path: root/arch
2005-09-05[PATCH] swsusp: fix remaining u32 vs. pm_message_t confusionPavel Machek
Fix remaining bits of u32 vs. pm_message confusion. Should not break anything. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ISA DMA suspend for x86_64Pierre Ossman
Reset the ISA DMA controller into a known state after a suspend. Primary concern was reenabling the cascading DMA channel (4). Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ISA DMA suspend for i386Pierre Ossman
Reset the ISA DMA controller into a known state after a suspend. Primary concern was reenabling the cascading DMA channel (4). Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] unify x86/x86-64 semaphore codeBenjamin LaHaise
This patch moves the common code in x86 and x86-64's semaphore.c into a single file in lib/semaphore-sleepers.c. The arch specific asm stubs are left in the arch tree (in semaphore.c for i386 and in the asm for x86-64). There should be no changes in code/functionality with this patch. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] i386 boottime for_each_cpu brokenZwane Mwaikambo
for_each_cpu walks through all processors in cpu_possible_map, which is defined as cpu_callout_map on i386 and isn't initialised until all processors have been booted. This breaks things which do for_each_cpu iterations early during boot. So, define cpu_possible_map as a bitmap with NR_CPUS bits populated. This was triggered by a patch i'm working on which does alloc_percpu before bringing up secondary processors. From: Alexander Nyberg <alexn@telia.com> i386-boottime-for_each_cpu-broken.patch i386-boottime-for_each_cpu-broken-fix.patch The SMP version of __alloc_percpu checks the cpu_possible_map before allocating memory for a certain cpu. With the above patches the BSP cpuid is never set in cpu_possible_map which breaks CONFIG_SMP on uniprocessor machines (as soon as someone tries to dereference something allocated via __alloc_percpu, which in fact is never allocated since the cpu is not set in cpu_possible_map). Signed-off-by: Zwane Mwaikambo <zwane@arm.linux.org.uk> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] i386: encapsulate copying of pgd entriesZachary Amsden
Add a clone operation for pgd updates. This helps complete the encapsulation of updates to page tables (or pages about to become page tables) into accessor functions rather than using memcpy() to duplicate them. This is both generally good for consistency and also necessary for running in a hypervisor which requires explicit updates to page table entries. The new function is: clone_pgd_range(pgd_t *dst, pgd_t *src, int count); dst - pointer to pgd range anwhere on a pgd page src - "" count - the number of pgds to copy. dst and src can be on the same page, but the range must not overlap and must not cross a page boundary. Note that I ommitted using this call to copy pgd entries into the software suspend page root, since this is not technically a live paging structure, rather it is used on resume from suspend. CC'ing Pavel in case he has any feedback on this. Thanks to Chris Wright for noticing that this could be more optimal in PAE compiles by eliminating the memset. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86 NMI: better support for debuggersGeorge Anzinger
This patch adds a notify to the die_nmi notify that the system is about to be taken down. If the notify is handled with a NOTIFY_STOP return, the system is given a new lease on life. We also change the nmi watchdog to carry on if die_nmi returns. This give debug code a chance to a) catch watchdog timeouts and b) possibly allow the system to continue, realizing that the time out may be due to debugger activities such as single stepping which is usually done with "other" cpus held. Signed-off-by: George Anzinger<george@mvista.com> Cc: Keith Owens <kaos@ocs.com.au> Signed-off-by: George Anzinger <george@mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: introduce a write acessor for updating the current LDTZachary Amsden
