path: root/arch/x86/include/asm
2018-01-23x86/retpoline: Optimize inline assembler for vmexit_fill_RSBAndi Kleen
commit 3f7d875566d8e79c5e0b2c9a413e91b2c29e0854 upstream. The generated assembler for the C fill RSB inline asm operations has several issues: - The C code sets up the loop register, which is then immediately overwritten in __FILL_RETURN_BUFFER with the same value again. - The C code also passes in the iteration count in another register, which is not used at all. Remove these two unnecessary operations. Just rely on the single constant passed to the macro for the iterations. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw@amazon.co.uk> Cc: dave.hansen@intel.com Cc: gregkh@linuxfoundation.org Cc: torvalds@linux-foundation.org Cc: arjan@linux.intel.com Link: https://lkml.kernel.org/r/20180117225328.15414-1-andi@firstfloor.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23retpoline: Introduce start/end markers of indirect thunkMasami Hiramatsu
commit 736e80a4213e9bbce40a7c050337047128b472ac upstream. Introduce start/end markers of __x86_indirect_thunk_* functions. To make it easy, consolidate .text.__x86.indirect_thunk.* sections to one .text.__x86.indirect_thunk section and put it in the end of kernel text section and adds __indirect_thunk_start/end so that other subsystem (e.g. kprobes) can identify it. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw@amazon.co.uk> Cc: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Link: https://lkml.kernel.org/r/151629206178.10241.6828804696410044771.stgit@devbox Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/mce: Make machine check speculation protectedThomas Gleixner
commit 6f41c34d69eb005e7848716bbcafc979b35037d5 upstream. The machine check idtentry uses an indirect branch directly from the low level code. This evades the speculation protection. Replace it by a direct call into C code and issue the indirect call there so the compiler can apply the proper speculation protection. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by:Borislav Petkov <bp@alien8.de> Reviewed-by: David Woodhouse <dwmw@amazon.co.uk> Niced-by: Peter Zijlstra <peterz@infradead.org> Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1801181626290.1847@nanos Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/cpufeature: Move processor tracing out of scattered featuresPaolo Bonzini
commit 4fdec2034b7540dda461c6ba33325dfcff345c64 upstream. Processor tracing is already enumerated in word 9 (CPUID[7,0].EBX), so do not duplicate it in the scattered features word. Besides being more tidy, this will be useful for KVM when it presents processor tracing to the guests. KVM selects host features that are supported by both the host kernel (depending on command line options, CPU errata, or whatever) and KVM. Whenever a full feature word exists, KVM's code is written in the expectation that the CPUID bit number matches the X86_FEATURE_* bit number, but this is not the case for X86_FEATURE_INTEL_PT. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Cc: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luwei Kang <luwei.kang@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: kvm@vger.kernel.org Link: http://lkml.kernel.org/r/1516117345-34561-1-git-send-email-pbonzini@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/retpoline: Add LFENCE to the retpoline/RSB filling RSB macrosTom Lendacky
commit 28d437d550e1e39f805d99f9f8ac399c778827b7 upstream. The PAUSE instruction is currently used in the retpoline and RSB filling macros as a speculation trap. The use of PAUSE was originally suggested because it showed a very, very small difference in the amount of cycles/time used to execute the retpoline as compared to LFENCE. On AMD, the PAUSE instruction is not a serializing instruction, so the pause/jmp loop will use excess power as it is speculated over waiting for return to mispredict to the correct target. The RSB filling macro is applicable to AMD, and, if software is unable to verify that LFENCE is serializing on AMD (possible when running under a hypervisor), the generic retpoline support will be used and, so, is also applicable to AMD. Keep the current usage of PAUSE for Intel, but add an LFENCE instruction to the speculation trap for AMD. The same sequence has been adopted by GCC for the GCC generated retpolines. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@alien8.de> Acked-by: David Woodhouse <dwmw@amazon.co.uk> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Paul Turner <pjt@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Jiri Kosina <jikos@kernel.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Kees Cook <keescook@google.com> Link: https://lkml.kernel.org/r/20180113232730.31060.36287.stgit@tlendack-t1.amdoffice.net Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23x86/retpoline: Fill RSB on context switch for affected CPUsDavid Woodhouse
