commit 44009105081b51417f311f4c3be0061870b6b8ed upstream.
The "event" variable is a u16 so the shift will always wrap to zero
making the line a no-op.
Signed-off-by: Robert Richter <robert.richter@amd.com>
Factor out IA32 (compatibility instruction set) from 32-bit address
space in the thread_info flags; this is a precondition patch for x32
support.
Originally-by: H. J. Lu <hjl.tools@gmail.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Link: http://lkml.kernel.org/n/tip-4pr1xnnksprt7t0h3w5fw4rv@git.kernel.org
Merge reason: Resolve conflicts with Don's NMI rework:
commit 9c48f1c629ecfa114850c03f875c6691003214de
Author: Don Zickus <dzickus@redhat.com>
Date: Fri Sep 30 15:06:21 2011 -0400
x86, nmi: Wire up NMI handlers to new routines
arch/x86/oprofile/nmi_timer_int.c
The legacy x86 nmi watchdog code was removed with the implementation
of the perf based nmi watchdog. This broke Oprofile's nmi timer
mode. To run nmi timer mode we relied on a continuous ticking nmi
source which the nmi watchdog provided. The nmi tick was no longer
available and current watchdog can not be used anymore since it runs
with very long periods in the range of seconds. This patch
reimplements the nmi timer mode using a perf counter nmi source.
V2:
* removing pr_info()
* fix undefined reference to `__udivdi3' for 32 bit build
* fix section mismatch of .cpuinit.data:nmi_timer_cpu_nb
* removed nmi timer setup in arch/x86
* implemented function stubs for op_nmi_init/exit()
* made code more readable in oprofile_init()
V3:
* fix architectural initialization in oprofile_init()
* fix CONFIG_OPROFILE_NMI_TIMER dependencies
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
We need this to better test x86 NMI timer mode. Otherwise it is very
hard to setup systems with NMI timer enabled, but we have this e.g. in
virtual machine environments.
If oprofile uses the nmi timer interrupt there is a crash while
unloading the module. The bug can be triggered with oprofile build as
module and kernel parameter nolapic set. This patch fixes this.
oprofile: using NMI timer interrupt.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
PGD 42dbca067 PUD 41da6a067 PMD 0
Oops: 0002 [#1] PREEMPT SMP
CPU 5
Modules linked in: oprofile(-) [last unloaded: oprofile]
Pid: 2518, comm: modprobe Not tainted 3.1.0-rc7-00019-gb2fb49d #19 Advanced Micro Device Anaheim/Anaheim
RIP: 0010:[<ffffffff8123c226>] [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
RSP: 0018:ffff88041ef71e98 EFLAGS: 00010296
RAX: 0000000000000000 RBX: ffffffffa0017100 RCX: dead000000200200
RDX: 0000000000000000 RSI: dead000000100100 RDI: ffffffff8178c620
RBP: ffff88041ef71ea8 R08: 0000000000000001 R09: 0000000000000082
R10: 0000000000000000 R11: ffff88041ef71de8 R12: 0000000000000080
R13: fffffffffffffff5 R14: 0000000000000001 R15: 0000000000610210
FS: 00007fc902f20700(0000) GS:ffff88042fd40000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000008 CR3: 000000041cdb6000 CR4: 00000000000006e0
Process modprobe (pid: 2518, threadinfo ffff88041ef70000, task ffff88041d348040)
Stack:
ffff88041ef71eb8 ffffffffa0017790 ffff88041ef71eb8 ffffffffa0013532
ffff88041ef71ec8 ffffffffa00132d6 ffff88041ef71ed8 ffffffffa00159b2
ffff88041ef71f78 ffffffff81073115 656c69666f72706f 0000000000610200
Call Trace:
[<ffffffffa0013532>] op_nmi_exit+0x15/0x17 [oprofile]
[<ffffffffa00132d6>] oprofile_arch_exit+0xe/0x10 [oprofile]
[<ffffffffa00159b2>] oprofile_exit+0x1e/0x20 [oprofile]
[<ffffffff81073115>] sys_delete_module+0x1c3/0x22f
[<ffffffff811bf09e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff8148070b>] system_call_fastpath+0x16/0x1b
Code: 20 c6 78 81 e8 c5 cc 23 00 48 8b 13 48 8b 43 08 48 be 00 01 10 00 00 00 ad de 48 b9 00 02 20 00 00 00 ad de 48 c7 c7 20 c6 78 81
89 42 08 48 89 10 48 89 33 48 89 4b 08 e8 a6 c0 23 00 5a 5b
RIP [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
RSP <ffff88041ef71e98>
---[ end trace 43a541a52956b7b0 ]---
CC: stable@kernel.org # 2.6.37+
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (121 commits)
