path: root/arch/x86/lib/insn.c
2011-10-10x86: Fix insn decoder for longer instructionMasami Hiramatsu
Fix x86 insn decoder for hardening against invalid length instructions. This adds length checkings for each byte-read site and if it exceeds MAX_INSN_SIZE, returns immediately. This can happen when decoding user-space binary. Caller can check whether it happened by checking insn.*.got member is set or not. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Stephane Eranian <eranian@google.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: acme@redhat.com Cc: ming.m.lin@intel.com Cc: robert.richter@amd.com Cc: ravitillo@lbl.gov Cc: yrl.pp-manager.tt@hitachi.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20111007133155.10933.58577.stgit@localhost.localdomain Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-29x86: AVX instruction set decoder supportMasami Hiramatsu
Add Intel AVX(Advanced Vector Extensions) instruction set support to x86 instruction decoder. This adds insn.vex_prefix field for storing VEX prefixes, and introduces some original tags for expressing opcodes attributes. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> LKML-Reference: <20091027204226.30545.23451.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-29x86: Merge INAT_REXPFX into INAT_PFX_*Masami Hiramatsu
Merge INAT_REXPFX into INAT_PFX_* macro and rename it to INAT_PFX_REX. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> LKML-Reference: <20091027204211.30545.58090.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-27x86: Instruction decoder APIMasami Hiramatsu
Add x86 instruction decoder to arch-specific libraries. This decoder can decode x86 instructions used in kernel into prefix, opcode, modrm, sib, displacement and immediates. This can also show the length of instructions. This version introduces instruction attributes for decoding instructions. The instruction attribute tables are generated from the opcode map file (x86-opcode-map.txt) by the generator script(gen-insn-attr-x86.awk). Currently, the opcode maps are based on opcode maps in Intel(R) 64 and IA-32 Architectures Software Developers Manual Vol.2: Appendix.A, and consist of below two types of opcode tables. 1-byte/2-bytes/3-bytes opcodes, which has 256 elements, are written as below; Table: table-name Referrer: escaped-name opcode: mnemonic|GrpXXX [operand1[,operand2...]] [(extra1)[,(extra2)...] [| 2nd-mnemonic ...] (or) opcode: escape # escaped-name EndTable Group opcodes, which has 8 elements, are written as below; GrpTable: GrpXXX reg: mnemonic [operand1[,operand2...]] [(extra1)[,(extra2)...] [| 2nd-mnemonic ...] EndTable These opcode maps include a few SSE and FP opcodes (for setup), because those opcodes are used in the kernel. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Przemysław Pawełczyk <przemyslaw@pawelczyk.it> Cc: Roland McGrath <roland@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> LKML-Reference: <20090813203413.31965.49709.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
