Commit 2ed53c0d6cc9 ("x86/smpboot: Speed up suspend/resume by
avoiding 100ms sleep for CPU offline during S3") introduced
completions to CPU offlining process. These completions are not
initialized on Xen kernels causing a panic in
play_dead_common().
Move handling of die_complete into common routines to make them
available to Xen guests.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Cc: tianyu.lan@intel.com
Cc: konrad.wilk@oracle.com
Cc: xen-devel@lists.xenproject.org
Link: http://lkml.kernel.org/r/1414770572-7950-1-git-send-email-boris.ostrovsky@oracle.com
preempt_schedule_context() does preempt_enable_notrace() at the end
and this can call the same function again; exception_exit() is heavy
and it is quite possible that need-resched is true again.
1. Change this code to dec preempt_count() and check need_resched()
by hand.
2. As Linus suggested, we can use the PREEMPT_ACTIVE bit and avoid
the enable/disable dance around __schedule(). But in this case
we need to move into sched/core.c.
3. Cosmetic, but x86 forgets to declare this function. This doesn't
really matter because it is only called by asm helpers, still it
make sense to add the declaration into asm/preempt.h to match
preempt_schedule().
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: Alexander Graf <agraf@suse.de>
Cc: Christoph Lameter <cl@linux.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Peter Anvin <hpa@zytor.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Chuck Ebbert <cebbert.lkml@gmail.com>
Link: http://lkml.kernel.org/r/20141005202322.GB27962@redhat.com
Pull kvm fixes from Paolo Bonzini:
"This is a pretty large update. I think it is roughly as big as what I
usually had for the _whole_ rc period.
There are a few bad bugs where the guest can OOPS or crash the host.
We have also started looking at attack models for nested
virtualization; bugs that usually result in the guest ring 0 crashing
itself become more worrisome if you have nested virtualization,
because the nested guest might bring down the non-nested guest as
well. For current uses of nested virtualization these do not really
have a security impact, but you never know and bugs are bugs
nevertheless.
A lot of these bugs are in 3.17 too, resulting in a large number of
stable@ Ccs. I checked that all the patches apply there with no
conflicts"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
kvm: vfio: fix unregister kvm_device_ops of vfio
KVM: x86: Wrong assertion on paging_tmpl.h
kvm: fix excessive pages un-pinning in kvm_iommu_map error path.
KVM: x86: PREFETCH and HINT_NOP should have SrcMem flag
KVM: x86: Emulator does not decode clflush well
KVM: emulate: avoid accessing NULL ctxt->memopp
KVM: x86: Decoding guest instructions which cross page boundary may fail
kvm: x86: don't kill guest on unknown exit reason
kvm: vmx: handle invvpid vm exit gracefully
KVM: x86: Handle errors when RIP is set during far jumps
KVM: x86: Emulator fixes for eip canonical checks on near branches
KVM: x86: Fix wrong masking on relative jump/call
KVM: x86: Improve thread safety in pit
KVM: x86: Prevent host from panicking on shared MSR writes.
KVM: x86: Check non-canonical addresses upon WRMSR
On systems with invvpid instruction support (corresponding bit in
IA32_VMX_EPT_VPID_CAP MSR is set) guest invocation of invvpid
causes vm exit, which is currently not handled and results in
propagation of unknown exit to userspace.
Fix this by installing an invvpid vm exit handler.
This is CVE-2014-3646.
Cc: stable@vger.kernel.org
Signed-off-by: Petr Matousek <pmatouse@redhat.com>
The previous patch blocked invalid writes directly when the MSR
is written. As a precaution, prevent future similar mistakes by
gracefulling handle GPs caused by writes to shared MSRs.
Signed-off-by: Andrew Honig <ahonig@google.com>
[Remove parts obsoleted by Nadav's patch. - Paolo]
Upon WRMSR, the CPU should inject #GP if a non-canonical value (address) is
written to certain MSRs. The behavior is "almost" identical for AMD and Intel
(ignoring MSRs that are not implemented in either architecture since they would
anyhow #GP). However, IA32_SYSENTER_ESP and IA32_SYSENTER_EIP cause #GP if
non-canonical address is written on Intel but not on AMD (which ignores the top
32-bits).
Accordingly, this patch injects a #GP on the MSRs which behave identically on
Intel and AMD. To eliminate the differences between the architecutres, the
value which is written to IA32_SYSENTER_ESP and IA32_SYSENTER_EIP is turned to
canonical value before writing instead of injecting a #GP.
Some references from Intel and AMD manuals:
According to Intel SDM description of WRMSR instruction #GP is expected on
WRMSR "If the source register contains a non-canonical address and ECX
specifies one of the following MSRs: IA32_DS_AREA, IA32_FS_BASE, IA32_GS_BASE,
IA32_KERNEL_GS_BASE, IA32_LSTAR, IA32_SYSENTER_EIP, IA32_SYSENTER_ESP."
According to AMD manual instruction manual:
LSTAR/CSTAR (SYSCALL): "The WRMSR instruction loads the target RIP into the
LSTAR and CSTAR registers. If an RIP written by WRMSR is not in canonical
form, a general-protection exception (#GP) occurs."
IA32_GS_BASE and IA32_FS_BASE (WRFSBASE/WRGSBASE): "The address written to the
base field must be in canonical form or a #GP fault will occur."
IA32_KERNEL_GS_BASE (SWAPGS): "The address stored in the KernelGSbase MSR must
be in canonical form."
This patch fixes CVE-2014-3610.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
Pull x86 EFI updates from Peter Anvin:
"This patchset falls under the "maintainers that grovel" clause in the
v3.18-rc1 announcement. We had intended to push it late in the merge
window since we got it into the -tip tree relatively late.