perf symbols: Increase symbol KSYM_NAME_LEN size
perf hists browser: Refuse 'a' hotkey on non symbolic views
perf ui browser: Use libslang to read keys
perf tools: Fix tracing info recording
perf hists browser: Elide DSO column when it is set to just one DSO, ditto for threads
perf hists: Don't consider filtered entries when calculating column widths
perf hists: Don't decay total_period for filtered entries
perf hists browser: Honour symbol_conf.show_{nr_samples,total_period}
perf hists browser: Do not exit on tab key with single event
perf annotate browser: Don't change selection line when returning from callq
perf tools: handle endianness of feature bitmap
perf tools: Add prelink suggestion to dso update message
perf script: Fix unknown feature comment
perf hists browser: Apply the dso and thread filters when merging new batches
perf hists: Move the dso and thread filters from hist_browser
perf ui browser: Honour the xterm colors
perf top tui: Give color hints just on the percentage, like on --stdio
perf ui browser: Make the colors configurable and change the defaults
perf tui: Remove unneeded call to newtCls on startup
perf hists: Don't format the percentage on hist_entry__snprintf
Fix up conflicts in arch/x86/kernel/kprobes.c manually.
Ingo's tree did the insane "add volatile to const array", which just
doesn't make sense ("volatile const"?). But we could remove the const
*and* make the array volatile to make doubly sure that gcc doesn't
optimize it away..
Also fix up kernel/trace/ring_buffer.c non-data-conflicts manually: the
reader_lock has been turned into a raw lock by the core locking merge,
and there was a new user of it introduced in this perf core merge. Make
sure that new use also uses the raw accessor functions.
This patch implements IBS feature detection and initialzation. The
code is shared between perf and oprofile. If IBS is available on the
system for perf, a pmu is setup.
Link: http://lkml.kernel.org/r/1316597423-25723-3-git-send-email-robert.richter@amd.com
Moving IBS macros from oprofile to <asm/perf_event.h> to make it
available to perf. No additional changes.
Link: http://lkml.kernel.org/r/1316597423-25723-2-git-send-email-robert.richter@amd.com
Just convert all the files that have an nmi handler to the new routines.
Most of it is straight forward conversion. A couple of places needed some
tweaking like kgdb which separates the debug notifier from the nmi handler
and mce removes a call to notify_die.
[Thanks to Ying for finding out the history behind that mce call
https://lkml.org/lkml/2010/5/27/114
And Boris responding that he would like to remove that call because of it
https://lkml.org/lkml/2011/9/21/163]
The things that get converted are the registeration/unregistration routines
and the nmi handler itself has its args changed along with code removal
to check which list it is on (most are on one NMI list except for kgdb
which has both an NMI routine and an NMI Unknown routine).
Signed-off-by: Don Zickus <dzickus@redhat.com>
Acked-by: Corey Minyard <minyard@acm.org>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Corey Minyard <minyard@acm.org>
Cc: Jack Steiner <steiner@sgi.com>
Link: http://lkml.kernel.org/r/1317409584-23662-4-git-send-email-dzickus@redhat.com
The oprofilefs_lock can be taken in atomic context (in profiling
interrupts) and therefore cannot cannot be preempted on -rt -
annotate it.
In mainline this change documents the low level nature of
the lock - otherwise there's no functional difference. Lockdep
and Sparse checking will work as usual.
Following fixes for:
1d12d35 oprofile, x86: Convert memory allocation to static array
Fix potential buffer overflow.
Fix the following warning:
arch/x86/oprofile/op_model_ppro.c: In function ‘ppro_check_ctrs’:
arch/x86/oprofile/op_model_ppro.c:143: warning: label ‘out’ defined but not used
Cc: Maarten Lankhorst <m.b.lankhorst@gmail.com>
On -rt, allocators don't work from atomic context any more,
and the maximum size of the array is known at compile time.
