path: root/arch/x86/xen/smp.c
2008-07-23Merge branch 'cpus4096-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits) NR_CPUS: Replace NR_CPUS in speedstep-centrino.c cpumask: Provide a generic set of CPUMASK_ALLOC macros, FIXUP NR_CPUS: Replace NR_CPUS in cpufreq userspace routines NR_CPUS: Replace per_cpu(..., smp_processor_id()) with __get_cpu_var NR_CPUS: Replace NR_CPUS in arch/x86/kernel/genapic_flat_64.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/genx2apic_uv_x.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/cpu/proc.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/cpu/mcheck/mce_64.c cpumask: Optimize cpumask_of_cpu in lib/smp_processor_id.c, fix cpumask: Use optimized CPUMASK_ALLOC macros in the centrino_target cpumask: Provide a generic set of CPUMASK_ALLOC macros cpumask: Optimize cpumask_of_cpu in lib/smp_processor_id.c cpumask: Optimize cpumask_of_cpu in kernel/time/tick-common.c cpumask: Optimize cpumask_of_cpu in drivers/misc/sgi-xp/xpc_main.c cpumask: Optimize cpumask_of_cpu in arch/x86/kernel/ldt.c cpumask: Optimize cpumask_of_cpu in arch/x86/kernel/io_apic_64.c cpumask: Replace cpumask_of_cpu with cpumask_of_cpu_ptr Revert "cpumask: introduce new APIs" cpumask: make for_each_cpu_mask a bit smaller net: Pass reference to cpumask variable in net/sunrpc/svc.c ... Fix up trivial conflicts in drivers/cpufreq/cpufreq.c manually
2008-07-16xen: implement Xen-specific spinlocksJeremy Fitzhardinge
The standard ticket spinlocks are very expensive in a virtual environment, because their performance depends on Xen's scheduler giving vcpus time in the order that they're supposed to take the spinlock. This implements a Xen-specific spinlock, which should be much more efficient. The fast-path is essentially the old Linux-x86 locks, using a single lock byte. The locker decrements the byte; if the result is 0, then they have the lock. If the lock is negative, then locker must spin until the lock is positive again. When there's contention, the locker spin for 2^16[*] iterations waiting to get the lock. If it fails to get the lock in that time, it adds itself to the contention count in the lock and blocks on a per-cpu event channel. When unlocking the spinlock, the locker looks to see if there's anyone blocked waiting for the lock by checking for a non-zero waiter count. If there's a waiter, it traverses the per-cpu "lock_spinners" variable, which contains which lock each CPU is waiting on. It picks one CPU waiting on the lock and sends it an event to wake it up. This allows efficient fast-path spinlock operation, while allowing spinning vcpus to give up their processor time while waiting for a contended lock. [*] 2^16 iterations is threshold at which 98% locks have been taken according to Thomas Friebel's Xen Summit talk "Preventing Guests from Spinning Around". Therefore, we'd expect the lock and unlock slow paths will only be entered 2% of the time. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <clameter@linux-foundation.org> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: Virtualization <virtualization@lists.linux-foundation.org> Cc: Xen devel <xen-devel@lists.xensource.com> Cc: Thomas Friebel <thomas.friebel@amd.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-16xen: use lock-byte spinlock implementationJeremy Fitzhardinge
Switch to using the lock-byte spinlock implementation, to avoid the worst of the performance hit from ticket locks. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <clameter@linux-foundation.org> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: Virtualization <virtualization@lists.linux-foundation.org> Cc: Xen devel <xen-devel@lists.xensource.com> Cc: Thomas Friebel <thomas.friebel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-16xen64: set up syscall and sysenter entrypoints for 64-bitJeremy Fitzhardinge
We set up entrypoints for syscall and sysenter. sysenter is only used for 32-bit compat processes, whereas syscall can be used in by both 32 and 64-bit processes. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-16xen: set num_processorsJeremy Fitzhardinge
Someone's got to do it. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-16xen64: smp.c compile hackingJeremy Fitzhardinge
A number of random changes to make xen/smp.c compile in 64-bit mode. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>a Cc: Stephen Tweedie <sct@redhat.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-16xen: move smp setup into smp.cJeremy Fitzhardinge
Move all the smp_ops setup into smp.c, allowing a lot of things to become static. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-16Merge branch 'linus' into cpus4096Ingo Molnar
Conflicts: arch/x86/xen/smp.c kernel/sched_rt.c net/iucv/iucv.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-15Merge branch 'generic-ipi' into generic-ipi-for-linusIngo Molnar
