path: root/arch/x86
2009-10-01x86: fix csum_ipv6_magic asm memory clobberSamuel Thibault
Just like ip_fast_csum, the assembly snippet in csum_ipv6_magic needs a memory clobber, as it is only passed the address of the buffer, not a memory reference to the buffer itself. This caused failures in Hurd's pfinetv4 when we tried to compile it with gcc-4.3 (bogus checksums). Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: "David S. Miller" <davem@davemloft.net> Cc: Andi Kleen <andi@firstfloor.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-30Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched_clock: Fix atomicity/continuity bug by using cmpxchg64() x86: Provide an alternative() based cmpxchg64()
2009-09-30x86: Provide an alternative() based cmpxchg64()Arjan van de Ven
cmpxchg64() today generates, to quote Linus, "barf bag" code. cmpxchg64() is about to get used in the scheduler to fix a bug there, but it's a prerequisite that cmpxchg64() first be made non-sucking. This patch turns cmpxchg64() into an efficient implementation that uses the alternative() mechanism to just use the raw instruction on all modern systems. Note: the fallback is NOT smp safe, just like the current fallback is not SMP safe. (Interested parties with i486 based SMP systems are welcome to submit fix patches for that.) Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> [ fixed asm constraint bug ] Fixed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20090930170754.0886ff2e@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-30Revert "x86, mce: do not compile mcelog message on AMD"Linus Torvalds
This reverts commit 22223c9b417be5fd0ab2cf9ad17eb7bd1e19f7b9, as requested by Andi Kleen: "Obviously kernels compiled with AMD support can still run on non AMD systems, so messages like this can never be removed at compile time." Requsted-by: Andi Kleen <andi@firstfloor.org> Cc: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-27Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: IA64=y ACPI=n build fix ACPI: Kill overly verbose "power state" log messages ACPI: fix Compaq Evo N800c (Pentium 4m) boot hang regression ACPI: Clarify resource conflict message thinkpad-acpi: fix CONFIG_THINKPAD_ACPI_HOTKEY_POLL build problem
2009-09-27x86: Fix hwpoison code related build failure on 32-bit NUMAQLinus Torvalds
This build failure triggers: In file included from include/linux/suspend.h:8, from arch/x86/kernel/asm-offsets_32.c:11, from arch/x86/kernel/asm-offsets.c:2: include/linux/mm.h:503:2: error: #error SECTIONS_WIDTH+NODES_WIDTH+ZONES_WIDTH > BITS_PER_LONG - NR_PAGEFLAGS Because due to the hwpoison page flag we ran out of page flags on 32-bit. Dont turn on hwpoison on 32-bit NUMA (it's rare in any case). Also clean up the Kconfig dependencies in the generic MM code by introducing ARCH_SUPPORTS_MEMORY_FAILURE. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-27ACPI: fix Compaq Evo N800c (Pentium 4m) boot hang regressionZhao Yakui
Don't disable ARB_DISABLE when the familary ID is 0x0F. http://bugzilla.kernel.org/show_bug.cgi?id=14211 This was a 2.6.31 regression, and so this patch needs to be applied to 2.6.31.stable Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-26Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf tools: Dont use openat() perf tools: Fix buffer allocation perf tools: .gitignore += perf*.html perf tools: Handle relative paths while loading module symbols perf tools: Fix module symbol loading bug perf_event, x86: Fix 'perf sched record' crashing the machine perf_event: Update PERF_EVENT_FORK header definition perf stat: Fix zero total printouts
