path: root/arch/x86/mm/tlb.c
2014-08-10x86/mm: Fix sparse 'tlb_single_page_flush_ceiling' warning and make the ↵Jeremiah Mahler
variable read-mostly A sparse warning is generated about 'tlb_single_page_flush_ceiling' not being declared. arch/x86/mm/tlb.c:177:15: warning: symbol 'tlb_single_page_flush_ceiling' was not declared. Should it be static? Since it isn't used anywhere outside this file, fix the warning by making it static. Also, optimize the use of this variable by adding the __read_mostly directive, as suggested by David Rientjes. Suggested-by: David Rientjes <rientjes@google.com> Signed-off-by: Jeremiah Mahler <jmmahler@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Link: http://lkml.kernel.org/r/1407569913-4035-1-git-send-email-jmmahler@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-08-08x86/mm: Fix RCU splat from new TLB tracepointsDave Hansen
Dave Jones reported seeing a bug from one of my TLB tracepoints: http://lkml.kernel.org/r/20140806181801.GA4605@redhat.com According to Paul McKenney, the right way to fix this is adding an _rcuidle suffix to the tracepoint. http://lkml.kernel.org/r/20140807065055.GA5821@linux.vnet.ibm.com This patch does just that. Reported-by: Dave Jones <davej@redhat.com>, Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Dave Hansen <dave@sr71.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140807175841.5C92D878@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-07-31x86/mm: Set TLB flush tunable to sane value (33)Dave Hansen
This has been run through Intel's LKP tests across a wide range of modern sytems and workloads and it wasn't shown to make a measurable performance difference positive or negative. Now that we have some shiny new tracepoints, we can actually figure out what the heck is going on. During a kernel compile, 60% of the flush_tlb_mm_range() calls are for a single page. It breaks down like this: size percent percent<= V V V GLOBAL: 2.20% 2.20% avg cycles: 2283 1: 56.92% 59.12% avg cycles: 1276 2: 13.78% 72.90% avg cycles: 1505 3: 8.26% 81.16% avg cycles: 1880 4: 7.41% 88.58% avg cycles: 2447 5: 1.73% 90.31% avg cycles: 2358 6: 1.32% 91.63% avg cycles: 2563 7: 1.14% 92.77% avg cycles: 2862 8: 0.62% 93.39% avg cycles: 3542 9: 0.08% 93.47% avg cycles: 3289 10: 0.43% 93.90% avg cycles: 3570 11: 0.20% 94.10% avg cycles: 3767 12: 0.08% 94.18% avg cycles: 3996 13: 0.03% 94.20% avg cycles: 4077 14: 0.02% 94.23% avg cycles: 4836 15: 0.04% 94.26% avg cycles: 5699 16: 0.06% 94.32% avg cycles: 5041 17: 0.57% 94.89% avg cycles: 5473 18: 0.02% 94.91% avg cycles: 5396 19: 0.03% 94.95% avg cycles: 5296 20: 0.02% 94.96% avg cycles: 6749 21: 0.18% 95.14% avg cycles: 6225 22: 0.01% 95.15% avg cycles: 6393 23: 0.01% 95.16% avg cycles: 6861 24: 0.12% 95.28% avg cycles: 6912 25: 0.05% 95.32% avg cycles: 7190 26: 0.01% 95.33% avg cycles: 7793 27: 0.01% 95.34% avg cycles: 7833 28: 0.01% 95.35% avg cycles: 8253 29: 0.08% 95.42% avg cycles: 8024 30: 0.03% 95.45% avg cycles: 9670 31: 0.01% 95.46% avg cycles: 8949 32: 0.01% 95.46% avg cycles: 9350 33: 3.11% 98.57% avg cycles: 8534 34: 0.02% 98.60% avg cycles: 10977 35: 0.02% 98.62% avg cycles: 11400 We get in to dimishing returns pretty quickly. On pre-IvyBridge CPUs, we used to set the limit at 8 pages, and it was set at 128 on IvyBrige. That 128 number looks pretty silly considering that less than 0.5% of the flushes are that large. The previous code tried to size this number based on the size of the TLB. Good idea, but it's error-prone, needs maintenance (which it didn't get up to now), and probably would not matter in practice much. Settting it to 33 means that we cover the mallopt M_TRIM_THRESHOLD, which is the most universally common size to do flushes. That's the short version. Here's the long one for why I chose 33: 1. These numbers have a constant bias in the timestamps from the tracing. Probably counts for a couple hundred cycles in each of these tests, but it should be fairly _even_ across all of them. The smallest delta between the tracepoints I have ever seen is 335 cycles. This is one reason the cycles/page cost goes down in general as the flushes get larger. The true cost is nearer to 100 cycles. 2. A full flush is more expensive than a single invlpg, but not by much (single percentages). 3. A dtlb miss is 17.1ns (~45 cycles) and a itlb miss is 13.0ns (~34 cycles). At those rates, refilling the 512-entry dTLB takes 22,000 cycles. 4. 22,000 cycles is approximately the equivalent of doing 85 invlpg operations. But, the odds are that the TLB can actually be filled up faster than that because TLB misses that are close in time also tend to leverage the same caches. 6. ~98% of flushes are <=33 pages. There are a lot of flushes of 33 pages, probably because libc's M_TRIM_THRESHOLD is set to 128k (32 pages) 7. I've found no consistent data to support changing the IvyBridge vs. SandyBridge tunable by a factor of 16 I used the performance counters on this hardware (IvyBridge i5-3320M) to figure out the tlb miss costs: ocperf.py stat -e dtlb_load_misses.walk_duration,dtlb_load_misses.walk_completed,dtlb_store_misses.walk_duration,dtlb_store_misses.walk_completed,itlb_misses.walk_duration,itlb_misses.walk_completed,itlb.itlb_flush 7,720,030,970 dtlb_load_misses_walk_duration [57.13%] 169,856,353 dtlb_load_misses_walk_completed [57.15%] 708,832,859 dtlb_store_misses_walk_duration [57.17%] 19,346,823 dtlb_store_misses_walk_completed [57.17%] 2,779,687,402 itlb_misses_walk_duration [57.15%] 82,241,148 itlb_misses_walk_completed [57.13%] 770,717 itlb_itlb_flush [57.11%] Show that a dtlb miss is 17.1ns (~45 cycles) and a itlb miss is 13.0ns (~34 cycles). At those rates, refilling the 512-entry dTLB takes 22,000 cycles. On a SandyBridge system with more cores and larger caches, those are dtlb=13.4ns and itlb=9.5ns. cat perf.stat.txt | perl -pe 's/,//g' | awk '/itlb_misses_walk_duration/ { icyc+=$1 } /itlb_misses_walk_completed/ { imiss+=$1 } /dtlb_.