about the underlying lock. The only real change is the return value of console_trylock which is inverted from try_acquire_console_sem() This patch also paves the way to switching console_sem from a semaphore to a mutex. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Thomas Gleixner <tglx@tglx.de> Cc: Greg KH <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-26thp: fix PARAVIRT x86 32bit noPAEAndrea Arcangeli
This fixes TRANSPARENT_HUGEPAGE=y with PARAVIRT=y and HIGHMEM64=n. The #ifdef that this patch removes was erratically introduced to fix a build error for noPAE (where pmd.pmd doesn't exist). So then the kernel built but it failed at runtime because set_pmd_at was a noop. This will correct it by enabling set_pmd_at for noPAE mode too. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: werner <w.landgraf@ru.ru> Reported-by: Minchan Kim <minchan.kim@gmail.com> Tested-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-26Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ALSA: AACI: fix timeout duration ALSA: AACI: fix timeout condition checking ARM: 6636/1: ep93xx: default multiplexed gpio ports to gpio mode ARM: 6637/1: Make the argument to virt_to_phys() "const volatile" ARM: twd: ensure timer reload is reprogrammed on entry to periodic mode ARM: 6635/2: Configure reference clock for Versatile Express timers ARM: versatile: name configuration options after actual board names ARM: realview: name configuration options after actual board names ARM: realview,vexpress: fix section mismatch warning for pen_release ARM: 6632/3: mmci: stop using the blockend interrupts
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k/amiga: Fix "debug=mem" m68k/atari: Rename "scc" to "atari_scc" m68k: Uninline strchr()
2011-01-26Merge branch 'rmobile-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'rmobile-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: ARM: mach-shmobile: AG5EVM LCDC / MIPI-DSI platform data ARM: mach-shmobile: sh73a0 CPGA fix for PLL CFG bit ARM: mach-shmobile: mackerel: clarify shdi/mmcif switch settings ARM: mach-shmobile: sh73a0 CPGA fix for IrDA MSTP ARM: mach-shmobile: sh73a0 CPGA fix for FRQCRA M3 ARM: mach-shmobile: remove sh7367 on-chip set_irq_type() ARM: mach-shmobile: sh7372 INTCS MFIS2 interrupt update ARM: mach-shmobile: ag5evm: Add IrDA support ARM: mach-shmobile: clock-sh7372: fixup pllc2 set_rate mmc: sh_mmcif: Convert to __raw_xxx() I/O accessors. ARM: mach-shmobile: ag5evm requires GPIOLIB ARM: mach-shmobile: fix cpu_base of gic_init() on sh73a0
2011-01-26Merge branch 'sh-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Fix build of sh7750 base boards sh: update INTC to clear IRQ sense valid flag sh: Fix sh build failure when CONFIG_SFC=m sh: fix MSIOF0 SPI on ecovec: it conflicts with VOU sh: support XZ-compressed kernel. sh: Fix up breakage from asm-generic/pgtable.h changes.
