path: root/arch/x86/include/asm/preempt.h
2016-06-08x86, asm: change the GEN_*_RMWcc() macros to not quote the conditionH. Peter Anvin
Change the lexical defintion of the GEN_*_RMWcc() macros to not take the condition code as a quoted string. This will help support changing them to use the new __GCC_ASM_FLAG_OUTPUTS__ feature in a subsequent patch. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/r/1465414726-197858-4-git-send-email-hpa@linux.intel.com Reviewed-by: Andy Lutomirski <luto@kernel.org> Reviewed-by: Borislav Petkov <bp@suse.de> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
2016-02-24sched/x86: Add stack frame dependency to __preempt_schedule[_notrace]()Josh Poimboeuf
If __preempt_schedule() or __preempt_schedule_notrace() is referenced at the beginning of a function, gcc can insert the asm inline "call ___preempt_schedule[_notrace]" instruction before setting up a stack frame, which breaks frame pointer convention if CONFIG_FRAME_POINTER is enabled and can result in bad stack traces. Force a stack frame to be created if CONFIG_FRAME_POINTER is enabled by listing the stack pointer as an output operand for the inline asm statements. Specifically this fixes the following stacktool warnings: stacktool: drivers/scsi/hpsa.o: hpsa_scsi_do_simple_cmd.constprop.106()+0x79: call without frame pointer save/setup stacktool: fs/mbcache.o: mb_cache_entry_find_first()+0x70: call without frame pointer save/setup stacktool: fs/mbcache.o: mb_cache_entry_find_first()+0x92: call without frame pointer save/setup stacktool: fs/mbcache.o: mb_cache_entry_free()+0xff: call without frame pointer save/setup stacktool: fs/mbcache.o: mb_cache_entry_free()+0xf5: call without frame pointer save/setup stacktool: fs/mbcache.o: mb_cache_entry_free()+0x11a: call without frame pointer save/setup stacktool: fs/mbcache.o: mb_cache_entry_get()+0x225: call without frame pointer save/setup stacktool: kernel/locking/percpu-rwsem.o: percpu_up_read()+0x27: call without frame pointer save/setup stacktool: kernel/profile.o: do_profile_hits.isra.5()+0x139: call without frame pointer save/setup stacktool: lib/nmi_backtrace.o: nmi_trigger_all_cpu_backtrace()+0x2b6: call without frame pointer save/setup stacktool: net/rds/ib_cm.o: rds_ib_cq_comp_handler_recv()+0x58: call without frame pointer save/setup stacktool: net/rds/ib_cm.o: rds_ib_cq_comp_handler_send()+0x58: call without frame pointer save/setup stacktool: net/rds/ib_recv.o: rds_ib_attempt_ack()+0xc1: call without frame pointer save/setup stacktool: net/rds/iw_recv.o: rds_iw_attempt_ack()+0xc1: call without frame pointer save/setup stacktool: net/rds/iw_recv.o: rds_iw_recv_cq_comp_handler()+0x55: call without frame pointer save/setup So it only adds a stack frame to 15 call sites out of ~5000 calls to ___preempt_schedule[_notrace](). All the others already had stack frames. Oddly, this change actually seems to make things faster in a lot of cases. For many smaller functions it causes the stack frame creation to get moved out of the common path and into the unlikely path. For example, here's the original cyc2ns_read_end(): ffffffff8101f8c0 <cyc2ns_read_end>: ffffffff8101f8c0: 55 push %rbp ffffffff8101f8c1: 48 89 e5 mov %rsp,%rbp ffffffff8101f8c4: 83 6f 10 01 subl $0x1,0x10(%rdi) ffffffff8101f8c8: 75 08 jne ffffffff8101f8d2 <cyc2ns_read_end+0x12> ffffffff8101f8ca: 65 48 89 3d e6 5a ff mov %rdi,%gs:0x7eff5ae6(%rip) # 153b8 <cyc2ns+0x38> ffffffff8101f8d1: 7e ffffffff8101f8d2: 65 ff 0d 77 c4 fe 7e decl %gs:0x7efec477(%rip) # bd50 <__preempt_count> ffffffff8101f8d9: 74 02 je ffffffff8101f8dd <cyc2ns_read_end+0x1d> ffffffff8101f8db: 5d pop %rbp ffffffff8101f8dc: c3 retq ffffffff8101f8dd: e8 1e 37 fe ff callq ffffffff81003000 <___preempt_schedule> ffffffff8101f8e2: 5d pop %rbp ffffffff8101f8e3: c3 retq ffffffff8101f8e4: 66 66 66 2e 0f 1f 84 data16 data16 nopw %cs:0x0(%rax,%rax,1) ffffffff8101f8eb: 00 00 00 00 00 And here's the same function with the patch: ffffffff8101f8c0 <cyc2ns_read_end>: ffffffff8101f8c0: 83 6f 10 01 subl $0x1,0x10(%rdi) ffffffff8101f8c4: 75 08 jne ffffffff8101f8ce <cyc2ns_read_end+0xe> ffffffff8101f8c6: 65 48 89 3d ea 5a ff mov %rdi,%gs:0x7eff5aea(%rip) # 153b8 <cyc2ns+0x38> ffffffff8101f8cd: 7e ffffffff8101f8ce: 65 ff 0d 7b c4 fe 7e decl %gs:0x7efec47b(%rip) # bd50 <__preempt_count> ffffffff8101f8d5: 74 01 je ffffffff8101f8d8 <cyc2ns_read_end+0x18> ffffffff8101f8d7: c3 retq ffffffff8101f8d8: 55 push %rbp ffffffff8101f8d9: 48 89 e5 mov %rsp,%rbp ffffffff8101f8dc: e8 1f 37 fe ff callq ffffffff81003000 <___preempt_schedule> ffffffff8101f8e1: 5d pop %rbp ffffffff8101f8e2: c3 retq ffffffff8101f8e3: 66 66 66 66 2e 0f 1f data16 data16 data16 nopw %cs:0x0(%rax,%rax,1) ffffffff8101f8ea: 84 00 00 00 00 00 Notice that it moved the frame pointer setup code to the unlikely ___preempt_schedule() call path. Going through a sampling of the differences in the asm, that's the most common change I see. Otherwise it has no real effect on callers which already have stack frames (though it does result in the reordering of some 'mov's). Reported-by: Jiri Slaby <jslaby@suse.cz> Tested-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: live-patching@vger.kernel.org Link: http://lkml.kernel.org/r/20160218174158.GA28230@treble.redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-06sched/core, sched/x86: Kill thread_info::saved_preempt_countPeter Zijlstra
With the introduction of the context switch preempt_count invariant, and the demise of PREEMPT_ACTIVE, its pointless to save/restore the per-cpu preemption count, it must always be 2. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-06sched/core: Create preempt_count invariantPeter Zijlstra
Assuming units of PREEMPT_DISABLE_OFFSET for preempt_count() numbers. Now that TASK_DEAD no longer results in preempt_count() == 3 during scheduling, we will always call context_switch() with preempt_count() == 2. However, we don't always end up with preempt_count() == 2 in finish_task_switch() because new tasks get created with preempt_count() == 1. Create FORK_PREEMPT_COUNT and set it to 2 and use that in the right places. Note that we cannot use INIT_PREEMPT_COUNT as that serves another purpose (boot). After this, preempt_count() is invariant across the context switch, with exception of PREEMPT_ACTIVE. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-03sched/preempt: Fix cond_resched_lock() and cond_resched_softirq()Konstantin Khlebnikov
These functions check should_resched() before unlocking spinlock/bh-enable: preempt_count always non-zero => should_resched() always returns false. cond_resched_lock() worked iff spin_needbreak is set. This patch adds argument "preempt_offset" to should_resched(). preempt_count offset constants for that: PREEMPT_DISABLE_OFFSET - offset after preempt_disable() PREEMPT_LOCK_OFFSET - offset after spin_lock() SOFTIRQ_DISABLE_OFFSET - offset after local_bh_distable() SOFTIRQ_LOCK_OFFSET - offset after spin_lock_bh() Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Graf <agraf@suse.de> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: bdb438065890 ("sched: Extract the basic add/sub preempt_count modifiers") Link: http://lkml.kernel.org/r/20150715095204.12246.98268.stgit@buzz Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-07preempt: Use preempt_schedule_context() as the official tracing preemption pointFrederic Weisbecker
preempt_schedule_context() is a tracing safe preemption point but it's only used when CONFIG_CONTEXT_TRACKING=y. Other configs have tracing recursion issues since commit: b30f0e3ffedf ("sched/preempt: Optimize preemption operations on __schedule() callers") introduced function based preemp_count_*() ops. Lets make it available on all configs and give it a more appropriate name for its new position. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1433432349-1021-3-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-28sched: Kill task_preempt_count()Oleg Nesterov
task_preempt_count() is pointless if preemption counter is per-cpu, currently this is x86 only. It is only valid if the task is not running, and even in this case the only info it can provide is the state of PREEMPT_ACTIVE bit. Change its single caller to check p->on_rq instead, this should be the same if p->state != TASK_RUNNING, and kill this helper. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Kirill Tkhai <tkhai@yandex.ru> Cc: Alexander Graf <agraf@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Christoph Lameter <cl@linux.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-arch@vger.kernel.org Link: http://lkml.kernel.org/r/20141008183348.GC17495@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-28sched: stop the unbound recursion in preempt_schedule_context()Oleg Nesterov
