path: root/arch/x86/Kconfig
2014-07-23clocksource: Move cycle_last validation to core codeThomas Gleixner
The only user of the cycle_last validation is the x86 TSC. In order to provide NMI safe accessor functions for clock monotonic and monotonic_raw we need to do that in the core. We can't do the TSC specific if (now < cycle_last) now = cycle_last; for the other wrapping around clocksources, but TSC has CLOCKSOURCE_MASK(64) which actually does not mask out anything so if now is less than cycle_last the subtraction will give a negative result. So we can check for that in clocksource_delta() and return 0 for that case. Implement and enable it for x86 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2014-07-23ktime: Kill non-scalar ktime_t implementation for 2038John Stultz
The non-scalar ktime_t implementation is basically a timespec which has to be changed to support dates past 2038 on 32bit systems. This patch removes the non-scalar ktime_t implementation, forcing the scalar s64 nanosecond version on all architectures. This may have additional performance overhead on some 32bit systems when converting between ktime_t and timespec structures, however the majority of 32bit systems (arm and i386) were already using scalar ktime_t, so no performance regressions will be seen on those platforms. On affected platforms, I'm open to finding optimizations, including avoiding converting to timespecs where possible. [ tglx: We can now cleanup the ktime_t.tv64 mess, but thats a different issue and we can throw a coccinelle script at it ] Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2014-07-22acpi, apei, ghes: Make NMI error notification to be GHES architecture extension.Tomasz Nowicki
Currently APEI depends on x86 architecture. It is because of NMI hardware error notification of GHES which is currently supported by x86 only. However, many other APEI features can be still used perfectly by other architectures. This commit adds two symbols: 1. HAVE_ACPI_APEI for those archs which support APEI. 2. HAVE_ACPI_APEI_NMI which is used for NMI code isolation in ghes.c file. NMI related data and functions are grouped so they can be wrapped inside one #ifdef section. Appropriate function stubs are provided for !NMI case. Note there is no functional changes for x86 due to hard selected HAVE_ACPI_APEI and HAVE_ACPI_APEI_NMI symbols. Signed-off-by: Tomasz Nowicki <tomasz.nowicki@linaro.org> Acked-by: Borislav Petkov <bp@suse.de> Signed-off-by: Tony Luck <tony.luck@intel.com>
2014-07-21ACPI / processor: Introduce ARCH_MIGHT_HAVE_ACPI_PDCHanjun Guo
The use of _PDC is deprecated in ACPI 3.0 in favor of _OSC, as ARM platform is supported only in ACPI 5.0 or higher version, _PDC will not be used in ARM platform, so make Make _PDC only for platforms with Intel CPUs. Introduce ARCH_MIGHT_HAVE_ACPI_PDC and move _PDC related code in ACPI processor driver into a single file processor_pdc.c, make x86 and ia64 select it when ACPI is enabled. This patch also use pr_* to replace printk to fix the checkpatch warning and factor acpi_processor_alloc_pdc() a little bit to avoid duplicate pr_err() code. Suggested-by: Robert Richter <rric@kernel.org> Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-21ACPI: add config for BIOS table scanGraeme Gregory
With the addition of ARM64 that does not have a traditional BIOS to scan, add a config option which is selected on x86 (ia64 doesn't need it either, it is EFI/UEFI based system) to do the traditional BIOS scanning for tables. Signed-off-by: Graeme Gregory <graeme.gregory@linaro.org> Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-18ftrace: x86: Remove check of obsolete variable function_trace_stopSteven Rostedt (Red Hat)
Nothing sets function_trace_stop to disable function tracing anymore. Remove the check for it in the arch code. Link: http://lkml.kernel.org/r/53C54D32.6000000@zytor.com Acked-by: H. Peter Anvin <hpa@linux.intel.com> Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-07-16locking/mutex: Disable optimistic spinning on some architecturesPeter Zijlstra
The optimistic spin code assumes regular stores and cmpxchg() play nice; this is found to not be true for at least: parisc, sparc32, tile32, metag-lock1, arc-!llsc and hexagon. There is further wreckage, but this in particular seemed easy to trigger, so blacklist this. Opt in for known good archs. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Reported-by: Mikulas Patocka <mpatocka@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: James Bottomley <James.Bottomley@hansenpartnership.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Jason Low <jason.low2@hp.com> Cc: Waiman Long <waiman.long@hp.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: John David Anglin <dave.anglin@bell.net> Cc: James Hogan <james.hogan@imgtec.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: stable@vger.kernel.org Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: sparclinux@vger.kernel.org Link: http://lkml.kernel.org/r/20140606175316.GV13930@laptop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-07-07efi/x86: Move UEFI Runtime Services wrappers to generic codeArd Biesheuvel
