path: root/arch/x86/kernel/crash.c
2016-10-11x86/panic: replace smp_send_stop() with kdump friendly version in panic pathHidehiro Kawai
Daniel Walker reported problems which happens when crash_kexec_post_notifiers kernel option is enabled (https://lkml.org/lkml/2015/6/24/44). In that case, smp_send_stop() is called before entering kdump routines which assume other CPUs are still online. As the result, for x86, kdump routines fail to save other CPUs' registers and disable virtualization extensions. To fix this problem, call a new kdump friendly function, crash_smp_send_stop(), instead of the smp_send_stop() when crash_kexec_post_notifiers is enabled. crash_smp_send_stop() is a weak function, and it just call smp_send_stop(). Architecture codes should override it so that kdump can work appropriately. This patch only provides x86-specific version. For Xen's PV kernel, just keep the current behavior. NOTES: - Right solution would be to place crash_smp_send_stop() before __crash_kexec() invocation in all cases and remove smp_send_stop(), but we can't do that until all architectures implement own crash_smp_send_stop() - crash_smp_send_stop()-like work is still needed by machine_crash_shutdown() because crash_kexec() can be called without entering panic() Fixes: f06e5153f4ae (kernel/panic.c: add "crash_kexec_post_notifiers" option) Link: http://lkml.kernel.org/r/20160810080948.11028.15344.stgit@sysi4-13.yrl.intra.hitachi.co.jp Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Reported-by: Daniel Walker <dwalker@fifo99.com> Cc: Dave Young <dyoung@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Xunlei Pang <xpang@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Toshi Kani <toshi.kani@hpe.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Daney <david.daney@cavium.com> Cc: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: "Steven J. Hill" <steven.hill@cavium.com> Cc: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-14x86/kernel: Audit and remove any unnecessary uses of module.hPaul Gortmaker
Historically a lot of these existed because we did not have a distinction between what was modular code and what was providing support to modules via EXPORT_SYMBOL and friends. That changed when we forked out support for the latter into the export.h file. This means we should be able to reduce the usage of module.h in code that is obj-y Makefile or bool Kconfig. The advantage in doing so is that module.h itself sources about 15 other headers; adding significantly to what we feed cpp, and it can obscure what headers we are effectively using. Since module.h was the source for init.h (for __init) and for export.h (for EXPORT_SYMBOL) we consider each obj-y/bool instance for the presence of either and replace as needed. Build testing revealed some implicit header usage that was fixed up accordingly. Note that some bool/obj-y instances remain since module.h is the header for some exception table entry stuff, and for things like __init_or_module (code that is tossed when MODULES=n). Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20160714001901.31603-4-paul.gortmaker@windriver.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-01-30x86/kexec: Remove walk_iomem_res() call with GART typeToshi Kani
There is no longer any driver inserting a "GART" region in the kernel since 707d4eefbdb3 ("Revert "[PATCH] Insert GART region into resource map""). Remove the call to walk_iomem_res() with "GART" type, its callback function, and GART-specific variables set by the callback. Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Signed-off-by: Borislav Petkov <bp@suse.de> Reviewed-by: Dave Young <dyoung@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Chun-Yi <joeyli.kernel@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Lee, Chun-Yi <joeyli.kernel@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Minfei Huang <mnfhuang@gmail.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Takao Indoh <indou.takao@jp.fujitsu.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: kexec@lists.infradead.org Cc: linux-arch@vger.kernel.org Cc: linux-mm <linux-mm@kvack.org> Link: http://lkml.kernel.org/r/1453841853-11383-16-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-01-30x86, kexec, nvdimm: Use walk_iomem_res_desc() for iomem searchToshi Kani
Change the callers of walk_iomem_res() scanning for the following resources by name to use walk_iomem_res_desc() instead. "ACPI Tables" "ACPI Non-volatile Storage" "Persistent Memory (legacy)" "Crash kernel" Note, the caller of walk_iomem_res() with "GART" will be removed in a later patch. Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Signed-off-by: Borislav Petkov <bp@suse.de> Reviewed-by: Dave Young <dyoung@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Chun-Yi <joeyli.kernel@gmail.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Don Zickus <dzickus@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Lee, Chun-Yi <joeyli.kernel@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Minfei Huang <mnfhuang@gmail.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Takao Indoh <indou.takao@jp.fujitsu.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: kexec@lists.infradead.org Cc: linux-arch@vger.kernel.org Cc: linux-mm <linux-mm@kvack.org> Cc: linux-nvdimm@lists.01.org Link: http://lkml.kernel.org/r/1453841853-11383-15-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-11-23perf, x86: Stop Intel PT before kdump startsTakao Indoh
