path: root/arch
2013-05-07Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Benjamin Herrenschmidt: "Here are a few more powerpc bits that I would like in 3.10. Mostly remaining bolts & screw tightening of power8 support such as actually exposing the new features via the previously added AT_HWCAP2, and a few fixes, some of them for problems exposed recently like irqdomain warnings or sysfs access permission issues, some exposed by power8 hardware. The only change outside of arch/powerpc is a small one to irqdomain.c to allow silent failure to fix a problem on Cell where we get a dozen WARN_ON's tripping at boot for what is basically a normal case." * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Make hard_irq_disable() do the right thing vs. irq tracing powerpc/topology: Fix spurr attribute permission powerpc/pci: Support per-aperture memory offset powerpc/cell/iommu: Improve error message for missing node powerpc/cell/spufs: Fix status attribute permission irqdomain: Allow quiet failure mode powerpc/pnv: Fix "compatible" property for P8 PHB powerpc/pci: Don't add bogus empty resources to PHBs powerpc/powerpnv: Properly handle failure starting CPUs powerpc/cputable: Advertise support for ISEL/HTM/DSCR/TAR on POWER8 powerpc/cputable: Advertise ISEL support on appropriate embedded processors powerpc/cputable: Advertise DSCR support on P7/P7+ powerpc/cputable: Reserve bits in HWCAP2 for new features powerpc/pseries: Perform proper max_bus_speed detection powerpc/pseries: Force 32 bit MSIs for devices that require it powerpc/tm: Fix null pointer deference in flush_hash_page powerpc/powernv: Defer OPAL exception handler registration powerpc: Emulate non privileged DSCR read and write
2013-05-07Merge branch 'rwsem-optimizations'Linus Torvalds
Merge rwsem optimizations from Michel Lespinasse: "These patches extend Alex Shi's work (which added write lock stealing on the rwsem slow path) in order to provide rwsem write lock stealing on the fast path (that is, without taking the rwsem's wait_lock). I have unfortunately been unable to push this through -next before due to Ingo Molnar / David Howells / Peter Zijlstra being busy with other things. However, this has gotten some attention from Rik van Riel and Davidlohr Bueso who both commented that they felt this was ready for v3.10, and Ingo Molnar has said that he was OK with me pushing directly to you. So, here goes :) Davidlohr got the following test results from pgbench running on a quad-core laptop: | db_size | clients | tps-vanilla | tps-rwsem | +---------+----------+----------------+--------------+ | 160 MB | 1 | 5803 | 6906 | + 19.0% | 160 MB | 2 | 13092 | 15931 | | 160 MB | 4 | 29412 | 33021 | | 160 MB | 8 | 32448 | 34626 | | 160 MB | 16 | 32758 | 33098 | | 160 MB | 20 | 26940 | 31343 | + 16.3% | 160 MB | 30 | 25147 | 28961 | | 160 MB | 40 | 25484 | 26902 | | 160 MB | 50 | 24528 | 25760 | ------------------------------------------------------ | 1.6 GB | 1 | 5733 | 7729 | + 34.8% | 1.6 GB | 2 | 9411 | 19009 | + 101.9% | 1.6 GB | 4 | 31818 | 33185 | | 1.6 GB | 8 | 33700 | 34550 | | 1.6 GB | 16 | 32751 | 33079 | | 1.6 GB | 20 | 30919 | 31494 | | 1.6 GB | 30 | 28540 | 28535 | | 1.6 GB | 40 | 26380 | 27054 | | 1.6 GB | 50 | 25241 | 25591 | ------------------------------------------------------ | 7.6 GB | 1 | 5779 | 6224 | | 7.6 GB | 2 | 10897 | 13611 | + 24.9% | 7.6 GB | 4 | 32683 | 33108 | | 7.6 GB | 8 | 33968 | 34712 | | 7.6 GB | 16 | 32287 | 32895 | | 7.6 GB | 20 | 27770 | 31689 | + 14.1% | 7.6 GB | 30 | 26739 | 29003 | | 7.6 GB | 40 | 24901 | 26683 | | 7.6 GB | 50 | 17115 | 25925 | + 51.5% ------------------------------------------------------ (Davidlohr also has one additional patch which further improves throughput, though I will ask him to send it directly to you as I have suggested some minor changes)." * emailed patches from Michel Lespinasse <walken@google.com>: rwsem: no need for explicit signed longs x86 rwsem: avoid taking slow path when stealing write lock rwsem: do not block readers at head of queue if other readers are active rwsem: implement support for write lock stealing on the fastpath rwsem: simplify __rwsem_do_wake rwsem: skip initial trylock in rwsem_down_write_failed rwsem: avoid taking wait_lock in rwsem_down_write_failed rwsem: use cmpxchg for trying to steal write lock rwsem: more agressive lock stealing in rwsem_down_write_failed rwsem: simplify rwsem_down_write_failed rwsem: simplify rwsem_down_read_failed rwsem: move rwsem_down_failed_common code into rwsem_down_{read,write}_failed rwsem: shorter spinlocked section in rwsem_down_failed_common() rwsem: make the waiter type an enumeration rather than a bitmask
2013-05-07x86 rwsem: avoid taking slow path when stealing write lockMichel Lespinasse
modify __down_write[_nested] and __down_write_trylock to grab the write lock whenever the active count is 0, even if there are queued waiters (they must be writers pending wakeup, since the active count is 0). Note that this is an optimization only; architectures without this optimization will still work fine: - __down_write() would take the slow path which would take the wait_lock and then try stealing the lock (as in the spinlocked rwsem implementation) - __down_write_trylock() would fail, but callers must be ready to deal with that - since there are some writers pending wakeup, they could have raced with us and obtained the lock before we steal it. Signed-off-by: Michel Lespinasse <walken@google.com> Reviewed-by: Peter Hurley <peter@hurleysoftware.com> Acked-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07powerpc: Make hard_irq_disable() do the right thing vs. irq tracingBenjamin Herrenschmidt
