path: root/arch/x86/mm/fault.c
2016-03-20Merge branch 'mm-pkeys-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 protection key support from Ingo Molnar: "This tree adds support for a new memory protection hardware feature that is available in upcoming Intel CPUs: 'protection keys' (pkeys). There's a background article at LWN.net: https://lwn.net/Articles/643797/ The gist is that protection keys allow the encoding of user-controllable permission masks in the pte. So instead of having a fixed protection mask in the pte (which needs a system call to change and works on a per page basis), the user can map a (handful of) protection mask variants and can change the masks runtime relatively cheaply, without having to change every single page in the affected virtual memory range. This allows the dynamic switching of the protection bits of large amounts of virtual memory, via user-space instructions. It also allows more precise control of MMU permission bits: for example the executable bit is separate from the read bit (see more about that below). This tree adds the MM infrastructure and low level x86 glue needed for that, plus it adds a high level API to make use of protection keys - if a user-space application calls: mmap(..., PROT_EXEC); or mprotect(ptr, sz, PROT_EXEC); (note PROT_EXEC-only, without PROT_READ/WRITE), the kernel will notice this special case, and will set a special protection key on this memory range. It also sets the appropriate bits in the Protection Keys User Rights (PKRU) register so that the memory becomes unreadable and unwritable. So using protection keys the kernel is able to implement 'true' PROT_EXEC on x86 CPUs: without protection keys PROT_EXEC implies PROT_READ as well. Unreadable executable mappings have security advantages: they cannot be read via information leaks to figure out ASLR details, nor can they be scanned for ROP gadgets - and they cannot be used by exploits for data purposes either. We know about no user-space code that relies on pure PROT_EXEC mappings today, but binary loaders could start making use of this new feature to map binaries and libraries in a more secure fashion. There is other pending pkeys work that offers more high level system call APIs to manage protection keys - but those are not part of this pull request. Right now there's a Kconfig that controls this feature (CONFIG_X86_INTEL_MEMORY_PROTECTION_KEYS) that is default enabled (like most x86 CPU feature enablement code that has no runtime overhead), but it's not user-configurable at the moment. If there's any serious problem with this then we can make it configurable and/or flip the default" * 'mm-pkeys-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (38 commits) x86/mm/pkeys: Fix mismerge of protection keys CPUID bits mm/pkeys: Fix siginfo ABI breakage caused by new u64 field x86/mm/pkeys: Fix access_error() denial of writes to write-only VMA mm/core, x86/mm/pkeys: Add execute-only protection keys support x86/mm/pkeys: Create an x86 arch_calc_vm_prot_bits() for VMA flags x86/mm/pkeys: Allow kernel to modify user pkey rights register x86/fpu: Allow setting of XSAVE state x86/mm: Factor out LDT init from context init mm/core, x86/mm/pkeys: Add arch_validate_pkey() mm/core, arch, powerpc: Pass a protection key in to calc_vm_flag_bits() x86/mm/pkeys: Actually enable Memory Protection Keys in the CPU x86/mm/pkeys: Add Kconfig prompt to existing config option x86/mm/pkeys: Dump pkey from VMA in /proc/pid/smaps x86/mm/pkeys: Dump PKRU with other kernel registers mm/core, x86/mm/pkeys: Differentiate instruction fetches x86/mm/pkeys: Optimize fault handling in access_error() mm/core: Do not enforce PKEY permissions on remote mm access um, pkeys: Add UML arch_*_access_permitted() methods mm/gup, x86/mm/pkeys: Check VMAs and PTEs for protection keys x86/mm/gup: Simplify get_user_pages() PTE bit handling ...
2016-03-08Merge branch 'linus' into ras/core, to pick up fixesIngo Molnar
2016-03-03x86/mm/pkeys: Fix access_error() denial of writes to write-only VMADave Hansen
Andrey Wagin reported that a simple test case was broken by: 2b5f7d013fc ("mm/core, x86/mm/pkeys: Add execute-only protection keys support") This test case creates an unreadable VMA and my patch assumed that all writes must be to readable VMAs. The simplest fix for this is to remove the pkey-related bits in access_error(). For execute-only support, I believe the existing version is sufficient because the permissions we are trying to enforce are entirely expressed in vma->vm_flags. We just depend on pkeys to get *an* exception, it does not matter that PF_PK was set, or even what state PKRU is in. I will re-add the necessary bits with the full pkeys implementation that includes the new syscalls. The three cases that matter are: 1. If a write to an execute-only VMA occurs, we will see PF_WRITE set, but !VM_WRITE on the VMA, and return 1. All execute-only VMAs have VM_WRITE clear by definition. 2. If a read occurs on a present PTE, we will fall in to the "read, present" case and return 1. 3. If a read occurs to a non-present PTE, we will miss the "read, not present" case, because the execute-only VMA will have VM_EXEC set, and we will properly return 0 allowing the PTE to be populated. Test program: int main() { int *p; p = mmap(NULL, 4096, PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS, -1, 0); p[0] = 1; return 0; } Reported-by: Andrey Wagin <avagin@gmail.com>, Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Dave Hansen <dave@sr71.net> Cc: Kirill A. Shutemov <kirill@shutemov.name> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mm@kvack.org Cc: linux-next@vger.kernel.org Fixes: 62b5f7d013fc ("mm/core, x86/mm/pkeys: Add execute-only protection keys support") Link: http://lkml.kernel.org/r/20160301194133.65D0110C@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-18mm/core, x86/mm/pkeys: Add execute-only protection keys supportDave Hansen