Call trace on a -rt kernel:
oprofile: using NMI interrupt.
BUG: sleeping function called from invalid context at kernel/rtmutex.c:645
in_atomic(): 1, irqs_disabled(): 1, pid: 0, name: kworker/0:1
Pid: 0, comm: kworker/0:1 Tainted: G C 3.0.0-rt3-patser+ #39
Call Trace:
<IRQ> [<ffffffff8103fc0a>] __might_sleep+0xca/0xf0
[<ffffffff8160d424>] rt_spin_lock+0x24/0x40
[<ffffffff811476c7>] __kmalloc+0xc7/0x370
[<ffffffffa0275c85>] ? ppro_setup_ctrs+0x215/0x260 [oprofile]
[<ffffffffa0273de0>] ? oprofile_cpu_notifier+0x60/0x60 [oprofile]
[<ffffffffa0275c85>] ppro_setup_ctrs+0x215/0x260 [oprofile]
[<ffffffffa0273ea4>] nmi_cpu_setup+0xc4/0x110 [oprofile]
[<ffffffff81094455>] generic_smp_call_function_interrupt+0x95/0x190
[<ffffffff8101df77>] smp_call_function_interrupt+0x27/0x40
[<ffffffff81615093>] call_function_interrupt+0x13/0x20
<EOI> [<ffffffff8131d0c4>] ? plist_check_head+0x54/0xc0
[<ffffffff81371fe8>] ? intel_idle+0xc8/0x120
[<ffffffff81371fc7>] ? intel_idle+0xa7/0x120
[<ffffffff814a57b0>] cpuidle_idle_call+0xb0/0x230
[<ffffffff810011db>] cpu_idle+0x8b/0xe0
[<ffffffff815fc82f>] start_secondary+0x1d3/0x1d8
Signed-off-by: Maarten Lankhorst <m.b.lankhorst@gmail.com>
copy_from_user_nmi() is used in oprofile and perf. Moving it to other
library functions like copy_from_user(). As this is x86 code for 32
and 64 bits, create a new file usercopy.c for unified code.
Link: http://lkml.kernel.org/r/20110607172413.GJ20052@erda.amd.com
Current oprofile's x86 callgraph support may trigger page faults
throwing the BUG_ON(in_nmi()) message below. This patch fixes this by
using the same nmi-safe copy-from-user code as in perf.
kernel BUG at .../arch/x86/kernel/traps.c:436!
invalid opcode: 0000 [#1] SMP
last sysfs file: /sys/devices/pci0000:00/0000:00:0a.0/0000:07:00.0/0000:08:04.0/net/eth0/broadcast
CPU 5
Modules linked in:
Pid: 8611, comm: opcontrol Not tainted 2.6.39-00007-gfe47ae7 #1 Advanced Micro Device Anaheim/Anaheim
RIP: 0010:[<ffffffff813e8e35>] [<ffffffff813e8e35>] do_nmi+0x22/0x1ee
RSP: 0000:ffff88042fd47f28 EFLAGS: 00010002
RAX: ffff88042c0a7fd8 RBX: 0000000000000001 RCX: 00000000c0000101
RDX: 00000000ffff8804 RSI: ffffffffffffffff RDI: ffff88042fd47f58
RBP: ffff88042fd47f48 R08: 0000000000000004 R09: 0000000000001484
R10: 0000000000000001 R11: 0000000000000000 R12: ffff88042fd47f58
R13: 0000000000000000 R14: ffff88042fd47d98 R15: 0000000000000020
FS: 00007fca25e56700(0000) GS:ffff88042fd40000(0000) knlGS:0000000000000000
CR2: 0000000000000074 CR3: 000000042d28b000 CR4: 00000000000006e0
Process opcontrol (pid: 8611, threadinfo ffff88042c0a6000, task ffff88042c532310)
Stack:
0000000000000000 0000000000000001 ffff88042c0a7fd8 0000000000000000
ffff88042fd47de8 ffffffff813e897a 0000000000000020 ffff88042fd47d98
0000000000000000 ffff88042c0a7fd8 ffff88042fd47de8 0000000000000074
Call Trace:
<NMI>
[<ffffffff813e897a>] nmi+0x1a/0x20
[<ffffffff813f08ab>] ? bad_to_user+0x25/0x771
<<EOE>>