If hard_irq_disable() is called while interrupts are already soft-disabled (which is the most common case) all is already well. However you can (and in some cases want) to call it while everything is enabled (to make sure you don't get a lazy even, for example before entry into KVM guests) and in this case we need to inform the irq tracer that the irqs are going off. We have to change the inline into a macro to avoid an include circular dependency hell hole. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06Merge tag 'iommu-updates-v3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "The updates are mostly about the x86 IOMMUs this time. Exceptions are the groundwork for the PAMU IOMMU from Freescale (for a PPC platform) and an extension to the IOMMU group interface. On the x86 side this includes a workaround for VT-d to disable interrupt remapping on broken chipsets. On the AMD-Vi side the most important new feature is a kernel command-line interface to override broken information in IVRS ACPI tables and get interrupt remapping working this way. Besides that there are small fixes all over the place." * tag 'iommu-updates-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (24 commits) iommu/tegra: Fix printk formats for dma_addr_t iommu: Add a function to find an iommu group by id iommu/vt-d: Remove warning for HPET scope type iommu: Move swap_pci_ref function to drivers/iommu/pci.h. iommu/vt-d: Disable translation if already enabled iommu/amd: fix error return code in early_amd_iommu_init() iommu/AMD: Per-thread IOMMU Interrupt Handling iommu: Include linux/err.h iommu/amd: Workaround for ERBT1312 iommu/amd: Document ivrs_ioapic and ivrs_hpet parameters iommu/amd: Don't report firmware bugs with cmd-line ivrs overrides iommu/amd: Add ioapic and hpet ivrs override iommu/amd: Add early maps for ioapic and hpet iommu/amd: Extend IVRS special device data structure iommu/amd: Move add_special_device() to __init iommu: Fix compile warnings with forward declarations iommu/amd: Properly initialize irq-table lock iommu/amd: Use AMD specific data structure for irq remapping iommu/amd: Remove map_sg_no_iommu() iommu/vt-d: add quirk for broken interrupt remapping on 55XX chipsets ...
2013-05-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull more s390 updates from Martin Schwidefsky: "This is the second batch of s390 patches for the 3.10 merge window. Heiko improved the memory detection, this fixes kdump for large memory sizes. Some kvm related memory management work, new ipldev/condev keywords in cio and bug fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/mem_detect: remove artificial kdump memory types s390/mm: add pte invalidation notifier for kvm s390/zcrypt: ap bus rescan problem when toggle crypto adapters on/off s390/memory hotplug,sclp: get rid of per memory increment usecount s390/memory hotplug: provide memory_block_size_bytes() function s390/mem_detect: limit memory detection loop to "mem=" parameter s390/kdump,bootmem: fix bootmem allocator bitmap size s390: get rid of odd global real_memory_size s390/kvm: Change the virtual memory mapping location for Virtio devices s390/zcore: calculate real memory size using own get_mem_size function s390/mem_detect: add DAT sanity check s390/mem_detect: fix lockdep irq tracing s390/mem_detect: move memory detection code to mm folder s390/zfcpdump: exploit new cio_ignore keywords s390/cio: add condev keyword to cio_ignore s390/cio: add ipldev keyword to cio_ignore s390/uaccess: add "fallthrough" comments
2013-05-06powerpc/topology: Fix spurr attribute permissionBenjamin Herrenschmidt
We are registering the attribute with permission 0600 but it doesn't have a store callback, which causes WARN_ON's during boot. Fix the permission. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/pci: Support per-aperture memory offsetBenjamin Herrenschmidt
The PCI core supports an offset per aperture nowadays but our arch code still has a single offset per host bridge representing the difference betwen CPU memory addresses and PCI MMIO addresses. This is a problem as new machines and hypervisor versions are coming out where the 64-bit windows will have a different offset (basically mapped 1:1) from the 32-bit windows. This fixes it by using separate offsets. In the long run, we probably want to get rid of that intermediary struct pci_controller and have those directly stored into the pci_host_bridge as they are parsed but this will be a more invasive change. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/cell/iommu: Improve error message for missing nodeBenjamin Herrenschmidt
Some devices don't have a correct node ID and thus can't be attached to an iommu. The message displayed by the iommu code isn't very useful if you don't have a device-tree node as it tries to print the device-tree path but not the struct device name. Improve this by printing the device name as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/cell/spufs: Fix status attribute permissionBenjamin Herrenschmidt
