The file names are somehow misleading as the code is not specific to
AMD K8 CPUs anymore. The files accomodate code for other AMD CPU
northbridges as well.
Same is true for the config option which is valid for AMD CPU
northbridges in general and not specific to K8.
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
LKML-Reference: <20100917160343.GD4958@loge.amd.com>
So far we only provide num_k8_northbridges. This is required in
different areas (e.g. L3 cache index disable, GART). But not all AMD
CPUs provide a GART. Thus it is useful to split off the GART handling
from the generic caching of AMD northbridge misc devices.
LKML-Reference: <20100917160254.GC4958@loge.amd.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
systems
de957628ce7c84764ff41331111036b3ae5bad0f changed setting of the
x86_init.iommu.iommu_init function ptr only when GART IOMMU is
found.
One side effect of it is that num_k8_northbridges
is not initialized anymore if not explicitly
called. This resulted in uninitialized pointers in
<arch/x86/kernel/cpu/intel_cacheinfo.c:amd_calc_l3_indices()>,
for example, which uses the num_k8_northbridges thing through
node_to_k8_nb_misc().
Fix that through an initcall that runs right after the PCI
subsystem and does all the scanning. Then, remove initialization
in gart_iommu_init() which is a rootfs_initcall and we're
running before that.
What is more, since num_k8_northbridges is being used in other
places beside GART IOMMU, include it whenever we add AMD CPU
support. The previous dependency chain in kconfig contained
K8_NB depends on AGP_AMD64|GART_IOMMU
which was clearly incorrect. The more natural way in terms of
hardware dependency should be
AGP_AMD64|GART_IOMMU depends on K8_NB depends on CPU_SUP_AMD &&
PCI. Make it so Number One!
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Joerg Roedel <joerg.roedel@amd.com>
LKML-Reference: <20100312144303.GA29262@aftab>
Tested-by: Joerg Roedel <joerg.roedel@amd.com>
Impact: fix AMD Family 11h boot hangs / USB device problems
The AMD Fam11h CPUs have a K8 northbridge. This northbridge is different
from other family's because it lacks GART support (as I just learned).
But the kernel implicitly expects a GART if it finds an AMD northbridge.
Fix this by removing the Fam11h northbridge id from the scan list of K8
northbridges. This patch also changes the message in the GART driver
about missing K8 northbridges to tell that the GART is missing which is
the correct information in this case.
Reported-by: Jouni Malinen <jkmalinen@gmail.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
This patch adds the detection of the northbridges in the AMD family 0x11
processors. It also fixes the magic numbers there while changing this code.