In order for other archs (such as arm64) to be able to reuse the virtual mode function call wrappers, move them to drivers/firmware/efi/runtime-wrappers.c. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-06-21x86, irq: Introduce mechanisms to support dynamically allocate IRQ for IOAPICJiang Liu
Currently x86 support identity mapping between GSI(IOAPIC pin) and IRQ number, so continous IRQs at low end are statically allocated to IOAPICs at boot time. This design causes trouble to support IOAPIC hotplug. This patch implements basic mechanism to dynamically allocate IRQ on demand for IOAPIC pins by using irqdomain framework. It first adds several fields into struct ioapic to support irqdomain. Then it implements an algorithm to dynamically allocate IRQ number for IOAPIC pins on demand. Currently it supports three types of irqdomain: 1) LEGACY: used to support IOAPIC hosting legacy IRQs and building identity mapping for legacy IRQs. A speical case, we dynamically allocate IRQ number for IOAPIC pin which has GSI number below nr_legacy_irqs() but isn't legacy IRQ. This is for backward compatibility and avoid regression. 2) STRICT: build identity mapping between GSI and IRQ nubmer. 3) DYNAMIC: dynamically allocate IRQ number for IOAPIC pin on demand. Legacy(ISA) IRQs is not managed by irqdomain because there may be multiple pins sharing the same IRQ number and current irqdomain only supports 1:1 mapping between pins and IRQ. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Link: http://lkml.kernel.org/r/1402302011-23642-24-git-send-email-jiang.liu@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-06-21x86: ce4100, irq: Make CE4100 depend on CONFIG_X86_IO_APICJiang Liu
Intel CE4100 platforms need IOAPIC support becasue some devices are always connected to the second IOAPIC, so make CONFIG_CE depends on CONFIG_X86_IO_APIC. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1402302011-23642-18-git-send-email-jiang.liu@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-06-16x86, kaslr: boot-time selectable with hibernationKees Cook
Changes kASLR from being compile-time selectable (blocked by CONFIG_HIBERNATION), to being boot-time selectable (with hibernation available by default) via the "kaslr" kernel command line. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-06-12Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more locking changes from Ingo Molnar: "This is the second round of locking tree updates for v3.16, offering large system scalability improvements: - optimistic spinning for rwsems, from Davidlohr Bueso. - 'qrwlocks' core code and x86 enablement, from Waiman Long and PeterZ" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, locking/rwlocks: Enable qrwlocks on x86 locking/rwlocks: Introduce 'qrwlocks' - fair, queued rwlocks locking/mutexes: Documentation update/rewrite locking/rwsem: Fix checkpatch.pl warnings locking/rwsem: Fix warnings for CONFIG_RWSEM_GENERIC_SPINLOCK locking/rwsem: Support optimistic spinning
2014-06-06x86, locking/rwlocks: Enable qrwlocks on x86Waiman Long
Make x86 use the fair rwlock_t. Implement the custom queue_write_unlock() for best performance. Signed-off-by: Waiman Long <Waiman.Long@hp.com> [peterz: near complete rewrite] Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Dave Jones <davej@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: "Paul E.McKenney" <paulmck@linux.vnet.ibm.com> Cc: linux-kernel@vger.kernel.org Cc: x86@kernel.org Link: http://lkml.kernel.org/n/tip-r1xuzmdysvuhl3h86n5fbxi7@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05Merge branch 'x86/espfix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull x86-64 espfix changes from Peter Anvin: "This is the espfix64 code, which fixes the IRET information leak as well as the associated functionality problem. With this code applied, 16-bit stack segments finally work as intended even on a 64-bit kernel. Consequently, this patchset also removes the runtime option that we added as an interim measure. To help the people working on Linux kernels for very small systems, this patchset also makes these compile-time configurable features" * 'x86/espfix' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: Revert "x86-64, modify_ldt: Make support for 16-bit segments a runtime option" x86, espfix: Make it possible to disable 16-bit support x86, espfix: Make espfix64 a Kconfig option, fix UML x86, espfix: Fix broken header guard x86, espfix: Move espfix definitions into a separate header file x86-32, espfix: Remove filter for espfix32 due to race x86-64, espfix: Don't leak bits 31:16 of %esp returning to 16-bit stack