Many of these are relatively simple things, but there are a couple of
key bits, especially Ard's and Matt's patches"
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits)
rtc: Disable EFI rtc for x86
efi: rtc-efi: Export platform:rtc-efi as module alias
efi: Delete the in_nmi() conditional runtime locking
efi: Provide a non-blocking SetVariable() operation
x86/efi: Adding efi_printks on memory allocationa and pci.reads
x86/efi: Mark initialization code as such
x86/efi: Update comment regarding required phys mapped EFI services
x86/efi: Unexport add_efi_memmap variable
x86/efi: Remove unused efi_call* macros
efi: Resolve some shadow warnings
arm64: efi: Format EFI memory type & attrs with efi_md_typeattr_format()
ia64: efi: Format EFI memory type & attrs with efi_md_typeattr_format()
x86: efi: Format EFI memory type & attrs with efi_md_typeattr_format()
efi: Introduce efi_md_typeattr_format()
efi: Add macro for EFI_MEMORY_UCE memory attribute
x86/efi: Clear EFI_RUNTIME_SERVICES if failing to enter virtual mode
arm64/efi: Do not enter virtual mode if booting with efi=noruntime or noefi
arm64/efi: uefi_init error handling fix
efi: Add kernel param efi=noruntime
lib: Add a generic cmdline parse function parse_option_str
Pull more perf updates from Ingo Molnar:
"A second (and last) round of late coming fixes and changes, almost all
of them in perf tooling:
User visible tooling changes:
- Add period data column and make it default in 'perf script' (Jiri
Olsa)
- Add a visual cue for toggle zeroing of samples in 'perf top'
(Taeung Song)
- Improve callchains when using libunwind (Namhyung Kim)
Tooling fixes and infrastructure changes:
- Fix for double free in 'perf stat' when using some specific invalid
command line combo (Yasser Shalabi)
- Fix off-by-one bugs in map->end handling (Stephane Eranian)
- Fix off-by-one bug in maps__find(), also related to map->end
handling (Namhyung Kim)
- Make struct symbol->end be the first addr after the symbol range,
to make it match the convention used for struct map->end. (Arnaldo
Carvalho de Melo)
- Fix perf_evlist__add_pollfd() error handling in 'perf kvm stat
live' (Jiri Olsa)
- Fix python test build by moving callchain_param to an object linked
into the python binding (Jiri Olsa)
- Document sysfs events/ interfaces (Cody P Schafer)
- Fix typos in perf/Documentation (Masanari Iida)
- Add missing 'struct option' forward declaration (Arnaldo Carvalho
de Melo)
- Add option to copy events when queuing for sorting across cpu
buffers and enable it for 'perf kvm stat live', to avoid having
events left in the queue pointing to the ring buffer be rewritten
in high volume sessions. (Alexander Yarygin, improving work done
by David Ahern):
- Do not include a struct hists per perf_evsel, untangling the
histogram code from perf_evsel, to pave the way for exporting a
minimalistic tools/lib/api/perf/ library usable by tools/perf and
initially by the rasd daemon being developed by Borislav Petkov,
Robert Richter and Jean Pihet. (Arnaldo Carvalho de Melo)
- Make perf_evlist__open(evlist, NULL, NULL), i.e. without cpu and
thread maps mean syswide monitoring, reducing the boilerplate for
tools that only want system wide mode. (Arnaldo Carvalho de Melo)
- Move exit stuff from perf_evsel__delete to perf_evsel__exit, delete
should be just a front end for exit + free (Arnaldo Carvalho de
Melo)
- Add support to new style format of kernel PMU event. (Kan Liang)
and other misc fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits)
perf script: Add period as a default output column
perf script: Add period data column
perf evsel: No need to drag util/cgroup.h
perf evlist: Add missing 'struct option' forward declaration
perf evsel: Move exit stuff from __delete to __exit
kprobes/x86: Remove stale ARCH_SUPPORTS_KPROBES_ON_FTRACE define
perf kvm stat live: Enable events copying
perf session: Add option to copy events when queueing
perf Documentation: Fix typos in perf/Documentation
perf trace: Use thread_{,_set}_priv helpers
perf kvm: Use thread_{,_set}_priv helpers
perf callchain: Create an address space per thread
perf report: Set callchain_param.record_mode for future use
perf evlist: Fix for double free in tools/perf stat
perf test: Add test case for pmu event new style format
perf tools: Add support to new style format of kernel PMU event
perf tools: Parse the pmu event prefix and suffix
Revert "perf tools: Default to cpu// for events v5"
perf Documentation: Remove Ruplicated docs for powerpc cpu specific events
perf Documentation: sysfs events/ interfaces
Pull MIPS updates from Ralf Baechle:
"This is the MIPS pull request for the next kernel:
- Zubair's patch series adds CMA support for MIPS. Doing so it also
touches ARM64 and x86.
- remove the last instance of IRQF_DISABLED from arch/mips
- updates to two of the MIPS defconfig files.
- cleanup of how cache coherency bits are handled on MIPS and
implement support for write-combining.
- platform upgrades for Alchemy
- move MIPS DTS files to arch/mips/boot/dts/"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (24 commits)
MIPS: ralink: remove deprecated IRQF_DISABLED
MIPS: pgtable.h: Implement the pgprot_writecombine function for MIPS
MIPS: cpu-probe: Set the write-combine CCA value on per core basis
MIPS: pgtable-bits: Define the CCA bit for WC writes on Ingenic cores
MIPS: pgtable-bits: Move the CCA bits out of the core's ifdef blocks
MIPS: DMA: Add cma support
x86: use generic dma-contiguous.h
arm64: use generic dma-contiguous.h
asm-generic: Add dma-contiguous.h
MIPS: BPF: Add new emit_long_instr macro
MIPS: ralink: Move device-trees to arch/mips/boot/dts/
MIPS: Netlogic: Move device-trees to arch/mips/boot/dts/
MIPS: sead3: Move device-trees to arch/mips/boot/dts/
MIPS: Lantiq: Move device-trees to arch/mips/boot/dts/
MIPS: Octeon: Move device-trees to arch/mips/boot/dts/
MIPS: Add support for building device-tree binaries
MIPS: Create common infrastructure for building built-in device-trees
MIPS: SEAD3: Enable DEVTMPFS
MIPS: SEAD3: Regenerate defconfigs
MIPS: Alchemy: DB1300: Add touch penirq support
Commit e7dbfe349d12 ("kprobes/x86: Move ftrace-based kprobe code
into kprobes-ftrace.c") switched from using
ARCH_SUPPORTS_KPROBES_ON_FTRACE to CONFIG_KPROBES_ON_FTRACE but
missed removing the define.