Introduce a write acessor for updating the current LDT. This is required for hypervisors like Xen that do not allow LDT pages to be directly written. Testing - here's a fun little LDT test that can be trivially modified to test limits as well. /* * Copyright (c) 2005, Zachary Amsden (zach@vmware.com) * This is licensed under the GPL. */ #include <stdio.h> #include <signal.h> #include <asm/ldt.h> #include <asm/segment.h> #include <sys/types.h> #include <unistd.h> #include <sys/mman.h> #define __KERNEL__ #include <asm/page.h> void main(void) { struct user_desc desc; char *code; unsigned long long tsc; code = (char *)mmap(0, 8192, PROT_EXEC|PROT_READ|PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS, -1, 0); desc.entry_number = 0; desc.base_addr = code; desc.limit = 1; desc.seg_32bit = 1; desc.contents = MODIFY_LDT_CONTENTS_CODE; desc.read_exec_only = 0; desc.limit_in_pages = 1; desc.seg_not_present = 0; desc.useable = 1; if (modify_ldt(1, &desc, sizeof(desc)) != 0) { perror("modify_ldt"); } printf("code base is 0x%08x\n", (unsigned)code); code[0x0ffe] = 0x0f; /* rdtsc */ code[0x0fff] = 0x31; code[0x1000] = 0xcb; /* lret */ __asm__ __volatile("lcall $7,$0xffe" : "=A" (tsc)); printf("TSC is 0x%016llx\n", tsc); } Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: remove redundant TSS clearingZachary Amsden
When reviewing GDT updates, I found the code: set_tss_desc(cpu,t); /* This just modifies memory; ... */ per_cpu(cpu_gdt_table, cpu)[GDT_ENTRY_TSS].b &= 0xfffffdff; This second line is unnecessary, since set_tss_desc() has already cleared the busy bit. Commented disassembly, line 1: c028b8bd: 8b 0c 86 mov (%esi,%eax,4),%ecx c028b8c0: 01 cb add %ecx,%ebx c028b8c2: 8d 0c 39 lea (%ecx,%edi,1),%ecx => %ecx = per_cpu(cpu_gdt_table, cpu) c028b8c5: 8d 91 80 00 00 00 lea 0x80(%ecx),%edx => %edx = &per_cpu(cpu_gdt_table, cpu)[GDT_ENTRY_TSS] c028b8cb: 66 c7 42 00 73 20 movw $0x2073,0x0(%edx) c028b8d1: 66 89 5a 02 mov %bx,0x2(%edx) c028b8d5: c1 cb 10 ror $0x10,%ebx c028b8d8: 88 5a 04 mov %bl,0x4(%edx) c028b8db: c6 42 05 89 movb $0x89,0x5(%edx) => ((char *)%edx)[5] = 0x89 (equivalent) ((char *)per_cpu(cpu_gdt_table, cpu)[GDT_ENTRY_TSS])[5] = 0x89 c028b8df: c6 42 06 00 movb $0x0,0x6(%edx) c028b8e3: 88 7a 07 mov %bh,0x7(%edx) c028b8e6: c1 cb 10 ror $0x10,%ebx => other bits Commented disassembly, line 2: c028b8e9: 8b 14 86 mov (%esi,%eax,4),%edx c028b8ec: 8d 04 3a lea (%edx,%edi,1),%eax => %eax = per_cpu(cpu_gdt_table, cpu) c028b8ef: 81 a0 84 00 00 00 ff andl $0xfffffdff,0x84(%eax) => per_cpu(cpu_gdt_table, cpu)[GDT_ENTRY_TSS].b &= 0xfffffdff; (equivalent) ((char *)per_cpu(cpu_gdt_table, cpu)[GDT_ENTRY_TSS])[5] &= 0xfd Note that (0x89 & ~0xfd) == 0; i.e, set_tss_desc(cpu,t) has already stored the type field in the GDT with the busy bit clear. Eliminating redundant and obscure code is always a good thing; in fact, I pointed out this same optimization many moons ago in arch/i386/setup.c, back when it used to be called that. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: make IOPL explicitZachary Amsden
The pushf/popf in switch_to are ONLY used to switch IOPL. Making this explicit in C code is more clear. This pushf/popf pair was added as a bugfix for leaking IOPL to unprivileged processes when using sysenter/sysexit based system calls (sysexit does not restore flags). When requesting an IOPL change in sys_iopl(), it is just as easy to change the current flags and the flags in the stack image (in case an IRET is required), but there is no reason to force an IRET if we came in from the SYSENTER path. This change is the minimal solution for supporting a paravirtualized Linux kernel that allows user processes to run with I/O privilege. Other solutions require radical rewrites of part of the low level fault / system call handling code, or do not fully support sysenter based system calls. Unfortunately, this added one field to the thread_struct. But as a bonus, on P4, the fastest time measured for switch_to() went from 312 to 260 cycles, a win of about 17% in the fast case through this performance critical path. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: privilege cleanupZachary Amsden
Privilege checking cleanup. Originally, these diffs were much greater, but recent cleanups in Linux have already done much of the cleanup. I added some explanatory comments in places where the reasoning behind certain tests is rather subtle. Also, in traps.c, we can skip the user_mode check in handle_BUG(). The reason is, there are only two call chains - one via die_if_kernel() and one via do_page_fault(), both entering from die(). Both of these paths already ensure that a kernel mode failure has happened. Also, the original check here, if (user_mode(regs)) was insufficient anyways, since it would not rule out BUG faults from V8086 mode execution. Saving the %ss segment in show_regs() rather than assuming a fixed value also gives better information about the current kernel state in the register dump. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: more asm cleanupsZachary Amsden
Some more assembler cleanups I noticed along the way. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] i386: use set_pte macros in a couple places where they were missingZachary Amsden
