path: root/arch
2012-03-05MIPS: BCM47XX: provide sprom to bcma busHauke Mehrtens
On SoCs the sprom is often stored in nvram in the flashchip. This patch registers a sprom fallback callback handler in bcma and provides the sprom needed for this device. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05MIPS: BCM47XX: move and extend sprom parsingHauke Mehrtens
Move the sprom parsing from nvram into sprom.c. There are all values needed for sprom version 1 to 9 read from nvram and there are more sanity checks added. This is based on the sprom parsing in the open source part of the Broadcom SDK. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05MIPS: BCM47XX: fix signature of nvram_parse_macaddrHauke Mehrtens
Explicitly enforce an char array of 6 bytes for the mac address. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-05MIPS: BCM47XX: return number of written bytes in nvram_getenvHauke Mehrtens
2012-02-15Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: net/mac80211/debugfs_sta.c net/mac80211/sta_info.h
2012-02-06bcma: add PCIe host controllerHauke Mehrtens
Some SoCs have a PCIe host controller to make it possible to attach some other devices to it, like an other Wifi card. This code was tested with an Netgear WNDR3400 (bcm4716 based), but should work with all bcma based SoCs. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Davem says: 1) Fix JIT code generation on x86-64 for divide by zero, from Eric Dumazet. 2) tg3 header length computation correction from Eric Dumazet. 3) More build and reference counting fixes for socket memory cgroup code from Glauber Costa. 4) module.h snuck back into a core header after all the hard work we did to remove that, from Paul Gortmaker and Jesper Dangaard Brouer. 5) Fix PHY naming regression and add some new PCI IDs in stmmac, from Alessandro Rubini. 6) Netlink message generation fix in new team driver, should only advertise the entries that changed during events, from Jiri Pirko. 7) SRIOV VF registration and unregistration fixes, and also add a missing PCI ID, from Roopa Prabhu. 8) Fix infinite loop in tx queue flush code of brcmsmac, from Stanislaw Gruszka. 9) ftgmac100/ftmac100 build fix, missing interrupt.h include. 10) Memory leak fix in net/hyperv do_set_mutlicast() handling, from Wei Yongjun. 11) Off by one fix in netem packet scheduler, from Vijay Subramanian. 12) TCP loss detection fix from Yuchung Cheng. 13) TCP reset packet MD5 calculation uses wrong address, fix from Shawn Lu. 14) skge carrier assertion and DMA mapping fixes from Stephen Hemminger. 15) Congestion recovery undo performed at the wrong spot in BIC and CUBIC congestion control modules, fix from Neal Cardwell. 16) Ethtool ETHTOOL_GSSET_INFO is unnecessarily restrictive, from Michał Mirosław. 17) Fix triggerable race in ipv6 sysctl handling, from Francesco Ruggeri. 18) Statistics bug fixes in mlx4 from Eugenia Emantayev. 19) rds locking bug fix during info dumps, from your's truly. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (67 commits) rds: Make rds_sock_lock BH rather than IRQ safe. netprio_cgroup.h: dont include module.h from other includes net: flow_dissector.c missing include linux/export.h team: send only changed options/ports via netlink net/hyperv: fix possible memory leak in do_set_multicast() drivers/net: dsa/mv88e6xxx.c files need linux/module.h stmmac: added PCI identifiers llc: Fix race condition in llc_ui_recvmsg stmmac: fix phy naming inconsistency dsa: Add reporting of silicon revision for Marvell 88E6123/88E6161/88E6165 switches. tg3: fix ipv6 header length computation skge: add byte queue limit support mv643xx_eth: Add Rx Discard and Rx Overrun statistics bnx2x: fix compilation error with SOE in fw_dump bnx2x: handle CHIP_REVISION during init_one bnx2x: allow user to change ring size in ISCSI SD mode bnx2x: fix Big-Endianess in ethtool -t bnx2x: fixed ethtool statistics for MF modes bnx2x: credit-leakage fixup on vlan_mac_del_all macvlan: fix a possible use after free ...