commit c995efd5a740d9cbafbf58bde4973e8b50b4d761 upstream. On context switch from a shallow call stack to a deeper one, as the CPU does 'ret' up the deeper side it may encounter RSB entries (predictions for where the 'ret' goes to) which were populated in userspace. This is problematic if neither SMEP nor KPTI (the latter of which marks userspace pages as NX for the kernel) are active, as malicious code in userspace may then be executed speculatively. Overwrite the CPU's return prediction stack with calls which are predicted to return to an infinite loop, to "capture" speculation if this happens. This is required both for retpoline, and also in conjunction with IBRS for !SMEP && !KPTI. On Skylake+ the problem is slightly different, and an *underflow* of the RSB may cause errant branch predictions to occur. So there it's not so much overwrite, as *filling* the RSB to attempt to prevent it getting empty. This is only a partial solution for Skylake+ since there are many other conditions which may result in the RSB becoming empty. The full solution on Skylake+ is to use IBRS, which will prevent the problem even when the RSB becomes empty. With IBRS, the RSB-stuffing will not be required on context switch. [ tglx: Added missing vendor check and slighty massaged comments and changelog ] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515779365-9032-1-git-send-email-dwmw@amazon.co.uk Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/pti/efi: broken conversion from efi to kernel page tablePavel Tatashin
The page table order must be increased for EFI table in order to avoid a bug where NMI tries to change the page table to kernel page table, while efi page table is active. For more disccussion about this bug, see this thread: http://lkml.iu.edu/hypermail/linux/kernel/1801.1/00951.html Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Reviewed-by: Steven Sistare <steven.sistare@oracle.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline: Fill return stack buffer on vmexitDavid Woodhouse
commit 117cc7a908c83697b0b737d15ae1eb5943afe35b upstream. In accordance with the Intel and AMD documentation, we need to overwrite all entries in the RSB on exiting a guest, to prevent malicious branch target predictions from affecting the host kernel. This is needed both for retpoline and for IBRS. [ak: numbers again for the RSB stuffing labels] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515755487-8524-1-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline/xen: Convert Xen hypercall indirect jumpsDavid Woodhouse
commit ea08816d5b185ab3d09e95e393f265af54560350 upstream. Convert indirect call in Xen hypercall to use non-speculative sequence, when CONFIG_RETPOLINE is enabled. Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Reviewed-by: Juergen Gross <jgross@suse.com> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-10-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/spectre: Add boot time option to select Spectre v2 mitigationDavid Woodhouse
commit da285121560e769cc31797bba6422eea71d473e0 upstream. Add a spectre_v2= option to select the mitigation used for the indirect branch speculation vulnerability. Currently, the only option available is retpoline, in its various forms. This will be expanded to cover the new IBRS/IBPB microcode features. The RETPOLINE_AMD feature relies on a serializing LFENCE for speculation control. For AMD hardware, only set RETPOLINE_AMD if LFENCE is a serializing instruction, which is indicated by the LFENCE_RDTSC feature. [ tglx: Folded back the LFENCE/AMD fixes and reworked it so IBRS integration becomes simple ] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-5-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/retpoline: Add initial retpoline supportDavid Woodhouse
commit 76b043848fd22dbf7f8bf3a1452f8c70d557b860 upstream. Enable the use of -mindirect-branch=thunk-extern in newer GCC, and provide the corresponding thunks. Provide assembler macros for invoking the thunks in the same way that GCC does, from native and inline assembler. This adds X86_FEATURE_RETPOLINE and sets it by default on all CPUs. In some circumstances, IBRS microcode features may be used instead, and the retpoline can be disabled. On AMD CPUs if lfence is serialising, the retpoline can be dramatically simplified to a simple "lfence; jmp *\reg". A future patch, after it has been verified that lfence really is serialising in all circumstances, can enable this by setting the X86_FEATURE_RETPOLINE_AMD feature bit in addition to X86_FEATURE_RETPOLINE. Do not align the retpoline in the altinstr section, because there is no guarantee that it stays aligned when it's copied over the oldinstr during alternative patching. [ Andi Kleen: Rename the macros, add CONFIG_RETPOLINE option, export thunks] [ tglx: Put actual function CALL/JMP in front of the macros, convert to symbolic labels ] [ dwmw2: Convert back to numeric labels, merge objtool fixes ] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-4-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/asm: Use register variable to get stack pointer valueAndrey Ryabinin
commit 196bd485ee4f03ce4c690bfcf38138abfcd0a4bc upstream. Currently we use current_stack_pointer() function to get the value of the stack pointer register. Since commit: f5caf621ee35 ("x86/asm: Fix inline asm call constraints for Clang") ... we have a stack register variable declared. It can be used instead of current_stack_pointer() function which allows to optimize away some excessive "mov %rsp, %<dst>" instructions: -mov %rsp,%rdx -sub %rdx,%rax -cmp $0x3fff,%rax -ja ffffffff810722fd <ist_begin_non_atomic+0x2d> +sub %rsp,%rax +cmp $0x3fff,%rax +ja ffffffff810722fa <ist_begin_non_atomic+0x2a> Remove current_stack_pointer(), rename __asm_call_sp to current_stack_pointer and use it instead of the removed function. Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170929141537.29167-1-aryabinin@virtuozzo.com Signed-off-by: Ingo Molnar <mingo@kernel.org> [dwmw2: We want ASM_CALL_CONSTRAINT for retpoline] Signed-off-by: David Woodhouse <dwmw@amazon.co.ku> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/alternatives: Add missing '\n' at end of ALTERNATIVE inline asmDavid Woodhouse