*_walk_duration/ { dcyc+=$1 } /dtlb_.*.*completed/ { dmiss+=$1 } END {print "itlb cyc/miss: ", icyc/imiss, " dtlb cyc/miss: ", dcyc/dmiss, " ----- ", icyc,imiss, dcyc,dmiss } On Westmere CPUs, the counters to use are: itlb_flush,itlb_misses.walk_cycles,itlb_misses.any,dtlb_misses.walk_cycles,dtlb_misses.any The assumptions that this code went in under: https://lkml.org/lkml/2012/6/12/119 say that a flush and a refill are about 100ns. Being generous, that is over by a factor of 6 on the refill side, although it is fairly close on the cost of an invlpg. An increase of a single invlpg operation seems to lengthen the flush range operation by about 200 cycles. Here is one example of the data collected for flushing 10 and 11 pages (full data are below): 10: 0.43% 93.90% avg cycles: 3570 cycles/page: 357 samples: 4714 11: 0.20% 94.10% avg cycles: 3767 cycles/page: 342 samples: 2145 How to generate this table: echo 10000 > /sys/kernel/debug/tracing/buffer_size_kb echo x86-tsc > /sys/kernel/debug/tracing/trace_clock echo 'reason != 0' > /sys/kernel/debug/tracing/events/tlb/tlb_flush/filter echo 1 > /sys/kernel/debug/tracing/events/tlb/tlb_flush/enable Pipe the trace output in to this script: http://sr71.net/~dave/intel/201402-tlb/trace-time-diff-process.pl.txt Note that these data were gathered with the invlpg threshold set to 150 pages. Only data points with >=50 of samples were printed: Flush % of %<= in flush this pages es size ------------------------------------------------------------------------------ -1: 2.20% 2.20% avg cycles: 2283 cycles/page: xxxx samples: 23960 1: 56.92% 59.12% avg cycles: 1276 cycles/page: 1276 samples: 620895 2: 13.78% 72.90% avg cycles: 1505 cycles/page: 752 samples: 150335 3: 8.26% 81.16% avg cycles: 1880 cycles/page: 626 samples: 90131 4: 7.41% 88.58% avg cycles: 2447 cycles/page: 611 samples: 80877 5: 1.73% 90.31% avg cycles: 2358 cycles/page: 471 samples: 18885 6: 1.32% 91.63% avg cycles: 2563 cycles/page: 427 samples: 14397 7: 1.14% 92.77% avg cycles: 2862 cycles/page: 408 samples: 12441 8: 0.62% 93.39% avg cycles: 3542 cycles/page: 442 samples: 6721 9: 0.08% 93.47% avg cycles: 3289 cycles/page: 365 samples: 917 10: 0.43% 93.90% avg cycles: 3570 cycles/page: 357 samples: 4714 11: 0.20% 94.10% avg cycles: 3767 cycles/page: 342 samples: 2145 12: 0.08% 94.18% avg cycles: 3996 cycles/page: 333 samples: 864 13: 0.03% 94.20% avg cycles: 4077 cycles/page: 313 samples: 289 14: 0.02% 94.23% avg cycles: 4836 cycles/page: 345 samples: 236 15: 0.04% 94.26% avg cycles: 5699 cycles/page: 379 samples: 390 16: 0.06% 94.32% avg cycles: 5041 cycles/page: 315 samples: 643 17: 0.57% 94.89% avg cycles: 5473 cycles/page: 321 samples: 6229 18: 0.02% 94.91% avg cycles: 5396 cycles/page: 299 samples: 224 19: 0.03% 94.95% avg cycles: 5296 cycles/page: 278 samples: 367 20: 0.02% 94.96% avg cycles: 6749 cycles/page: 337 samples: 185 21: 0.18% 95.14% avg cycles: 6225 cycles/page: 296 samples: 1964 22: 0.01% 95.15% avg cycles: 6393 cycles/page: 290 samples: 83 23: 0.01% 95.16% avg cycles: 6861 cycles/page: 298 samples: 61 24: 0.12% 95.28% avg cycles: 6912 cycles/page: 288 samples: 1307 25: 0.05% 95.32% avg cycles: 7190 cycles/page: 287 samples: 533 26: 0.01% 95.33% avg cycles: 7793 cycles/page: 299 samples: 94 27: 0.01% 95.34% avg cycles: 7833 cycles/page: 290 samples: 66 28: 0.01% 95.35% avg cycles: 8253 cycles/page: 294 samples: 73 29: 0.08% 95.42% avg cycles: 8024 cycles/page: 276 samples: 846 30: 0.03% 95.45% avg cycles: 9670 cycles/page: 322 samples: 296 31: 0.01% 95.46% avg cycles: 8949 cycles/page: 288 samples: 79 32: 0.01% 95.46% avg cycles: 9350 cycles/page: 292 samples: 60 33: 3.11% 98.57% avg cycles: 8534 cycles/page: 258 samples: 33936 34: 0.02% 98.60% avg cycles: 10977 cycles/page: 322 samples: 268 35: 0.02% 98.62% avg cycles: 11400 cycles/page: 325 samples: 177 36: 0.01% 98.63% avg cycles: 11504 cycles/page: 319 samples: 161 37: 0.02% 98.65% avg cycles: 11596 cycles/page: 313 samples: 182 38: 0.02% 98.66% avg cycles: 11850 cycles/page: 311 samples: 195 39: 0.01% 98.68% avg cycles: 12158 cycles/page: 311 samples: 128 40: 0.01% 98.68% avg cycles: 11626 cycles/page: 290 samples: 78 41: 0.04% 98.73% avg cycles: 11435 cycles/page: 278 samples: 477 42: 0.01% 98.73% avg cycles: 12571 cycles/page: 299 samples: 74 43: 0.01% 98.74% avg cycles: 12562 cycles/page: 292 samples: 78 44: 0.01% 98.75% avg cycles: 12991 cycles/page: 295 samples: 108 45: 0.01% 98.76% avg cycles: 13169 cycles/page: 292 samples: 78 46: 0.02% 98.78% avg cycles: 12891 cycles/page: 280 samples: 261 47: 0.01% 98.79% avg cycles: 13099 cycles/page: 278 samples: 67 48: 0.01% 98.80% avg cycles: 13851 cycles/page: 288 samples: 77 49: 0.01% 98.80% avg cycles: 13749 cycles/page: 280 samples: 66 50: 0.01% 98.81% avg cycles: 13949 cycles/page: 278 samples: 73 52: 0.00% 98.82% avg cycles: 14243 cycles/page: 273 samples: 52 54: 0.01% 98.83% avg cycles: 15312 cycles/page: 283 