2012-01-23Merge tag 'arm-soc-imx-move' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Consolidate i.MX 5 platforms to be under the new shared i.MX 3/5/6 tree. * tag 'arm-soc-imx-move' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM i.MX: Update defconfig ARM i.MX: Merge i.MX5 support into mach-imx ARM i.MX5: remove unnecessary includes from board files Fix up fairly trivial conflicts due to various changes nearby in arch/arm/{mach,plat}-imx/{Kconfig,Makefile} Pull request had been sent to the wrong email address, but happened before the merge window closed. I'm merging the MX 5 consolidation, since it apparently will help the next development window and will avoid conflicts later as per Arnd.
2012-01-23score: fix off-by-one index into syscall tableDan Rosenberg
If the provided system call number is equal to __NR_syscalls, the current check will pass and a function pointer just after the system call table may be called, since sys_call_table is an array with total size __NR_syscalls. Whether or not this is a security bug depends on what the compiler puts immediately after the system call table. It's likely that this won't do anything bad because there is an additional NULL check on the syscall entry, but if there happens to be a non-NULL value immediately after the system call table, this may result in local privilege escalation. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: <stable@vger.kernel.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Eugene Teo <eugeneteo@kernel.sg> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-23kdump: define KEXEC_NOTE_BYTES arch specific for s390xMichael Holzheu
kdump only allocates memory for the prstatus ELF note. For s390x, besides of prstatus multiple ELF notes for various different register types are stored. Therefore the currently allocated memory is not sufficient. With this patch the KEXEC_NOTE_BYTES macro can be defined by architecture code and for s390x it is set to the correct size now. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Reviewed-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-19Merge branches 'sched-urgent-for-linus', 'perf-urgent-for-linus' and ↵Linus Torvalds
'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/accounting, proc: Fix /proc/stat interrupts sum * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tracepoints/module: Fix disabling tracepoints with taint CRAP or OOT x86/kprobes: Add arch/x86/tools/insn_sanity to .gitignore x86/kprobes: Fix typo transferred from Intel manual * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, syscall: Need __ARCH_WANT_SYS_IPC for 32 bits x86, tsc: Fix SMI induced variation in quick_pit_calibrate() x86, opcode: ANDN and Group 17 in x86-opcode-map.txt x86/kconfig: Move the ZONE_DMA entry under a menu x86/UV2: Add accounting for BAU strong nacks x86/UV2: Ack BAU interrupt earlier x86/UV2: Remove stale no-resources test for UV2 BAU x86/UV2: Work around BAU bug x86/UV2: Fix BAU destination timeout initialization x86/UV2: Fix new UV2 hardware by using native UV2 broadcast mode x86: Get rid of dubious one-bit signed bitfield
2012-01-19x86, syscall: Need __ARCH_WANT_SYS_IPC for 32 bitsH. Peter Anvin
In checkin 303395ac3bf3 x86: Generate system call tables and unistd_*.h from tables the feature macros in <asm/unistd.h> were unified between 32 and 64 bits. Unfortunately 32 bits requires __ARCH_WANT_SYS_IPC and this was inadvertently dropped. Reported-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/r/CALLzPKbeXN5gdngo8uYYU8mAow=XhrwBFBhKfG811f37BubQOg@mail.gmail.com
2012-01-19Merge remote-tracking branch 'linus/master' into x86/urgentH. Peter Anvin
2012-01-18uml: fix compile for x86-64Linus Torvalds
Randy Dunlap reports that we get arch/x86/um/shared/sysdep/ptrace.h:7:20: error: redefinition of 'regs_return_value' arch/x86/um/shared/sysdep/ptrace.h:7:20: note: previous definition of 'regs_return_value' was here when compiling UML for x86-64. Stephen Rothwell root-caused it and says: "Caused by commit d7e7528bcd45 ("Audit: push audit success and retcode into arch ptrace.h") (another patch that was never in linux-next :-(). This file now needs protection against double inclusion." so let's do as the man says. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Analyzed-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-18Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux This includes initial support for the recently published ACPI 5.0 spec. In particular, support for the "hardware-reduced" bit that eliminates the dependency on legacy hardware. APEI has patches resulting from testing on real hardware. Plus other random fixes. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (52 commits) acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi spec intel_idle: Split up and provide per CPU initialization func ACPI processor: Remove unneeded variable passed by acpi_processor_hotadd_init V2 ACPI processor: Remove unneeded cpuidle_unregister_driver call intel idle: Make idle driver more robust intel_idle: Fix a cast to pointer from integer of different size warning in intel_idle ACPI: kernel-parameters.txt : Add intel_idle.max_cstate intel_idle: remove redundant local_irq_disable() call ACPI processor: Fix error path, also remove sysdev link ACPI: processor: fix acpi_get_cpuid for UP processor intel_idle: fix API misuse ACPI APEI: Convert atomicio routines ACPI: Export interfaces for ioremapping/iounmapping ACPI registers ACPI: Fix possible alignment issues with GAS 'address' references ACPI, ia64: Use SRAT table rev to use 8bit or 16/32bit PXM fields (ia64) ACPI, x86: Use SRAT table rev to use 8bit or 32bit PXM fields (x86/x86-64) ACPI: Store SRAT table revision ACPI, APEI, Resolve false conflict between ACPI NVS and APEI ACPI, Record ACPI NVS regions ACPI, APEI, EINJ, Refine the fix of resource conflict ...
