The nfsservctl system call is now gone, so we should remove all
linkage for it.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
32bit and 64bit on x86 are tested and working. The rest I have looked
at closely and I can't find any problems.
setns is an easy system call to wire up. It just takes two ints so I
don't expect any weird architecture porting problems.
While doing this I have noticed that we have some architectures that are
very slow to get new system calls. cris seems to be the slowest where
the last system calls wired up were preadv and pwritev. avr32 is weird
in that recvmmsg was wired up but never declared in unistd.h. frv is
behind with perf_event_open being the last syscall wired up. On h8300
the last system call wired up was epoll_wait. On m32r the last system
call wired up was fallocate. mn10300 has recvmmsg as the last system
call wired up. The rest seem to at least have syncfs wired up which was
new in the 2.6.39.
v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com>
v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com>
v4: Moved wiring up of the system call to another patch
v5: ported to v2.6.39-rc6
v6: rebased onto parisc-next and net-next to avoid syscall conflicts.
v7: ported to Linus's latest post 2.6.39 tree.
> arch/blackfin/include/asm/unistd.h | 3 ++-
> arch/blackfin/mach-common/entry.S | 1 +
Oh - ia64 wiring looks good.
Acked-by: Tony Luck <tony.luck@intel.com>
This patch adds a multiple message send syscall and is the send
version of the existing recvmmsg syscall. This is heavily
based on the patch by Arnaldo that added recvmmsg.
I wrote a microbenchmark to test the performance gains of using
this new syscall:
http://ozlabs.org/~anton/junkcode/sendmmsg_test.c
The test was run on a ppc64 box with a 10 Gbit network card. The
benchmark can send both UDP and RAW ethernet packets.
64B UDP
batch pkts/sec
1 804570
2 872800 (+ 8 %)
4 916556 (+14 %)
8 939712 (+17 %)
16 952688 (+18 %)
32 956448 (+19 %)
64 964800 (+20 %)
64B raw socket
batch pkts/sec
1 1201449
2 1350028 (+12 %)
4 1461416 (+22 %)
8 1513080 (+26 %)
16 1541216 (+28 %)
32 1553440 (+29 %)
64 1557888 (+30 %)
We see a 20% improvement in throughput on UDP send and 30%
on raw socket send.
[ Add sparc syscall entries. -DaveM ]
It is frequently useful to sync a single file system, instead of all
mounted file systems via sync(2):
- On machines with many mounts, it is not at all uncommon for some of
them to hang (e.g. unresponsive NFS server). sync(2) will get stuck on
those and may never get to the one you do care about (e.g., /).
- Some applications write lots of data to the file system and then
want to make sure it is flushed to disk. Calling fsync(2) on each
file introduces unnecessary ordering constraints that result in a large
amount of sub-optimal writeback/flush/commit behavior by the file
system.
There are currently two ways (that I know of) to sync a single super_block:
- BLKFLSBUF ioctl on the block device: That also invalidates the bdev
mapping, which isn't usually desirable, and doesn't work for non-block
file systems.
- 'mount -o remount,rw' will call sync_filesystem as an artifact of the
current implemention. Relying on this little-known side effect for
something like data safety sounds foolish.
Both of these approaches require root privileges, which some applications
do not have (nor should they need?) given that sync(2) is an unprivileged
operation.
This patch introduces a new system call syncfs(2) that takes an fd and
syncs only the file system it references. Maybe someday we can
$ sync /some/path
and not get
sync: ignoring all arguments
The syscall is motivated by comments by Al and Christoph at the last LSF.
syncfs(2) seems like an appropriate name given statfs(2).
A similar ioctl was also proposed a while back, see
http://marc.info/?l=linux-fsdevel&m=127970513829285&w=2
Signed-off-by: Sage Weil <sage@newdream.net>
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (62 commits)
posix-clocks: Check write permissions in posix syscalls
hrtimer: Remove empty hrtimer_init_hres_timer()
hrtimer: Update hrtimer->state documentation
hrtimer: Update base[CLOCK_BOOTTIME].offset correctly
timers: Export CLOCK_BOOTTIME via the posix timers interface
timers: Add CLOCK_BOOTTIME hrtimer base
time: Extend get_xtime_and_monotonic_offset() to also return sleep
time: Introduce get_monotonic_boottime and ktime_get_boottime
hrtimers: extend hrtimer base code to handle more then 2 clockids
ntp: Remove redundant and incorrect parameter check
mn10300: Switch do_timer() to xtimer_update()
posix clocks: Introduce dynamic clocks
posix-timers: Cleanup namespace
posix-timers: Add support for fd based clocks
x86: Add clock_adjtime for x86
posix-timers: Introduce a syscall for clock tuning.
