path: root/arch/x86/pci/direct.c
2008-12-29x86, pci: move arch/x86/pci/pci.h to arch/x86/include/asm/pci_x86.hJaswinder Singh Rajput
Impact: cleanup Now that arch/x86/pci/pci.h is used in a number of other places as well, move the lowlevel x86 pci definitions into the architecture include files. (not to be confused with the existing arch/x86/include/asm/pci.h file, which provides public details about x86 PCI) Tested on: X86_32_UP, X86_32_SMP and X86_64_SMP Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-11x86: attempt reboot via port CF9 if we have standard PCI portsH. Peter Anvin
Impact: Changes reboot behavior. If port CF9 seems to be safe to touch, attempt it before trying the keyboard controller. Port CF9 is not available on all chipsets (a significant but decreasing number of modern chipsets don't implement it), but port CF9 itself should in general be safe to poke (no ill effects if unimplemented) on any system which has PCI Configuration Method #1 or #2, as it falls inside the PCI configuration port range in both cases. No chipset without PCI is known to have port CF9, either, although an explicit "pci=bios" would mean we miss this and therefore don't use port CF9. An explicit "reboot=pci" can be used to force the use of port CF9. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-07-08x86: Move PCI IO ECS code to x86/pciRobert Richter
"Form follows function". Code is now where it belongs to. Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-02x86: add PCI extended config space access for AMD BarcelonaRobert Richter
This patch implements PCI extended configuration space access for AMD's Barcelona CPUs. It extends the method using CF8/CFC IO addresses. An x86 capability bit has been introduced that is set for CPUs supporting PCI extended config space accesses. Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86 pci: remove checking type for mmconfig probeYinghai Lu
doesn't need to check if it is type1 or type2, we can use raw_pci_ops directly. also make pci_direct_conf1 static again. anyway is there system with type 2 and mmconf support? Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-10Change pci_raw_ops to pci_raw_read/writeMatthew Wilcox
We want to allow different implementations of pci_raw_ops for standard and extended config space on x86. Rather than clutter generic code with knowledge of this, we make pci_raw_ops private to x86 and use it to implement the new raw interface -- raw_pci_read() and raw_pci_write(). Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11i386: move pciThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