2009-09-26Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Remove redundant non-NUMA topology functions x86: early_printk: Protect against using the same device twice x86: Reduce verbosity of "PAT enabled" kernel message x86: Reduce verbosity of "TSC is reliable" message x86: mce: Use safer ways to access MCE registers x86: mce, inject: Use real inject-msg in raise_local x86: mce: Fix thermal throttling message storm x86: mce: Clean up thermal throttling state tracking code x86: split NX setup into separate file to limit unstack-protected code xen: check EFER for NX before setting up GDT mapping x86: Cleanup linker script using new linker script macros. x86: Use section .data.page_aligned for the idt_table. x86: convert to use __HEAD and HEAD_TEXT macros. x86: convert compressed loader to use __HEAD and HEAD_TEXT macros. x86: fix fragile computation of vsyscall address
2009-09-25Merge branch 'x86/asm' into x86/urgentIngo Molnar
Merge reason: The linker script cleanups are ready for upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-24Merge branch 'drm-intel-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel * 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: (57 commits) drm/i915: Handle ERESTARTSYS during page fault drm/i915: Warn before mmaping a purgeable buffer. drm/i915: Track purged state. drm/i915: Remove eviction debug spam drm/i915: Immediately discard any backing storage for uneeded objects drm/i915: Do not mis-classify clean objects as purgeable drm/i915: Whitespace correction for madv drm/i915: BUG_ON page refleak during unbind drm/i915: Search harder for a reusable object drm/i915: Clean up evict from list. drm/i915: Add tracepoints drm/i915: framebuffer compression for GM45+ drm/i915: split display functions by chip type drm/i915: Skip the sanity checks if the current relocation is valid drm/i915: Check that the relocation points to within the target drm/i915: correct FBC update when pipe base update occurs drm/i915: blacklist Acer AspireOne lid status ACPI: make ACPI button funcs no-ops if not built in drm/i915: prevent FIFO calculation overflows on 32 bits with high dotclocks drm/i915: intel_display.c handle latency variable efficiently ... Fix up trivial conflicts in drivers/gpu/drm/i915/{i915_dma.c|i915_drv.h}
2009-09-24Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (21 commits) x86/PCI: make 32 bit NUMA node array int, not unsigned char x86/PCI: default pcibus cpumask to all cpus if it lacks affinity MAINTAINTERS: remove hotplug driver entries PCI: pciehp: remove slot capabilities definitions PCI: pciehp: remove error message definitions PCI: pciehp: remove number field PCI: pciehp: remove hpc_ops PCI: pciehp: remove pci_dev field PCI: pciehp: remove crit_sect mutex PCI: pciehp: remove slot_bus field PCI: pciehp: remove first_slot field PCI: pciehp: remove slot_device_offset field PCI: pciehp: remove hp_slot field PCI: pciehp: remove device field PCI: pciehp: remove bus field PCI: pciehp: remove slot_num_inc field PCI: pciehp: remove num_slots field PCI: pciehp: remove slot_list field PCI: fix VGA arbiter header file PCI: Disable AER with pci=nomsi ... Fixed up trivial conflicts in MAINTAINERS
2009-09-24Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits) HWPOISON: Enable error_remove_page on btrfs HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs HWPOISON: Add madvise() based injector for hardware poisoned pages v4 HWPOISON: Enable error_remove_page for NFS HWPOISON: Enable .remove_error_page for migration aware file systems HWPOISON: The high level memory error handler in the VM v7 HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process HWPOISON: shmem: call set_page_dirty() with locked page HWPOISON: Define a new error_remove_page address space op for async truncation HWPOISON: Add invalidate_inode_page HWPOISON: Refactor truncate to allow direct truncating of page v2 HWPOISON: check and isolate corrupted free pages v2 HWPOISON: Handle hardware poisoned pages in try_to_unmap HWPOISON: Use bitmask/action code for try_to_unmap behaviour HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2 HWPOISON: Add poison check to page fault handling HWPOISON: Add basic support for poisoned pages in fault handler v3 HWPOISON: Add new SIGBUS error codes for hardware poison signals HWPOISON: Add support for poison swap entries v2 HWPOISON: Export some rmap vma locking to outside world ...