2014-06-04Merge branch 'akpm' (patchbomb from Andrew) into nextLinus Torvalds
Merge misc updates from Andrew Morton: - a few fixes for 3.16. Cc'ed to stable so they'll get there somehow. - various misc fixes and cleanups - most of the ocfs2 queue. Review is slow... - most of MM. The MM queue is pretty huge this time, but not much in the way of feature work. - some tweaks under kernel/ - printk maintenance work - updates to lib/ - checkpatch updates - tweaks to init/ * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (276 commits) fs/autofs4/dev-ioctl.c: add __init to autofs_dev_ioctl_init fs/ncpfs/getopt.c: replace simple_strtoul by kstrtoul init/main.c: remove an ifdef kthreads: kill CLONE_KERNEL, change kernel_thread(kernel_init) to avoid CLONE_SIGHAND init/main.c: add initcall_blacklist kernel parameter init/main.c: don't use pr_debug() fs/binfmt_flat.c: make old_reloc() static fs/binfmt_elf.c: fix bool assignements fs/efs: convert printk(KERN_DEBUG to pr_debug fs/efs: add pr_fmt / use __func__ fs/efs: convert printk to pr_foo() scripts/checkpatch.pl: device_initcall is not the only __initcall substitute checkpatch: check stable email address checkpatch: warn on unnecessary void function return statements checkpatch: prefer kstrto<foo> to sscanf(buf, "%<lhuidx>", &bar); checkpatch: add warning for kmalloc/kzalloc with multiply checkpatch: warn on #defines ending in semicolon checkpatch: make --strict a default for files in drivers/net and net/ checkpatch: always warn on missing blank line after variable declaration block checkpatch: fix wildcard DT compatible string checking ...
2014-06-04mm: x86 pgtable: require X86_64 for soft-dirty trackerCyrill Gorcunov
Tracking dirty status on 2 level pages requires very ugly macros and taking into account how old the machines who can operate without PAE mode only are, lets drop soft dirty tracker from them for code simplicity (note I can't drop all the macros from 2 level pages by now since _PAGE_BIT_PROTNONE and _PAGE_BIT_FILE are still used even without tracker). Linus proposed to completely rip off softdirty support on x86-32 (even with PAE) and since for CRIU we're not planning to support native x86-32 mode, lets do that. (Softdirty tracker is relatively new feature which is mostly used by CRIU so I don't expect if such API change would cause problems for userspace). Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Noonan <steven@uplinklabs.net> Cc: Rik van Riel <riel@redhat.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04x86: enable DMA CMA with swiotlbAkinobu Mita
The DMA Contiguous Memory Allocator support on x86 is disabled when swiotlb config option is enabled. So DMA CMA is always disabled on x86_64 because swiotlb is always enabled. This attempts to support for DMA CMA with enabling swiotlb config option. The contiguous memory allocator on x86 is integrated in the function dma_generic_alloc_coherent() which is .alloc callback in nommu_dma_ops for dma_alloc_coherent(). x86_swiotlb_alloc_coherent() which is .alloc callback in swiotlb_dma_ops tries to allocate with dma_generic_alloc_coherent() firstly and then swiotlb_alloc_coherent() is called as a fallback. The main part of supporting DMA CMA with swiotlb is that changing x86_swiotlb_free_coherent() which is .free callback in swiotlb_dma_ops for dma_free_coherent() so that it can distinguish memory allocated by dma_generic_alloc_coherent() from one allocated by swiotlb_alloc_coherent() and release it with dma_generic_free_coherent() which can handle contiguous memory. This change requires making is_swiotlb_buffer() global function. This also needs to change .free callback in the dma_map_ops for amd_gart and sta2x11, because these dma_ops are also using dma_generic_alloc_coherent(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Don Dutile <ddutile@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04x86: require x86-64 for automatic NUMA balancingMel Gorman
32-bit support for NUMA is an oddity on its own but with automatic NUMA balancing on top there is a reasonable risk that the CPUPID information cannot be stored in the page flags. This patch removes support for automatic NUMA support on 32-bit x86. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Anvin <hpa@zytor.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Noonan <steven@uplinklabs.net> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04hugetlb: restrict hugepage_migration_support() to x86_64Naoya Horiguchi