Protection keys provide new page-based protection in hardware. But, they have an interesting attribute: they only affect data accesses and never affect instruction fetches. That means that if we set up some memory which is set as "access-disabled" via protection keys, we can still execute from it. This patch uses protection keys to set up mappings to do just that. If a user calls: mmap(..., PROT_EXEC); or mprotect(ptr, sz, PROT_EXEC); (note PROT_EXEC-only without PROT_READ/WRITE), the kernel will notice this, and set a special protection key on the memory. It also sets the appropriate bits in the Protection Keys User Rights (PKRU) register so that the memory becomes unreadable and unwritable. I haven't found any userspace that does this today. With this facility in place, we expect userspace to move to use it eventually. Userspace _could_ start doing this today. Any PROT_EXEC calls get converted to PROT_READ inside the kernel, and would transparently be upgraded to "true" PROT_EXEC with this code. IOW, userspace never has to do any PROT_EXEC runtime detection. This feature provides enhanced protection against leaking executable memory contents. This helps thwart attacks which are attempting to find ROP gadgets on the fly. But, the security provided by this approach is not comprehensive. The PKRU register which controls access permissions is a normal user register writable from unprivileged userspace. An attacker who can execute the 'wrpkru' instruction can easily disable the protection provided by this feature. The protection key that is used for execute-only support is permanently dedicated at compile time. This is fine for now because there is currently no API to set a protection key other than this one. Despite there being a constant PKRU value across the entire system, we do not set it unless this feature is in use in a process. That is to preserve the PKRU XSAVE 'init state', which can lead to faster context switches. PKRU *is* a user register and the kernel is modifying it. That means that code doing: pkru = rdpkru() pkru |= 0x100; mmap(..., PROT_EXEC); wrpkru(pkru); could lose the bits in PKRU that enforce execute-only permissions. To avoid this, we suggest avoiding ever calling mmap() or mprotect() when the PKRU value is expected to be unstable. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Chen Gang <gang.chen.5i5j@gmail.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Dave Hansen <dave@sr71.net> Cc: David Hildenbrand <dahi@linux.vnet.ibm.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Piotr Kwapulinski <kwapulinski.piotr@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Vladimir Murzin <vladimir.murzin@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: keescook@google.com Cc: linux-kernel@vger.kernel.org Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20160212210240.CB4BB5CA@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-18mm/core, x86/mm/pkeys: Differentiate instruction fetchesDave Hansen
As discussed earlier, we attempt to enforce protection keys in software. However, the code checks all faults to ensure that they are not violating protection key permissions. It was assumed that all faults are either write faults where we check PKRU[key].WD (write disable) or read faults where we check the AD (access disable) bit. But, there is a third category of faults for protection keys: instruction faults. Instruction faults never run afoul of protection keys because they do not affect instruction fetches. So, plumb the PF_INSTR bit down in to the arch_vma_access_permitted() function where we do the protection key checks. We also add a new FAULT_FLAG_INSTRUCTION. This is because handle_mm_fault() is not passed the architecture-specific error_code where we keep PF_INSTR, so we need to encode the instruction fetch information in to the arch-generic fault flags. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20160212210224.96928009@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-18x86/mm/pkeys: Optimize fault handling in access_error()Dave Hansen
We might not strictly have to make modifictions to access_error() to check the VMA here. If we do not, we will do this: 1. app sets VMA pkey to K 2. app touches a !present page 3. do_page_fault(), allocates and maps page, sets pte.pkey=K 4. return to userspace 5. touch instruction reexecutes, but triggers PF_PK 6. do PKEY signal What happens with this patch applied: 1. app sets VMA pkey to K 2. app touches a !present page 3. do_page_fault() notices that K is inaccessible 4. do PKEY signal We basically skip the fault that does an allocation. So what this lets us do is protect areas from even being *populated* unless it is accessible according to protection keys. That seems handy to me and makes protection keys work more like an mprotect()'d mapping. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20160212210222.EBB63D8C@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-18mm/gup, x86/mm/pkeys: Check VMAs and PTEs for protection keysDave Hansen
Today, for normal faults and page table walks, we check the VMA and/or PTE to ensure that it is compatible with the action. For instance, if we get a write fault on a non-writeable VMA, we SIGSEGV. We try to do the same thing for protection keys. Basically, we try to make sure that if a user does this: mprotect(ptr, size, PROT_NONE); *ptr = foo; they see the same effects with protection keys when they do this: mprotect(ptr, size, PROT_READ|PROT_WRITE); set_pkey(ptr, size, 4); wrpkru(0xffffff3f); // access disable pkey 4 *ptr = foo; The state to do that checking is in the VMA, but we also sometimes have to do it on the page tables only, like when doing a get_user_pages_fast() where we have no VMA. We add two functions and expose them to generic code: arch_pte_access_permitted(pte_flags, write) arch_vma_access_permitted(vma, write) These are, of course, backed up in x86 arch code with checks against the PTE or VMA's protection key. But, there are also cases where we do not want to respect protection keys. When we ptrace(), for instance, we do not want to apply the tracer's PKRU permissions to the PTEs from the process being traced. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Alexey Kardashevskiy <aik@ozlabs.ru> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Dave Hansen <dave@sr71.net> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: David Hildenbrand <dahi@linux.vnet.ibm.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Dominik Dingel <dingel@linux.vnet.ibm.com> Cc: Dominik Vogt <vogt@linux.vnet.ibm.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jason Low <jason.low2@hp.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Laurent Dufour <ldufour@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Hocko <mhocko@suse.com> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Shachar Raindel <raindel@mellanox.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Toshi Kani <toshi.kani@hpe.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: linux-mm@kvack.org Cc: linux-s390@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/20160212210219.14D5D715@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-18x86/mm/pkeys: Fill in pkey field in siginfoDave Hansen
