path: root/arch/x86/lib/insn.c
2012-02-11x86: Fix to decode grouped AVX with VEX pp bitsMasami Hiramatsu
Fix to decode grouped AVX with VEX pp bits which should be handled as same as last-prefixes. This fixes below warnings in posttest with CONFIG_CRYPTO_SHA1_SSSE3=y. Warning: arch/x86/tools/test_get_len found difference at <sha1_transform_avx>:ffffffff810d5fc0 Warning: ffffffff810d6069: c5 f9 73 de 04 vpsrldq $0x4,%xmm6,%xmm0 Warning: objdump says 5 bytes, but insn_get_length() says 4 ... With this change, test_get_len can decode it correctly. $ arch/x86/tools/test_get_len -v -y ffffffff810d6069: c5 f9 73 de 04 vpsrldq $0x4,%xmm6,%xmm0 Succeed: decoded and checked 1 instructions Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20120210053340.30429.73410.stgit@localhost.localdomain Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05x86: Fix instruction decoder to handle grouped AVX instructionsMasami Hiramatsu
For reducing memory usage of attribute table, x86 instruction decoder puts "Group" attribute only on "no-last-prefix" attribute table (same as vex_p == 0 case). Thus, the decoder should look no-last-prefix table first, and then only if it is not a group, move on to "with-last-prefix" table (vex_p != 0). However, current implementation, inat_get_avx_attribute() looks with-last-prefix directly. So, when decoding a grouped AVX instruction, the decoder fails to find correct group because there is no "Group" attribute on the table. This ends up with the mis-decoding of instructions, as Ingo reported in http://thread.gmane.org/gmane.linux.kernel/1214103 This patch fixes it to check no-last-prefix table first even if that is an AVX instruction, and get an attribute from "with last-prefix" table only if that is not a group. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20111205120539.15475.91428.stgit@cloud Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-10x86: Fix insn decoder for longer instructionMasami Hiramatsu
Fix x86 insn decoder for hardening against invalid length instructions. This adds length checkings for each byte-read site and if it exceeds MAX_INSN_SIZE, returns immediately. This can happen when decoding user-space binary. Caller can check whether it happened by checking insn.*.got member is set or not. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Stephane Eranian <eranian@google.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: acme@redhat.com Cc: ming.m.lin@intel.com Cc: robert.richter@amd.com Cc: ravitillo@lbl.gov Cc: yrl.pp-manager.tt@hitachi.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20111007133155.10933.58577.stgit@localhost.localdomain Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-29x86: AVX instruction set decoder supportMasami Hiramatsu
Add Intel AVX(Advanced Vector Extensions) instruction set support to x86 instruction decoder. This adds insn.vex_prefix field for storing VEX prefixes, and introduces some original tags for expressing opcodes attributes. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> LKML-Reference: <20091027204226.30545.23451.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-29x86: Merge INAT_REXPFX into INAT_PFX_*Masami Hiramatsu
Merge INAT_REXPFX into INAT_PFX_* macro and rename it to INAT_PFX_REX. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> LKML-Reference: <20091027204211.30545.58090.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-27x86: Instruction decoder APIMasami Hiramatsu
Add x86 instruction decoder to arch-specific libraries. This decoder can decode x86 instructions used in kernel into prefix, opcode, modrm, sib, displacement and immediates. This can also show the length of instructions. This version introduces instruction attributes for decoding instructions. The instruction attribute tables are generated from the opcode map file (x86-opcode-map.txt) by the generator script(gen-insn-attr-x86.awk). Currently, the opcode maps are based on opcode maps in Intel(R) 64 and IA-32 Architectures Software Developers Manual Vol.2: Appendix.A, and consist of below two types of opcode tables. 1-byte/2-bytes/3-bytes opcodes, which has 256 elements, are written as below; Table: table-name Referrer: escaped-name opcode: mnemonic|GrpXXX [operand1[,operand2...]] [(extra1)[,(extra2)...] [| 2nd-mnemonic ...] (or) opcode: escape # escaped-name EndTable Group opcodes, which has 8 elements, are written as below; GrpTable: GrpXXX reg: mnemonic [operand1[,operand2...]] [(extra1)[,(extra2)...] [| 2nd-mnemonic ...] EndTable These opcode maps include a few SSE and FP opcodes (for setup), because those opcodes are used in the kernel. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Przemysław Pawełczyk <przemyslaw@pawelczyk.it> Cc: Roland McGrath <roland@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> LKML-Reference: <20090813203413.31965.49709.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
