path: root/arch/x86/kernel
2008-05-26x86: fix the stackprotector canary of the boot CPUIngo Molnar
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-26stackprotector: add boot_init_stack_canary()Ingo Molnar
add the boot_init_stack_canary() and make the secondary idle threads use it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-26x86: fix canary of the boot CPU's idle taskIngo Molnar
the boot CPU's idle task has a zero stackprotector canary value. this is a special task that is never forked, so the fork code does not randomize its canary. Do it when we hit cpu_idle(). Academic sidenote: this means that the early init code runs with a zero canary and hence the canary becomes predictable for this short, boot-only amount of time. Although attack vectors against early init code are very rare, it might make sense to move this initialization to an earlier point. (to one of the early init functions that never return - such as start_kernel()) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-26x86: setup stack canary for the idle threadsArjan van de Ven
The idle threads for non-boot CPUs are a bit special in how they are created; the result is that these don't have the stack canary set up properly in their PDA. Easiest fix is to just always set the PDA up correctly when entering the idle thread; this is a NOP for the boot cpu. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-26x86: fix stackprotector canary updates during context switchesIngo Molnar
fix a bug noticed and fixed by pageexec@freemail.hu. if built with -fstack-protector-all then we'll have canary checks built into the __switch_to() function. That does not work well with the canary-switching code there: while we already use the %rsp of the new task, we still call __switch_to() whith the previous task's canary value in the PDA, hence the __switch_to() ssp prologue instructions will store the previous canary. Then we update the PDA and upon return from __switch_to() the canary check triggers and we panic. so update the canary after we have called __switch_to(), where we are at the same stackframe level as the last stackframe of the next (and now freshly current) task. Note: this means that we call __switch_to() [and its sub-functions] still with the old canary, but that is not a problem, both the previous and the next task has a high-quality canary. The only (mostly academic) disadvantage is that the canary of one task may leak onto the stack of another task, increasing the risk of information leaks, were an attacker able to read the stack of specific tasks (but not that of others). To solve this we'll have to reorganize the way we switch tasks, and move the PDA setting into the switch_to() assembly code. That will happen in another patch. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-26x86: stackprotector & PARAVIRT fixIngo Molnar
on paravirt enabled 64-bit kernels the paravirt ops do function calls themselves - which is bad with the stackprotector - for example pda_init() loads 0 into %gs and then does MSR_GS_BASE write (which modifies gs.base) - but that MSR write is a function call on paravirt, which with stackprotector tries to read the stack canary from the PDA ... crashing the bootup. the solution was suggested by Arjan van de Ven: to exclude paravirt.c from stackprotector, too many lowlevel functionality is in it. It's not like we'll have paravirt functions with character arrays on their stack anyway... Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-24Merge branch 'x86-fixes-for-linus' of ↵tip-auto-x86-next-base-2008-05-26_08_52_Montip-auto-sched-next-base-2008-05-26_08_52_Montip-auto-latest-base-2008-05-26_08_52_Montip-auto-ftrace-next-base-2008-05-26_08_52_MonLinus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip: x86: prevent PGE flush from interruption/preemption x86: use explicit copy in vdso_gettimeofday() namespacecheck: automated fixes x86/xen: fix arbitrary_virt_to_machine() x86: don't read maxlvt before checking if APIC is mapped x86: disable TSC for sched_clock() when calibration failed x86: distangle user disabled TSC from unstable x86: fix setup of cyc2ns in tsc_64.c
2008-05-23Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] clarify license of freq_table.c [CPUFREQ] Remove documentation of removed ondemand tunable. [CPUFREQ] Crusoe: longrun cpufreq module reports false min freq [CPUFREQ] powernow-k8: improve error messages
2008-05-23namespacecheck: automated fixesIngo Molnar
2008-05-23x86: don't read maxlvt before checking if APIC is mappedChuck Ebbert
A check for unmapped apic was added before reading maxlvt but the early read of maxlvt wasn't removed. Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@kernel.org
2008-05-23x86: disable TSC for sched_clock() when calibration failedThomas Gleixner