This fills in the new siginfo field: si_pkey to indicate to userspace which protection key was set on the PTE that we faulted on. Note though that *ALL* protection key faults have to be generated by a valid, present PTE at some point. But this code does no PTE lookups which seeds odd. The reason is that we take advantage of the way we generate PTEs from VMAs. All PTEs under a VMA share some attributes. For instance, they are _all_ either PROT_READ *OR* PROT_NONE. They also always share a protection key, so we never have to walk the page tables; we just use the VMA. Note that _pkey is a 64-bit value. The current hardware only supports 4-bit protection keys. We do this because there is _plenty_ of space in _sigfault and it is possible that future processors would support more than 4 bits of protection keys. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20160212210213.ABC488FA@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-18x86/mm/pkeys: Pass VMA down in to fault signal generation codeDave Hansen
During a page fault, we look up the VMA to ensure that the fault is in a region with a valid mapping. But, in the top-level page fault code we don't need the VMA for much else. Once we have decided that an access is bad, we are going to send a signal no matter what and do not need the VMA any more. So we do not pass it down in to the signal generation code. But, for protection keys, we need the VMA. It tells us *which* protection key we violated if we get a PF_PK. So, we need to pass the VMA down and fill in siginfo->si_pkey. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20160212210211.AD3B36A3@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-18x86/mm/pkeys: Add new 'PF_PK' page fault error code bitDave Hansen
Note: "PK" is how the Intel SDM refers to this bit, so we also use that nomenclature. This only defines the bit, it does not plumb it anywhere to be handled. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20160212210207.DA7B43E6@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-18x86/mm: Expand the exception table logic to allow new handling optionsTony Luck
Huge amounts of help from Andy Lutomirski and Borislav Petkov to produce this. Andy provided the inspiration to add classes to the exception table with a clever bit-squeezing trick, Boris pointed out how much cleaner it would all be if we just had a new field. Linus Torvalds blessed the expansion with: ' I'd rather not be clever in order to save just a tiny amount of space in the exception table, which isn't really criticial for anybody. ' The third field is another relative function pointer, this one to a handler that executes the actions. We start out with three handlers: 1: Legacy - just jumps the to fixup IP 2: Fault - provide the trap number in %ax to the fixup code 3: Cleaned up legacy for the uaccess error hack Signed-off-by: Tony Luck <tony.luck@intel.com> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-02-18x86/mm: Fix vmalloc_fault() to handle large pages properlyToshi Kani
A kernel page fault oops with the callstack below was observed when a read syscall was made to a pmem device after a huge amount (>512GB) of vmalloc ranges was allocated by ioremap() on a x86_64 system: BUG: unable to handle kernel paging request at ffff880840000ff8 IP: vmalloc_fault+0x1be/0x300 PGD c7f03a067 PUD 0 Oops: 0000 [#1] SM Call Trace: __do_page_fault+0x285/0x3e0 do_page_fault+0x2f/0x80 ? put_prev_entity+0x35/0x7a0 page_fault+0x28/0x30 ? memcpy_erms+0x6/0x10 ? schedule+0x35/0x80 ? pmem_rw_bytes+0x6a/0x190 [nd_pmem] ? schedule_timeout+0x183/0x240 btt_log_read+0x63/0x140 [nd_btt] : ? __symbol_put+0x60/0x60 ? kernel_read+0x50/0x80 SyS_finit_module+0xb9/0xf0 entry_SYSCALL_64_fastpath+0x1a/0xa4 Since v4.1, ioremap() supports large page (pud/pmd) mappings in x86_64 and PAE. vmalloc_fault() however assumes that the vmalloc range is limited to pte mappings. vmalloc faults do not normally happen in ioremap'd ranges since ioremap() sets up the kernel page tables, which are shared by user processes. pgd_ctor() sets the kernel's PGD entries to user's during fork(). When allocation of the vmalloc ranges crosses a 512GB boundary, ioremap() allocates a new pud table and updates the kernel PGD entry to point it. If user process's PGD entry does not have this update yet, a read/write syscall to the range will cause a vmalloc fault, which hits the Oops above as it does not handle a large page properly. Following changes are made to vmalloc_fault(). 64-bit: - No change for the PGD sync operation as it handles large pages already. - Add pud_huge() and pmd_huge() to the validation code to handle large pages. - Change pud_page_vaddr() to pud_pfn() since an ioremap range is not directly mapped (while the if-statement still works with a bogus addr). - Change pmd_page() to pmd_pfn() since an ioremap range is not backed by struct page (while the if-statement still works with a bogus addr). 32-bit: - No change for the sync operation since the index3 PGD entry covers the entire vmalloc range, which is always valid. (A separate change to sync PGD entry is necessary if this memory layout is changed regardless of the page size.) - Add pmd_huge() to the validation code to handle large pages. This is for completeness since vmalloc_fault() won't happen in ioremap'd ranges as its PGD entry is always valid. Reported-by: Henning Schild <henning.schild@siemens.com> Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Acked-by: Borislav Petkov <bp@alien8.de> Cc: <stable@vger.kernel.org> # 4.1+ Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: linux-mm@kvack.org Cc: linux-nvdimm@lists.01.org Link: http://lkml.kernel.org/r/1455758214-24623-1-git-send-email-toshi.kani@hpe.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-31x86/vm86: Clean up vm86.h includesBrian Gerst