samples: 87 55: 0.01% 98.84% avg cycles: 15197 cycles/page: 276 samples: 109 56: 0.02% 98.86% avg cycles: 15234 cycles/page: 272 samples: 208 57: 0.00% 98.86% avg cycles: 14888 cycles/page: 261 samples: 53 58: 0.01% 98.87% avg cycles: 15037 cycles/page: 259 samples: 59 59: 0.01% 98.87% avg cycles: 15752 cycles/page: 266 samples: 63 62: 0.00% 98.89% avg cycles: 16222 cycles/page: 261 samples: 54 64: 0.02% 98.91% avg cycles: 17179 cycles/page: 268 samples: 248 65: 0.12% 99.03% avg cycles: 18762 cycles/page: 288 samples: 1324 85: 0.00% 99.10% avg cycles: 21649 cycles/page: 254 samples: 50 127: 0.01% 99.18% avg cycles: 32397 cycles/page: 255 samples: 75 128: 0.13% 99.31% avg cycles: 31711 cycles/page: 247 samples: 1466 129: 0.18% 99.49% avg cycles: 33017 cycles/page: 255 samples: 1927 181: 0.33% 99.84% avg cycles: 2489 cycles/page: 13 samples: 3547 256: 0.05% 99.91% avg cycles: 2305 cycles/page: 9 samples: 550 512: 0.03% 99.95% avg cycles: 2133 cycles/page: 4 samples: 304 1512: 0.01% 99.99% avg cycles: 3038 cycles/page: 2 samples: 65 Here are the tlb counters during a 10-second slice of a kernel compile for a SandyBridge system. It's better than IvyBridge, but probably due to the larger caches since this was one of the 'X' extreme parts. 10,873,007,282 dtlb_load_misses_walk_duration 250,711,333 dtlb_load_misses_walk_completed 1,212,395,865 dtlb_store_misses_walk_duration 31,615,772 dtlb_store_misses_walk_completed 5,091,010,274 itlb_misses_walk_duration 163,193,511 itlb_misses_walk_completed 1,321,980 itlb_itlb_flush 10.008045158 seconds time elapsed # cat perf.stat.1392743721.txt | perl -pe 's/,//g' | awk '/itlb_misses_walk_duration/ { icyc+=$1 } /itlb_misses_walk_completed/ { imiss+=$1 } /dtlb_.*_walk_duration/ { dcyc+=$1 } /dtlb_.*.*completed/ { dmiss+=$1 } END {print "itlb cyc/miss: ", icyc/imiss/3.3, " dtlb cyc/miss: ", dcyc/dmiss/3.3, " ----- ", icyc,imiss, dcyc,dmiss }' itlb ns/miss: 9.45338 dtlb ns/miss: 12.9716 Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Link: http://lkml.kernel.org/r/20140731154103.10C1115E@viggo.jf.intel.com Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-07-31x86/mm: New tunable for single vs full TLB flushDave Hansen
Most of the logic here is in the documentation file. Please take a look at it. I know we've come full-circle here back to a tunable, but this new one is *WAY* simpler. I challenge anyone to describe in one sentence how the old one worked. Here's the way the new one works: If we are flushing more pages than the ceiling, we use the full flush, otherwise we use per-page flushes. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Link: http://lkml.kernel.org/r/20140731154101.12B52CAF@viggo.jf.intel.com Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-07-31x86/mm: Add tracepoints for TLB flushesDave Hansen
We don't have any good way to figure out what kinds of flushes are being attempted. Right now, we can try to use the vm counters, but those only tell us what we actually did with the hardware (one-by-one vs full) and don't tell us what was actually _requested_. This allows us to select out "interesting" TLB flushes that we might want to optimize (like the ranged ones) and ignore the ones that we have very little control over (the ones at context switch). Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Link: http://lkml.kernel.org/r/20140731154059.4C96CBA5@viggo.jf.intel.com Acked-by: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-07-31x86/mm: Unify remote INVLPG codeDave Hansen
There are currently three paths through the remote flush code: 1. full invalidation 2. single page invalidation using invlpg 3. ranged invalidation using invlpg This takes 2 and 3 and combines them in to a single path by making the single-page one just be the start and end be start plus a single page. This makes placement of our tracepoint easier. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Link: http://lkml.kernel.org/r/20140731154058.E0F90408@viggo.jf.intel.com Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-07-31x86/mm: Fix missed global TLB flush statDave Hansen
If we take the if (end == TLB_FLUSH_ALL || vmflag & VM_HUGETLB) { local_flush_tlb(); goto out; } path out of flush_tlb_mm_range(), we will have flushed the tlb, but not incremented NR_TLB_LOCAL_FLUSH_ALL. This unifies the way out of the function so that we always take a single path when doing a full tlb flush. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Link: http://lkml.kernel.org/r/20140731154056.FF763B76@viggo.jf.intel.com Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-07-31x86/mm: Rip out complicated, out-of-date, buggy TLB flushingDave Hansen