We are registering the attribute with permission 0644 but it doesn't have a store callback, which causes WARN_ON's during boot. Fix the permission. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06irqdomain: Allow quiet failure modeBenjamin Herrenschmidt
Some interrupt controllers refuse to map interrupts marked as "protected" by firwmare. Since we try to map everyting in the device-tree on some platforms, we end up with a lot of nasty WARN's in the boot log for what is a normal situation on those machines. This defines a specific return code (-EPERM) from the host map() callback which cause irqdomain to fail silently. MPIC is updated to return this when hitting a protected source printing only a single line message for diagnostic purposes. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-05Merge tag 'mfd-3.10-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next Pull MFD update from Samuel Ortiz: "For 3.10 we have a few new MFD drivers for: - The ChromeOS embedded controller which provides keyboard, battery and power management services. This controller is accessible through i2c or SPI. - Silicon Laboratories 476x controller, providing access to their FM chipset and their audio codec. - Realtek's RTS5249, a memory stick, MMC and SD/SDIO PCI based reader. - Nokia's Tahvo power button and watchdog device. This device is very similar to Retu and is thus supported by the same code base. - STMicroelectronics STMPE1801, a keyboard and GPIO controller supported by the stmpe driver. - ST-Ericsson AB8540 and AB8505 power management and voltage converter controllers through the existing ab8500 code. Some other drivers got cleaned up or improved. In particular: - The Linaro/STE guys got the ab8500 driver in sync with their internal code through a series of optimizations, fixes and improvements. - The AS3711 and OMAP USB drivers now have DT support. - The arizona clock and interrupt handling code got improved. - The wm5102 register patch and boot mechanism also got improved." * tag 'mfd-3.10-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next: (104 commits) mfd: si476x: Don't use 0bNNN mfd: vexpress: Handle pending config transactions mfd: ab8500: Export ab8500_gpadc_sw_hw_convert properly mfd: si476x: Fix i2c warning mfd: si476x: Add header files and Kbuild plumbing mfd: si476x: Add chip properties handling code mfd: si476x: Add the bulk of the core driver mfd: si476x: Add commands abstraction layer mfd: rtsx: Support RTS5249 mfd: retu: Add Tahvo support mfd: ucb1400: Pass ucb1400-gpio data through ac97 bus mfd: wm8994: Add some OF properties mfd: wm8994: Add device ID data to WM8994 OF device IDs input: Export matrix_keypad_parse_of_params() mfd: tps65090: Add compatible string for charger subnode mfd: db8500-prcmu: Support platform dependant device selection mfd: syscon: Fix warnings when printing resource_size_t of: Add stub of_get_parent for non-OF builds mfd: omap-usb-tll: Convert to devm_ioremap_resource() mfd: omap-usb-host: Convert to devm_ioremap_resource() ...
2013-05-06powerpc/pnv: Fix "compatible" property for P8 PHBBenjamin Herrenschmidt
The property should be "ibm,power8-pciex", not "ibm,p8-pciex". The latter was changed in FW because it was inconsistent with the rest of the nodes. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/pci: Don't add bogus empty resources to PHBsBenjamin Herrenschmidt
When converting to use the new pci_add_resource_offset() we didn't properly account for empty resources (0 flags) and add those bogons to the PHBs. The result is some annoying messages in the log. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/powerpnv: Properly handle failure starting CPUsBenjamin Herrenschmidt
If OPAL returns an error, propagate it upward rather than spinning seconds waiting for a CPU that will never show up Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/cputable: Advertise support for ISEL/HTM/DSCR/TAR on POWER8Nishanth Aravamudan
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/cputable: Advertise ISEL support on appropriate embedded processorsNishanth Aravamudan
2013-05-06powerpc/cputable: Advertise DSCR support on P7/P7+Nishanth Aravamudan
2013-05-06powerpc/cputable: Reserve bits in HWCAP2 for new featuresNishanth Aravamudan
Also, make HTM's presence dependent on the .config option. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/pseries: Perform proper max_bus_speed detectionKleber Sacilotto de Souza
On pseries machines the detection for max_bus_speed should be done through an OpenFirmware property. This patch adds a function to perform this detection and a hook to perform dynamic adding of the function only for pseries. This is done by overwriting the weak pcibios_root_bridge_prepare function which is called by pci_create_root_bus(). From: Lucas Kannebley Tavares <lucaskt@linux.vnet.ibm.com> Signed-off-by: Kleber Sacilotto de Souza <klebers@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/pseries: Force 32 bit MSIs for devices that require itBrian King
The following patch implements a new PAPR change which allows the OS to force the use of 32 bit MSIs, regardless of what the PCI capabilities indicate. This is required for some devices that advertise support for 64 bit MSIs but don't actually support them. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/tm: Fix null pointer deference in flush_hash_pageMichael Neuling
