path: root/arch/x86/kernel/irqinit.c
2012-12-17x86, 386 removal: Remove support for IRQ 13 FPU error reportingH. Peter Anvin
Remove support for FPU error reporting via IRQ 13, as opposed to exception 16 (#MF). One last remnant of i386 gone. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Alan Cox <alan@linux.intel.com>
2012-06-27x86/tlb: replace INVALIDATE_TLB_VECTOR by CALL_FUNCTION_VECTORAlex Shi
There are 32 INVALIDATE_TLB_VECTOR now in kernel. That is quite big amount of vector in IDT. But it is still not enough, since modern x86 sever has more cpu number. That still causes heavy lock contention in TLB flushing. The patch using generic smp call function to replace it. That saved 32 vector number in IDT, and resolved the lock contention in TLB flushing on large system. In the NHM EX machine 4P * 8cores * HT = 64 CPUs, hackbench pthread has 3% performance increase. Signed-off-by: Alex Shi <alex.shi@intel.com> Link: http://lkml.kernel.org/r/1340845344-27557-9-git-send-email-alex.shi@intel.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-03-29Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cleanups from Peter Anvin: "The biggest textual change is the cleanup to use symbolic constants for x86 trap values. The only *functional* change and the reason for the x86/x32 dependency is the move of is_ia32_task() into <asm/thread_info.h> so that it can be used in other code that needs to understand if a system call comes from the compat entry point (and therefore uses i386 system call numbers) or not. One intended user for that is the BPF system call filter. Moving it out of <asm/compat.h> means we can define it unconditionally, returning always true on i386." * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Move is_ia32_task to asm/thread_info.h from asm/compat.h x86: Rename trap_no to trap_nr in thread_struct x86: Use enum instead of literals for trap values
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Disintegrate asm/system.h for X86David Howells
Disintegrate asm/system.h for X86. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> cc: x86@kernel.org
2012-03-23x86: use for_each_clear_bit_from()Akinobu Mita
Use for_each_clear_bit() to iterate over all the cleared bit in a memory region. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-09x86: Use enum instead of literals for trap valuesKees Cook
The traps are referred to by their numbers and it can be difficult to understand them while reading the code without context. This patch adds enumeration of the trap numbers and replaces the numbers with the correct enum for x86. Signed-off-by: Kees Cook <keescook@chromium.org> Link: http://lkml.kernel.org/r/20120310000710.GA32667@www.outflux.net Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2011-12-21driver-core: remove sysdev.h usage.Kay Sievers
The sysdev.h file should not be needed by any in-kernel code, so remove the .h file from these random files that seem to still want to include it. The sysdev code will be going away soon, so this include needs to be removed no matter what. Cc: Jiandong Zheng <jdzheng@broadcom.com> Cc: Scott Branden <sbranden@broadcom.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: "Venkatesh Pallipadi Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-16x86, mce: Replace MCE_SELF_VECTOR by irq_workHidetoshi Seto
The MCE handler uses a special vector for self IPI to invoke post-emergency processing in an interrupt context, e.g. call an NMI-unsafe function, wakeup loggers, schedule time-consuming work for recovery, etc. This mechanism is now generalized by the following commit: > e360adbe29241a0194e10e20595360dd7b98a2b3 > Author: Peter Zijlstra <a.p.zijlstra@chello.nl> > Date: Thu Oct 14 14:01:34 2010 +0800 > > irq_work: Add generic hardirq context callbacks > > Provide a mechanism that allows running code in IRQ context. It is > most useful for NMI code that needs to interact with the rest of the > system -- like wakeup a task to drain buffers. : So change to use provided generic mechanism. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Acked-by: Tony Luck <tony.luck@intel.com> Link: http://lkml.kernel.org/r/4DEED6B2.6080005@jp.fujitsu.com Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-03-15Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) x86: Clean up apic.c and apic.h x86: Remove superflous goal definition of tsc_sync x86: dt: Correct local apic documentation in device tree bindings x86: dt: Cleanup local apic setup x86: dt: Fix OLPC=y/INTEL_CE=n build rtc: cmos: Add OF bindings x86: ce4100: Use OF to setup devices x86: ioapic: Add OF bindings for IO_APIC x86: dtb: Add generic bus probe x86: dtb: Add support for PCI devices backed by dtb nodes x86: dtb: Add device tree support for HPET x86: dtb: Add early parsing of IO_APIC x86: dtb: Add irq domain abstraction x86: dtb: Add a device tree for CE4100 x86: Add device tree support x86: e820: Remove conditional early mapping in parse_e820_ext x86: OLPC: Make OLPC=n build again x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection x86: OLPC: Cleanup config maze completely x86: OLPC: Hide OLPC_OPENFIRMWARE config switch ... Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