I think the flush_tlb_mm_range() code that tries to tune the flush sizes based on the CPU needs to get ripped out for several reasons: 1. It is obviously buggy. It uses mm->total_vm to judge the task's footprint in the TLB. It should certainly be using some measure of RSS, *NOT* ->total_vm since only resident memory can populate the TLB. 2. Haswell, and several other CPUs are missing from the intel_tlb_flushall_shift_set() function. Thus, it has been demonstrated to bitrot quickly in practice. 3. It is plain wrong in my vm: [ 0.037444] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0 [ 0.037444] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0 [ 0.037444] tlb_flushall_shift: 6 Which leads to it to never use invlpg. 4. The assumptions about TLB refill costs are wrong: http://lkml.kernel.org/r/1337782555-8088-3-git-send-email-alex.shi@intel.com (more on this in later patches) 5. I can not reproduce the original data: https://lkml.org/lkml/2012/5/17/59 I believe the sample times were too short. Running the benchmark in a loop yields times that vary quite a bit. Note that this leaves us with a static ceiling of 1 page. This is a conservative, dumb setting, and will be revised in a later patch. This also removes the code which attempts to predict whether we are flushing data or instructions. We expect instruction flushes to be relatively rare and not worth tuning for explicitly. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Link: http://lkml.kernel.org/r/20140731154055.ABC88E89@viggo.jf.intel.com Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-07-31x86/mm: Clean up the TLB flushing codeDave Hansen
The if (cpumask_any_but(mm_cpumask(mm), smp_processor_id()) < nr_cpu_ids) line of code is not exactly the easiest to audit, especially when it ends up at two different indentation levels. This eliminates one of the the copy-n-paste versions. It also gives us a unified exit point for each path through this function. We need this in a minute for our tracepoint. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Link: http://lkml.kernel.org/r/20140731154054.44F1CDDC@viggo.jf.intel.com Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-25x86/mm: Eliminate redundant page table walk during TLB range flushingMel Gorman
When choosing between doing an address space or ranged flush, the x86 implementation of flush_tlb_mm_range takes into account whether there are any large pages in the range. A per-page flush typically requires fewer entries than would covered by a single large page and the check is redundant. There is one potential exception. THP migration flushes single THP entries and it conceivably would benefit from flushing a single entry instead of the mm. However, this flush is after a THP allocation, copy and page table update potentially with any other threads serialised behind it. In comparison to that, the flush is noise. It makes more sense to optimise balancing to require fewer flushes than to optimise the flush itself. This patch deletes the redundant huge page check. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Davidlohr Bueso <davidlohr@hp.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Alex Shi <alex.shi@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-sgei1drpOcburujPsfh6ovmo@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-25x86/mm: Clean up inconsistencies when flushing TLB rangesMel Gorman
NR_TLB_LOCAL_FLUSH_ALL is not always accounted for correctly and the comparison with total_vm is done before taking tlb_flushall_shift into account. Clean it up. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Davidlohr Bueso <davidlohr@hp.com> Reviewed-by: Alex Shi <alex.shi@linaro.org> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Hugh Dickins <hughd@google.com> Link: http://lkml.kernel.org/n/tip-Iz5gcahrgskIldvukulzi0hh@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-25mm, x86: Account for TLB flushes only when debuggingMel Gorman
Bisection between 3.11 and 3.12 fingered commit 9824cf97 ("mm: vmstats: tlb flush counters") to cause overhead problems. The counters are undeniably useful but how often do we really need to debug TLB flush related issues? It does not justify taking the penalty everywhere so make it a debugging option. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Davidlohr Bueso <davidlohr@hp.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com> Cc: Alex Shi <alex.shi@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-XzxjntugxuwpxXhcrxqqh53b@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-11mm: vmstats: track TLB flush stats on UP tooDave Hansen
The previous patch doing vmstats for TLB flushes ("mm: vmstats: tlb flush counters") effectively missed UP since arch/x86/mm/tlb.c is only compiled for SMP. UP systems do not do remote TLB flushes, so compile those counters out on UP. arch/x86/kernel/cpu/mtrr/generic.c calls __flush_tlb() directly. This is probably an optimization since both the mtrr code and __flush_tlb() write cr4. It would probably be safe to make that a flush_tlb_all() (and then get these statistics), but the mtrr code is ancient and I'm hesitant to touch it other than to just stick in the counters. [akpm@linux-foundation.org: tweak comments] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11mm: vmstats: tlb flush countersDave Hansen
I was investigating some TLB flush scaling issues and realized that we do not have any good methods for figuring out how many TLB flushes we are doing. It would be nice to be able to do these in generic code, but the arch-independent calls don't explicitly specify whether we actually need to do remote flushes or not. In the end, we really need to know if we actually _did_ global vs. local invalidations, so that leaves us with few options other than to muck with the counters from arch-specific code. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-24x86: Convert a few mistaken __cpuinit annotations to __initJan Beulich
The first two are functions serving as initcalls; the SFI one is only being called from __init code. Signed-off-by: Jan Beulich <jbeulich@suse.com> Link: http://lkml.kernel.org/r/50AFB35102000078000AAECA@nat28.tlf.novell.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-11-29x86, 386 removal: Remove CONFIG_INVLPGH. Peter Anvin