Make sure that current->thread.reg exists before we deference it in flush_hash_page. Signed-off-by: Michael Neuling <mikey@neuling.org> Reported-by: John J Miller <millerjo@us.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/powernv: Defer OPAL exception handler registrationJeremy Kerr
Currently, the OPAL exception vectors are registered before the feature fixups are processed. This means that the now-firmware-owned vectors will likely be overwritten by the kernel. This change moves the exception registration code to an early initcall, rather than at machine_init time. Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc: Emulate non privileged DSCR read and writeAnton Blanchard
POWER8 allows read and write of the DSCR in userspace. We added kernel emulation so applications could always use the instructions regardless of the CPU type. Unfortunately there are two SPRs for the DSCR and we only added emulation for the privileged one. Add code to match the non privileged one. A simple test was created to verify the fix: http://ozlabs.org/~anton/junkcode/user_dscr_test.c Without the patch we get a SIGILL and it passes with the patch. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-05Merge tag 'kvm-3.10-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm updates from Gleb Natapov: "Highlights of the updates are: general: - new emulated device API - legacy device assignment is now optional - irqfd interface is more generic and can be shared between arches x86: - VMCS shadow support and other nested VMX improvements - APIC virtualization and Posted Interrupt hardware support - Optimize mmio spte zapping ppc: - BookE: in-kernel MPIC emulation with irqfd support - Book3S: in-kernel XICS emulation (incomplete) - Book3S: HV: migration fixes - BookE: more debug support preparation - BookE: e6500 support ARM: - reworking of Hyp idmaps s390: - ioeventfd for virtio-ccw And many other bug fixes, cleanups and improvements" * tag 'kvm-3.10-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (204 commits) kvm: Add compat_ioctl for device control API KVM: x86: Account for failing enable_irq_window for NMI window request KVM: PPC: Book3S: Add API for in-kernel XICS emulation kvm/ppc/mpic: fix missing unlock in set_base_addr() kvm/ppc: Hold srcu lock when calling kvm_io_bus_read/write kvm/ppc/mpic: remove users kvm/ppc/mpic: fix mmio region lists when multiple guests used kvm/ppc/mpic: remove default routes from documentation kvm: KVM_CAP_IOMMU only available with device assignment ARM: KVM: iterate over all CPUs for CPU compatibility check KVM: ARM: Fix spelling in error message ARM: KVM: define KVM_ARM_MAX_VCPUS unconditionally KVM: ARM: Fix API documentation for ONE_REG encoding ARM: KVM: promote vfp_host pointer to generic host cpu context ARM: KVM: add architecture specific hook for capabilities ARM: KVM: perform HYP initilization for hotplugged CPUs ARM: KVM: switch to a dual-step HYP init code ARM: KVM: rework HYP page table freeing ARM: KVM: enforce maximum size for identity mapped code ARM: KVM: move to a KVM provided HYP idmap ...
2013-05-05Merge branch 'timers-nohz-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull 'full dynticks' support from Ingo Molnar: "This tree from Frederic Weisbecker adds a new, (exciting! :-) core kernel feature to the timer and scheduler subsystems: 'full dynticks', or CONFIG_NO_HZ_FULL=y. This feature extends the nohz variable-size timer tick feature from idle to busy CPUs (running at most one task) as well, potentially reducing the number of timer interrupts significantly. This feature got motivated by real-time folks and the -rt tree, but the general utility and motivation of full-dynticks runs wider than that: - HPC workloads get faster: CPUs running a single task should be able to utilize a maximum amount of CPU power. A periodic timer tick at HZ=1000 can cause a constant overhead of up to 1.0%. This feature removes that overhead - and speeds up the system by 0.5%-1.0% on typical distro configs even on modern systems. - Real-time workload latency reduction: CPUs running critical tasks should experience as little jitter as possible. The last remaining source of kernel-related jitter was the periodic timer tick. - A single task executing on a CPU is a pretty common situation, especially with an increasing number of cores/CPUs, so this feature helps desktop and mobile workloads as well. The cost of the feature is mainly related to increased timer reprogramming overhead when a CPU switches its tick period, and thus slightly longer to-idle and from-idle latency. Configuration-wise a third mode of operation is added to the existing two NOHZ kconfig modes: - CONFIG_HZ_PERIODIC: [formerly !CONFIG_NO_HZ], now explicitly named as a config option. This is the traditional Linux periodic tick design: there's a HZ tick going on all the time, regardless of whether a CPU is idle or not. - CONFIG_NO_HZ_IDLE: [formerly CONFIG_NO_HZ=y], this turns off the periodic tick when a CPU enters idle mode. - CONFIG_NO_HZ_FULL: this new mode, in addition to turning off the tick when a CPU is idle, also slows the tick down to 1 Hz (one timer interrupt per second) when