Cc: masami.hiramatsu.pt@hitachi.com
Cc: ananth@in.ibm.com
Cc: a.p.zijlstra@chello.nl
Cc: fweisbec@gmail.com
Cc: rostedt@goodmis.org
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu consistent-ops changes from Tejun Heo:
"Way back, before the current percpu allocator was implemented, static
and dynamic percpu memory areas were allocated and handled separately
and had their own accessors. The distinction has been gone for many
years now; however, the now duplicate two sets of accessors remained
with the pointer based ones - this_cpu_*() - evolving various other
operations over time. During the process, we also accumulated other
inconsistent operations.
This pull request contains Christoph's patches to clean up the
duplicate accessor situation. __get_cpu_var() uses are replaced with
with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr().
Unfortunately, the former sometimes is tricky thanks to C being a bit
messy with the distinction between lvalues and pointers, which led to
a rather ugly solution for cpumask_var_t involving the introduction of
this_cpu_cpumask_var_ptr().
This converts most of the uses but not all. Christoph will follow up
with the remaining conversions in this merge window and hopefully
remove the obsolete accessors"
* 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits)
irqchip: Properly fetch the per cpu offset
percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix
ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write.
Revert "powerpc: Replace __get_cpu_var uses"
percpu: Remove __this_cpu_ptr
clocksource: Replace __this_cpu_ptr with raw_cpu_ptr
sparc: Replace __get_cpu_var uses
avr32: Replace __get_cpu_var with __this_cpu_write
blackfin: Replace __get_cpu_var uses
tile: Use this_cpu_ptr() for hardware counters
tile: Replace __get_cpu_var uses
alpha: Replace __get_cpu_var
ia64: Replace __get_cpu_var uses
s390: cio driver &__get_cpu_var replacements
s390: Replace __get_cpu_var uses
mips: Replace __get_cpu_var uses
MIPS: Replace __get_cpu_var uses in FPU emulator.
arm: Replace __this_cpu_ptr with raw_cpu_ptr
Pull x86 fixes from Ingo Molnar:
"Misc smaller fixes that missed the v3.17 cycle"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/build: Add arch/x86/purgatory/ make generated files to gitignore
x86: Fix section conflict for numachip
x86: Reject x32 executables if x32 ABI not supported
x86_64, entry: Filter RFLAGS.NT on entry from userspace
x86, boot, kaslr: Fix nuisance warning on 32-bit builds
Pull x86 seccomp changes from Ingo Molnar:
"This tree includes x86 seccomp filter speedups and related preparatory
work, which touches core seccomp facilities as well.
The main idea is to split seccomp into two phases, to be able to enter
a simple fast path for syscalls with ptrace side effects.
There's no substantial user-visible (and ABI) effects expected from
this, except a change in how we emit a better audit record for
SECCOMP_RET_TRACE events"
* 'x86-seccomp-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86_64, entry: Use split-phase syscall_trace_enter for 64-bit syscalls
x86_64, entry: Treat regs->ax the same in fastpath and slowpath syscalls
x86: Split syscall_trace_enter into two phases
x86, entry: Only call user_exit if TIF_NOHZ
x86, x32, audit: Fix x32's AUDIT_ARCH wrt audit
seccomp: Document two-phase seccomp and arch-provided seccomp_data
seccomp: Allow arch code to provide seccomp_data
seccomp: Refactor the filter callback and the API
seccomp,x86,arm,mips,s390: Remove nr parameter from secure_computing
Pull x86 mm updates from Ingo Molnar:
"This tree includes the following changes:
- fix memory hotplug
- fix hibernation bootup memory layout assumptions
- fix hyperv numa guest kernel messages
- remove dead code
- update documentation"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mm: Update memory map description to list hypervisor-reserved area
x86/mm, hibernate: Do not assume the first e820 area to be RAM
x86/mm/numa: Drop dead code and rename setup_node_data() to setup_alloc_data()
x86/mm/hotplug: Modify PGD entry when removing memory
x86/mm/hotplug: Pass sync_global_pgds() a correct argument in remove_pagetable()
x86: Remove set_pmd_pfn
Pull x86 microcode loading updates from Ingo Molnar:
"Misc smaller cleanups"
* 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, microcode, intel: Fix total_size computation
x86, microcode, intel: Rename apply_microcode and declare it static
x86, microcode, intel: Fix typos
x86, microcode, intel: Add missing static declarations
x86, microcode, amd: Fix missing static declaration
Pull x86 FPU updates from Ingo Molnar:
"x86 FPU handling fixes, cleanups and enhancements from Oleg.
