path: root/arch/x86/mm/pgtable.c
2011-03-18x86: Flush TLB if PGD entry is changed in i386 PAE modeShaohua Li
According to intel CPU manual, every time PGD entry is changed in i386 PAE mode, we need do a full TLB flush. Current code follows this and there is comment for this too in the code. But current code misses the multi-threaded case. A changed page table might be used by several CPUs, every such CPU should flush TLB. Usually this isn't a problem, because we prepopulate all PGD entries at process fork. But when the process does munmap and follows new mmap, this issue will be triggered. When it happens, some CPUs keep doing page faults: http://marc.info/?l=linux-kernel&m=129915020508238&w=2 Reported-by: Yasunori Goto<y-goto@jp.fujitsu.com> Tested-by: Yasunori Goto<y-goto@jp.fujitsu.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Shaohua Li<shaohua.li@intel.com> Cc: Mallick Asit K <asit.k.mallick@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-mm <linux-mm@kvack.org> Cc: stable <stable@kernel.org> LKML-Reference: <1300246649.2337.95.camel@sli10-conroe> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-10x86/mm: Fix pgd_lock deadlockAndrea Arcangeli
It's forbidden to take the page_table_lock with the irq disabled or if there's contention the IPIs (for tlb flushes) sent with the page_table_lock held will never run leading to a deadlock. Nobody takes the pgd_lock from irq context so the _irqsave can be removed. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@kernel.org> LKML-Reference: <201102162345.p1GNjMjm021738@imap1.linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-13thp: add x86 32bit supportJohannes Weiner
Add support for transparent hugepages to x86 32bit. Share the same VM_ bitflag for VM_MAPPED_COPY. mm/nommu.c will never support transparent hugepages. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: add pmd mangling functions to x86Andrea Arcangeli
Add needed pmd mangling functions with symmetry with their pte counterparts. pmdp_splitting_flush() is the only new addition on the pmd_ methods and it's needed to serialize the VM against split_huge_page. It simply atomically sets the splitting bit in a similar way pmdp_clear_flush_young atomically clears the accessed bit. pmdp_splitting_flush() also has to flush the tlb to make it effective against gup_fast, but it wouldn't really require to flush the tlb too. Just the tlb flush is the simplest operation we can invoke to serialize pmdp_splitting_flush() against gup_fast. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-21Merge branch 'x86-vmware-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-vmware-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, paravirt: Remove alloc_pmd_clone hook, only used by VMI x86, vmware: Remove deprecated VMI kernel support Fix up trivial #include conflict in arch/x86/kernel/smpboot.c
2010-10-19x86, mm: Hold mm->page_table_lock while doing vmalloc_syncJeremy Fitzhardinge
Take mm->page_table_lock while syncing the vmalloc region. This prevents a race with the Xen pagetable pin/unpin code, which expects that the page_table_lock is already held. If this race occurs, then Xen can see an inconsistent page type (a page can either be read/write or a pagetable page, and pin/unpin converts it between them), which will cause either the pin or the set_p[gm]d to fail; either will crash the kernel. vmalloc_sync_all() should be called rarely, so this extra use of page_table_lock should not interfere with its normal users. The mm pointer is stashed in the pgd page's index field, as that won't be otherwise used for pgds. Reported-by: Ian Campbell <ian.cambell@eu.citrix.com> Originally-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <4CB88A4C.1080305@goop.org> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-08-23x86, paravirt: Remove alloc_pmd_clone hook, only used by VMIAlok Kataria
VMI was the only user of the alloc_pmd_clone hook, given that VMI is now removed we can also remove this hook. Signed-off-by: Alok N Kataria <akataria@vmware.com> LKML-Reference: <1282608357.19396.36.camel@ank32.eng.vmware.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-25x86, mm: Allow highmem user page tables to be disabled at boot timeIan Campbell
Distros generally (I looked at Debian, RHEL5 and SLES11) seem to enable CONFIG_HIGHPTE for any x86 configuration which has highmem enabled. This means that the overhead applies even to machines which have a fairly modest amount of high memory and which therefore do not really benefit from allocating PTEs in high memory but still pay the price of the additional mapping operations. Running kernbench on a 4G box I found that with CONFIG_HIGHPTE=y but no actual highptes being allocated there was a reduction in system time used from 59.737s to 55.9s. With CONFIG_HIGHPTE=y and highmem PTEs being allocated: Average Optimal load -j 4 Run (std deviation): Elapsed Time 175.396 (0.238914) User Time 515.983 (5.85019) System Time 59.737 (1.26727) Percent CPU 263.8 (71.6796) Context Switches 39989.7 (4672.64) Sleeps 42617.7 (246.307) With CONFIG_HIGHPTE=y but with