vm86.h was being implicitly included in alot of places via processor.h, which in turn got it from math_emu.h. Break that chain and explicitly include vm86.h in all files that need it. Also remove unused vm86 field from math_emu_info. Signed-off-by: Brian Gerst <brgerst@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1438148483-11932-7-git-send-email-brgerst@gmail.com [ Fixed build failure. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-31x86/vm86: Move vm86 fields out of 'thread_struct'Brian Gerst
Allocate a separate structure for the vm86 fields. Signed-off-by: Brian Gerst <brgerst@gmail.com> Acked-by: Andy Lutomirski <luto@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1438148483-11932-2-git-send-email-brgerst@gmail.com [ Build fixes. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19mm/fault, arch: Use pagefault_disable() to check for disabled pagefaults in ↵David Hildenbrand
the handler Introduce faulthandler_disabled() and use it to check for irq context and disabled pagefaults (via pagefault_disable()) in the pagefault handlers. Please note that we keep the in_atomic() checks in place - to detect whether in irq context (in which case preemption is always properly disabled). In contrast, preempt_disable() should never be used to disable pagefaults. With !CONFIG_PREEMPT_COUNT, preempt_disable() doesn't modify the preempt counter, and therefore the result of in_atomic() differs. We validate that condition by using might_fault() checks when calling might_sleep(). Therefore, add a comment to faulthandler_disabled(), describing why this is needed. faulthandler_disabled() and pagefault_disable() are defined in linux/uaccess.h, so let's properly add that include to all relevant files. This patch is based on a patch from Thomas Gleixner. Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: David.Laight@ACULAB.COM Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: airlied@linux.ie Cc: akpm@linux-foundation.org Cc: benh@kernel.crashing.org Cc: bigeasy@linutronix.de Cc: borntraeger@de.ibm.com Cc: daniel.vetter@intel.com Cc: heiko.carstens@de.ibm.com Cc: herbert@gondor.apana.org.au Cc: hocko@suse.cz Cc: hughd@google.com Cc: mst@redhat.com Cc: paulus@samba.org Cc: ralf@linux-mips.org Cc: schwidefsky@de.ibm.com Cc: yang.shi@windriver.com Link: http://lkml.kernel.org/r/1431359540-32227-7-git-send-email-dahi@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-03-23x86/asm/entry: Change all 'user_mode_vm()' calls to 'user_mode()'Andy Lutomirski
user_mode_vm() and user_mode() are now the same. Change all callers of user_mode_vm() to user_mode(). The next patch will remove the definition of user_mode_vm. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brad Spengler <spender@grsecurity.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/43b1f57f3df70df5a08b0925897c660725015554.1426728647.git.luto@kernel.org [ Merged to a more recent kernel. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-03-23x86/mm/fault: Use TASK_SIZE_MAX in is_prefetch()Andy Lutomirski
This is slightly shorter and slightly faster. It's also more correct: the split between user and kernel addresses is TASK_SIZE_MAX, regardless of ti->flags. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brad Spengler <spender@grsecurity.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/09156b63bad90a327827003c9e53faa82ef4c56e.1426728647.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-02-04x86: Store a per-cpu shadow copy of CR4Andy Lutomirski
Context switches and TLB flushes can change individual bits of CR4. CR4 reads take several cycles, so store a shadow copy of CR4 in a per-cpu variable. To avoid wasting a cache line, I added the CR4 shadow to cpu_tlbstate, which is already touched in switch_mm. The heaviest users of the cr4 shadow will be switch_mm and __switch_to_xtra, and __switch_to_xtra is called shortly after switch_mm during context switch, so the cacheline is likely to be hot. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Kees Cook <keescook@chromium.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Vince Weaver <vince@deater.net> Cc: "hillf.zj" <hillf.zj@alibaba-inc.com> Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/3a54dd3353fffbf84804398e00dfdc5b7c1afd7d.1414190806.git.luto@amacapital.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-01-29vm: add VM_FAULT_SIGSEGV handling supportLinus Torvalds
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a "you should SIGSEGV" error, because the SIGSEGV case was generally handled by the caller - usually the architecture fault handler. That results in lots of duplication - all the architecture fault handlers end up doing very similar "look up vma, check permissions, do retries etc" - but it generally works. However, there are cases where the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV. In particular, when accessing the stack guard page, libsigsegv expects a SIGSEGV. And it usually got one, because the stack growth is handled by that duplicated architecture fault handler. However, when the generic VM layer started propagating the error return from the stack expansion in commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page"), that now exposed the existing VM_FAULT_SIGBUS result to user space. And user space really expected SIGSEGV, not SIGBUS. To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those duplicate architecture fault handlers about it. They all already have the code to handle SIGSEGV, so it's about just tying that new return value to the existing code, but it's all a bit annoying. This is the mindless minimal patch to do this. A more extensive patch would be to try to gather up the mostly shared fault handling logic into one generic helper routine, and long-term we really should do that cleanup. Just from this patch, you can generally see that most architectures just copied (directly or indirectly) the old x86 way of doing things, but in the meantime that original x86 model has been improved to hold the VM semaphore for shorter times etc and to handle VM_FAULT_RETRY and other "newer" things, so it would be a good idea to bring all those improvements to the generic case and teach other architectures about them too. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-17x86: mm: fix VM_FAULT_RETRY handlingLinus Torvalds