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24x86: Remove redundant non-NUMA topology functionsRusty Russell
arch/x86/include/asm/topology.h declares inline fns cpu_to_node and cpumask_of_node for !NUMA, even though they are then declared as macros by asm-generic/topology.h, which is #included just below. The macros (which are the same) end up being used; these functions are just confusing. Noticed-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: "Greg Kroah-Hartman" <gregkh@suse.de> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Tejun Heo <tj@kernel.org> LKML-Reference: <200909241748.45629.rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-24x86: early_printk: Protect against using the same device twiceJason Wessel
If you use the kernel argument: earlyprintk=serial,ttyS0,115200 This will cause a recursive hang printing the same line again and again: BIOS-e820: 000000003fff3000 - 0000000040000000 (ACPI data) BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved) BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved) bootconsole [earlyser0] enabled Linux version 2.6.31-07863-gb64ada6 (mingo@sirius) (gcc version 4.3.2 20081105 (Red Hat 4.3.2-7) (GCC) ) #16789 SMP Wed Sep 23 21:09:43 CEST 2009 Linux version 2.6.31-07863-gb64ada6 (mingo@sirius) (gcc version 4.3.2 20081105 (Red Hat 4.3.2-7) (GCC) ) #16789 SMP Wed Sep 23 21:09:43 CEST 2009 Linux version 2.6.31-07863-gb64ada6 (mingo@sirius) (gcc version 4.3.2 20081105 (Red Hat 4.3.2-7) (GCC) ) #16789 SMP Wed Sep 23 21:09:43 CEST 2009 Linux version 2.6.31-07863-gb64ada6 (mingo@sirius) (gcc version 4.3.2 20081105 (Red Hat 4.3.2-7) (GCC) ) #16789 SMP Wed Sep 23 21:09:43 CEST 2009 Linux version 2.6.31-07863-gb64ada6 (mingo@sirius) (gcc version 4.3.2 20081105 (Red Hat 4.3.2-7) (GCC) ) #16789 SMP Wed Sep 23 21:09:43 CEST 2009 Instead warn the end user that they specified the device a second time, and ignore that second console. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <gregkh@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4ABAAB89.1080407@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-24Merge branch 'linus' into x86/urgentIngo Molnar
Merge reason: Queueing up dependent early-printk fix. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-24x86: Reduce verbosity of "PAT enabled" kernel messageRoland Dreier
On modern systems, the kernel prints the message x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 once for every CPU. This gets kind of ridiculous on huge systems; for example, on a 64-thread system I was lucky enough to get: dmesg| grep 'PAT enabled' | wc 64 704 5174 There is already a BUG() if non-boot CPUs have PAT capabilities that don't match the boot CPU, so just print the message on the boot CPU. (I kept the print after the wrmsrl() that enables PAT, so that the log output continues to mean that the system survived enabling PAT on the boot CPU) Signed-off-by: Roland Dreier <rolandd@cisco.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> LKML-Reference: <adavdj92sso.fsf@cisco.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-24x86: Reduce verbosity of "TSC is reliable" messageRoland Dreier
On modern systems, the kernel prints the message Skipping synchronization checks as TSC is reliable. once for every non-boot CPU. This gets kind of ridiculous on huge systems; for example, on a 64-thread system I was lucky enough to get: $ dmesg | grep 'TSC is reliable' | wc 63 567 4221 There's no point to doing this for every CPU, since the code is just checking the boot CPU anyway, so change this to a printk_once() to make the message appears only once. Signed-off-by: Roland Dreier <rolandd@cisco.com> LKML-Reference: <adazl8l2swc.fsf@cisco.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (39 commits) cpumask: Move deprecated functions to end of header. cpumask: remove unused deprecated functions, avoid accusations of insanity cpumask: use new-style cpumask ops in mm/quicklist. cpumask: use mm_cpumask() wrapper: x86 cpumask: use mm_cpumask() wrapper: um cpumask: use mm_cpumask() wrapper: mips cpumask: use mm_cpumask() wrapper: mn10300 cpumask: use mm_cpumask() wrapper: m32r cpumask: use mm_cpumask() wrapper: arm cpumask: Use accessors for cpu_*_mask: um cpumask: Use accessors for cpu_*_mask: powerpc cpumask: Use accessors for cpu_*_mask: mips cpumask: Use accessors for cpu_*_mask: m32r cpumask: remove arch_send_call_function_ipi cpumask: arch_send_call_function_ipi_mask: s390 cpumask: arch_send_call_function_ipi_mask: powerpc cpumask: arch_send_call_function_ipi_mask: mips cpumask: arch_send_call_function_ipi_mask: m32r cpumask: arch_send_call_function_ipi_mask: alpha cpumask: remove obsolete topology_core_siblings and topology_thread_siblings: ia64 ...