2012-01-18net: bpf_jit: fix divide by 0 generationEric Dumazet
Several problems fixed in this patch : 1) Target of the conditional jump in case a divide by 0 is performed by a bpf is wrong. 2) Must 'generate' the full function prologue/epilogue at pass=0, or else we can stop too early in pass=1 if the proglen doesnt change. (if the increase of prologue/epilogue equals decrease of all instructions length because some jumps are converted to near jumps) 3) Change the wrong length detection at the end of code generation to issue a more explicit message, no need for a full stack trace. Reported-by: Phil Oester <kernel@linuxace.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-18Merge branches 'einj', 'intel_idle', 'misc', 'srat' and 'turbostat-ivb' into ↵Len Brown
release
2012-01-17Merge tag 'arm-soc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc ARM: fixes for ARM platforms Some fallout from the 3.3. merge window as well as a couple bug fixes for older preexisting bugs that seem valid to include at this time: * sched_clock changes broke picoxcell, fix included * BSYM bugs causing issues with thumb2-built kernels on SMP * Missing module.h include on msm. * A collection of bugfixes for samsung platforms that didn't make it into the first pull requests. * tag 'arm-soc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: make BSYM macro assembly only ARM: highbank: remove incorrect BSYM usage ARM: imx: remove incorrect BSYM usage ARM: exynos: remove incorrect BSYM usage ARM: ux500: add missing ENDPROC to headsmp.S ARM: msm: Add missing ENDPROC to headsmp.S ARM: versatile: Add missing ENDPROC to headsmp.S ARM: EXYNOS: Invert VCLK polarity for framebuffer on ORIGEN ARM: S3C64XX: Fix interrupt configuration for PCA935x on Cragganmore ARM: S3C64XX: Fix the memory mapped GPIOs on Cragganmore ARM: S3C64XX: Remove hsmmc1 from Cragganmore ARM: S3C64XX: Remove unconditional power domain disables ARM: SAMSUNG: Declare struct platform_device in plat/s3c64xx-spi.h ARM: SAMSUNG: dma-ops.h needs mach/dma.h ARM: SAMSUNG: Guard against multiple inclusion of plat/dma.h ARM: picoxcell: fix sched_clock() cleanup fallout ARM: msm: vreg is a module and so needs module.h
2012-01-17Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits) ARM: mach-shmobile: specify CHCLR registers on SH7372 dma: shdma: fix runtime PM: clear channel buffers on reset dma/imx-sdma: save irq flags when use spin_lock in sdma_tx_submit dmaengine/ste_dma40: clear LNK on channel startup dmaengine: intel_mid_dma: remove legacy pm interface ASoC: mxs: correct 'direction' of device_prep_dma_cyclic dmaengine: intel_mid_dma: error path fix dmaengine: intel_mid_dma: locking and freeing fixes mtd: gpmi-nand: move to dma_transfer_direction mtd: fix compile error for gpmi-nand mmc: mxs-mmc: fix the dma_transfer_direction migration dmaengine: add DMA_TRANS_NONE to dma_transfer_direction dma: mxs-dma: Don't use CLKGATE bits in CTRL0 to disable DMA channels dma: mxs-dma: make mxs_dma_prep_slave_sg() multi user safe dma: mxs-dma: Always leave mxs_dma_init() with the clock disabled. dma: mxs-dma: fix a typo in comment DMA: PL330: Remove pm_runtime_xxx calls from pl330 probe/remove video i.MX IPU: Fix display connections i.MX IPU DMA: Fix wrong burstsize settings dmaengine/ste_dma40: allow fixed physical channel ... Fix up conflicts in drivers/dma/{Kconfig,mxs-dma.c,pl330.c} The conflicts looked pretty trivial, but I'll ask people to verify them.
