Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Acked-by: Chris Zankel <chris@zankel.net>
Link: http://lkml.kernel.org/r/20130321215235.546600507@linutronix.de
The Xtensa architecture provides a global register called THREADPTR
for the purpose of Thread Local Storage (TLS) support. This allows us
to use a fairly simple implementation, keeping the thread pointer in
the regset and simply saving and restoring it upon entering/exiting
the from user space.
Signed-off-by: Chris Zankel <chris@zankel.net>
Remove heading and trailing spaces, trim trailing lines, and wrap lines
that are longer than 80 characters.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
When we copy a user thread with CLONE_VM, we also have to reset
windowbase and windowstart to start a pristine stack frame. Otherwise,
overflows can happen using the address 0 as the stack pointer.
Also add a special case for vfork, which continues on the
parent stack until it calls execve. Because this could be a call8, we
need to spill the stack pointer of the previus frame (if still 'live' in
the register file).
Fix two compiler warnings complaining about truncating a value on
a 64-bit host, and about declaring an unused variable that is only
used for a specific configuration.
When doing a fork (new VM), the new task has a mirror image of the
parent's stack, so keeps the same live register windows etc.
However when doing a clone with CLONE_VM, keeping the same VM
(eg. when creating a new thread), the child starts afresh on a new
stack -- it cannot share any part of the parent stack. It
especially cannot have the same live AR windows as the parent,
otherwise it will overwrite the parent stack on overflow, likely
causing corruption. (and so it did...)
Effectively, the register windows need to be spilled.
Turns out it's much easier to simply not copy parent register
windows when CLONE_VM is set.
Signed-off-by: Marc Gauthier <marc@tensilica.com>
getname() is intended to copy pathname strings from userspace into a
kernel buffer. The result is just a string in kernel space. It would
however be quite helpful to be able to attach some ancillary info to
the string.
For instance, we could attach some audit-related info to reduce the
amount of audit-related processing needed. When auditing is enabled,
we could also call getname() on the string more than once and not
need to recopy it from userspace.
This patchset converts the getname()/putname() interfaces to return
a struct instead of a string. For now, the struct just tracks the
string in kernel space and the original userland pointer for it.
Later, we'll add other information to the struct as it becomes
convenient.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
In the old times, the whole idle task was considered
as an RCU quiescent state. But as RCU became more and
more successful overtime, some RCU read side critical
section have been added even in the code of some
architectures idle tasks, for tracing for example.
So nowadays, rcu_idle_enter() and rcu_idle_exit() must
be called by the architecture to tell RCU about the part
in the idle loop that doesn't make use of rcu read side
critical sections, typically the part that puts the CPU
in low power mode.
This is necessary for RCU to find the quiescent states in
idle in order to complete grace periods.
Add this missing pair of calls in the xtensa's idle loop.
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: <stable@vger.kernel.org> # 3.3+
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Addresses: https://bugzilla.kernel.org/show_bug.cgi?id=43871
Reported-by: <dcb314@hotmail.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Historical prepare_to_copy() is mostly a no-op, duplicated for majority of
the architectures and the rest following the x86 model of flushing the extended
register state like fpu there.
Remove it and use the arch_dup_task_struct() instead.
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Link: http://lkml.kernel.org/r/1336692811-30576-1-git-send-email-suresh.b.siddha@intel.com
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Disintegrate asm/system.h for Xtensa.
cc: Chris Zankel <chris@zankel.net>
Coccinelle based conversion.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Make do_execve() take a const filename pointer so that kernel_execve() compiles
correctly on ARM:
arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type
This also requires the argv and envp arguments to be consted twice, once for
the pointer array and once for the strings the array points to. This is
because do_execve() passes a pointer to the filename (now const) to
copy_strings_kernel(). A simpler alternative would be to cast the filename
pointer in do_execve() when it's passed to copy_strings_kernel().
do_execve() may not change any of the strings it is passed as part of the argv
or envp lists as they are some of them in .rodata, so marking these strings as
const should be fine.
Further kernel_execve() and sys_execve() need to be changed to match.
This has been test built on x86_64, frv, arm and mips.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Mark arguments to certain system calls as being const where they should be but
aren't. The list includes:
(*) The filename arguments of various stat syscalls, execve(), various utimes
syscalls and some mount syscalls.
(*) The filename arguments of some syscall helpers relating to the above.
(*) The buffer argument of various write syscalls.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
avr32, mn10300, parisc, s390, sh, xtensa:
They never set PT_DTRACE, but clear it after do_execve().
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Matthew Wilcox <matthew@wil.cx>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Roland McGrath <roland@redhat.com>
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
First argument unused since 2.3.11.
Cc: <linux-arch@vger.kernel.org>
The Xtensa architecture allows to define custom instructions and
registers. Registers that are bound to a coprocessor are only
accessible if the corresponding enable bit is set, which allows
to implement a 'lazy' context switch mechanism. Other registers
needs to be saved and restore at the time of the context switch
or during interrupt handling.
This patch adds support for these additional states:
- save and restore registers that are used by the compiler upon
interrupt entry and exit.
- context switch additional registers unbound to any coprocessor
- 'lazy' context switch of registers bound to a coprocessor
- ptrace interface to provide access to additional registers
- update configuration files in include/asm-xtensa/variant-fsf
Remove additional registers from the ELF gregset structure that
are only used by the kernel or are not required or invalid in
user-space. The ar registers are always aligned to a windowbase
value of 0, and the WB register is always assumed to be 0.
Increase the size of the structure to 128 entries. This will
provide enough space in future.
Move all initialization structures for the initial task to it's own file.
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
This is a long outstanding patch to finally fix the syscall interface. The
constants used for the system calls are those we have provided in our libc
patches. This patch also fixes the shmbuf and stat structure, and fcntl
definitions.
The Xtensa port contained many header files that were never needed. This
rather lengthy patch removes all those files. Unfortunately, there were
many dependencies that needed to be updated, so this patch touches quite a
few source files.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Add the missing pm_power_off's for the h8300, v850 and xtensa
architectures.
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
Run idle threads with preempt disabled.
Also corrected a bugs in arm26's cpu_idle (make it actually call schedule()).
How did it ever work before?
Might fix the CPU hotplugging hang which Nigel Cunningham noted.
We think the bug hits if the idle thread is preempted after checking
need_resched() and before going to sleep, then the CPU offlined.
After calling stop_machine_run, the CPU eventually returns from preemption and
into the idle thread and goes to sleep. The CPU will continue executing
previous idle and have no chance to call play_dead.
By disabling preemption until we are ready to explicitly schedule, this bug is
fixed and the idle threads generally become more robust.
PPC build fix
MIPS build fix
Signed-off-by: Nick Piggin <npiggin@suse.de>
Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp>
Remove io_remap_page_range() from all of Linux 2.6.x (as requested and
suggested by Randy Dunlap) and minor clean-ups.
Delete obsoleted parts form arch makefiles and rename to asm-offsets.h
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
The attached patches provides part 3 of an architecture implementation for the
Tensilica Xtensa CPU series.