preempt_schedule_context() does preempt_enable_notrace() at the end and this can call the same function again; exception_exit() is heavy and it is quite possible that need-resched is true again. 1. Change this code to dec preempt_count() and check need_resched() by hand. 2. As Linus suggested, we can use the PREEMPT_ACTIVE bit and avoid the enable/disable dance around __schedule(). But in this case we need to move into sched/core.c. 3. Cosmetic, but x86 forgets to declare this function. This doesn't really matter because it is only called by asm helpers, still it make sense to add the declaration into asm/preempt.h to match preempt_schedule(). Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Graf <agraf@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Lameter <cl@linux.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Anvin <hpa@zytor.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Chuck Ebbert <cebbert.lkml@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20141005202322.GB27962@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-07percpu: add raw_cpu_opsChristoph Lameter
The kernel has never been audited to ensure that this_cpu operations are consistently used throughout the kernel. The code generated in many places can be improved through the use of this_cpu operations (which uses a segment register for relocation of per cpu offsets instead of performing address calculations). The patch set also addresses various consistency issues in general with the per cpu macros. A. The semantics of __this_cpu_ptr() differs from this_cpu_ptr only because checks are skipped. This is typically shown through a raw_ prefix. So this patch set changes the places where __this_cpu_ptr() is used to raw_cpu_ptr(). B. There has been the long term wish by some that __this_cpu operations would check for preemption. However, there are cases where preemption checks need to be skipped. This patch set adds raw_cpu operations that do not check for preemption and then adds preemption checks to the __this_cpu operations. C. The use of __get_cpu_var is always a reference to a percpu variable that can also be handled via a this_cpu operation. This patch set replaces all uses of __get_cpu_var with this_cpu operations. D. We can then use this_cpu RMW operations in various places replacing sequences of instructions by a single one. E. The use of this_cpu operations throughout will allow other arches than x86 to implement optimized references and RMV operations to work with per cpu local data. F. The use of this_cpu operations opens up the possibility to further optimize code that relies on synchronization through per cpu data. The patch set works in a couple of stages: I. Patch 1 adds the additional raw_cpu operations and raw_cpu_ptr(). Also converts the existing __this_cpu_xx_# primitive in the x86 code to raw_cpu_xx_#. II. Patch 2-4 use the raw_cpu operations in places that would give us false positives once they are enabled. III. Patch 5 adds preemption checks to __this_cpu operations to allow checking if preemption is properly disabled when these functions are used. IV. Patches 6-20 are patches that simply replace uses of __get_cpu_var with this_cpu_ptr. They do not depend on any changes to the percpu code. No preemption tests are skipped if they are applied. V. Patches 21-46 are conversion patches that use this_cpu operations in various kernel subsystems/drivers or arch code. VI. Patches 47/48 (not included in this series) remove no longer used functions (__this_cpu_ptr and __get_cpu_var). These should only be applied after all the conversion patches have made it and after we have done additional passes through the kernel to ensure that none of the uses of these functions remain. This patch (of 46): The patches following this one will add preemption checks to __this_cpu ops so we need to have an alternative way to use this_cpu operations without preemption checks. raw_cpu_ops will be the basis for all other ops since these will be the operations that do not implement any checks. Primitive operations are renamed by this patch from __this_cpu_xxx to raw_cpu_xxxx. Also change the uses of the x86 percpu primitives in preempt.h. These depend directly on asm/percpu.h (header #include nesting issue). Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Christoph Lameter <cl@linux.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Tejun Heo <tj@kernel.org> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Alex Shi <alex.shi@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Bryan Wu <cooloney@gmail.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: David Daney <david.daney@cavium.com> Cc: David Miller <davem@davemloft.net> Cc: David S. Miller <davem@davemloft.net> Cc: Dimitri Sivanich <sivanich@sgi.com> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@linux.intel.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Hedi Berriche <hedi@sgi.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: John Stultz <john.stultz@linaro.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mike Travis <travis@sgi.com> Cc: Neil Brown <neilb@suse.de> Cc: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Robert Richter <rric@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-11sched: Remove PREEMPT_NEED_RESCHED from generic codePeter Zijlstra
While hunting a preemption issue with Alexander, Ben noticed that the currently generic PREEMPT_NEED_RESCHED stuff is horribly broken for load-store architectures. We currently rely on the IPI to fold TIF_NEED_RESCHED into PREEMPT_NEED_RESCHED, but when this IPI lands while we already have a load for the preempt-count but before the store, the store will erase the PREEMPT_NEED_RESCHED change. The current preempt-count only works on load-store archs because interrupts are assumed to be completely balanced wrt their preempt_count fiddling; the previous preempt_count load will match the preempt_count state after the interrupt and therefore nothing gets lost. This patch removes the PREEMPT_NEED_RESCHED usage from generic code and pushes it into x86 arch code; the generic code goes back to relying on TIF_NEED_RESCHED. Boot tested on x86_64 and compile tested on ppc64. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-and-Tested-by: Alexander Graf <agraf@suse.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20131128132641.GP10022@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-28sched: Revert need_resched() to look at TIF_NEED_RESCHEDPeter Zijlstra
Yuanhan reported a serious throughput regression in his pigz benchmark. Using the ftrace patch I found that several idle paths need more TLC before we can switch the generic need_resched() over to preempt_need_resched. The preemption paths benefit most from preempt_need_resched and do indeed use it; all other need_resched() users don't really care that much so reverting need_resched() back to tif_need_resched() is the simple and safe solution. Reported-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: lkp@linux.intel.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20130927153003.GF15690@laptop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched, x86: Optimize the preempt_schedule() callPeter Zijlstra
Remove the bloat of the C calling convention out of the preempt_enable() sites by creating an ASM wrapper which allows us to do an asm("call ___preempt_schedule") instead. calling.h bits by Andi Kleen Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-tk7xdi1cvvxewixzke8t8le1@git.kernel.org [ Fixed build error. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched, x86: Provide a per-cpu preempt_count implementationPeter Zijlstra
Convert x86 to use a per-cpu preemption count. The reason for doing so is that accessing per-cpu variables is a lot cheaper than accessing thread_info variables. We still need to save/restore the actual preemption count due to PREEMPT_ACTIVE so we place the per-cpu __preempt_count variable in the same cache-line as the other hot __switch_to() variables such as current_task. NOTE: this save/restore is required even for !PREEMPT kernels as cond_resched() also relies on preempt_count's PREEMPT_ACTIVE to ignore task_struct::state. Also rename thread_info::preempt_count to ensure nobody is 'accidentally' still poking at it. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-gzn5rfsf8trgjoqx8hyayy3q@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