All 486+ CPUs support INVLPG, so remove the fallback 386 support code. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1354132230-21854-6-git-send-email-hpa@linux.intel.com
2012-11-14x86, mm: Correct vmflag test for checking VM_HUGETLBJoonsoo Kim
commit 611ae8e3f5204f7480b3b405993b3352cfa16662('enable tlb flush range support for x86') change flush_tlb_mm_range() considerably. After this, we test whether vmflag equal to VM_HUGETLB and it may be always failed, because vmflag usually has other flags simultaneously. Our intention is to check whether this vma is for hughtlb, so correct it according to this purpose. Signed-off-by: Joonsoo Kim <js1304@gmail.com> Acked-by: Alex Shi <alex.shi@intel.com> Link: http://lkml.kernel.org/r/1352740656-19417-1-git-send-email-js1304@gmail.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-09-27x86: Distinguish TLB shootdown interrupts from other functions call interruptsTomoki Sekiyama
As TLB shootdown requests to other CPU cores are now using function call interrupts, TLB shootdowns entry in /proc/interrupts is always shown as 0. This behavior change was introduced by commit 52aec3308db8 ("x86/tlb: replace INVALIDATE_TLB_VECTOR by CALL_FUNCTION_VECTOR"). This patch reverts TLB shootdowns entry in /proc/interrupts to count TLB shootdowns separately from the other function call interrupts. Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama.qu@hitachi.com> Link: http://lkml.kernel.org/r/20120926021128.22212.20440.stgit@hpxw Acked-by: Alex Shi <alex.shi@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-09-07x86/mm: Fix range check in tlbflush debugfs interfaceJan Beulich
Since the shift count settable there is used for shifting values of type "unsigned long", its value must not match or exceed BITS_PER_LONG (otherwise the shift operations are undefined). Similarly, the value must not be negative (but -1 must be permitted, as that's the value used to distinguish the case of the fine grained flushing being disabled). Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: Alex Shi <alex.shi@intel.com> Link: http://lkml.kernel.org/r/5049B65C020000780009990C@nat28.tlf.novell.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-06-27x86/tlb: do flush_tlb_kernel_range by 'invlpg'Alex Shi
This patch do flush_tlb_kernel_range by 'invlpg'. The performance pay and gain was analyzed in previous patch (x86/flush_tlb: try flush_tlb_single one by one in flush_tlb_range). In the testing: http://lkml.org/lkml/2012/6/21/10 The pay is mostly covered by long kernel path, but the gain is still quite clear, memory access in user APP can increase 30+% when kernel execute this funtion. Signed-off-by: Alex Shi <alex.shi@intel.com> Link: http://lkml.kernel.org/r/1340845344-27557-10-git-send-email-alex.shi@intel.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-06-27x86/tlb: replace INVALIDATE_TLB_VECTOR by CALL_FUNCTION_VECTORAlex Shi
There are 32 INVALIDATE_TLB_VECTOR now in kernel. That is quite big amount of vector in IDT. But it is still not enough, since modern x86 sever has more cpu number. That still causes heavy lock contention in TLB flushing. The patch using generic smp call function to replace it. That saved 32 vector number in IDT, and resolved the lock contention in TLB flushing on large system. In the NHM EX machine 4P * 8cores * HT = 64 CPUs, hackbench pthread has 3% performance increase. Signed-off-by: Alex Shi <alex.shi@intel.com> Link: http://lkml.kernel.org/r/1340845344-27557-9-git-send-email-alex.shi@intel.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-06-27x86/tlb: enable tlb flush range support for x86Alex Shi
Not every tlb_flush execution moment is really need to evacuate all TLB entries, like in munmap, just few 'invlpg' is better for whole process performance, since it leaves most of TLB entries for later accessing. This patch also rewrite flush_tlb_range for 2 purposes: 1, split it out to get flush_blt_mm_range function. 2, clean up to reduce line breaking, thanks for Borislav's input. My micro benchmark 'mummap' http://lkml.org/lkml/2012/5/17/59 show that the random memory access on other CPU has 0~50% speed up on a 2P * 4cores * HT NHM EP while do 'munmap'. Thanks Yongjie's testing on this patch: ------------- I used Linux 3.4-RC6 w/ and w/o his patches as Xen dom0 and guest kernel. After running two benchmarks in Xen HVM guest, I found his patches brought about 1%~3% performance gain in 'kernel build' and 'netperf' testing, though the performance gain was not very stable in 'kernel build' testing. Some detailed testing results are below. Testing Environment: Hardware: Romley-EP platform Xen version: latest upstream Linux kernel: 3.4-RC6 Guest vCPU number: 8 NIC: Intel 82599 (10GB bandwidth) In 'kernel build' testing in guest: Command line | performance gain make -j 4 | 3.81% make -j 8 | 0.37% make -j 16 | -0.52% In 'netperf' testing, we tested TCP_STREAM with default socket size 16384 byte as large packet and 64 byte as small packet. I used several clients to add networking pressure, then 'netperf' server automatically generated several threads to response them. I also used large-size packet and small-size packet in the testing. Packet size | Thread number | performance gain 16384 bytes | 4 | 0.02% 16384 bytes | 8 | 2.21% 16384 bytes | 16 | 2.04% 64 bytes | 4 | 1.07% 64 bytes | 8 | 3.31% 64 bytes | 16 | 0.71% Signed-off-by: Alex Shi <alex.shi@intel.com> Link: http://lkml.kernel.org/r/1340845344-27557-8-git-send-email-alex.shi@intel.com Tested-by: Ren, Yongjie <yongjie.ren@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-06-27x86/tlb: add tlb_flushall_shift knob into debugfsAlex Shi