The signal handling race fix and the __restore_xstate_sig() preemption
fix for eager-mode is marked for -stable as well"
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: copy_thread: Don't nullify ->ptrace_bps twice
x86, fpu: Shift "fpu_counter = 0" from copy_thread() to arch_dup_task_struct()
x86, fpu: copy_process: Sanitize fpu->last_cpu initialization
x86, fpu: copy_process: Avoid fpu_alloc/copy if !used_math()
x86, fpu: Change __thread_fpu_begin() to use use_eager_fpu()
x86, fpu: __restore_xstate_sig()->math_state_restore() needs preempt_disable()
x86, fpu: shift drop_init_fpu() from save_xstate_sig() to handle_signal()
Pull x86 cpufeature updates from Ingo Molnar:
- Introduce DISABLED_MASK to list disabled CPU features, to simplify
CPU feature handling and avoid excessive #ifdefs
- Remove the lightly used cpu_has_pae() primitive"
* 'x86-cpufeature-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Add more disabled features
x86: Introduce disabled-features
x86: Axe the lightly-used cpu_has_pae
Pull x86 cleanups from Ingo Molnar:
"Three small cleanups"
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/tty/serial/8250: Clean up the asm/serial.h include file a bit
x86/tty/serial/8250: Resolve missing-field-initializers warnings
x86: Remove obsolete comment in uapi/e820.h
Pull perf updates from Ingo Molnar:
"Kernel side updates:
- Fix and enhance poll support (Jiri Olsa)
- Re-enable inheritance optimization (Jiri Olsa)
- Enhance Intel memory events support (Stephane Eranian)
- Refactor the Intel uncore driver to be more maintainable (Zheng
Yan)
- Enhance and fix Intel CPU and uncore PMU drivers (Peter Zijlstra,
Andi Kleen)
- [ plus various smaller fixes/cleanups ]
User visible tooling updates:
- Add +field argument support for --field option, so that one can add
fields to the default list of fields to show, ie now one can just
do:
perf report --fields +pid
And the pid will appear in addition to the default fields (Jiri
Olsa)
- Add +field argument support for --sort option (Jiri Olsa)
- Honour -w in the report tools (report, top), allowing to specify
the widths for the histogram entries columns (Namhyung Kim)
- Properly show submicrosecond times in 'perf kvm stat' (Christian
Borntraeger)
- Add beautifier for mremap flags param in 'trace' (Alex Snast)
- perf script: Allow callchains if any event samples them
- Don't truncate Intel style addresses in 'annotate' (Alex Converse)
- Allow profiling when kptr_restrict == 1 for non root users, kernel
samples will just remain unresolved (Andi Kleen)
- Allow configuring default options for callchains in config file
(Namhyung Kim)
- Support operations for shared futexes. (Davidlohr Bueso)
- "perf kvm stat report" improvements by Alexander Yarygin:
- Save pid string in opts.target.pid
- Enable the target.system_wide flag
- Unify the title bar output
- [ plus lots of other fixes and small improvements. ]
Tooling infrastructure changes:
- Refactor unit and scale function parameters for PMU parsing
routines (Matt Fleming)
- Improve DSO long names lookup with rbtree, resulting in great
speedup for workloads with lots of DSOs (Waiman Long)
- We were not handling POLLHUP notifications for event file
descriptors
Fix it by filtering entries in the events file descriptor array
after poll() returns, refcounting mmaps so that when the last fd
pointing to a perf mmap goes away we do the unmap (Arnaldo Carvalho
de Melo)
- Intel PT prep work, from Adrian Hunter, including:
- Let a user specify a PMU event without any config terms
- Add perf-with-kcore script
- Let default config be defined for a PMU
- Add perf_pmu__scan_file()
- Add a 'perf test' for tracking with sched_switch
- Add 'flush' callback to scripting API
- Use ring buffer consume method to look like other tools (Arnaldo
Carvalho de Melo)
- hists browser (used in top and report) refactorings, getting rid of
unused variables and reducing source code size by handling similar
cases in a fewer functions (Namhyung Kim).
- Replace thread unsafe strerror() with strerror_r() accross the
whole tools/perf/ tree (Masami Hiramatsu)
- Rename ordered_samples to ordered_events and allow setting a queue
size for ordering events (Jiri Olsa)
- [ plus lots of fixes, cleanups and other improvements ]"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (198 commits)
perf/x86: Tone down kernel messages when the PMU check fails in a virtual environment
perf/x86/intel/uncore: Fix minor race in box set up
perf record: Fix error message for --filter option not coming after tracepoint
perf tools: Fix build breakage on arm64 targets
perf symbols: Improve DSO long names lookup speed with rbtree
perf symbols: Encapsulate dsos list head into struct dsos
perf bench futex: Sanitize -q option in requeue
perf bench futex: Support operations for shared futexes
perf trace: Fix mmap return address truncation to 32-bit
perf tools: Refactor unit and scale function parameters
perf tools: Fix line number in the config file error message
perf tools: Convert {record,top}.call-graph option to call-graph.record-mode
perf tools: Introduce perf_callchain_config()
perf callchain: Move some parser functions to callchain.c
perf tools: Move callchain config from record_opts to callchain_param
perf hists browser: Fix callchain print bug on TUI
perf tools: Use ACCESS_ONCE() instead of volatile cast
perf tools: Modify error code for when perf_session__new() fails
perf tools: Fix perf record as non root with kptr_restrict == 1
perf stat: Fix --per-core on multi socket systems
Pull core locking updates from Ingo Molnar:
"The main updates in this cycle were:
- mutex MCS refactoring finishing touches: improve comments, refactor
and clean up code, reduce debug data structure footprint, etc.
- qrwlock finishing touches: remove old code, self-test updates.
- small rwsem optimization
- various smaller fixes/cleanups"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
locking/lockdep: Revert qrwlock recusive stuff
locking/rwsem: Avoid double checking before try acquiring write lock
locking/rwsem: Move EXPORT_SYMBOL() lines to follow function definition
locking/rwlock, x86: Delete unused asm/rwlock.h and rwlock.S
locking/rwlock, x86: Clean up asm/spinlock*.h to remove old rwlock code
locking/semaphore: Resolve some shadow warnings
locking/selftest: Support queued rwlock
locking/lockdep: Restrict the use of recursive read_lock() with qrwlock
locking/spinlocks: Always evaluate the second argument of spin_lock_nested()
locking/Documentation: Update locking/mutex-design.txt disadvantages
locking/Documentation: Move locking related docs into Documentation/locking/
locking/mutexes: Use MUTEX_SPIN_ON_OWNER when appropriate
locking/mutexes: Refactor optimistic spinning code
locking/mcs: Remove obsolete comment
locking/mutexes: Document quick lock release when unlocking
locking/mutexes: Standardize arguments in lock/unlock slowpaths
locking: Remove deprecated smp_mb__() barriers
Pull arch atomic cleanups from Ingo Molnar:
"This is a series kept separate from the main locking tree, which
cleans up and improves various details in the atomics type handling:
- Remove the unused atomic_or_long() method
- Consolidate and compress atomic ops implementations between
architectures, to reduce linecount and to make it easier to add new
ops.
