upstream commit: 01522df346f846906eaf6ca57148641476209909
Jordan Hargrave diagnosed a BIOS clobbering %esi in the E820 call.
That particular BIOS has been fixed, but there is a possibility that
this is responsible for other occasional reports of early boot
failure, and it does not hurt to add %esi to the clobbers.
-stable candidate patch.
Cc: Justin Forbes <jmforbes@linuxtx.org>
Signed-off-by: Michael K Johnson <johnsonm@rpath.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: stable@kernel.org
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Impact: fix potential miscompile (currently believed non-manifest)
As the comment explains, the VBE DDC call can clobber any register.
Tell the compiler about that fact.
Signed-off-by: Andreas Schwab <schwab@suse.de>
'x86/crashdump', 'x86/debug', 'x86/defconfig', 'x86/detect-hyper', 'x86/doc', 'x86/dumpstack', 'x86/early-printk', 'x86/fpu', 'x86/idle', 'x86/io', 'x86/memory-corruption-check', 'x86/microcode', 'x86/mm', 'x86/mtrr', 'x86/nmi-watchdog', 'x86/pat2', 'x86/pci-ioapic-boot-irq-quirks', 'x86/ptrace', 'x86/quirks', 'x86/reboot', 'x86/setup-memory', 'x86/signal', 'x86/sparse-fixes', 'x86/time', 'x86/uv' and 'x86/xen' into x86/core
Impact: build fix with certain compilers
GCC can decide to use %dil when "r" is used, which is not valid for
setnz.
This bug was brought out by Stephen Rothwell's merging of the
branch tracer into linux-next.
[ Thanks to Uros Bizjak for recommending 'q' over 'Q' ]
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Impact: make global variables static
Fix these sparse warnings:
arch/x86/boot/video.c:233:3: warning: symbol 'saved' was not declared. Should it be static?
arch/x86/boot/video-vga.c:37:13: warning: symbol 'video_vga' was not declared. Should it be static?
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: fix section mismatch warning - apic_x2apic_phys
x86: fix section mismatch warning - apic_x2apic_cluster
x86: fix section mismatch warning - apic_x2apic_uv_x
x86: fix section mismatch warning - apic_physflat
x86: fix section mismatch warning - apic_flat
x86: memtest fix use of reserve_early()
x86 syscall.h: fix argument order
x86/tlb_uv: remove strange mc146818rtc include
x86: remove redundant KERN_DEBUG on pr_debug
x86: do_boot_cpu - check if we have ESR register
x86: MAINTAINERS change for AMD microcode patch loader
x86/proc: fix /proc/cpuinfo cpu offline bug
x86: call dmi-quirks for HP Laptops after early-quirks are executed
x86, kexec: fix hang on i386 when panic occurs while console_sem is held
MCE: Don't run 32bit machine checks with interrupts on
x86: SB600: skip IRQ0 override if it is not routed to INT2 of IOAPIC
x86: make variables static
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since:
a. the double underscore is ugly and pointless.
b. no leading underscore violates namespace constraints.
These variables are only used in their source files, so make them static.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Currently, it is possible to set a graphics VESA mode at boot time via the
vga= parameter even when no framebuffer driver supporting this is
configured. This could lead to the system booting with a black screen,
without a usable console.
Fix this problem by only allowing to set graphics modes at boot time if a
supporting framebuffer driver is configured.
Signed-off-by: Michal Januszewski <spock@gentoo.org>
Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl>
'x86/memory-corruption-check', 'x86/early-printk', 'x86/xsave', 'x86/ptrace-v2', 'x86/quirks', 'x86/setup', 'x86/spinlocks' and 'x86/signal' into x86/core-v2
arch/x86/kernel/cpu/common.c
arch/x86/kernel/signal_64.c
include/asm-x86/cpufeature.h
'x86/crashdump', 'x86/debug', 'x86/defconfig', 'x86/doc', 'x86/exports', 'x86/fpu', 'x86/gart', 'x86/idle', 'x86/mm', 'x86/mtrr', 'x86/nmi-watchdog', 'x86/oprofile', 'x86/paravirt', 'x86/reboot', 'x86/sparse-fixes', 'x86/tsc', 'x86/urgent' and 'x86/vmalloc' into x86-v28-for-linus-phase1
include/asm-x86/dma-mapping.h
include/asm-x86/gpio.h
include/asm-x86/idle.h
include/asm-x86/kvm_host.h
include/asm-x86/namei.h
include/asm-x86/uaccess.h
Replace a magic number with a named constant in the VESA boot code.
Cc: linux-fbdev-devel@lists.sourceforge.net
After commit 968de4f ("i386: Relocatable kernel support") IMAGE_OFFSET wasn't
actually used anymore in the (current) X86 build system. Now remove its last
traces.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Impact: segfault on build of a 32-bit relocatable kernel
When converting arch/x86/boot/compressed/relocs.c to support unlimited
sections, the computation of sym_strtab in walk_relocs() was done
incorrectly. This causes a segfault for some people when building the
relocatable 32-bit kernel.