only a single task is running on a CPU. The .config behavior is compatible: existing !CONFIG_NO_HZ and CONFIG_NO_HZ=y settings get translated to the new values, without the user having to configure anything. CONFIG_NO_HZ_FULL is turned off by default. This feature is based on a lot of infrastructure work that has been steadily going upstream in the last 2-3 cycles: related RCU support and non-periodic cputime support in particular is upstream already. This tree adds the final pieces and activates the feature. The pull request is marked RFC because: - it's marked 64-bit only at the moment - the 32-bit support patch is small but did not get ready in time. - it has a number of fresh commits that came in after the merge window. The overwhelming majority of commits are from before the merge window, but still some aspects of the tree are fresh and so I marked it RFC. - it's a pretty wide-reaching feature with lots of effects - and while the components have been in testing for some time, the full combination is still not very widely used. That it's default-off should reduce its regression abilities and obviously there are no known regressions with CONFIG_NO_HZ_FULL=y enabled either. - the feature is not completely idempotent: there is no 100% equivalent replacement for a periodic scheduler/timer tick. In particular there's ongoing work to map out and reduce its effects on scheduler load-balancing and statistics. This should not impact correctness though, there are no known regressions related to this feature at this point. - it's a pretty ambitious feature that with time will likely be enabled by most Linux distros, and we'd like you to make input on its design/implementation, if you dislike some aspect we missed. Without flaming us to crisp! :-) Future plans: - there's ongoing work to reduce 1Hz to 0Hz, to essentially shut off the periodic tick altogether when there's a single busy task on a CPU. We'd first like 1 Hz to be exposed more widely before we go for the 0 Hz target though. - once we reach 0 Hz we can remove the periodic tick assumption from nr_running>=2 as well, by essentially interrupting busy tasks only as frequently as the sched_latency constraints require us to do - once every 4-40 msecs, depending on nr_running. I am personally leaning towards biting the bullet and doing this in v3.10, like the -rt tree this effort has been going on for too long - but the final word is up to you as usual. More technical details can be found in Documentation/timers/NO_HZ.txt" * 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (39 commits) sched: Keep at least 1 tick per second for active dynticks tasks rcu: Fix full dynticks' dependency on wide RCU nocb mode nohz: Protect smp_processor_id() in tick_nohz_task_switch() nohz_full: Add documentation. cputime_nsecs: use math64.h for nsec resolution conversion helpers nohz: Select VIRT_CPU_ACCOUNTING_GEN from full dynticks config nohz: Reduce overhead under high-freq idling patterns nohz: Remove full dynticks' superfluous dependency on RCU tree nohz: Fix unavailable tick_stop tracepoint in dynticks idle nohz: Add basic tracing nohz: Select wide RCU nocb for full dynticks nohz: Disable the tick when irq resume in full dynticks CPU nohz: Re-evaluate the tick for the new task after a context switch nohz: Prepare to stop the tick on irq exit nohz: Implement full dynticks kick nohz: Re-evaluate the tick from the scheduler IPI sched: New helper to prevent from stopping the tick in full dynticks sched: Kick full dynticks CPU that have more than one task enqueued. perf: New helper to prevent full dynticks CPUs from stopping tick perf: Kick full dynticks CPU if events rotation is needed ...
2013-05-05Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc fixes plus a small hw-enablement patch for Intel IB model 58 uncore events" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/intel/lbr: Demand proper privileges for PERF_SAMPLE_BRANCH_KERNEL perf/x86/intel/lbr: Fix LBR filter perf/x86: Blacklist all MEM_*_RETIRED events for Ivy Bridge perf: Fix vmalloc ring buffer pages handling perf/x86/intel: Fix unintended variable name reuse perf/x86/intel: Add support for IvyBridge model 58 Uncore perf/x86/intel: Fix typo in perf_event_intel_uncore.c x86: Eliminate irq_mis_count counted in arch_irq_stat
2013-05-05Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull mudule updates from Rusty Russell: "We get rid of the general module prefix confusion with a binary config option, fix a remove/insert race which Never Happens, and (my favorite) handle the case when we have too many modules for a single commandline. Seriously, the kernel is full, please go away!" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: fix unwanted VMLINUX_SYMBOL_STR expansion X.509: Support parse long form of length octets in Authority Key Identifier module: don't unlink the module until we've removed all exposure. kernel: kallsyms: memory override issue, need check destination buffer length MODSIGN: do not send garbage to stderr when enabling modules signature modpost: handle huge numbers of modules. modpost: add -T option to read module names from file/stdin. modpost: minor cleanup. genksyms: pass symbol-prefix instead of arch module: fix symbol versioning with symbol prefixes CONFIG_SYMBOL_PREFIX: cleanup.