2011-03-15Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (93 commits) x86, tlb, UV: Do small micro-optimization for native_flush_tlb_others() x86-64, NUMA: Don't call numa_set_distanc() for all possible node combinations during emulation x86-64, NUMA: Don't assume phys node 0 is always online in numa_emulation() x86-64, NUMA: Clean up initmem_init() x86-64, NUMA: Fix numa_emulation code with node0 without RAM x86-64, NUMA: Revert NUMA affine page table allocation x86: Work around old gas bug x86-64, NUMA: Better explain numa_distance handling x86-64, NUMA: Fix distance table handling mm: Move early_node_map[] reverse scan helpers under HAVE_MEMBLOCK x86-64, NUMA: Fix size of numa_distance array x86: Rename e820_table_* to pgt_buf_* bootmem: Move __alloc_memory_core_early() to nobootmem.c bootmem: Move contig_page_data definition to bootmem.c/nobootmem.c bootmem: Separate out CONFIG_NO_BOOTMEM code into nobootmem.c x86-64, NUMA: Seperate out numa_alloc_distance() from numa_set_distance() x86-64, NUMA: Add proper function comments to global functions x86-64, NUMA: Move NUMA emulation into numa_emulation.c x86-64, NUMA: Prepare numa_emulation() for moving NUMA emulation into a separate file x86-64, NUMA: Do not scan two times for setup_node_bootmem() ... Fix up conflicts in arch/x86/kernel/smpboot.c
2011-03-12x86: Mark low level interrupts IRQF_NO_THREADThomas Gleixner
These cannot be threaded. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-12x86: Cleanup the genirq name spaceThomas Gleixner
genirq is switching to a consistent name space for the irq related functions. Convert x86. Conversion was done with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-23x86: ioapic: Add OF bindings for IO_APICSebastian Andrzej Siewior
ioapic_xlate provides a translation from the information in device tree to ioapic related informations. This includes - obtaining hw irq which is the vector number "=> pin number + gsi" - obtaining type (level/edge/..) - programming this information into ioapic ioapic_add_ofnode adds an irq_domain based on informations from the device tree. This information (irq_domain) is required in order to map a device to its proper interrupt controller. [ tglx: Adapted to the io_apic changes, which let us move that whole code to devicetree.c ] Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: sodaville@linutronix.de Cc: devicetree-discuss@lists.ozlabs.org LKML-Reference: <1298405266-1624-10-git-send-email-bigeasy@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-23x86: dtb: Add early parsing of IO_APICSebastian Andrzej Siewior
APIC and IO_APIC have to be added to the system early because native_init_IRQ() requires it. In order to obtain the address of the ioapic the device tree has to be unflattened so of_address_to_resource() works. The device tree is relocated to ensure it is always covered by the kernel mapping. That way the boot loader does not have to make any assumptions about kernel's memory layout. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: sodaville@linutronix.de Cc: devicetree-discuss@lists.ozlabs.org Cc: Dirk Brandewie <dirk.brandewie@gmail.com> LKML-Reference: <1298405266-1624-6-git-send-email-bigeasy@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-14x86: Allocate 32 tlb_invalidate_interrupt handler stubsShaohua Li