commit b9e705ef7cfaf22db0daab91ad3cd33b0fa32eb9 upstream. Where an ALTERNATIVE is used in the middle of an inline asm block, this would otherwise lead to the following instruction being appended directly to the trailing ".popsection", and a failed compile. Fixes: 9cebed423c84 ("x86, alternative: Use .pushsection/.popsection") Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: ak@linux.intel.com Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Turner <pjt@google.com> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180104143710.8961-8-dwmw@amazon.co.uk Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpu/AMD: Use LFENCE_RDTSC in preference to MFENCE_RDTSCTom Lendacky
commit 9c6a73c75864ad9fa49e5fa6513e4c4071c0e29f upstream. With LFENCE now a serializing instruction, use LFENCE_RDTSC in preference to MFENCE_RDTSC. However, since the kernel could be running under a hypervisor that does not support writing that MSR, read the MSR back and verify that the bit has been set successfully. If the MSR can be read and the bit is set, then set the LFENCE_RDTSC feature, otherwise set the MFENCE_RDTSC feature. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: David Woodhouse <dwmw@amazon.co.uk> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/20180108220932.12580.52458.stgit@tlendack-t1.amdoffice.net Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpu/AMD: Make LFENCE a serializing instructionTom Lendacky
commit e4d0e84e490790798691aaa0f2e598637f1867ec upstream. To aid in speculation control, make LFENCE a serializing instruction since it has less overhead than MFENCE. This is done by setting bit 1 of MSR 0xc0011029 (DE_CFG). Some families that support LFENCE do not have this MSR. For these families, the LFENCE instruction is already serializing. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: David Woodhouse <dwmw@amazon.co.uk> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/20180108220921.12580.71694.stgit@tlendack-t1.amdoffice.net Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpufeatures: Add X86_BUG_SPECTRE_V[12]David Woodhouse
commit 99c6fa2511d8a683e61468be91b83f85452115fa upstream. Add the bug bits for spectre v1/2 and force them unconditionally for all cpus. Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/1515239374-23361-2-git-send-email-dwmw@amazon.co.uk Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/pti: Rename BUG_CPU_INSECURE to BUG_CPU_MELTDOWNThomas Gleixner
commit de791821c295cc61419a06fe5562288417d1bc58 upstream. Use the name associated with the particular attack which needs page table isolation for mitigation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw@amazon.co.uk> Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Cc: Jiri Koshina <jikos@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Andi Lutomirski <luto@amacapital.net> Cc: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Turner <pjt@google.com> Cc: Tom Lendacky <thomas.lendacky@amd.com> Cc: Greg KH <gregkh@linux-foundation.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1801051525300.1724@nanos Signed-off-by: Razvan Ghitulete <rga@amazon.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpufeatures: Add X86_BUG_CPU_INSECUREThomas Gleixner
commit a89f040fa34ec9cd682aed98b8f04e3c47d998bd upstream. Many x86 CPUs leak information to user space due to missing isolation of user space and kernel space page tables. There are many well documented ways to exploit that. The upcoming software migitation of isolating the user and kernel space page tables needs a misfeature flag so code can be made runtime conditional. Add the BUG bits which indicates that the CPU is affected and add a feature bit which indicates that the software migitation is enabled. Assume for now that _ALL_ x86 CPUs are affected by this. Exceptions can be made later. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David Laight <David.Laight@aculab.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eduardo Valentin <eduval@amazon.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: aliguori@amazon.com Cc: daniel.gruss@iaik.tugraz.at Cc: hughd@google.com Cc: keescook@google.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17x86/cpufeatures: Make CPU bugs stickyThomas Gleixner
commit 6cbd2171e89b13377261d15e64384df60ecb530e upstream. There is currently no way to force CPU bug bits like CPU feature bits. That makes it impossible to set a bug bit once at boot and have it stick for all upcoming CPUs. Extend the force set/clear arrays to handle bug bits as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bpetkov@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David Laight <David.Laight@aculab.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eduardo Valentin <eduval@amazon.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Will Deacon <will.deacon@arm.com> Cc: aliguori@amazon.com Cc: daniel.gruss@iaik.tugraz.at Cc: hughd@google.com Cc: keescook@google.com Link: https://lkml.kernel.org/r/20171204150606.992156574@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10Map the vsyscall page with _PAGE_USERBorislav Petkov
This needs to happen early in kaiser_pagetable_walk(), before the hierarchy is established so that _PAGE_USER permission can be really set. A proper fix would be to teach kaiser_pagetable_walk() to update those permissions but the vsyscall page is the only exception here so ... Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05KPTI: Rename to PAGE_TABLE_ISOLATIONKees Cook
This renames CONFIG_KAISER to CONFIG_PAGE_TABLE_ISOLATION. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05x86/kaiser: Move feature detection upBorislav Petkov