Code: ff 59 5b 41 5c 41 5d c9 c3 55 65 48 8b 04 25 88 b5 00 00 48 89 e5 41 55 41 54 49 89 fc 53 48 83 ec 08 f6 80 47 e0 ff ff 04 74 04 <0f> 0b eb fe 81 80 44 e0 ff ff 00 00 01 04 65 ff 04 25 c4 0f 01
RIP [<ffffffff813e8e35>] do_nmi+0x22/0x1ee
RSP <ffff88042fd47f28>
---[ end trace ed6752185092104b ]---
Kernel panic - not syncing: Fatal exception in interrupt
Pid: 8611, comm: opcontrol Tainted: G D 2.6.39-00007-gfe47ae7 #1
Call Trace:
<NMI> [<ffffffff813e5e0a>] panic+0x8c/0x188
[<ffffffff813e915c>] oops_end+0x81/0x8e
[<ffffffff8100403d>] die+0x55/0x5e
[<ffffffff813e8c45>] do_trap+0x11c/0x12b
[<ffffffff810023c8>] do_invalid_op+0x91/0x9a
[<ffffffff813e8e35>] ? do_nmi+0x22/0x1ee
[<ffffffff8131e6fa>] ? oprofile_add_sample+0x83/0x95
[<ffffffff81321670>] ? op_amd_check_ctrs+0x4f/0x2cf
[<ffffffff813ee4d5>] invalid_op+0x15/0x20
[<ffffffff813e8e7a>] ? do_nmi+0x67/0x1ee
<<EOE>>
Cc: John Lumby <johnlumby@hotmail.com>
Cc: Maynard Johnson <maynardj@us.ibm.com>
Cc: <stable@kernel.org> # .37+
In some rare cases, nmis are generated immediately after the nmi
handler of the cpu was started. This causes the counter not to be
enabled. Before enabling the nmi handlers we need to set variable
ctr_running first and make sure its value is written to memory.
Also, the patch makes all existing barriers a memory barrier instead
of a compiler barrier only.
Reported-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Cc: <stable@kernel.org> # .35+
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/urgent
Adding a comment in the code as IBS LVT setup is not obvious at all ...
IBS initialization is a mix of per-core register access and per-node
pci device setup. Register access should be pinned to the cpu, but pci
setup must run with preemption enabled.
This patch better separates the code into non-/preemptible sections
and fixes sleeping with preemption disabled. See bug message below.
Fixes also freeing the eilvt entry by introducing put_eilvt().
BUG: sleeping function called from invalid context at mm/slub.c:824
in_atomic(): 1, irqs_disabled(): 0, pid: 32357, name: modprobe
INFO: lockdep is turned off.
Pid: 32357, comm: modprobe Not tainted 2.6.39-rc7+ #14
Call Trace:
[<ffffffff8104bdc8>] __might_sleep+0x112/0x117
[<ffffffff81129693>] kmem_cache_alloc_trace+0x4b/0xe7
[<ffffffff81278f14>] kzalloc.constprop.0+0x29/0x2b
[<ffffffff81278f4c>] pci_get_subsys+0x36/0x78
[<ffffffff81022689>] ? setup_APIC_eilvt+0xfb/0x139
[<ffffffff81278fa4>] pci_get_device+0x16/0x18
[<ffffffffa06c8b5d>] op_amd_init+0xd3/0x211 [oprofile]
[<ffffffffa064d000>] ? 0xffffffffa064cfff
[<ffffffffa064d298>] op_nmi_init+0x21e/0x26a [oprofile]
[<ffffffffa064d062>] oprofile_arch_init+0xe/0x26 [oprofile]
[<ffffffffa064d010>] oprofile_init+0x10/0x42 [oprofile]
[<ffffffff81002099>] do_one_initcall+0x7f/0x13a
[<ffffffff81096524>] sys_init_module+0x132/0x281
[<ffffffff814cc682>] system_call_fastpath+0x16/0x1b
Reported-by: Dave Jones <davej@redhat.com>
Cc: <stable@kernel.org> [2.6.37.x]
Both warning and warning_symbol are nowhere used.
Let's get rid of them.