Currently hugepage migration is available for all archs which support pmd-level hugepage, but testing is done only for x86_64 and there're bugs for other archs. So to avoid breaking such archs, this patch limits the availability strictly to x86_64 until developers of other archs get interested in enabling this feature. Simply disabling hugepage migration on non-x86_64 archs is not enough to fix the reported problem where sys_move_pages() hits the BUG_ON() in follow_page(FOLL_GET), so let's fix this by checking if hugepage migration is supported in vma_migratable(). Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reported-by: Michael Ellerman <mpe@ellerman.id.au> Tested-by: Michael Ellerman <mpe@ellerman.id.au> Acked-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: <stable@vger.kernel.org> [3.12+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull core irq updates from Thomas Gleixner: "The irq department delivers: - Another tree wide update to get rid of the horrible create_irq interface along with its even more horrible variants. That also gets rid of the last leftovers of the initial sparse irq hackery. arch/driver specific changes have been either acked or ignored. - A fix for the spurious interrupt detection logic with threaded interrupts. - A new ARM SoC interrupt controller - The usual pile of fixes and improvements all over the place" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) Documentation: brcmstb-l2: Add Broadcom STB Level-2 interrupt controller binding irqchip: brcmstb-l2: Add Broadcom Set Top Box Level-2 interrupt controller genirq: Improve documentation to match current implementation ARM: iop13xx: fix msi support with sparse IRQ genirq: Provide !SMP stub for irq_set_affinity_notifier() irqchip: armada-370-xp: Move the devicetree binding documentation irqchip: gic: Use mask field in GICC_IAR genirq: Remove dynamic_irq mess ia64: Use irq_init_desc genirq: Replace dynamic_irq_init/cleanup genirq: Remove irq_reserve_irq[s] genirq: Replace reserve_irqs in core code s390: Avoid call to irq_reserve_irqs() s390: Remove pointless arch_show_interrupts() s390: pci: Check return value of alloc_irq_desc() proper sh: intc: Remove pointless irq_reserve_irqs() invocation x86, irq: Remove pointless irq_reserve_irqs() call genirq: Make create/destroy_irq() ia64 private tile: Use SPARSE_IRQ tile: pci: Use irq_alloc/free_hwirq() ...
2014-06-03Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull x86 IOSF platform updates from Ingo Molnar: "IOSF (Intel OnChip System Fabric) updates: - generalize the IOSF interface to allow mixed mode drivers: non-IOSF drivers to utilize of IOSF features on IOSF platforms. - add 'Quark X1000' IOSF/MBI support - clean up BayTrail and Quark PCI ID enumeration" * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, iosf: Add PCI ID macros for better readability x86, iosf: Add Quark X1000 PCI ID x86, iosf: Added Quark MBI identifiers x86, iosf: Make IOSF driver modular and usable by more drivers
2014-06-03Merge tag 'tty-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty into next Pull tty/serial driver updates from Greg KH: "Here is the big tty / serial driver pull request for 3.16-rc1. A variety of different serial driver fixes and updates and additions, nothing huge, and no real major core tty changes at all. All have been in linux-next for a while" * tag 'tty-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (84 commits) Revert "serial: imx: remove the DMA wait queue" serial: kgdb_nmi: Improve console integration with KDB I/O serial: kgdb_nmi: Switch from tasklets to real timers serial: kgdb_nmi: Use container_of() to locate private data serial: cpm_uart: No LF conversion in put_poll_char() serial: sirf: Fix compilation failure console: Remove superfluous readonly check console: Use explicit pointer type for vc_uni_pagedir* fields vgacon: Fix & cleanup refcounting ARM: tty: Move HVC DCC assembly to arch/arm tty/hvc/hvc_console: Fix wakeup of HVC thread on hvc_kick() drivers/tty/n_hdlc.c: replace kmalloc/memset by kzalloc vt: emulate 8- and 24-bit colour codes. printk/of_serial: fix serial console cessation part way through boot. serial: 8250_dma: check the result of TX buffer mapping serial: uart: add hw flow control support configuration tty/serial: at91: add interrupts for modem control lines tty/serial: at91: use mctrl_gpio helpers tty/serial: Add GPIOLIB helpers for controlling modem lines ARM: at91: gpio: implement get_direction ...