no highmem PTEs being allocated: Average Optimal load -j 4 Run (std deviation): Elapsed Time 174.278 (0.831968) User Time 515.659 (6.07012) System Time 55.9 (1.07799) Percent CPU 263.8 (71.266) Context Switches 39929.6 (4485.13) Sleeps 42583.7 (373.039) This patch allows the user to control the allocation of PTEs in highmem from the command line ("userpte=nohigh") but retains the status-quo as the default. It is possible that some simple heuristic could be developed which allows auto-tuning of this option however I don't have a sufficiently large machine available to me to perform any particularly meaningful experiments. We could probably handwave up an argument for a threshold at 16G of total RAM. Assuming 768M of lowmem we have 196608 potential lowmem PTE pages. Each page can map 2M of RAM in a PAE-enabled configuration, meaning a maximum of 384G of RAM could potentially be mapped using lowmem PTEs. Even allowing generous factor of 10 to account for other required lowmem allocations, generous slop to account for page sharing (which reduces the total amount of RAM mappable by a given number of PT pages) and other innacuracies in the estimations it would seem that even a 32G machine would not have a particularly pressing need for highmem PTEs. I think 32G could be considered to be at the upper bound of what might be sensible on a 32 bit machine (although I think in practice 64G is still supported). It's seems questionable if HIGHPTE is even a win for any amount of RAM you would sensibly run a 32 bit kernel on rather than going 64 bit. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> LKML-Reference: <1266403090-20162-1-git-send-email-ian.campbell@citrix.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-08-04x86, 32-bit: Fix double accounting in reserve_top_address()Jan Beulich
With VMALLOC_END included in the calculation of MAXMEM (as of 2.6.28) it is no longer correct to also bump __VMALLOC_RESERVE in reserve_top_address(). Doing so results in needlessly small lowmem. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <4A71DD2A020000780000D482@vpn.id2.novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-27mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()Benjamin Herrenschmidt
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb() Upcoming paches to support the new 64-bit "BookE" powerpc architecture will need to have the virtual address corresponding to PTE page when freeing it, due to the way the HW table walker works. Basically, the TLB can be loaded with "large" pages that cover the whole virtual space (well, sort-of, half of it actually) represented by a PTE page, and which contain an "indirect" bit indicating that this TLB entry RPN points to an array of PTEs from which the TLB can then create direct entries. Thus, in order to invalidate those when PTE pages are deleted, we need the virtual address to pass to tlbilx or tlbivax instructions. The old trick of sticking it somewhere in the PTE page struct page sucks too much, the address is almost readily available in all call sites and almost everybody implemets these as macros, so we may as well add the argument everywhere. I added it to the pmd and pud variants for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV] Acked-by: Nick Piggin <npiggin@suse.de> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15kmemcheck: don't track page tablesVegard Nossum
As these are allocated using the page allocator, we need to pass __GFP_NOTRACK before we add page allocator support to kmemcheck. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-04-09x86: fix set_fixmap to use phys_addr_tMasami Hiramatsu
Use phys_addr_t for receiving a physical address argument instead of unsigned long. This allows fixmap to handle pages higher than 4GB on x86-32. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-27x86, fixmap: define reserve_top_address for x86_64Gustavo F. Padovan
Impact: new interface (not yet use) Define reserve_top_address for x86_64; only for later x86 integration. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Acked-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-09-06x86: pgd_{c,d}tor() cleanupJan Beulich
Giving pgd_ctor() a properly typed parameter allows eliminating a local variable. Adjust pgd_dtor() to match. Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: "Jeremy Fitzhardinge" <jeremy@goop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-11x86: work around gcc 3.4.x bugJeremy Fitzhardinge
Simon Horman reported that gcc-3.4.x crashes when compiling pgd_prepopulate_pmd() when PREALLOCATED_PMDS == 0 and CONFIG_DEBUG_INFO is enabled. Adding an extra check for PREALLOCATED_PMDS == 0 [which is compiled out by gcc] seems to avoid the problem. Reported-by: Simon Horman <horms@verge.net.au> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: preallocate and prepopulate separatelyJeremy Fitzhardinge