- Rewrite generic atomic support to only require cmpxchg() from an
architecture - generate all other methods from that"
* 'locking-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
locking,arch: Use ACCESS_ONCE() instead of cast to volatile in atomic_read()
locking, mips: Fix atomics
locking, sparc64: Fix atomics
locking,arch: Rewrite generic atomic support
locking,arch,xtensa: Fold atomic_ops
locking,arch,sparc: Fold atomic_ops
locking,arch,sh: Fold atomic_ops
locking,arch,powerpc: Fold atomic_ops
locking,arch,parisc: Fold atomic_ops
locking,arch,mn10300: Fold atomic_ops
locking,arch,mips: Fold atomic_ops
locking,arch,metag: Fold atomic_ops
locking,arch,m68k: Fold atomic_ops
locking,arch,m32r: Fold atomic_ops
locking,arch,ia64: Fold atomic_ops
locking,arch,hexagon: Fold atomic_ops
locking,arch,cris: Fold atomic_ops
locking,arch,avr32: Fold atomic_ops
locking,arch,arm64: Fold atomic_ops
locking,arch,arm: Fold atomic_ops
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen updates from David Vrabel:
"Features and fixes:
- Add pvscsi frontend and backend drivers.
- Remove _PAGE_IOMAP PTE flag, freeing it for alternate uses.
- Try and keep memory contiguous during PV memory setup (reduces
SWIOTLB usage).
- Allow front/back drivers to use threaded irqs.
- Support large initrds in PV guests.
- Fix PVH guests in preparation for Xen 4.5"
* tag 'stable/for-linus-3.18-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (22 commits)
xen: remove DEFINE_XENBUS_DRIVER() macro
xen/xenbus: Remove BUG_ON() when error string trucated
xen/xenbus: Correct the comments for xenbus_grant_ring()
x86/xen: Set EFER.NX and EFER.SCE in PVH guests
xen: eliminate scalability issues from initrd handling
xen: sync some headers with xen tree
xen: make pvscsi frontend dependant on xenbus frontend
arm{,64}/xen: Remove "EXPERIMENTAL" in the description of the Xen options
xen-scsifront: don't deadlock if the ring becomes full
x86: remove the Xen-specific _PAGE_IOMAP PTE flag
x86/xen: do not use _PAGE_IOMAP PTE flag for I/O mappings
x86: skip check for spurious faults for non-present faults
xen/efi: Directly include needed headers
xen-scsiback: clean up a type issue in scsiback_make_tpg()
xen-scsifront: use GFP_ATOMIC under spin_lock
MAINTAINERS: Add xen pvscsi maintainer
xen-scsiback: Add Xen PV SCSI backend driver
xen-scsifront: Add Xen PV SCSI frontend driver
xen: Add Xen pvSCSI protocol description
xen/events: support threaded irqs for interdomain event channels
ARCH_USES_NUMA_PROT_NONE was defined for architectures that implemented
_PAGE_NUMA using _PROT_NONE. This saved using an additional PTE bit and
relied on the fact that PROT_NONE vmas were skipped by the NUMA hinting
fault scanner. This was found to be conceptually confusing with a lot of
implicit assumptions and it was asked that an alternative be found.
Commit c46a7c81 "x86: define _PAGE_NUMA by reusing software bits on the
PMD and PTE levels" redefined _PAGE_NUMA on x86 to be one of the swap PTE
bits and shrunk the maximum possible swap size but it did not go far
enough. There are no architectures that reuse _PROT_NONE as _PROT_NUMA
but the relics still exist.
This patch removes ARCH_USES_NUMA_PROT_NONE and removes some unnecessary
duplication in powerpc vs the generic implementation by defining the types
the core NUMA helpers expected to exist from x86 with their ppc64
equivalent. This necessitated that a PTE bit mask be created that
identified the bits that distinguish present from NUMA pte entries but it
is expected this will only differ between arches based on _PAGE_PROTNONE.
The naming for the generic helpers was taken from x86 originally but ppc64
has types that are equivalent for the purposes of the helper so they are
mapped instead of duplicating code.
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Pull timer fixes from Ingo Molnar:
"Main changes:
- Fix the deadlock reported by Dave Jones et al
- Clean up and fix nohz_full interaction with arch abilities
- nohz init code consolidation/cleanup"
* 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
nohz: nohz full depends on irq work self IPI support
nohz: Consolidate nohz full init code
arm64: Tell irq work about self IPI support
arm: Tell irq work about self IPI support
x86: Tell irq work about self IPI support
irq_work: Force raised irq work to run on irq work interrupt
irq_work: Introduce arch_irq_work_has_interrupt()
nohz: Move nohz full init call to tick init
Pull KVM updates from Paolo Bonzini:
"Fixes and features for 3.18.
Apart from the usual cleanups, here is the summary of new features:
- s390 moves closer towards host large page support
- PowerPC has improved support for debugging (both inside the guest
and via gdbstub) and support for e6500 processors
- ARM/ARM64 support read-only memory (which is necessary to put
firmware in emulated NOR flash)
- x86 has the usual emulator fixes and nested virtualization
improvements (including improved Windows support on Intel and
Jailhouse hypervisor support on AMD), adaptive PLE which helps
overcommitting of huge guests. Also included are some patches that
make KVM more friendly to memory hot-unplug, and fixes for rare
caching bugs.
Two patches have trivial mm/ parts that were acked by Rik and Andrew.
Note: I will soon switch to a subkey for signing purposes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (157 commits)
kvm: do not handle APIC access page if in-kernel irqchip is not in use
KVM: s390: count vcpu wakeups in stat.halt_wakeup
KVM: s390/facilities: allow TOD-CLOCK steering facility bit
KVM: PPC: BOOK3S: HV: CMA: Reserve cma region only in hypervisor mode
arm/arm64: KVM: Report correct FSC for unsupported fault types
arm/arm64: KVM: Fix VTTBR_BADDR_MASK and pgd alloc
kvm: Fix kvm_get_page_retry_io __gup retval check
arm/arm64: KVM: Fix set_clear_sgi_pend_reg offset
kvm: x86: Unpin and remove kvm_arch->apic_access_page
kvm: vmx: Implement set_apic_access_page_addr
kvm: x86: Add request bit to reload APIC access page address
kvm: Add arch specific mmu notifier for page invalidation
kvm: Rename make_all_cpus_request() to kvm_make_all_cpus_request() and make it non-static
kvm: Fix page ageing bugs
kvm/x86/mmu: Pass gfn and level to rmapp callback.
x86: kvm: use alternatives for VMCALL vs. VMMCALL if kernel text is read-only
kvm: x86: use macros to compute bank MSRs
KVM: x86: Remove debug assertion of non-PAE reserved bits
kvm: don't take vcpu mutex for obviously invalid vcpu ioctls
kvm: Faults which trigger IO release the mmap_sem
It is currently possible to execve() an x32 executable on an x86_64
kernel that has only ia32 compat enabled. However all its syscalls
will fail, even _exit(). This usually causes it to segfault.