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cpumask: use mm_cpumask() wrapper: x86Rusty Russell
Makes code futureproof against the impending change to mm->cpu_vm_mask (to be a pointer). It's also a chance to use the new cpumask_ ops which take a pointer (the older ones are deprecated, but there's no hurry for arch code). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-24cpumask: remove arch_send_call_function_ipiRusty Russell
Now everyone is converted to arch_send_call_function_ipi_mask, remove the shim and the #defines. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-24cpumask: remove last assignment to mask field of struct irqaction.Rusty Russell
This snuck in after the patch which removed all the others. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2009-09-24cpumask: use zalloc_cpumask_var() where possibleLi Zefan
Remove open-coded zalloc_cpumask_var() and zalloc_cpumask_var_node(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-23Merge branch 'x86/ptrace-syscall-exit' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frob/linux-2.6-roland * 'x86/ptrace-syscall-exit' of git://git.kernel.org/pub/scm/linux/kernel/git/frob/linux-2.6-roland: x86: ptrace: sysret path should reach syscall_trace_leave
2009-09-23Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: (23 commits) intel-iommu: Disable PMRs after we enable translation, not before intel-iommu: Kill DMAR_BROKEN_GFX_WA option. intel-iommu: Fix integer wrap on 32 bit kernels intel-iommu: Fix integer overflow in dma_pte_{clear_range,free_pagetable}() intel-iommu: Limit DOMAIN_MAX_PFN to fit in an 'unsigned long' intel-iommu: Fix kernel hang if interrupt remapping disabled in BIOS intel-iommu: Disallow interrupt remapping if not all ioapics covered intel-iommu: include linux/dmi.h to use dmi_ routines pci/dmar: correct off-by-one error in dmar_fault() intel-iommu: Cope with yet another BIOS screwup causing crashes intel-iommu: iommu init error path bug fixes intel-iommu: Mark functions with __init USB: Work around BIOS bugs by quiescing USB controllers earlier ia64: IOMMU passthrough mode shouldn't trigger swiotlb init intel-iommu: make domain_add_dev_info() call domain_context_mapping() intel-iommu: Unify hardware and software passthrough support intel-iommu: Cope with broken HP DC7900 BIOS iommu=pt is a valid early param intel-iommu: double kfree() intel-iommu: Kill pointless intel_unmap_single() function ... Fixed up trivial include lines conflict in drivers/pci/intel-iommu.c
2009-09-23Merge branch 'sfi-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6 * 'sfi-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6: SFI: remove unneeded includes sfi: Remove unused code SFI: Hook PCI MMCONFIG x86: add arch-specific SFI support SFI: add capability to parse ACPI tables SFI: add platform-independent core support SFI: create linux/sfi.h SFI: Simple Firmware Interface - MAINTAINERS, Kconfig
2009-09-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (119 commits) ACPI: don't pass handle for fixed hardware notifications ACPI: remove null pointer checks in deferred execution path ACPI: simplify deferred execution path acerhdf: additional BIOS versions acerhdf: convert to dev_pm_ops acerhdf: fix fan control for AOA150 model thermal: add missing Kconfig dependency acpi: switch /proc/acpi/{debug_layer,debug_level} to seq_file hp-wmi: fix rfkill memory leak on unload ACPI: remove unnecessary #ifdef CONFIG_DMI ACPI: linux/acpi.h should not include linux/dmi.h hwmon driver for ACPI 4.0 power meters topstar-laptop: add new driver for hotkeys support on Topstar N01 thinkpad_acpi: fix rfkill memory leak on unload thinkpad-acpi: report brightness events when required thinkpad-acpi: don't poll by default any of the reserved hotkeys thinkpad-acpi: Fix procfs hotkey reset command thinkpad-acpi: deprecate hotkey_bios_mask thinkpad-acpi: hotkey poll fixes thinkpad-acpi: be more strict when detecting a ThinkPad ...