My commit 26178ec11ef3 ("x86: mm: consolidate VM_FAULT_RETRY handling") had a really stupid typo: the FAULT_FLAG_USER bit is in the 'flags' variable, not the 'fault' variable. Duh, The one silver lining in this is that Dave finding this at least confirms that trinity actually triggers this special path easily, in a way normal use does not. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-15x86: mm: consolidate VM_FAULT_RETRY handlingLinus Torvalds
The VM_FAULT_RETRY handling was confusing and incorrect for the case of returning to kernel mode. We need to handle the exception table fixup if we return to kernel mode due to a fatal signal - it will basically look to the kernel user mode access like the access failed due to the VM going away from udner it. Which is correct - the process is dying - and avoids the whole "repeat endless kernel page faults" case. Handling the VM_FAULT_RETRY early and in just one place also simplifies the mmap_sem handling, since once we've taken care of VM_FAULT_RETRY we know that we can just drop the lock. The remaining accounting and possible error handling is thread-local and does not need the mmap_sem. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-15x86: mm: move mmap_sem unlock from mm_fault_error() to callerLinus Torvalds
This replaces four copies in various stages of mm_fault_error() handling with just a single one. It will also allow for more natural placement of the unlocking after some further cleanup. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm updates from Ingo Molnar: "This tree includes the following changes: - fix memory hotplug - fix hibernation bootup memory layout assumptions - fix hyperv numa guest kernel messages - remove dead code - update documentation" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mm: Update memory map description to list hypervisor-reserved area x86/mm, hibernate: Do not assume the first e820 area to be RAM x86/mm/numa: Drop dead code and rename setup_node_data() to setup_alloc_data() x86/mm/hotplug: Modify PGD entry when removing memory x86/mm/hotplug: Pass sync_global_pgds() a correct argument in remove_pagetable() x86: Remove set_pmd_pfn
2014-10-13Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes in this cycle were: - Optimized support for Intel "Cluster-on-Die" (CoD) topologies (Dave Hansen) - Various sched/idle refinements for better idle handling (Nicolas Pitre, Daniel Lezcano, Chuansheng Liu, Vincent Guittot) - sched/numa updates and optimizations (Rik van Riel) - sysbench speedup (Vincent Guittot) - capacity calculation cleanups/refactoring (Vincent Guittot) - Various cleanups to thread group iteration (Oleg Nesterov) - Double-rq-lock removal optimization and various refactorings (Kirill Tkhai) - various sched/deadline fixes ... and lots of other changes" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (72 commits) sched/dl: Use dl_bw_of() under rcu_read_lock_sched() sched/fair: Delete resched_cpu() from idle_balance() sched, time: Fix build error with 64 bit cputime_t on 32 bit systems sched: Improve sysbench performance by fixing spurious active migration sched/x86: Fix up typo in topology detection x86, sched: Add new topology for multi-NUMA-node CPUs sched/rt: Use resched_curr() in task_tick_rt() sched: Use rq->rd in sched_setaffinity() under RCU read lock sched: cleanup: Rename 'out_unlock' to 'out_free_new_mask' sched: Use dl_bw_of() under RCU read lock sched/fair: Remove duplicate code from can_migrate_task() sched, mips, ia64: Remove __ARCH_WANT_UNLOCKED_CTXSW sched: print_rq(): Don't use tasklist_lock sched: normalize_rt_tasks(): Don't use _irqsave for tasklist_lock, use task_rq_lock() sched: Fix the task-group check in tg_has_rt_tasks() sched/fair: Leverage the idle state info when choosing the "idlest" cpu sched: Let the scheduler see CPU idle states sched/deadline: Fix inter- exclusive cpusets migrations sched/deadline: Clear dl_entity params when setscheduling to different class sched/numa: Kill the wrong/dead TASK_DEAD check in task_numa_fault() ...
2014-09-23x86: skip check for spurious faults for non-present faultsDavid Vrabel
If a fault on a kernel address is due to a non-present page, then it cannot be the result of stale TLB entry from a protection change (RO to RW or NX to X). Thus the pagetable walk in spurious_fault() can be skipped. See the initial if in spurious_fault() and the tests in spurious_fault_check()) for the set of possible error codes checked for spurious faults. These are: IRUWP Before x00xx && ( 1xxxx || xxx1x ) After ( 10001 || 00011 ) && ( 1xxxx || xxx1x ) Thus the new condition is a subset of the previous one, excluding only non-present faults (I == 1 and W == 1 are mutually exclusive). This avoids spurious_fault() oopsing in some cases if the pagetables it attempts to walk are not accessible. This obscures the location of the original fault. This also fixes a crash with Xen PV guests when they access entries in the M2P corresponding to device MMIO regions. The M2P is mapped (read-only) by Xen into the kernel address space of the guest and this mapping may contains holes for non-RAM regions. Read faults will result in calls to spurious_fault(), but because the page tables for the M2P mappings are not accessible by the guest the pagetable walk would fault. This was not normally a problem as MMIO mappings would not normally result in a M2P lookup because of the use of the _PAGE_IOMAP bit the PTE. However, removing the _PAGE_IOMAP bit requires M2P lookups for MMIO mappings as well. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Dave Hansen <dave.hansen@intel.com>
2014-09-19sched: Add helper for task stack page overrun checkingAaron Tomlin
This facility is used in a few places so let's introduce a helper function to improve code readability. Signed-off-by: Aaron Tomlin <atomlin@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: aneesh.kumar@linux.vnet.ibm.com Cc: dzickus@redhat.com Cc: bmr@redhat.com Cc: jcastillo@redhat.com Cc: oleg@redhat.com Cc: riel@redhat.com Cc: prarit@redhat.com Cc: jgh@redhat.com Cc: minchan@kernel.org Cc: mpe@ellerman.id.au Cc: tglx@linutronix.de Cc: hannes@cmpxchg.org Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/1410527779-8133-3-git-send-email-atomlin@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-09-19init/main.c: Give init_task a canaryAaron Tomlin
