As the actual pointer value is the same for the thread stack allocation
and the thread_info, code that confused the two worked fine, but will
break when the thread info is moved away from the stack allocation. It
also looks very confusing.
For example, the kprobe code wanted to know the current top of stack.
To do that, it used this:
(unsigned long)current_thread_info() + THREAD_SIZE
which did indeed give the correct value. But it's not only a fairly
nonsensical expression, it's also rather complex, especially since we
actually have this:
static inline unsigned long current_top_of_stack(void)
which not only gives us the value we are interested in, but happens to
be how "current_thread_info()" is currently defined as:
(struct thread_info *)(current_top_of_stack() - THREAD_SIZE);
so using current_thread_info() to figure out the top of the stack really
is a very round-about thing to do.
The other cases are just simpler confusion about task_thread_info() vs
task_stack_page(), which currently return the same pointer - but if you
want the stack page, you really should be using the latter one.
And there was one entirely unused assignment of the current stack to a
thread_info pointer.
All cleaned up to make more sense today, and make it easier to move the
thread_info away from the stack in the future.
No semantic changes.
Commit e7dbfe349d12 ("kprobes/x86: Move ftrace-based kprobe code
into kprobes-ftrace.c") switched from using
ARCH_SUPPORTS_KPROBES_ON_FTRACE to CONFIG_KPROBES_ON_FTRACE but
missed removing the define.
Cc: masami.hiramatsu.pt@hitachi.com
Cc: ananth@in.ibm.com
Cc: a.p.zijlstra@chello.nl
Cc: fweisbec@gmail.com
Cc: rostedt@goodmis.org
To avoid a kernel crash by probing on lockdep code, call
kprobe_int3_handler() and kprobe_debug_handler()(which was
formerly called post_kprobe_handler()) directly from
do_int3 and do_debug.
Currently kprobes uses notify_die() to hook the int3/debug
exceptoins. Since there is a locking code in notify_die,
the lockdep code can be invoked. And because the lockdep
involves printk() related things, theoretically, we need to
prohibit probing on such code, which means much longer blacklist
we'll have. Instead, hooking the int3/debug for kprobes before
notify_die() can avoid this problem.
Anyway, most of the int3 handlers in the kernel are already
called from do_int3 directly, e.g. ftrace_int3_handler,
poke_int3_handler, kgdb_ll_trap. Actually only
kprobe_exceptions_notify is on the notifier_call_chain.
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Borislav Petkov <bp@suse.de>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Jonathan Lebon <jlebon@redhat.com>
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Link: http://lkml.kernel.org/r/20140417081733.26341.24423.stgit@ltc230.yrl.intra.hitachi.co.jp
- Make all the external assembler template symbols __visible
- Move the templates inline assembler code into a top level
assembler statement, not inside a function. This avoids it being
optimized away or cloned.
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/1375740170-7446-8-git-send-email-andi@firstfloor.org
Currently kprobes check whether the copied instruction modifies
IF (interrupt flag) on each probe hit. This results not only in
introducing overhead but also involving
inat_get_opcode_attribute into the kprobes hot path, and it can
cause an infinite recursive call (and kernel panic in the end).
Actually, since the copied instruction itself can never be modified
on the buffer, it is needless to analyze the instruction on every
probe hit.
To fix this issue, we check it only once when registering probe
and store the result on ainsn->if_modifier.
Reported-by: Timo Juhani Lindfors <timo.lindfors@iki.fi>
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: yrl.pp-manager.tt@hitachi.com
Link: http://lkml.kernel.org/r/20130314115242.19690.33573.stgit@mhiramat-M0-7522
Add function tracer based kprobe optimization support
handlers on x86. This allows kprobes to use function
tracer for probing on mcount call.
Link: http://lkml.kernel.org/r/20120605102838.27845.26317.stgit@localhost.localdomain
Cc: "Frank Ch. Eigler" <fche@redhat.com>
[ Updated to new port of ftrace save regs functions ]
Since there's now two users for this, place it in a common header.
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: Masami Hiramatsu <mhiramat@redhat.com>
Cc: paulus@samba.org
Cc: eranian@google.com
Cc: robert.richter@amd.com
LKML-Reference: <20100304140100.923774125@chello.nl>
Introduce x86 arch-specific optimization code, which supports
both of x86-32 and x86-64.
This code also supports safety checking, which decodes whole of
a function in which probe is inserted, and checks following
conditions before optimization:
- The optimized instructions which will be replaced by a jump instruction
don't straddle the function boundary.
- There is no indirect jump instruction, because it will jumps into
the address range which is replaced by jump operand.
- There is no jump/loop instruction which jumps into the address range
- Don't optimize kprobes if it is in functions into which fixup code will
jumps.
This uses text_poke_multibyte() which doesn't support modifying
code on NMI/MCE handler. However, since kprobes itself doesn't
support NMI/MCE code probing, it's not a problem.
Changes in v9:
- Use *_text_reserved() for checking the probe can be optimized.
- Verify jump address range is in 2G range when preparing slot.
- Backup original code when switching optimized buffer, instead of
preparing buffer, because there can be int3 of other probes in
preparing phase.
- Check kprobe is disabled in arch_check_optimized_kprobe().
- Strictly check indirect jump opcodes (ff /4, ff /5).
Changes in v6:
- Split stop_machine-based jump patching code.
- Update comments and coding style.
Changes in v5:
- Introduce stop_machine-based jump replacing.
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Cc: systemtap <systemtap@sources.redhat.com>
Cc: DLE <dle-develop@lists.sourceforge.net>
Cc: Jim Keniston <jkenisto@us.ibm.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Anders Kaseorg <andersk@ksplice.com>
Cc: Tim Abbott <tabbott@ksplice.com>
Cc: Jason Baron <jbaron@redhat.com>
Cc: Mathieu Desnoyers <compudj@krystal.dyndns.org>
LKML-Reference: <20100225133446.6725.78994.stgit@localhost6.localdomain6>
Change RELATIVEJUMP_INSTRUCTION macro to RELATIVEJUMP_OPCODE
since it represents just the opcode byte.
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
LKML-Reference: <20100225133349.6725.99302.stgit@localhost6.localdomain6>
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since:
a. the double underscore is ugly and pointless.
b. no leading underscore violates namespace constraints.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