Pointed out by Anonymous <pageexec@freemail.hu>.
This reverts commit 464f04c9e9b3b1c4f5ffb89c51d8ba2a2034c846.
Obsoleted by commit 6cdcdb99cf7c2e1835fc5b471864d21161c3e679.
Some BIOSes do not indicate error when trying to read from non-
existing device. Zero buffer before reading and check that we
possibly have valid MBR by looking for MBR magic.
This was fixed in different way for edd.S in
http://marc.info/?l=linux-kernel&m=114087765422490&w=2, but lost
again when edd.S was rewritten in C.
Signed-off-by: Andrey Borzenkov < arvidjaar@mail.ru>
Checkin e38e05a85828dac23540cd007df5f20985388afc added a 9th CPU flag
word, but didn't adjust the boot code to match. This patch adds the
necessary boot code support.
Note: due to a typo in an #if statement, it didn't trigger the #error
this was supposed to do.
Impact: None (cleanup)
SWAP_DEV is unused since 2.6.23-rc1. The comment was already incorrect
since (at least) 2.6.12.
> This is regression but old enough. Apparently I had for whatever reasons
> EDD turned off till recently. This is 2.6.27-rc5 just in case.
> In 2006 I fixed ghost devices due to buggy BIOS:
> Later edd.S has been rewritten in C, and apparently this patch has been
> lost:
> {pts/1}% ls /sys/firmware/edd
> int13_dev80/ int13_dev84/ int13_dev88/ int13_dev8c/
> int13_dev81/ int13_dev85/ int13_dev89/ int13_dev8d/
> int13_dev82/ int13_dev86/ int13_dev8a/ int13_dev8e/
> int13_dev83/ int13_dev87/ int13_dev8b/ int13_dev8f/
> But I have just a single disk. This is the same system BTW.
Some BIOSes do not always set CF on error before return from int13.
The patch adds additional check for status being zero (AH == 0).
This was fixed for edd.S in
Signed-off-by: Andrey Borzenkov <arvidjaar@mail.ru>
When building image.iso (make isoimage), use the isohybrid tool if it
exists. isohybrid is a script included with Syslinux 3.72 and higher,
which creates an image that can be booted either as a hard disk
(including removable, e.g. USB disk) or as a CD-ROM.
If isohybrid doesn't exist, then this has no effect.
The CPU feature detection code in the boot code is somewhat minimal,
and doesn't include all possible CPUID words. In particular, it
doesn't contain the code for CPU feature words 2 (Transmeta),
3 (Linux-specific), 5 (VIA), or 7 (scattered). Zero them out, so we
can still set those bits as known at compile time; in particular, this
allows creating a Linux-specific NOPL flag and have it required (and
therefore resolvable at compile time) in 64-bit mode.
arch/x86/kernel/cpu/feature_names.c
The Kbuild variable "targets" is supposed to be
configuration-independent and reflect "all possible targets". This is
required to make "make clean" work properly.
Therefore, move all manipulation of "targets" as well as custom rules
out of the x86-32 ifdef statement. Only leave inside the ifdefs the
things that are genuinely configuration-dependent.
We have had a number of cases where <asm/cpufeature.h> (and its
predecessors) have diverged substantially from the names list in
/proc/cpuinfo. This patch generates the latter from the former.
It retains the option for explicitly overriding the strings, but by
making that require a separate action it should at least be less
likely to happen.
It would be good to do a future pass and rename strings that are
gratuituously different in the kernel (/proc/cpuinfo is a userspace
interface and must remain constant.)
arch/x86/kernel/cpu/cyrix.c
This recent patch
commit c3965bd15118742d72b4bc1a290d37b3f081eb98
Author: Paul Jackson <pj@sgi.com>
Date: Wed May 14 08:15:34 2008 -0700
x86 boot: proper use of ARRAY_SIZE instead of repeated E820MAX constant
caused these new warnings during a normal build:
In file included from linux-2.6/arch/x86/boot/memory.c:17:
linux-2.6/include/linux/log2.h: In function '__ilog2_u32':
linux-2.6/include/linux/log2.h:34: warning: implicit declaration of function 'fls'
linux-2.6/include/linux/log2.h: In function '__ilog2_u64':
linux-2.6/include/linux/log2.h:42: warning: implicit declaration of function 'fls64'
linux-2.6/include/linux/log2.h: In function '__roundup_pow_of_two ':
linux-2.6/include/linux/log2.h:63: warning: implicit declaration of function 'fls_long'
I tried to fix them in log2.h, but it's difficult because the real mode
environment is completely different from a normal kernel environment. Instead
define an own ARRAY_SIZE macro in boot.h, similar to the other private
macros there.