2012-01-17x86-32: Fix build failure with AUDIT=y, AUDITSYSCALL=nAl Viro
JONGMAN HEO reports: With current linus git (commit a25a2b84), I got following build error, arch/x86/kernel/vm86_32.c: In function 'do_sys_vm86': arch/x86/kernel/vm86_32.c:340: error: implicit declaration of function '__audit_syscall_exit' make[3]: *** [arch/x86/kernel/vm86_32.o] Error 1 OK, I can reproduce it (32bit allmodconfig with AUDIT=y, AUDITSYSCALL=n) It's due to commit d7e7528bcd45: "Audit: push audit success and retcode into arch ptrace.h". Reported-by: JONGMAN HEO <jongman.heo@samsung.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit: (29 commits) audit: no leading space in audit_log_d_path prefix audit: treat s_id as an untrusted string audit: fix signedness bug in audit_log_execve_info() audit: comparison on interprocess fields audit: implement all object interfield comparisons audit: allow interfield comparison between gid and ogid audit: complex interfield comparison helper audit: allow interfield comparison in audit rules Kernel: Audit Support For The ARM Platform audit: do not call audit_getname on error audit: only allow tasks to set their loginuid if it is -1 audit: remove task argument to audit_set_loginuid audit: allow audit matching on inode gid audit: allow matching on obj_uid audit: remove audit_finish_fork as it can't be called audit: reject entry,always rules audit: inline audit_free to simplify the look of generic code audit: drop audit_set_macxattr as it doesn't do anything audit: inline checks for not needing to collect aux records audit: drop some potentially inadvisable likely notations ... Use evil merge to fix up grammar mistakes in Kconfig file. Bad speling and horrible grammar (and copious swearing) is to be expected, but let's keep it to commit messages and comments, rather than expose it to users in config help texts or printouts.
2012-01-17x86, tsc: Fix SMI induced variation in quick_pit_calibrate()Linus Torvalds
pit_expect_msb() returns success wrongly in the below SMI scenario: a. pit_verify_msb() has not yet seen the MSB transition. b. we are close to the MSB transition though and got a SMI immediately after returning from pit_verify_msb() which didn't see the MSB transition. PIT MSB transition has happened somewhere during SMI execution. c. returned from SMI and we noted down the 'tsc', saw the pit MSB change now and exited the loop to calculate 'deltatsc'. Instead of noting the TSC at the MSB transition, we are way off because of the SMI. And as the SMI happened between the pit_verify_msb() and before the 'tsc' is recorded in the for loop, 'delattsc' (d1/d2 in quick_pit_calibrate()) will be small and quick_pit_calibrate() will not notice this error. Depending on whether SMI disturbance happens while computing d1 or d2, we will see the TSC calibrated value smaller or bigger than the expected value. As a result, in a cluster we were seeing a variation of approximately +/- 20MHz in the calibrated values, resulting in NTP failures. [ As far as the SMI source is concerned, this is a periodic SMI that gets disabled after ACPI is enabled by the OS. But the TSC calibration happens before the ACPI is enabled. ] To address this, change pit_expect_msb() so that - the 'tsc' is the TSC in between the two reads that read the MSB change from the PIT (same as before) - the 'delta' is the difference in TSC from *before* the MSB changed to *after* the MSB changed. Now the delta is twice as big as before (it covers four PIT accesses, roughly 4us) and quick_pit_calibrate() will loop a bit longer to get the calibrated value with in the 500ppm precision. As the delta (d1/d2) covers four PIT accesses, actual calibrated result might be closer to 250ppm precision. As the loop now takes longer to stabilize, double MAX_QUICK_PIT_MS to 50. SMI disturbance will showup as much larger delta's and the loop will take longer than usual for the result to be with in the accepted precision. Or will fallback to slow PIT calibration if it takes more than 50msec. Also while we are at this, remove the calibration correction that aims to get the result to the middle of the error bars. We really don't know which direction to correct into, so remove it. Reported-and-tested-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Link: http://lkml.kernel.org/r/1326843337.5291.4.camel@sbsiddha-mobl2 Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-01-17Kernel: Audit Support For The ARM PlatformNathaniel Husted
