commit fcd0861db1cf4e6ed99f60a815b7b72c2ed36ea4 upstream.
The shift direction was wrong because the function takes a
page number and i is the address is the loop.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
commit 838312be46f3abfbdc175f81c3e54a857994476d upstream.
These warnings (generally one per CPU) are a result of
initializing x86_cpu_to_logical_apicid while apic_default is
still in use, but the check in setup_local_APIC() being done
when apic_bigsmp was already used as an override in
default_setup_apic_routing():
Overriding APIC driver with bigsmp
Enabling APIC mode: Physflat. Using 5 I/O APICs
WARNING: at .../arch/x86/kernel/apic/apic.c:1239
CPU 1 irqstacks, hard=f1c9a000 soft=f1c9c000
Booting Node 0, Processors #1
smpboot cpu 1: start_ip = 9e000
Initializing CPU#1
setup_local_APIC+0x137/0x46b() Hardware name: ...
CPU1 logical APIC ID: 2 != 8
Fix this (for the time being, i.e. until
x86_32_early_logical_apicid() will get removed again, as Tejun
says ought to be possible) by overriding the previously stored
values at the point where the APIC driver gets overridden.
v2: Move this and the pre-existing override logic into
arch/x86/kernel/apic/bigsmp_32.c.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Acked-by: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/4E835D16020000780005844C@nat28.tlf.novell.com
commit 315eb8a2a1b7f335d40ceeeb11b9e067475eb881 upstream.
When compiling an i386_defconfig kernel with gcc-4.6.1-9.fc15.i686, I
noticed a warning about the asm operand for test_bit in kprobes'
can_boost. I discovered that this caused only the first long of
twobyte_is_boostable[] to be output.
Jakub filed and fixed gcc PR50571 to correct the warning and this output
issue. But to solve it for less current gcc, we can make kprobes'
twobyte_is_boostable[] non-const, and it won't be optimized out.
Before:
CC arch/x86/kernel/kprobes.o
In file included from include/linux/bitops.h:22:0,
from include/linux/kernel.h:17,
from [...]/arch/x86/include/asm/percpu.h:44,
from [...]/arch/x86/include/asm/current.h:5,
from [...]/arch/x86/include/asm/processor.h:15,
from [...]/arch/x86/include/asm/atomic.h:6,
from include/linux/atomic.h:4,
from include/linux/mutex.h:18,
from include/linux/notifier.h:13,
from include/linux/kprobes.h:34,
from arch/x86/kernel/kprobes.c:43:
[...]/arch/x86/include/asm/bitops.h: In function ‘can_boost.part.1’:
[...]/arch/x86/include/asm/bitops.h:319:2: warning: use of memory input
without lvalue in asm operand 1 is deprecated [enabled by default]
$ objdump -rd arch/x86/kernel/kprobes.o | grep -A1 -w bt
551: 0f a3 05 00 00 00 00 bt %eax,0x0
554: R_386_32 .rodata.cst4
$ objdump -s -j .rodata.cst4 -j .data arch/x86/kernel/kprobes.o
arch/x86/kernel/kprobes.o: file format elf32-i386
Contents of section .data:
0000 48000000 00000000 00000000 00000000 H...............
Contents of section .rodata.cst4:
0000 4c030000 L...
Only a single long of twobyte_is_boostable[] is in the object file.
After, without the const on twobyte_is_boostable:
551: 0f a3 05 20 00 00 00 bt %eax,0x20
554: R_386_32 .data
0010 00000000 00000000 00000000 00000000 ................
0020 4c030000 0f000200 ffff0000 ffcff0c0 L...............
0030 0000ffff 3bbbfff8 03ff2ebb 26bb2e77 ....;.......&..w
Now all 32 bytes are output into .data instead.
Signed-off-by: Josh Stone <jistone@redhat.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Jakub Jelinek <jakub@redhat.com>
commit 6a469e4665bc158599de55d64388861d0a9f10f4 upstream.
This is a workaround for a UV2 hub bug that affects the format of system
global addresses.
The GRU API for UV2 was inadvertently broken by a hardware change. The
format of the physical address used for TLB dropins and for addresses used
with instructions running in unmapped mode has changed. This change was
not documented and became apparent only when diags failed running on
system simulators.
For UV1, TLB and GRU instruction physical addresses are identical to
socket physical addresses (although high NASID bits must be OR'ed into the
address).