... before the first use of kaiser_enabled as otherwise funky things happen: about to get started... (XEN) d0v0 Unhandled page fault fault/trap [#14, ec=0000] (XEN) Pagetable walk from ffff88022a449090: (XEN) L4[0x110] = 0000000229e0e067 0000000000001e0e (XEN) L3[0x008] = 0000000000000000 ffffffffffffffff (XEN) domain_crash_sync called from entry.S: fault at ffff82d08033fd08 entry.o#create_bounce_frame+0x135/0x14d (XEN) Domain 0 (vcpu#0) crashed on cpu#0: (XEN) ----[ Xen-4.9.1_02-3.21 x86_64 debug=n Not tainted ]---- (XEN) CPU: 0 (XEN) RIP: e033:[<ffffffff81007460>] (XEN) RFLAGS: 0000000000000286 EM: 1 CONTEXT: pv guest (d0v0) Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: kaiser_flush_tlb_on_return_to_user() check PCIDHugh Dickins
Let kaiser_flush_tlb_on_return_to_user() do the X86_FEATURE_PCID check, instead of each caller doing it inline first: nobody needs to optimize for the noPCID case, it's clearer this way, and better suits later changes. Replace those no-op X86_CR3_PCID_KERN_FLUSH lines by a BUILD_BUG_ON() in load_new_mm_cr3(), in case something changes. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: asm/tlbflush.h handle noPGE at lower levelHugh Dickins
I found asm/tlbflush.h too twisty, and think it safer not to avoid __native_flush_tlb_global_irq_disabled() in the kaiser_enabled case, but instead let it handle kaiser_enabled along with cr3: it can just use __native_flush_tlb() for that, no harm in re-disabling preemption. (This is not the same change as Kirill and Dave have suggested for upstream, flipping PGE in cr4: that's neat, but needs a cpu_has_pge check; cr3 is enough for kaiser, and thought to be cheaper than cr4.) Also delete the X86_FEATURE_INVPCID invpcid_flush_all_nonglobals() preference from __native_flush_tlb(): unlike the invpcid_flush_all() preference in __native_flush_tlb_global(), it's not seen in upstream 4.14, and was recently reported to be surprisingly slow. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: use ALTERNATIVE instead of x86_cr3_pcid_noflushHugh Dickins
Now that we're playing the ALTERNATIVE game, use that more efficient method: instead of user-mapping an extra page, and reading an extra cacheline each time for x86_cr3_pcid_noflush. Neel has found that __stringify(bts $X86_CR3_PCID_NOFLUSH_BIT, %rax) is a working substitute for the "bts $63, %rax" in these ALTERNATIVEs; but the one line with $63 in looks clearer, so let's stick with that. Worried about what happens with an ALTERNATIVE between the jump and jump label in another ALTERNATIVE? I was, but have checked the combinations in SWITCH_KERNEL_CR3_NO_STACK at entry_SYSCALL_64, and it does a good job. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: add "nokaiser" boot option, using ALTERNATIVEHugh Dickins
Added "nokaiser" boot option: an early param like "noinvpcid". Most places now check int kaiser_enabled (#defined 0 when not CONFIG_KAISER) instead of #ifdef CONFIG_KAISER; but entry_64.S and entry_64_compat.S are using the ALTERNATIVE technique, which patches in the preferred instructions at runtime. That technique is tied to x86 cpu features, so X86_FEATURE_KAISER is fabricated. Prior to "nokaiser", Kaiser #defined _PAGE_GLOBAL 0: revert that, but be careful with both _PAGE_GLOBAL and CR4.PGE: setting them when nokaiser like when !CONFIG_KAISER, but not setting either when kaiser - neither matters on its own, but it's hard to be sure that _PAGE_GLOBAL won't get set in some obscure corner, or something add PGE into CR4. By omitting _PAGE_GLOBAL from __supported_pte_mask when kaiser_enabled, all page table setup which uses pte_pfn() masks it out of the ptes. It's slightly shameful that the same declaration versus definition of kaiser_enabled appears in not one, not two, but in three header files (asm/kaiser.h, asm/pgtable.h, asm/tlbflush.h). I felt safer that way, than with #including any of those in any of the others; and did not feel it worth an asm/kaiser_enabled.h - kernel/cpu/common.c includes them all, so we shall hear about it if they get out of synch. Cleanups while in the area: removed the silly #ifdef CONFIG_KAISER from kaiser.c; removed the unused native_get_normal_pgd(); removed the spurious reg clutter from SWITCH_*_CR3 macro stubs; corrected some comments. But more interestingly, set CR4.PSE in secondary_startup_64: the manual is clear that it does not matter whether it's 0 or 1 when 4-level-pts are enabled, but I was distracted to find cr4 different on BSP and auxiliaries - BSP alone was adding PSE, in probe_page_size_mask(). Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: paranoid_entry pass cr3 need to paranoid_exitHugh Dickins
Neel Natu points out that paranoid_entry() was wrong to assume that an entry that did not need swapgs would not need SWITCH_KERNEL_CR3: paranoid_entry (used for debug breakpoint, int3, double fault or MCE; though I think it's only the MCE case that is cause for concern here) can break in at an awkward time, between cr3 switch and swapgs, but its handling always needs kernel gs and kernel cr3. Easy to fix in itself, but paranoid_entry() also needs to convey to paranoid_exit() (and my reading of macro idtentry says paranoid_entry and paranoid_exit are always paired) how to restore the prior state. The swapgs state is already conveyed by %ebx (0 or 1), so extend that also to convey when SWITCH_USER_CR3 will be needed (2 or 3). (Yes, I'd much prefer that 0 meant no swapgs, whereas it's the other way round: and a convention shared with error_entry() and error_exit(), which I don't want to touch. Perhaps I should have inverted the bit for switch cr3 too, but did not.) paranoid_exit() would be straightforward, except for TRACE_IRQS: it did TRACE_IRQS_IRETQ when doing