Currently percpu readmostly subsection may share cachelines with other
percpu subsections which may result in unnecessary cacheline bounce
and performance degradation.
This patch adds @cacheline parameter to PERCPU() and PERCPU_VADDR()
linker macros, makes each arch linker scripts specify its cacheline
size and use it to align percpu subsections.
This is based on Shaohua's x86 only patch.
Cc: Shaohua Li <shaohua.li@intel.com>
Use new 'datap' variable in order to remove unnecessary castings.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Cc: Chris Zankel <chris@zankel.net>
Fix up the arguments to arch_ptrace() to take account of the fact that
@addr and @data are now unsigned long rather than long as of a preceding
patch in this series.
Cc: <linux-arch@vger.kernel.org>
Acked-by: Roland McGrath <roland@redhat.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
3 years transition phase is enough. Cleanup the last users and remove
the cruft.
Cc: Leo Chen <leochen@broadcom.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jeff Dike <jdike@addtoit.com>
Make do_execve() take a const filename pointer so that kernel_execve() compiles
correctly on ARM:
arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type
This also requires the argv and envp arguments to be consted twice, once for
the pointer array and once for the strings the array points to. This is
because do_execve() passes a pointer to the filename (now const) to
copy_strings_kernel(). A simpler alternative would be to cast the filename
pointer in do_execve() when it's passed to copy_strings_kernel().
do_execve() may not change any of the strings it is passed as part of the argv
or envp lists as they are some of them in .rodata, so marking these strings as
const should be fine.
Further kernel_execve() and sys_execve() need to be changed to match.
This has been test built on x86_64, frv, arm and mips.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Mark arguments to certain system calls as being const where they should be but
aren't. The list includes:
(*) The filename arguments of various stat syscalls, execve(), various utimes
syscalls and some mount syscalls.
(*) The filename arguments of some syscall helpers relating to the above.
(*) The buffer argument of various write syscalls.
fix the following 'make includecheck' warnings:
arch/xtensa/kernel/vectors.S: asm/processor.h is included more than once.
arch/xtensa/kernel/vectors.S: asm/ptrace.h is included more than once.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Also remove lots of unused irq_cpustat fields.
* 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
avr32: Fix typo in read_persistent_clock()
sparc: Convert sparc to use read/update_persistent_clock
cris: Convert cris to use read/update_persistent_clock
m68k: Convert m68k to use read/update_persistent_clock
m32r: Convert m32r to use read/update_peristent_clock
blackfin: Convert blackfin to use read/update_persistent_clock
ia64: Convert ia64 to use read/update_persistent_clock
avr32: Convert avr32 to use read/update_persistent_clock
h8300: Convert h8300 to use read/update_persistent_clock
frv: Convert frv to use read/update_persistent_clock
mn10300: Convert mn10300 to use read/update_persistent_clock
alpha: Convert alpha to use read/update_persistent_clock
xtensa: Fix unnecessary setting of xtime
time: Clean up direct xtime usage in xen
The linker script was including assembly macros from the coprocessor
header file that is not otherwise used by the script.
Signed-off-by: Chris Zankel <chris@zankel.net>
The bss start and end symbols have changed to __bss_start and __bss_stop.
The Xtensa architecture requires to patch the generated linker script
to insert precede certain sections with a .literal section. Ammend the
sed script to fix-up only sequences that start with a '*':
'*(.init.text)' -> '*(.init.literal .init.text)'
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits)
doc: fix typo in comment explaining rb_tree usage
Remove fs/ntfs/ChangeLog
doc: fix console doc typo
doc: cpuset: Update the cpuset flag file
Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed
Remove drivers/parport/ChangeLog
Remove drivers/char/ChangeLog
doc: typo - Table 1-2 should refer to "status", not "statm"
tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments
No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h
devres/irq: Fix devm_irq_match comment
Remove reference to kthread_create_on_cpu
tree-wide: Assorted spelling fixes
tree-wide: fix 'lenght' typo in comments and code
drm/kms: fix spelling in error message
doc: capitalization and other minor fixes in pnp doc
devres: typo fix s/dev/devm/
Remove redundant trailing semicolons from macros
fix typo "definetly" -> "definitely" in comment
tree-wide: s/widht/width/g typo in comments
Fix trivial conflict in Documentation/laptops/00-INDEX
Use the generic ptrace_resume code for PTRACE_SYSCALL, PTRACE_CONT,
PTRACE_KILL and PTRACE_SINGLESTEP. This implies defining
arch_has_single_step in <asm/ptrace.h> and implementing the
user_enable_single_step and user_disable_single_step functions, which also
causes the breakpoint information to be cleared on fork, which could be
considered a bug fix.
Also the TIF_SYSCALL_TRACE thread flag is now cleared on PTRACE_KILL which
it previously wasn't which is consistent with all architectures using the
modern ptrace code.
Cc: Roland McGrath <roland@redhat.com>
xtensa supports read_persisitent_clock(), so there is no reason for
the arch specific code to be setting xtime. Setting xtime will be
done by the generic timekeeping code.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
Now that we return the new resource start position, there is no
need to update "struct resource" inside the align function.