This patch stops Intel PT logging and saves its registers in memory before kdump is started. This feature is needed to prevent Intel PT from overwriting its log buffer after panic, and saved registers are needed to find the last position where Intel PT wrote data. After the crash dump is captured by kdump, users can retrieve the log buffer from the vmcore and use it to investigate bad kernel behavior. Signed-off-by: Takao Indoh <indou.takao@jp.fujitsu.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Shishkin<alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: H.Peter Anvin <hpa@zytor.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: Vivek Goyal <vgoyal@redhat.com> Link: http://lkml.kernel.org/r/1446614553-6072-3-git-send-email-indou.takao@jp.fujitsu.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-12x86/kexec: Remove obsolete 'in_crash_kexec' flagMinfei Huang
Previously, UV NMI used the 'in_crash_kexec' flag to determine whether we are in a kdump kernel or not: 5edd19af18a36a4 ("x86, UV: Make kdump avoid stack dumps") But this flags was removed in the following commit: 9c48f1c629ecfa1 ("x86, nmi: Wire up NMI handlers to new routines") Since it isn't used any more, remove it. Signed-off-by: Minfei Huang <mnfhuang@gmail.com> Acked-by: Don Zickus <dzickus@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: cpw@sgi.com Cc: kexec@lists.infradead.org Cc: mhuang@redhat.com Link: http://lkml.kernel.org/r/1444070155-17934-1-git-send-email-mhuang@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-02x86/kexec: Fix kexec crash in syscall kexec_file_load()Lee, Chun-Yi
The original bug is a page fault crash that sometimes happens on big machines when preparing ELF headers: BUG: unable to handle kernel paging request at ffffc90613fc9000 IP: [<ffffffff8103d645>] prepare_elf64_ram_headers_callback+0x165/0x260 The bug is caused by us under-counting the number of memory ranges and subsequently not allocating enough ELF header space for them. The bug is typically masked on smaller systems, because the ELF header allocation is rounded up to the next page. This patch modifies the code in fill_up_crash_elf_data() by using walk_system_ram_res() instead of walk_system_ram_range() to correctly count the max number of crash memory ranges. That's because the walk_system_ram_range() filters out small memory regions that reside in the same page, but walk_system_ram_res() does not. Here's how I found the bug: After tracing prepare_elf64_headers() and prepare_elf64_ram_headers_callback(), the code uses walk_system_ram_res() to fill-in crash memory regions information to the program header, so it counts those small memory regions that reside in a page area. But, when the kernel was using walk_system_ram_range() in fill_up_crash_elf_data() to count the number of crash memory regions, it filters out small regions. I printed those small memory regions, for example: kexec: Get nr_ram ranges. vaddr=0xffff880077592258 paddr=0x77592258, sz=0xdc0 Based on the code in walk_system_ram_range(), this memory region will be filtered out: pfn = (0x77592258 + 0x1000 - 1) >> 12 = 0x77593 end_pfn = (0x77592258 + 0xfc0 -1 + 1) >> 12 = 0x77593 end_pfn - pfn = 0x77593 - 0x77593 = 0 <=== if (end_pfn > pfn) is FALSE So, the max_nr_ranges that's counted by the kernel doesn't include small memory regions - causing us to under-allocate the required space. That causes the page fault crash that happens in a later code path when preparing ELF headers. This bug is not easy to reproduce on small machines that have few CPUs, because the allocated page aligned ELF buffer has more free space to cover those small memory regions' PT_LOAD headers. Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Baoquan He <bhe@redhat.com> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Takashi Iwai <tiwai@suse.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: kexec@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/1443531537-29436-1-git-send-email-jlee@suse.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-03x86/mm: Decouple <linux/vmalloc.h> from <asm/io.h>Stephen Rothwell
