path: root/arch/x86/kernel/sigframe.h
2008-12-18x86: signal: move sigframe.h to arch/x86/include/asmHiroshi Shimamoto
Impact: cleanup, move header file Move arch/x86/kernel/sigframe.h to arch/x86/include/asm/sigframe.h. It will be used in arch/x86/ia32/ia32_signal.c. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-18x86: signal: rename sigframe and rt_sigframe on 32-bitHiroshi Shimamoto
Impact: cleanup, prepare to move sigframe.h On 32-bit, rename struct sigrame to struct sigframe_ia32, struct rt_sigframe to struct rt_sigframe_ia32 and several structures. And add helper macros to access the above data in arch/x86/kernel/signal.c. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-18x86: signal: move ia32 func declarations into arch/x86/kernel/signal.cHiroshi Shimamoto
Impact: cleanup Move declarations of ia32_setup_rt_frame() and ia32_setup_frame() into arch/x86/kernel/signal.c. This is for future use of sigframe.h. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-11Merge branch 'x86/unify-cpu-detect' into x86-v28-for-linus-phase4-DIngo Molnar
Conflicts: arch/x86/kernel/cpu/common.c arch/x86/kernel/signal_64.c include/asm-x86/cpufeature.h
2008-07-31x86: coding style fixes to arch/x86/kernel/signal_64.cGustavo F. Padovan
Fix all errors and many warnings reported by checkpatch.pl without change signal_64.o arch/x86/kernel/signal_64.o text data bss dec hex filename 5143 0 8 5151 141f signal_64.o.after 5143 0 8 5151 141f signal_64.o.before md5: e68718092b3641cb27e79e55ce57e3ad signal_64.o.after e68718092b3641cb27e79e55ce57e3ad signal_64.o.before Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-30x86, xsave: dynamically allocate sigframes fpstate instead of static allocationSuresh Siddha
dynamically allocate fpstate on the stack, instead of static allocation in the current sigframe layout on the user stack. This will allow the fpstate structure to grow in the future, which includes extended state information supporting xsave/xrstor. signal handlers will be able to access the fpstate pointer from the sigcontext structure asusual, with no change. For the non RT sigframe's (which are supported only for 32bit apps), current static fpstate layout in the sigframe will be unused(so that we don't change the extramask[] offset in the sigframe and thus prevent breaking app's which modify extramask[]). Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move struct definitions to unifed sigframe.hHarvey Harrison
[ tglx@linutronix.de: cleanup the other structs as well ] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