kernel will replace cr3 rewrite with invlpg when tlb_flush_entries <= active_tlb_entries / 2^tlb_flushall_factor if tlb_flushall_factor is -1, kernel won't do this replacement. User can modify its value according to specific CPU/applications. Thanks for Borislav providing the help message of CONFIG_DEBUG_TLBFLUSH. Signed-off-by: Alex Shi <alex.shi@intel.com> Link: http://lkml.kernel.org/r/1340845344-27557-6-git-send-email-alex.shi@intel.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-06-27x86/tlb: add tlb_flushall_shift for specific CPUAlex Shi
Testing show different CPU type(micro architectures and NUMA mode) has different balance points between the TLB flush all and multiple invlpg. And there also has cases the tlb flush change has no any help. This patch give a interface to let x86 vendor developers have a chance to set different shift for different CPU type. like some machine in my hands, balance points is 16 entries on Romely-EP; while it is at 8 entries on Bloomfield NHM-EP; and is 256 on IVB mobile CPU. but on model 15 core2 Xeon using invlpg has nothing help. For untested machine, do a conservative optimization, same as NHM CPU. Signed-off-by: Alex Shi <alex.shi@intel.com> Link: http://lkml.kernel.org/r/1340845344-27557-5-git-send-email-alex.shi@intel.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-06-27x86/tlb: fall back to flush all when meet a THP large pageAlex Shi
We don't need to flush large pages by PAGE_SIZE step, that just waste time. and actually, large page don't need 'invlpg' optimizing according to our micro benchmark. So, just flush whole TLB is enough for them. The following result is tested on a 2CPU * 4cores * 2HT NHM EP machine, with THP 'always' setting. Multi-thread testing, '-t' paramter is thread number: without this patch with this patch ./mprotect -t 1 14ns 13ns ./mprotect -t 2 13ns 13ns ./mprotect -t 4 12ns 11ns ./mprotect -t 8 14ns 10ns ./mprotect -t 16 28ns 28ns ./mprotect -t 32 54ns 52ns ./mprotect -t 128 200ns 200ns Signed-off-by: Alex Shi <alex.shi@intel.com> Link: http://lkml.kernel.org/r/1340845344-27557-4-git-send-email-alex.shi@intel.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-06-27x86/flush_tlb: try flush_tlb_single one by one in flush_tlb_rangeAlex Shi
x86 has no flush_tlb_range support in instruction level. Currently the flush_tlb_range just implemented by flushing all page table. That is not the best solution for all scenarios. In fact, if we just use 'invlpg' to flush few lines from TLB, we can get the performance gain from later remain TLB lines accessing. But the 'invlpg' instruction costs much of time. Its execution time can compete with cr3 rewriting, and even a bit more on SNB CPU. So, on a 512 4KB TLB entries CPU, the balance points is at: (512 - X) * 100ns(assumed TLB refill cost) = X(TLB flush entries) * 100ns(assumed invlpg cost) Here, X is 256, that is 1/2 of 512 entries. But with the mysterious CPU pre-fetcher and page miss handler Unit, the assumed TLB refill cost is far lower then 100ns in sequential access. And 2 HT siblings in one core makes the memory access more faster if they are accessing the same memory. So, in the patch, I just do the change when the target entries is less than 1/16 of whole active tlb entries. Actually, I have no data support for the percentage '1/16', so any suggestions are welcomed. As to hugetlb, guess due to smaller page table, and smaller active TLB entries, I didn't see benefit via my benchmark, so no optimizing now. My micro benchmark show in ideal scenarios, the performance improves 70 percent in reading. And in worst scenario, the reading/writing performance is similar with unpatched 3.4-rc4 kernel. Here is the reading data on my 2P * 4cores *HT NHM EP machine, with THP 'always': multi thread testing, '-t' paramter is thread number: with patch unpatched 3.4-rc4 ./mprotect -t 1 14ns 24ns ./mprotect -t 2 13ns 22ns ./mprotect -t 4 12ns 19ns ./mprotect -t 8 14ns 16ns ./mprotect -t 16 28ns 26ns ./mprotect -t 32 54ns 51ns ./mprotect -t 128 200ns 199ns Single process with sequencial flushing and memory accessing: with patch unpatched 3.4-rc4 ./mprotect 7ns 11ns ./mprotect -p 4096 -l 8 -n 10240 21ns 21ns [ hpa: http://lkml.kernel.org/r/1B4B44D9196EFF41AE41FDA404FC0A100BFF94@SHSMSX101.ccr.corp.intel.com has additional performance numbers. ] Signed-off-by: Alex Shi <alex.shi@intel.com> Link: http://lkml.kernel.org/r/1340845344-27557-3-git-send-email-alex.shi@intel.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-05-23Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm changes from Ingo Molnar: "This tree includes a micro-optimization that avoids cr3 switches during idling; it fixes corner cases and there's also small cleanups" Fix up trivial context conflict with the percpu_xx -> this_cpu_xx changes. * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86-64: Fix accounting in kernel_physical_mapping_init() x86/tlb: Clean up and unify TLB_FLUSH_ALL definition x86: Drop obsolete ARCH_BOOTMEM support x86, tlb: Switch cr3 in leave_mm() only when needed x86/mm: Fix the size calculation of mapping tables
2012-05-14x86: replace percpu_xxx funcs with this_cpu_xxxAlex Shi