For UV2, socket physical addresses need to be converted. The NODE portion
of the physical address needs to be shifted so that the low bit is in bit
39 or bit 40, depending on an MMR value.
It is not yet clear if this bug will be fixed in a silicon respin. If it
is fixed, the hub revision will be incremented & the workaround disabled.
Signed-off-by: Jack Steiner <steiner@sgi.com>
commit a34668f6beb4ab01e07683276d6a24bab6c175e0 upstream.
Add support to Romely-EP SandyBridge.
Signed-off-by: Youquan Song <youquan.song@intel.com>
Signed-off-by: Anhua Xu <anhua.xu@intel.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Link: http://lkml.kernel.org/r/1312264895-2010-1-git-send-email-youquan.song@intel.com
commit f1ca1512e765337a7c09eb875eedef8ea4e07654 upstream.
The value is only set to true but never set back to false,
which causes to many completion-wait commands to be sent to
hardware. Fix it with this patch.
commit e33acde91140f1809952d1c135c36feb66a51887 upstream.
The domain_flush_devices() function takes the domain->lock.
But this function is only called from update_domain() which
itself is already called unter the domain->lock. This causes
a deadlock situation when the dma-address-space of a domain
grows larger than 1GB.
commit 20afc60f892d285fde179ead4b24e6a7938c2f1b upstream.
An event may occur when an mm is already released.
I added an event in dequeue_entity() and caught a panic with
the following backtrace:
[ 434.421110] BUG: unable to handle kernel NULL pointer dereference at 0000000000000050
[ 434.421258] IP: [<ffffffff810464ac>] __get_user_pages_fast+0x9c/0x120
[ 434.421258] Call Trace:
[ 434.421258] [<ffffffff8101ae81>] copy_from_user_nmi+0x51/0xf0
[ 434.421258] [<ffffffff8109a0d5>] ? sched_clock_local+0x25/0x90
[ 434.421258] [<ffffffff8101b048>] perf_callchain_user+0x128/0x170
[ 434.421258] [<ffffffff811154cd>] ? __perf_event_header__init_id+0xed/0x100
[ 434.421258] [<ffffffff81116690>] perf_prepare_sample+0x200/0x280
[ 434.421258] [<ffffffff81118da8>] __perf_event_overflow+0x1b8/0x290
[ 434.421258] [<ffffffff81065240>] ? tg_shares_up+0x0/0x670
[ 434.421258] [<ffffffff8104fe1a>] ? walk_tg_tree+0x6a/0xb0
[ 434.421258] [<ffffffff81118f44>] perf_swevent_overflow+0xc4/0xf0
[ 434.421258] [<ffffffff81119150>] do_perf_sw_event+0x1e0/0x250
[ 434.421258] [<ffffffff81119204>] perf_tp_event+0x44/0x70
[ 434.421258] [<ffffffff8105701f>] ftrace_profile_sched_block+0xdf/0x110
[ 434.421258] [<ffffffff8106121d>] dequeue_entity+0x2ad/0x2d0
[ 434.421258] [<ffffffff810614ec>] dequeue_task_fair+0x1c/0x60
[ 434.421258] [<ffffffff8105818a>] dequeue_task+0x9a/0xb0
[ 434.421258] [<ffffffff810581e2>] deactivate_task+0x42/0xe0
[ 434.421258] [<ffffffff814bc019>] thread_return+0x191/0x808
[ 434.421258] [<ffffffff81098a44>] ? switch_task_namespaces+0x24/0x60
[ 434.421258] [<ffffffff8106f4c4>] do_exit+0x464/0x910
[ 434.421258] [<ffffffff8106f9c8>] do_group_exit+0x58/0xd0
[ 434.421258] [<ffffffff8106fa57>] sys_exit_group+0x17/0x20
[ 434.421258] [<ffffffff8100b202>] system_call_fastpath+0x16/0x1b
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Link: http://lkml.kernel.org/r/1314693156-24131-1-git-send-email-avagin@openvz.org
commit 05e33fc20ea5e493a2a1e7f1d04f43cdf89f83ed upstream.
Delete the 10 msec delay between the INIT and SIPI when starting
slave cpus. I can find no requirement for this delay. BIOS also
has similar code sequences without the delay.
Removing the delay reduces boot time by 40 sec. Every bit helps.