This patch provides functionality to audit system call events on the ARM platform. The implementation was based off the structure of the MIPS platform and information in this (http://lists.fedoraproject.org/pipermail/arm/2009-October/000382.html) mailing list thread. The required audit_syscall_exit and audit_syscall_entry checks were added to ptrace using the standard registers for system call values (r0 through r3). A thread information flag was added for auditing (TIF_SYSCALL_AUDIT) and a meta-flag was added (_TIF_SYSCALL_WORK) to simplify modifications to the syscall entry/exit. Now, if either the TRACE flag is set or the AUDIT flag is set, the syscall_trace function will be executed. The prober changes were made to Kconfig to allow CONFIG_AUDITSYSCALL to be enabled. Due to platform availability limitations, this patch was only tested on the Android platform running the modified "android-goldfish-2.6.29" kernel. A test compile was performed using Code Sourcery's cross-compilation toolset and the current linux-3.0 stable kernel. The changes compile without error. I'm hoping, due to the simple modifications, the patch is "obviously correct". Signed-off-by: Nathaniel Husted <nhusted@gmail.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: inline audit_syscall_entry to reduce burden on archsEric Paris
Every arch calls: if (unlikely(current->audit_context)) audit_syscall_entry() which requires knowledge about audit (the existance of audit_context) in the arch code. Just do it all in static inline in audit.h so that arch's can remain blissfully ignorant. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: ia32entry.S sign extend error codes when calling 64 bit codeEric Paris
In the ia32entry syscall exit audit fastpath we have assembly code which calls __audit_syscall_exit directly. This code was, however, zeroes the upper 32 bits of the return code. It then proceeded to call code which expects longs to be 64bits long. In order to handle code which expects longs to be 64bit we sign extend the return code if that code is an error. Thus the __audit_syscall_exit function can correctly handle using the values in snprintf("%ld"). This fixes the regression introduced in 5cbf1565f29eb57a86a. Old record: type=SYSCALL msg=audit(1306197182.256:281): arch=40000003 syscall=192 success=no exit=4294967283 New record: type=SYSCALL msg=audit(1306197182.256:281): arch=40000003 syscall=192 success=no exit=-13 Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com>
2012-01-17Audit: push audit success and retcode into arch ptrace.hEric Paris
The audit system previously expected arches calling to audit_syscall_exit to supply as arguments if the syscall was a success and what the return code was. Audit also provides a helper AUDITSC_RESULT which was supposed to simplify things by converting from negative retcodes to an audit internal magic value stating success or failure. This helper was wrong and could indicate that a valid pointer returned to userspace was a failed syscall. The fix is to fix the layering foolishness. We now pass audit_syscall_exit a struct pt_reg and it in turns calls back into arch code to collect the return value and to determine if the syscall was a success or failure. We also define a generic is_syscall_success() macro which determines success/failure based on if the value is < -MAX_ERRNO. This works for arches like x86 which do not use a separate mechanism to indicate syscall failure. We make both the is_syscall_success() and regs_return_value() static inlines instead of macros. The reason is because the audit function must take a void* for the regs. (uml calls theirs struct uml_pt_regs instead of just struct pt_regs so audit_syscall_exit can't take a struct pt_regs). Since the audit function takes a void* we need to use static inlines to cast it back to the arch correct structure to dereference it. The other major change is that on some arches, like ia64, MIPS and ppc, we change regs_return_value() to give us the negative value on syscall failure. THE only other user of this macro, kretprobe_example.c, won't notice and it makes the value signed consistently for the audit functions across all archs. In arch/sh/kernel/ptrace_64.c I see that we were using regs[9] in the old audit code as the return value. But the ptrace_64.h code defined the macro regs_return_value() as regs[3]. I have no idea which one is correct, but this patch now uses the regs_return_value() function, so it now uses regs[3]. For powerpc we previously used regs->result but now use the regs_return_value() function which uses regs->gprs[3]. regs->gprs[3] is always positive so the regs_return_value(), much like ia64 makes it negative before calling the audit code when appropriate. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> [for x86 portion] Acked-by: Tony Luck <tony.luck@intel.com> [for ia64] Acked-by: Richard Weinberger <richard@nod.at> [for uml] Acked-by: David S. Miller <davem@davemloft.net> [for sparc] Acked-by: Ralf Baechle <ralf@linux-mips.org> [for mips] Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [for ppc]
2012-01-17x86, opcode: ANDN and Group 17 in x86-opcode-map.txtUlrich Drepper
The Intel documentation at http://software.intel.com/file/36945 shows the ANDN opcode and Group 17 with encoding f2 and f3 encoding respectively. The current version of x86-opcode-map.txt shows them with f3 and f4. Unless someone can point to documentation which shows the currently used encoding the following patch be applied. Signed-off-by: Ulrich Drepper <drepper@gmail.com> Link: http://lkml.kernel.org/r/CAOPLpQdq5SuVo9=023CYhbFLAX9rONyjmYq7jJkqc5xwctW5eA@mail.gmail.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-01-17Merge branch 'next' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'next' of git://git.monstr.eu/linux-2.6-microblaze: USB: EHCI: Don't use NO_IRQ in xilinx ehci driver microblaze: Add topology init
2012-01-17x86/kconfig: Move the ZONE_DMA entry under a menuRandy Dunlap
Move the ZONE_DMA kconfig symbol under a menu item instead of having it listed before everything else in "make {xconfig | gconfig | nconfig | menuconfig}". This drops the first line of the top-level kernel config menu (in 3.2) below and moves it under "Processor type and features". [*] DMA memory allocation support General setup ---> [*] Enable loadable module support ---> [*] Enable the block layer ---> Processor type and features ---> Power management and ACPI options ---> Bus options (PCI etc.) ---> Executable file formats / Emulations ---> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: David Rientjes <rientjes@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-mm@kvack.org <linux-mm@kvack.org> Link: http://lkml.kernel.org/r/4F14811E.6090107@xenotime.net Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: David Rientjes <rientjes@google.com>
2012-01-17ACPI, ia64: Use SRAT table rev to use 8bit or 16/32bit PXM fields (ia64)Kurt Garloff
In SRAT v1, we had 8bit proximity domain (PXM) fields; SRAT v2 provides 32bits for these. The new fields were reserved before. According to the ACPI spec, the OS must disregrard reserved fields. ia64 did handle the PXM fields almost consistently, but depending on sgi's sn2 platform. This patch leaves the sn2 logic in, but does also use 16/32 bits for PXM if the SRAT has rev 2 or higher. The patch also adds __init to the two pxm accessor functions, as they access __initdata now and are called from an __init function only anyway. Note that the code only uses 16 bits for the PXM field in the processor proximity field; the patch does not address this as 16 bits are more than enough. Signed-off-by: Kurt Garloff <kurt@garloff.de> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI, x86: Use SRAT table rev to use 8bit or 32bit PXM fields (x86/x86-64)Kurt Garloff
In SRAT v1, we had 8bit proximity domain (PXM) fields; SRAT v2 provides 32bits for these. The new fields were reserved before. According to the ACPI spec, the OS must disregrard reserved fields. x86/x86-64 was rather inconsistent prior to this patch; it used 8 bits for the pxm field in cpu_affinity, but 32 bits in mem_affinity. This patch makes it consistent: Either use 8 bits consistently (SRAT rev 1 or lower) or 32 bits (SRAT rev 2 or higher). cc: x86@kernel.org Signed-off-by: Kurt Garloff <kurt@garloff.de> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPI, Record ACPI NVS regionsHuang Ying
