replace "printk(KERN_ERR" by "pr_err("
and fix needlessly multi-lined #ifdef
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Nishanth Menon <nm@ti.com>
Convert boards that use SMSC911x to use gpmc-smsc911x.
Also allocate struct platform_device dynamically.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
[tony@atomide.com: folded in a fix from Igor Grindberg]
SMSC911x devices attached to OMAP GPMC always use low level irqs.
Setting the appropriate flag in the irq resourse strucure allows using
.flags field in the omap_smsc911x_platform_data for driver specific
flags
* 'for-39-rc4' of git://codeaurora.org/quic/kernel/davidb/linux-msm:
msm: timer: fix missing return value
msm: Remove extraneous ffa device check
Because of speculative event roll back, it is possible for some event coutners
to decrease between reads on POWER7. This causes a problem with the way that
counters are updated. Delta calues are calculated in a 64 bit value and the
top 32 bits are masked. If the register value has decreased, this leaves us
with a very large positive value added to the kernel counters. This patch
protects against this by skipping the update if the delta would be negative.
This can lead to a lack of precision in the coutner values, but from my testing
the value is typcially fewer than 10 samples at a time.
Signed-off-by: Eric B Munson <emunson@mgebm.net>
Cc: stable@kernel.org
This problem was noticed on an MPC855T platform. Ftrace did oops
when trying to write to the kernel text segment.
Many thanks to Joakim for finding the root cause of this problem.
Cc: Joakim Tjernlund <joakim.tjernlund@transmode.se>
We currently enable interrupts before the dispatch log for the boot
cpu is setup. If a timer interrupt comes in early enough we oops in
scan_dispatch_log:
Unable to handle kernel paging request for data at address 0x00000010
.scan_dispatch_log+0xb0/0x170
.account_system_vtime+0xa0/0x220
.irq_enter+0x88/0xc0
.do_IRQ+0x48/0x230
The patch below adds a check to scan_dispatch_log to ensure the
dispatch log has been allocated.
Cc: <stable@kernel.org>
PAPR specifies that DTL buffers can not cross AMS environments (aka CMO
in the PAPR) and can not cross a memory entitlement granule boundary
(4k). This is found in section 14.11.3.2 H_REGISTER_VPA of the PAPR.
kmalloc does not guarantee an alignment of the allocation, though,
beyond 8 bytes (at least in my understanding). Create a special kmem
cache for DTL buffers with the alignment requirement.
Recent commit b987812b3fcaf70fdf0037589e5d2f5f2453e6ce caused
a compile failure on UP because a considerably large block
of the file was included within CONFIG_SMP, hence making a stub
function not exposed on UP builds when it needed to be.
Relocate the stub to the #else /* ! CONFIG_SMP */ section
and also annotate the relevant else/endif so that nobody
else falls into the same trap I did.
Reported-by: Michael Guntsche <mike@it-loops.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung
* 's5p-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: SAMSUNG: Fix warning 's3c_pm_show_resume_irqs' defined but not used
ARM: SAMSUNG: Fix build failure in PM CRC check code
ARM: S5P: Remove unused s3c_pm_check_resume_pin
Signed-off-by: Richard Henderson <rth@twiddle.net>
Following commit 091738a266fc ("genirq: Remove real old transition
functions") we removed an automatic conversion of no_irq_chip to
dummy_irq_chip. This change needs to be propagated back into the alpha
backend.
This is a new warning in gcc 4.6. Several of these variables are
used within #if 0 code, which probably ought to be removed. Most
of the changes are legitimate cleanups.
There are outstanding gcc 4.6 warnings that need to be cleaned up
in the subdirectory. No sense forcing the issue immediately.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (43 commits)
Revert "USB: isp1760-hcd: move imask clear after pending work is done"
xHCI: Implement AMD PLL quirk
xhci: Tell USB core both roothubs lost power.
usbcore: Bug fix: system can't suspend with USB3.0 device connected to USB3.0 hub
USB: Fix unplug of device with active streams
USB: xhci - also free streams when resetting devices
xhci: Fix NULL pointer deref in handle_port_status()
USB: xhci - fix math in xhci_get_endpoint_interval()
USB: xhci: simplify logic of skipping missed isoc TDs
USB: xhci - remove excessive 'inline' markings
USB: xhci: unsigned char never equals -1
USB: xhci - fix unsafe macro definitions
USB: fix formatting of SuperSpeed endpoints in /proc/bus/usb/devices
USB: fsl_qe_udc: send ZLP when zero flag and length % maxpacket == 0
usb: qcserial add missing errorpath kfrees
usb: qcserial avoid pointing to freed memory
usb: Fix qcserial memory leak on rmmod
USB: ftdi_sio: add ids for Hameg HO720 and HO730
USB: option: Added support for Samsung GT-B3730/GT-B3710 LTE USB modem.