Link: http://lkml.kernel.org/r/20110805140900.GA6774@sgi.com
commit 6d3321e8e2b3bf6a5892e2ef673c7bf536e3f904 upstream.
MTRR rendezvous sequence using stop_one_cpu_nowait() can potentially
happen in parallel with another system wide rendezvous using
stop_machine(). This can lead to deadlock (The order in which
works are queued can be different on different cpu's. Some cpu's
will be running the first rendezvous handler and others will be running
the second rendezvous handler. Each set waiting for the other set to join
for the system wide rendezvous, leading to a deadlock).
MTRR rendezvous sequence is not implemented using stop_machine() as this
gets called both from the process context aswell as the cpu online paths
(where the cpu has not come online and the interrupts are disabled etc).
stop_machine() works with only online cpus.
For now, take the stop_machine mutex in the MTRR rendezvous sequence that
gets called from an online cpu (here we are in the process context
and can potentially sleep while taking the mutex). And the MTRR rendezvous
that gets triggered during cpu online doesn't need to take this stop_machine
lock (as the stop_machine() already ensures that there is no cpu hotplug
going on in parallel by doing get_online_cpus())
TBD: Pursue a cleaner solution of extending the stop_machine()
infrastructure to handle the case where the calling cpu is
still not online and use this for MTRR rendezvous sequence.
fixes: https://bugzilla.novell.com/show_bug.cgi?id=672008
Reported-by: Vadim Kotelnikov <vadimuzzz@inbox.ru>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Link: http://lkml.kernel.org/r/20110623182056.807230326@sbsiddha-MOBL3.sc.intel.com
commit 17edf2d79f1ea6dfdb4c444801d928953b9f98d6 upstream.
Fix the printk_once() so that it actually prints (didn't print before
due to a stray comma.)
[ hpa: changed to an incremental patch and adjusted the description
accordingly. ]
Signed-off-by: Len Brown <len.brown@intel.com>
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1107151732480.18606@x980
commit 050438ed5a05b25cdf287f5691e56a58c2606997 upstream.
In kexec jump support, jump back address passed to the kexeced
kernel via function calling ABI, that is, the function call
return address is the jump back entry.
Furthermore, jump back entry == 0 should be used to signal that
the jump back or preserve context is not enabled in the original
kernel.
But in the current implementation the stack position used for
function call return address is not cleared context
preservation is disabled. The patch fixes this bug.
Reported-and-tested-by: Yin Kangkai <kangkai.yin@intel.com>
Signed-off-by: Huang Ying <ying.huang@intel.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Link: http://lkml.kernel.org/r/1310607277-25029-1-git-send-email-ying.huang@intel.com
commit abe48b108247e9b90b4c6739662a2e5c765ed114 upstream.
Since 2.6.36 (23016bf0d25), Linux prints the existence of "epb" in /proc/cpuinfo,
Since 2.6.38 (d5532ee7b40), the x86_energy_perf_policy(8) utility has
been available in-tree to update MSR_IA32_ENERGY_PERF_BIAS.
However, the typical BIOS fails to initialize the MSR, presumably
because this is handled by high-volume shrink-wrap operating systems...
Linux distros, on the other hand, do not yet invoke x86_energy_perf_policy(8).
As a result, WSM-EP, SNB, and later hardware from Intel will run in its
default hardware power-on state (performance), which assumes that users
care for performance at all costs and not for energy efficiency.
While that is fine for performance benchmarks, the hardware's intended default
operating point is "normal" mode...
Initialize the MSR to the "normal" by default during kernel boot.
x86_energy_perf_policy(8) is available to change the default after boot,
should the user have a different preference.
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1107140051020.18606@x980
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Yet another variant of the Dell Latitude series which requires
reboot=pci.
From the E5420 bug report by Daniel J Blueman:
> The E6420 is affected also (same platform, different casing and
> features), which provides an external confirmation of the issue; I can
> submit a patch for that later or include it if you prefer:
> http://linux.koolsolutions.com/2009/08/04/howto-fix-linux-hangfreeze-during-reboots-and-restarts/
Reported-by: Daniel J Blueman <daniel.blueman@gmail.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: <stable@kernel.org>
Rebooting on the Dell E5420 often hangs with the keyboard or ACPI
methods, but is reliable via the PCI method.
[ hpa: this was deferred because we believed for a long time that the
recent reshuffling of the boot priorities in commit
660e34cebf0a11d54f2d5dd8838607452355f321 fixed this platform.