time: Splitout compat timex accessors
ntp: Add ADJ_SETOFFSET mode bit
time: Introduce timekeeping_inject_offset
posix-timer: Update comment
Fix up new system-call-related conflicts in
arch/x86/ia32/ia32entry.S
arch/x86/include/asm/unistd_32.h
arch/x86/include/asm/unistd_64.h
arch/x86/kernel/syscall_table_32.S
(name_to_handle_at()/open_by_handle_at() vs clock_adjtime()), and some
due to movement of get_jiffies_64() in:
kernel/time.c
This patch adds new syscalls to x86_32
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
This patch adds the clock_adjtime system call to the x86 architecture.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
Acked-by: John Stultz <johnstul@us.ibm.com>
LKML-Reference: <20110201134419.968905083@linutronix.de>
As pointed out by Jiri Slaby: when I resolved the the 32-bit x85 system
call entry tables for prlimit (due to the conflict with fanotify), I
forgot to add the numbering in comments that we do for every fifth entry.
Reported-by: Jiri Slaby <jslaby@suse.cz>
* 'writable_limits' of git://decibel.fi.muni.cz/~xslaby/linux:
unistd: add __NR_prlimit64 syscall numbers
rlimits: implement prlimit64 syscall
rlimits: switch more rlimit syscalls to do_prlimit
rlimits: redo do_setrlimit to more generic do_prlimit
rlimits: add rlimit64 structure
rlimits: do security check under task_lock
rlimits: allow setrlimit to non-current tasks
rlimits: split sys_setrlimit
rlimits: selinux, do rlimits changes under task_lock
rlimits: make sure ->rlim_max never grows in sys_setrlimit
rlimits: add task_struct to update_rlimit_cpu
rlimits: security, add task_struct to setrlimit
Fix up various system call number conflicts. We not only added fanotify
system calls in the meantime, but asm-generic/unistd.h added a wait4
along with a range of reserved per-architecture system calls.
This patch simply declares the new sys_fanotify_mark syscall
int fanotify_mark(int fanotify_fd, unsigned int flags, u64_mask,
int dfd const char *pathname)
Signed-off-by: Eric Paris <eparis@redhat.com>
This patch defines a new syscall fanotify_init() of the form:
int sys_fanotify_init(unsigned int flags, unsigned int event_f_flags,
unsigned int priority)
This syscall is used to create and fanotify group. This is very similar to
the inotify_init() syscall.
Add __NR_prlimit64 syscall numbers to asm-generic. Add them also to
asm-x86, both 32 and 64-bit.
Add a generic implementation of the old mmap() syscall, which expects its
argument in a memory block and switch all architectures over to use it.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Reviewed-by: H. Peter Anvin <hpa@zytor.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Greg Ungerer <gerg@uclinux.org>
Add a generic implementation of the old select() syscall, which expects
its argument in a memory block and switch all architectures over to use
it.
Acked-by: Andreas Schwab <schwab@linux-m68k.org>
New helper - sys_mmap_pgoff(); switch syscalls to using it.
Meaning receive multiple messages, reducing the number of syscalls and
net stack entry/exit operations.
Next patches will introduce mechanisms where protocols that want to
optimize this operation will provide an unlocked_recvmsg operation.
This takes into account comments made by:
. Paul Moore: sock_recvmsg is called only for the first datagram,
sock_recvmsg_nosec is used for the rest.
. Caitlin Bestler: recvmmsg now has a struct timespec timeout, that
works in the same fashion as the ppoll one.
If the underlying protocol returns a datagram with MSG_OOB set, this
will make recvmmsg return right away with as many datagrams (+ the OOB
one) it has received so far.
. Rémi Denis-Courmont & Steven Whitehouse: If we receive N < vlen
datagrams and then recvmsg returns an error, recvmmsg will return
the successfully received datagrams, store the error and return it
in the next call.
This paves the way for a subsequent optimization, sk_prot->unlocked_recvmsg,
where we will be able to acquire the lock only at batch start and end, not at
every underlying recvmsg call.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Bye-bye Performance Counters, welcome Performance Events!
In the past few months the perfcounters subsystem has grown out its
initial role of counting hardware events, and has become (and is
becoming) a much broader generic event enumeration, reporting, logging,
monitoring, analysis facility.
Naming its core object 'perf_counter' and naming the subsystem
'perfcounters' has become more and more of a misnomer. With pending
code like hw-breakpoints support the 'counter' name is less and
less appropriate.