When the TSC calibration fails then TSC is still used in sched_clock(). Disable it completely in that case. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@kernel.org
2008-05-23x86: distangle user disabled TSC from unstableThomas Gleixner
tsc_enabled is set to 0 from the command line switch "notsc" and from the mark_tsc_unstable code. Seperate those functionalities and replace tsc_enable with tsc_disable. This makes also the native_sched_clock() decision when to use TSC understandable. Preparatory patch to solve the sched_clock() issue on 32 bit. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23x86: fix setup of cyc2ns in tsc_64.cThomas Gleixner
When the TSC is calibrated against the PIT due to the nonavailability of PMTIMER/HPET or due to SMI interference then the setup of the per CPU cyc2ns variables is skipped. This is unlikely to happen but it would definitely render sched_clock() unusable. This was introduced with commit 53d517cdbaac704352b3d0c10fecb99e0b54572e x86: scale cyc_2_nsec according to CPU frequency Update the per CPU cyc2ns variables in all exit pathes of tsc_calibrate. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@kernel.org
2008-05-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: [PATCH] return to old errno choice in mkdir() et.al. [Patch] fs/binfmt_elf.c: fix wrong return values [PATCH] get rid of leak in compat_execve() [Patch] fs/binfmt_elf.c: fix a wrong free [PATCH] avoid multiplication overflows and signedness issues for max_fds [PATCH] dup_fd() part 4 - race fix [PATCH] dup_fd() - part 3 [PATCH] dup_fd() part 2 [PATCH] dup_fd() fixes, part 1 [PATCH] take init_files to fs/file.c
2008-05-19[CPUFREQ] Crusoe: longrun cpufreq module reports false min freqmaximilian attems
The longrun cpufreq module reports a false minimum frequency 3MHz on 300-600MHz Crusoe processor. This may be due to a calculation bug in the module. Original patch from Kaz Sasayama <kazssym@hypercore.co.jp> submitted as http://bugs.debian.org/468149 patch ported to x86 Cc: Kaz Sasayama <kazssym@hypercore.co.jp> Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Dave Jones <davej@redhat.com>
2008-05-19[CPUFREQ] powernow-k8: improve error messagesMark Langsdorf
The most common error with powernow-k8 is an ACPI _PSS error caused either by failure to load the ACPI processor module or a bad parse of the _PSS object. Make the error message returned to the user in these situations more straightforward and easier to understand. -Mark Langsdorf Operating System Research Center AMD Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com> Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Dave Jones <davej@redhat.com>
2008-05-17x86: disable mwait for AMD family 10H/11H CPUsThomas Gleixner
The previous revert of 0c07ee38c9d4eb081758f5ad14bbffa7197e1aec left out the mwait disable condition for AMD family 10H/11H CPUs. Andreas Herrman said: It depends on the CPU. For AMD CPUs that support MWAIT this is wrong. Family 0x10 and 0x11 CPUs will enter C1 on HLT. Powersavings then depend on a clock divisor and current Pstate of the core. If all cores of a processor are in halt state (C1) the processor can enter the C1E (C1 enhanced) state. If mwait is used this will never happen. Thus HLT saves more power than MWAIT here. It might be best to switch off the mwait flag for these AMD CPU families like it was introduced with commit f039b754714a422959027cb18bb33760eb8153f0 (x86: Don't use MWAIT on AMD Family 10) Re-add the AMD families 10H/11H check and disable the mwait usage for those. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-17x86: remove mwait capability C-state checkIngo Molnar
Vegard Nossum reports: | powertop shows between 200-400 wakeups/second with the description | "<kernel IPI>: Rescheduling interrupts" when all processors have load (e.g. | I need to run two busy-loops on my 2-CPU system for this to show up). | | The bisect resulted in this commit: | | commit 0c07ee38c9d4eb081758f5ad14bbffa7197e1aec | Date: Wed Jan 30 13:33:16 2008 +0100 | | x86: use the correct cpuid method to detect MWAIT support for C states remove the functional effects of this patch and make mwait unconditional. A future patch will turn off mwait on specific CPUs where that causes power to be wasted. Bisected-by: Vegard Nossum <vegard.nossum@gmail.com> Tested-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-16[PATCH] take init_files to fs/file.cAl Viro
2008-05-13x86: user_regset_view table fix for ia32 on 64-bitRoland McGrath
The user_regset_view table for the 32-bit regsets on the 64-bit build had the wrong sizes for the FP regsets. This bug had no user-visible effect (just on kernel modules using the user_regset interfaces and the like). But the fix is trivial and risk-free. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-13x86: fix csum_partial() exportIngo Molnar
