When mapping a foreign page with xenbus_map_ring_valloc() with the
GNTTABOP_map_grant_ref hypercall, set the GNTMAP_contains_pte flag and
pass a pointer to the PTE (in init_mm).
After the page is mapped, the usual fault mechanism can be used to
update additional MMs. This allows the vmalloc_sync_all() to be
removed from alloc_vm_area().
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
[v1: Squashed fix by Michal for no-mmu case]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Replace calls to the Xen-specific xen_alloc_vm_area() and
xen_free_vm_area() functions with the generic equivalent
(alloc_vm_area() and free_vm_area()).
On x86, these were identical already.
split out x86 specific part from grant-table.c and
allow ia64/xen specific initialization.
ia64/xen grant table is based on pseudo physical address
(guest physical address) unlike x86/xen. On ia64 init_mm
doesn't map identity straight mapped area.
ia64/xen specific grant table initialization is necessary.
Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp>