2013-05-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull single_open() leak fixes from Al Viro: "A bunch of fixes for a moderately common class of bugs: file with single_open() done by its ->open() and seq_release as its ->release(). That leaks; fortunately, it's not _too_ common (either people manage to RTFM that says "When using single_open(), the programmer should use single_release() instead of seq_release() in the file_operations structure to avoid a memory leak", or they just copy a correct instance), but grepping through the tree has caught quite a pile. All of that is, AFAICS, -stable fodder, for as far as the patches apply. I tried to carve it up into reasonably-sized pieces (more or less "comes from the same tree")" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: rcutrace: single_open() leaks gadget: single_open() leaks staging: single_open() leaks megaraid: single_open() leak wireless: single_open() leaks input: single_open() leak rtc: single_open() leaks ds1620: single_open() leak sh: single_open() leaks parisc: single_open() leaks mips: single_open() leaks ia64: single_open() leaks h8300: single_open() leaks cris: single_open() leaks arm: single_open() leaks
2013-05-05perf/x86/intel/lbr: Demand proper privileges for PERF_SAMPLE_BRANCH_KERNELPeter Zijlstra
We should always have proper privileges when requesting kernel data. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: eranian@google.com Link: http://lkml.kernel.org/r/20130503121256.230745028@chello.nl [ Fix build error reported by fengguang.wu@intel.com, propagate error code back. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/n/tip-v0x9ky3ahzr6nm3c6ilwrili@git.kernel.org
2013-05-05sh: single_open() leaksAl Viro
Cc: vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-05parisc: single_open() leaksAl Viro
Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-05mips: single_open() leaksAl Viro
2013-05-05ia64: single_open() leaksAl Viro
2013-05-05h8300: single_open() leaksAl Viro
2013-05-05cris: single_open() leaksAl Viro
2013-05-05arm: single_open() leaksAl Viro
2013-05-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-nextLinus Torvalds
Pull sparc updates from David Miller: 1) Hibernation support, as well as removal of excess interrupt twiddling in MMU context allocation on sparc64 from Kirill Tkhai. 2) Kill references to __ARCH_WANT_UNLOCKED_CTXSW. 3) Sparc32 LEON bug fixes from Daniel Hellstrom and Andreas Larsson. 4) Provide cmpxchg64(), from Geert Uytterhoeven. 5) Device refcount and registry bug fixes from Federico Vaga and Wei Yongjun. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next: serial: sunsu: add missing platform_driver_unregister() when module exit sparc32, leon: Do not overwrite previously set irq flow handlers sparc/kernel/vio.c: add put_device() after device_find_child() sparc64: Do not save/restore interrupts in get_new_mmu_context() sparc: Consistently use 'wr' and 'rd' instructions for ASRs. sparc64: Kill __ARCH_WANT_UNLOCKED_CTXSW sparc64: Provide cmpxchg64() sparc64: Do not change num_physpages during initmem freeing sparc64: Hibernation support sparc,leon: updated GRPCI2 config name sparc,leon: support for GRPCI1 PCI host bridge controller sparc32,leon: add support for PCI busn resource for GRPCI2
2013-05-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcDavid S. Miller
Merge sparc bug fixes that didn't make it into v3.9 into sparc-next. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-04sparc32, leon: Do not overwrite previously set irq flow handlersAndreas Larsson
This is needed because when scan_of_devices finds the GAISLER_GPTIMER core that corresponds to the SMP "ticker" timer, the previously set proper irq flow handler gets overwritten with an incorrect one. This leads to very flaky timer interrupt handling on some hardware. Proper updates to handlers can still be done using leon_update_virq_handling. Signed-off-by: Andreas Larsson <andreas@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-04sparc/kernel/vio.c: add put_device() after device_find_child()Federico Vaga
The vio_remove() function uses device_find_child() but it does not drop the reference of the retrieved child. Signed-off-by: Federico Vaga <federico.vaga@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-04Merge tag 'mmc-updates-for-3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC update from Chris Ball: "MMC highlights for 3.10: Core: - Introduce MMC_CAP2_NO_PRESCAN_POWERUP to allow skipping mmc_power_up() at boot/initialization time if it's already happened, for performance (faster boot time) reasons. - Fix a bit width test failure that resulted in old eMMC cards being put into 1-bit mode when 4-bit mode was available. - Expose fwrev/hwrev for MMCv4 parts. - Improve card removal logic in the case where the card's removed slowly; we were missing card removal events if the card retained contact with the slot pads for long enough to reply to a CMD13 while being removed. Drivers: - davinci_mmc: Support using PIO instead of DMA. - dw_mmc: Add support for Exynos4412. - mxcmmc: DT support, use slot-gpio API. - mxs-mmc: Add broken-cd/cd-inverted/non-removable DT property support. - sdhci-sirf: New sdhci-pltfm driver for CSR SiRF SoCs: SiRFprimaII: unicore ARM Cortex-A9 SiRFatlas6: unicore ARM Cortex-A9 SiRFmarco: dual core ARM Cortex-A9 SMP - sdhci-tegra: Add support for Tegra114 platforms, use mmc_of_parse()" * tag 'mmc-updates-for-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (66 commits) mmc: sdhci-tegra: fix MODULE_DEVICE_TABLE mmc: core: fix init controller performance regression, updated patch mmc: mxcmmc: enable DMA support on mpc512x mmc: mxcmmc: constify mxcmci_devtype mmc: mxcmmc: use slot-gpio API for write-protect detection mmc: mxcmmc: add mpc512x SDHC support mmc: mxcmmc: fix race conditions for host->req and host->data access mmc: mxcmmc: DT support mmc: dw_mmc: let device core setup the default pin configuration mmc: mxs-mmc: add broken-cd property mmc: mxs-mmc: add non-removable property mmc: mxs-mmc: add cd-inverted property mmc: core: call pm_runtime_put_noidle in pm_runtime_get_sync failed case mmc: mxcmmc: Fix bug when card is present during boot mmc: core: fix performance regression initializing MMC host controllers Revert "mmc: core: wait while adding MMC host to ensure root mounts successfully" mmc: atmel-mci: pio hang on block errors mmc: core: Fix bit width test failing on old eMMC cards mmc: dw_mmc: Use pr_info instead of printk mmc: dw_mmc: Check return value of regulator_enable ...