Nothing in <asm/io.h> uses anything from <linux/vmalloc.h>, so remove it from there and fix up the resulting build problems triggered on x86 {64|32}-bit {def|allmod|allno}configs. The breakages were triggering in places where x86 builds relied on vmalloc() facilities but did not include <linux/vmalloc.h> explicitly and relied on the implicit inclusion via <asm/io.h>. Also add: - <linux/init.h> to <linux/io.h> - <asm/pgtable_types> to <asm/io.h> ... which were two other implicit header file dependencies. Suggested-by: David Miller <davem@davemloft.net> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> [ Tidied up the changelog. ] Acked-by: David Miller <davem@davemloft.net> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Vinod Koul <vinod.koul@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anton Vorontsov <anton@enomsg.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Colin Cross <ccross@android.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Cc: James E.J. Bottomley <JBottomley@odin.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: K. Y. Srinivasan <kys@microsoft.com> Cc: Kees Cook <keescook@chromium.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Kristen Carlson Accardi <kristen@linux.intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Suma Ramars <sramars@cisco.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-03-23x86/asm/entry: Change all 'user_mode_vm()' calls to 'user_mode()'Andy Lutomirski
user_mode_vm() and user_mode() are now the same. Change all callers of user_mode_vm() to user_mode(). The next patch will remove the definition of user_mode_vm. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brad Spengler <spender@grsecurity.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/43b1f57f3df70df5a08b0925897c660725015554.1426728647.git.luto@kernel.org [ Merged to a more recent kernel. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-12-16x86, irq: Move IOAPIC related declarations from hw_irq.h into io_apic.hJiang Liu
Clean up code by moving IOAPIC related declarations from hw_irq.h into io_apic.h. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: Matt Fleming <matt.fleming@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Aubrey <aubrey.li@linux.intel.com> Cc: Ryan Desfosses <ryan@desfo.org> Cc: Quentin Lambert <lambert.quentin@gmail.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Link: http://lkml.kernel.org/r/1414397531-28254-14-git-send-email-jiang.liu@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-10-14kexec: check if crashk_res_low exists when exclude it from crash mem rangesBaoquan He
Add a check if crashk_res_low exists just like GART region does. If crashk_res_low doesn't exist, calling exclude_mem_range is unnecessary. Meanwhile, since crashk_res_low has been initialized at definition, it's safe just use "if (crashk_low_res.end)" to check if it's exist. And this can make it consistent with other places of check. Signed-off-by: Baoquan He <bhe@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-29kexec: create a new config option CONFIG_KEXEC_FILE for new syscallVivek Goyal
Currently new system call kexec_file_load() and all the associated code compiles if CONFIG_KEXEC=y. But new syscall also compiles purgatory code which currently uses gcc option -mcmodel=large. This option seems to be available only gcc 4.4 onwards. Hiding new functionality behind a new config option will not break existing users of old gcc. Those who wish to enable new functionality will require new gcc. Having said that, I am trying to figure out how can I move away from using -mcmodel=large but that can take a while. I think there are other advantages of introducing this new config option. As this option will be enabled only on x86_64, other arches don't have to compile generic kexec code which will never be used. This new code selects CRYPTO=y and CRYPTO_SHA256=y. And all other arches had to do this for CONFIG_KEXEC. Now with introduction of new config option, we can remove crypto dependency from other arches. Now CONFIG_KEXEC_FILE is available only on x86_64. So whereever I had CONFIG_X86_64 defined, I got rid of that. For CONFIG_KEXEC_FILE, instead of doing select CRYPTO=y, I changed it to "depends on CRYPTO=y". This should be safer as "select" is not recursive. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: H. Peter Anvin <hpa@zytor.com> Tested-by: Shaun Ruffell <sruffell@digium.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08kexec: support for kexec on panic using new system callVivek Goyal
This patch adds support for loading a kexec on panic (kdump) kernel usning new system call. It prepares ELF headers for memory areas to be dumped and for saved cpu registers. Also prepares the memory map for second kernel and limits its boot to reserved areas only. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Cc: Borislav Petkov <bp@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Eric Biederman <ebiederm@xmission.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Greg Kroah-Hartman <greg@kroah.com> Cc: Dave Young <dyoung@redhat.com> Cc: WANG Chao <chaowang@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-13x86, crash: Unify ifdefBorislav Petkov
Merge two back-to-back CONFIG_X86_32 ifdefs into one. Signed-off-by: Borislav Petkov <bp@suse.de> Link: http://lkml.kernel.org/r/1394633584-5509-3-git-send-email-bp@alien8.de Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-06x86: Delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. [ hpa: undid incorrect removal from arch/x86/kernel/head_32.S ] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Link: http://lkml.kernel.org/r/1389054026-12947-1-git-send-email-paul.gortmaker@windriver.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2013-11-07x86/apic: Disable I/O APIC before shutdown of the local APICFenghua Yu