swapgs, but TRACE_IRQS_IRETQ_DEBUG when not: which is it supposed to use when SWITCH_USER_CR3 is split apart from that? As best as I can determine, commit 5963e317b1e9 ("ftrace/x86: Do not change stacks in DEBUG when calling lockdep") missed the swapgs case, and should have used TRACE_IRQS_IRETQ_DEBUG there too (the discrepancy has nothing to do with the liberal use of _NO_STACK and _UNSAFE_STACK hereabouts: TRACE_IRQS_OFF_DEBUG has just been used in all cases); discrepancy lovingly preserved across several paranoid_exit() cleanups, but I'm now removing it. Neel further indicates that to use SWITCH_USER_CR3_NO_STACK there in paranoid_exit() is now not only unnecessary but unsafe: might corrupt syscall entry's unsafe_stack_register_backup of %rax. Just use SWITCH_USER_CR3: and delete SWITCH_USER_CR3_NO_STACK altogether, before we make the mistake of using it again. hughd adds: this commit fixes an issue in the Kaiser-without-PCIDs part of the series, and ought to be moved earlier, if you decided to make a release of Kaiser-without-PCIDs. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: x86_cr3_pcid_noflush and x86_cr3_pcid_userHugh Dickins
Mostly this commit is just unshouting X86_CR3_PCID_KERN_VAR and X86_CR3_PCID_USER_VAR: we usually name variables in lower-case. But why does x86_cr3_pcid_noflush need to be __aligned(PAGE_SIZE)? Ah, it's a leftover from when kaiser_add_user_map() once complained about mapping the same page twice. Make it __read_mostly instead. (I'm a little uneasy about all the unrelated data which shares its page getting user-mapped too, but that was so before, and not a big deal: though we call it user-mapped, it's not mapped with _PAGE_USER.) And there is a little change around the two calls to do_nmi(). Previously they set the NOFLUSH bit (if PCID supported) when forcing to kernel context before do_nmi(); now they also have the NOFLUSH bit set (if PCID supported) when restoring context after: nothing done in do_nmi() should require a TLB to be flushed here. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: PCID 0 for kernel and 128 for userHugh Dickins
Why was 4 chosen for kernel PCID and 6 for user PCID? No good reason in a backport where PCIDs are only used for Kaiser. If we continue with those, then we shall need to add Andy Lutomirski's 4.13 commit 6c690ee1039b ("x86/mm: Split read_cr3() into read_cr3_pa() and __read_cr3()"), which deals with the problem of read_cr3() callers finding stray bits in the cr3 that they expected to be page-aligned; and for hibernation, his 4.14 commit f34902c5c6c0 ("x86/hibernate/64: Mask off CR3's PCID bits in the saved CR3"). But if 0 is used for kernel PCID, then there's no need to add in those commits - whenever the kernel looks, it sees 0 in the lower bits; and 0 for kernel seems an obvious choice. And I naughtily propose 128 for user PCID. Because there's a place in _SWITCH_TO_USER_CR3 where it takes note of the need for TLB FLUSH, but needs to reset that to NOFLUSH for the next occasion. Currently it does so with a "movb $(0x80)" into the high byte of the per-cpu quadword, but that will cause a machine without PCID support to crash. Now, if %al just happened to have 0x80 in it at that point, on a machine with PCID support, but 0 on a machine without PCID support... (That will go badly wrong once the pgd can be at a physical address above 2^56, but even with 5-level paging, physical goes up to 2^52.) Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: load_new_mm_cr3() let SWITCH_USER_CR3 flush userHugh Dickins
We have many machines (Westmere, Sandybridge, Ivybridge) supporting PCID but not INVPCID: on these load_new_mm_cr3() simply crashed. Flushing user context inside load_new_mm_cr3() without the use of invpcid is difficult: momentarily switch from kernel to user context and back to do so? I'm not sure whether that can be safely done at all, and would risk polluting user context with kernel internals, and kernel context with stale user externals. Instead, follow the hint in the comment that was there: change X86_CR3_PCID_USER_VAR to be a per-cpu variable, then load_new_mm_cr3() can leave a note in it, for SWITCH_USER_CR3 on return to userspace to flush user context TLB, instead of default X86_CR3_PCID_USER_NOFLUSH. Which works well enough that there's no need to do it this way only when invpcid is unsupported: it's a good alternative to invpcid here. But there's a couple of inlines in asm/tlbflush.h that need to do the same trick, so it's best to localize all this per-cpu business in mm/kaiser.c: moving that part of the initialization from setup_pcid() to kaiser_setup_pcid(); with kaiser_flush_tlb_on_return_to_user() the function for noting an X86_CR3_PCID_USER_FLUSH. And let's keep a KAISER_SHADOW_PGD_OFFSET in there, to avoid the extra OR on exit. I did try to make the feature tests in asm/tlbflush.h more consistent with each other: there seem to be far too many ways of performing such tests, and I don't have a good grasp of their differences. At first I converted them all to be static_cpu_has(): but that proved to be a mistake, as the comment in __native_flush_tlb_single() hints; so then I reversed and made them all this_cpu_has(). Probably all gratuitous change, but that's the way it's working at present. I am slightly bothered by the way non-per-cpu X86_CR3_PCID_KERN_VAR gets re-initialized by each cpu (before and after these changes): no problem when (as usual) all cpus on a machine have the same features, but in principle incorrect. However, my experiment to per-cpu-ify that one did not end well... Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: enhanced by kernel and user PCIDsHugh Dickins