All in one, we've decided to rename the subsystem to 'performance
events' and to propagate this rename through all fields, variables
and API names. (in an ABI compatible fashion)
The word 'event' is also a bit shorter than 'counter' - which makes
it slightly more convenient to write/handle as well.
Thanks goes to Stephane Eranian who first observed this misnomer and
suggested a rename.
User-space tooling and ABI compatibility is not affected - this patch
should be function-invariant. (Also, defconfigs were not touched to
keep the size down.)
This patch has been generated via the following script:
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/PERF_EVENT_/PERF_RECORD_/g' \
-e 's/PERF_COUNTER/PERF_EVENT/g' \
-e 's/perf_counter/perf_event/g' \
-e 's/nb_counters/nb_events/g' \
-e 's/swcounter/swevent/g' \
-e 's/tpcounter_event/tp_event/g' \
$FILES
for N in $(find . -name perf_counter.[ch]); do
M=$(echo $N | sed 's/perf_counter/perf_event/g')
mv $N $M
done
FILES=$(find . -name perf_event.*)
sed -i \
-e 's/COUNTER_MASK/REG_MASK/g' \
-e 's/COUNTER/EVENT/g' \
-e 's/\<event\>/event_id/g' \
-e 's/counter/event/g' \
-e 's/Counter/Event/g' \
$FILES
... to keep it as correct as possible. This script can also be
used by anyone who has pending perfcounters patches - it converts
a Linux kernel tree over to the new naming. We tried to time this
change to the point in time where the amount of pending patches
is the smallest: the end of the merge window.
Namespace clashes were fixed up in a preparatory patch - and some
stylistic fallout will be fixed up in a subsequent patch.
( NOTE: 'counters' are still the proper terminology when we deal
with hardware registers - and these sed scripts are a bit
over-eager in renaming them. I've undone some of that, but
in case there's something left where 'counter' would be
better than 'event' we can undo that on an individual basis
instead of touching an otherwise nicely automated patch. )
Suggested-by: Stephane Eranian <eranian@google.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Paul Mackerras <paulus@samba.org>
Reviewed-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: <linux-arch@vger.kernel.org>
LKML-Reference: <new-submission>
This is necessary to avoid the conflict of syscall numbers.
Fixes up the borked syscall numbers of perfcounters versus
preadv/pwritev as well.
Make the new sys_rt_tgsigqueueinfo available for x86.
Merge reason: we have gathered quite a few conflicts, need to merge upstream
arch/powerpc/kernel/Makefile
arch/x86/include/asm/hardirq.h
arch/x86/kernel/cpu/common.c
arch/x86/kernel/irq.c
arch/x86/mm/iomap_32.c
include/linux/sched.h
kernel/Makefile
This patch adds preadv and pwritev system calls. These syscalls are a
pretty straightforward combination of pread and readv (same for write).
They are quite useful for doing vectored I/O in threaded applications.
Using lseek+readv instead opens race windows you'll have to plug with
locking.
Other systems have such system calls too, for example NetBSD, check
here: http://www.daemon-systems.org/man/preadv.2.html
The application-visible interface provided by glibc should look like
this to be compatible to the existing implementations in the *BSD family:
ssize_t preadv(int d, const struct iovec *iov, int iovcnt, off_t offset);
ssize_t pwritev(int d, const struct iovec *iov, int iovcnt, off_t offset);
This prototype has one problem though: On 32bit archs is the (64bit)
offset argument unaligned, which the syscall ABI of several archs doesn't
allow to do. At least s390 needs a wrapper in glibc to handle this. As
we'll need a wrappers in glibc anyway I've decided to push problem to
glibc entriely and use a syscall prototype which works without
arch-specific wrappers inside the kernel: The offset argument is
explicitly splitted into two 32bit values.
The patch sports the actual system call implementation and the windup in
the x86 system call tables. Other archs follow as separate patches.
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
Cc: <linux-api@vger.kernel.org>
arch/x86/Kconfig
arch/x86/kernel/apic.c
arch/x86/kernel/setup_percpu.c
Some syscalls need to access the pt_regs structure, either to copy
user register state or to modifiy it. This patch adds stubs to load
the address of the pt_regs struct into the %eax register, and changes
the syscalls to regparm(1) to receive the pt_regs pointer as the
first argument.
Signed-off-by: Brian Gerst <brgerst@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
include/linux/syscalls.h
This way it matches the generic system call name convention.
Implement performance counters for x86 Intel CPUs.
It's simplified right now: the PERFMON CPU feature is assumed,
which is available in Core2 and later Intel CPUs.