2013-05-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second round of VFS updates from Al Viro: "Assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: xtensa simdisk: fix braino in "xtensa simdisk: switch to proc_create_data()" hostfs: use kmalloc instead of kzalloc hostfs: move HOSTFS_SUPER_MAGIC to <linux/magic.h> hostfs: remove "will unlock" comment vfs: use list_move instead of list_del/list_add proc_devtree: Replace include linux/module.h with linux/export.h create_mnt_ns: unidiomatic use of list_add() fs: remove dentry_lru_prune() Removed unused typedef to avoid "unused local typedef" warnings. kill fs/read_write.h fs: Fix hang with BSD accounting on frozen filesystem sun3_scsi: add ->show_info() nubus: Kill nubus_proc_detach_device() more mode_t whack-a-mole... do_coredump(): don't wait for thaw if coredump has already been interrupted do_mount(): fix a leak introduced in 3.9 ("mount: consolidate permission checks")
2013-05-04xtensa simdisk: fix braino in "xtensa simdisk: switch to proc_create_data()"Al Viro
2013-05-04Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board specific changes (part 1) from Olof Johansson: "These changes are all for board specific files. These used to make up a large portion of the ARM changes in the past, but as we are generalizing the support and moving to device tree probing, this has gotten significantly smaller. The only platform actually adding new code here at the moment is Renesas shmobile, as they are still busy converting their code to device tree and have not come far enough to not need it." * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits) ARM: msm: USB_MSM_OTG needs USB_PHY ARM: davinci: da850 evm: fix const qualifier placement ARM: davinci: da850 board: add remoteproc support ARM: pxa: move debug uart code ARM: pxa: select PXA935 on saar & tavorevb ARM: mmp: add more compatible names in gpio driver ARM: pxa: move PXA_GPIO_TO_IRQ macro ARM: pxa: remove cpu_is_xxx in gpio driver ARM: Kirkwood: update Network Space Mini v2 description ARM: Kirkwood: DT board setup for CloudBox ARM: Kirkwood: sort board entries by ASCII-code order ARM: OMAP: board-4430sdp: Provide regulator to pwm-backlight ARM: OMAP: zoom: Use pwm stack for lcd and keyboard backlight ARM: OMAP2+: omap2plus_defconfig: Add support for BMP085 pressure sensor omap2+: Remove useless Makefile line omap2+: Remove useless Makefile line ARM: OMAP: RX-51: add missing regulator supply definitions for lis3lv02d ARM: OMAP1: fix omap_udc registration ARM: davinci: use is IS_ENABLED macro ARM: kirkwood: add MACH_GURUPLUG_DT to defconfig ...