In reboot and crash path, when we shut down the local APIC, the I/O APIC is still active. This may cause issues because external interrupts can still come in and disturb the local APIC during shutdown process. To quiet external interrupts, disable I/O APIC before shutdown local APIC. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Link: http://lkml.kernel.org/r/1382578212-4677-1-git-send-email-fenghua.yu@intel.com Cc: <stable@kernel.org> [ I suppose the 'issue' is a hang during shutdown. It's a fine change nevertheless. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-08-20x86/ioapic/kcrash: Prevent crash_kexec() from deadlocking on ioapic_lockYoshihiro YUNOMAE
Prevent crash_kexec() from deadlocking on ioapic_lock. When crash_kexec() is executed on a CPU, the CPU will take ioapic_lock in disable_IO_APIC(). So if the cpu gets an NMI while locking ioapic_lock, a deadlock will happen. In this patch, ioapic_lock is zapped/initialized before disable_IO_APIC(). You can reproduce this deadlock the following way: 1. Add mdelay(1000) after raw_spin_lock_irqsave() in native_ioapic_set_affinity()@arch/x86/kernel/apic/io_apic.c Although the deadlock can occur without this modification, it will increase the potential of the deadlock problem. 2. Build and install the kernel 3. Set up the OS which will run panic() and kexec when NMI is injected # echo "kernel.unknown_nmi_panic=1" >> /etc/sysctl.conf # vim /etc/default/grub add "nmi_watchdog=0 crashkernel=256M" in GRUB_CMDLINE_LINUX line # grub2-mkconfig 4. Reboot the OS 5. Run following command for each vcpu on the guest # while true; do echo <CPU num> > /proc/irq/<IO-APIC-edge or IO-APIC-fasteoi>/smp_affinitity; done; By running this command, cpus will get ioapic_lock for setting affinity. 6. Inject NMI (push a dump button or execute 'virsh inject-nmi <domain>' if you use VM). After injecting NMI, panic() is called in an nmi-handler context. Then, kexec will normally run in panic(), but the operation will be stopped by deadlock on ioapic_lock in crash_kexec()->machine_crash_shutdown()-> native_machine_crash_shutdown()->disable_IO_APIC()->clear_IO_APIC()-> clear_IO_APIC_pin()->ioapic_read_entry(). Signed-off-by: Yoshihiro YUNOMAE <yoshihiro.yunomae.ez@hitachi.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: yrl.pp-manager.tt@hitachi.com Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Link: http://lkml.kernel.org/r/20130820070107.28245.83806.stgit@yunodevel Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-12-11x86/kexec: crash_vmclear_local_vmcss needs __rcuZhang Yanfei
This removes the sparse warning: arch/x86/kernel/crash.c:49:32: sparse: incompatible types in comparison expression (different address spaces) Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-06x86/kexec: VMCLEAR VMCSs loaded on all cpus if necessaryZhang Yanfei
This patch provides a way to VMCLEAR VMCSs related to guests on all cpus before executing the VMXOFF when doing kdump. This is used to ensure the VMCSs in the vmcore updated and non-corrupted. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2011-10-10x86, nmi: Wire up NMI handlers to new routinesDon Zickus
Just convert all the files that have an nmi handler to the new routines. Most of it is straight forward conversion. A couple of places needed some tweaking like kgdb which separates the debug notifier from the nmi handler and mce removes a call to notify_die. [Thanks to Ying for finding out the history behind that mce call https://lkml.org/lkml/2010/5/27/114 And Boris responding that he would like to remove that call because of it https://lkml.org/lkml/2011/9/21/163] The things that get converted are the registeration/unregistration routines and the nmi handler itself has its args changed along with code removal to check which list it is on (most are on one NMI list except for kgdb which has both an NMI routine and an NMI Unknown routine). Signed-off-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Corey Minyard <minyard@acm.org> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Corey Minyard <minyard@acm.org> Cc: Jack Steiner <steiner@sgi.com> Link: http://lkml.kernel.org/r/1317409584-23662-4-git-send-email-dzickus@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-21x86, UV: Make kdump avoid stack dumpsCliff Wickman
UV NMI callback's should not write stack dumps when a kdump is to be written. When invoking the crash kernel to write a dump, kdump_nmi_shootdown_cpus() uses NMI's to get all the cpu's to save their register context and halt. But the NMI interrupt handler runs a callback list. This patch sets a flag to prevent any of those callbacks from interfering with the halt of the cpu. For UV, which currently has the only callback to which this is relevant, the uv_handle_nmi() callback should not do dumping of stacks. The 'in_crash_kexec' flag is defined as an extern in kdebug.h firstly because x2apic_uv_x.c includes it. Secondly because some future callback might need the flag to know that it should not enter the debugger. (Such a scenario was in fact present in the 2.6.32 kernel, SuSE distribution, where a call to kdb needed to be avoided.) Signed-off-by: Cliff Wickman <cpw@sgi.com> LKML-Reference: <E1ObLvt-0005UZ-Va@eag09.americas.sgi.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-04-07Revert "x86: disable IOMMUs on kernel crash"Chris Wright