2014-05-16x86: Implement arch_setup/teardown_hwirq()Thomas Gleixner
This is just a cleanup to get rid of the create/destroy_irq variants which were designed in hell. The long term solution for x86 is to switch over to irq domains and cleanup the whole vector allocation mess. The generic irq_alloc_hwirqs() interface deliberately prevents multi-MSI vector allocation to further enforce the irq domain conversion (aside of the desire to support ioapic hotplug). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Grant Likely <grant.likely@linaro.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: x86@kernel.org Link: http://lkml.kernel.org/r/20140507154334.482904047@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-05-15goldfish: Allow 64bit buildsAlan
We can now enable the 64bit option for the Goldfish 64bit emulator. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-09x86, iosf: Make IOSF driver modular and usable by more driversDavid E. Box
Currently drivers that run on non-IOSF systems (Core/Xeon) can't use the IOSF driver on SOC's without selecting it which forces an unnecessary and limiting dependency. Provides dummy functions to allow these modules to conditionally use the driver on IOSF equipped platforms without impacting their ability to compile and load on non-IOSF platforms. Build default m to ensure availability on x86 SOC's. Signed-off-by: David E. Box <david.e.box@linux.intel.com> Link: http://lkml.kernel.org/r/1399668248-24199-2-git-send-email-david.e.box@linux.intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-05-04x86, espfix: Make it possible to disable 16-bit supportH. Peter Anvin
Embedded systems, which may be very memory-size-sensitive, are extremely unlikely to ever encounter any 16-bit software, so make it a CONFIG_EXPERT option to turn off support for any 16-bit software whatsoever. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com
2014-05-04x86, espfix: Make espfix64 a Kconfig option, fix UMLH. Peter Anvin
Make espfix64 a hidden Kconfig option. This fixes the x86-64 UML build which had broken due to the non-existence of init_espfix_bsp() in UML: since UML uses its own Kconfig, this option does not appear in the UML build. This also makes it possible to make support for 16-bit segments a configuration option, for the people who want to minimize the size of the kernel. Reported-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Richard Weinberger <richard@nod.at> Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com
2014-04-24x86: move FIX_EARLYCON_MEM kconfig into x86Rob Herring
In preparation to support FIX_EARLYCON_MEM on other arches, make the option per arch. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: x86@kernel.org Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-12Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit updates from Eric Paris. * git://git.infradead.org/users/eparis/audit: (28 commits) AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range audit: do not cast audit_rule_data pointers pointlesly AUDIT: Allow login in non-init namespaces audit: define audit_is_compat in kernel internal header kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c sched: declare pid_alive as inline audit: use uapi/linux/audit.h for AUDIT_ARCH declarations syscall_get_arch: remove useless function arguments audit: remove stray newline from audit_log_execve_info() audit_panic() call audit: remove stray newlines from audit_log_lost messages audit: include subject in login records audit: remove superfluous new- prefix in AUDIT_LOGIN messages audit: allow user processes to log from another PID namespace audit: anchor all pid references in the initial pid namespace audit: convert PPIDs to the inital PID namespace. pid: get pid_t ppid of task in init_pid_ns audit: rename the misleading audit_get_context() to audit_take_context() audit: Add generic compat syscall support audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL ...