Tasks get their end of stack set to STACK_END_MAGIC with the aim to catch stack overruns. Currently this feature does not apply to init_task. This patch removes this restriction. Note that a similar patch was posted by Prarit Bhargava some time ago but was never merged: http://marc.info/?l=linux-kernel&m=127144305403241&w=2 Signed-off-by: Aaron Tomlin <atomlin@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> Cc: aneesh.kumar@linux.vnet.ibm.com Cc: dzickus@redhat.com Cc: bmr@redhat.com Cc: jcastillo@redhat.com Cc: jgh@redhat.com Cc: minchan@kernel.org Cc: tglx@linutronix.de Cc: hannes@cmpxchg.org Cc: Alex Thorlton <athorlton@sgi.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Daeseok Youn <daeseok.youn@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Fabian Frederick <fabf@skynet.be> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Michael Opdenacker <michael.opdenacker@free-electrons.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/1410527779-8133-2-git-send-email-atomlin@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-09-16x86/mm/hotplug: Modify PGD entry when removing memoryYasuaki Ishimatsu
When hot-adding/removing memory, sync_global_pgds() is called for synchronizing PGD to PGD entries of all processes MM. But when hot-removing memory, sync_global_pgds() does not work correctly. At first, sync_global_pgds() checks whether target PGD is none or not. And if PGD is none, the PGD is skipped. But when hot-removing memory, PGD may be none since PGD may be cleared by free_pud_table(). So when sync_global_pgds() is called after hot-removing memory, sync_global_pgds() should not skip PGD even if the PGD is none. And sync_global_pgds() must clear PGD entries of all processes MM. Currently sync_global_pgds() does not clear PGD entries of all processes MM when hot-removing memory. So when hot adding memory which is same memory range as removed memory after hot-removing memory, following call traces are shown: kernel BUG at arch/x86/mm/init_64.c:206! ... [<ffffffff815e0c80>] kernel_physical_mapping_init+0x1b2/0x1d2 [<ffffffff815ced94>] init_memory_mapping+0x1d4/0x380 [<ffffffff8104aebd>] arch_add_memory+0x3d/0xd0 [<ffffffff815d03d9>] add_memory+0xb9/0x1b0 [<ffffffff81352415>] acpi_memory_device_add+0x1af/0x28e [<ffffffff81325dc4>] acpi_bus_device_attach+0x8c/0xf0 [<ffffffff813413b9>] acpi_ns_walk_namespace+0xc8/0x17f [<ffffffff81325d38>] ? acpi_bus_type_and_status+0xb7/0xb7 [<ffffffff81325d38>] ? acpi_bus_type_and_status+0xb7/0xb7 [<ffffffff813418ed>] acpi_walk_namespace+0x95/0xc5 [<ffffffff81326b4c>] acpi_bus_scan+0x9a/0xc2 [<ffffffff81326bff>] acpi_scan_bus_device_check+0x8b/0x12e [<ffffffff81326cb5>] acpi_scan_device_check+0x13/0x15 [<ffffffff81320122>] acpi_os_execute_deferred+0x25/0x32 [<ffffffff8107e02b>] process_one_work+0x17b/0x460 [<ffffffff8107edfb>] worker_thread+0x11b/0x400 [<ffffffff8107ece0>] ? rescuer_thread+0x400/0x400 [<ffffffff81085aef>] kthread+0xcf/0xe0 [<ffffffff81085a20>] ? kthread_create_on_node+0x140/0x140 [<ffffffff815fc76c>] ret_from_fork+0x7c/0xb0 [<ffffffff81085a20>] ? kthread_create_on_node+0x140/0x140 This patch clears PGD entries of all processes MM when sync_global_pgds() is called after hot-removing memory Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Gu Zheng <guz.fnst@cn.fujitsu.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-08-06mm: describe mmap_sem rules for __lock_page_or_retry() and callersPaul Cassella
Add a comment describing the circumstances in which __lock_page_or_retry() will or will not release the mmap_sem when returning 0. Add comments to lock_page_or_retry()'s callers (filemap_fault(), do_swap_page()) noting the impact on VM_FAULT_RETRY returns. Add comments on up the call tree, particularly replacing the false "We return with mmap_sem still held" comments. Signed-off-by: Paul Cassella <cassella@cray.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-04Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm changes from Ingo Molnar: "The main change in this cycle is the rework of the TLB range flushing code, to simplify, fix and consolidate the code. By Dave Hansen" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mm: Set TLB flush tunable to sane value (33) x86/mm: New tunable for single vs full TLB flush x86/mm: Add tracepoints for TLB flushes x86/mm: Unify remote INVLPG code x86/mm: Fix missed global TLB flush stat x86/mm: Rip out complicated, out-of-date, buggy TLB flushing x86/mm: Clean up the TLB flushing code x86/smep: Be more informative when signalling an SMEP fault
2014-06-12Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more perf updates from Ingo Molnar: "A second round of perf updates: - wide reaching kprobes sanitization and robustization, with the hope of fixing all 'probe this function crashes the kernel' bugs, by Masami Hiramatsu. - uprobes updates from Oleg Nesterov: tmpfs support, corner case fixes and robustization work. - perf tooling updates and fixes from Jiri Olsa, Namhyung Ki, Arnaldo et al: * Add support to accumulate hist periods (Namhyung Kim) * various fixes, refactorings and enhancements" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (101 commits) perf: Differentiate exec() and non-exec() comm events perf: Fix perf_event_comm() vs. exec() assumption uprobes/x86: Rename arch_uprobe->def to ->defparam, minor comment updates perf/documentation: Add description for conditional branch filter perf/x86: Add conditional branch filtering support perf/tool: Add conditional branch filter 'cond' to perf record perf: Add new conditional branch filter 'PERF_SAMPLE_BRANCH_COND' uprobes: Teach copy_insn() to support tmpfs uprobes: Shift ->readpage check from __copy_insn() to uprobe_register() perf/x86: Use common PMU interrupt disabled code perf/ARM: Use common PMU interrupt disabled code perf: Disable sampled events if no PMU interrupt perf: Fix use after free in perf_remove_from_context() perf tools: Fix 'make help' message error perf record: Fix poll return value propagation perf tools: Move elide bool into perf_hpp_fmt struct perf tools: Remove elide setup for SORT_MODE__MEMORY mode perf tools: Fix "==" into "=" in ui_browser__warning assignment perf tools: Allow overriding sysfs and proc finding with env var perf tools: Consider header files outside perf directory in tags target ...