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (142 commits) USB: Fix sysfs paths in documentation USB: skeleton: fix coding style issues. USB: O_NONBLOCK in read path of skeleton USB: make usb-skeleton honor O_NONBLOCK in write path USB: skel_read really sucks royally USB: Add hub descriptor update hook for xHCI USB: xhci: Support USB hubs. USB: xhci: Set multi-TT field for LS/FS devices under hubs. USB: xhci: Set route string for all devices. USB: xhci: Fix command wait list handling. USB: xhci: Change how xHCI commands are handled. USB: xhci: Refactor input device context setup. USB: xhci: Endpoint representation refactoring. USB: gadget: ether needs to select CRC32 USB: fix USBTMC get_capabilities success handling USB: fix missing error check in probing USB: usbfs: add USBDEVFS_URB_BULK_CONTINUATION flag USB: support for autosuspend in sierra while online USB: ehci-dbgp,ehci: Allow dbpg to work with suspend/resume USB: ehci-dbgp,documentation: Documentation updates for ehci-dbgp ...
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: lguest: don't force VIRTIO_F_NOTIFY_ON_EMPTY lguest: cleanup for map_switcher() lguest: use PGDIR_SHIFT for PAE code to allow different PAGE_OFFSET lguest: use set_pte/set_pmd uniformly for real page table entries lguest: move panic notifier registration to its expected place. virtio_blk: add support for cache flush virtio: add virtio IDs file virtio: get rid of redundant VIRTIO_ID_9P definition virtio: make add_buf return capacity remaining virtio_pci: minor MSI-X cleanups
2009-09-23x86: mce: Use safer ways to access MCE registersIngo Molnar
Use rdmsrl_safe() when accessing MCE registers. While in theory we always 'know' which ones are safe to access from the capability bits, there's a lot of hardware variations and reality might differ from theory, as it did in this case: http://bugzilla.kernel.org/show_bug.cgi?id=14204 [ 0.010016] mce: CPU supports 5 MCE banks [ 0.011029] general protection fault: 0000 [#1] [ 0.011998] last sysfs file: [ 0.011998] Modules linked in: [ 0.011998] [ 0.011998] Pid: 0, comm: swapper Not tainted (2.6.31_router #1) HP Vectra [ 0.011998] EIP: 0060:[<c100d9b9>] EFLAGS: 00010246 CPU: 0 [ 0.011998] EIP is at mce_rdmsrl+0x19/0x60 [ 0.011998] EAX: 00000000 EBX: 00000001 ECX: 00000407 EDX: 08000000 [ 0.011998] ESI: 00000000 EDI: 8c000000 EBP: 00000405 ESP: c17d5eac So WARN_ONCE() instead of crashing the box. ( also fix a number of stylistic inconsistencies in the code. ) Note, we might still crash in wrmsrl() if we get that far, but we shouldnt if the registers are truly inaccessible. Reported-by: GNUtoo <GNUtoo@no-log.org> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Andi Kleen <ak@linux.intel.com> LKML-Reference: <bug-14204-5438@http.bugzilla.kernel.org/> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-23Merge branch 'x86/orig_ax' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frob/linux-2.6-roland * 'x86/orig_ax' of git://git.kernel.org/pub/scm/linux/kernel/git/frob/linux-2.6-roland: x86: ptrace: set TS_COMPAT when 32-bit ptrace sets orig_eax>=0 x86: ptrace: do not sign-extend orig_ax on write x86: syscall_get_nr returns int asm-generic: syscall_get_nr returns int
2009-09-23kcore: register module area in generic wayKAMEZAWA Hiroyuki
Some archs define MODULED_VADDR/MODULES_END which is not in VMALLOC area. This is handled only in x86-64. This patch make it more generic. And we can use vread/vwrite to access the area. Fix it. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: use registerd physmem informationKAMEZAWA Hiroyuki
