path: root/arch
2008-10-16fbdev: ignore VESA modes if framebuffer does not support themMichal Januszewski
Currently, it is possible to set a graphics VESA mode at boot time via the vga= parameter even when no framebuffer driver supporting this is configured. This could lead to the system booting with a black screen, without a usable console. Fix this problem by only allowing to set graphics modes at boot time if a supporting framebuffer driver is configured. Signed-off-by: Michal Januszewski <spock@gentoo.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16spi_s3c24xx: pin configuration updatesBen Dooks
Add a pin configuration callback for the s3c24xx SPI driver, as there are several options depending on the channel and the chip in use. This is needed as the controller may not have been setup by the initial bootloader and the fact that the SPI controller gets reset over suspend/resume into slave mode but the GPIO function registers do not. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16alpha: introduce field 'taso' into struct linux_binprmKirill A. Shutemov
This change is Alpha-specific. It adds field 'taso' into struct linux_binprm to remember if the application is TASO. Previously, field sh_bang was used for this purpose. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16sparc64: use iommu_num_pages function in IOMMU codeJoerg Roedel
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16alpha: use iommu_num_pages function in IOMMU codeJoerg Roedel
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16powerpc: use iommu_num_pages function in IOMMU codeJoerg Roedel
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16x86: convert Calgary IOMMU driver to generic iommu_num_pages functionJoerg Roedel
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16x86, AMD IOMMU: convert driver to generic iommu_num_pages functionJoerg Roedel
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16x86: convert GART driver to generic iommu_num_pages functionJoerg Roedel
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16powerpc: rename iommu_num_pages function to iommu_nr_pagesJoerg Roedel
This is a preparation patch for introducing a generic iommu_num_pages function. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16sparc64: rename iommu_num_pages function to iommu_nr_pagesJoerg Roedel
This is a preparation patch for introducing a generic iommu_num_pages function. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16x86: rename iommu_num_pages function to iommu_nr_pagesJoerg Roedel
This series of patches re-introduces the iommu_num_pages function so that it can be used by each architecture specific IOMMU implementations. The series also changes IOMMU implementations for X86, Alpha, PowerPC and UltraSparc. The other implementations are not yet changed because the modifications required are not obvious and I can't test them on real hardware. This patch: This is a preparation patch for introducing a generic iommu_num_pages function. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16compat: generic compat get/settimeofdayChristoph Hellwig
Nothing arch specific in get/settimeofday. The details of the timeval conversion varied a little from arch to arch, but all with the same results. Also add an extern declaration for sys_tz to linux/time.h because externs in .c files are fowned upon. I'll kill the externs in various other files in a sparate patch. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: David S. Miller <davem@davemloft.net> [ sparc bits ] Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16compat: move cp_compat_stat to common codeChristoph Hellwig
struct stat / compat_stat is the same on all architectures, so cp_compat_stat should be, too. Turns out it is, except that various architectures have slightly and some high2lowuid/high2lowgid or the direct assignment instead of the SET_UID/SET_GID that expands to the correct one anyway. This patch replaces the arch-specific cp_compat_stat implementations with a common one based on the x86-64 one. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: David S. Miller <davem@davemloft.net> [ sparc bits ] Acked-by: Kyle McMartin <kyle@mcmartin.ca> [ parisc bits ] Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Make the taint flags reliableAndi Kleen
It's somewhat unlikely that it happens, but right now a race window between interrupts or machine checks or oopses could corrupt the tainted bitmap because it is modified in a non atomic fashion. Convert the taint variable to an unsigned long and use only atomic bit operations on it. Unfortunately this means the intvec sysctl functions cannot be used on it anymore. It turned out the taint sysctl handler could actually be simplified a bit (since it only increases capabilities) so this patch actually removes code. [akpm@linux-foundation.org: remove unneeded include] Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Kconfig: eliminate "def_bool n" constructsJan Beulich
Using "def_bool n" is pointless, simply using bool here appears more appropriate. Further, retaining such options that don't have a prompt and aren't selected by anything seems also at least questionable. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tony Luck <tony.luck@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16misc: replace __FUNCTION__ with __func__Harvey Harrison
2008-10-16uml: remove the dead TTY_LOG codeAdrian Bunk
Remove the dead CONFIG_TTY_LOG (no kconfig option). Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16alpha: notify_cpu_starting() compile fixletAlexey Dobriyan
arch/alpha/kernel/smp.c:153: error: implicit declaration of function 'notify_cpu_starting' Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Alpha Miata: remove dead URLAdrian Bunk
Remove a dead URL. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16asm-h8300/md.h: remove CVS keywordAdrian Bunk
Remove a CVS keyword that wasn't updated for a long time from a comment. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16h8300: GENERIC_BUG supportYoshinori Sato
CONFIG_GENERIC_BUG support. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16h8300: update timer handler - misc updateYoshinori Sato
- Update selection - Update common timer handler - Add support functions Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16h8300: update timer handler - new filesYoshinori Sato
New timer handler files. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16h8300: update timer handler - delete filesYoshinori Sato
Delete old timer handler. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-15cpufreq: remove policy->governor setting in drivers initializationDominik Brodowski
As policy->governor is already set to CPUFREQ_DEFAULT_GOVERNOR in the (always built-in) cpufreq core, we do not need to set it in the drivers. This fixes the sparc64 allmodconfig build failure. Also, remove a totally useles setting of ->policy in cpufreq-pxa3xx.c. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-15Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: MIPS: Kill unused <asm/debug.h> inclusions MIPS: IP32: Add platform device for CMOS RTC; remove dead code RTC: M48T35: new RTC driver MIPS: IP27: Switch over to RTC class driver MIPS: DS1286: New RTC driver MIPS: IP22/28: Switch over to RTC class driver MIPS: PCI: Scan busses when they are registered MIPS: WGT634U: Add reset button support MIPS: BCM47xx: Use the new SSB GPIO API MIPS: BCM47xx: Remove references to BCM947XX MIPS: WGT634U: Add machine detection message MIPS: Align .data.cacheline_aligned based on CONFIG_MIPS_L1_CACHE_SHIFT MIPS: show_cpuinfo prints the type of the calling CPU MIPS: Fix wrong branch target in new spin_lock code. MIPS: Have a heart for a lonely, lost header file ...