Unfortunately that turned out to be incorrect. ]
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
Link: http://lkml.kernel.org/r/1305248699-2347-1-git-send-email-daniel.blueman@gmail.com
The Dell Latitude E6320 doesn't reboot unless reboot=pci is set.
Force it thanks to DMI.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Link: http://lkml.kernel.org/r/1309269451-4966-1-git-send-email-maxime.ripard@free-electrons.com
Cc: Matthew Garrett <mjg@redhat.com>
Some BIOSes will reset the Intel MISC_ENABLE MSR (specifically the
XD_DISABLE bit) when resuming from S3, which can interact poorly with
ebba638ae723d8a8fc2f7abce5ec18b688b791d7. In 32bit PAE mode, this can
lead to a fault when EFER is restored by the kernel wakeup routines,
due to it setting the NX bit for a CPU that (thanks to the BIOS reset)
now incorrectly thinks it lacks the NX feature. (64bit is not affected
because it uses a common CPU bring-up that specifically handles the
XD_DISABLE bit.)
The need for MISC_ENABLE being restored so early is specific to the S3
resume path. Normally, MISC_ENABLE is saved in save_processor_state(),
but this happens after the resume header is created, so just reproduce
the logic here. (acpi_suspend_lowlevel() creates the header, calls
do_suspend_lowlevel, which calls save_processor_state(), so the saved
processor context isn't available during resume header creation.)
[ hpa: Consider for stable if OK in mainline ]
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Link: http://lkml.kernel.org/r/20110707011034.GA8523@outflux.net
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: <stable@kernel.org> 2.6.38+
Since git commit
660e34cebf0a11d54f2d5dd8838607452355f321 x86: reorder reboot method
preferences,
my Acer Aspire One hangs on reboot. It appears that its ACPI method
for rebooting is broken. The attached patch adds a quirk so that the
machine will reboot via the BIOS.
[ hpa: verified that the ACPI control on this machine is just plain broken. ]
Signed-off-by: Peter Chubb <peter.chubb@nicta.com.au>
Link: http://lkml.kernel.org/r/w439iki5vl.wl%25peter@chubb.wattle.id.au
[ Also from Ben Hutchings <ben@decadent.org.uk> and Vitaliy Ivanov
<vitalivanov@gmail.com> ]
Commit 06ae40ce073d ("x86 idle: EXPORT_SYMBOL(default_idle, pm_idle)
only when APM demands it") removed the export for pm_idle/default_idle
unless the apm module was modularised and CONFIG_APM_CPU_IDLE was set.
But the apm module uses pm_idle/default_idle unconditionally,
CONFIG_APM_CPU_IDLE only affects the bios idle threshold. Adjust the
export accordingly.
[ Used #ifdef instead of #if defined() as it's shorter, and what both
Ben and Vitaliy used.. Andy, you're out-voted ;) - Linus ]
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: Len Brown <len.brown@intel.com>
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm: Compare only lower 32 bits of framebuffer map offsets
drm/i915: Don't leak in i915_gem_shmem_pread_slow()
drm/radeon/kms: do bounds checking for 3D_LOAD_VBPNTR and bump array limit
drm/radeon/kms: fix mac g5 quirk
x86/uv/x2apic: update for change in pci bridge handling.
alpha, drm: Remove obsolete Alpha support in MGA DRM code
alpha/drm: Cleanup Alpha support in DRM generic code
savage: remove unnecessary if statement
drm/radeon: fix GUI idle IH debug statements
drm/radeon/kms: check modes against max pixel clock
drm: fix fbs in DRM_IOCTL_MODE_GETRESOURCES ioctl
When I added 3448a19da479b6bd1e28e2a2be9fa16c6a6feb39
I forgot about the special uv handling code for this, so this
patch fixes it up.
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
ftrace: Revert 8ab2b7efd ftrace: Remove unnecessary disabling of irqs
kprobes/trace: Fix kprobe selftest for gcc 4.6
ftrace: Fix possible undefined return code
oprofile, dcookies: Fix possible circular locking dependency
oprofile: Fix locking dependency in sync_start()
oprofile: Free potentially owned tasks in case of errors
oprofile, x86: Add comments to IBS LVT offset initialization
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: devicetree: Add missing early_init_dt_setup_initrd_arch stub
x86: cpu-hotplug: Prevent softirq wakeup on wrong CPU
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: Prevent potential NULL dereference in irq_set_irq_wake()
Unconditionally changing the address limit to USER_DS and not restoring
it to its old value in the error path is wrong because it prevents us
using kernel memory on repeated calls to this function. This, in fact,
breaks the fallback of hard coded paths to the init program from being
ever successful if the first candidate fails to load.