Signed-off-by: Richard Weinberger <richard@nod.at>
Cc: Soeren Sandmann Pedersen <ssp@redhat.com>
Cc: Namhyung Kim <namhyung@gmail.com>
Cc: x86 <x86@kernel.org>
Link: http://lkml.kernel.org/r/1305205872-10321-2-git-send-email-richard@nod.at
For some performance events it's useful to set the EDGE and INV
bits and the CMASK mask in the counter control register. The list
of predefined events Intel releases for each CPU has some events which
require these settings to get more "natural" to use higher level events.
oprofile currently doesn't allow this.
This patch adds new extra configuration fields for them, so that
they can be specified in oprofilefs.
An updated oprofile daemon can then make use of this to set them.
v2: Write back masked extra value to variable.
Some subsystems in the x86 tree need to carry out suspend/resume and
shutdown operations with one CPU on-line and interrupts disabled and
they define sysdev classes and sysdevs or sysdev drivers for this
purpose. This leads to unnecessarily complicated code and excessive
memory usage, so switch them to using struct syscore_ops objects for
this purpose instead.
Generally, there are three categories of subsystems that use
sysdevs for implementing PM operations: (1) subsystems whose
suspend/resume callbacks ignore their arguments entirely (the
majority), (2) subsystems whose suspend/resume callbacks use their
struct sys_device argument, but don't really need to do that,
because they can be implemented differently in an arguably simpler
way (io_apic.c), and (3) subsystems whose suspend/resume callbacks
use their struct sys_device argument, but the value of that argument
is always the same and could be ignored (microcode_core.c). In all
of these cases the subsystems in question may be readily converted to
using struct syscore_ops objects for power management and shutdown.
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Flush TLB if PGD entry is changed in i386 PAE mode
x86, dumpstack: Correct stack dump info when frame pointer is available
x86: Clean up csum-copy_64.S a bit
x86: Fix common misspellings
x86: Fix misspelling and align params
x86: Use PentiumPro-optimized partial_csum() on VIA C7
Current stack dump code scans entire stack and check each entry
contains a pointer to kernel code. If CONFIG_FRAME_POINTER=y it
could mark whether the pointer is valid or not based on value of
the frame pointer. Invalid entries could be preceded by '?' sign.
However this was not going to happen because scan start point
was always higher than the frame pointer so that they could not
meet.
Commit 9c0729dc8062 ("x86: Eliminate bp argument from the stack
tracing routines") delayed bp acquisition point, so the bp was
read in lower frame, thus all of the entries were marked
invalid.
This patch fixes this by reverting above commit while retaining
stack_frame() helper as suggested by Frederic Weisbecker.
End result looks like below:
before:
[ 3.508329] Call Trace:
[ 3.508551] [<ffffffff814f35c9>] ? panic+0x91/0x199
[ 3.508662] [<ffffffff814f3739>] ? printk+0x68/0x6a
[ 3.508770] [<ffffffff81a981b2>] ? mount_block_root+0x257/0x26e
[ 3.508876] [<ffffffff81a9821f>] ? mount_root+0x56/0x5a
[ 3.508975] [<ffffffff81a98393>] ? prepare_namespace+0x170/0x1a9
[ 3.509216] [<ffffffff81a9772b>] ? kernel_init+0x1d2/0x1e2
[ 3.509335] [<ffffffff81003894>] ? kernel_thread_helper+0x4/0x10
[ 3.509442] [<ffffffff814f6880>] ? restore_args+0x0/0x30
[ 3.509542] [<ffffffff81a97559>] ? kernel_init+0x0/0x1e2
[ 3.509641] [<ffffffff81003890>] ? kernel_thread_helper+0x0/0x10
after:
[ 3.522991] Call Trace:
[ 3.523351] [<ffffffff814f35b9>] panic+0x91/0x199
[ 3.523468] [<ffffffff814f3729>] ? printk+0x68/0x6a
[ 3.523576] [<ffffffff81a981b2>] mount_block_root+0x257/0x26e
[ 3.523681] [<ffffffff81a9821f>] mount_root+0x56/0x5a
[ 3.523780] [<ffffffff81a98393>] prepare_namespace+0x170/0x1a9
[ 3.523885] [<ffffffff81a9772b>] kernel_init+0x1d2/0x1e2
[ 3.523987] [<ffffffff81003894>] kernel_thread_helper+0x4/0x10
[ 3.524228] [<ffffffff814f6880>] ? restore_args+0x0/0x30
[ 3.524345] [<ffffffff81a97559>] ? kernel_init+0x0/0x1e2
[ 3.524445] [<ffffffff81003890>] ? kernel_thread_helper+0x0/0x10
-v5:
* fix build breakage with oprofile
-v4:
* use 0 instead of regs->bp
* separate out printk changes
-v3:
* apply comment from Frederic
* add a couple of printk fixes
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: Soren Sandmann <ssp@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <1300416006-3163-1-git-send-email-namhyung@gmail.com>
Fix a bunch of
warning: ‘inline’ is not at beginning of declaration
messages when building a 'make allyesconfig' kernel with -Wextra.