Fix this symbol export problem: Building modules, stage 2. MODPOST 193 modules ERROR: "csum_partial" [fs/reiserfs/reiserfs.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 This is due to a known weakness of symbol exports: if a symbol's only in-core user is an EXPORT_SYMBOL from a lib-y section, the symbol is not linked in. The solution is to move the export to x8664_ksyms_64.c - but the real solution would be to fix kbuild. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-13x86: early_init_centaur(): use set_cpu_cap()Andrew Morton
arch/x86/kernel/setup_64.c:954: warning: passing argument 2 of 'set_bit' from incompatible pointer type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-13x86: fix app crashes after SMP resumeHugh Dickins
After resume on a 2cpu laptop, kernel builds collapse with a sed hang, sh or make segfault (often on 20295564), real-time signal to cc1 etc. Several hurdles to jump, but a manually-assisted bisect led to -rc1's d2bcbad5f3ad38a1c09861bca7e252dde7bb8259 x86: do not zap_low_mappings in __smp_prepare_cpus. Though the low mappings were removed at bootup, they were left behind (with Global flags helping to keep them in TLB) after resume or cpu online, causing the crashes seen. Reinstate zap_low_mappings (with local __flush_tlb_all) for each cpu_up on x86_32. This used to be serialized by smp_commenced_mask: that's now gone, but a low_mappings flag will do. No need for native_smp_cpus_done to repeat the zap: let mem_init zap BSP's low mappings just like on UP. (In passing, fix error code from native_cpu_up: do_boot_cpu returns a variety of diagnostic values, Dprintk what it says but convert to -EIO. And save_pg_dir separately before zap_low_mappings: doesn't matter now, but zapping twice in succession wiped out resume's swsusp_pg_dir.) That worked well on the duo and one quad, but wouldn't boot 3rd or 4th cpu on P4 Xeon, oopsing just after unlock_ipi_call_lock. The TLB flush IPI now being sent reveals a long-standing bug: the booting cpu has its APIC readied in smp_callin at the top of start_secondary, but isn't put into the cpu_online_map until just before that unlock_ipi_call_lock. So native_smp_call_function_mask to online cpus would send_IPI_allbutself, including the cpu just coming up, though it has been excluded from the count to wait for: by the time it handles the IPI, the call data on native_smp_call_function_mask's stack may well have been overwritten. So fall back to send_IPI_mask while cpu_online_map does not match cpu_callout_map: perhaps there's a better APICological fix to be made at the start_secondary end, but I wouldn't know that. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-12x86: wakeup.lds.S - section ordering fixCyrill Gorcunov
To allow linker to catch sections overlapping we have to declare them in appropriate order. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-12x86: [VOYAGER] fix duplicate phys_cpu_present_map symbolJames Bottomley
The phys_cpu_present_map is an expected symbol in the SMP harness. Unfortunately, x86 recently moved this and a few others to kernel/setup.c where it doesn't quite work because voyager has to define its own. Use CONFIG_X86_LOCAL_APIC to isolate these definitions and fix up another area in setup.c where CONFIG_X86_SMP should be used instead of CONFIG_SMP. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: toralf.foerster@gmx.de Cc: Mike Travis <travis@sgi.com> Cc: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-12x86/pci: fix broken ISA DMATakashi Iwai
Rene Herman reported: > commit 8779f2fc3b84ebb6c5181fb13d702e9944c16069 > > "x86: don't try to allocate from DMA zone at first" > > breaks all of ISA DMA. Or all of ALSA ISA DMA at least. All > ISA soundcards are silent following that commit -- no error > messages, everything appears fine, just silence. That patch is buggy. We had an implicit assumption that dev = NULL for ISA devices that require 24bit DMA. The recent work on x86 dma_alloc_coherent() breaks the ISA DMA buffer allocation, which is represented by "dev = NULL" and requires 24bit DMA implicitly. Bisected-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Tested-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: x86: rdc: leds build/config fix x86: sysfs cpu?/topology is empty in 2.6.25 (32-bit Intel system) x86: revert commit 709f744 ("x86: bitops asm constraint fixes") x86: restrict keyboard io ports reservation to make ipmi driver work x86: fix fpu restore from sig return x86: remove spew print out about bus to node mapping x86: revert printk format warning change which is for linux-next x86: cleanup PAT cpu validation x86: geode: define geode_has_vsa2() even if CONFIG_MGEODE_LX is not set x86: GEODE: cache results from geode_has_vsa2() and uninline x86: revert geode config dependency