For /proc/kcore, each arch registers its memory range by kclist_add(). In usual, - range of physical memory - range of vmalloc area - text, etc... are registered but "range of physical memory" has some troubles. It doesn't updated at memory hotplug and it tend to include unnecessary memory holes. Now, /proc/iomem (kernel/resource.c) includes required physical memory range information and it's properly updated at memory hotplug. Then, it's good to avoid using its own code(duplicating information) and to rebuild kclist for physical memory based on /proc/iomem. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: register text area in generic wayKAMEZAWA Hiroyuki
Some 64bit arch has special segment for mapping kernel text. It should be entried to /proc/kcore in addtion to direct-linear-map, vmalloc area. This patch unifies KCORE_TEXT entry scattered under x86 and ia64. I'm not familiar with other archs (mips has its own even after this patch) but range of [_stext ..._end) is a valid area of text and it's not in direct-map area, defining CONFIG_ARCH_PROC_KCORE_TEXT is only a necessary thing to do. Note: I left mips as it is now. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: register vmalloc area in generic wayKAMEZAWA Hiroyuki
For /proc/kcore, vmalloc areas are registered per arch. But, all of them registers same range of [VMALLOC_START...VMALLOC_END) This patch unifies them. By this. archs which have no kclist_add() hooks can see vmalloc area correctly. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: add kclist typesKAMEZAWA Hiroyuki
Presently, kclist_add() only eats start address and size as its arguments. Considering to make kclist dynamically reconfigulable, it's necessary to know which kclists are for System RAM and which are not. This patch add kclist types as KCORE_RAM KCORE_VMALLOC KCORE_TEXT KCORE_OTHER This "type" is used in a patch following this for detecting KCORE_RAM. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23early_printk: Allow more than one early consoleJason Wessel
It is desirable to be able to use one early boot device to debug another or to have multiple places you can see the early boot diagnostics, such as the vga screen or serial device. This patch changes the early_printk console device registration to allow more than one early printk device to get registered via register_console(). Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: ehci,dbgp,early_printk: split ehci debug driver from early_printk.cJason Wessel
Move the dbgp early printk driver in advance of refactoring and adding new code, so the changes to this code are tracked separately from the move of the code. The drivers/usb/early directory will be the location of the current and future early usb code for driving usb devices prior initializing the standard interrupt driven USB drivers. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23lguest: move panic notifier registration to its expected place.Rusty Russell
We used to defer it, so lockdep was happy. We now init lockdep early anyway, so just do it after that. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23Merge branch 'bugfix' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen into x86/urgent
2009-09-23perf_event, x86: Fix 'perf sched record' crashing the machinePeter Zijlstra
Chris Malley reported that 'perf sched record' sometimes crashes his box with: [ 389.272175] BUG: unable to handle kernel paging request at ffffb300 [ 389.272294] IP: [<c011b0bd>] default_send_IPI_self+0x1d/0x50 [ 389.272366] *pde = 0073f067 *pte = 00000000 [ 389.274708] Call Trace: [ 389.274752] [<c010e3b4>] ? set_perf_event_pending+0x14/0x20 [ 389.274801] [<c01b9751>] ? perf_output_unlock+0x121/0x1a0 [ 389.274848] [<c01b981a>] ? perf_output_end+0x4a/0x70 [ 389.274893] [<c01ba690>] ? __perf_event_overflow+0x240/0x2f0 [ 389.274942] [<c030963e>] ? atomic64_cmpxchg+0x1e/0x30 [ 389.274988] [<c01ba8f4>] ? perf_swevent_ctx_event+0x1b4/0x1c0 [ 389.275035] [<c01ba773>] ? perf_swevent_ctx_event+0x33/0x1c0 [ 389.275081] [<c01ba9a7>] ? do_perf_sw_event+0xa7/0x160 [ 389.275127] [<c01baae2>] ? perf_tp_event+0x82/0xa0 [ 389.275174] [<c012e9c6>] ? ftrace_profile_sched_stat_runtime+0xe6/0x120 [ 389.275224] [<c012e8e0>] ? ftrace_profile_sched_stat_runtime+0x0/0x120 [ 389.275273] [<c013c85a>] ? update_curr+0x18a/0x230 [ 389.275318] [<c013cdc5>] ? put_prev_task_fair+0x155/0x160 [ 389.275366] [<c01618b5>] ? sched_clock_cpu+0xd5/0x110 [ 389.275413] [<c04e7525>] ? _spin_lock_irq+0x45/0x50 [ 389.275458] [<c04e424e>] ? schedule+0x20e/0xb10 The problem is that the box has no lapic enabled: [ 0.042445] Local APIC not detected. Using dummy APIC emulation. The below seems like the best fix. We disabled all lapic bits, except the self-IPI-resend logic. Reported-by: Chris Malley <mail@chrismalley.co.uk> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <7863dc4c0909221409v7893bfd3o4b590d5951a233ba@mail.gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-22x86: ptrace: set TS_COMPAT when 32-bit ptrace sets orig_eax>=0Roland McGrath
The 32-bit ptrace syscall on a 64-bit kernel (32-bit debugger on 32-bit task) behaves differently than a native 32-bit kernel. When setting a register state of orig_eax>=0 and eax=-ERESTART* when the debugged task is NOT on its way out of a 32-bit syscall, the task will fail to do the syscall restart logic that it should do. Test case available at http://sources.redhat.com/cgi-bin/cvsweb.cgi/~checkout~/tests/ptrace-tests/tests/erestartsys-trap.c?cvsroot=systemtap This happens because the 32-bit ptrace syscall sets eax=0xffffffff when it sets orig_eax>=0. The resuming task will not sign-extend this for the -ERESTART* check because TS_COMPAT is not set. (So the task thinks it is restarting after a 64-bit syscall, not a 32-bit one.) The fix is to have 32-bit ptrace calls set TS_COMPAT when setting orig_eax>=0. This ensures that the 32-bit syscall restart logic will apply when the child resumes. Signed-off-by: Roland McGrath <roland@redhat.com>
2009-09-22x86: ptrace: do not sign-extend orig_ax on writeRoland McGrath
The high 32 bits of orig_ax will be ignored when it matters, so don't fiddle them when setting it. Signed-off-by: Roland McGrath <roland@redhat.com>
2009-09-22x86: ptrace: sysret path should reach syscall_trace_leaveRoland McGrath
If TIF_SYSCALL_TRACE or TIF_SINGLESTEP is set while inside a syscall, the path back to user mode should get to syscall_trace_leave. This does happen in most circumstances. The exception to this is on the 64-bit syscall fastpath, when no such flag was set on syscall entry and nothing else has punted it off the fastpath for exit. That one exit fastpath fails to check for _TIF_WORK_SYSCALL_EXIT flags. This makes the behavior inconsistent with what 32-bit tasks see and what the native 32-bit kernel always does, and what 64-bit tasks see in all cases where the iret path is taken anyhow. Perhaps the only example that is affected is a ptrace stop inside do_fork (for PTRACE_O_TRACE{CLONE,FORK,VFORK,VFORKDONE}). Other syscalls with internal ptrace stop points (execve) already take the iret exit path for unrelated reasons. Test cases for both PTRACE_SYSCALL and PTRACE_SINGLESTEP variants are at: http://sources.redhat.com/cgi-bin/cvsweb.cgi/~checkout~/tests/ptrace-tests/tests/syscall-from-clone.c?cvsroot=systemtap http://sources.redhat.com/cgi-bin/cvsweb.cgi/~checkout~/tests/ptrace-tests/tests/step-from-clone.c?cvsroot=systemtap There was no special benefit to the sysret path's special path to call do_notify_resume, because it always takes the iret exit path at the end. So this change just makes the sysret exit path join the iret exit path for all the signals and ptrace cases. The fastpath still applies to the plain syscall-audit and resched cases. Signed-off-by: Roland McGrath <roland@redhat.com> CC: Oleg Nesterov <oleg@redhat.com>
2009-09-22x86: syscall_get_nr returns intRoland McGrath
Make syscall_get_nr() return int, so we always sign-extend the low 32 bits of orig_ax in checks. Signed-off-by: Roland McGrath <roland@redhat.com>