2014-06-11x86/smep: Be more informative when signalling an SMEP faultJiri Kosina
If pagefault triggers due to SMEP triggering, it can't be really easily distinguished from any other oops-causing pagefault, which might lead to quite some confusion when trying to understand the reason for the oops. Print an explanatory message in case the fault happened during instruction fetch for _PAGE_USER page which is present and executable on SMEP-enabled CPUs. This is consistent with what we are doing for NX already; in addition to immediately seeing from the oops what might be happening, it can even easily give a good indication to sysadmins who are carefully monitoring their kernel logs that someone might be trying to pwn them. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Link: http://lkml.kernel.org/r/alpine.LNX.2.00.1406102248490.1321@pobox.suse.cz Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-05-05x86, vdso: Move the vvar and hpet mappings next to the 64-bit vDSOAndy Lutomirski
This makes the 64-bit and x32 vdsos use the same mechanism as the 32-bit vdso. Most of the churn is deleting all the old fixmap code. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Link: http://lkml.kernel.org/r/8af87023f57f6bb96ec8d17fce3f88018195b49b.1399317206.git.luto@amacapital.net Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-04-24kprobes, x86: Use NOKPROBE_SYMBOL() instead of __kprobes annotationMasami Hiramatsu
Use NOKPROBE_SYMBOL macro for protecting functions from kprobes instead of __kprobes annotation under arch/x86. This applies nokprobe_inline annotation for some cases, because NOKPROBE_SYMBOL() will inhibit inlining by referring the symbol address. This just folds a bunch of previous NOKPROBE_SYMBOL() cleanup patches for x86 to one patch. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/20140417081814.26341.51656.stgit@ltc230.yrl.intra.hitachi.co.jp Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Borislav Petkov <bp@suse.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fernando Luis Vázquez Cao <fernando_b1@lab.ntt.co.jp> Cc: Gleb Natapov <gleb@redhat.com> Cc: Jason Wang <jasowang@redhat.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Jonathan Lebon <jlebon@redhat.com> Cc: Kees Cook <keescook@chromium.org> Cc: Matt Fleming <matt.fleming@intel.com> Cc: Michel Lespinasse <walken@google.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-31Merge branch 'x86-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 EFI changes from Ingo Molnar: "The main changes: - Add debug code to the dump EFI pagetable - Borislav Petkov - Make 1:1 runtime mapping robust when booting on machines with lots of memory - Borislav Petkov - Move the EFI facilities bits out of 'x86_efi_facility' and into efi.flags which is the standard architecture independent place to keep EFI state, by Matt Fleming. - Add 'EFI mixed mode' support: this allows 64-bit kernels to be booted from 32-bit firmware. This needs a bootloader that supports the 'EFI handover protocol'. By Matt Fleming" * 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits) x86, efi: Abstract x86 efi_early calls x86/efi: Restore 'attr' argument to query_variable_info() x86/efi: Rip out phys_efi_get_time() x86/efi: Preserve segment registers in mixed mode x86/boot: Fix non-EFI build x86, tools: Fix up compiler warnings x86/efi: Re-disable interrupts after calling firmware services x86/boot: Don't overwrite cr4 when enabling PAE x86/efi: Wire up CONFIG_EFI_MIXED x86/efi: Add mixed runtime services support x86/efi: Firmware agnostic handover entry points x86/efi: Split the boot stub into 32/64 code paths x86/efi: Add early thunk code to go from 64-bit to 32-bit x86/efi: Build our own EFI services pointer table efi: Add separate 32-bit/64-bit definitions x86/efi: Delete dead code when checking for non-native x86/mm/pageattr: Always dump the right page table in an oops x86, tools: Consolidate #ifdef code x86/boot: Cleanup header.S by removing some #ifdefs efi: Use NULL instead of 0 for pointer ...
2014-03-06x86, trace: Further robustify CR2 handling vs tracingPeter Zijlstra
Building on commit 0ac09f9f8cd1 ("x86, trace: Fix CR2 corruption when tracing page faults") this patch addresses another few issues: - Now that read_cr2() is lifted into trace_do_page_fault(), we should pass the address to trace_page_fault_entries() to avoid it re-reading a potentially changed cr2. - Put both trace_do_page_fault() and trace_page_fault_entries() under CONFIG_TRACING. - Mark both fault entry functions {,trace_}do_page_fault() as notrace to avoid getting __mcount or other function entry trace callbacks before we've observed CR2. - Mark __do_page_fault() as noinline to guarantee the function tracer does get to see the fault. Cc: <jolsa@redhat.com> Cc: <vincent.weaver@maine.edu> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140306145300.GO9987@twins.programming.kicks-ass.net Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-03-05Merge remote-tracking branch 'tip/x86/efi-mixed' into efi-for-mingoMatt Fleming
Conflicts: arch/x86/kernel/setup.c arch/x86/platform/efi/efi.c arch/x86/platform/efi/efi_64.c
2014-03-04x86, trace: Fix CR2 corruption when tracing page faultsJiri Olsa
The trace_do_page_fault function trigger tracepoint and then handles the actual page fault. This could lead to error if the tracepoint caused page fault. The original cr2 value gets lost and the original page fault handler kills current process with SIGSEGV. This happens if you record page faults with callchain data, the user part of it will cause tracepoint handler to page fault: # perf record -g -e exceptions:page_fault_user ls Fixing this by saving the original cr2 value and using it after tracepoint handler is done. v2: Moving the cr2 read before exception_enter, because it could trigger tracepoint as well. Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Reported-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Vince Weaver <vincent.weaver@maine.edu> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1402211701380.6395@vincent-weaver-1.um.maine.edu Link: http://lkml.kernel.org/r/20140228160526.GD1133@krava.brq.redhat.com
2014-03-04x86/mm/pageattr: Always dump the right page table in an oopsMatt Fleming
Now that we have EFI-specific page tables we need to lookup the pgd when dumping those page tables, rather than assuming that swapper_pgdir is the current pgdir. Remove the double underscore prefix, which is usually reserved for static functions. Acked-by: Borislav Petkov <bp@suse.de> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-02-13x86, smap: smap_violation() is bogus if CONFIG_X86_SMAP is offH. Peter Anvin
If CONFIG_X86_SMAP is disabled, smap_violation() tests for conditions which are incorrect (as the AC flag doesn't matter), causing spurious faults. The dynamic disabling of SMAP (nosmap on the command line) is fine because it disables X86_FEATURE_SMAP, therefore causing the static_cpu_has() to return false. Found by Fengguang Wu's test system. [ v3: move all predicates into smap_violation() ] [ v2: use IS_ENABLED() instead of #ifdef ] Reported-by: Fengguang Wu <fengguang.wu@intel.com> Link: http://lkml.kernel.org/r/20140213124550.GA30497@localhost Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: <stable@vger.kernel.org> # v3.7+