'sched-fixes-for-linus', 'timer-fixes-for-linus' and 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Set FLAGS_HAS_TIMEOUT during futex_wait restart setup
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf_event: Fix cgrp event scheduling bug in perf_enable_on_exec()
perf: Fix a build error with some GCC versions
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Fix erroneous all_pinned logic
sched: Fix sched-domain avg_load calculation
* 'timer-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
RTC: rtc-mrst: follow on to the change of rtc_device_register()
RTC: add missing "return 0" in new alarm func for rtc-bfin.c
RTC: Fix s3c compile error due to missing s3c_rtc_setpie
RTC: Fix early irqs caused by calling rtc_set_alarm too early
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, amd: Disable GartTlbWlkErr when BIOS forgets it
x86, NUMA: Fix fakenuma boot failure
x86/mrst: Fix boot crash caused by incorrect pin to irq mapping
x86/ce4100: Add reg property to bridges
* 'for-linus' of git://android.git.kernel.org/kernel/tegra:
arm: tegra: fix error check in tegra2_clocks.c
ARM: tegra: gpio: Fix unused variable warnings
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: 6879/1: fix personality test wrt usage of domain handlers
ARM: 6878/1: fix personality flag propagation across an exec
ARM: 6877/1: the ADDR_NO_RANDOMIZE personality flag should be honored with mmap()
ARM: 6876/1: Kconfig.debug: Remove unused CONFIG_DEBUG_ERRORS
ARM: pxa: convert incorrect IRQ_TO_IRQ() to irq_to_gpio()
ARM: mmp: align NR_BUILTIN_GPIO with gpio interrupt number
ARM: pxa: align NR_BUILTIN_GPIO with GPIO interrupt number
ARM: pxa: always clear LPM bits for PXA168 MFPR
pcmcia: limit pxa2xx_trizeps4 subdriver to trizeps4 platform
pcmcia: limit pxa2xx_balloon3 subdriver to balloon3 platform
ARM: pxafb: Fix access to nonexistent member of pxafb_info
ARM: 6872/1: arch:common:Makefile Remove unused config in the Makefile.
ARM: 6868/1: Preserve the VFP state during fork
ARM: 6867/1: Introduce THREAD_NOTIFY_COPY for copy_thread() hooks
ARM: 6866/1: Do not restrict HIGHPTE to !OUTER_CACHE
ARM: 6865/1: perf: ensure pass through zero is counted on overflow
ARM: 6864/1: hw_breakpoint: clear DBGVCR out of reset
ARM: Only allow PM_SLEEP with CPUs which support suspend
ARM: Make consolidated PM sleep code depend on PM_SLEEP
This patch disables GartTlbWlk errors on AMD Fam10h CPUs if
the BIOS forgets to do is (or is just too old). Letting
these errors enabled can cause a sync-flood on the CPU
causing a reboot.
The AMD BKDG recommends disabling GART TLB Wlk Error completely.
This patch is the fix for
https://bugzilla.kernel.org/show_bug.cgi?id=33012
on my machine.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Link: http://lkml.kernel.org/r/20110415131152.GJ18463@8bytes.org
Tested-by: Alexandre Demers <alexandre.f.demers@gmail.com>
Currently, numa=fake boot parameter is broken. If it's used,
kernel may panic due to devide by zero error depending on CPU
configuration
Call Trace:
[<ffffffff8104ad4c>] find_busiest_group+0x38c/0xd30
[<ffffffff81086aff>] ? local_clock+0x6f/0x80
[<ffffffff81050533>] load_balance+0xa3/0x600
[<ffffffff81050f53>] idle_balance+0xf3/0x180
[<ffffffff81550092>] schedule+0x722/0x7d0
[<ffffffff81550538>] ? wait_for_common+0x128/0x190
[<ffffffff81550a65>] schedule_timeout+0x265/0x320
[<ffffffff81095815>] ? lock_release_holdtime+0x35/0x1a0
[<ffffffff8109bb6c>] ? __lock_release+0x9c/0x1d0
[<ffffffff815534e0>] ? _raw_spin_unlock_irq+0x30/0x40
[<ffffffff81550540>] wait_for_common+0x130/0x190
[<ffffffff81051920>] ? try_to_wake_up+0x510/0x510
[<ffffffff8155067d>] wait_for_completion+0x1d/0x20
[<ffffffff8107f36c>] kthread_create_on_node+0xac/0x150
[<ffffffff81077bb0>] ? process_scheduled_works+0x40/0x40
[<ffffffff8155045f>] ? wait_for_common+0x4f/0x190
[<ffffffff8107a283>] __alloc_workqueue_key+0x1a3/0x590
[<ffffffff81e0cce2>] cpuset_init_smp+0x6b/0x7b
[<ffffffff81df3d07>] kernel_init+0xc3/0x182
[<ffffffff8155d5e4>] kernel_thread_helper+0x4/0x10
[<ffffffff81553cd4>] ? retint_restore_args+0x13/0x13
[<ffffffff81df3c44>] ? start_kernel+0x400/0x400
[<ffffffff8155d5e0>] ? gs_change+0x13/0x13
The divede by zero is caused by the following line,
group->cpu_power==0:
kernel/sched_fair.c::update_sg_lb_stats()
/* Adjust by relative CPU power of the group */
sgs->avg_load = (sgs->group_load * SCHED_LOAD_SCALE) / group->cpu_power;
This regression was caused by commit e23bba6044 ("x86-64, NUMA: Unify
emulated distance mapping") because it changes cpu -> node
mapping in the process of dropping fake_physnodes().