Add up to 32 invalidate_interrupt handlers. How many handlers are added depends on NUM_INVALIDATE_TLB_VECTORS. So if NUM_INVALIDATE_TLB_VECTORS is smaller than 32, we reduce code size. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> LKML-Reference: <1295232725.1949.708.camel@sli10-conroe> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-21Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (96 commits) apic, x86: Use BIOS settings for IBS and MCE threshold interrupt LVT offsets apic, x86: Check if EILVT APIC registers are available (AMD only) x86: ioapic: Call free_irte only if interrupt remapping enabled arm: Use ARCH_IRQ_INIT_FLAGS genirq, ARM: Fix boot on ARM platforms genirq: Fix CONFIG_GENIRQ_NO_DEPRECATED=y build x86: Switch sparse_irq allocations to GFP_KERNEL genirq: Switch sparse_irq allocator to GFP_KERNEL genirq: Make sparse_lock a mutex x86: lguest: Use new irq allocator genirq: Remove the now unused sparse irq leftovers genirq: Sanitize dynamic irq handling genirq: Remove arch_init_chip_data() x86: xen: Sanitise sparse_irq handling x86: Use sane enumeration x86: uv: Clean up the direct access to irq_desc x86: Make io_apic.c local functions static genirq: Remove irq_2_iommu x86: Speed up the irq_remapped check in hot pathes intr_remap: Simplify the code further ... Fix up trivial conflicts in arch/x86/Kconfig
2010-10-18irq_work: Add generic hardirq context callbacksPeter Zijlstra
Provide a mechanism that allows running code in IRQ context. It is most useful for NMI code that needs to interact with the rest of the system -- like wakeup a task to drain buffers. Perf currently has such a mechanism, so extract that and provide it as a generic feature, independent of perf so that others may also benefit. The IRQ context callback is generated through self-IPIs where possible, or on architectures like powerpc the decrementer (the built-in timer facility) is set to generate an interrupt immediately. Architectures that don't have anything like this get to do with a callback from the timer tick. These architectures can call irq_work_run() at the tail of any IRQ handlers that might enqueue such work (like the perf IRQ handler) to avoid undue latencies in processing the work. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [ various fixes ] Signed-off-by: Huang Ying <ying.huang@intel.com> LKML-Reference: <1287036094.7768.291.camel@yhuang-dev> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-12x86: Remove useless reinitialization of irq descriptorsThomas Gleixner
The descriptors are already initialized in exactly this way. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-05-03x86: Merge simd_math_error() into math_error()Brian Gerst
The only difference between FPU and SIMD exceptions is where the status bits are read from (cwd/swd vs. mxcsr). This also fixes the discrepency introduced by commit adf77bac, which fixed FPU but not SIMD. Signed-off-by: Brian Gerst <brgerst@gmail.com> LKML-Reference: <1269176446-2489-3-git-send-email-brgerst@gmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-16x86: Handle legacy PIC interrupts on all the cpu'sSuresh Siddha
Ingo Molnar reported that with the recent changes of not statically blocking IRQ0_VECTOR..IRQ15_VECTOR's on all the cpu's, broke an AMD platform (with Nvidia chipset) boot when "noapic" boot option is used. On this platform, legacy PIC interrupts are getting delivered to all the cpu's instead of just the boot cpu. Thus not initializing the vector to irq mapping for the legacy irq's resulted in not handling certain interrupts causing boot hang. Fix this by initializing the vector to irq mapping on all the logical cpu's, if the legacy IRQ is handled by the legacy PIC. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> [ -v2: io-apic-enabled improvement ] Acked-by: Yinghai Lu <yinghai@kernel.org> Cc: Eric W. Biederman <ebiederm@xmission.com> LKML-Reference: <1268692386.3296.43.camel@sbs-t61.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-24x86, legacy_irq: Remove left over nr_legacy_irqsYinghai Lu
nr_legacy_irqs and its ilk have moved to legacy_pic. -v2: there is one in ioapic_.c Singed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <4B84AAC4.2020204@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-02-22Merge remote branch 'origin/x86/apic' into x86/mrstH. Peter Anvin
Conflicts: arch/x86/kernel/apic/io_apic.c
2010-02-19x86, pic: Make use of legacy_pic abstractionJacob Pan
This patch replaces legacy PIC-related global variable and functions with the new legacy_pic abstraction. Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com> LKML-Reference: <43F901BD926A4E43B106BF17856F07559FB80D04@orsmsx508.amr.corp.intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-01-19x86, irq: Don't block IRQ0_VECTOR..IRQ15_VECTOR's on all cpu'sSuresh Siddha