2008-05-10x86: restrict keyboard io ports reservation to make ipmi driver workHelge Wagner
On some of our (single board computer) boards (x86) we are using an IPMI controller that uses I/O ports 0x62 and 0x66 for a KCS (keyboard controller style) IPMI system interface. Trying to load the openipmi driver fails, because the ports (0x62/0x66) are reserved for keyboard. keyboard reserves the full range 0x60-0x6F while it doesn't need to. Reserve only ports 0x60 and 0x64 for the legacy PS/2 i8042 keyboad controller instead of 0x60-0x6F to allow the openipmi driver to work. [ tglx: added 64bit fixup ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-10x86: fix fpu restore from sig returnSuresh Siddha
If the task never used fpu, initialize the fpu before restoring the FP state from the signal handler context. This will allocate the fpu state, if the task never needed it before. Reported-and-bisected-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Tested-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Frederik Deweerdt <deweerdt@free.fr> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-10x86: revert printk format warning change which is for linux-nextThomas Gleixner
commit 62179849b40aded9e727cca5006627a1c4d6446e x86: fix setup printk format warning is for linux-next and not for .26 Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-08x86: cleanup PAT cpu validationThomas Gleixner
Move the scattered checks for PAT support to a single function. Its moved to addon_cpuid_features.c as this file is shared between 32 and 64 bit. Remove the manipulation of the PAT feature bit and just disable PAT in the PAT layer, based on the PAT bit provided by the CPU and the current CPU version/model white list. Change the boot CPU check so it works on Voyager somewhere in the future as well :) Also panic, when a secondary has PAT disabled but the primary one has alrady switched to PAT. We have no way to undo that. The white list is kept for now to ensure that we can rely on known to work CPU types and concentrate on the software induced problems instead of fighthing CPU erratas and subtle wreckage caused by not yet verified CPUs. Once the PAT code has stabilized enough, we can remove the white list and open the can of worms. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-08x86: GEODE: cache results from geode_has_vsa2() and uninlineAndres Salomon
This moves geode_has_vsa2 into a .c file, caches the result we get from the VSA virtual registers, and causes the function to no longer be inline. [akpm@linux-foundation.org: cleanup] Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-07pcspkr: fix dependanciesStas Sergeev
fix pcspkr dependancies: make the pcspkr platform drivers to depend on a platform device, and not the other way around. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Dmitry Torokhov <dtor@mail.ru> CC: Vojtech Pavlik <vojtech@suse.cz> CC: Michael Opdenacker <michael-lists@free-electrons.com> [fixed for 2.6.26-rc1 by tiwai] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-fixes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-fixes: x86: fix setup printk format warning x86: olpc build fix x86: video/fbdev.c: add MODULE_LICENSE x86: fix up bootparam.h for userspace inclusion x86: relocs ELF handling - use SELFMAG instead of numeric constant x86: vdso ELF handling - use SELFMAG instead of numeric constant x86: remove dell reboot dmi quirk board name match x86: es7000 build fix x86: make additional_cpus static x86: make start_secondary() static kbuild, suspend, x86: fix rebuild of wakeup.bin uml: fix gcc problem x86: undo visws/numaq build changes
2008-05-04x86: fix setup printk format warningRandy Dunlap
Fix x86 setup printk format warming: next-20080430/arch/x86/kernel/setup.c:172: warning: format '%lu' expects type 'long unsigned int', but argument 2 has type 'ssize_t' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: mingo@elte.hu Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-04x86: remove dell reboot dmi quirk board name matchBen
http://bugzilla.kernel.org/show_bug.cgi?id=10547 Newer Dell OptiPlex 745s hang before rebooting after 'sudo reboot'. A patch for some versions of the OptiPlex was proposed here -- http://lkml.org/lkml/2007/6/5/59 -- and is included in 2.6.23 and later kernels, according to http://lxr.linux.no/linux+v2.6.23/arch/i386/kernel/reboot.c . However, the DMI_BOARD_NAME ("0WF810") is too restrictive. Newer OptiPlex machines have a DMI_BOARD_NAME of "0RF703". I therefore suggest adding another clause to reboot.c, similar to the one in the original patch, but matching a DMI_BOARD_NAME of "0RF703". On further inspection, it seems that there are other DMI_BOARD_NAMEs for this same machine. They seem to change from time to time, which means that the current code is fragile. Moreover, using bios reboot should not break non-SFF OptiPlex 745s, and so a reasonable fix is to simply drop the match on DMI_BOARD_NAME. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-04x86: es7000 build fixIngo Molnar