Merged performance improvements to Kaiser, using distinct kernel and user Process Context Identifiers to minimize the TLB flushing. [This work actually all from Dave Hansen 2017-08-30: still omitting trackswitch mods, and KAISER_REAL_SWITCH deleted.] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: delete KAISER_REAL_SWITCH optionHugh Dickins
We fail to see what CONFIG_KAISER_REAL_SWITCH is for: it seems to be left over from early development, and now just obscures tricky parts of the code. Delete it before adding PCIDs, or nokaiser boot option. (Or if there is some good reason to keep the option, then it needs a help text - and a "depends on KAISER", so that all those without KAISER are not asked the question. But we'd much rather delete it.) Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: name that 0x1000 KAISER_SHADOW_PGD_OFFSETHugh Dickins
There's a 0x1000 in various places, which looks better with a name. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: cleanups while trying for gold linkHugh Dickins
While trying to get our gold link to work, four cleanups: matched the gdt_page declaration to its definition; in fiddling unsuccessfully with PERCPU_INPUT(), lined up backslashes; lined up the backslashes according to convention in percpu-defs.h; deleted the unused irq_stack_pointer addition to irq_stack_union. Sad to report that aligning backslashes does not appear to help gold align to 8192: but while these did not help, they are worth keeping. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: tidied up asm/kaiser.h somewhatHugh Dickins
Mainly deleting a surfeit of blank lines, and reflowing header comment. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: do not set _PAGE_NX on pgd_noneHugh Dickins
native_pgd_clear() uses native_set_pgd(), so native_set_pgd() must avoid setting the _PAGE_NX bit on an otherwise pgd_none() entry: usually that just generated a warning on exit, but sometimes more mysterious and damaging failures (our production machines could not complete booting). The original fix to this just avoided adding _PAGE_NX to an empty entry; but eventually more problems surfaced with kexec, and EFI mapping expected to be a problem too. So now instead change native_set_pgd() to update shadow only if _PAGE_USER: A few places (kernel/machine_kexec_64.c, platform/efi/efi_64.c for sure) use set_pgd() to set up a temporary internal virtual address space, with physical pages remapped at what Kaiser regards as userspace addresses: Kaiser then assumes a shadow pgd follows, which it will try to corrupt. This appears to be responsible for the recent kexec and kdump failures; though it's unclear how those did not manifest as a problem before. Ah, the shadow pgd will only be assumed to "follow" if the requested pgd is on an even-numbered page: so I suppose it was going wrong 50% of the time all along. What we need is a flag to set_pgd(), to tell it we're dealing with userspace. Er, isn't that what the pgd's _PAGE_USER bit is saying? Add a test for that. But we cannot do the same for pgd_clear() (which may be called to clear corrupted entries - set aside the question of "corrupt in which pgd?" until later), so there just rely on pgd_clear() not being called in the problematic cases - with a WARN_ON_ONCE() which should fire half the time if it is. But this is getting too big for an inline function: move it into arch/x86/mm/kaiser.c (which then demands a boot/compressed mod); and de-void and de-space native_get_shadow/normal_pgd() while here. Also make an unnecessary change to KASLR's init_trampoline(): it was using set_pgd() to assign a pgd-value to a global variable (not in a pg directory page), which was rather scary given Kaiser's previous set_pgd() implementation: not a problem now, but too scary to leave as was, it could easily blow up if we have to change set_pgd() again. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: merged updateDave Hansen
Merged fixes and cleanups, rebased to 4.9.51 tree (no 5-level paging). Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05KAISER: Kernel Address IsolationRichard Fellner
This patch introduces our implementation of KAISER (Kernel Address Isolation to have Side-channels Efficiently Removed), a kernel isolation technique to close hardware side channels on kernel address information. More information about the patch can be found on: https://github.com/IAIK/KAISER From: Richard Fellner <richard.fellner@student.tugraz.at> From: Daniel Gruss <daniel.gruss@iaik.tugraz.at> Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode Date: Thu, 4 May 2017 14:26:50 +0200 Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2 Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5 To: <linux-kernel@vger.kernel.org> To: <kernel-hardening@lists.openwall.com> Cc: <clementine.maurice@iaik.tugraz.at> Cc: <moritz.lipp@iaik.tugraz.at> Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Cc: Richard Fellner <richard.fellner@student.tugraz.at> Cc: Ingo Molnar <mingo@kernel.org> Cc: <kirill.shutemov@linux.intel.com> Cc: <anders.fogh@gdata-adan.de> After several recent works [1,2,3] KASLR on x86_64 was basically considered dead by many researchers. We have been working on an efficient but effective fix for this problem and found that not mapping the kernel space when running in user mode is the solution to this problem [4] (the corresponding paper [5] will be presented at ESSoS17). With this RFC patch we allow anybody to configure their kernel with the flag CONFIG_KAISER to add our defense mechanism. If there are any questions we would love to answer them. We also appreciate any comments! Cheers, Daniel (+ the KAISER team from Graz University of Technology) [1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf [2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf [3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf [4] https://github.com/IAIK/KAISER [5] https://gruss.cc/files/kaiser.pdf [patch based also on https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch] Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at> Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at> Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at> Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05x86/boot: Add early cmdline parsing for options with argumentsTom Lendacky