Change the ELF compat architecture check so that x32 executables are
rejected if we don't support the x32 ABI.
Link: http://lkml.kernel.org/r/1410120305.6822.9.camel@decadent.org.uk
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux
Pull "tinification" patches from Josh Triplett.
Work on making smaller kernels.
* tag 'tiny/for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux:
bloat-o-meter: Ignore syscall aliases SyS_ and compat_SyS_
mm: Support compiling out madvise and fadvise
x86: Support compiling out human-friendly processor feature names
x86: Drop support for /proc files when !CONFIG_PROC_FS
x86, boot: Don't compile early_serial_console.c when !CONFIG_EARLY_PRINTK
x86, boot: Don't compile aslr.c when !CONFIG_RANDOMIZE_BASE
x86, boot: Use the usual -y -n mechanism for objects in vmlinux
x86: Add "make tinyconfig" to configure the tiniest possible kernel
x86, platform, kconfig: move kvmconfig functionality to a helper
arch/x86/boot/compressed/eboot.c
commit 5dc3826d9f08 ("efi: Implement mandatory locking for UEFI Runtime
Services") implemented some conditional locking when accessing variable
runtime services that Ingo described as "pretty disgusting".
The intention with the !efi_in_nmi() checks was to avoid live-locks when
trying to write pstore crash data into an EFI variable. Such lockless
accesses are allowed according to the UEFI specification when we're in a
"non-recoverable" state, but whether or not things are implemented
correctly in actual firmware implementations remains an unanswered
question, and so it would seem sensible to avoid doing any kind of
unsynchronized variable accesses.
Furthermore, the efi_in_nmi() tests are inadequate because they don't
account for the case where we call EFI variable services from panic or
oops callbacks and aren't executing in NMI context. In other words,
live-locking is still possible.
Let's just remove the conditional locking altogether. Now we've got the
->set_variable_nonblocking() EFI variable operation we can abort if the
runtime lock is already held. Aborting is by far the safest option.
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
The 32 bit and 64 bit implementations differ in their __init annotations
for some functions referenced from the common EFI code. Namely, the 32
bit variant is missing some of the __init annotations the 64 bit variant
has.
To solve the colliding annotations, mark the corresponding functions in
efi_32.c as initialization code, too -- as it is such.
Actually, quite a few more functions are only used during initialization
and therefore can be marked __init. They are therefore annotated, too.
Also add the __init annotation to the prototypes in the efi.h header so
users of those functions will see it's meant as initialization code
only.
This patch also fixes the "prelog" typo. ("prologue" / "epilogue" might
be more appropriate but this is C code after all, not an opera! :D)
Signed-off-by: Mathias Krause <minipli@googlemail.com>
This variable was accidentally exported, even though it's only used in
this compilation unit and only during initialization.
Remove the bogus export, make the variable static instead and mark it
as __initdata.
Fixes: 200001eb140e ("x86 boot: only pick up additional EFI memmap...")
Cc: Paul Jackson <pj@sgi.com>
Complement commit 62fa6e69a436 ("x86/efi: Delete most of the efi_call*
macros") and delete the stub macros for the !CONFIG_EFI case, too. In
fact, there are no EFI calls in this case so we don't need a dummy for
efi_call() even.
According to section 7.1 of the UEFI spec, Runtime Services are not fully
reentrant, and there are particular combinations of calls that need to be
serialized. Use a spinlock to serialize all Runtime Services with respect
to all others, even if this is more than strictly needed.
We've managed to get away without requiring a runtime services lock
until now because most of the interactions with EFI involve EFI
variables, and those operations are already serialised with
__efivars->lock.
Some of the assumptions underlying the decision whether locks are
needed or not (e.g., SetVariable() against ResetSystem()) may not
apply universally to all [new] architectures that implement UEFI.
Rather than try to reason our way out of this, let's just implement at
least what the spec requires in terms of locking.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Use the much more reader friendly ACCESS_ONCE() instead of the cast to volatile.
This is purely a stylistic change.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Link: http://lkml.kernel.org/r/1411482607-20948-1-git-send-email-bobby.prani@gmail.com
"This has:
- EFI revert to fix a boot regression
- early_ioremap() fix for boot failure
- KASLR fix for possible boot failures
- EFI fix for corrupted string printing
- remove a misleading EFI bootup 'failed!' error message
Unfortunately it's all rather close to the merge window"
x86/efi: Truncate 64-bit values when calling 32-bit OutputString()
x86/efi: Delete misleading efi_printk() error message
Revert "efi/x86: efistub: Move shared dependencies to <asm/efi.h>"
x86/kaslr: Avoid the setup_data area when picking location
x86 early_ioremap: Increase FIX_BTMAPS_SLOTS to 8
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into x86/urgent
Pull EFI fixes from Matt Fleming:
* Revert the static library changes from the merge window since they're
causing issues for Macbooks and Fedora + Grub2 (Matt Fleming)
* Delete the misleading "setup_efi_pci() failed!" message which some
people are seeing when booting EFI (Matt Fleming)
* Fix printing strings from the 32-bit EFI boot stub by only passing
32-bit addresses to the firmware (Matt Fleming)
In order to make the APIC access page migratable, stop pinning it in
memory.
And because the APIC access page is not pinned in memory, we can
remove kvm_arch->apic_access_page. When we need to write its
physical address into vmcs, we use gfn_to_page() to get its page
struct, which is needed to call page_to_phys(); the page is then
immediately unpinned.
Suggested-by: Gleb Natapov <gleb@kernel.org>
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Currently, the APIC access page is pinned by KVM for the entire life
of the guest. We want to make it migratable in order to make memory
hot-unplug available for machines that run KVM.