Also, setting PDPEs in PAE mode does not require atomic operations, since the PDPEs are cached by the processor, and only reloaded on an explicit or implicit reload of CR3. Since the four PDPEs must always be present in an active root, and the kernel PDPE is never updated, we are safe even from SMIs and interrupts / NMIs using task gates (which reload CR3). Actually, much of this is moot, since the user PDPEs are never updated either, and the only usage of task gates is by the doublefault handler. It appears the only place PGDs get updated in PAE mode is in init_low_mappings() / zap_low_mapping() for initial page table creation and recovery from ACPI sleep state, and these sites are safe by inspection. Getting rid of the cmpxchg8b saves code space and 720 cycles in pgd_alloc on P4. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] i386: load_tls() fixZachary Amsden
Subtle fix: load_TLS has been moved after saving %fs and %gs segments to avoid creating non-reversible segments. This could conceivably cause a bug if the kernel ever needed to save and restore fs/gs from the NMI handler. It currently does not, but this is the safest approach to avoiding fs/gs corruption. SMIs are safe, since SMI saves the descriptor hidden state. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] i386: inline assembler: cleanup and encapsulate descriptor and task ↵Zachary Amsden
register management i386 inline assembler cleanup. This change encapsulates descriptor and task register management. Also, it is possible to improve assembler generation in two cases; savesegment may store the value in a register instead of a memory location, which allows GCC to optimize stack variables into registers, and MOV MEM, SEG is always a 16-bit write to memory, making the casting in math-emu unnecessary. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] i386: cleanup serialize msrZachary Amsden
i386 arch cleanup. Introduce the serialize macro to serialize processor state. Why the microcode update needs it I am not quite sure, since wrmsr() is already a serializing instruction, but it is a microcode update, so I will keep the semantic the same, since this could be a timing workaround. As far as I can tell, this has always been there since the original microcode update source. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] i386: inline asm cleanupZachary Amsden
i386 Inline asm cleanup. Use cr/dr accessor functions. Also, a potential bugfix. Also, some CR accessors really should be volatile. Reads from CR0 (numeric state may change in an exception handler), writes to CR4 (flipping CR4.TSD) and reads from CR2 (page fault) prevent instruction re-ordering. I did not add memory clobber to CR3 / CR4 / CR0 updates, as it was not there to begin with, and in no case should kernel memory be clobbered, except when doing a TLB flush, which already has memory clobber. I noticed that page invalidation does not have a memory clobber. I can't find a bug as a result, but there is definitely a potential for a bug here: #define __flush_tlb_single(addr) \ __asm__ __volatile__("invlpg %0": :"m" (*(char *) addr)) Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] i386: clean up vDSO alignment paddingRoland McGrath
This makes the vDSO use nops for all its padding around instructions, rather than sometimes zeros, and nop-pads the end of the area containing instructions to a 32-byte cache line, to keep text and data in separate lines. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ES7000 platform update (i386)Natalie.Protasevich@unisys.com
This is subarch update for ES7000. I've modified platform check code and removed unnecessary OEM table parsing for newer systems that don't use OEM information during boot. Parsing the table in fact is causing problems, and the platform doesn't get recognized. The patch only affects the ES7000 subach. Signed-off-by: <Natalie.Protasevich@unisys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: Add the check for all the cores in a package in cache informationVenkatesh Pallipadi
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: sutomatically enable bigsmp when we have more than 8 CPUsVenkatesh Pallipadi
i386 generic subarchitecture requires explicit dmi strings or command line to enable bigsmp mode. The patch below removes that restriction, and uses bigsmp as soon as it finds more than 8 logical CPUs, Intel processors and xAPIC support. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] kdump: Save parameter segment in protected mode (x86)Vivek Goyal