Some firmware will access memory in ACPI NVS region via APEI. That is, instructions in APEI ERST/EINJ table will read/write ACPI NVS region. The original resource conflict checking in APEI code will check memory/ioport accessed by APEI via general resource management mechanism. But ACPI NVS region is marked as busy already, so that the false resource conflict will prevent APEI ERST/EINJ to work. To fix this, this patch record ACPI NVS regions, so that we can avoid request resources for memory region inside it. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17Merge branch 'tip/perf/urgent-2' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/urgent
2012-01-17x86/UV2: Add accounting for BAU strong nacksCliff Wickman
This patch adds separate accounting of UV2 message "strong nack's" in the BAU statistics. Signed-off-by: Cliff Wickman <cpw@sgi.com> Link: http://lkml.kernel.org/r/20120116212238.GF5767@sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-17x86/UV2: Ack BAU interrupt earlierCliff Wickman
This patch moves the ack of the BAU interrupt to the beginning of the interrupt handler so that there is less possibility of a lost interrupt and slower response to a shootdown message. Signed-off-by: Cliff Wickman <cpw@sgi.com> Link: http://lkml.kernel.org/r/20120116212146.GE5767@sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-17x86/UV2: Remove stale no-resources test for UV2 BAUCliff Wickman
This patch removes an unnecessary test for a no-destination-resources-available condition that looks like a destination timeout in UV1, but is separately distinguishable in UV2. Signed-off-by: Cliff Wickman <cpw@sgi.com> Link: http://lkml.kernel.org/r/20120116212050.GD5767@sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-17x86/UV2: Work around BAU bugCliff Wickman
This patch implements a workaround for a UV2 hardware bug. The bug is a non-atomic update of a memory-mapped register. When hardware message delivery and software message acknowledge occur simultaneously the pending message acknowledge for the arriving message may be lost. This causes the sender's message status to stay busy. Part of the workaround is to not acknowledge a completed message until it is verified that no other message is actually using the resource that is mistakenly recorded in the completed message. Part of the workaround is to test for long elapsed time in such a busy condition, then handle it by using a spare sending descriptor. The stay-busy condition is eventually timed out by hardware, and then the original sending descriptor can be re-used. Most of that logic change is in keeping track of the current descriptor and the state of the spares. The occurrences of the workaround are added to the BAU statistics. Signed-off-by: Cliff Wickman <cpw@sgi.com> Link: http://lkml.kernel.org/r/20120116211947.GC5767@sgi.com Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-17x86/UV2: Fix BAU destination timeout initializationCliff Wickman
Move the call to enable_timeouts() forward so that BAU_MISC_CONTROL is initialized before using it in calculate_destination_timeout(). Fix the calculation of a BAU destination timeout for UV2 (in calculate_destination_timeout()). Signed-off-by: Cliff Wickman <cpw@sgi.com> Link: http://lkml.kernel.org/r/20120116211848.GB5767@sgi.com Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-17x86/UV2: Fix new UV2 hardware by using native UV2 broadcast modeCliff Wickman
Update the use of the Broadcast Assist Unit on SGI Altix UV2 to the use of native UV2 mode on new hardware (not the legacy mode). UV2 native mode has a different format for a broadcast message. We also need quick differentiaton between UV1 and UV2. Signed-off-by: Cliff Wickman <cpw@sgi.com> Link: http://lkml.kernel.org/r/20120116211750.GA5767@sgi.com Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-01-16Merge branch 'samsung-fixes' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes * 'samsung-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: EXYNOS: Invert VCLK polarity for framebuffer on ORIGEN ARM: S3C64XX: Fix interrupt configuration for PCA935x on Cragganmore ARM: S3C64XX: Fix the memory mapped GPIOs on Cragganmore ARM: S3C64XX: Remove hsmmc1 from Cragganmore ARM: S3C64XX: Remove unconditional power domain disables ARM: SAMSUNG: Declare struct platform_device in plat/s3c64xx-spi.h ARM: SAMSUNG: dma-ops.h needs mach/dma.h ARM: SAMSUNG: Guard against multiple inclusion of plat/dma.h
2012-01-16Merge branch 'fixes-for-arm-soc' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into fixes * 'fixes-for-arm-soc' of git://sources.calxeda.com/kernel/linux: ARM: make BSYM macro assembly only ARM: highbank: remove incorrect BSYM usage ARM: imx: remove incorrect BSYM usage ARM: exynos: remove incorrect BSYM usage ARM: ux500: add missing ENDPROC to headsmp.S ARM: msm: Add missing ENDPROC to headsmp.S ARM: versatile: Add missing ENDPROC to headsmp.S