With this patch applied switching to USER_DS is delayed until the point
of no return is reached which makes it possible to have a multi-arch
rootfs with one arch specific init binary for each of the (hard coded)
probed paths.
Since the address limit is already set to USER_DS when start_thread()
will be invoked, this redundancy can be safely removed.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: stable@kernel.org
This patch fixes the following build failure:
drivers/built-in.o: In function `early_init_dt_check_for_initrd':
/home/florian/dev/kernel/x86/linux-2.6-x86/drivers/of/fdt.c:571:
undefined reference to `early_init_dt_setup_initrd_arch'
make: *** [.tmp_vmlinux1] Error 1
which happens as soon as we enable initrd support on a x86 devicetree
platform such as Intel CE4100.
Signed-off-by: Florian Fainelli <ffainelli@freebox.fr>
Cc: Maxime Bizon <mbizon@freebox.fr>
Acked-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: stable@kernel.org # 2.6.39
Link: http://lkml.kernel.org/r/201106061015.50039.ffainelli@freebox.fr
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/urgent
After a newly plugged CPU sets the cpu_online bit it enables
interrupts and goes idle. The cpu which brought up the new cpu waits
for the cpu_online bit and when it observes it, it sets the cpu_active
bit for this cpu. The cpu_active bit is the relevant one for the
scheduler to consider the cpu as a viable target.
With forced threaded interrupt handlers which imply forced threaded
softirqs we observed the following race:
cpu 0 cpu 1
bringup(cpu1);
set_cpu_online(smp_processor_id(), true);
local_irq_enable();
while (!cpu_online(cpu1));
timer_interrupt()
-> wake_up(softirq_thread_cpu1);
-> enqueue_on(softirq_thread_cpu1, cpu0);
cpu_notify(CPU_ONLINE, cpu1);
-> sched_cpu_active(cpu1)
-> set_cpu_active((cpu1, true);
When an interrupt happens before the cpu_active bit is set by the cpu
which brought up the newly onlined cpu, then the scheduler refuses to
enqueue the woken thread which is bound to that newly onlined cpu on
that newly onlined cpu due to the not yet set cpu_active bit and
selects a fallback runqueue. Not really an expected and desirable
behaviour.
So far this has only been observed with forced hard/softirq threading,
but in theory this could happen without forced threaded hard/softirqs
as well. It's probably unobservable as it would take a massive
interrupt storm on the newly onlined cpu which causes the softirq loop
to wake up the softirq thread and an even longer delay of the cpu
which waits for the cpu_online bit.
Reviewed-by: Peter Zijlstra <peterz@infradead.org>
Some PCIe cards ship with a PCI-PCIe bridge which is not
visible as a PCI device in Linux. But the device-id of the
bridge is present in the IOMMU tables which causes a boot
crash in the IOMMU driver.
This patch fixes by removing these cards from the IOMMU
handling. This is a pure -stable fix, a real fix to handle
this situation appriatly will follow for the next merge
window.
Cc: stable@kernel.org # > 2.6.32
Unfortunatly there are systems where the AMD IOMMU does not
cover all devices. This breaks with the current driver as it
initializes the global dma_ops variable. This patch limits
the AMD IOMMU to the devices listed in the IVRS table fixing
DMA for devices not covered by the IOMMU.
The driver contains several loops counting on an u16 value
where the exit-condition is checked against variables that
can have values up to 0xffff. In this case the loops will
never exit. This patch fixed 3 such loops.
x86: Fix mwait_play_dead() faulting on mwait-incapable cpus
x86 idle: Fix mwait deprecation warning message
Evil merge to remove extra quote noticed by Joe Perches
x86: Put back -pg to tsc.o and add no GCOV to vread_tsc_64.o
Adding a comment in the code as IBS LVT setup is not obvious at all ...
Signed-off-by: Robert Richter <robert.richter@amd.com>
A logic error in mwait_play_dead() causes the kernel to use
mwait even on cpus which don't support it, such as KVM virtual
cpus.