o With introduction of kexec as boot-loader, the assumption that parameter segment will always be loaded at lower address than kernel and will be addressable by early bootup page tables is no longer valid. In kexec on panic case parameter segment might well be loaded beyond kernel image and might not be addressable by early boot page tables. o This case might hit in the scenario where user has reserved a chunk of memory for second kernel, for example 16MB to 64MB, and has also built second kernel for physical memory location 16MB. In this case kexec has no choice but to load the parameter segment at a higher address than new kernel image at safe location where new kernel does not stomp it. o Though problem should automatically go away once relocatable kernel for i386 is in place and kexec can determine the location of new kernel at run time and load parameter segment at lower address than kernel image. But till then this patch can go in (assuming it does not break something else). o This patch moves up the boot parameter saving code. Now boot parameters are copied out in protected mode before page tables are initialized. This will ensure that parameter segment is always addressable irrespective of its physical location. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] vm86: Honor TF bit when emulating an instructionPetr Tesarik
If the virtual 86 machine reaches an instruction which raises a General Protection Fault (such as CLI or STI), the instruction is emulated (in handle_vm86_fault). However, the emulation ignored the TF bit, so the hardware debug interrupt was not invoked after such an emulated instruction (and the DOS debugger missed it). This patch fixes the problem by emulating the hardware debug interrupt as the last action before control is returned to the VM86 program. Signed-off-by: Petr Tesarik <kernel@tesarici.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: fix EFI memory map parsingMatt Tolentino
The memory descriptors that comprise the EFI memory map are not fixed in stone such that the size could change in the future. This uses the memory descriptor size obtained from EFI to iterate over the memory map entries during boot. This enables the removal of an x86 specific pad (and ifdef) in the EFI header. I also couldn't stomach the broken up nature of the function to put EFI runtime calls into virtual mode any longer so I fixed that up a bit as well. For reference, this patch only impacts x86. Signed-off-by: Matt Tolentino <matthew.e.tolentino@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] hpet: use read_timer_tsc only when CPU has TSCVenkatesh Pallipadi
Only use read_timer_tsc only when CPU has TSC. Thanks to Andrea for pointing this out. Should not be issue on any platforms as all recent systems that has HPET also has CPUs that supports TSC. The patch is still required for correctness. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: compress the stack layout of do_page_fault()Ingo Molnar
This patch pushes the creation of a rare signal frame (SIGBUS or SIGSEGV) into a separate function, thus saving stackspace in the main do_page_fault() stackframe. The effect is 132 bytes less of stack used by the typical do_page_fault() invocation - resulting in a denser cache-layout. (Another minor effect is that in case of kernel crashes that come from a pagefault, we add less space to the already existing frame, giving the crash functions a slightly higher chance to do their stuff without overflowing the stack.) (The changes also result in slightly cleaner code.) argument bugfix from "Guillaume C." <guichaz@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] arch/sh64/Kconfig: doesn't need it's own LOG_BUF_SHIFTAdrian Bunk
The LOG_BUF_SHIFT from lib/Kconfig.debug is sufficient. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Paul Mundt <lethal@Linux-SH.ORG> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: fix build warningsYoichi Yuasa
This patch has fixed the following warnings. arch/mips/kernel/genex.S:250:5: warning: "CONFIG_64BIT" is not defined arch/mips/math-emu/cp1emu.c:1128:5: warning: "__mips64" is not defined arch/mips/math-emu/cp1emu.c:1206:5: warning: "__mips64" is not defined arch/mips/math-emu/cp1emu.c:1270:5: warning: "__mips64" is not defined arch/mips/math-emu/cp1emu.c:323:5: warning: "__mips64" is not defined arch/mips/math-emu/cp1emu.c:808:5: warning: "__mips64" is not defined arch/mips/math-emu/cp1emu.c:953:5: warning: "__mips64" is not defined arch/mips/mm/tlbex.c:519:5: warning: "CONFIG_64BIT" is not defined include/asm/reg.h:73:5: warning: "CONFIG_64BIT" is not defined Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: add more SYS_SUPPORT_*_KERNEL and CPU_SUPPORTS_*_KERNELYoichi Yuasa