Therefore, mark the struct resource as const.
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
As suggested by Linus, align functions should return the start
of a resource, not void. An update of "res->start" is no longer
necessary.
In particular, several occurances of funny versions of 'success',
'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address',
'beginning', 'desirable', 'separate' and 'necessary' are fixed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
* hpux_pipe() - no need to take BKL
* sys32_pipe() in arch/x86/ia32 and xtensa_pipe() in arch/xtensa -
no need at all, since both functions are open-coded sys_pipe()
Convert locks which cannot be sleeping locks in preempt-rt to
raw_spinlocks.
Acked-by: Peter Zijlstra <peterz@infradead.org>
New helper - sys_mmap_pgoff(); switch syscalls to using it.
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
Signed-off-by: Tim Abbott <tabbott@ksplice.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
This patch changes the remaining direct references to
.bss.page_aligned in C and assembly code to use the macros in
include/linux/linkage.h.
Acked-by: Paul Mundt <lethal@linux-sh.org>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Albin Tonnerre <albin.tonnerre@free-electrons.com> reported:
Bash 4 filters out variables which contain a dot in them.
This happends to be the case of CPPFLAGS_vmlinux.lds.
This is rather unfortunate, as it now causes
build failures when using SHELL=/bin/bash to compile,
or when bash happens to be used by make (eg when it's /bin/sh)
Remove the common definition of CPPFLAGS_vmlinux.lds by
pushing relevant stuff to either Makefile.build or the
arch specific kernel/Makefile where we build the linker script.
This is also nice cleanup as we move the information out where
it is used.
Notes for the different architectures touched:
arm - we use an already exported symbol
cris - we use a config symbol aleady available
[Not build tested]
mips - the jiffies complexity has moved to vmlinux.lds.S where we need it.
Added a few variables to CPPFLAGS - they are only used by
the linker script.
[Not build tested]
powerpc - removed assignment that is not needed
[not build tested]
sparc - simplified it using $(BITS)
um - introduced a few new exported variables to deal with this
xtensa - added options to CPP invocation
[not build tested]
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
* 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (34 commits)
time: Prevent 32 bit overflow with set_normalized_timespec()
clocksource: Delay clocksource down rating to late boot
clocksource: clocksource_select must be called with mutex locked
clocksource: Resolve cpu hotplug dead lock with TSC unstable, fix crash
timers: Drop a function prototype
timer.c: Fix S/390 comments
timekeeping: Fix invalid getboottime() value
timekeeping: Fix up read_persistent_clock() breakage on sh
timekeeping: Increase granularity of read_persistent_clock(), build fix
time: Introduce CLOCK_REALTIME_COARSE
x86: Do not unregister PIT clocksource on PIT oneshot setup/shutdown
clocksource: Avoid clocksource watchdog circular locking dependency
clocksource: Protect the watchdog rating changes with clocksource_mutex
clocksource: Call clocksource_change_rating() outside of watchdog_lock
timekeeping: Introduce read_boot_clock
timekeeping: Update clocksource with stop_machine
timekeeping: Add timekeeper read_clock helper functions
timekeeping: Move NTP adjusted clock multiplier to struct timekeeper
Fix trivial conflict due to MIPS lemote -> loongson renaming.
The persistent clock of some architectures (e.g. s390) have a
better granularity than seconds. To reduce the delta between the
host clock and the guest clock in a virtualized system change the
read_persistent_clock function to return a struct timespec.
Acked-by: John Stultz <johnstul@us.ibm.com>
Cc: Daniel Walker <dwalker@fifo99.com>
LKML-Reference: <20090814134811.013873340@de.ibm.com>
arch/sparc/kernel/smp_64.c
arch/x86/kernel/cpu/perf_counter.c
arch/x86/kernel/setup_percpu.c
drivers/cpufreq/cpufreq_ondemand.c
mm/percpu.c
Conflicts in core and arch percpu codes are mostly from commit
ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many
num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all
the first chunk allocators into mm/percpu.c, the changes are moved
from arch code to mm/percpu.c.
Discarded sections in different archs share some commonality but have
considerable differences. This led to linker script for each arch
implementing its own /DISCARD/ definition, which makes maintaining
tedious and adding new entries error-prone.
This patch makes all linker scripts to move discard definitions to the
end of the linker script and use the common DISCARDS macro. As ld
uses the first matching section definition, archs can include default
discarded sections by including them earlier in the linker script.
ia64 is notable because it first throws away some ia64 specific
subsections and then include the rest of the sections into the final
image, so those sections must be discarded before the inclusion.
defconfig compile tested for x86, x86-64, powerpc, powerpc64, ia64,
alpha, sparc, sparc64 and s390. Michal Simek tested microblaze.
Tested-by: Michal Simek <monstr@monstr.eu>
Cc: microblaze-uclinux@itee.uq.edu.au
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up
handling of log-levels and newlines") changed printk semantics. printk
lines with multiple KERN_<level> prefixes are no longer emitted as
before the patch.