commit e505371dd83963caae1a37ead9524e8d997341be upstream. Add a cmdline_find_option() function to look for cmdline options that take arguments. The argument is returned in a supplied buffer and the argument length (regardless of whether it fits in the supplied buffer) is returned, with -1 indicating not found. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Alexander Potapenko <glider@google.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Brijesh Singh <brijesh.singh@amd.com> Cc: Dave Young <dyoung@redhat.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Toshimitsu Kani <toshi.kani@hpe.com> Cc: kasan-dev@googlegroups.com Cc: kvm@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: linux-doc@vger.kernel.org Cc: linux-efi@vger.kernel.org Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/36b5f97492a9745dce27682305f990fc20e5cf8a.1500319216.git.thomas.lendacky@amd.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02x86/mm: Enable CR4.PCIDE on supported systemsAndy Lutomirski
commit 660da7c9228f685b2ebe664f9fd69aaddcc420b5 upstream. We can use PCID if the CPU has PCID and PGE and we're not on Xen. By itself, this has no effect. A followup patch will start using PCID. Signed-off-by: Andy Lutomirski <luto@kernel.org> Reviewed-by: Nadav Amit <nadav.amit@gmail.com> Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/6327ecd907b32f79d5aa0d466f04503bbec5df88.1498751203.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02x86/mm: Disable PCID on 32-bit kernelsAndy Lutomirski
commit cba4671af7550e008f7a7835f06df0763825bf3e upstream. 32-bit kernels on new hardware will see PCID in CPUID, but PCID can only be used in 64-bit mode. Rather than making all PCID code conditional, just disable the feature on 32-bit builds. Signed-off-by: Andy Lutomirski <luto@kernel.org> Reviewed-by: Nadav Amit <nadav.amit@gmail.com> Reviewed-by: Borislav Petkov <bp@suse.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/2e391769192a4d31b808410c383c6bf0734bc6ea.1498751203.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02x86/mm: Remove the UP asm/tlbflush.h code, always use the (formerly) SMP codeAndy Lutomirski
commit ce4a4e565f5264909a18c733b864c3f74467f69e upstream. The UP asm/tlbflush.h generates somewhat nicer code than the SMP version. Aside from that, it's fallen quite a bit behind the SMP code: - flush_tlb_mm_range() didn't flush individual pages if the range was small. - The lazy TLB code was much weaker. This usually wouldn't matter, but, if a kernel thread flushed its lazy "active_mm" more than once (due to reclaim or similar), it wouldn't be unlazied and would instead pointlessly flush repeatedly. - Tracepoints were missing. Aside from that, simply having the UP code around was a maintanence burden, since it means that any change to the TLB flush code had to make sure not to break it. Simplify everything by deleting the UP code. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Borislav Petkov <bpetkov@suse.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.com> Cc: Nadav Amit <nadav.amit@gmail.com> Cc: Nadav Amit <namit@vmware.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mm@kvack.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02x86/mm: Reimplement flush_tlb_page() using flush_tlb_mm_range()Andy Lutomirski
commit ca6c99c0794875c6d1db6e22f246699691ab7e6b upstream. flush_tlb_page() was very similar to flush_tlb_mm_range() except that it had a couple of issues: - It was missing an smp_mb() in the case where current->active_mm != mm. (This is a longstanding bug reported by Nadav Amit) - It was missing tracepoints and vm counter updates. The only reason that I can see for keeping it at as a separate function is that it could avoid a few branches that flush_tlb_mm_range() needs to decide to flush just one page. This hardly seems worthwhile. If we decide we want to get rid of those branches again, a better way would be to introduce an __flush_tlb_mm_range() helper and make both flush_tlb_page() and flush_tlb_mm_range() use it. Signed-off-by: Andy Lutomirski <luto@kernel.org> Acked-by: Kees Cook <keescook@chromium.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Borislav Petkov <bpetkov@suse.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.com> Cc: Nadav Amit <nadav.amit@gmail.com> Cc: Nadav Amit <namit@vmware.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/3cc3847cf888d8907577569b8bac3f01992ef8f9.1495492063.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02x86/mm: Remove flush_tlb() and flush_tlb_current_task()Andy Lutomirski
commit 29961b59a51f8c6838a26a45e871a7ed6771809b upstream. I was trying to figure out what how flush_tlb_current_task() would possibly work correctly if current->mm != current->active_mm, but I realized I could spare myself the effort: it has no callers except the unused flush_tlb() macro. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Nadav Amit <namit@vmware.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/e52d64c11690f85e9f1d69d7b48cc2269cd2e94b.1492844372.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14KVM: x86: fix APIC page invalidationRadim Krčmář