The design is flexible to be extended to more CPU types as well.
Remove the size parameter from the new epoll_create syscall and renames the
syscall itself. The updated test program follows.
#include <fcntl.h>
#include <stdio.h>
#include <time.h>
#include <unistd.h>
#include <sys/syscall.h>
#ifndef __NR_epoll_create2
# ifdef __x86_64__
# define __NR_epoll_create2 291
# elif defined __i386__
# define __NR_epoll_create2 329
# else
# error "need __NR_epoll_create2"
# endif
#endif
#define EPOLL_CLOEXEC O_CLOEXEC
int
main (void)
int fd = syscall (__NR_epoll_create2, 0);
if (fd == -1)
puts ("epoll_create2(0) failed");
return 1;
int coe = fcntl (fd, F_GETFD);
if (coe == -1)
puts ("fcntl failed");
return 1;
if (coe & FD_CLOEXEC)
puts ("epoll_create2(0) set close-on-exec flag");
return 1;
close (fd);
fd = syscall (__NR_epoll_create2, EPOLL_CLOEXEC);
if (fd == -1)
puts ("epoll_create2(EPOLL_CLOEXEC) failed");
return 1;
if (coe == -1)
return 1;
if ((coe & FD_CLOEXEC) == 0)
puts ("epoll_create2(EPOLL_CLOEXEC) set close-on-exec flag");
return 1;
close (fd);
puts ("OK");
return 0;
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Acked-by: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
This patch introduces the new syscall inotify_init1 (note: the 1 stands for
the one parameter the syscall takes, as opposed to no parameter before). The
values accepted for this parameter are function-specific and defined in the
inotify.h header. Here the values must match the O_* flags, though. In this
patch CLOEXEC support is introduced.
The following test must be adjusted for architectures other than x86 and
x86-64 and in case the syscall numbers changed.
#include <fcntl.h>
#include <stdio.h>
#include <unistd.h>
#ifndef __NR_inotify_init1
# ifdef __x86_64__
# define __NR_inotify_init1 294
# define __NR_inotify_init1 332
# else
# error "need __NR_inotify_init1"
# endif
#endif
#define IN_CLOEXEC O_CLOEXEC
int
main (void)
int fd;
fd = syscall (__NR_inotify_init1, 0);
if (fd == -1)
puts ("inotify_init1(0) failed");
return 1;
if (coe == -1)
return 1;
puts ("inotify_init1(0) set close-on-exit");
return 1;
close (fd);
fd = syscall (__NR_inotify_init1, IN_CLOEXEC);
if (fd == -1)
puts ("inotify_init1(IN_CLOEXEC) failed");
return 1;
if (coe == -1)
return 1;
puts ("inotify_init1(O_CLOEXEC) does not set close-on-exit");
return 1;
close (fd);
puts ("OK");
return 0;
[akpm@linux-foundation.org: add sys_ni stub]
This patch introduces the new syscall pipe2 which is like pipe but it also
takes an additional parameter which takes a flag value. This patch implements
the handling of O_CLOEXEC for the flag. I did not add support for the new
syscall for the architectures which have a special sys_pipe implementation. I
think the maintainers of those archs have the chance to go with the unified
implementation but that's up to them.
The implementation introduces do_pipe_flags. I did that instead of changing
all callers of do_pipe because some of the callers are written in assembler.
I would probably screw up changing the assembly code. To avoid breaking code
do_pipe is now a small wrapper around do_pipe_flags. Once all callers are
changed over to do_pipe_flags the old do_pipe function can be removed.
#include <fcntl.h>
#include <stdio.h>
#include <unistd.h>
#ifndef __NR_pipe2
# ifdef __x86_64__
# define __NR_pipe2 293
# define __NR_pipe2 331
# else
# error "need __NR_pipe2"
# endif
#endif
int
main (void)
int fd[2];
if (syscall (__NR_pipe2, fd, 0) != 0)
puts ("pipe2(0) failed");
return 1;
for (int i = 0; i < 2; ++i)
int coe = fcntl (fd[i], F_GETFD);
if (coe == -1)
return 1;
printf ("pipe2(0) set close-on-exit for fd[%d]\n", i);
return 1;
close (fd[0]);
close (fd[1]);
if (syscall (__NR_pipe2, fd, O_CLOEXEC) != 0)
puts ("pipe2(O_CLOEXEC) failed");
return 1;
if (coe == -1)
return 1;
printf ("pipe2(O_CLOEXEC) does not set close-on-exit for fd[%d]\n", i);
return 1;
close (fd[0]);
close (fd[1]);
puts ("OK");
return 0;
This patch adds the new dup3 syscall. It extends the old dup2 syscall by one
parameter which is meant to hold a flag value. Support for the O_CLOEXEC flag
is added in this patch.