Introduced by:
349c004e3d31: x86: A fast way to check capabilities of the current cpu
Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=36222
Reported-by: Török Edwin <edwintorok@gmail.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/1306758237-9327-1-git-send-email-avi@redhat.com
Fix:
arch/x86/kernel/process.c:645:1: warning: unknown escape sequence '\i'
due to missing escape backslash, introduced by this commit:
5d4c47e0195b: x86 idle: deprecate mwait_idle() and "idle=mwait" cmdline param
Signed-off-by: Borislav Petkov <bp@alien8.de>
Cc: Len Brown <len.brown@intel.com>
Link: http://lkml.kernel.org/r/1306748286-24701-1-git-send-email-bp@alien8.de
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
x86 idle: deprecate "no-hlt" cmdline param
x86 idle APM: deprecate CONFIG_APM_CPU_IDLE
x86 idle floppy: deprecate disable_hlt()
x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it
x86 idle: clarify AMD erratum 400 workaround
idle governor: Avoid lock acquisition to read pm_qos before entering idle
cpuidle: menu: fixed wrapping timers at 4.294 seconds
mwait_idle() is a C1-only idle loop intended to be more efficient
than HLT on SMP hardware that supports it.
But mwait_idle() has been replaced by the more general
mwait_idle_with_hints(), which handles both C1 and deeper C-states.
ACPI uses only mwait_idle_with_hints(), and never uses mwait_idle().
Deprecate mwait_idle() and the "idle=mwait" cmdline param
to simplify the x86 idle code.
After this change, kernels configured with
(!CONFIG_ACPI=n && !CONFIG_INTEL_IDLE=n) when run on hardware
that support MWAIT will simply use HLT. If MWAIT is desired
on those systems, cpuidle and the cpuidle drivers above
can be used.
cc: x86@kernel.org
cc: stable@kernel.org # .39.x
We'd rather that modern machines not check if HLT works on
every entry into idle, for the benefit of machines that had
marginal electricals 15-years ago. If those machines are still running
the upstream kernel, they can use "idle=poll". The only difference
will be that they'll now invoke HLT in machine_hlt().
cc: x86@kernel.org # .39.x
We don't want to export the pm_idle function pointer to modules.
Currently CONFIG_APM_CPU_IDLE w/ CONFIG_APM_MODULE forces us to.
CONFIG_APM_CPU_IDLE is of dubious value, it runs only on 32-bit
uniprocessor laptops that are over 10 years old. It calls into
the BIOS during idle, and is known to cause a number of machines
to fail.
Removing CONFIG_APM_CPU_IDLE and will allow us to stop exporting
pm_idle. Any systems that were calling into the APM BIOS
at run-time will simply use HLT instead.
cc: x86@kernel.org
cc: Jiri Kosina <jkosina@suse.cz>
In the long run, we don't want default_idle() or (pm_idle)() to
be exported outside of process.c. Start by not exporting them
to modules, unless the APM build demands it.
cc: x86@kernel.org
The workaround for AMD erratum 400 uses the term "c1e" falsely suggesting:
1. Intel C1E is somehow involved
2. All AMD processors with C1E are involved
Use the string "amd_c1e" instead of simply "c1e" to clarify that
this workaround is specific to AMD's version of C1E.
Use the string "e400" to clarify that the workaround is specific
to AMD processors with Erratum 400.
This patch is text-substitution only, with no functional change.
cc: x86@kernel.org
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
x86, asm: Clean up desc.h a bit
x86, amd: Do not enable ARAT feature on AMD processors below family 0x12
x86: Move do_page_fault()'s error path under unlikely()
x86, efi: Retain boot service code until after switching to virtual mode
x86: Remove unnecessary check in detect_ht()
x86: Reorder mm_context_t to remove x86_64 alignment padding and thus shrink mm_struct
x86, UV: Clean up uv_tlb.c
x86, UV: Add support for SGI UV2 hub chip
x86, cpufeature: Update CPU feature RDRND to RDRAND
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits)
perf: Fix SIGIO handling
perf top: Don't stop if no kernel symtab is found
perf top: Handle kptr_restrict
perf top: Remove unused macro
perf events: initialize fd array to -1 instead of 0
perf tools: Make sure kptr_restrict warnings fit 80 col terms
perf tools: Fix build on older systems
perf symbols: Handle /proc/sys/kernel/kptr_restrict
perf: Remove duplicate headers
ftrace: Add internal recursive checks
tracing: Update btrfs's tracepoints to use u64 interface
tracing: Add __print_symbolic_u64 to avoid warnings on 32bit machine
ftrace: Set ops->flag to enabled even on static function tracing
tracing: Have event with function tracer check error return
ftrace: Have ftrace_startup() return failure code
jump_label: Check entries limit in __jump_label_update
ftrace/recordmcount: Avoid STT_FUNC symbols as base on ARM
scripts/tags.sh: Add magic for trace-events for etags too
scripts/tags.sh: Fix ctags for DEFINE_EVENT()
x86/ftrace: Fix compiler warning in ftrace.c
* setns:
ns: Wire up the setns system call
Done as a merge to make it easier to fix up conflicts in arm due to
addition of sendmmsg system call
32bit and 64bit on x86 are tested and working. The rest I have looked
at closely and I can't find any problems.