Conflicts: arch/powerpc/Kconfig arch/s390/kernel/time.c arch/x86/kernel/apic_32.c arch/x86/kernel/cpu/perfctr-watchdog.c arch/x86/kernel/i8259_64.c arch/x86/kernel/ldt.c arch/x86/kernel/nmi_64.c arch/x86/kernel/smpboot.c arch/x86/xen/smp.c include/asm-x86/hw_irq_32.h include/asm-x86/hw_irq_64.h include/asm-x86/mach-default/irq_vectors.h include/asm-x86/mach-voyager/irq_vectors.h include/asm-x86/smp.h kernel/Makefile Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-26smp_call_function: get rid of the unused nonatomic/retry argumentJens Axboe
It's never used and the comments refer to nonatomic and retry interchangably. So get rid of it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-26x86: convert to generic helpers for IPI function callsJens Axboe
This converts x86, x86-64, and xen to use the new helpers for smp_call_function() and friends, and adds support for smp_call_function_single(). Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-27xen: implement save/restoreJeremy Fitzhardinge
This patch implements Xen save/restore and migration. Saving is triggered via xenbus, which is polled in drivers/xen/manage.c. When a suspend request comes in, the kernel prepares itself for saving by: 1 - Freeze all processes. This is primarily to prevent any partially-completed pagetable updates from confusing the suspend process. If CONFIG_PREEMPT isn't defined, then this isn't necessary. 2 - Suspend xenbus and other devices 3 - Stop_machine, to make sure all the other vcpus are quiescent. The Xen tools require the domain to run its save off vcpu0. 4 - Within the stop_machine state, it pins any unpinned pgds (under construction or destruction), performs canonicalizes various other pieces of state (mostly converting mfns to pfns), and finally 5 - Suspend the domain Restore reverses the steps used to save the domain, ending when all the frozen processes are thawed. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-27xen: count resched interrupts properlyJeremy Fitzhardinge
Make sure resched interrupts appear in /proc/interrupts in the proper place. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23x86: use performance variant for_each_cpu_mask_nrMike Travis
Change references from for_each_cpu_mask to for_each_cpu_mask_nr where appropriate Reviewed-by: Paul Jackson <pj@sgi.com> Reviewed-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> commit 2d474871e2fb092eb46a0930aba5442e10eb96cc Author: Mike Travis <travis@sgi.com> Date: Mon May 12 21:21:13 2008 +0200
2008-04-26x86: use cpumask function for present, possible, and online cpusAkinobu Mita
cpu_online(), cpu_present(), for_each_possible_cpu(), num_possible_cpus() Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-24xen: implement a debug-interrupt handlerJeremy Fitzhardinge
Xen supports the notion of a debug interrupt which can be triggered from the console. For now this is implemented to show pending events, masks and each CPU's pending event set. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24xen: support sysenter/sysexit if hypervisor doesJeremy Fitzhardinge
64-bit Xen supports sysenter for 32-bit guests, so support its use. (sysenter is faster than int $0x80 in 32-on-64.) sysexit is still not supported, so we fake it up using iret. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17x86: change naming of cpu_initialized_mask for xenGlauber Costa
xen does not use the global cpu_initialized mask, but rather, a specific one. So we change its name so it won't conflict with the upcoming movement of cpu_initialized_mask from smp_64.h to smp_32.h. Signed-off-by: Glauber Costa <gcosta@redhat.com> CC: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: use generic register name in the thread and tss structuresH. Peter Anvin
This changes size-specific register names (eip/rip, esp/rsp, etc.) to generic names in the thread and tss structures. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: prevent dereferencing non-allocated per_cpu variablesMike Travis
'for_each_possible_cpu(i)' when there's a _remote possibility_ of dereferencing a non-allocated per_cpu variable involved. All files except mm/vmstat.c are x86 arch. Thanks to pageexec@freemail.hu for pointing this out. Signed-off-by: Mike Travis <travis@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: <pageexec@freemail.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17Merge ssh://master.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-x86Linus Torvalds
* ssh://master.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-x86: (114 commits) x86: delete vsyscall files during make clean kbuild: fix typo SRCARCH in find_sources x86: fix kernel rebuild due to vsyscall fallout .gitignore update for x86 arch x86: unify include/asm/debugreg_32/64.h x86: unify include/asm/unwind_32/64.h x86: unify include/asm/types_32/64.h x86: unify include/asm/tlb_32/64.h x86: unify include/asm/siginfo_32/64.h x86: unify include/asm/bug_32/64.h x86: unify include/asm/mman_32/64.h x86: unify include/asm/agp_32/64.h x86: unify include/asm/kdebug_32/64.h x86: unify include/asm/ioctls_32/64.h x86: unify include/asm/floppy_32/64.h x86: apply missing DMA/OOM prevention to floppy_32.h x86: unify include/asm/cache_32/64.h x86: unify include/asm/cache_32/64.h x86: unify include/asm/dmi_32/64.h x86: unify include/asm/delay_32/64.h ...