This effectively reverts commit 61d047be99757fd9b0af900d7abce9a13a337488. Disabling the IOMMU can potetially allow DMA transactions to complete without being translated. Leave it enabled, and allow crash kernel to do the IOMMU reinitialization properly. Cc: stable@kernel.org Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-11-08x86: Use x86_platform for iommu_shutdownFUJITA Tomonori
This patch cleans up pci_iommu_shutdown() a bit to use x86_platform (similar to how IA64 initializes an IOMMU driver). This adds iommu_shutdown() to x86_platform to avoid calling every IOMMUs' shutdown functions in pci_iommu_shutdown() in order. The IOMMU shutdown functions are platform specific (we don't have multiple different IOMMU hardware) so the current way is pointless. An IOMMU driver sets x86_platform.iommu_shutdown to the shutdown function if necessary. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: joerg.roedel@amd.com LKML-Reference: <20091027163358F.fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-15x86: disable IOMMUs on kernel crashJoerg Roedel
If the IOMMUs are still enabled when the kexec kernel boots access to the disk is not possible. This is bad for tools like kdump or anything else which wants to use PCI devices. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-02-17x86, apic: remove duplicate asm/apic.h inclusionsIngo Molnar
Impact: cleanup Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-17x86, apic: remove genapic.hIngo Molnar
Impact: cleanup Remove genapic.h and remove all references to it. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-29x86, smp: remove mach_ipi.hIngo Molnar
Move mach_ipi.h definitions into genapic.h. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-07x86: smp.h move safe_smp_processor_id declartion to cpu.hJaswinder Singh Rajput
Impact: cleanup Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-31kdump: forcibly disable VMX and SVM on machine_crash_shutdown()Eduardo Habkost
We need to disable virtualization extensions on all CPUs before booting the kdump kernel, otherwise the kdump kernel booting will fail, and rebooting after the kdump kernel did its task may also fail. We do it using cpu_emergency_vmxoff() and cpu_emergency_svm_disable(), that should always work, because those functions check if the CPUs support SVM or VMX before doing their tasks. Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-11-12x86: move nmi_shootdown_cpus() to reboot.cEduardo Habkost
Impact: make nmi_shootdown_cpus() available to the rest of the x86 platform Now nmi_shootdown_cpus() is ready to be used by non-kdump code also. Move it to reboot.c. Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12x86 kdump: make nmi_shootdown_cpus() non-staticEduardo Habkost
Impact: make API available to the rest of x86 platform code Add prototype to asm/reboot.h. Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12x86 kdump: make kdump_nmi_callback() a function ptr on crash_nmi_callback()Eduardo Habkost
Impact: extend nmi_shootdown_cpus() with a callback The reboot code will use a different function on crash_nmi_callback(). Adding a function pointer parameter to nmi_shootdown_cpus() for that. Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12x86 kdump: create kdump_nmi_shootdown_cpus()Eduardo Habkost
Impact: cleanup For the kdump-specific code that was living on nmi_shootdown_cpus(). Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12x86 kdump: move crashing_cpu assignment to nmi_shootdown_cpus()Eduardo Habkost
Impact: cleanup This variable will be moved to non-kdump-specific code. Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12x86 kdump: extract kdump-specific code from crash_nmi_callback()Eduardo Habkost
Impact: cleanup The NMI CPU-halting code will be used on non-kdump cases, also (e.g. emergency_reboot when virtualization is enabled). Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-27x86: allow machine_crash_shutdown to be replacedGlauber Costa
This patch a llows machine_crash_shutdown to be replaced, just like any of the other functions in machine_ops Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-17x86: move ipi definitions to mach_ipi.hGlauber Costa
take them out of the x86_64-only asm/mach_apic.h Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-03x86: disable hpet legacy replacement for kdumpOGAWA Hirofumi
we should also add hpet_disable() for kdump. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-24x86: fix CONFIG_KEXEC build breakageMike Galbraith
X86_32 build fix to commit 62a31a03b3d2a9d20e7a073e2cd9b27bfb7d6a3f Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-23x86: unify crash_32/64.cHiroshi Shimamoto
Most of contents in crash are same. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