Currently IRQ0..IRQ15 are assigned to IRQ0_VECTOR..IRQ15_VECTOR's on all the cpu's. If these IRQ's are handled by legacy pic controller, then the kernel handles them only on cpu 0. So there is no need to block this vector space on all cpu's. Similarly if these IRQ's are handled by IO-APIC, then the IRQ affinity will determine on which cpu's we need allocate the vector resource for that particular IRQ. This can be done dynamically and here also there is no need to block 16 vectors for IRQ0..IRQ15 on all cpu's. Fix this by initially assigning IRQ0..IRQ15 to IRQ0_VECTOR..IRQ15_VECTOR's only on cpu 0. If the legacy controllers like pic handles these irq's, then this configuration will be fixed. If more modern controllers like IO-APIC handle these IRQ's, then we start with this configuration and as IRQ's migrate, vectors (/and cpu's) associated with these IRQ's change dynamically. This will freeup the block of 16 vectors on other cpu's which don't handle IRQ0..IRQ15, which can now be used for other IRQ's that the particular cpu handle. [ hpa: this also an architectural cleanup for future legacy-PIC-free configurations. ] [ hpa: fixed typo NR_LEGACY_IRQS -> NR_IRQS_LEGACY ] Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1263932453.2814.52.camel@sbs-t61.sc.intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-10-14x86: UV RTC: Rename generic_interrupt to x86_platform_ipiDimitri Sivanich
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> LKML-Reference: <20091014142257.GE11048@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (38 commits) x86: Move get/set_wallclock to x86_platform_ops x86: platform: Fix section annotations x86: apic namespace cleanup x86: Distangle ioapic and i8259 x86: Add Moorestown early detection x86: Add hardware_subarch ID for Moorestown x86: Add early platform detection x86: Move tsc_init to late_time_init x86: Move tsc_calibration to x86_init_ops x86: Replace the now identical time_32/64.c by time.c x86: time_32/64.c unify profile_pc x86: Move calibrate_cpu to tsc.c x86: Make timer setup and global variables the same in time_32/64.c x86: Remove mca bus ifdef from timer interrupt x86: Simplify timer_ack magic in time_32.c x86: Prepare unification of time_32/64.c x86: Remove do_timer hook x86: Add timer_init to x86_init_ops x86: Move percpu clockevents setup to x86_init_ops x86: Move xen_post_allocator_init into xen_pagetable_setup_done ... Fix up conflicts in arch/x86/include/asm/io_apic.h
2009-09-17Merge branch 'x86-mce-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (21 commits) x86, mce: Fix compilation with !CONFIG_DEBUG_FS in mce-severity.c x86, mce: CE in last bank prevents panic by unknown MCE x86, mce: Fake panic support for MCE testing x86, mce: Move debugfs mce dir creating to mce.c x86, mce: Support specifying raise mode for software MCE injection x86, mce: Support specifying context for software mce injection x86, mce: fix reporting of Thermal Monitoring mechanism enabled x86, mce: remove never executed code x86, mce: add missing __cpuinit tags x86, mce: fix "mce" boot option handling for CONFIG_X86_NEW_MCE x86, mce: don't log boot MCEs on Pentium M (model == 13) CPUs x86: mce: Lower maximum number of banks to architecture limit x86: mce: macros to compute banks MSRs x86: mce: Move per bank data in a single datastructure x86: mce: Move code in mce.c x86: mce: Rename CONFIG_X86_NEW_MCE to CONFIG_X86_MCE x86: mce: Remove old i386 machine check code x86: mce: Update X86_MCE description in x86/Kconfig x86: mce: Make CONFIG_X86_ANCIENT_MCE dependent on CONFIG_X86_MCE x86, mce: use atomic_inc_return() instead of add by 1 ... Manually fixed up trivial conflicts: Documentation/feature-removal-schedule.txt arch/x86/kernel/cpu/mcheck/mce.c
2009-09-16x86: platform: Fix section annotationsThomas Gleixner
init_IRQ() and x86_late_time_init() are missing __init annotations. The x86 platform ops variables are annotated, but the annotation needs to be put between the variable name and the "=" of the initializer. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-31x86: Move irq_init to x86_init_opsThomas Gleixner
irq_init is overridden by x86_quirks and by paravirts. Unify the whole mess and make it an unconditional x86_init_ops function which defaults to the standard function and can be overridden by the early platform code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-31x86: Move pre_intr_init to x86_init_opsThomas Gleixner
Replace the quirk machinery by a x86_init_ops function which defaults to the standard implementation. This is also a preparatory patch for Moorestown support which needs to replace the default init_ISA_irqs as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-07-21x86, mce: Rename incorrect macro name "CONFIG_X86_THRESHOLD"Hidehiro Kawai