2011-01-25ARM: 6636/1: ep93xx: default multiplexed gpio ports to gpio modeHartley Sweeten
The EP93xx C and D GPIO ports are multiplexed with the Keypad Interface peripheral.  At power-up they default into non-GPIO mode with the Key Matrix controller enabled so these ports are unusable for GPIO.  Note that the Keypad Interface peripheral is only available in the EP9307, EP9312, and EP9315 processor variants. The keypad support will clear the DeviceConfig bits appropriately to enable the Keypad Interface when the driver is loaded.  And, when the driver is unloaded it will set the bits to return the ports to GPIO mode. To make these ports available for GPIO after power-up on all EP93xx processor variants, set the KEYS and GONK bits in the DeviceConfig register. Similarly, the E, G, and H ports are multiplexed with the IDE Interface peripheral.  At power-up these also default into non-GPIO mode.  Note that the IDE peripheral is only available in the EP9312 and EP9315 processor variants. Since an IDE driver is not even available in mainline, set the EONIDE, GONIDE, and HONIDE bits in the DeviceConfig register so that these ports will be available for GPIO use after power-up. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-25ARM: 6637/1: Make the argument to virt_to_phys() "const volatile"Catalin Marinas
Changing the virt_to_phys() argument to "const volatile void *" avoids compiler warnings in some situations where this function is used. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-25ARM: twd: ensure timer reload is reprogrammed on entry to periodic modeRussell King
Ensure that the twd timer reload value is reprogrammed each time we enter periodic mode. This ensures that the reload value is always reset correctly. Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Colin Cross <ccross@android.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-25ARM: 6635/2: Configure reference clock for Versatile Express timersPawel Moll
Timers on Versatile Express mainboard are used as system clock/event sources. Driver assumes that they are clocked with 1MHz signal. Old V2M firmware apparently configured it by default, but on newer boards one can observe that "sleep 1" command takes over 30 seconds to finish, as the timers are fed with 32kHz instead... This patch performs required magic and also removes code clearing timer's control registers, as exactly the same operations are performed by the timer driver few jiffies later. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-25ARM: versatile: name configuration options after actual board namesRussell King
Update the option text to those which appear on the front of the appropriate board user guides. This gives consistent board naming, and makes it obvious which option is for which platform. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-25ARM: realview: name configuration options after actual board namesRussell King
As no one seems to really know which configuration options tie up with which boards, I thought I'd do some investigation and try to work it out. After discussion with some folk in linaro, I think I have this nailed. The names are updated to use the name on the front of the appropriate board user guide for the various baseboards, which I've taken to be the official name for each board. I haven't significantly updated the descriptions for the tiles as that is even less clear - as far as I can see on ARMs website, there is no Cortex-A9 tile for Realview EB - only ARM11MPCore, ARM1156T2F-S, ARM1176TZF-S and Cortex-R4F. So exactly what this 'Multicore Cortex-A9 Tile' is... Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-25ARM: realview,vexpress: fix section mismatch warning for pen_releaseRussell King
Fix two section mismatch warnings in the platform SMP bringup code for Realview and Versatile Express: WARNING: arch/arm/mach-realview/built-in.o(.text+0x8ac): Section mismatch in reference from the function write_pen_release() to the variable .cpuinit.data:pen_release The function write_pen_release() references the variable __cpuinitdata pen_release. This is often because write_pen_release lacks a __cpuinitdata annotation or the annotation of pen_release is wrong. WARNING: arch/arm/mach-vexpress/built-in.o(.text+0x7b4): Section mismatch in reference from the function write_pen_release() to the variable .cpuinit.data:pen_release The function write_pen_release() references the variable __cpuinitdata pen_release. This is often because write_pen_release lacks a __cpuinitdata annotation or the annotation of pen_release is wrong. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-25sh: Fix build of sh7750 base boardsNobuhiro Iwamatsu
Renamed platform_register_device to platform_device_register. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-24x86-64: Don't use pointer to out-of-scope variable in dump_trace()Jesper Juhl