2014-04-07x86: use generic early_ioremapMark Salter
Move x86 over to the generic early ioremap implementation. Signed-off-by: Mark Salter <msalter@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Borislav Petkov <borislav.petkov@amd.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Dave Young <dyoung@redhat.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-02Merge branch 'x86-nuke-platforms-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 old platform removal from Peter Anvin: "This patchset removes support for several completely obsolete platforms, where the maintainers either have completely vanished or acked the removal. For some of them it is questionable if there even exists functional specimens of the hardware" Geert Uytterhoeven apparently thought this was a April Fool's pull request ;) * 'x86-nuke-platforms-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, platforms: Remove NUMAQ x86, platforms: Remove SGI Visual Workstation x86, apic: Remove support for IBM Summit/EXA chipset x86, apic: Remove support for ia32-based Unisys ES7000
2014-04-02Merge branch 'x86-vdso-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 vdso changes from Peter Anvin: "This is the revamp of the 32-bit vdso and the associated cleanups. This adds timekeeping support to the 32-bit vdso that we already have in the 64-bit vdso. Although 32-bit x86 is legacy, it is likely to remain in the embedded space for a very long time to come. This removes the traditional COMPAT_VDSO support; the configuration variable is reused for simply removing the 32-bit vdso, which will produce correct results but obviously suffer a performance penalty. Only one beta version of glibc was affected, but that version was unfortunately included in one OpenSUSE release. This is not the end of the vdso cleanups. Stefani and Andy have agreed to continue work for the next kernel cycle; in fact Andy has already produced another set of cleanups that came too late for this cycle. An incidental, but arguably important, change is that this ensures that unused space in the VVAR page is properly zeroed. It wasn't before, and would contain whatever garbage was left in memory by BIOS or the bootloader. Since the VVAR page is accessible to user space this had the potential of information leaks" * 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) x86, vdso: Fix the symbol versions on the 32-bit vDSO x86, vdso, build: Don't rebuild 32-bit vdsos on every make x86, vdso: Actually discard the .discard sections x86, vdso: Fix size of get_unmapped_area() x86, vdso: Finish removing VDSO32_PRELINK x86, vdso: Move more vdso definitions into vdso.h x86: Load the 32-bit vdso in place, just like the 64-bit vdsos x86, vdso32: handle 32 bit vDSO larger one page x86, vdso32: Disable stack protector, adjust optimizations x86, vdso: Zero-pad the VVAR page x86, vdso: Add 32 bit VDSO time support for 64 bit kernel x86, vdso: Add 32 bit VDSO time support for 32 bit kernel x86, vdso: Patch alternatives in the 32-bit VDSO x86, vdso: Introduce VVAR marco for vdso32 x86, vdso: Cleanup __vdso_gettimeofday() x86, vdso: Replace VVAR(vsyscall_gtod_data) by gtod macro x86, vdso: __vdso_clock_gettime() cleanup x86, vdso: Revamp vclock_gettime.c mm: Add new func _install_special_mapping() to mmap.c x86, vdso: Make vsyscall_gtod_data handling x86 generic ...
2014-04-01Merge tag 'driver-core-3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core and sysfs updates from Greg KH: "Here's the big driver core / sysfs update for 3.15-rc1. Lots of kernfs updates to make it useful for other subsystems, and a few other tiny driver core patches. All have been in linux-next for a while" * tag 'driver-core-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (42 commits) Revert "sysfs, driver-core: remove unused {sysfs|device}_schedule_callback_owner()" kernfs: cache atomic_write_len in kernfs_open_file numa: fix NULL pointer access and memory leak in unregister_one_node() Revert "driver core: synchronize device shutdown" kernfs: fix off by one error. kernfs: remove duplicate dir.c at the top dir x86: align x86 arch with generic CPU modalias handling cpu: add generic support for CPU feature based module autoloading sysfs: create bin_attributes under the requested group driver core: unexport static function create_syslog_header firmware: use power efficient workqueue for unloading and aborting fw load firmware: give a protection when map page failed firmware: google memconsole driver fixes firmware: fix google/gsmi duplicate efivars_sysfs_init() drivers/base: delete non-required instances of include <linux/init.h> kernfs: fix kernfs_node_from_dentry() ACPI / platform: drop redundant ACPI_HANDLE check kernfs: fix hash calculation in kernfs_rename_ns() kernfs: add CONFIG_KERNFS sysfs, kobject: add sysfs wrapper for kernfs_enable_ns() ...