The addtion of SYS_SUPPORTS_*_KERNEL and CPU_SUPPORTS_*_KERNEL is halfway. This patch has added more SYS_SUPPORTS_*_KERNEL and CPU_SUPPORTS_*_KERNEL to arch/mips/Kconfig. Please apply. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: add pcibios_bus_to_resourceYoichi Yuasa
This patch has added pcibios_bus_to_resource to MIPS. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: fix coherency configurationRalf Baechle
Fix the MIPS coherency configuration such that we always keep the mapping state in <asm/pci.h> when we need to on non-coherent platforms. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: changed from VR41xx to VR4100 series in KconfigYoichi Yuasa
This patch has changed from VR41XX to VR4100 series in arch/mips/Kconfig. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: remove vrc4171 configYoichi Yuasa
This patch has removed obsolete VRC4171 config. Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] fix warning of TANBAC_TB0219 in drivers/char/KconfigYoichi Yuasa
$ make menuconfig scripts/kconfig/mconf arch/i386/Kconfig drivers/char/Kconfig:847:warning: 'select' used by config symbol 'TANBAC_TB0219' refer to undefined symbol 'PCI_VR41XX' Here is a patch for this warning fix. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: add default select configs for vr41xxYoichi Yuasa
This patch has added default select configs for vr41xx. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: add TANBAC VR4131 multichip moduleYoichi Yuasa
This patch has added TANBAC VR4131 multichip module in arch/mips/Kconfig Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: add support for Qemu system architectureRalf Baechle
Add support for the virtual MIPS system that is emulated by Qemu. See http://www.linux-mips.org/wiki/Qemu for a detailed current status. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] more vr4181 removalAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: moreover remove vr4181Yoichi Yuasa
We also need this patch for removing mips vr4181. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: remove VR4181 supportRalf Baechle
There seem to be no more users or interest in the NEC Osprey evaluation system for the NEC VR4181 SOC which is an old part anyway, so remove the code. More information on the Osprey can be found at http://www.linux-mips.org/wiki/Osprey. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: change system type name in proc for vr41xxYoichi Yuasa
This patch has changed system type name in proc for vr41xx. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: update IRQ handling for vr41xxYoichi Yuasa
This patch has updated IRQ handling for vr41xx. o added common IRQ dispatch o changed IRQ number in int-handler.S o added resource management to icu.c Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: remove obsolete GIU function call for vr41xxYoichi Yuasa
This patch has removed obsolete GIU function call for vr41xx. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] frv: Remove export of strtok()Jesper Juhl
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc64: replace schedule_timeout() with msleep_interruptible()Nishanth Aravamudan
Use msleep_interruptible() instead of schedule_timeout() in ppc64-specific code to cleanup/simplify the sleeping logic. Change the units of the parameter of do_event_scan_all_cpus() to milliseconds from jiffies. The return value of rtas_extended_busy_delay_time() was incorrectly being used as a jiffies value (it is actually milliseconds), which is fixed by using the value as a parameter to msleep_interruptible(). Also, use rtas_extended_busy_delay_time() in another case where similar logic is duplicated. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc64: Add VMX save flag to VPAOlof Johansson
We need to indicate to the hypervisor that it needs to save our VMX registers when switching partitions on a shared-processor system, just as it needs to for FP and PMC registers. This could be made to be on-demand when VMX is used, but we don't do that for FP nor PMC right now either so let's not overcomplicate things. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Paul Mackerras <paulus@samba.org> Cc: Anton Blanchard <anton@samba.org> Cc: <engebret@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc64: update xmon helptextOlaf Hering
xmon will do nothing but noise on a G5 if BOOTX_TEXT is not enabled. mention the recognized kernel cmdline options for xmon. Signed-off-by: Olaf Hering <olh@suse.de> Cc: Paul Mackeras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] ppc32: cpci690 updatesMark A. Greer
Update the cpci690 platform code: - pass mem size in from bootwrapper via bi_rec - some minor fixups Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