CONFIG_X86_THRESHOLD used in arch/x86/kernel/irqinit.c is always undefined. Rename it to the correct name "CONFIG_X86_MCE_THRESHOLD". Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> LKML-Reference: <4A667FD4.3010509@hitachi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-07-09x86: mce: Rename CONFIG_X86_NEW_MCE to CONFIG_X86_MCEAndi Kleen
Drop the CONFIG_X86_NEW_MCE symbol and change all references to it to check for CONFIG_X86_MCE directly. No code changes Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-06-11Merge branch 'linus' into x86/mce3Ingo Molnar
Conflicts: arch/x86/kernel/cpu/mcheck/mce_64.c arch/x86/kernel/irq.c Merge reason: Resolve the conflicts above. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11Merge branch 'linus' into perfcounters/coreIngo Molnar
Conflicts: arch/x86/kernel/irqinit.c arch/x86/kernel/irqinit_64.c arch/x86/kernel/traps.c arch/x86/mm/fault.c include/linux/sched.h kernel/exit.c
2009-06-03x86: fix panic with interrupts off (needed for MCE)Andi Kleen
For some time each panic() called with interrupts disabled triggered the !irqs_disabled() WARN_ON in smp_call_function(), producing ugly backtraces and confusing users. This is a common situation with machine checks for example which tend to call panic with interrupts disabled, but will also hit in other situations e.g. panic during early boot. In fact it means that panic cannot be called in many circumstances, which would be bad. This all started with the new fancy queued smp_call_function, which is then used by the shutdown path to shut down the other CPUs. On closer examination it turned out that the fancy RCU smp_call_function() does lots of things not suitable in a panic situation anyways, like allocating memory and relying on complex system state. I originally tried to patch this over by checking for panic there, but it was quite complicated and the original patch was also not very popular. This also didn't fix some of the underlying complexity problems. The new code in post 2.6.29 tries to patch around this by checking for oops_in_progress, but that is not enough to make this fully safe and I don't think that's a real solution because panic has to be reliable. So instead use an own vector to reboot. This makes the reboot code extremly straight forward, which is definitely a big plus in a panic situation where it is important to avoid relying on too much kernel state. The new simple code is also safe to be called from interupts off region because it is very very simple. There can be situations where it is important that panic is reliable. For example on a fatal machine check the panic is needed to get the system up again and running as quickly as possible. So it's important that panic is reliable and all function it calls simple. This is why I came up with this simple vector scheme. It's very hard to beat in simplicity. Vectors are not particularly precious anymore since all big systems are using per CPU vectors. Another possibility would have been to use an NMI similar to kdump, but there is still the problem that NMIs don't work reliably on some systems due to BIOS issues. NMIs would have been able to stop CPUs running with interrupts off too. In the sake of universal reliability I opted for using a non NMI vector for now. I put the reboot vector into the highest priority bucket of the APIC vectors and moved the 64bit UV_BAU message down instead into the next lower priority. [ Impact: bug fix, fixes an old regression ] Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-06-03x86, mce: implement bootstrapping for machine check wakeupsAndi Kleen
Machine checks support waking up the mcelog daemon quickly. The original wake up code for this was pretty ugly, relying on a idle notifier and a special process flag. The reason it did it this way is that the machine check handler is not subject to normal interrupt locking rules so it's not safe to call wake_up(). Instead it set a process flag and then either did the wakeup in the syscall return or in the idle notifier. This patch adds a new "bootstraping" method as replacement. The idea is that the handler checks if it's in a state where it is unsafe to call wake_up(). If it's safe it calls it directly. When it's not safe -- that is it interrupted in a critical section with interrupts disables -- it uses a new "self IPI" to trigger an IPI to its own CPU. This can be done safely because IPI triggers are atomic with some care. The IPI is raised once the interrupts are reenabled and can then safely call wake_up(). When APICs are disabled the event is just queued and will be picked up eventually by the next polling timer. I think that's a reasonable compromise, since it should only happen quite rarely. Contains fixes from Ying Huang. [ solve conflict on irqinit, make it work on 32bit (entry_arch.h) - HS ] Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-06-01Merge branch 'irq/numa' into x86/mce3H. Peter Anvin