2012-01-16Merge branch 'msm-fix' of git://codeaurora.org/quic/kernel/davidb/linux-msm ↵Olof Johansson
into fixes * 'msm-fix' of git://codeaurora.org/quic/kernel/davidb/linux-msm: ARM: msm: vreg is a module and so needs module.h
2012-01-16Merge branch 'picoxcell-fixes' of git://github.com/jamieiles/linux-2.6-ji ↵Olof Johansson
into fixes * 'picoxcell-fixes' of git://github.com/jamieiles/linux-2.6-ji: ARM: picoxcell: fix sched_clock() cleanup fallout
2012-01-16Merge branch 'x86-syscall-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-syscall-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Move <asm/asm-offsets.h> from trace_syscalls.c to asm/syscall.h x86, um: Fix typo in 32-bit system call modifications um: Use $(srctree) not $(KBUILD_SRC) x86, um: Mark system call tables readonly x86, um: Use the same style generated syscall tables as native um: Generate headers before generating user-offsets.s um: Run host archheaders, allow use of host generated headers kbuild, headers.sh: Don't make archheaders explicitly x86, syscall: Allow syscall offset to be symbolic x86, syscall: Re-fix typo in comment x86: Simplify syscallhdr.sh x86: Generate system call tables and unistd_*.h from tables checksyscalls: Use arch/x86/syscalls/syscall_32.tbl as source x86: Machine-readable syscall tables and scripts to process them trace: Include <asm/asm-offsets.h> in trace_syscalls.c x86-64, ia32: Move compat_ni_syscall into C and its own file x86-64, syscall: Adjust comment spacing and remove typo kbuild: Add support for an "archheaders" target kbuild: Add support for installing generated asm headers
2012-01-16Merge branch 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommuLinus Torvalds
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: ARM: OMAP3: fix build on !CONFIG_IOMMU_API
2012-01-16mce: fix warning messages about static struct mce_deviceGreg Kroah-Hartman
When suspending, there was a large list of warnings going something like: Device 'machinecheck1' does not have a release() function, it is broken and must be fixed This patch turns the static mce_devices into dynamically allocated, and properly frees them when they are removed from the system. It solves the warning messages on my laptop here. Reported-by: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: Djalal Harouni <tixxdz@opendz.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Borislav Petkov <bp@amd64.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-16Merge branch 'fixes' of ↵Linus Torvalds
git://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-arm * 'fixes' of git://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-arm: ARM: sa11x0: assabet: fix build warning ARM: Add arm_memblock_steal() to allocate memory away from the kernel ARM: 7275/1: LPAE: Check the CPU support for the long descriptor format ARM: 7274/1: NUC900: Rename nuc900-audio platform device to nuc900-ac97 ARM: 7272/1: S3C24XX: Fix build error for missing <mach/system-reset.h> ARM: 7271/1: Fix typo in conversion of ARCH_NR_GPIOS to Kconfig
2012-01-16Merge branch 'pm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm * 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / Hibernate: Drop the check of swap space size for compressed image PM / shmobile: fix A3SP suspend method PM / Domains: Skip governor functions for CONFIG_PM_RUNTIME unset PM / Domains: Fix build for CONFIG_PM_SLEEP unset PM: Make sysrq-o be available for CONFIG_PM unset
2012-01-16Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Kbuild: Use dtc's -d (dependency) option dtc: Implement -d option to write out a dependency file kbuild: Fix comment in Makefile.lib scripts/genksyms: clean lex/yacc generated files kbuild: Correctly deal with make options which contain an "s"
2012-01-16ARM: sa11x0: assabet: fix build warningRussell King
Since a32618d2 (ARM: pgtable: switch to use pgtable-nopud.h), assabet warns as follows: arch/arm/mach-sa1100/assabet.c: In function 'map_sa1100_gpio_regs': arch/arm/mach-sa1100/assabet.c:264: warning: passing argument 1 of 'pmd_offset' from incompatible pointer type Fix this by adding the necessary pud_offset() macro. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