Jan Beulich points out that vmalloc_sync_all() assumes that the kernel's pmd is always expected to be present in the pgd. The current pgd construction code will add the pgd to the pgd_list before its pmds have been pre-populated, thereby making it visible to vmalloc_sync_all(). However, because pgd_prepopulate_pmd also does the allocation, it may block and cannot be done under spinlock. The solution is to preallocate the pmds out of the spinlock, then populate them while holding the pgd_list lock. This patch also pulls the pmd preallocation and mop-up functions out to be common, assuming that the compiler will generate no code for them when PREALLOCTED_PMDS is 0. Also, there's no need for pgd_ctor to clear the pgd again, since it's allocated as a zeroed page. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: xen-devel <xen-devel@lists.xensource.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Jan Beulich <jbeulich@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86/paravirt: add a pgd_alloc/free hooksJeremy Fitzhardinge
Add hooks which are called at pgd_alloc/free time. The pgd_alloc hook may return an error code, which if non-zero, causes the pgd allocation to be failed. The hooks may be used to allocate/free auxillary per-pgd information. also fix: > * Ingo Molnar <mingo@elte.hu> wrote: > > include/asm/pgalloc.h: In function ‘paravirt_pgd_free': > include/asm/pgalloc.h:14: error: parameter name omitted > arch/x86/kernel/entry_64.S: In file included from > arch/x86/kernel/traps_64.c:51:include/asm/pgalloc.h: In function ‘paravirt_pgd_free': > include/asm/pgalloc.h:14: error: parameter name omitted Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: xen-devel <xen-devel@lists.xensource.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08Merge branch 'x86/fixmap' into x86/develIngo Molnar
Conflicts: arch/x86/mm/init_64.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-20x86: unify __set_fixmap, fixIngo Molnar
fix build failure: arch/x86/mm/pgtable.c:280: warning: ‘enum fixed_addresses’ declared inside parameter list arch/x86/mm/pgtable.c:280: warning: its scope is only this definition or declaration, which is probably not what you want arch/x86/mm/pgtable.c:280: error: parameter 1 (‘idx’) has incomplete type Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-20x86/paravirt/xen: add set_fixmap pv_mmu_opsJeremy Fitzhardinge
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Juan Quintela <quintela@redhat.com> Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-20x86: implement set_pte_vaddrJeremy Fitzhardinge
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-20x86: unify __set_fixmapJeremy Fitzhardinge
In both cases, I went with the 32-bit behaviour. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-25x86: fixup the fallout of the bitops changesThomas Gleixner
2008-04-24x86: unify pgd ctor/dtorJeremy Fitzhardinge
All pagetables need fundamentally the same setup and destruction, so just use the same code for everything. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24x86: unify KERNEL_PGD_PTRSJeremy Fitzhardinge
Make KERNEL_PGD_PTRS common, as previously it was only being defined for 32-bit. There are a couple of follow-on changes from this: - KERNEL_PGD_PTRS was being defined in terms of USER_PGD_PTRS. The definition of USER_PGD_PTRS doesn't really make much sense on x86-64, since it can have two different user address-space configurations. I renamed USER_PGD_PTRS to KERNEL_PGD_BOUNDARY, which is meaningful for all of 32/32, 32/64 and 64/64 process configurations. - USER_PTRS_PER_PGD was also defined and was being used for similar purposes. Converting its users to KERNEL_PGD_BOUNDARY left it completely unused, and so I removed it. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Andi Kleen <ak@suse.de> Cc: Zach Amsden <zach@vmware.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24x86/pgtable.h: demacro ptep_clear_flush_youngJeremy Fitzhardinge
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24x86/pgtable.h: demacro ptep_test_and_clear_youngJeremy Fitzhardinge
2008-04-24x86/pgtable.h: demacro ptep_set_access_flagsJeremy Fitzhardinge
2008-04-24x86: add pud_alloc for 4-level pagetablesJeremy Fitzhardinge
2008-04-24x86: rename paravirt_alloc_pt etc after the pagetable structureJeremy Fitzhardinge
Rename (alloc|release)_(pt|pd) to pte/pmd to explicitly match the name of the appropriate pagetable level structure. [ x86.git merge work by Mark McLoughlin <markmc@redhat.com> ] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24x86: move all the pgd_list handling to one placeJeremy Fitzhardinge
2008-04-24x86: move pgalloc pud and pgd operations into common placeJeremy Fitzhardinge
2008-04-24x86: move pmd functions into common asm/pgalloc.hJeremy Fitzhardinge
Common definitions for 3-level pagetable functions. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24x86: move pte functions into common asm/pgalloc.hJeremy Fitzhardinge
Common definitions for 2-level pagetable functions. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24x86: xen unify x86 add common mm pgtable c fixIngo Molnar
2008-04-24x86: add common mm/pgtable.cJeremy Fitzhardinge
Add a common arch/x86/mm/pgtable.c file for common pagetable functions. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