This patch prepares to handle this in generic code, through a new
request bit (that will be set by the MMU notifier) and a new hook
that is called whenever the request bit is processed.
This will be used to let the guest run while the APIC access page is
not pinned. Because subsequent patches will fill in the function
for x86, place the (still empty) x86 implementation in the x86.c file
instead of adding an inline function in kvm_host.h.
1. We were calling clear_flush_young_notify in unmap_one, but we are
within an mmu notifier invalidate range scope. The spte exists no more
(due to range_start) and the accessed bit info has already been
propagated (due to kvm_pfn_set_accessed). Simply call
clear_flush_young.
2. We clear_flush_young on a primary MMU PMD, but this may be mapped
as a collection of PTEs by the secondary MMU (e.g. during log-dirty).
This required expanding the interface of the clear_flush_young mmu
notifier, so a lot of code has been trivially touched.
3. In the absence of shadow_accessed_mask (e.g. EPT A bit), we emulate
the access bit by blowing the spte. This requires proper synchronizing
with MMU notifier consumers, like every other removal of spte's does.
Signed-off-by: Andres Lagar-Cavilla <andreslc@google.com>
On x86_64, kernel text mappings are mapped read-only with CONFIG_DEBUG_RODATA.
In that case, KVM will fail to patch VMCALL instructions to VMMCALL
as required on AMD processors.
The failure mode is currently a divide-by-zero exception, which obviously
is a KVM bug that has to be fixed. However, picking the right instruction
between VMCALL and VMMCALL will be faster and will help if you cannot upgrade
the hypervisor.
Reported-by: Chris Webb <chris@arachsys.com>
Tested-by: Chris Webb <chris@arachsys.com>
Cc: x86@kernel.org
Acked-by: Borislav Petkov <bp@suse.de>
A one-line wrapper around kvm_make_request is not particularly
useful. Replace kvm_mmu_flush_tlb() with kvm_make_request().
Signed-off-by: Liang Chen <liangchen.linux@gmail.com>
This reverts commit f23cf8bd5c1f ("efi/x86: efistub: Move shared
dependencies to <asm/efi.h>") as well as the x86 parts of commit
f4f75ad5741f ("efi: efistub: Convert into static library").
The road leading to these two reverts is long and winding.
The above two commits were merged during the v3.17 merge window and
turned the common EFI boot stub code into a static library. This
necessitated making some symbols global in the x86 boot stub which
introduced new entries into the early boot GOT.
The problem was that we weren't fixing up the newly created GOT entries
before invoking the EFI boot stub, which sometimes resulted in hangs or
resets. This failure was reported by Maarten on his Macbook pro.
The proposed fix was commit 9cb0e394234d ("x86/efi: Fixup GOT in all
boot code paths"). However, that caused issues for Linus when booting
his Sony Vaio Pro 11. It was subsequently reverted in commit
f3670394c29f.
So that leaves us back with Maarten's Macbook pro not booting.
At this stage in the release cycle the least risky option is to revert
the x86 EFI boot stub to the pre-merge window code structure where we
explicitly #include efi-stub-helper.c instead of linking with the static
library. The arm64 code remains unaffected.
We can take another swing at the x86 parts for v3.18.
arch/x86/include/asm/efi.h
Tested-by: Josh Boyer <jwboyer@fedoraproject.org>
Tested-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Tested-by: Leif Lindholm <leif.lindholm@linaro.org> [arm64]
Tested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>,
The _PAGE_IO_MAP PTE flag was only used by Xen PV guests to mark PTEs
that were used to map I/O regions that are 1:1 in the p2m. This
allowed Xen to obtain the correct PFN when converting the MFNs read
from a PTE back to their PFN.
Xen guests no longer use _PAGE_IOMAP for this. Instead mfn_to_pfn()
returns the correct PFN by using a combination of the m2p and p2m to
determine if an MFN corresponds to a 1:1 mapping in the the p2m.
Remove _PAGE_IOMAP, replacing it with _PAGE_UNUSED2 to allow for
future uses of the PTE flag.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
dma-contiguous.h is now in asm-generic. Use that to avoid code
repetition in x86.
Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Cc: catalin.marinas@arm.com
Cc: will.deacon@arm.com
Cc: tglx@linutronix.de
Cc: mingo@redhat.com
Cc: hpa@zytor.com
Cc: arnd@arndb.de
Cc: gregkh@linuxfoundation.org
Cc: m.szyprowski@samsung.com
Cc: x86@kernel.org
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/7359/
"Misc fixes:
EFI fixes, a build fix, a page table dumping (debug) fix and a clang
build fix"
efi/arm64: Fix fdt-related memory reservation
x86/mm: Apply the section attribute to the variable, not its type
x86/efi: Fixup GOT in all boot code paths
x86/efi: Only load initrd above 4g on second try
x86-64, ptdump: Mark espfix area only if existent
x86, irq: Fix build error caused by 9eabc99a635a77cbf09
Pull EFI fix from Matt Fleming:
* Increase the number of early_ioremap() slots to fix a regression with
earlyprintk=efi after recent changes to the ACPI code (Dave Young)
kvm_arch->ept_identity_pagetable holds the ept identity pagetable page. But
it is never used to refer to the page at all.
In vcpu initialization, it indicates two things:
1. indicates if ept page is allocated
2. indicates if a memory slot for identity page is initialized
Actually, kvm_arch->ept_identity_pagetable_done is enough to tell if the ept
identity pagetable is initialized. So we can remove ept_identity_pagetable.
NOTE: In the original code, ept identity pagetable page is pinned in memroy.
As a result, it cannot be migrated/hot-removed. After this patch, since
kvm_arch->ept_identity_pagetable is removed, ept identity pagetable page
is no longer pinned in memory. And it can be migrated/hot-removed.
Reviewed-by: Gleb Natapov <gleb@kernel.org>
The setup_node_data() function allocates a pg_data_t object,
inserts it into the node_data[] array and initializes the
following fields: node_id, node_start_pfn and
node_spanned_pages.
However, a few function calls later during the kernel boot,
free_area_init_node() re-initializes those fields, possibly with
setup_node_data() is not used.