2008-05-04x86: make additional_cpus staticAdrian Bunk
This patch makes the needlessly global additional_cpus static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-04x86: make start_secondary() staticAdrian Bunk
start_secondary() needlessly became global. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-04kbuild, suspend, x86: fix rebuild of wakeup.binSam Ravnborg
In kernel/acpi/realmode/Makefile use the 'always' variable to say that wakeup.bin should always be made. In acpi/Makefile we then do not need to specify the requested target and we avoid the message from make: `arch/x86/kernel/acpi/realmode/wakeup.bin' is up to date. Add wakeup.lds to list af targets to avoid rebuilding wakeup.bin - from Roland McGrath. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@suse.cz> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-04x86: KVM geust: make setup_secondary_clock definition dependent on local apicGlauber Costa
Since the pv_apic_ops are only present if CONFIG_X86_LOCAL_APIC is compiled in, kvmclock failed to build without this option. This patch fixes this. Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-03unified (weak) sys_pipe implementationUlrich Drepper
This replaces the duplicated arch-specific versions of "sys_pipe()" with one unified implementation. This removes almost 250 lines of duplicated code. It's marked __weak, so that *if* an architecture wants to override the default implementation it can do so by simply having its own replacement version, since many architectures use alternate calling conventions for the 'pipe()' system call for legacy reasons (ie traditional UNIX implementations often return the two file descriptors in registers) I still haven't changed the cris version even though Linus says the BKL isn't needed. The arch maintainer can easily do it if there are really no obstacles. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30fix: x86: support for new UV apicAndi Kleen
Don't warn in read_apic_id() when preemptible but only one CPU online. Signed-off-by: Andi Kleen <andi@firstfloor.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: fix early-BUG messageVegard Nossum
The .asciz directive takes any number of strings, but each one is zero- terminated, and string pasting is not done as in C. That results in only the first line being output. Replace .asciz with multiple .ascii directives and terminate with .asciz. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: iommu_sac_force can become staticDmitri Vorobiev
The iommu_sac_force variable is needlessly defined global, and this patch makes it static. Additionally, this variable needs not be explicitly initialized. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: add proper header for reboot_forceDmitri Vorobiev
This patch fixes one sparse warning by including the appropriate header for the reboot_force symbol. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86 VISWS: build fixIngo Molnar
the 'reboot_force' flag is a notion that non-PC subarchitectures do not have. also, unify the X86_BIOS_REBOOT option between 32-bit and 64-bit and get rid of a few unnecessary Kconfig and Makefile complications that way. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30hpet: fixIngo Molnar
Al Viro pointed out that there's a missing readl() of timer->hpet_config, found by Sparse. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits) ACPI: Fix acpi_processor_idle and idle= boot parameters interaction acpi: fix section mismatch warning in pnpacpi intel_menlo: fix build warning ACPI: Cleanup: Remove unneeded, multiple local dummy variables ACPI: video - fix permissions on some proc entries ACPI: video - properly handle errors when registering proc elements ACPI: video - do not store invalid entries in attached_array list ACPI: re-name acpi_pm_ops to acpi_suspend_ops ACER_WMI/ASUS_LAPTOP: fix build bug thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed ACPI: check a return value correctly in acpi_power_get_context() #if 0 acpi/bay.c:eject_removable_drive() eeepc-laptop: add hwmon fan control eeepc-laptop: add backlight eeepc-laptop: add base driver ACPI: thinkpad-acpi: bump up version to 0.20 ACPI: thinkpad-acpi: fix selects in Kconfig ACPI: thinkpad-acpi: use a private workqueue ACPI: thinkpad-acpi: fluff really minor fix ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation ... Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c manually.
2008-04-30Merge branches 'release', 'acpica', 'bugzilla-10224', 'bugzilla-9772', ↵Len Brown
'bugzilla-9916', 'ec', 'eeepc', 'idle', 'misc', 'pm-legacy', 'sysfs-links-2.6.26', 'thermal', 'thinkpad' and 'video' into release