These warnings are trivial to kill, yet rather annoying when building with
-Wextra.
The more we can cut down on pointless crap like this the better (IMHO).
A previous patch to do this for a 'allnoconfig' build has already been
merged. This just takes the cleanup a little further.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits)
perf session: Fix infinite loop in __perf_session__process_events
perf evsel: Support perf_evsel__open(cpus > 1 && threads > 1)
perf sched: Use PTHREAD_STACK_MIN to avoid pthread_attr_setstacksize() fail
perf tools: Emit clearer message for sys_perf_event_open ENOENT return
perf stat: better error message for unsupported events
perf sched: Fix allocation result check
perf, x86: P4 PMU - Fix unflagged overflows handling
dynamic debug: Fix build issue with older gcc
tracing: Fix TRACE_EVENT power tracepoint creation
tracing: Fix preempt count leak
tracepoint: Add __rcu annotation
tracing: remove duplicate null-pointer check in skb tracepoint
tracing/trivial: Add missing comma in TRACE_EVENT comment
tracing: Include module.h in define_trace.h
x86: Save rbp in pt_regs on irq entry
x86, dumpstack: Fix unused variable warning
x86, NMI: Clean-up default_do_nmi()
x86, NMI: Allow NMI reason io port (0x61) to be processed on any CPU
x86, NMI: Remove DIE_NMI_IPI
x86, NMI: Add priorities to handlers
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits)
gameport: use this_cpu_read instead of lookup
x86: udelay: Use this_cpu_read to avoid address calculation
x86: Use this_cpu_inc_return for nmi counter
x86: Replace uses of current_cpu_data with this_cpu ops
x86: Use this_cpu_ops to optimize code
vmstat: User per cpu atomics to avoid interrupt disable / enable
irq_work: Use per cpu atomics instead of regular atomics
cpuops: Use cmpxchg for xchg to avoid lock semantics
x86: this_cpu_cmpxchg and this_cpu_xchg operations
percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support
percpu,x86: relocate this_cpu_add_return() and friends
connector: Use this_cpu operations
xen: Use this_cpu_inc_return
taskstats: Use this_cpu_ops
random: Use this_cpu_inc_return
fs: Use this_cpu_inc_return in buffer.c
highmem: Use this_cpu_xx_return() operations
vmstat: Use this_cpu_inc_return for vm statistics
x86: Support for this_cpu_add, sub, dec, inc_return
percpu: Generic support for this_cpu_add, sub, dec, inc_return
Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c}
as per Tejun.
With priorities in place and no one really understanding the difference between
DIE_NMI and DIE_NMI_IPI, just remove DIE_NMI_IPI and convert everyone to DIE_NMI.
This also simplifies default_do_nmi() a little bit. Instead of calling the
die_notifier in both the if and else part, just pull it out and call it before
the if-statement. This has the side benefit of avoiding a call to the ioport
to see if there is an external NMI sitting around until after the (more frequent)
internal NMIs are dealt with.
Patch-Inspired-by: Huang Ying <ying.huang@intel.com>
LKML-Reference: <1294348732-15030-5-git-send-email-dzickus@redhat.com>
In order to consolidate the NMI die_chain events, we need to setup the priorities
for the die notifiers.
I started by defining a bunch of common priorities that can be used by the
notifier blocks. Then I modified the notifier blocks to use the newly created
priorities.
Now that the priorities are straightened out, it should be easier to remove the
event DIE_NMI_IPI.
LKML-Reference: <1294348732-15030-4-git-send-email-dzickus@redhat.com>
* 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
apic, amd: Make firmware bug messages more meaningful
mce, amd: Remove goto in threshold_create_device()
mce, amd: Add helper functions to setup APIC
mce, amd: Shorten local variables mci_misc_{hi,lo}
mce, amd: Implement mce_threshold_block_init() helper function
Merge reason: Add the final .37 tree.