2014-01-16x86, mm, perf: Allow recursive faults from interruptsPeter Zijlstra
Waiman managed to trigger a PMI while in a emulate_vsyscall() fault, the PMI in turn managed to trigger a fault while obtaining a stack trace. This triggered the sig_on_uaccess_error recursive fault logic and killed the process dead. Fix this by explicitly excluding interrupts from the recursive fault logic. Reported-and-Tested-by: Waiman Long <waiman.long@hp.com> Fixes: e00b12e64be9 ("perf/x86: Further optimize copy_from_user_nmi()") Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Scott J Norton <scott.norton@hp.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140110200603.GJ7572@laptop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-14Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull two x86 fixes from Ingo Molnar. * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/microcode/amd: Tone down printk(), don't treat a missing firmware file as an error x86/dumpstack: Fix printk_address for direct addresses
2013-11-14Merge branch 'x86-trace-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/trace changes from Ingo Molnar: "This adds page fault tracepoints which have zero runtime cost in the disabled case via IDT trickery (no NOPs in the page fault hotpath)" * 'x86-trace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, trace: Change user|kernel_page_fault to page_fault_user|kernel x86, trace: Add page fault tracepoints x86, trace: Delete __trace_alloc_intr_gate() x86, trace: Register exception handler to trace IDT x86, trace: Remove __alloc_intr_gate()
2013-11-12x86/dumpstack: Fix printk_address for direct addressesJiri Slaby
Consider a kernel crash in a module, simulated the following way: static int my_init(void) { char *map = (void *)0x5; *map = 3; return 0; } module_init(my_init); When we turn off FRAME_POINTERs, the very first instruction in that function causes a BUG. The problem is that we print IP in the BUG report using %pB (from printk_address). And %pB decrements the pointer by one to fix printing addresses of functions with tail calls. This was added in commit 71f9e59800e5ad4 ("x86, dumpstack: Use %pB format specifier for stack trace") to fix the call stack printouts. So instead of correct output: BUG: unable to handle kernel NULL pointer dereference at 0000000000000005 IP: [<ffffffffa01ac000>] my_init+0x0/0x10 [pb173] We get: BUG: unable to handle kernel NULL pointer dereference at 0000000000000005 IP: [<ffffffffa0152000>] 0xffffffffa0151fff To fix that, we use %pS only for stack addresses printouts (via newly added printk_stack_address) and %pB for regs->ip (via printk_address). I.e. we revert to the old behaviour for all except call stacks. And since from all those reliable is 1, we remove that parameter from printk_address. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: joe@perches.com Cc: jirislaby@gmail.com Link: http://lkml.kernel.org/r/1382706418-8435-1-git-send-email-jslaby@suse.cz Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-11x86, trace: Change user|kernel_page_fault to page_fault_user|kernelH. Peter Anvin
Tracepoints are named hierachially, and it makes more sense to keep a general flow of information level from general to specific from left to right, i.e. x86_exceptions.page_fault_user|kernel rather than x86_exceptions.user|kernel_page_fault Suggested-by: Ingo Molnar <mingo@kernel.org> Acked-by: Seiji Aguchi <seiji.aguchi@hds.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/r/20131111082955.GB12405@gmail.com
2013-11-08x86, trace: Add page fault tracepointsSeiji Aguchi
This patch introduces page fault tracepoints to x86 architecture by switching IDT. Two events, for user and kernel spaces, are introduced at the beginning of page fault handler for tracing. - User space event There is a request of page fault event for user space as below. https://lkml.kernel.org/r/1368079520-11015-2-git-send-email-fdeslaur+()+gmail+!+com https://lkml.kernel.org/r/1368079520-11015-1-git-send-email-fdeslaur+()+gmail+!+com - Kernel space event: When we measure an overhead in kernel space for investigating performance issues, we can check if it comes from the page fault events. Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Link: http://lkml.kernel.org/r/52716E67.6090705@hds.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-11-08x86, trace: Register exception handler to trace IDTSeiji Aguchi
This patch registers exception handlers for tracing to a trace IDT. To implemented it in set_intr_gate(), this patch does followings. - Register the exception handlers to the trace IDT by prepending "trace_" to the handler's names. - Also, newly introduce trace_page_fault() to add tracepoints in a subsequent patch. Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Link: http://lkml.kernel.org/r/52716DEC.5050204@hds.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-10-29perf/x86: Further optimize copy_from_user_nmi()Peter Zijlstra
Now that we can deal with nested NMI due to IRET re-enabling NMIs and can deal with faults from NMI by making sure we preserve CR2 over NMIs we can in fact simply access user-space memory from NMI context. So rewrite copy_from_user_nmi() to use __copy_from_user_inatomic() and rework the fault path to do the minimal required work before taking the in_atomic() fault handler. In particular avoid perf_sw_event() which would make perf recurse on itself (it should be harmless as our recursion protections should be able to deal with this -- but why tempt fate). Also rename notify_page_fault() to kprobes_fault() as that is a much better name; there is no notifier in it and its specific to kprobes. Don measured that his worst case NMI path shrunk from ~300K cycles to ~150K cycles. Cc: Stephane Eranian <eranian@google.com> Cc: jmario@redhat.com Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: dave.hansen@linux.intel.com Tested-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20131024105206.GM2490@laptop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-12x86: finish user fault error path with fatal signalJohannes Weiner
The x86 fault handler bails in the middle of error handling when the task has a fatal signal pending. For a subsequent patch this is a problem in OOM situations because it relies on pagefault_out_of_memory() being called even when the task has been killed, to perform proper per-task OOM state unwinding. Shortcutting the fault like this is a rather minor optimization that saves a few instructions in rare cases. Just remove it for user-triggered faults. Use the opportunity to split the fault retry handling from actual fault errors and add locking documentation that reads suprisingly similar to ARM's. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12arch: mm: pass userspace fault flag to generic fault handlerJohannes Weiner
Unlike global OOM handling, memory cgroup code will invoke the OOM killer in any OOM situation because it has no way of telling faults occuring in kernel context - which could be handled more gracefully - from user-triggered faults. Pass a flag that identifies faults originating in user space from the architecture-specific fault handlers to generic code so that memcg OOM handling can be improved. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