setns is an easy system call to wire up. It just takes two ints so I
don't expect any weird architecture porting problems.
While doing this I have noticed that we have some architectures that are
very slow to get new system calls. cris seems to be the slowest where
the last system calls wired up were preadv and pwritev. avr32 is weird
in that recvmmsg was wired up but never declared in unistd.h. frv is
behind with perf_event_open being the last syscall wired up. On h8300
the last system call wired up was epoll_wait. On m32r the last system
call wired up was fallocate. mn10300 has recvmmsg as the last system
call wired up. The rest seem to at least have syncfs wired up which was
new in the 2.6.39.
v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com>
v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com>
v4: Moved wiring up of the system call to another patch
v5: ported to v2.6.39-rc6
v6: rebased onto parisc-next and net-next to avoid syscall conflicts.
v7: ported to Linus's latest post 2.6.39 tree.
> arch/blackfin/include/asm/unistd.h | 3 ++-
> arch/blackfin/mach-common/entry.S | 1 +
Oh - ia64 wiring looks good.
Acked-by: Tony Luck <tony.luck@intel.com>
The commit 44259b1abfaa8bb819d25d41d71e8e33e25dd36a
Author: Andy Lutomirski <luto@MIT.EDU>
x86-64: Move vread_tsc into a new file with sensible options
Removed the -pg from tsc.o which caused the function graph tracer
to go into an infinite function call recursion as it uses the tsc
internally outside its recursion protection, thus tracing the tsc
breaks the function graph tracer.
This commit also added the file vread_tsc_64.c that gets used
by vdso but failed to prevent GCOV from monkeying with it,
causing userspace to try to access kernel data when GCOV was
enabled.
Thanks to Thomas Gleixner for pointing out GCOV as the likely
culprit that added strange kernel accesses into the vread_tsc()
call.
Cc: Author: Andy Lutomirski <luto@MIT.EDU>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: vdso: Remove unused variable
x86-64: Optimize vDSO time()
x86-64: Add time to vDSO
x86-64: Turn off -pg and turn on -foptimize-sibling-calls for vDSO
x86-64: Vclock_gettime(CLOCK_MONOTONIC) can't ever see nsec < 0
x86-64: Don't generate cmov in vread_tsc
x86-64: Remove unnecessary barrier in vread_tsc
x86-64: Clean up vdso/kernel shared variables
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
seqlock: Get rid of SEQLOCK_UNLOCKED
* 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
irq: Remove smp_affinity_list when unregister irq proc
Commit b87cf80af3ba4b4c008b4face3c68d604e1715c6 added support for
ARAT (Always Running APIC timer) on AMD processors that are not
affected by erratum 400. This erratum is present on certain processor
families and prevents APIC timer from waking up the CPU when it
is in a deep C state, including C1E state.
Determining whether a processor is affected by this erratum may
have some corner cases and handling these cases is somewhat
complicated. In the interest of simplicity we won't claim ARAT
support on processor families below 0x12 and will go back to
broadcasting timer when going idle.
Signed-off-by: Boris Ostrovsky <ostr@amd64.org>
Link: http://lkml.kernel.org/r/1306423192-19774-1-git-send-email-ostr@amd64.org
Tested-by: Boris Petkov <borislav.petkov@amd.com>
Cc: Hans Rosenfeld <Hans.Rosenfeld@amd.com>
Cc: Andreas Herrmann <Andreas.Herrmann3@amd.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
Cc: stable@kernel.org # 32.x, 38.x, 39.x