Since percpu_xxx() serial functions are duplicated with this_cpu_xxx(). Removing percpu_xxx() definition and replacing them by this_cpu_xxx() in code. There is no function change in this patch, just preparation for later percpu_xxx serial function removing. On x86 machine the this_cpu_xxx() serial functions are same as __this_cpu_xxx() without no unnecessary premmpt enable/disable. Thanks for Stephen Rothwell, he found and fixed a i386 build error in the patch. Also thanks for Andrew Morton, he kept updating the patchset in Linus' tree. Signed-off-by: Alex Shi <alex.shi@intel.com> Acked-by: Christoph Lameter <cl@gentwo.org> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2012-03-22x86, tlb: Switch cr3 in leave_mm() only when neededSuresh Siddha
Currently leave_mm() unconditionally switches the cr3 to swapper_pg_dir. But there is no need to change the cr3, if we already left that mm. intel_idle() for example calls leave_mm() on every deep c-state entry where the CPU flushes the TLB for us. Similarly flush_tlb_all() was also calling leave_mm() whenever the TLB is in LAZY state. Both these paths will be improved with this change. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Link: http://lkml.kernel.org/r/1332460885.16101.147.camel@sbsiddha-desk.sc.intel.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2011-03-15x86, tlb, UV: Do small micro-optimization for native_flush_tlb_others()Xiao Guangrong
native_flush_tlb_others() is called from: flush_tlb_current_task() flush_tlb_mm() flush_tlb_page() All these functions disable preemption explicitly, so we can use smp_processor_id() instead of get_cpu() and put_cpu(). Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Cliff Wickman <cpw@sgi.com> LKML-Reference: <4D7EC791.4040003@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-02-14x86: Avoid tlbstate lock if not enough cpusShaohua Li
This one isn't related to previous patch. If online cpus are below NUM_INVALIDATE_TLB_VECTORS, we don't need the lock. The comments in the code declares we don't need the check, but a hot lock still needs an atomic operation and expensive, so add the check here. Uses nr_cpu_ids here as suggested by Eric Dumazet. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Andi Kleen <andi@firstfloor.org> LKML-Reference: <1295232730.1949.710.camel@sli10-conroe> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-18x86: Use online node real index in calulate_tbl_offset()Yinghai Lu
Found a NUMA system that doesn't have RAM installed at the first socket which hangs while executing init scripts. bisected it to: | commit 932967202182743c01a2eee4bdfa2c42697bc586 | Author: Shaohua Li <shaohua.li@intel.com> | Date: Wed Oct 20 11:07:03 2010 +0800 | | x86: Spread tlb flush vector between nodes It turns out when first socket is not online it could have cpus on node1 tlb_offset set to bigger than NUM_INVALIDATE_TLB_VECTORS. That could affect systems like 4 sockets, but socket 2 doesn't have installed, sockets 3 will get too big tlb_offset. Need to use real online node idx. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Shaohua Li <shaohua.li@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4CDEDE59.40603@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-01x86, mm: Fix section mismatch in tlb.cRakib Mullick
Mark tlb_cpuhp_notify as __cpuinit. It's basically a callback function, which is called from __cpuinit init_smp_flash(). So - it's safe. We were warned by the following warning: WARNING: arch/x86/mm/built-in.o(.text+0x356d): Section mismatch in reference from the function tlb_cpuhp_notify() to the function .cpuinit.text:calculate_tlb_offset() The function tlb_cpuhp_notify() references the function __cpuinit calculate_tlb_offset(). This is often because tlb_cpuhp_notify lacks a __cpuinit annotation or the annotation of calculate_tlb_offset is wrong. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Cc: Borislav Petkov <borislav.petkov@amd.com> Cc: Shaohua Li <shaohua.li@intel.com> LKML-Reference: <AANLkTinWQRG=HA9uB3ad0KAqRRTinL6L_4iKgF84coph@mail.gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-20x86: Spread tlb flush vector between nodesShaohua Li
Currently flush tlb vector allocation is based on below equation: sender = smp_processor_id() % 8 This isn't optimal, CPUs from different node can have the same vector, this causes a lot of lock contention. Instead, we can assign the same vectors to CPUs from the same node, while different node has different vectors. This has below advantages: a. if there is lock contention, the lock contention is between CPUs from one node. This should be much cheaper than the contention between nodes. b. completely avoid lock contention between nodes. This especially benefits kswapd, which is the biggest user of tlb flush, since kswapd sets its affinity to specific node. In my test, this could reduce > 20% CPU overhead in extreme case.The test machine has 4 nodes and each node has 16 CPUs. I then bind each node's kswapd to the first CPU of the node. I run a workload with 4 sequential mmap file read thread. The files are empty sparse file. This workload will trigger a lot of page reclaim and tlbflush. The kswapd bind is to easy trigger the extreme tlb flush lock contention because otherwise kswapd keeps migrating between CPUs of a node and I can't get stable result. Sure in real workload, we can't always see so big tlb flush lock contention, but it's possible. [ hpa: folded in fix from Eric Dumazet to use this_cpu_read() ] Signed-off-by: Shaohua Li <shaohua.li@intel.com> LKML-Reference: <1287544023.4571.8.camel@sli10-conroe.sh.intel.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-07-21x86, tlb: Clean up and correct used typeBorislav Petkov