Merge reason: arch/x86/kernel/irqinit_{32,64}.c unified in irq/numa and modified in x86/mce3; this merge resolves the conflict. Conflicts: arch/x86/kernel/irqinit.c Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-04-15x86: use used_vectors in init_IRQ()Yinghai Lu
Impact: fix crash with many devices I found this crash: [ 552.616646] general protection fault: 0403 [#1] SMP [ 552.620013] last sysfs file: /sys/devices/pci0000:00/0000:00:02.0/usb1/1-1/1-1:1.0/host13/target13:0:0/13:0:0:0/block/sr0/size [ 552.620013] CPU 0 [ 552.620013] Modules linked in: [ 552.620013] Pid: 0, comm: swapper Not tainted 2.6.30-rc1-tip-01931-g8fcafd8-dirty #28 Sun Fire X4440 [ 552.620013] RIP: 0010:[<ffffffff8023bada>] [<ffffffff8023bada>] default_idle+0x7d/0xda [ 552.620013] RSP: 0018:ffffffff81345e68 EFLAGS: 00010246 [ 552.620013] RAX: 0000000000000000 RBX: ffffffff8133d870 RCX: ffffc20000000000 [ 552.620013] RDX: 00000000001d0620 RSI: ffffffff8023bad8 RDI: ffffffff802a3169 [ 552.620013] RBP: ffffffff81345e98 R08: 0000000000000000 R09: ffffffff812244a0 [ 552.620013] R10: ffffffff81345dc8 R11: 7ebe1b6fa0bcac50 R12: 4ec4ec4ec4ec4ec5 [ 552.620013] R13: ffffffff813a54d0 R14: ffffffff813a7a40 R15: 0000000000000000 [ 552.620013] FS: 00000000006d1880(0000) GS:ffffc20000000000(0000) knlGS:0000000000000000 [ 552.620013] CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b [ 552.620013] CR2: 00007fec9d936a50 CR3: 000000007d1a9000 CR4: 00000000000006e0 [ 552.620013] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 552.620013] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 552.620013] Process swapper (pid: 0, threadinfo ffffffff81344000,task ffffffff812244a0) [ 552.620013] Stack: [ 552.620013] 0000000000000000 ffffc20000000000 00000000001d0620 7ebe1b6fa0bcac50 [ 552.620013] ffffffff8133d870 4ec4ec4ec4ec4ec5 ffffffff81345ec8 ffffffff8023bd84 [ 552.620013] 4ec4ec4ec4ec4ec5 ffffffff813a54d0 7ebe1b6fa0bcac50 ffffffff8133d870 [ 552.620013] Call Trace: [ 552.620013] [<ffffffff8023bd84>] c1e_idle+0x109/0x124 [ 552.620013] [<ffffffff8023314b>] cpu_idle+0xb8/0x101 [ 552.620013] [<ffffffff80c16d6a>] rest_init+0x7e/0x94 [ 552.620013] [<ffffffff81357efc>] start_kernel+0x3dc/0x3fd [ 552.620013] [<ffffffff813572a9>] x86_64_start_reservations+0xb9/0xd4 [ 552.620013] [<ffffffff813573b2>] x86_64_start_kernel+0xee/0x109 [ 552.620013] Code: 48 8b 04 25 f8 b4 00 00 83 a0 3c e0 ff ff fb 0f ae f0 65 48 8b 04 25 f8 b4 00 00 f6 80 38 e0 ff ff 08 75 09 e8 71 76 06 00 fb f4 <eb> 06 e8 68 76 06 00 fb 65 48 8b 04 25 f8 b4 00 00 83 88 3c e0 [ 552.620013] RIP [<ffffffff8023bada>] default_idle+0x7d/0xda [ 552.620013] RSP <ffffffff81345e68> [ 552.828646] ---[ end trace 4cbfc5c01382af7f ]--- Joerg Roedel said "The 0403 error code means that there was an external interrupt with vector 0x80. Yinghai, my theory is that the kernel on this machine has no 32bit emulation compiled in, right? In this case the selector points to a zero entry which may cause the #gpf right after the hlt. But I have no idea where the external int 0x80 comes from" it turns out that we could use 0x80 for external device on 64-bit when 32-bit emulation is disabled. But we forgot to set the gate for it. try to set gate for it by checking used_vectors. Also move apic_intr_init() early to avoid setting that gate two times. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Joerg Roedel <joerg.roedel@amd.com> LKML-Reference: <49E62DFD.6010904@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-10x86, irqinit: preempt merge conflictsIngo Molnar
To make the topic merge life easier for tip:perfcounters/core, include two (inactive in this topic) IRQ vector initializations here. Also fix build bug - missing kprobes.h inclusion. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-10x86: remove some ifdefs from native_init_IRQ()Pekka Enberg
Impact: cleanup Reviewed-by Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-10x86: define IA32_SYSCALL_VECTOR on 32-bit to reduce ifdefsPekka Enberg
Impact: cleanup We can remove some #ifdefs if we define IA32_SYSCALL_VECTOR on 32-bit. Reviewed-by Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-10x86: unify irqinit_{32,64}.c into irqinit.cPekka Enberg