In arch/x86/kernel/dumpstack_64.c::dump_trace() we have this code: ... if (!stack) { unsigned long dummy; stack = &dummy; if (task && task != current) stack = (unsigned long *)task->thread.sp; } bp = stack_frame(task, regs); /* * Print function call entries in all stacks, starting at the * current stack address. If the stacks consist of nested * exceptions */ tinfo = task_thread_info(task); for (;;) { char *id; unsigned long *estack_end; estack_end = in_exception_stack(cpu, (unsigned long)stack, &used, &id); ... You'll notice that we assign to 'stack' the address of the variable 'dummy' which is only in-scope inside the 'if (!stack)'. So when we later access stack (at the end of the above, and assuming we did not take the 'if (task && task != current)' branch) we'll be using the address of a variable that is no longer in scope. I believe this patch is the proper fix, but I freely admit that I'm not 100% certain. Signed-off-by: Jesper Juhl <jj@chaosbits.net> LKML-Reference: <alpine.LNX.2.00.1101242232590.10252@swampdragon.chaosbits.net> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-01-25Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: omap: DMA: clear interrupt status correctly OMAP3: Devkit8000: Fix tps65930 pullup/pulldown configuration arm: omap3: cm-t3517: minor comment fix arm: omap3: cm-t3517: rtc fix omap1: Fix sched_clock implementation when both MPU timer and 32K timer are used omap1: Fix booting for 15xx and 730 with omap1_defconfig omap1: Fix sched_clock for the MPU timer OMAP: PRCM: remove duplicated headers OMAP4: clockdomain: bypass unimplemented wake-up dependency functions on OMAP4 OMAP: counter_32k: init clocksource as part of machine timer init
2011-01-25Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf tools: Fix time function double declaration with glibc perf tools: Fix build by checking if extra warnings are supported perf tools: Fix build when using gcc 3.4.6 perf tools: Add missing header, fixes build perf tools: Fix 64 bit integer format strings perf test: Fix build on older glibcs perf: perf_event_exit_task_context: s/rcu_dereference/rcu_dereference_raw/ perf test: Use cpu_map->[cpu] when setting affinity perf symbols: Fix annotation of thumb code perf: Annotate cpuctx->ctx.mutex to avoid a lockdep splat powerpc, perf: Fix frequency calculation for overflowing counters (FSL version) perf: Fix perf_event_init_task()/perf_event_free_task() interaction perf: Fix find_get_context() vs perf_event_exit_task() race
2011-01-25Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Fix jump label with RO/NX module protection crash x86, hotplug: Fix powersavings with offlined cores on AMD x86, mcheck, therm_throt.c: Export symbol platform_thermal_notify to allow coretemp to handler intr x86: Use asm-generic/cacheflush.h x86: Update CPU cache attributes table descriptors
2011-01-23x86: Fix jump label with RO/NX module protection crashmatthieu castet
If we use jump table in module init, there are marked as removed in __jump_table section after init is done. But we already applied ro permissions on the module, so we can't modify a read only section (crash in remove_jump_label_module_init). Make the __jump_table section rw. Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Cc: Xiaotian Feng <xtfeng@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Siarhei Liakh <sliakh.lkml@gmail.com> Cc: Xuxian Jiang <jiang@cs.ncsu.edu> Cc: James Morris <jmorris@namei.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Dave Jones <davej@redhat.com> Cc: Kees Cook <kees.cook@canonical.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <4D3C3F20.7030203@free.fr> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-23m68k/amiga: Fix "debug=mem"Geert Uytterhoeven
`debug=mem' on Amiga has been broken for a while. early_param() processing is done very/too early, i.e. before amiga_identify() / amiga_chip_init(), causing amiga_savekmsg_setup() not to find any Chip RAM. As we don't plan to free this memory anyway, just steal it from the initial Chip RAM memory block instead. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-01-23m68k/atari: Rename "scc" to "atari_scc"Geert Uytterhoeven
It's a way too generic name for a global #define and conflicts with a variable with the same name, causing build errors like: | drivers/staging/brcm80211/brcmfmac/../util/siutils.c: In function ‘_si_clkctl_cc’: | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1364: error: expected identifier or ‘(’ before ‘volatile’ | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1364: error: expected ‘)’ before ‘(’ token | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1421: error: incompatible types in assignment | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1422: error: invalid operands to binary & | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1423: error: invalid operands to binary & | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1424: error: invalid operands to binary | | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: incompatible type for argument 4 of ‘bcmsdh_reg_write’ | drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1428: error: invalid operands to binary & | make[8]: *** [drivers/staging/brcm80211/brcmfmac/../util/siutils.o] Error 1 Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