commit b1394e745b9453dcb5b0671c205b770e87dedb87 upstream. Implementation of the unpinned APIC page didn't update the VMCS address cache when invalidation was done through range mmu notifiers. This became a problem when the page notifier was removed. Re-introduce the arch-specific helper and call it from ...range_start. Reported-by: Fabian Grünbichler <f.gruenbichler@proxmox.com> Fixes: 38b9917350cb ("kvm: vmx: Implement set_apic_access_page_addr") Fixes: 369ea8242c0f ("mm/rmap: update to new mmu_notifier semantic v2") Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Tested-by: Wanpeng Li <wanpeng.li@hotmail.com> Tested-by: Fabian Grünbichler <f.gruenbichler@proxmox.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09x86/entry: Use SYSCALL_DEFINE() macros for sys_modify_ldt()Dave Hansen
[ Upstream commit da20ab35180780e4a6eadc804544f1fa967f3567 ] We do not have tracepoints for sys_modify_ldt() because we define it directly instead of using the normal SYSCALL_DEFINEx() macros. However, there is a reason sys_modify_ldt() does not use the macros: it has an 'int' return type instead of 'unsigned long'. This is a bug, but it's a bug cemented in the ABI. What does this mean? If we return -EINVAL from a function that returns 'int', we have 0x00000000ffffffea in %rax. But, if we return -EINVAL from a function returning 'unsigned long', we end up with 0xffffffffffffffea in %rax, which is wrong. To work around this and maintain the 'int' behavior while using the SYSCALL_DEFINEx() macros, so we add a cast to 'unsigned int' in both implementations of sys_modify_ldt(). Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Andy Lutomirski <luto@kernel.org> Reviewed-by: Brian Gerst <brgerst@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20171018172107.1A79C532@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15x86/uaccess, sched/preempt: Verify access_ok() contextPeter Zijlstra
commit 7c4788950ba5922fde976d80b72baf46f14dee8d upstream. I recently encountered wreckage because access_ok() was used where it should not be, add an explicit WARN when access_ok() is used wrongly. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-18x86/alternatives: Fix alt_max_short macro to really be a max()Mathias Krause
commit 6b32c126d33d5cb379bca280ab8acedc1ca978ff upstream. The alt_max_short() macro in asm/alternative.h does not work as intended, leading to nasty bugs. E.g. alt_max_short("1", "3") evaluates to 3, but alt_max_short("3", "1") evaluates to 1 -- not exactly the maximum of 1 and 3. In fact, I had to learn it the hard way by crashing my kernel in not so funny ways by attempting to make use of the ALTENATIVE_2 macro with alternatives where the first one was larger than the second one. According to [1] and commit dbe4058a6a44 ("x86/alternatives: Fix ALTERNATIVE_2 padding generation properly") the right handed side should read "-(-(a < b))" not "-(-(a - b))". Fix that, to make the macro work as intended. While at it, fix up the comments regarding the additional "-", too. It's not about gas' usage of s32 but brain dead logic of having a "true" value of -1 for the < operator ... *sigh* Btw., the one in asm/alternative-asm.h is correct. And, apparently, all current users of ALTERNATIVE_2() pass same sized alternatives, avoiding to hit the bug. [1] http://graphics.stanford.edu/~seander/bithacks.html#IntegerMinOrMax Reviewed-and-tested-by: Borislav Petkov <bp@suse.de> Fixes: dbe4058a6a44 ("x86/alternatives: Fix ALTERNATIVE_2 padding generation properly") Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Borislav Petkov <bp@suse.de> Link: https://lkml.kernel.org/r/1507228213-13095-1-git-send-email-minipli@googlemail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-12KVM: x86: fix singlestepping over syscallPaolo Bonzini
commit c8401dda2f0a00cd25c0af6a95ed50e478d25de4 upstream. TF is handled a bit differently for syscall and sysret, compared to the other instructions: TF is checked after the instruction completes, so that the OS can disable #DB at a syscall by adding TF to FMASK. When the sysret is executed the #DB is taken "as if" the syscall insn just completed. KVM emulates syscall so that it can trap 32-bit syscall on Intel processors. Fix the behavior, otherwise you could get #DB on a user stack which is not nice. This does not affect Linux guests, as they use an IST or task gate for #DB. This fixes CVE-2017-7518. Cc: stable@vger.kernel.org Reported-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> [bwh: Backported to 4.9: - kvm_vcpu_check_singlestep() sets some flags differently - Drop changes to kvm_skip_emulated_instruction()] Cc: Ben Hutchings <benh@debian.org> Cc: Salvatore Bonaccorso <carnil@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-20x86/fsgsbase/64: Report FSBASE and GSBASE correctly in core dumpsAndy Lutomirski
commit 9584d98bed7a7a904d0702ad06bbcc94703cb5b4 upstream. In ELF_COPY_CORE_REGS, we're copying from the current task, so accessing thread.fsbase and thread.gsbase makes no sense. Just read the values from the CPU registers. In practice, the old code would have been correct most of the time simply because thread.fsbase and thread.gsbase usually matched the CPU registers. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bpetkov@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Chang Seok <chang.seok.bae@intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