<level> is now included in the output on each additional use.
Remove all uses of multiple KERN_<level>s in formats.
Pull linus#master to merge PER_CPU_DEF_ATTRIBUTES and alpha build fix
changes. As alpha in percpu tree uses 'weak' attribute instead of
inline assembly, there's no need for __used attribute.
arch/alpha/include/asm/percpu.h
arch/mn10300/kernel/vmlinux.lds.S
include/linux/percpu-defs.h
x86 throws away .discard section but no other archs do. Also,
.discard is not thrown away while linking modules. Make every arch
and module linking throw it away. This will be used to define dummy
variables for percpu declarations and definitions.
This patch is based on Ivan Kokshaysky's alpha percpu patch.
[ Impact: always throw away everything in .discard ]
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Bryan Wu <cooloney@kernel.org>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Kyle McMartin <kyle@mcmartin.ca>
There was already a PLATFORM_NR_IRQS define, which is now accompanied
by a VARIANT_NR_IRQS. To be able to initialize these interrupts,
init_IRQ now calls a variant specific hook.
Changes compared to v1:
- adapted to new CONFIG_VARIANT_IRQ_EXT
- removed definition and call of platform_init_IRQ as there already
is a platform_init_irq defined in asm/platform.h with a weak default
in kernel/platform.c
- renamed variant_init_IRQ to variant_init_irq
Note that I could not find the call site of platform_init_irq although
it is stated in platform.h that it is called from init_IRQ.
Signed-off-by: Daniel Glöckner <dg@emlix.com>
avr32, mn10300, parisc, s390, sh, xtensa:
They never set PT_DTRACE, but clear it after do_execve().
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Matthew Wilcox <matthew@wil.cx>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Acked-by: Chris Zankel <chris@zankel.net>
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
* create mm/init-mm.c, move init_mm there
* remove INIT_MM, initialize init_mm with C99 initializer
* unexport init_mm on all arches:
init_mm is already unexported on x86.
One strange place is some OMAP driver (drivers/video/omap/) which
won't build modular, but it's already wants get_vm_area() export.
Somebody should look there.
[akpm@linux-foundation.org: add missing #includes]
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Americo Wang <xiyou.wangcong@gmail.com>
Everyone cut and paste this comment from my original one. We now do
it generically, so cut the comments.
Cc: Amerigo Wang <amwang@redhat.com>
Fix resembles implementation from Marc Gauthier and Piet Denaly:
In the Xtensa architecture, assembly generates literals which must always
precede the code (the L32R instruction that loads them only uses negative
PC-relative offsets). For any *.text section, literals are placed in a
corresponding *.literal section. The linker script (vmlinux.lds) must
place these in the correct order. It must also combine them, when the
*.text section can be larger than L32R's 256 kB range.
For example, this doesn't work: *(.literal) *(.text) because L32R
instructions at the end of .text can't reach the literals.
The linker can solve this if they are combined in parentheses, like this:
*(.literal .text)
because it is now allowed mix literals in .text to bring them in range.
None of this is done by standard vmlinux.lds.h macros such as TEXT_TEXT
and INIT_TEXT. To avoid replicating the logic of that header file, we
instead post-process the generated linker script to convert *(xxx.text)
to *(xxx.literal xxx.text) for the following text sections:
.text .ref.text .*init.text .*exit.text .text.*
using a sed script. To do this we must override the default rule for
vmlinux.lds (see scripts/Makefile.build and the top-level Makefile)
to insert this extra step.
Signed-off-by: Marc Gauthier <marc@tensilica.com>
Signed-off-by: Pete Delaney <piet@tensilica.com>
Commit '28a0ce7 xtensa: use correct stack pointer for stack traces'
changed the stack tracer from always reading the stack pointer
register to always using the saved value in the task descriptor.
The author was too dense to consider the fact that the saved stack
value is stale for a running process und thus unusable for 'current'.
What we do now is to use the stack pointer register (a1) for when the
task is unknown - we can't help it then - or when the task is
'current'. For everything else use the saved stack pointer value
contained in the task descriptor.
Signed-off-by: Johannes Weiner <jw@emlix.com>
Signed-off-by: Tim Abbott <tabbott@mit.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into merge
Move it from .text to .init.text to get rid of it after boot and
prevent illegal section references.
Switch to GENERIC_TIME by using the ccount register as a clock source.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
platform_get/set_rtc_time() is not implemented by any of the supported
xtensa platforms. Remove the facility completely.
The initial seconds for xtime come from read_persistent_clock() which
returns just 0 in the generic implementation. Platforms that sport a
persistent clock can implement this function.
This is needed to implement the ccount as a clock source.
Current xtensa implementation of sched_clock() is the same as the
generic one. Just remove it, the weak symbol in kernel/sched_clock.c
will be used instead.
The linker script should not assume a fix offset in memory for the
kernel, this is platform-specific, so let the platform set it.
Allow the core variant code to provide irq enable/disable callbacks.