2014-03-20audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALLAKASHI Takahiro
Currently AUDITSYSCALL has a long list of architecture depencency: depends on AUDIT && (X86 || PARISC || PPC || S390 || IA64 || UML || SPARC64 || SUPERH || (ARM && AEABI && !OABI_COMPAT) || ALPHA) The purpose of this patch is to replace it with HAVE_ARCH_AUDITSYSCALL for simplicity. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> (arm) Acked-by: Richard Guy Briggs <rgb@redhat.com> (audit) Acked-by: Matt Turner <mattst88@gmail.com> (alpha) Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Signed-off-by: Eric Paris <eparis@redhat.com>
2014-03-18x86, vdso: Make vsyscall_gtod_data handling x86 genericStefani Seibold
This patch move the vsyscall_gtod_data handling out of vsyscall_64.c into an additonal file vsyscall_gtod.c to make the functionality available for x86 32 bit kernel. It also adds a new vsyscall_32.c which setup the VVAR page. Reviewed-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Stefani Seibold <stefani@seibold.net> Link: http://lkml.kernel.org/r/1395094933-14252-2-git-send-email-stefani@seibold.net Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-03-13x86, vdso: Remove compat vdso supportAndy Lutomirski
The compat vDSO is a complicated hack that's needed to maintain compatibility with a small range of glibc versions. This removes it and replaces it with a much simpler hack: a config option to disable the 32-bit vDSO by default. This also changes the default value of CONFIG_COMPAT_VDSO to n -- users configuring kernels from scratch almost certainly want that choice. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Link: http://lkml.kernel.org/r/4bb4690899106eb11430b1186d5cc66ca9d1660c.1394751608.git.luto@amacapital.net Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-03-04x86/efi: Wire up CONFIG_EFI_MIXEDMatt Fleming
Add the Kconfig option and bump the kernel header version so that boot loaders can check whether the handover code is available if they want. The xloadflags field in the bzImage header is also updated to reflect that the kernel supports both entry points by setting both of XLF_EFI_HANDOVER_32 and XLF_EFI_HANDOVER_64 when CONFIG_EFI_MIXED=y. XLF_CAN_BE_LOADED_ABOVE_4G is disabled so that the kernel text is guaranteed to be addressable with 32-bits. Note that no boot loaders should be using the bits set in xloadflags to decide which entry point to jump to. The entire scheme is based on the concept that 32-bit bootloaders always jump to ->handover_offset and 64-bit loaders always jump to ->handover_offset + 512. We set both bits merely to inform the boot loader that it's safe to use the native handover offset even if the machine type in the PE/COFF header claims otherwise. Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-02-27x86, platforms: Remove NUMAQH. Peter Anvin
The NUMAQ support seems to be unmaintained, remove it. Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: David Rientjes <rientjes@google.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/n/530CFD6C.7040705@zytor.com
2014-02-27x86, platforms: Remove SGI Visual WorkstationH. Peter Anvin
The SGI Visual Workstation seems to be dead; remove support so we don't have to continue maintaining it. Cc: Andrey Panin <pazke@donpac.ru> Cc: Michael Reed <mdr@sgi.com> Link: http://lkml.kernel.org/r/530CFD6C.7040705@zytor.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-02-18x86: align x86 arch with generic CPU modalias handlingArd Biesheuvel
The x86 CPU feature modalias handling existed before it was reimplemented generically. This patch aligns the x86 handling so that it (a) reuses some more code that is now generic; (b) uses the generic format for the modalias module metadata entry, i.e., it now uses 'cpu:type:x86,venVVVVfamFFFFmodMMMM:feature:,XXXX,YYYY' instead of the 'x86cpu:vendor:VVVV:family:FFFF:model:MMMM:feature:,XXXX,YYYY' that was used before. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-11x86, apic: Remove support for IBM Summit/EXA chipsetDavid Rientjes
There should no longer be any IBM x440 systems or those using the Summit/EXA chipset out in the wild, so remove support for it. We've done our due diligence in reaching out to any contact information listed for this chipset and no indication was given that it should be kept around. Signed-off-by: David Rientjes <rientjes@google.com>
2014-02-11x86, apic: Remove support for ia32-based Unisys ES7000David Rientjes
There should no longer be any ia32-based Unisys ES7000 systems out in the wild, so remove support for it. We've done our due diligence in reaching out to any contact information listed for this system and no indication was given that it should be kept around. Signed-off-by: David Rientjes <rientjes@google.com>
2014-02-07Merge tag 'efi-urgent' into x86/urgentH. Peter Anvin
* Avoid WARN_ON() when mapping BGRT on Baytrail (EFI 32-bit). Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-25x86/intel/mid: Fix X86_INTEL_MID dependenciesDavid Cohen