2008-10-15Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (158 commits) powerpc: Fix CHRP PCI config access for indirect_pci powerpc/chrp: Fix detection of Python PCI host bridge on IBM CHRPs powerpc: Fix 32-bit SMP boot on CHRP powerpc: Fix link errors on 32-bit machines using legacy DMA powerpc/pci: Improve detection of unassigned bridge resources hvc_console: Fix free_irq in spinlocked section powerpc: Get USE_STRICT_MM_TYPECHECKS working again powerpc: Reflect the used arguments in machine_init() prototype powerpc: Fix DMA offset for non-coherent DMA powerpc: fix fsl_upm nand driver modular build powerpc/83xx: add NAND support for the MPC8360E-RDK boards powerpc: FPGA support for GE Fanuc SBC610 i2c: MPC8349E-mITX Power Management and GPIO expander driver powerpc: reserve two DMA channels for audio in MPC8610 HPCD device tree powerpc: document the "fsl,ssi-dma-channel" compatible property powerpc: disable CHRP and PMAC support in various defconfigs OF: add fsl,mcu-mpc8349emitx to the exception list powerpc/83xx: add DS1374 RTC support for the MPC837xE-MDS boards powerpc: remove support for bootmem-allocated memory for the DIU driver powerpc: remove non-dependent load fsl_booke PTE_64BIT ...
2008-10-15MIPS: Kill unused <asm/debug.h> inclusionsShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15MIPS: IP32: Add platform device for CMOS RTC; remove dead codeThomas Bogendoerfer
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15MIPS: IP27: Switch over to RTC class driverThomas Bogendoerfer
This patchset removes some dead code and creates a platform device for the RTC class driver. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15MIPS: IP22/28: Switch over to RTC class driverThomas Bogendoerfer
2008-10-15MIPS: PCI: Scan busses when they are registeredAurelien Jarno
The patch below changes register_pci_controller() such that controllers being added after pcibios_init() has run are be scanned immediately. This is needed for example by the BCM47xx PCI controller, which is located on the SSB bus, which is now initialized after the PCI subsystem. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15MIPS: WGT634U: Add reset button supportAurelien Jarno
This patch adds support for the reset button of WGT634U machine, using GPIO interrupts. Based on a patch from Michel Lespinasse. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15MIPS: BCM47xx: Use the new SSB GPIO APIAurelien Jarno
This patch simplifies the BCM47xx GPIO code by using the new SSB GPIO API, which does a lot things that were implemented directly in the BCM47xx code. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15MIPS: BCM47xx: Remove references to BCM947XXAurelien Jarno
This patch removes the remaining reference to the BCM947xx development board codename. Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15MIPS: WGT634U: Add machine detection messageAurelien Jarno
This adds a printk message when a WGT634U machine is detected. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15MIPS: Align .data.cacheline_aligned based on CONFIG_MIPS_L1_CACHE_SHIFTDavid Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15MIPS: show_cpuinfo prints the type of the calling CPUJohannes Dickgreber
It should print the type of the Nth processor. Signed-off-by: Johannes Dickgreber <tanzy@gmx.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15MIPS: Fix wrong branch target in new spin_lock code.Johannes Dickgreber
2008-10-15MIPS: Have a heart for a lonely, lost header file ...Ralf Baechle
... and move it to where all its brothers and sisters reside. Requested by Shane McDonald <mcdonald.shane@gmail.com>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15Merge commit 'origin'Benjamin Herrenschmidt
Manual fixup of conflicts on: arch/powerpc/include/asm/dcr-regs.h drivers/net/ibm_newemac/core.h
2008-10-14Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c-viapro: Add support for SMBus Process Call transactions i2c: Restore i2c_smbus_process_call function i2c: Do earlier driver model init i2c: Only build Tyan SMBus mux drivers on x86 i2c: Guard against oopses from bad init sequences i2c: Document the implementation details of the /dev interface i2c: Improve dev-interface documentation i2c-parport-light: Don't register a platform device resource hwmon: (dme1737) Convert to a new-style i2c driver hwmon: (dme1737) Be less i2c-centric i2c/tps65010: Vibrator hookup to gpiolib i2c-viapro: Add VX800/VX820 support i2c: Renesas Highlander FPGA SMBus support i2c-pca-isa: Don't grab arbitrary resources i2c/isp1301_omap: Convert to a new-style i2c driver, part 2 i2c/isp1301_omap: Convert to a new-style i2c driver, part 1
2008-10-14x86: register a platform RTC device if PNP doesn't describe itBjorn Helgaas
