path: root/arch/x86/mm/numa.c
2010-05-31x86/mm: Remove unused DBG() macroAkinobu Mita
DBG() macro for CONFIG_DEBUG_PER_CPU_MAPS is unused. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> LKML-Reference: <1274706291-13554-1-git-send-email-akinobu.mita@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-30Revert "cpusets: randomize node rotor used in cpuset_mem_spread_node()"Linus Torvalds
This reverts commit 0ac0c0d0f837c499afd02a802f9cf52d3027fa3b, which caused cross-architecture build problems for all the wrong reasons. IA64 already added its own version of __node_random(), but the fact is, there is nothing architectural about the function, and the original commit was just badly done. Revert it, since no fix is forthcoming. Requested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cpusets: randomize node rotor used in cpuset_mem_spread_node()Jack Steiner
Some workloads that create a large number of small files tend to assign too many pages to node 0 (multi-node systems). Part of the reason is that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts at node 0 for newly created tasks. This patch changes the rotor to be initialized to a random node number of the cpuset. [akpm@linux-foundation.org: fix layout] [Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration] Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-13cpumask: convert node_to_cpumask_map[] to cpumask_var_tRusty Russell
Impact: fix (CONFIG_MAXSMP=y only) boot crash c032ef60d1aa9af33730b7a35bbea751b131adc1 "cpumask: convert node_to_cpumask_map[] to cpumask_var_t" didn't get this one conversion. There was a compile warning, but I missed it. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Mike Travis <travis@sgi.com> LKML-Reference: <200903132342.42813.rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13cpumask: remove x86 cpumask_t uses.Rusty Russell
Impact: cleanup We are removing cpumask_t in favour of struct cpumask: mainly as a marker of what code is now CONFIG_CPUMASK_OFFSTACK-safe. The only non-trivial change here is vector_allocation_domain(): explicitly clear the mask and set the first word, rather than using assignment. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
Impact: reduce kernel memory usage when CONFIG_CPUMASK_OFFSTACK=y Straightforward conversion: done for 32 and 64 bit kernels. node_to_cpumask_map is now a cpumask_var_t array. 64-bit used to be a dynamic cpumask_t array, and 32-bit used to be a static cpumask_t array. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-03-13x86: unify 32 and 64-bit node_to_cpumask_mapRusty Russell
Impact: cleanup We take the 64-bit code and use it on 32-bit as well. The new file is called mm/numa.c. In a minor cleanup, we use cpu_none_mask instead of declaring a local cpu_mask_none. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