Before:
total: 4 errors, 6 warnings, 439 lines checked
After:
total: 1 errors, 5 warnings, 441 lines checked
Before
-#include <asm/io.h>
+#include <linux/io.h>
paolo@paolo-desktop:~/linux.trees.git$ md5sum /tmp/misc.o.*
8b2394e1fe519a9542e9a7e3e7b69c39 /tmp/misc.o.after
8b2394e1fe519a9542e9a7e3e7b69c39 /tmp/misc.o.before
After
59a2d264284be5e72b5af4f3a8ccfb47 /tmp/misc.o.after
Signed-off-by: Paolo Ciarrocchi <paolo.ciarrocchi@gmail.com>
Clean up the code for crashes during SpeedStep probing on older
machines.
yesterday I tried to reactivate my old 486 box and wanted to install a
current Linux with latest kernel on it. But it turned out that the
latest kernel does not boot because the machine crashes early in the
setup code.
After some debugging it turned out that the problem is the query_ist()
function. If this interrupt with that function is called the machine
simply locks up. It looks like a BIOS bug. Looking for a workaround for
this problem I wrote the attached patch. It checks for the CPUID
instruction and if it is not implemented it does not call the speedstep
BIOS function. As far as I know speedstep should be available since some
Pentium earliest.
Alan Cox observed that it's available since the Pentium II, so cpuid
levels 4 and 5 can be excluded altogether.
H. Peter Anvin cleaned up the code some more:
> Right in concept, but I dislike the implementation (duplication of the
> CPU detect code we already have). Could you try this patch and see if
> it works for you?
which, with a small modification to fix a build error with it the
resulting kernel boots on my machine.
Signed-off-by: Joerg Roedel <joro@8bytes.org>
Signed-off-by: "H. Peter Anvin" <hpa@zytor.com>
Cc: <stable@kernel.org>
Comments in arch/x86/boot/compressed/head_32.S erroneously refer to the
real mode pointer as the second and the heap area as the third argument
to decompress_kernel(). In fact, these have been the first and second
argument, respectively, since v2.6.20.
This patch corrects the comments. It introduces no code changes.
Signed-off-by: Philipp Kohlbecher <xt28@gmx.de>
include/asm-x86/ide.h
Inflate requires some dynamic memory allocation very early in the boot
process and this is provided with a set of four functions:
malloc/free/gzip_mark/gzip_release.
The old inflate code used a mark/release strategy rather than implement
free. This new version instead keeps a count on the number of outstanding
allocations and when it hits zero, it resets the malloc arena.
This allows removing all the mark and release implementations and unifying
all the malloc/free implementations.
The architecture-dependent code must define two addresses:
- free_mem_ptr, the address of the beginning of the area in which
allocations should be made
- free_mem_end_ptr, the address of the end of the area in which
allocations should be made. If set to 0, then no check is made on
the number of allocations, it just grows as much as needed
The architecture-dependent code can also provide an arch_decomp_wdog()
function call. This function will be called several times during the
decompression process, and allow to notify the watchdog that the system is
still running. If an architecture provides such a call, then it must
define ARCH_HAS_DECOMP_WDOG so that the generic inflate code calls
arch_decomp_wdog().
Work initially done by Matt Mackall, updated to a recent version of the
kernel and improved by me.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Mikael Starvik <mikael.starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Yoshinori Sato <ysato@users.sourceforge.jp>
This patch consolidates the header guard names which are also used
externally, i.e. in .c files.
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
Without checking the return value of get_edd_info() and adding the
entry only in the success case, 6 devices show up under
/sys/firmware/edd/, no matter how many devices are actually present.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Merge the GDT_ENTRY() macro between arch/x86/boot/pm.c and
arch/x86/kernel/acpi/sleep.c and put the new one in
<asm-x86/segment.h>.
While we're at it, correct the bitmasks for the limit and flags. The
new version relies on using ULL constants in order to cause type
promotion rather than explicit casts; this avoids having to include
<linux/types.h> in <asm-x86/segments.h>.
arch/x86/Kconfig
arch/x86/kernel/io_apic_32.c
arch/x86/kernel/setup_64.c
arch/x86/mm/init_32.c
This patch allows the disabling of decompression messages during
x86 bootup.
Signed-off-by: Ben Collins <ben.collins@canonical.com>
Jeremy Fitzhardinge wrote:
> Maybe it really does require the far jump immediately after setting PE
> in cr0...
> Hm, I don't remember this paragraph being in vol 3a, section 8.9.1
> before. Is it a recent addition?
> Random failures can occur if other instructions exist between steps
> 3 and 4 above. Failures will be readily seen in some situations,
> such as when instructions that reference memory are inserted between
> steps 3 and 4 while in system management mode.
I don't remember that, either.
Impact: build failure in maximal configurations
The 32-bit x86 relocatable kernel requires an auxilliary host program
to process the relocations. This program had a hard-coded arbitrary
limit of a 100 ELF sections. Instead of a hard-coded limit, allocate
the structures dynamically.
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Apparently, DOS and possibly other legacy operating systems issued a
null command to the keyboard controller after toggling A20,
specifically "pulse output pins" with no output pins specified. This
was presumably done for synchronization reasons. This has made it
into at least the UHCI spec, and it has been found to cause
compatibility problems when "legacy USB" is enabled (which it almost
always is) to not have this byte sent.
It is *NOT* clear if any of these compatibility problems has any
effect on Linux. However, for maximum compatibility, issue this null
command after togging A20 through the KBC.