Most if not all x86 platforms have an RTC device, but sometimes the RTC is not exposed as a PNP0b00/PNP0b01/PNP0b02 device in PNPBIOS or ACPI: http://bugzilla.kernel.org/show_bug.cgi?id=11580 https://bugzilla.redhat.com/show_bug.cgi?id=451188 It's best if we can discover the RTC via PNP because then we know which flavor of device it is, where it lives, and which IRQ it uses. But if we can't, we should register a platform device using the compiled-in RTC_PORT/RTC_IRQ resource assumptions. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Reported-by: Rik Theys <rik.theys@esat.kuleuven.be> Reported-by: shr_msn@yahoo.com.tw Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-15powerpc: Fix CHRP PCI config access for indirect_pciBenjamin Herrenschmidt
Recently, indirect_pci was changed to test if the bus number requested is the one hanging straight off the PHB, then it substitutes the bus number with another one contained in a new "self_busno" field of the pci_controller structure. However, this breaks CHRP which didn't initialize this new field, and which relies on having the right bus number passed to the hardware. This fixes it by initializing this variable properly for all CHRP bridges Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-15powerpc/chrp: Fix detection of Python PCI host bridge on IBM CHRPsBenjamin Herrenschmidt
The detection of the IBM "Python" PCI host bridge on IBM CHRP machines such as old RS6000 was broken when we changed of_device_is_compatible() from strncasecmp to strcasecmp (dropped the "n" variant) due to the way IBM encodes the chip version. We fix that by instead doing a match on the model property like we do for others bridges in that file. It should be good enough for those machines. If yours is still broken, let me know. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-15powerpc: Fix 32-bit SMP boot on CHRPBenjamin Herrenschmidt
prom_init was changed to take a new argument, the address where the kernel is loaded, which is now used to copy the SMP spin loop down before use. However, only head_64.S was adapted to pass this new value, not head_32.S, thus breaking SMP boot on 32-bit SMP CHRP machines. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-15powerpc: Fix link errors on 32-bit machines using legacy DMABenjamin Herrenschmidt
The new merged DMA code will try to access isa_bridge_pcidev when trying to DMA to/from legacy devices. This is however only defined on 64-bit. Fixes this for now by adding the variable, even if it stays NULL. In the long run, we'll make isa-bridge.c common to 32 and 64-bit. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-15powerpc/pci: Improve detection of unassigned bridge resourcesBenjamin Herrenschmidt
When the powerpc PCI layer is not configured to re-assign everything, it currently fails to detect that a PCI to PCI bridge has been left unassigned by the firmware and tries to allocate resource for the default window values in the bridge (0...X) (with the notable exception of a hack we have in there that detects some Apple firmware unassigned bridge resources). This results in resource allocation failures, which are generally fixed up later on but it causes scary warnings in the logs and we have seen the fixup code fall over in some circumstances (a different issue to fix as well). This code improves that by providing a more complete & useful function to intuit that a bridge was left unassigned by the firmware, and thus force a full re-allocation by the PCI code without trying to allocate the existing useless resources first. The algorithm we use basically considers unassigned a window that starts at 0 (PCI address) if the corresponding address space enable bit is not set. In addition, for memory space, it considers such a resource unassigned also if the host bridge isn't configured to forward cycles to address 0 (ie, the resource basically overlaps main memory). This fixes a range of problems with things like Bare-Metal support on pSeries machines, or attempt to use partial firmware PCI setup. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-14arch/m68k/mm/kmap.c: introduce missing kfreeJulia Lawall
Error handling code following a kmalloc should free the allocated data. The semantic match that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; statement S; expression E; identifier f,l; position p1,p2; expression *ptr != NULL; @@ ( if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S | x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...); .. if (x == NULL) S ) <... when != x when != if (...) { <+...x...+> } x->f = E ..> ( return \(0\|<+...x...+>\|ptr\); | return@p2 ...; ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