old) all cpus are assinged node 0
now) cpus are assigned round robin
(the logic is implemented by numa_init_array())
Note: The change in behavior only happens if the system doesn't
have neither ACPI SRAT table nor AMD northbridge NUMA
information.
Round robin assignment doesn't work because init_numa_sched_groups_power()
assumes all logical cpus in the same physical cpu share the same node
(then it only accounts for group_first_cpu()), and the simple round robin
breaks the above assumption.
Thus, this patch implements a reassignment of node-ids if buggy firmware
or numa emulation makes wrong cpu node map. Tt enforce all logical cpus
in the same physical cpu share the same node.
Acked-by: Tejun Heo <tj@kernel.org>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: Shaohui Zheng <shaohui.zheng@intel.com>
Cc: H. Peter Anvin <hpa@linux.intel.com>
Link: http://lkml.kernel.org/r/20110415203928.1303.A69D9226@jp.fujitsu.com
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin:
Blackfin: SMP: fix cache flush loop
Blackfin: time-ts: ack gptimer sooner to avoid missing short ints
Blackfin: gptimers: fix thinko when disabling timers
Blackfin: SMP: make all barriers handle cache issues
Commit 8a5ec0ba "Lockless (and preemptless) fastpaths for slub" makes use
of this_cpu_cmpxchg_double() which needs this_cpu_cmpxchg16b_emu() on
x86_64. Implementing cmpxchg16b emulation for UML would introduce too
much complexity. So just disable it.
Signed-off-by: Richard Weinberger <richard@nod.at>
Reported-by: Sergei Trofimovich <slyich@gmail.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
Commit 1de1502c ("x86, um: now we can get rid of trivial uml headers")
removed accidentally bug.h which broke UML's call tracer and bug
handler.
Without asm-generic/bug.h UML uses BUG() from arch/x86/ which makes use
of ud2. UML cannot use ud2, it raises SIGILL in user mode. As UML has
a different stack for handling signals the call trace will be cut off.
Tested-by: Sergei Trofimovich <slyich@gmail.com>
Fix a possible problem with mport registration left non-cleared after
fsl_rio_setup() exits on link error. Abort mport initialization if
registration failed.
This patch is applicable to 2.6.39-rc1 only. The problem does not exist
for earlier versions.
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
Cc: Thomas Moll <thomas.moll@sysgo.com>
There are optional bits that may complement a personality ID. It is
therefore wrong to simply test against the absolute current->personality
value to determine the effective personality. The PER_LINUX_32BIT is
itself just PER_LINUX with one of those optional bits set.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Our SET_PERSONALITY() implementation was overwriting all existing
personality flags, including ADDR_NO_RANDOMIZE, making them unavailable
to processes being exec'd after a call to personality() in user space.
This prevents the gdb test suite from running successfully.
mmap()
This config option isn't actually used anywhere and can be safely
removed. The last user was traps.c before commit 082f47a ([ARM]
always allow dump_stack() to produce a backtrace, 2007-07-05).
Reviewed-by: Jesper Juhl <jj@chaosbits.net>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
s3c_pm_show_resume_irqs() is used by some s3c_pm_arch_show_resume_irqs()
implementations, which get included through mach/pm-core.h. Add __maybe_unused
to silence warnings when it isn't used (e.g. on S3C64XX platforms).
Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch fixes build error that occurs on enabling the Samsung
specific PM CRC check code. Missed removing this reference of
s3c_sleep_save_phys during move to generic cpu suspend/resume
support.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
The s3c_pm_check_resume_pin() is not being used and can be safely
removed to fix the build warning.
The recent commit (10774912647781) wasn't entirely correct. While
it fixed some issues, it introduced others. So pull in the fixes
from the public cache flush functions, and document why we need to
call things directly ourselves.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
If the period of a gptimer is fairly low, we might miss an interrupt
by acking it too late (we end up acking the new int as well).