This patch fixes the following warning: warning: (X86_INTEL_MID) selects INTEL_SCU_IPC which has unmet direct dependencies (X86 && X86_PLATFORM_DEVICES && X86_INTEL_MID) It happens because when selected, X86_INTEL_MID tries to select INTEL_SCU_IPC regardless all its dependencies are met or not. This patch fixes it by adding the missing X86_PLATFORM_DEVICES dependency to X86_INTEL_MID. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: David Cohen <david.a.cohen@linux.intel.com> Link: http://lkml.kernel.org/r/1390329699-20782-1-git-send-email-david.a.cohen@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-25Merge branch 'linus' into x86/urgentIngo Molnar
Merge in the x86 changes to apply a fix. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem updates from Dmitry Torokhov: "Just a swath of driver fixes and cleanups, no new drivers this time (although ALPS now supports one of the newer protocols, more to come)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (57 commits) Input: wacom - add support for DTU-1031 Input: wacom - fix wacom->shared guards for dual input devices Input: edt_ft5x06 - use devm_* functions where appropriate Input: hyperv-keyboard - pass through 0xE1 prefix Input: logips2pp - fix spelling s/reciver/receiver/ Input: delete non-required instances of include <linux/init.h> Input: twl4030-keypad - convert to using managed resources Input: twl6040-vibra - remove unneeded check for CONFIG_OF Input: twl4030-keypad - add device tree support Input: twl6040-vibra - add missing of_node_put Input: twl4030-vibra - add missing of_node_put Input: i8042 - cleanup SERIO_I8042 dependencies Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on x86 Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on unicore32 Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on sparc Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO for SH_CAYMAN Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on powerpc Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on mips Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on IA64 Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on ARM/Footbridge ...
2014-01-23Kconfig: update flightly outdated CONFIG_SMP documentationRobert Graffham
Remove an outdated reference to "most personal computers" having only one CPU, and change the use of "singleprocessor" and "single processor" in CONFIG_SMP's documentation to "uniprocessor" across all arches where that documentation is present. Signed-off-by: Robert Graffham <psquid@psquid.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23firmware/dmi_scan: generalize for use by other archsArd Biesheuvel
This patch makes a couple of changes to the SMBIOS/DMI scanning code so it can be used on other archs (such as ARM and arm64): (a) wrap the calls to ioremap()/iounmap(), this allows the use of a flavor of ioremap() more suitable for random unaligned access; (b) allow the non-EFI fallback probe into hardcoded physical address 0xF0000 to be disabled. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Grant Likely <grant.likely@linaro.org> Cc: Ingo Molnar <mingo@elte.hu> Cc "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual rocket science stuff from trivial.git" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) neighbour.h: fix comment sched: Fix warning on make htmldocs caused by wait.h slab: struct kmem_cache is protected by slab_mutex doc: Fix typo in USB Gadget Documentation of/Kconfig: Spelling s/one/once/ mkregtable: Fix sscanf handling lp5523, lp8501: comment improvements thermal: rcar: comment spelling treewide: fix comments and printk msgs IXP4xx: remove '1 &&' from a condition check in ixp4xx_restart() Documentation: update /proc/uptime field description Documentation: Fix size parameter for snprintf arm: fix comment header and macro name asm-generic: uaccess: Spelling s/a ny/any/ mtd: onenand: fix comment header doc: driver-model/platform.txt: fix a typo drivers: fix typo in DEVTMPFS_MOUNT Kconfig help text doc: Fix typo (acces_process_vm -> access_process_vm) treewide: Fix typos in printk drivers/gpu/drm/qxl/Kconfig: reformat the help text ...
2014-01-20Merge branch 'x86-kaslr-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 kernel address space randomization support from Peter Anvin: "This enables kernel address space randomization for x86" * 'x86-kaslr-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, kaslr: Clarify RANDOMIZE_BASE_MAX_OFFSET x86, kaslr: Remove unused including <linux/version.h> x86, kaslr: Use char array to gain sizeof sanity x86, kaslr: Add a circular multiply for better bit diffusion x86, kaslr: Mix entropy sources together as needed x86/relocs: Add percpu fixup for GNU ld 2.23 x86, boot: Rename get_flags() and check_flags() to *_cpuflags() x86, kaslr: Raise the maximum virtual address to -1 GiB on x86_64 x86, kaslr: Report kernel offset on panic x86, kaslr: Select random position from e820 maps x86, kaslr: Provide randomness functions x86, kaslr: Return location from decompress_kernel x86, boot: Move CPU flags out of cpucheck x86, relocs: Add more per-cpu gold special cases