Disable preemption in init_ibs(). The function only checks the
ibs capabilities and sets up pci devices (if necessary). It runs
only on one cpu but operates with the local APIC and some MSRs,
thus it is better to disable preemption.
[ 7.034377] BUG: using smp_processor_id() in preemptible [00000000] code: modprobe/483
[ 7.034385] caller is setup_APIC_eilvt+0x155/0x180
[ 7.034389] Pid: 483, comm: modprobe Not tainted 2.6.37-rc1-20101110+ #1
[ 7.034392] Call Trace:
[ 7.034400] [<ffffffff812a2b72>] debug_smp_processor_id+0xd2/0xf0
[ 7.034404] [<ffffffff8101e985>] setup_APIC_eilvt+0x155/0x180
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=22812
Reported-by: <atswartz@gmail.com>
Cc: oprofile-list@lists.sourceforge.net <oprofile-list@lists.sourceforge.net>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Dan Carpenter <error27@gmail.com>
LKML-Reference: <20110103111514.GM4739@erda.amd.com>
[ small cleanups ]
Replace all uses of current_cpu_data with this_cpu operations on the
per cpu structure cpu_info. The scala accesses are replaced with the
matching this_cpu ops which results in smaller and more efficient
code.
In the long run, it might be a good idea to remove cpu_data() macro
too and use per_cpu macro directly.
tj: updated description
Cc: Yinghai Lu <yinghai@kernel.org>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Christoph Lameter <cl@linux.com>
Go through x86 code and replace __get_cpu_var and get_cpu_var
instances that refer to a scalar and are not used for address
determinations.
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/core
CONFIG_HARDLOCKUP_DETECTOR
The x86 arch has shifted its use of the nmi_watchdog from a
local implementation to the global one provide by
kernel/watchdog.c. This shift has caused a whole bunch of
compile problems under different config options. I attempt to
simplify things with the patch below.
In order to simplify things, I had to come to terms with the
meaning of two terms ARCH_HAS_NMI_WATCHDOG and
CONFIG_HARDLOCKUP_DETECTOR. Basically they mean the same thing,
the former on a local level and the latter on a global level.
With the old x86 nmi watchdog gone, there is no need to rely on
defining the ARCH_HAS_NMI_WATCHDOG variable because it doesn't
make sense any more. x86 will now use the global
implementation.
The changes below do a few things. First it changes the few
places that relied on ARCH_HAS_NMI_WATCHDOG to use
CONFIG_X86_LOCAL_APIC (the former was an alias for the latter
anyway, so nothing unusual here). Those pieces of code were
relying more on local apic functionality the nmi watchdog
functionality, so the change should make sense.
Second, I removed the x86 implementation of
touch_nmi_watchdog(). It isn't need now, instead x86 will rely
on kernel/watchdog.c's implementation.
Third, I removed the #define ARCH_HAS_NMI_WATCHDOG itself from
x86. And tweaked the include/linux/nmi.h file to tell users to
look for an externally defined touch_nmi_watchdog in the case of
ARCH_HAS_NMI_WATCHDOG _or_ CONFIG_HARDLOCKUP_DETECTOR. This
changes removes some of the ugliness in that file.
Finally, I added a Kconfig dependency for
CONFIG_HARDLOCKUP_DETECTOR that said you can't have
ARCH_HAS_NMI_WATCHDOG _and_ CONFIG_HARDLOCKUP_DETECTOR. You can
only have one nmi_watchdog.
Tested with
ARCH=i386: allnoconfig, defconfig, allyesconfig, (various broken
configs) ARCH=x86_64: allnoconfig, defconfig, allyesconfig,
(various broken configs)
Hopefully, after this patch I won't get any more compile broken
emails. :-)
v3:
changed a couple of 'linux/nmi.h' -> 'asm/nmi.h' to pick-up correct function
prototypes when CONFIG_HARDLOCKUP_DETECTOR is not set.
Cc: fweisbec@gmail.com
LKML-Reference: <1293044403-14117-1-git-send-email-dzickus@redhat.com>
This patch adds support for up to 6 hardware counters for AMD family
15h cpus. There is a new MSR range for hardware counters beginning at
MSRC001_0200 Performance Event Select (PERF_CTL0).