2013-05-04Merge tag 'firmware-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM platform specific firmware interfaces from Olof Johansson: "Two platforms, bcm and exynos have their own firmware interfaces using the "secure monitor call", this adds support for those. We had originally planned to have a third set of patches in here, which would extend support for the existing generic "psci" call that is used on multiple platforms as well as Xen and KVM guests, but that ended up getting dropped because the patches were not ready in time." * tag 'firmware-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: bcm: mark bcm_kona_smc_init as __init ARM: bcm281xx: Add DT support for SMC handler ARM: bcm281xx: Add L2 cache enable code ARM: EXYNOS: Add secure firmware support to secondary CPU bring-up ARM: EXYNOS: Add IO mapping for non-secure SYSRAM. ARM: EXYNOS: Add support for Exynos secure firmware ARM: EXYNOS: Add support for secure monitor calls ARM: Add interface for registering and calling firmware-specific operations
2013-05-04Merge tag 'renesas-pinctrl-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC pinctrl changes for Renesas from Olof Johansson: "This is yet another driver change, which is split out just because of its size. As already in 3.9, a lot of changes are going on here, as the shmobile platform gets converted from its own pin control API to the generic drivers/pinctrl subsystem. Based on agreements with Paul Mundt, we are merging the sh-arch-side changes here as well" * tag 'renesas-pinctrl-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (142 commits) ARM: shmobile: r8a7779: Remove INTC function GPIOs ARM: shmobile: r8a7779: Remove LBSC function GPIOs ARM: shmobile: r8a7779: Remove USB function GPIOs ARM: shmobile: r8a7779: Remove HSPI function GPIOs ARM: shmobile: r8a7779: Remove SCIF function GPIOs ARM: shmobile: r8a7779: Remove SDHI and MMCIF function GPIOs ARM: shmobile: r8a7779: Remove DU function GPIOs ARM: shmobile: r8a7779: Remove DU1_DOTCLKOUT1 GPIO ARM: shmobile: r8a7740: Remove SDHI and MMCIF function GPIOs ARM: shmobile: r8a7740: Remove LCD0 and LCD1 function GPIOs ARM: shmobile: sh73a0: Remove IrDA function GPIOs ARM: shmobile: sh73a0: Remove USB function GPIOs ARM: shmobile: sh73a0: Remove BSC function GPIOs ARM: shmobile: sh73a0: Remove KEYSC function GPIOs ARM: shmobile: sh73a0: Remove pull-up function GPIOS ARM: shmobile: sh73a0: Remove FSI function GPIOs ARM: shmobile: sh73a0: Remove I2C function GPIOs ARM: shmobile: sh73a0: Remove SCIFA and SCIFB function GPIOs ARM: shmobile: sh73a0: Remove LCDC and LCDC2 function GPIOs ARM: shmobile: sh7372: Remove SDHI and MMCIF function GPIOs ...
2013-05-04Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Olof Johansson: "This is a rather large set of patches for device drivers that for one reason or another the subsystem maintainer preferred to get merged through the arm-soc tree. There are both new drivers as well as existing drivers that are getting converted from platform-specific code into standalone drivers using the appropriate subsystem specific interfaces. In particular, we can now have pinctrl, clk, clksource and irqchip drivers in one file per driver, without the need to call into platform specific interface, or to get called from platform specific code, as long as all information about the hardware is provided through a device tree. Most of the drivers we touch this time are for clocksource. Since now most of them are part of drivers/clocksource, I expect that we won't have to touch these again from arm-soc and can let the clocksource maintainers take care of these in the future. Another larger part of this series is specific to the exynos platform, which is seeing some significant effort in upstreaming and modernization of its device drivers this time around, which unfortunately is also the cause for the churn and a lot of the merge conflicts. There is one new subsystem that gets merged as part of this series: the reset controller interface, which is a very simple interface for taking devices on the SoC out of reset or back into reset. Patches to use this interface on i.MX follow later in this merge window, and we are going to have other platforms (at least tegra and sirf) get converted in 3.11. This will let us get rid of platform specific callbacks in a number of platform independent device drivers." * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (256 commits) irqchip: s3c24xx: add missing __init annotations ARM: dts: Disable the RTC by default on exynos5 clk: exynos5250: Fix parent clock for sclk_mmc{0,1,2,3} ARM: exynos: restore mach/regs-clock.h for exynos5 clocksource: exynos_mct: fix build error on non-DT pinctrl: vt8500: wmt: Fix checking return value of pinctrl_register() irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructure reset: NULL deref on allocation failure reset: Add reset controller API dt: describe base reset signal binding ARM: EXYNOS: Add arm-pmu DT binding for exynos421x ARM: EXYNOS: Add arm-pmu DT binding for exynos5250 ARM: EXYNOS: Enable PMUs for exynos4 irqchip: exynos-combiner: Correct combined IRQs for exynos4 irqchip: exynos-combiner: Add set_irq_affinity function for combiner_irq ARM: EXYNOS: fix compilation error introduced due to common clock migration clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3} clk: exynos4: export clocks required for fimc-is clk: samsung: Fix compilation error clk: tegra: fix enum tegra114_clk to match binding ...
2013-05-04perf/x86/intel/lbr: Fix LBR filterPeter Zijlstra
The LBR 'from' adddress is under full userspace control; ensure we validate it before reading from it. Note: is_module_text_address() can potentially be quite expensive; for those running into that with high overhead in modules optimize it using an RCU backed rb-tree. Reported-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> Cc: eranian@google.com Link: http://lkml.kernel.org/r/20130503121256.158211806@chello.nl Signed-off-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/n/tip-mk8i82ffzax01cnqo829iy1q@git.kernel.org
2013-05-04perf/x86: Blacklist all MEM_*_RETIRED events for Ivy BridgePeter Zijlstra
Errata BV98 states that all MEM_*_RETIRED events corrupt the counter value of the SMT sibling's counters. Blacklist these events Reported-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> Cc: eranian@google.com Link: http://lkml.kernel.org/r/20130503121256.083340271@chello.nl Signed-off-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/n/tip-jwra43mujrv1oq9xk6mfe57v@git.kernel.org