This causes a small glitch when running Linux as a hyperv numa
guest:
SRAT: PXM 0 -> APIC 0x00 -> Node 0
SRAT: PXM 0 -> APIC 0x01 -> Node 0
SRAT: PXM 1 -> APIC 0x02 -> Node 1
SRAT: PXM 1 -> APIC 0x03 -> Node 1
SRAT: Node 0 PXM 0 [mem 0x00000000-0x7fffffff]
SRAT: Node 1 PXM 1 [mem 0x80200000-0xf7ffffff]
SRAT: Node 1 PXM 1 [mem 0x100000000-0x1081fffff]
NUMA: Node 1 [mem 0x80200000-0xf7ffffff] + [mem 0x100000000-0x1081fffff] -> [mem 0x80200000-0x1081fffff]
Initmem setup node 0 [mem 0x00000000-0x7fffffff]
NODE_DATA [mem 0x7ffdc000-0x7ffeffff]
Initmem setup node 1 [mem 0x80800000-0x1081fffff]
NODE_DATA [mem 0x1081ea000-0x1081fdfff]
crashkernel: memory value expected
[ffffea0000000000-ffffea0001ffffff] PMD -> [ffff88007de00000-ffff88007fdfffff] on node 0
[ffffea0002000000-ffffea00043fffff] PMD -> [ffff880105600000-ffff8801077fffff] on node 1
Zone ranges:
DMA [mem 0x00001000-0x00ffffff]
DMA32 [mem 0x01000000-0xffffffff]
Normal [mem 0x100000000-0x1081fffff]
Movable zone start for each node
Early memory node ranges
node 0: [mem 0x00001000-0x0009efff]
node 0: [mem 0x00100000-0x7ffeffff]
node 1: [mem 0x80200000-0xf7ffffff]
node 1: [mem 0x100000000-0x1081fffff]
On node 0 totalpages: 524174
DMA zone: 64 pages used for memmap
DMA zone: 21 pages reserved
DMA zone: 3998 pages, LIFO batch:0
DMA32 zone: 8128 pages used for memmap
DMA32 zone: 520176 pages, LIFO batch:31
On node 1 totalpages: 524288
DMA32 zone: 7672 pages used for memmap
DMA32 zone: 491008 pages, LIFO batch:31
Normal zone: 520 pages used for memmap
Normal zone: 33280 pages, LIFO batch:7
In this dmesg, the SRAT table reports that the memory range for
node 1 starts at 0x80200000. However, the line starting with
"Initmem" reports that node 1 memory range starts at 0x80800000.
The "Initmem" line is reported by setup_node_data() and is
wrong, because the kernel ends up using the range as reported in
the SRAT table.
This commit drops all that dead code from setup_node_data(),
renames it to alloc_node_data() and adds a printk() to
free_area_init_node() so that we report a node's memory range
accurately.
Here's the same dmesg section with this patch applied:
NODE_DATA(0) allocated [mem 0x7ffdc000-0x7ffeffff]
NODE_DATA(1) allocated [mem 0x1081ea000-0x1081fdfff]
Zone ranges:
Initmem setup node 0 [mem 0x00001000-0x7ffeffff]
Initmem setup node 1 [mem 0x80200000-0x1081fffff]
This commit was tested on a two node bare-metal NUMA machine and
Linux as a numa guest on hyperv and qemu/kvm.
PS: The wrong memory range reported by setup_node_data() seems to be
harmless in the current kernel because it's just not used. However,
that bad range is used in kernel 2.6.32 to initialize the old boot
memory allocator, which causes a crash during boot.
Signed-off-by: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Yinghai Lu <yinghai@kernel.org>
When hot-adding/removing memory, sync_global_pgds() is called
for synchronizing PGD to PGD entries of all processes MM. But
when hot-removing memory, sync_global_pgds() does not work
correctly.
At first, sync_global_pgds() checks whether target PGD is none
or not. And if PGD is none, the PGD is skipped. But when
hot-removing memory, PGD may be none since PGD may be cleared by
free_pud_table(). So when sync_global_pgds() is called after
hot-removing memory, sync_global_pgds() should not skip PGD even
if the PGD is none. And sync_global_pgds() must clear PGD
Currently sync_global_pgds() does not clear PGD entries of all
processes MM when hot-removing memory. So when hot adding
memory which is same memory range as removed memory after
hot-removing memory, following call traces are shown:
kernel BUG at arch/x86/mm/init_64.c:206!
[<ffffffff815e0c80>] kernel_physical_mapping_init+0x1b2/0x1d2
[<ffffffff815ced94>] init_memory_mapping+0x1d4/0x380
[<ffffffff8104aebd>] arch_add_memory+0x3d/0xd0
[<ffffffff815d03d9>] add_memory+0xb9/0x1b0
[<ffffffff81352415>] acpi_memory_device_add+0x1af/0x28e
[<ffffffff81325dc4>] acpi_bus_device_attach+0x8c/0xf0
[<ffffffff813413b9>] acpi_ns_walk_namespace+0xc8/0x17f
[<ffffffff81325d38>] ? acpi_bus_type_and_status+0xb7/0xb7
[<ffffffff813418ed>] acpi_walk_namespace+0x95/0xc5
[<ffffffff81326b4c>] acpi_bus_scan+0x9a/0xc2
[<ffffffff81326bff>] acpi_scan_bus_device_check+0x8b/0x12e
[<ffffffff81326cb5>] acpi_scan_device_check+0x13/0x15
[<ffffffff81320122>] acpi_os_execute_deferred+0x25/0x32
[<ffffffff8107e02b>] process_one_work+0x17b/0x460
[<ffffffff8107edfb>] worker_thread+0x11b/0x400
[<ffffffff8107ece0>] ? rescuer_thread+0x400/0x400
[<ffffffff81085aef>] kthread+0xcf/0xe0
[<ffffffff81085a20>] ? kthread_create_on_node+0x140/0x140
[<ffffffff815fc76c>] ret_from_fork+0x7c/0xb0
This patch clears PGD entries of all processes MM when
sync_global_pgds() is called after hot-removing memory
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Acked-by: Toshi Kani <toshi.kani@hp.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Gu Zheng <guz.fnst@cn.fujitsu.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