Reported-by: Isabelle Leonardi <i.leonardi@detracom.fr>
We only want to clear the run bit for this one timer, not all status bits.
So don't read the whole reg and then write all the bits back out.
When suspending/resuming, the common task freezing code will run in
parallel and freeze processes on each core. This is because the code
uses the non-smp version of memory barriers (as well it should).
The Blackfin smp barrier logic at the moment contains the cache sync
logic, but the non-smp barriers do not. This is incorrect as Rafel
summarized:
> The existing memory barriers are SMP barriers too, but they are more
> than _just_ SMP barriers. At least that's how it is _supposed_ to be
> (eg. rmb() is supposed to be stronger than smp_rmb()).
> However, looking at the blackfin's definitions of SMP barriers I see
> that it uses extra stuff that should _also_ be used in the definitions
> of the mandatory barriers.
URL: http://lkml.org/lkml/2011/4/13/11
LKML-Reference: <BANLkTi=F-C-vwX4PGGfbkdTBw3OWL-twfg@mail.gmail.com>
Signed-off-by: Graf Yang <graf.yang@analog.com>
Disable USB_ARCH_HAS_EHCI in arch Kconfig and enable it in usb Kconfig
Warning log:
warning: (MICROBLAZE) selects USB_ARCH_HAS_EHCI which has unmet
direct dependencies (USB_SUPPORT)
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into fixes
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6:
avr32: add ATAG_BOARDINFO
don't check platform_get_irq's return value against zero
avr32: init cannot ignore signals sent by force_sig_info()
avr32: fix deadlock when reading clock list in debugfs
avr32: Fix .size directive for cpu_enter_idle
avr32: At32ap: pio fix typo "))" on gpio_irq_unmask prototype
fix the wrong argument of the functions definition
The ATAG_BOARDINFO is intended to hand over the information
bd->bi_board_number from u-boot to the kernel.
This piece of information can be used to implement some kind of board
identification while booting the kernel. Therefore it is placed in .initdata
section and can be accessed via the new symbol board_number only while
initializing the kernel.
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
platform_get_irq returns -ENXIO on failure, so !int_irq was probably
always true. Better use (int)int_irq <= 0. Note that a return value of
zero is still handled as error even though this could mean irq0.
This is a followup to 305b3228f9ff4d59f49e6d34a7034d44ee8ce2f0 that
changed the return value of platform_get_irq from 0 to -ENXIO on error.
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
We can delete the code that checks to see if we're sending an ignored
signal to init because force_sig_info() already handles this case.
force_sig_info() will kill init even if the signal handler is SIG_DFL
and the scenario described in the comment where init might "generate
the same exception over and over again" cannot occur (force_sig_info()
clears SIGNAL_UNKILLABLE to ensure that init will die).
Also, the use of is_global_init() is not correct in the multhreaded
case, as Oleg Nesterov explains,
"is_global_init() is not right in theory, /sbin/init can be
multithreaded. And, this doesn't cover the sub-namespace
inits... I'd suggest to check SIGNAL_UNKILLABLE, but looking
closer I think you can simply remove this code."
It seems this code was copied from arch/powerpc in March 2007 in commit
623b0355d5b1 "[AVR32] Clean up exception handling code"
but the code was deleted from arch/powerpc in November 2009 in commit
a0592d42fe3e "powerpc: kill the obsolete code under is_global_init()"
So catch up with powerpc and delete the bogus code.
Signed-off-by: Matt Fleming <matt.fleming@linux.intel.com>
When writing out /sys/kernel/debug/at32ap_clk, clock list lock is being
held while clk_get() is called. clk_get() attempts to take the same
lock, which results in deadlock. Introduce and call lock free version,
__clk_get(), instead.
Signed-off-by: Ole Henrik Jahren <olehenja@alumni.ntnu.no>
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
gas used to accept (and ignore?) .size directives which referred to
undefined symbols, as this does. In binutils 2.21 these are treated
as errors.
introduce in commit d75f1bfdbccb
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
The functions of eic_chip's memebers use the wrong argument .
Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com>
syncfs
Acked-by: Greg Ungerer <gerg@uclinux.org>
This fixes the failure to register the IRQ_RTCAlrm alarm as a wakeup
event. It is misinterpreted as a gpio irq not a PWER bitmask. Fixed
this by converting the incorrect IRQ_TO_IRQ() to a correct version of
irq_to_gpio().
Reported-by: Nick Bane <nickbane1@gmail.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
fix XEN_SAVE_RESTORE Kconfig dependencies
PM / Hibernate: Introduce CONFIG_HIBERNATE_CALLBACKS