smp_processor_id() returns an int and not an unsigned long. Also, since the function is small enough, there's no need for a local variable caching its value. No functionality change, just cleanup. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> LKML-Reference: <20100721124705.GA674@aftab> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-17x86: Convert tlbstate_lock to raw_spinlockThomas Gleixner
2009-11-19x86: Eliminate redundant/contradicting cache line size config optionsJan Beulich
Rather than having X86_L1_CACHE_BYTES and X86_L1_CACHE_SHIFT (with inconsistent defaults), just having the latter suffices as the former can be easily calculated from it. To be consistent, also change X86_INTERNODE_CACHE_BYTES to X86_INTERNODE_CACHE_SHIFT, and set it to 7 (128 bytes) for NUMA to account for last level cache line size (which here matters more than L1 cache line size). Finally, make sure the default value for X86_L1_CACHE_SHIFT, when X86_GENERIC is selected, is being seen before that for the individual CPU model options (other than on x86-64, where GENERIC_CPU is part of the choice construct, X86_GENERIC is a separate option on ix86). Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Ravikiran Thirumalai <kiran@scalex86.org> Acked-by: Nick Piggin <npiggin@suse.de> LKML-Reference: <4AFD5710020000780001F8F0@vpn.id2.novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-24cpumask: use mm_cpumask() wrapper: x86Rusty Russell
Makes code futureproof against the impending change to mm->cpu_vm_mask (to be a pointer). It's also a chance to use the new cpumask_ ops which take a pointer (the older ones are deprecated, but there's no hurry for arch code). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-08-21x86: don't call '->send_IPI_mask()' with an empty maskLinus Torvalds
As noted in 83d349f35e1ae72268c5104dbf9ab2ae635425d4 ("x86: don't send an IPI to the empty set of CPU's"), some APIC's will be very unhappy with an empty destination mask. That commit added a WARN_ON() for that case, and avoided the resulting problem, but didn't fix the underlying reason for why those empty mask cases happened. This fixes that, by checking the result of 'cpumask_andnot()' of the current CPU actually has any other CPU's left in the set of CPU's to be sent a TLB flush, and not calling down to the IPI code if the mask is empty. The reason this started happening at all is that we started passing just the CPU mask pointers around in commit 4595f9620 ("x86: change flush_tlb_others to take a const struct cpumask"), and when we did that, the cpumask was no longer thread-local. Before that commit, flush_tlb_mm() used to create it's own copy of 'mm->cpu_vm_mask' and pass that copy down to the low-level flush routines after having tested that it was not empty. But after changing it to just pass down the CPU mask pointer, the lower level TLB flush routines would now get a pointer to that 'mm->cpu_vm_mask', and that could still change - and become empty - after the test due to other CPU's having flushed their own TLB's. See http://bugzilla.kernel.org/show_bug.cgi?id=13933 for details. Tested-by: Thomas Björnell <thomas.bjornell@gmail.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-18x86: add x2apic_wrmsr_fence() to x2apic flush tlb pathsSuresh Siddha
Impact: optimize APIC IPI related barriers Uncached MMIO accesses for xapic are inherently serializing and hence we don't need explicit barriers for xapic IPI paths. x2apic MSR writes/reads don't have serializing semantics and hence need a serializing instruction or mfence, to make all the previous memory stores globally visisble before the x2apic msr write for IPI. Add x2apic_wrmsr_fence() in flush tlb path to x2apic specific paths. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: "steiner@sgi.com" <steiner@sgi.com> Cc: Nick Piggin <npiggin@suse.de> LKML-Reference: <1237313814.27006.203.camel@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-17x86, apic: remove duplicate asm/apic.h inclusionsIngo Molnar
Impact: cleanup Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-17x86, apic: remove genapic.hIngo Molnar
Impact: cleanup Remove genapic.h and remove all references to it. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-29x86, smp: remove mach_ipi.hIngo Molnar
Move mach_ipi.h definitions into genapic.h. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-28x86, apic: untangle the send_IPI_*() jungleIngo Molnar
Our send_IPI_*() methods and definitions are a twisted mess: the same symbol is defined to different things depending on .config details, in a non-transparent way. - spread out the quirks into separately named per apic driver methods - prefix the standard PC methods with default_ - get rid of wrapper macro obfuscation - clean up various details Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-21Merge branch 'x86/mm' into core/percpuIngo Molnar
Conflicts: arch/x86/mm/fault.c
2009-01-21x86, mm: move tlb.c to arch/x86/mm/Ingo Molnar
Impact: cleanup Now that it's unified, move the (SMP) TLB flushing code from arch/x86/kernel/ to arch/x86/mm/, where it belongs logically. Signed-off-by: Ingo Molnar <mingo@elte.hu>