2007-10-17x86: expand /proc/interrupts to include missing vectors, v2Joe Korty
Add missing IRQs and IRQ descriptions to /proc/interrupts. /proc/interrupts is most useful when it displays every IRQ vector in use by the system, not just those somebody thought would be interesting. This patch inserts the following vector displays to the i386 and x86_64 platforms, as appropriate: rescheduling interrupts TLB flush interrupts function call interrupts thermal event interrupts threshold interrupts spurious interrupts A threshold interrupt occurs when ECC memory correction is occuring at too high a frequency. Thresholds are used by the ECC hardware as occasional ECC failures are part of normal operation, but long sequences of ECC failures usually indicate a memory chip that is about to fail. Thermal event interrupts occur when a temperature threshold has been exceeded for some CPU chip. IIRC, a thermal interrupt is also generated when the temperature drops back to a normal level. A spurious interrupt is an interrupt that was raised then lowered by the device before it could be fully processed by the APIC. Hence the apic sees the interrupt but does not know what device it came from. For this case the APIC hardware will assume a vector of 0xff. Rescheduling, call, and TLB flush interrupts are sent from one CPU to another per the needs of the OS. Typically, their statistics would be used to discover if an interrupt flood of the given type has been occuring. AK: merged v2 and v4 which had some more tweaks AK: replace Local interrupts with Local timer interrupts AK: Fixed description of interrupt types. [ tglx: arch/x86 adaptation ] [ mingo: small cleanup ] Signed-off-by: Joe Korty <joe.korty@ccur.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Tim Hockin <thockin@hockin.org> Cc: Andi Kleen <ak@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17Merge branch 'xen-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'xen-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: xfs: eagerly remove vmap mappings to avoid upsetting Xen xen: add some debug output for failed multicalls xen: fix incorrect vcpu_register_vcpu_info hypercall argument xen: ask the hypervisor how much space it needs reserved xen: lock pte pages while pinning/unpinning xen: deal with stale cr3 values when unpinning pagetables xen: add batch completion callbacks xen: yield to IPI target if necessary Clean up duplicate includes in arch/i386/xen/ remove dead code in pgtable_cache_init paravirt: clean up lazy mode handling paravirt: refactor struct paravirt_ops into smaller pv_*_ops
2007-10-16xen: yield to IPI target if necessaryJeremy Fitzhardinge
When sending a call-function IPI to a vcpu, yield if the vcpu isn't running. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
2007-10-16Convert cpu_sibling_map to be a per cpu variableMike Travis
Convert cpu_sibling_map from a static array sized by NR_CPUS to a per_cpu variable. This saves sizeof(cpumask_t) * NR unused cpus. Access is mostly from startup and CPU HOTPLUG functions. Signed-off-by: Mike Travis <travis@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16x86: Convert cpu_core_map to be a per cpu variableMike Travis
This is from an earlier message from 'Christoph Lameter': cpu_core_map is currently an array defined using NR_CPUS. This means that we overallocate since we will rarely really use maximum configured cpu. If we put the cpu_core_map into the per cpu area then it will be allocated for each processor as it comes online. This means that the core map cannot be accessed until the per cpu area has been allocated. Xen does a weird thing here looping over all processors and zeroing the masks that are not yet allocated and that will be zeroed when they are allocated. I commented the code out. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11i386: move xenThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