#include <fcntl.h>
#include <stdio.h>
#include <time.h>
#include <unistd.h>
#ifndef __NR_dup3
# ifdef __x86_64__
# define __NR_dup3 292
# define __NR_dup3 330
# else
# error "need __NR_dup3"
# endif
#endif
int
main (void)
int fd = syscall (__NR_dup3, 1, 4, 0);
if (fd == -1)
puts ("dup3(0) failed");
return 1;
if (coe == -1)
return 1;
puts ("dup3(0) set close-on-exec flag");
return 1;
close (fd);
fd = syscall (__NR_dup3, 1, 4, O_CLOEXEC);
if (fd == -1)
puts ("dup3(O_CLOEXEC) failed");
return 1;
if (coe == -1)
return 1;
puts ("dup3(O_CLOEXEC) set close-on-exec flag");
return 1;
close (fd);
puts ("OK");
return 0;
This patch adds the new epoll_create2 syscall. It extends the old epoll_create
syscall by one parameter which is meant to hold a flag value. In this
patch the only flag support is EPOLL_CLOEXEC which causes the close-on-exec
flag for the returned file descriptor to be set.
A new name EPOLL_CLOEXEC is introduced which in this implementation must
have the same value as O_CLOEXEC.
#include <fcntl.h>
#include <stdio.h>
#include <time.h>
#include <unistd.h>
# ifdef __x86_64__
# else
# endif
#endif
int
main (void)
int fd = syscall (__NR_epoll_create2, 1, 0);
if (fd == -1)
return 1;
if (coe == -1)
return 1;
return 1;
close (fd);
fd = syscall (__NR_epoll_create2, 1, EPOLL_CLOEXEC);
if (fd == -1)
return 1;
if (coe == -1)
return 1;
return 1;
close (fd);
puts ("OK");
return 0;
This patch adds the new eventfd2 syscall. It extends the old eventfd
patch the only flag support is EFD_CLOEXEC which causes the close-on-exec
A new name EFD_CLOEXEC is introduced which in this implementation must
#include <fcntl.h>
#include <stdio.h>
#include <unistd.h>
#ifndef __NR_eventfd2
# ifdef __x86_64__
# define __NR_eventfd2 290
# define __NR_eventfd2 328
# else
# error "need __NR_eventfd2"
# endif
#endif
#define EFD_CLOEXEC O_CLOEXEC
int
main (void)
int fd = syscall (__NR_eventfd2, 1, 0);
if (fd == -1)
puts ("eventfd2(0) failed");
return 1;
if (coe == -1)
return 1;
puts ("eventfd2(0) sets close-on-exec flag");
return 1;
close (fd);
fd = syscall (__NR_eventfd2, 1, EFD_CLOEXEC);
if (fd == -1)
puts ("eventfd2(EFD_CLOEXEC) failed");
return 1;
if (coe == -1)
return 1;
puts ("eventfd2(EFD_CLOEXEC) does not set close-on-exec flag");
return 1;
close (fd);
puts ("OK");
return 0;
This patch adds the new signalfd4 syscall. It extends the old signalfd
patch the only flag support is SFD_CLOEXEC which causes the close-on-exec
A new name SFD_CLOEXEC is introduced which in this implementation must
#include <fcntl.h>
#include <signal.h>
#include <stdio.h>
#include <unistd.h>
#ifndef __NR_signalfd4
# ifdef __x86_64__
# define __NR_signalfd4 289
# define __NR_signalfd4 327
# else
# error "need __NR_signalfd4"
# endif
#endif
#define SFD_CLOEXEC O_CLOEXEC
int
main (void)
sigset_t ss;
sigemptyset (&ss);
sigaddset (&ss, SIGUSR1);
int fd = syscall (__NR_signalfd4, -1, &ss, 8, 0);
if (fd == -1)
puts ("signalfd4(0) failed");
return 1;
if (coe == -1)
return 1;
puts ("signalfd4(0) set close-on-exec flag");
return 1;
close (fd);
fd = syscall (__NR_signalfd4, -1, &ss, 8, SFD_CLOEXEC);
if (fd == -1)
puts ("signalfd4(SFD_CLOEXEC) failed");
return 1;
if (coe == -1)
return 1;
puts ("signalfd4(SFD_CLOEXEC) does not set close-on-exec flag");
return 1;
close (fd);
puts ("OK");
return 0;
Wires up the new timerfd API to the x86 family.
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