This patch adds support for AMD family 15h (Interlagos/Valencia/
Zambezi) cpus.
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into perf/core
The various stack tracing routines take a 'bp' argument in which the
caller is supposed to provide the base pointer to use, or 0 if doesn't
have one. Since bp is garbage whenever CONFIG_FRAME_POINTER is not
defined, this means all callers in principle should either always pass
0, or be conditional on CONFIG_FRAME_POINTER.
However, there are only really three use cases for stack tracing:
(a) Trace the current task, including IRQ stack if any
(b) Trace the current task, but skip IRQ stack
(c) Trace some other task
In all cases, if CONFIG_FRAME_POINTER is not defined, bp should just
be 0. If it _is_ defined, then
- in case (a) bp should be gotten directly from the CPU's register, so
the caller should pass NULL for regs,
- in case (b) the caller should should pass the IRQ registers to
dump_trace(),
- in case (c) bp should be gotten from the top of the task's stack, so
the caller should pass NULL for regs.
Hence, the bp argument is not necessary because the combination of
task and regs is sufficient to determine an appropriate value for bp.
This patch introduces a new inline function stack_frame(task, regs)
that computes the desired bp. This function is then called from the
two versions of dump_stack().
Signed-off-by: Soren Sandmann <ssp@redhat.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Arjan van de Ven <arjan@infradead.org>,
Cc: Frederic Weisbecker <fweisbec@gmail.com>,
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>,
LKML-Reference: <m3oc9rop28.fsf@dhcp-100-3-82.bos.redhat.com>>
Now that the bulk of the old nmi_watchdog is gone, remove all
the stub variables and hooks associated with it.
This touches lots of files mainly because of how the io_apic
nmi_watchdog was implemented. Now that the io_apic nmi_watchdog
is forever gone, remove all its fingers.
Most of this code was not being exercised by virtue of
nmi_watchdog != NMI_IO_APIC, so there shouldn't be anything to
risky here.
Cc: gorcunov@openvz.org
LKML-Reference: <1289578944-28564-3-git-send-email-dzickus@redhat.com>
This improves error messages in case the BIOS was setting up
wrong LVT offsets.
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
LKML-Reference: <1288015419-29543-6-git-send-email-robert.richter@amd.com>
arch/x86/oprofile/op_model_amd.c
Stephen Rothwell reported this build warning:
arch/x86/oprofile/op_model_amd.c: In function 'ibs_eilvt_valid':
arch/x86/oprofile/op_model_amd.c:289: warning: 'offset' may be used uninitialized in this function
And correctly observed that indeed the variable is used uninitialized in
this function. The result of this bug can be a debug printk with a bogus
value.
Also fix a few more small details that made this function hard to read
and which probably contributed to the bug being introduced to begin with:
- Use more symmetric error conditions
- Remove the !0 obfuscation
- Add newlines to the printk output
- Remove bogus linebreaks in printk strings and elsewhere
LKML-Reference: <20101025115736.41d51abe.sfr@canb.auug.org.au>
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (96 commits)
apic, x86: Use BIOS settings for IBS and MCE threshold interrupt LVT offsets
apic, x86: Check if EILVT APIC registers are available (AMD only)
x86: ioapic: Call free_irte only if interrupt remapping enabled
arm: Use ARCH_IRQ_INIT_FLAGS
genirq, ARM: Fix boot on ARM platforms
genirq: Fix CONFIG_GENIRQ_NO_DEPRECATED=y build
x86: Switch sparse_irq allocations to GFP_KERNEL
genirq: Switch sparse_irq allocator to GFP_KERNEL
genirq: Make sparse_lock a mutex
x86: lguest: Use new irq allocator
genirq: Remove the now unused sparse irq leftovers
genirq: Sanitize dynamic irq handling
genirq: Remove arch_init_chip_data()
x86: xen: Sanitise sparse_irq handling
x86: Use sane enumeration
x86: uv: Clean up the direct access to irq_desc
x86: Make io_apic.c local functions static
genirq: Remove irq_2_iommu
x86: Speed up the irq_remapped check in hot pathes
intr_remap: Simplify the code further
Fix up trivial conflicts in arch/x86/Kconfig
